  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 515.0k Aufrufe 35 Beobachtet
  • J Jan1
    @apollon77
    Der compact mode läuft mit Version 2.0.6 nicht mehr. Der admin restartet ständig.
    hier mal ein Log:
    admin.0	2019-09-22 08:50:22.584	info	(COMPACT) received all states
    admin.0	2019-09-22 08:50:22.024	info	(COMPACT) Request actual repository...
    admin.0	2019-09-22 08:50:22.024	info	(COMPACT) requesting all objects
    admin.0	2019-09-22 08:50:22.022	info	(COMPACT) requesting all states
    admin.0	2019-09-22 08:50:22.015	info	(COMPACT) starting. Version 3.6.5 in /opt/iobroker/node_modules/iobroker.admin, node: v10.16.3
    admin.0	2019-09-22 08:49:51.387	info	(COMPACT) terminating
    admin.0	2019-09-22 08:49:50.884	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    admin.0	2019-09-22 08:49:50.881	info	(COMPACT) terminating
    admin.0	2019-09-22 08:49:50.880	info	(COMPACT) terminating http server on port 8081
    admin.0	2019-09-22 08:49:50.877	info	(COMPACT) Got terminate signal.
    tankerkoenig.0	2019-09-22 08:49:44.927	info	(COMPACT) Reading data from tankerkoenig ...
    tankerkoenig.0	2019-09-22 08:49:44.907	info	(COMPACT) Sync time set to 9 minutes or 540000 ms
    tankerkoenig.0	2019-09-22 08:49:44.905	info	(COMPACT) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v10.16.3
    telegram.0	2019-09-22 08:49:43.651	info	(COMPACT) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v10.16.3
    host.Beelink.compactgroup1	2019-09-22 08:49:43.068	info	instance system.adapter.telegram.0 started in COMPACT mode
    harmony.0	2019-09-22 08:49:38.881	info	(COMPACT) [PROCESS] Synced hub config for Harmony Hub (192.168.100.44)
    host.Beelink.compactgroup1	2019-09-22 08:49:38.871	info	instance system.adapter.tankerkoenig.0 started in COMPACT mode
    harmony.0	2019-09-22 08:49:37.791	info	(COMPACT) [CONNECT] Connected to Harmony Hub (192.168.100.44)
    harmony.0	2019-09-22 08:49:36.633	info	(COMPACT) [CONNECT] Connecting to Harmony Hub (192.168.100.44)
    harmony.0	2019-09-22 08:49:36.556	info	(COMPACT) [DISCOVER] Discovered Harmony Hub (192.168.100.44) and will try to connect
    harmony.0	2019-09-22 08:49:35.362	info	(COMPACT) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
    harmony.0	2019-09-22 08:49:35.354	info	(COMPACT) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.harmony, node: v10.16.3
    host.Beelink.compactgroup1	2019-09-22 08:49:34.995	info	instance system.adapter.harmony.0 started in COMPACT mode
    history.0	2019-09-22 08:49:31.181	info	(COMPACT) enabled logging of admin.0.Datenpunkte.Heizung.HZ_Regelung_laeuft (Count=1), Alias=false
    history.0	2019-09-22 08:49:31.155	info	(COMPACT) starting. Version 1.8.7 in /opt/iobroker/node_modules/iobroker.history, node: v10.16.3
    host.Beelink.compactgroup1	2019-09-22 08:49:30.736	info	instance system.adapter.history.0 started in COMPACT mode
    backitup.0	2019-09-22 08:49:28.851	info	(COMPACT) [total] backup was activated at 03:00 every 7 day(s)
    backitup.0	2019-09-22 08:49:28.838	info	(COMPACT) [minimal] backup was activated at 02:00 every 2 day(s)
    backitup.0	2019-09-22 08:49:28.818	info	(COMPACT) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.16.3
    host.Beelink.compactgroup1	2019-09-22 08:49:27.952	info	instance system.adapter.backitup.0 started in COMPACT mode
    admin.0	2019-09-22 08:49:25.560	info	(COMPACT) Repository received successfully.
    admin.0	2019-09-22 08:49:25.004	info	(COMPACT) Use link "http://localhost:8081" to configure.
    admin.0	2019-09-22 08:49:25.003	info	(COMPACT) http server listening on port 8081
    admin.0	2019-09-22 08:49:24.916	info	(COMPACT) received all objects
    admin.0	2019-09-22 08:49:24.626	info	(COMPACT) received all states
    host.Beelink	2019-09-22 08:49:24.613	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    admin.0	2019-09-22 08:49:24.112	info	(COMPACT) Request actual repository...
    admin.0	2019-09-22 08:49:24.110	info	(COMPACT) requesting all objects
    admin.0	2019-09-22 08:49:24.108	info	(COMPACT) requesting all states
    admin.0	2019-09-22 08:49:24.100	info	(COMPACT) starting. Version 3.6.5 in /opt/iobroker/node_modules/iobroker.admin, node: v10.16.3
    host.Beelink.compactgroup1	2019-09-22 08:49:23.304	info	instance system.adapter.admin.0 started in COMPACT mode
    host.Beelink.compactgroup1	2019-09-22 08:49:22.703	info	starting 6 instances
    host.Beelink.compactgroup1	2019-09-22 08:49:22.546	info	connected to Objects and States
    host.Beelink.compactgroup1	2019-09-22 08:49:22.465	info	iobroker.js-controller version 2.0.6 js-controller starting
    host.Beelink	2019-09-22 08:49:21.895	info	instance system.adapter.telegram.0 is handled by compact group controller pid 10508
    host.Beelink	2019-09-22 08:49:21.876	info	start controller for compactgroup 1
       2019-09-22 08:49:20.872	info	"system.adapter.admin.0","system.adapter.backitup.0","system.adapter.iot.0","system.adapter.history.0","system.adapter.harmony.0","system.adapter.tankerkoenig.0","system.adapter.telegram.0","system.ad
    host.Beelink	2019-09-22 08:49:20.872	info	Restart compact group controller 1
    host.Beelink	2019-09-22 08:49:20.872	error	Caught by controller[11]: at Timer.processTimers (timers.js:223:10)
    host.Beelink	2019-09-22 08:49:20.872	error	Caught by controller[11]: at listOnTimeout (timers.js:263:5)
    host.Beelink	2019-09-22 08:49:20.872	error	Caught by controller[11]: at tryOnTimeout (timers.js:300:5)
    host.Beelink	2019-09-22 08:49:20.872	error	Caught by controller[11]: at ontimeout (timers.js:436:11)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at process.exit (internal/process/per_thread.js:168:15)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at process.emit (events.js:203:15)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Object.onceWrapper (events.js:286:20)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Adapter.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[11]: TypeError: Cannot read property 'setState' of null
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[10]: at Timer.processTimers (timers.js:223:10)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[10]: at listOnTimeout (timers.js:263:5)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[10]: at tryOnTimeout (timers.js:300:5)
    host.Beelink	2019-09-22 08:49:20.871	error	Caught by controller[10]: at ontimeout (timers.js:436:11)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at process.exit (internal/process/per_thread.js:168:15)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at process.emit (events.js:203:15)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Object.onceWrapper (events.js:286:20)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Adapter.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[10]: TypeError: Cannot read property 'setState' of null
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[9]: at Timer.processTimers (timers.js:223:10)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[9]: at listOnTimeout (timers.js:263:5)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[9]: at tryOnTimeout (timers.js:300:5)
    host.Beelink	2019-09-22 08:49:20.870	error	Caught by controller[9]: at ontimeout (timers.js:436:11)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at process.exit (internal/process/per_thread.js:168:15)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at process.emit (events.js:203:15)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Object.onceWrapper (events.js:286:20)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Adapter.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[9]: TypeError: Cannot read property 'setState' of null
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[8]: at Timer.processTimers (timers.js:223:10)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[8]: at listOnTimeout (timers.js:263:5)
    host.Beelink	2019-09-22 08:49:20.869	error	Caught by controller[8]: at tryOnTimeout (timers.js:300:5)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at ontimeout (timers.js:436:11)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at process.exit (internal/process/per_thread.js:168:15)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at process.emit (events.js:203:15)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Object.onceWrapper (events.js:286:20)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Adapter.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[8]: TypeError: Cannot read property 'setState' of null
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[7]: at Timer.processTimers (timers.js:223:10)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[7]: at listOnTimeout (timers.js:263:5)
    host.Beelink	2019-09-22 08:49:20.868	error	Caught by controller[7]: at tryOnTimeout (timers.js:300:5)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at ontimeout (timers.js:436:11)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at process.exit (internal/process/per_thread.js:168:15)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at process.emit (events.js:203:15)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Object.onceWrapper (events.js:286:20)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Adapter.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: TypeError: Cannot read property 'setState' of null
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at Timer.processTimers (timers.js:223:10)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at listOnTimeout (timers.js:263:5)
    host.Beelink	2019-09-22 08:49:20.867	error	Caught by controller[7]: at tryOnTimeout (timers.js:300:5)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at ontimeout (timers.js:436:11)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at process.exit (internal/process/per_thread.js:168:15)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at process.emit (events.js:203:15)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Object.onceWrapper (events.js:286:20)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Adapter.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[7]: TypeError: Cannot read property 'setState' of null
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[6]: at process._tickCallback (internal/process/next_tick.js:61:11)
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[6]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
    host.Beelink	2019-09-22 08:49:20.866	error	Caught by controller[6]: at Socket.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[6]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[6]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[6]: TypeError: Cannot read property 'pushMessage' of null
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at process._tickCallback (internal/process/next_tick.js:61:11)
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at Socket.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[5]: TypeError: Cannot read property 'pushMessage' of null
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[4]: at process._tickCallback (internal/process/next_tick.js:61:11)
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[4]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
    host.Beelink	2019-09-22 08:49:20.865	error	Caught by controller[4]: at Socket.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[4]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[4]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[4]: TypeError: Cannot read property 'pushMessage' of null
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at process._tickCallback (internal/process/next_tick.js:61:11)
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at Socket.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[3]: TypeError: Cannot read property 'pushMessage' of null
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[2]: at process._tickCallback (internal/process/next_tick.js:61:11)
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
    host.Beelink	2019-09-22 08:49:20.864	error	Caught by controller[2]: at Socket.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[2]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[2]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[2]: TypeError: Cannot read property 'pushMessage' of null
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:61:11)
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/lib/socket.js:503:12
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at Socket.emit (events.js:198:13)
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/socket.js:878:25)
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: at Adapter.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4732:29)
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[1]: TypeError: Cannot read property 'pushMessage' of null
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319. at internal/modules/cjs/loader.js:778:30
    host.Beelink	2019-09-22 08:49:20.863	error	Caught by controller[0]: In the future, you will have to enable it yourself.
    host.Beelink	2019-09-22 08:49:20.862	error	Caught by controller[0]: Sun, 22 Sep 2019 06:49:06 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	warn	stopInstance system.adapter.simple-api.0 not running
    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.simple-api.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.iqontrol.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.alexa2.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.info.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.735	info	stopInstance system.adapter.fritzdect.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	info	stopInstance system.adapter.javascript.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	warn	stopInstance system.adapter.telegram.0 not running
    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	info	stopInstance system.adapter.telegram.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	warn	stopInstance system.adapter.tankerkoenig.0 not running
    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	info	stopInstance system.adapter.tankerkoenig.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.734	warn	stopInstance system.adapter.harmony.0 not running
    host.Beelink.compactgroup1	2019-09-22 08:49:20.733	info	stopInstance system.adapter.harmony.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.733	warn	stopInstance system.adapter.history.0 not running
    host.Beelink.compactgroup1	2019-09-22 08:49:20.733	info	stopInstance system.adapter.history.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.732	info	stopInstance system.adapter.iot.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.732	warn	stopInstance system.adapter.backitup.0 not running
    host.Beelink.compactgroup1	2019-09-22 08:49:20.732	info	stopInstance system.adapter.backitup.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.731	warn	stopInstance system.adapter.admin.0 not running
    host.Beelink.compactgroup1	2019-09-22 08:49:20.731	info	stopInstance system.adapter.admin.0
    host.Beelink.compactgroup1	2019-09-22 08:49:20.728	warn	Slave controller detected disconnection. Stop all instances.
    tankerkoenig.0	2019-09-22 08:49:20.286	info	(COMPACT) terminating
    harmony.0	2019-09-22 08:49:20.285	info	(COMPACT) terminating
    backitup.0	2019-09-22 08:49:20.279	info	(COMPACT) terminating
    admin.0	2019-09-22 08:49:20.278	info	(COMPACT) terminating
    telegram.0	2019-09-22 08:49:19.786	error	(COMPACT) exception by stop: Cannot read property 'setState' of null
    telegram.0	2019-09-22 08:49:19.786	error	at Timer.processTimers (timers.js:223:10)
    telegram.0	2019-09-22 08:49:19.786	error	at listOnTimeout (timers.js:263:5)
    telegram.0	2019-09-22 08:49:19.786	error	at tryOnTimeout (timers.js:300:5)
    telegram.0	2019-09-22 08:49:19.786	error	at ontimeout (timers.js:436:11)
    telegram.0	2019-09-22 08:49:19.786	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    telegram.0	2019-09-22 08:49:19.786	error	at process.exit (internal/process/per_thread.js:168:15)
    telegram.0	2019-09-22 08:49:19.786	error	at process.emit (events.js:203:15)
    telegram.0	2019-09-22 08:49:19.786	error	at Object.onceWrapper (events.js:286:20)
    telegram.0	2019-09-22 08:49:19.786	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    telegram.0	2019-09-22 08:49:19.786	error	at Adapter.emit (events.js:198:13)
    telegram.0	2019-09-22 08:49:19.786	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    telegram.0	2019-09-22 08:49:19.786	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    telegram.0	2019-09-22 08:49:19.786	error	(COMPACT) TypeError: Cannot read property 'setState' of null
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Timer.processTimers (timers.js:223:10)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at listOnTimeout (timers.js:263:5)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at tryOnTimeout (timers.js:300:5)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at ontimeout (timers.js:436:11)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at process.exit (internal/process/per_thread.js:168:15)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at process.emit (events.js:203:15)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Object.onceWrapper (events.js:286:20)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Adapter.emit (events.js:198:13)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    tankerkoenig.0	2019-09-22 08:49:19.785	error	(COMPACT) TypeError: Cannot read property 'setState' of null
    history.0	2019-09-22 08:49:19.783	info	(COMPACT) terminating
    history.0	2019-09-22 08:49:19.783	error	at Timer.processTimers (timers.js:223:10)
    history.0	2019-09-22 08:49:19.783	error	at listOnTimeout (timers.js:263:5)
    history.0	2019-09-22 08:49:19.783	error	at tryOnTimeout (timers.js:300:5)
    history.0	2019-09-22 08:49:19.783	error	at ontimeout (timers.js:436:11)
    history.0	2019-09-22 08:49:19.783	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    history.0	2019-09-22 08:49:19.783	error	at process.exit (internal/process/per_thread.js:168:15)
    history.0	2019-09-22 08:49:19.783	error	at process.emit (events.js:203:15)
    history.0	2019-09-22 08:49:19.783	error	at Object.onceWrapper (events.js:286:20)
    history.0	2019-09-22 08:49:19.783	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    history.0	2019-09-22 08:49:19.783	error	at Adapter.emit (events.js:198:13)
    history.0	2019-09-22 08:49:19.783	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    history.0	2019-09-22 08:49:19.783	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    history.0	2019-09-22 08:49:19.783	error	(COMPACT) TypeError: Cannot read property 'setState' of null
    backitup.0	2019-09-22 08:49:19.778	error	at Timer.processTimers (timers.js:223:10)
    backitup.0	2019-09-22 08:49:19.778	error	at listOnTimeout (timers.js:263:5)
    backitup.0	2019-09-22 08:49:19.778	error	at tryOnTimeout (timers.js:300:5)
    backitup.0	2019-09-22 08:49:19.778	error	at ontimeout (timers.js:436:11)
    backitup.0	2019-09-22 08:49:19.778	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    backitup.0	2019-09-22 08:49:19.778	error	at process.exit (internal/process/per_thread.js:168:15)
    backitup.0	2019-09-22 08:49:19.778	error	at process.emit (events.js:203:15)
    backitup.0	2019-09-22 08:49:19.778	error	at Object.onceWrapper (events.js:286:20)
    backitup.0	2019-09-22 08:49:19.778	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    backitup.0	2019-09-22 08:49:19.778	error	at Adapter.emit (events.js:198:13)
    backitup.0	2019-09-22 08:49:19.778	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    backitup.0	2019-09-22 08:49:19.778	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    backitup.0	2019-09-22 08:49:19.778	error	(COMPACT) TypeError: Cannot read property 'setState' of null
    harmony.0	2019-09-22 08:49:19.784	info	(COMPACT) terminating
    harmony.0	2019-09-22 08:49:19.784	info	(COMPACT) [END] Terminating
    harmony.0	2019-09-22 08:49:19.784	error	at Timer.processTimers (timers.js:223:10)
    harmony.0	2019-09-22 08:49:19.784	error	at listOnTimeout (timers.js:263:5)
    harmony.0	2019-09-22 08:49:19.784	error	at tryOnTimeout (timers.js:300:5)
    harmony.0	2019-09-22 08:49:19.784	error	at ontimeout (timers.js:436:11)
    harmony.0	2019-09-22 08:49:19.784	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/main.js:3425:38)
    harmony.0	2019-09-22 08:49:19.784	error	at process.exit (internal/process/per_thread.js:168:15)
    harmony.0	2019-09-22 08:49:19.784	error	at process.emit (events.js:203:15)
    harmony.0	2019-09-22 08:49:19.784	error	at Object.onceWrapper (events.js:286:20)
    harmony.0	2019-09-22 08:49:19.784	error	at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6730:18)
    harmony.0	2019-09-22 08:49:19.784	error	at Adapter.emit (events.js:198:13)
    harmony.0	2019-09-22 08:49:19.784	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.telegram/main.js:172:50)
    harmony.0	2019-09-22 08:49:19.784	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4846:33)
    harmony.0	2019-09-22 08:49:19.784	error	(COMPACT) TypeError: Cannot read property 'setState' of null
    harmony.0	2019-09-22 08:49:19.784	error	(COMPACT) uncaught exception: Cannot read property 'setState' of null
    admin.0	2019-09-22 08:49:19.777	info	(COMPACT) terminating
    admin.0	2019-09-22 08:49:19.776	info	(COMPACT) terminating http server on port 8081
    apollon77A
    apollon77A
    #90
    @Jan1 Mist. Schaue ich mir an
    • apollon77A apollon77
      J
      J
      Jan1
      #91
      @apollon77
      keine Panik, wenn ich den compact modus disable, läuft ja alles und das ist in ein paar Sekunden umgestellt 😉
        @opossum sagte in [Aufruf] js-controller 2.0 Beta Test:
        … wo muss ich meine eigenen Icons jetzt hinkopieren?
        Am Besten im VIS-Editor unter 'Setup' - 'Dateimanager' in den Ordner '/vis.0/' hochladen indem du auf den Upload-Button klickst.
        Unter vis.0 kann man auch eigene Unterordner erstellen.
        Wenn man das direkt auf dem ioBroker-Rechner machen möchte, gehören die Dateien nach /opt/iobroker/iobroker-data/files/vis.0
        opossumO
        opossumO
        opossum
        #92
        erst mal danke für die schnelle Antwort.
        @Dr-Bakterius sagte in [Aufruf] js-controller 2.0 Beta Test:
        habe ich kopiert:
        Aber sie werden mir im Auswahldialog leider nicht angezeigt:
        Irgend etwas ist noch nicht korrekt bei mir. Klicke ich auf den Uploadbutton, dann kommt bei mir folgendes:
        Ich kann von dort auch hochladen, aber in der Auswahl sieht das dann so aus:
        Dabei stehen die Rechte der Dateien wie folgt:
        Sorry, wenn ich nerve.
        Egbert
        https://www.schlepper-petersdorf.de
        • J Jan1
          @apollon77
          hier mal ein Log:
          apollon77A
          apollon77A
          #93
          @Jan1 Liegt nicht direkt an der 2.0.6 ... ist ein "Timing" thema. fix kommt in 2.0.7
          • opossumO opossum
            habe ich kopiert:
            Egbert
            apollon77A
            apollon77A
            #94
            @opossum vis upload vor der 1.2.1 war kaputt. Bitte 1.2.1 aus latest installieren
            opossumO 1 Antwort Letzte Antwort
              opossumO
              opossumO
              opossum
              schrieb am zuletzt editiert von opossum
              #95
              das war es, nun funktioniert das. Danke @apollon77, dann werde meine vis umstellen.
              Egbert
              • J Jan1
                @apollon77
                Hier mal das Log wenn ich den BLE neustarte:
                host.Beelink	2019-09-20 18:01:34.337	info	Restart compact group controller 1
                host.Beelink	2019-09-20 18:01:34.337	error	Caught by controller[13]: at process._fatalException (internal/bootstrap/node.js:496:27)
                host.Beelink	2019-09-20 18:01:34.337	error	Caught by controller[13]: at process.emit (events.js:203:15)
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[13]: at process.on.err (/opt/iobroker/node_modules/iobroker.ble/build/main.js:382:17)
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[13]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[13]: ^
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[13]: adapter.log.error("unhandled exception:" + err.message);
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[13]: /opt/iobroker/node_modules/iobroker.ble/build/main.js:382
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[12]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[12]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[12]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.336	error	Caught by controller[12]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[12]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[11]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[11]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[11]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[11]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[11]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[10]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[10]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[10]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.335	error	Caught by controller[10]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.334	error	Caught by controller[10]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.334	error	Caught by controller[9]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.334	error	Caught by controller[9]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.334	error	Caught by controller[9]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.334	error	Caught by controller[9]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.334	error	Caught by controller[9]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.334	error	Caught by controller[8]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.334	error	Caught by controller[8]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.333	error	Caught by controller[8]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.333	error	Caught by controller[8]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.333	error	Caught by controller[8]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.333	error	Caught by controller[7]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.333	error	Caught by controller[7]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.333	error	Caught by controller[7]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.333	error	Caught by controller[7]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.333	error	Caught by controller[7]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[6]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[6]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[6]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[6]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[6]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[5]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[5]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[5]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.332	error	Caught by controller[5]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.331	error	Caught by controller[5]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.331	error	Caught by controller[4]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.331	error	Caught by controller[4]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.331	error	Caught by controller[4]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.331	error	Caught by controller[4]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.331	error	Caught by controller[4]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.331	error	Caught by controller[3]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.331	error	Caught by controller[3]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[3]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[3]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[3]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[2]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[2]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[2]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[2]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[2]: TypeError: Cannot read property 'error' of undefined
                host.Beelink	2019-09-20 18:01:34.330	error	Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:69:34)
                host.Beelink	2019-09-20 18:01:34.329	error	Caught by controller[1]: at emitPromiseRejectionWarnings (internal/process/promises.js:119:20)
                host.Beelink	2019-09-20 18:01:34.329	error	Caught by controller[1]: at process.emit (events.js:198:13)
                host.Beelink	2019-09-20 18:01:34.329	error	Caught by controller[1]: at process.on.r (/opt/iobroker/node_modules/iobroker.ble/build/main.js:377:17)
                host.Beelink	2019-09-20 18:01:34.329	error	Caught by controller[1]: TypeError: Cannot read property 'error' of undefined
                iqontrol.0	2019-09-20 18:01:34.188	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                alexa2.0	2019-09-20 18:01:34.185	warn	(COMPACT) Exception: TypeError: Cannot read property 'error' of undefined
                info.0	2019-09-20 18:01:34.183	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                fritzdect.0	2019-09-20 18:01:34.181	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                javascript.0	2019-09-20 18:01:34.169	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                telegram.0	2019-09-20 18:01:34.167	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                tankerkoenig.0	2019-09-20 18:01:34.165	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                harmony.0	2019-09-20 18:01:34.162	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                history.0	2019-09-20 18:01:34.155	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                iot.0	2019-09-20 18:01:34.152	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                backitup.0	2019-09-20 18:01:34.150	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                admin.0	2019-09-20 18:01:34.138	error	(COMPACT) uncaught exception: Cannot read property 'error' of undefined
                ble	2019-09-20 18:01:33.387	warn	(COMPACT) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                ble	2019-09-20 18:01:33.386	error	(COMPACT) ble.0 already running
                host.Beelink.compactgroup1	2019-09-20 18:01:33.361	error	Cannot start ble.0 in compact mode: Cannot read property 'on' of undefined
                host.Beelink	2019-09-20 18:01:33.351	info	stopInstance system.adapter.ble.0
                host.Beelink	2019-09-20 18:01:33.350	info	object change system.adapter.ble.0 (from: system.adapter.admin.0)
                host.Beelink.compactgroup1	2019-09-20 18:01:41.391	info	instance system.adapter.backitup.0 started in COMPACT mode
                Dann noch die comact mode Übersicht:
                root@Beelink:~# iobroker list instances
                + system.adapter.admin.0                 : admin                 -  enabled, compact enabled (group 1), port: 8081, bind: 0.0.0.0, run as: admin
                 system.adapter.admin.1                 : admin                 - disabled, compact disabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                + system.adapter.alexa2.0                : alexa2                -  enabled, compact enabled (group 1)
                + system.adapter.backitup.0              : backitup              -  enabled, compact enabled (group 1)
                + system.adapter.ble.0                   : ble                   -  enabled, compact disabled
                + system.adapter.email.0                 : email                 -  enabled, compact disabled
                + system.adapter.enigma2.0               : enigma2               -  enabled, compact disabled
                + system.adapter.fritzdect.0             : fritzdect             -  enabled, compact enabled (group 1)
                + system.adapter.google-sharedlocations.0: google-sharedlocations -  enabled, compact disabled
                + system.adapter.harmony.0               : harmony               -  enabled, compact enabled (group 1)
                + system.adapter.history.0               : history               -  enabled, compact enabled (group 1)
                 system.adapter.ical.0                  : ical                  -  enabled, compact disabled
                + system.adapter.info.0                  : info                  -  enabled, compact enabled (group 1)
                + system.adapter.iot.0                   : iot                   -  enabled, compact enabled (group 1)
                + system.adapter.iqontrol.0              : iqontrol              -  enabled, compact enabled (group 1)
                + system.adapter.javascript.0            : javascript            -  enabled, compact enabled (group 1)
                + system.adapter.milight-smart-light.0   : milight-smart-light   -  enabled, compact disabled
                + system.adapter.node-red.0              : node-red              -  enabled, compact disabled, port: 1880, bind: 0.0.0.0
                 system.adapter.openweathermap.0        : openweathermap        -  enabled, compact disabled
                + system.adapter.scenes.0                : scenes                -  enabled, compact disabled
                 system.adapter.simple-api.0            : simple-api            -  enabled, compact enabled (group 1), port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.sonoff.0                : sonoff                -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                + system.adapter.tankerkoenig.0          : tankerkoenig          -  enabled, compact enabled (group 1)
                + system.adapter.telegram.0              : telegram              -  enabled, compact enabled (group 1), port: 8443, bind: 0.0.0.0
                + system.adapter.tr-064-community.0      : tr-064-community      -  enabled, compact disabled
                + system.adapter.vr200.0                 : vr200                 -  enabled, compact disabled
                + system.adapter.web.0                   : web                   -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.wifilight.0             : wifilight             -  enabled, compact disabled
                + system.adapter.zigbee.0                : zigbee                -  enabled, compact disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED3DD2-if00
                + instance is alive
                AlCalzoneA
                AlCalzoneA
                AlCalzone
                #96
                @Jan1 Kannst du bitte BLE v0.9.1 probieren?
                • AlCalzoneA AlCalzone
                  apollon77A
                  apollon77A
                  #97
                  @AlCalzone @Jan1 bitte warte mal noch :-)) Ich würde gern das Du die alte nochmal mit der 2.0.7 vom controller testet :-)) geht das? Ich finalisiere den jetzt
                  • apollon77A
                    apollon77A
                    #98
                    Sooooooo ... Auf GitHub haben wir jetzt die 2.0.7 vom js-controller.
                    Änderungen und Test-Bitten:
                    • Ich habe nochmal am Fallback-Handling bei Adaptern mit "kaputtem" Compact-Mode gearbeitet. Bitte mit der "alten" BLE Version nochmal testen :-) Danach die neue gern auch
                    • In einigen Fällen konnten in den File-DB-Strukturen Fehler entstehen die dann dazugefhrt haben das Files nicht angezeigt wurden, Diese werden nun beim lesen behoben.
                    • Slaves sollten jetzt Disconnects (von der Objects-DB!) besser erkennen und ggf in 30s Intervallen neu versuchen. @e-i-k-e Schaunochmal wie sich die Slaves jetzt verhalten wenn der Master weg ist. AM besten die Slaves zuerst auf 2.0.7, dann starten und dann den Master ... Ein Log wäre wieder interessant
                    J E 2 Antworten Letzte Antwort
                      J
                      J
                      Jan1
                      #99
                      @apollon77
                      jetzt läuft alles im compact mode wie es soll (mit BLE 0.9.0). Keine Fehler oder Warnungen im Log, ale Adapter lassen sich einzeln neu starten, ohne Auswirkung auf das System
                      @AlCalzone
                      BLE 0.9.1 funktioniert nun auch im compact modus.
                      • J Jan1
                        @apollon77
                        @AlCalzone
                        apollon77A
                        apollon77A
                        #100
                        @Jan1 sagte in [Aufruf] js-controller 2.0 Beta Test:
                        @apollon77
                        Hast Du mal noch ein Log von so einem 0.9.0 versuch?! Aber cool
                          @apollon77
                          J
                          J
                          Jan1
                          #101
                          @apollon77
                          nein, weil alles sauber war und keine Fehler oder Warnungen drin standen. Wenn Du willst, hau ich noch mal die 0.9.0 Version ndes BLE drauf.
                          • J Jan1
                            @apollon77
                            apollon77A
                            apollon77A
                            #102
                            @Jan1 Ich hätte mindestesn eine Meldung "compact geht nicht daher starte ich normal" erwartet und dann sollte der start direkt erfolgen und ein pot. gestarteter compact sollte sich beenden.
                              J
                              J
                              Jan1
                              #103
                              @apollon77
                              so hab noch mal die 0.9.0 drauf und den compact modus aktiviert, jetzt waren plötzlich viele Fehler im Log
                              host.Beelink.compactgroup1	2019-09-23 08:56:08.158	info	Restart adapter system.adapter.ble.0 because enabled
                              host.Beelink.compactgroup1	2019-09-23 08:56:08.157	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                              ble	2019-09-23 08:56:08.097	error	(13338) ble.0 already running
                              ble.0	2019-09-23 08:56:07.851	info	(COMPACT) monitored services: fe95
                              ble.0	2019-09-23 08:56:07.851	info	(COMPACT) enabled plugins: mi-flora, _default
                              ble.0	2019-09-23 08:56:07.850	info	(COMPACT) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                              ble.0	2019-09-23 08:56:07.721	info	(COMPACT) starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v10.16.3
                              host.Beelink.compactgroup1	2019-09-23 08:56:07.407	info	instance system.adapter.ble.0 started with pid 13338
                                 2019-09-23 08:56:07.385	error	ndefined
                              host.Beelink.compactgroup1	2019-09-23 08:56:07.385	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
                              host.Beelink.compactgroup1	2019-09-23 08:55:37.362	info	Restart adapter system.adapter.ble.0 because enabled
                              host.Beelink.compactgroup1	2019-09-23 08:55:37.361	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                              ble	2019-09-23 08:55:37.295	error	(12663) ble.0 already running
                              ble.0	2019-09-23 08:55:37.177	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:55:37.175	info	(COMPACT) terminating
                              ble	2019-09-23 08:55:36.694	warn	(COMPACT) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                              ble	2019-09-23 08:55:36.693	error	(COMPACT) ble.0 already running
                              ble.0	2019-09-23 08:55:36.676	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:55:36.675	info	(COMPACT) stopping scan
                              ble.0	2019-09-23 08:55:36.675	info	(COMPACT) Got terminate signal 12663
                              ble.0	2019-09-23 08:55:36.674	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              ble.0	2019-09-23 08:55:36.674	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:55:36.673	info	(COMPACT) stopping scan
                              ble.0	2019-09-23 08:55:36.672	info	(COMPACT) Got terminate signal -1
                              host.Beelink.compactgroup1	2019-09-23 08:55:36.667	info	instance system.adapter.ble.0 started with pid 12663
                                 2019-09-23 08:55:36.648	error	ndefined
                              host.Beelink.compactgroup1	2019-09-23 08:55:36.648	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
                              host.Beelink.compactgroup1	2019-09-23 08:55:06.630	info	Restart adapter system.adapter.ble.0 because enabled
                              host.Beelink.compactgroup1	2019-09-23 08:55:06.629	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                              ble	2019-09-23 08:55:06.569	error	(11988) ble.0 already running
                              ble.0	2019-09-23 08:55:06.435	info	(COMPACT) monitored services: fe95
                              ble.0	2019-09-23 08:55:06.435	info	(COMPACT) enabled plugins: mi-flora, _default
                              ble.0	2019-09-23 08:55:06.434	info	(COMPACT) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                              ble.0	2019-09-23 08:55:06.278	info	(COMPACT) starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v10.16.3
                              host.Beelink.compactgroup1	2019-09-23 08:55:05.904	info	instance system.adapter.ble.0 started with pid 11988
                                 2019-09-23 08:55:05.886	error	ndefined
                              host.Beelink.compactgroup1	2019-09-23 08:55:05.885	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
                              host.Beelink.compactgroup1	2019-09-23 08:54:35.866	info	Restart adapter system.adapter.ble.0 because enabled
                              host.Beelink.compactgroup1	2019-09-23 08:54:35.865	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                              ble	2019-09-23 08:54:35.798	error	(11309) ble.0 already running
                              ble.0	2019-09-23 08:54:35.630	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:54:35.628	info	(COMPACT) terminating
                              ble	2019-09-23 08:54:35.179	warn	(COMPACT) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                              ble	2019-09-23 08:54:35.179	error	(COMPACT) ble.0 already running
                              ble.0	2019-09-23 08:54:35.128	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:54:35.128	info	(COMPACT) stopping scan
                              ble.0	2019-09-23 08:54:35.128	info	(COMPACT) Got terminate signal 11309
                              ble.0	2019-09-23 08:54:35.127	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              ble.0	2019-09-23 08:54:35.126	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:54:35.125	info	(COMPACT) stopping scan
                              ble.0	2019-09-23 08:54:35.124	info	(COMPACT) Got terminate signal -1
                              host.Beelink.compactgroup1	2019-09-23 08:54:35.095	info	instance system.adapter.ble.0 started with pid 11309
                                 2019-09-23 08:54:35.071	error	ndefined
                              host.Beelink.compactgroup1	2019-09-23 08:54:35.071	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
                              host.Beelink.compactgroup1	2019-09-23 08:54:05.056	info	Restart adapter system.adapter.ble.0 because enabled
                              host.Beelink.compactgroup1	2019-09-23 08:54:05.056	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                              ble	2019-09-23 08:54:04.991	error	(10634) ble.0 already running
                              ble.0	2019-09-23 08:54:04.623	info	(COMPACT) monitored services: fe95
                              ble.0	2019-09-23 08:54:04.623	info	(COMPACT) enabled plugins: mi-flora, _default
                              ble.0	2019-09-23 08:54:04.622	info	(COMPACT) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                              ble.0	2019-09-23 08:54:04.510	info	(COMPACT) starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v10.16.3
                              host.Beelink.compactgroup1	2019-09-23 08:54:04.130	info	instance system.adapter.ble.0 started with pid 10634
                                 2019-09-23 08:54:04.105	error	ndefined
                              host.Beelink.compactgroup1	2019-09-23 08:54:04.104	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
                              node-red.0	2019-09-23 08:54:03.727	warn	23 Sep 08:54:03 - [warn] Projekte inaktiviert: setze editorTheme.projects.enabled=true zum Aktivieren
                              node-red.0	2019-09-23 08:54:03.727	warn	(10445) 23 Sep 08:54:03 - [info] Benutzerverzeichnis: /opt/iobroker/iobroker-data/node-red/
                              node-red.0	2019-09-23 08:54:03.317	warn	(10445) 23 Sep 08:54:03 - [warn] rpi-gpio : Pi RPi.GPIO-Python-Bibliothek nicht gefunden
                              node-red.0	2019-09-23 08:54:03.311	warn	(10445) 23 Sep 08:54:03 - [warn] rpi-gpio : Raspberry Pi-spezifische Nodes inaktiv
                              node-red.0	2019-09-23 08:53:59.523	info	(10445) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                              node-red.0	2019-09-23 08:53:58.974	info	(10445) starting. Version 1.9.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v10.16.3
                              host.Beelink	2019-09-23 08:53:57.433	info	instance system.adapter.node-red.0 started with pid 10445
                              host.Beelink	2019-09-23 08:53:53.437	info	instance system.adapter.sonoff.0 started with pid 10418
                              host.Beelink	2019-09-23 08:53:49.417	info	instance system.adapter.ble.0 is handled by compact group controller pid 8673
                              iqontrol.0	2019-09-23 08:53:45.419	info	(COMPACT) state system.adapter.iqontrol.0.sigKill changed: 0 (ack = false)
                              host.Beelink	2019-09-23 08:53:45.418	info	instance system.adapter.iqontrol.0 is handled by compact group controller pid 8673
                              tr-064-community.0	2019-09-23 08:53:43.109	info	(10087) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.16.3
                              host.Beelink	2019-09-23 08:53:41.430	info	instance system.adapter.tr-064-community.0 started with pid 10087
                              host.Beelink	2019-09-23 08:53:37.456	info	instance system.adapter.zigbee.0 started with pid 10056
                              wifilight.0	2019-09-23 08:53:35.007	info	(9890) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.wifilight, node: v10.16.3
                              host.Beelink.compactgroup1	2019-09-23 08:53:34.094	info	Restart adapter system.adapter.ble.0 because enabled
                              host.Beelink.compactgroup1	2019-09-23 08:53:34.093	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                              ble	2019-09-23 08:53:34.028	error	(9878) ble.0 already running
                              ble.0	2019-09-23 08:53:33.778	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:53:33.777	info	(COMPACT) terminating
                              host.Beelink	2019-09-23 08:53:33.437	info	instance system.adapter.wifilight.0 started with pid 9890
                              ble	2019-09-23 08:53:33.287	warn	(COMPACT) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                              ble	2019-09-23 08:53:33.287	error	(COMPACT) ble.0 already running
                              ble.0	2019-09-23 08:53:33.271	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:53:33.271	info	(COMPACT) stopping scan
                              ble.0	2019-09-23 08:53:33.270	info	(COMPACT) Got terminate signal 9878
                              ble.0	2019-09-23 08:53:33.267	info	(COMPACT) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              ble.0	2019-09-23 08:53:33.266	info	(COMPACT) terminating
                              ble.0	2019-09-23 08:53:33.265	info	(COMPACT) stopping scan
                              ble.0	2019-09-23 08:53:33.264	info	(COMPACT) Got terminate signal -1
                              host.Beelink.compactgroup1	2019-09-23 08:53:33.260	info	instance system.adapter.ble.0 started with pid 9878
                                 2019-09-23 08:53:33.237	error	ndefined
                              host.Beelink.compactgroup1	2019-09-23 08:53:33.237	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
                              enigma2.0	2019-09-23 08:53:31.542	info	(9519) enigma2 Verbunden!
                              host.Beelink	2019-09-23 08:53:29.414	info	instance system.adapter.alexa2.0 is handled by compact group controller pid 8673
                              info.0	2019-09-23 08:53:25.426	info	(COMPACT) ack is not set!
                              info.0	2019-09-23 08:53:25.425	info	(COMPACT) stateChange system.adapter.info.0.sigKill {"val":0,"ack":false,"ts":1569221605415,"q":0,"from":"system.host.Beelink","lc":1569221570394}
                              host.Beelink	2019-09-23 08:53:25.415	info	instance system.adapter.info.0 is handled by compact group controller pid 8673
                              host.Beelink	2019-09-23 08:53:21.416	info	instance system.adapter.fritzdect.0 is handled by compact group controller pid 8673
                              host.Beelink	2019-09-23 08:53:17.431	info	instance system.adapter.google-sharedlocations.0 started with pid 9550
                              enigma2.0	2019-09-23 08:53:16.301	info	(9519) starting Polling every 15000 ms
                              enigma2.0	2019-09-23 08:53:16.270	info	(9519) starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v10.16.3
                              host.Beelink	2019-09-23 08:53:13.436	info	instance system.adapter.enigma2.0 started with pid 9519
                              email.0	2019-09-23 08:53:10.755	info	(9360) starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.email, node: v10.16.3
                              host.Beelink	2019-09-23 08:53:09.430	info	instance system.adapter.email.0 started with pid 9360
                              host.Beelink	2019-09-23 08:53:05.416	info	instance system.adapter.javascript.0 is handled by compact group controller pid 8673
                              vr200.0	2019-09-23 08:53:03.576	info	(9174) devices found: 1
                              host.Beelink.compactgroup1	2019-09-23 08:53:03.219	info	Restart adapter system.adapter.ble.0 because enabled
                              host.Beelink.compactgroup1	2019-09-23 08:53:03.218	error	instance system.adapter.ble.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                              ble.0	2019-09-23 08:53:03.174	info	(COMPACT) starting scan for services ["fe95"]
                              ble	2019-09-23 08:53:03.153	error	(9328) ble.0 already running
                              ble.0	2019-09-23 08:53:02.837	info	(COMPACT) monitored services: fe95
                              ble.0	2019-09-23 08:53:02.835	info	(COMPACT) enabled plugins: mi-flora, _default
                              vr200.0	2019-09-23 08:53:02.926	info	(9174) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.vr200, node: v10.16.3
                              ble.0	2019-09-23 08:53:02.834	info	(COMPACT) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                              ble.0	2019-09-23 08:53:02.728	info	(COMPACT) starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v10.16.3
                              host.Beelink.compactgroup1	2019-09-23 08:53:02.387	info	instance system.adapter.ble.0 started with pid 9328
                                 2019-09-23 08:53:02.362	error	ndefined
                              host.Beelink.compactgroup1	2019-09-23 08:53:02.361	error	Cannot start ble.0 in compact mode. Fallback to normal start! : Cannot read property 'on' of undefined
                              host.Beelink	2019-09-23 08:53:01.431	info	instance system.adapter.vr200.0 started with pid 9174
                              alexa2.0	2019-09-23 08:53:00.806	info	(COMPACT) Alexa-Push-Connection established. Disable Polling
                              iqontrol.0	2019-09-23 08:52:59.028	info	(COMPACT) Deleting unused Objects...
                              War ne blöde Idee noch mal auf 0.9.0 zurück zu gehen, jetzt startet der BLE Adapter nicht mehr. Bin gerade am reparieren.
                              Läuft wieder nach dem der Fixer drüber ist
                              root@Beelink:/opt/iobroker# iobroker list instances
                              + system.adapter.ble.0                   : ble                   -  enabled, compact enabled (group 1)
                              + instance is alive
                              • apollon77A
                                apollon77A
                                #104
                                Ok, sehe schon :-) alles ok. Ich fixe noch was ... grrrr :-)
                                  @SBorg den git clone Fehler hatte Arteck auch mal plötzlich. Ursache muss irgendwo bei npm liegen. Aber gut zu wissen das das andere Kommando tat.
                                  Node-red release ich dann heute Abend.
                                  SBorgS
                                  SBorgS
                                  SBorg
                                  #105
                                  @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                                  @SBorg den git clone Fehler hatte Arteck auch mal plötzlich. Ursache muss irgendwo bei npm liegen...
                                  Zumindest habe ich ihn jetzt permanent. Ohne "sudo -H..." lässt sich nichts mehr installieren. Die Fehlermeldung seitens npm scheint mir aber auch irreführend. Ich habe ja alle Rechte im tmp-Verzeichnis und spaßeshalber ein chmod 777 darauf bringt keinerlei Besserung. Ev. bringt ja ein neues npm-Release Besserung ;)
                                  LG SBorg ( SBorg auf GitHub)
                                  • C
                                    C
                                    CADYTA
                                    schrieb am zuletzt editiert von Stabilostick
                                    #106
                                    Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden, darf der js-controller nicht mir npm aktualisiert werden. Es wird eine neue Version des Windows Installers geben, die das Update des js-controllers mit wenigen Mausklicks ermöglicht. Wir updaten dazu hier im Thread.
                                    [Edit: Defekte Links entfernt. 24.09.19, stabilostick]
                                    • SBorgS SBorg
                                      AlCalzoneA
                                      AlCalzoneA
                                      AlCalzone
                                      #107
                                      @SBorg sagte in [Aufruf] js-controller 2.0 Beta Test:
                                      Mal den Fixer ausgeführt?
                                      • SBorgS
                                        SBorgS
                                        SBorg
                                        #108
                                        @AlCalzone Mehrmals, dürfte aber nix bringen, da NPM meckert, dass er im /[User-Verzeichnis]/.npm/_cacache/tmp/git-clone... das Verzeichnis zum DL nicht anlegen kann. Mit NPM 6.4.1 ging es noch, erst mit dem Update auf 6.11.3 trat es bei mir auf. NPM selbst verriet ja noch, dass es bei älteren Versionen durchaus zu Fehlern in den Userrechten kam. Der vorgeschlagene Fix fruchtet aber auch nicht.
                                        Ist zumindest kein Problem vom Broker/JS-Controller.
                                        AlCalzoneA 2 Antworten Letzte Antwort
                                        • SBorgS SBorg
                                          AlCalzoneA
                                          AlCalzoneA
                                          AlCalzone
                                          #109
                                          @SBorg Ich sehe üblicherweise die Fehler, dass npm als non-root ausgeführt wird (wie es sein sollte), aber versucht in /root/.npm zu schreiben. Das kommt meiner Erfahrung nach daher, dass die Rechte im Zielordner falsch sind und npm daher auf das falsche Cache-Verzeichnis zugreifen will.
                                          84.1k
