  4. Test Adapter fb-checkpresence v0.1.x
fb-checkpresence adapter
346 Beiträge 30 Kommentatoren 75.0k Aufrufe 25 Beobachtet
  • afuerhoffA afuerhoff
    @sigi234 sagte in [Neuer Adapter] iobroker.fb-checkpresence:
    Seit 15 Minuten keine Aktualisierung.
    Hallo, das deutet darauf hin, dass zur Fritzbox keine Verbindung besteht. Kannst Du mal einen Log Auszug posten.
    sigi234S Online
    sigi234S Online
    #93
    @afuerhoff sagte in [Neuer Adapter] iobroker.fb-checkpresence:
    2019-09-06 21:48:26.426  - info: host.Medion object change system.adapter.fb-checkpresence.0
    2019-09-06 21:48:26.426  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0
    2019-09-06 21:48:26.427  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0 killing pid 12400
    2019-09-06 21:48:26.474  - warn: host.Medion instance system.adapter.fb-checkpresence.0 terminated due to SIGTERM
    2019-09-06 21:48:26.474  - info: host.Medion instance system.adapter.fb-checkpresence.0 terminated with code null ()
    2019-09-06 21:48:29.001  - info: host.Medion instance system.adapter.fb-checkpresence.0 started with pid 2188
    2019-09-06 21:48:29.370  - debug: fb-checkpresence.0 objectDB connected
    2019-09-06 21:48:29.378  - debug: fb-checkpresence.0 statesDB connected
    2019-09-06 21:48:29.387  - info: fb-checkpresence.0 starting. Version 0.0.1 in C:/ioBroker/node_modules/iobroker.fb-checkpresence, node: v10.16.0
    2019-09-06 21:48:29.398  - info: fb-checkpresence.0 start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 30 (*/30 * * * *)
    2019-09-06 21:48:29.465  - info: email.0 Send email: {"text":"iobroker - System Adapter laufen fehlerfrei","from":"xxxxxxxxxx@xxxxxxxxxx","to":"xxxxxxxxxx@gmail.com","subject":"ioBroker"}
    2019-09-06 21:48:29.518  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:48:29.530  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799309528}
    2019-09-06 21:48:29.530  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
    2019-09-06 21:48:29.581  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:48:29.591  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
    2019-09-06 21:48:29.591  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799309589}
    2019-09-06 21:48:29.626  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:48:29.637  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799309636}
    2019-09-06 21:48:29.637  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
    2019-09-06 21:48:30.630  - info: email.0 sent to xxxxxxxxxx@gmail.com
    2019-09-06 21:48:52.472  - debug: fb-checkpresence.0 system.adapter.admin.0: logging true
    2019-09-06 21:49:18.232  - debug: fb-checkpresence.0 system.adapter.admin.0: logging false
    2019-09-06 21:51:23.794  - debug: fb-checkpresence.0 system.adapter.admin.0: logging true
    2019-09-06 21:53:15.098  - info: host.Medion object change system.adapter.fb-checkpresence.0
    2019-09-06 21:53:15.098  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0
    2019-09-06 21:53:15.098  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0 killing pid 2188
    2019-09-06 21:53:15.125  - warn: host.Medion instance system.adapter.fb-checkpresence.0 terminated due to SIGTERM
    2019-09-06 21:53:15.125  - info: host.Medion instance system.adapter.fb-checkpresence.0 terminated with code null ()
    2019-09-06 21:53:15.141  - info: email.0 Send email: {"text":"iobroker - System Adapter meldet Probleme fb-checkpresence.0 alive","from":"xxxxxxxxxx@xxxxxxxxxx","to":"xxxxxxxxxx@gmail.com","subject":"ioBroker"}
    2019-09-06 21:53:16.392  - info: email.0 sent to xxxxxxxxxx@gmail.com
    2019-09-06 21:53:17.660  - info: host.Medion instance system.adapter.fb-checkpresence.0 started with pid 11812
    2019-09-06 21:53:18.120  - debug: fb-checkpresence.0 objectDB connected
    2019-09-06 21:53:18.128  - debug: fb-checkpresence.0 statesDB connected
    2019-09-06 21:53:18.135  - info: fb-checkpresence.0 starting. Version 0.0.1 in C:/ioBroker/node_modules/iobroker.fb-checkpresence, node: v10.16.0
    2019-09-06 21:53:18.144  - info: fb-checkpresence.0 start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 30 (*/30 * * * *)
    2019-09-06 21:53:18.217  - info: email.0 Send email: {"text":"iobroker - System Adapter laufen fehlerfrei","from":"xxxxxxxxxx@xxxxxxxxxx","to":"xxxxxxxxxx@gmail.com","subject":"ioBroker"}
    2019-09-06 21:53:18.268  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:53:18.272  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799598271}
    2019-09-06 21:53:18.272  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
    2019-09-06 21:53:18.341  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:53:18.341  - info: history.0 {"common":{"custom":{"history.0":{"changesOnly":true,"debounce":0,"retention":31536000,"maxLength":10,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.history.0","user":"system.user.admin","ts":1567799598340}
    2019-09-06 21:53:18.341  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
    2019-09-06 21:53:18.399  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:53:18.400  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
    2019-09-06 21:53:20.564  - debug: fb-checkpresence.0 system.adapter.admin.0: logging false
    2019-09-06 21:53:26.987  - debug: fb-checkpresence.0 system.adapter.admin.0: logging true
    2019-09-06 21:54:17.438  - debug: fb-checkpresence.0 system.adapter.admin.0: logging false
    2019-09-06 21:57:01.382  - debug: fb-checkpresence.0 system.adapter.admin.0: logging true
    2019-09-06 21:57:34.664  - debug: fb-checkpresence.0 system.adapter.admin.0: logging false
    2019-09-06 21:57:46.674  - info: host.Medion object change system.adapter.fb-checkpresence.0
    2019-09-06 21:57:46.674  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0
    2019-09-06 21:57:46.674  - info: host.Medion stopInstance system.adapter.fb-checkpresence.0 killing pid 11812
    2019-09-06 21:57:46.696  - warn: host.Medion instance system.adapter.fb-checkpresence.0 terminated due to SIGTERM
    2019-09-06 21:57:46.696  - info: host.Medion instance system.adapter.fb-checkpresence.0 terminated with code null ()
    2019-09-06 21:57:49.232  - info: host.Medion instance system.adapter.fb-checkpresence.0 started with pid 7736
    2019-09-06 21:57:49.789  - debug: fb-checkpresence.0 objectDB connected
    2019-09-06 21:57:49.798  - debug: fb-checkpresence.0 statesDB connected
    2019-09-06 21:57:49.811  - info: fb-checkpresence.0 starting. Version 0.0.1 in C:/ioBroker/node_modules/iobroker.fb-checkpresence, node: v10.16.0
    2019-09-06 21:57:49.824  - info: fb-checkpresence.0 start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 10 (*/10 * * * *)
    2019-09-06 21:57:49.962  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:57:50.032  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:57:50.090  - debug: fb-checkpresence.0 sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    2019-09-06 21:57:50.091  - info: history.0 enabled logging of fb-checkpresence.0.xxxxxxxxxx, Alias=false
    • sigi234S sigi234
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      #94
      @sigi234
      Das sieht so aus, als ob dein Polling Intervall auf 30 Minuten eingestellt ist.
      • NegaleinN Offline
        NegaleinN Offline
        Negalein
        #95
        @afuerhoff
        Wäre es möglich, die Daten von fb-checkpresence.0.xxxx.history als Tabelle anzuzeigen?
        Derzeit gibt der DP leider nichts ansehbares raus.
        ° Fixer ---> iob fix
          @sigi234
          sigi234S Online
          sigi234S Online
          #96
          @sigi234
          Jupp........🙄
          Dachte es sind Sekunden.
          • sigi234S sigi234
            @Negalein sagte in [Neuer Adapter] iobroker.fb-checkpresence:
            <span style="color:yellow">{fb-checkpresence.0.Lisi.history}
            Danke!
            Ist das normal, dass die Daten so komisch (schiach) angezeigt werden?
            Tabelle ist mit diesem DP nicht möglich?
            Ja leider, da wäre ein DP Table nötig.
            Vielleicht kann das @afuerhoff einbauen?
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #97
            Danke!
            Ist auf der ToDo Liste
            • B bommel_030
              @afuerhoff
              Ich nutze aktuell HM Pdetect auf der CCU.
              Wunsch wäre quasi das analog auf dem iobroker nachzubilden.
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #98
              @bommel_030 sagte in [Neuer Adapter] iobroker.fb-checkpresence:
              @afuerhoff
              Schaue ich mir an.
              • O Offline
                O Offline
                onkel-ede
                #99
                Der Adapter macht eigentlich genau das, was ich brauch. Nur gelegentlich merkt er nicht, dass ich das Haus verlassen habe. Woran kann das liegen? Abrufintervall (steht auf 1 ändern)? Ich nutze ein iphone. Bei den Androiden habe ich dies noch beobachtet.
                • O onkel-ede
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #100
                  @onkel-ede
                  es dauert bis zu 10 Minuten bis die Fritzbox den Status auf false setzt. Kann es daran liegen?
                  O 1 Antwort Letzte Antwort
                  • sigi234S Online
                    sigi234S Online
                    #101
                    kommt er bald in den Beta Status?
                    • sigi234S sigi234
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #102
                      @sigi234
                      Es ist noch einiges zu tun. Ist ja auch einer meiner ersten Adapter und Javascript ist auch neu für mich. Ich kann demnächst mal wieder eine Version freischalten.
                      • opossumO Offline
                        opossumO Offline
                        opossum
                        #103
                        ich habe den Adapter auf meinem Testsystem installiert. Er funktioniert. Die Datenpunkte sind angelegt und werden auch aktualisiert. Genutzt werden in unserem Haushalt Huawei-Telefone. Wenn ich bei mir das History-Logging deaktiviere und das SQL-Logging aktiviere, erhalte ich im Log den Fehler:
                        ERROR:TypeError: Cannot read property 'enabled' of undefined
                        Leider nutze ich den History-Adapter nicht, bei mir läuft eine SQL-Datenbank, die alle Datensammlungen aufnimmt. Wirst Du da in absehbarer Zeit eine Erweiterung vornehmen?
                        @sigi234 Würdest Du mir Deine o.g. Ansicht als Export zur Verfügung stellen? Gern auch per PN?
                        Egbert
                        https://www.schlepper-petersdorf.de
                        sigi234S afuerhoffA 2 Antworten Letzte Antwort
                        • opossumO opossum
                          Egbert
                          sigi234S Online
                          sigi234S Online
                          #104
                          @opossum sagte in [Neuer Adapter] iobroker.fb-checkpresence:
                          Bitte sehr:
                          Widget_Checkpresence_2.zip
                          NegaleinN opossumO 2 Antworten Letzte Antwort
                          • sigi234S sigi234
                            Bitte sehr:
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #105
                            Ist das eine neue Version?
                            Ist mit Passwort gesichert! :(
                            • NegaleinN Negalein
                              sigi234S Online
                              sigi234S Online
                              #106
                              Nein keine neue Version
                                @onkel-ede
                                O Offline
                                O Offline
                                onkel-ede
                                #107
                                @onkel-ede
                                Nein, daran liegt es nicht. Ich war ca. 3 Stunden unterwegs und in der Historie des Datenpunktes steht davon nix.
                                In der FritzBox unter Netzwerkverbindungen stehen die iphone dann allerdings auch noch drin, jedoch ohne "verbunden mit:".
                                • sigi234S sigi234
                                  Bitte sehr:
                                  opossumO Offline
                                  opossumO Offline
                                  opossum
                                  #108
                                  @sigi234
                                  Bitte sehr:
                                  Vielen Dank, hat alles funktioniert.
                                  • opossumO opossum
                                    Egbert
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #109
                                    Hallo, SQL ist schon in Arbeit.
                                    • O onkel-ede
                                      @onkel-ede
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #110
                                      @onkel-ede sagte in [Neuer Adapter] iobroker.fb-checkpresence:
                                      @onkel-ede
                                      Hallo, kannst Du mal den Log vom Adapter posten.
                                      • Ralla66R Offline
                                        Ralla66R Offline
                                        Ralla66
                                        #111
                                        Adapter bleibt bei mir Gelb.
                                        TR-064 verbindet sich mit der Fritte, ist aber deaktiviert.
                                        Scheint so als wenn der Adapter sich nicht mit der Fritte verbindet.
                                        Denkfehler von mir ?
                                        Log sagt immer invalid status code <500> ?
                                        Wäre ja 500 Internal Server Error Dies ist ein „Sammel-Statuscode“ für unerwartete Serverfehler.
                                        Muß was in der Fritte freigegeben werden ?
                                          @onkel-ede
                                          O Offline
                                          O Offline
                                          onkel-ede
                                          #112
                                          @onkel-ede
                                          Hier mal ein Logauszug. Zu diesem Zeitpunkt war ein iPhone unterwegs (fb-checkpresence.0.Ede) und ein iPhone daheim (fb-checkpresence.0.Benny).
                                          Beide haben jedoch Wert=true.
                                          fb-checkpresence-log.txt
