  4. [gelöst] Per Button mehere objectids nacheinander
vis
33 Beiträge 2 Kommentatoren 4.1k Aufrufe 1 Beobachtet
  • dslraserD dslraser
    @mavier
    probiere mal so in der Art. Bei Object ID Deine Tasten vom Adapter rein.
     <block type="procedures_defcustomnoreturn" id="q@Y(35RpdB%os@yuNd3{" x="63" y="113">
       <mutation statements="false"></mutation>
       <field name="NAME">Datenpunkte_anlegen</field>
       <field name="SCRIPT">Ly9EYXRlbnB1bmt0IEFSRCBlcnN0ZWxsZW4KY3JlYXRlU3RhdGUoIlRWX1NlbmRlci4wMUFSRCIsIHsKICAgIG5hbWU6ICcwMUFSRCcsIAogICAgcm9sZTogJ2J1dHRvbicsCiAgICByZWFkOiAgdHJ1ZSwgCiAgICB3cml0ZTogdHJ1ZSwKICAgIHR5cGU6ICJib29sZWFuIiwKICAgICJzbWFydE5hbWUiOiB7CiAgICAiZGUiOiAia2FuYWwgZWlucywgYS4gci4gZC4gIiwKICAgICJzbWFydFR5cGUiOiAiU1dJVENIIgp9Cn0pOw==</field>
     </block>
     <block type="procedures_callcustomnoreturn" id="k0GBv7Hl29j-tY}uFeBM" x="63" y="187">
       <mutation name="Datenpunkte_anlegen"></mutation>
       <next>
         <block type="on_ext" id="e17*0%.R|-Mkp^fdcvOf">
           <mutation items="1"></mutation>
           <value name="OID0">
             <shadow type="field_oid" id="CXFfQPiE^*sodr*$0z6e">
               <field name="oid">javascript.0.TV_Sender.01ARD</field>
             </shadow>
           </value>
           <statement name="STATEMENT">
             <block type="comment" id="N0_U?fq[{7oe|Pq!I7k.">
               <field name="COMMENT">erste Taste</field>
               <next>
                 <block type="control" id="Jwh3|Kdb-w{FS/axTt,J">
                   <mutation delay_input="false"></mutation>
                   <value name="VALUE">
                     <block type="logic_boolean" id="vgAu_@5qUvs(fzRCf+nT">
                     </block>
                   </value>
                   <next>
                     <block type="comment" id="!^lB/e$$Xi,$[:kn/mz$">
                       <field name="COMMENT">zweite Taste</field>
                       <next>
                         <block type="control" id="2kC5`_f|}lXk;8=).HZx">
                           <mutation delay_input="true"></mutation>
                           <field name="DELAY_MS">30</field>
                           <field name="UNIT">ms</field>
                             <block type="logic_boolean" id="Y`C=I70m%[TZ7z=)+OYn">
                             </block>
                           </value>
                           <next>
                             <block type="comment" id="@8knNQiQvr`SqLQ^Nd_A">
                               <field name="COMMENT">dritte Taste</field>
                               <next>
                                 <block type="control" id="0LK)c:$M:unq+k3ksO::">
                                   <field name="DELAY_MS">60</field>
                                     <block type="logic_boolean" id="59-J.-^xj2TNd]0rz6S{">
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    unter javascript.0 gibt es nach dem ausführen des Blockly einen neuen Ordner TV_Sender und einen Sender Button 01ARD.
    Dann kannst Du diesen Knopf mal drücken und wir schauen mal wieviel Verzögerung der TV braucht. Ich habe erstmal nur eine mini Verzögerung drinn.
    dslraserD Offline
    dslraserD Offline
    dslraser
    @dslraser sagte in Per Button mehere objectids nacheinander senden:
    da habe ich was geschrieben, teste das erstmal
    • M mavier
      so, es ist importiert. aber wie verfahre ich danach weiter? im vis habe ich ein button, den würde ich gerne als umschalter nehmen. wie verbinde ich den button mit dem blockly script?
      dslraserD Offline
      dslraserD Offline
      dslraser
      @mavier
      und noch bei den Object ID drauf/rein klicken und Deine Tasten auswählen nicht vergessen (ist in dem Blockly nicht drinn, da ich den Adapter nicht habe, deshalb sind die noch leer)
      • M mavier
        dslraserD Offline
        dslraserD Offline
        dslraser
        @mavier sagte in Per Button mehere objectids nacheinander senden:
        dann klicke in den Trigger, da wo jetzt javascript.0.TV_Sender.01ARD steht und wähle Deinen Button von Deiner VIS aus.
        (ich nutze kein VIS, deshalb weiß ich das nicht genau und wollte das erstmal über den neuen eigenen Button testen)
          mavier
          es funktioniert. wie verfahre ich denn mit anderen sendern? müsste ich für jeden sender ein skript erstellen oder kann ich das alles in ein blockly einfügen?
          ich danke dir schonmal für deine schnelle hilfe.
          • M mavier
            dslraserD Offline
            dslraserD Offline
            dslraser
            @mavier
            welchen Button hast Du denn jetzt genommen ? (Deinen VIS Button, oder den aus dem Blockly ?)
            • M mavier
              dslraserD Offline
              dslraserD Offline
              dslraser
              @mavier
              wenn Du den Button aus dem Blockly genommen hast könntest Du so weiter machen.
              (nutzt Du Alexa auch zum umschalten per Sprache ? Ich hatte da beim ersten Button gleich noch was drinn für SmartNamen, wenn nicht kann das raus)
              hier ganz rechts drauf klicken (da </>)
              dann weitere Datenpunkte erstellen
              und das Blockly erweitern
                 <field name="SCRIPT">Ly9EYXRlbnB1bmt0IEFSRCBlcnN0ZWxsZW4KY3JlYXRlU3RhdGUoIlRWX1NlbmRlci4wMUFSRCIsIHsKICAgIG5hbWU6ICcwMUFSRCcsIAogICAgcm9sZTogJ2J1dHRvbicsCiAgICByZWFkOiAgdHJ1ZSwgCiAgICB3cml0ZTogdHJ1ZSwKICAgIHR5cGU6ICJib29sZWFuIgp9KTsKLy9EYXRlbnB1bmt0IFpERiBlcnN0ZWxsZW4KY3JlYXRlU3RhdGUoIlRWX1NlbmRlci4wMlpERiIsIHsKICAgIG5hbWU6ICcwMlpERicsIAogICAgcm9sZTogJ2J1dHRvbicsCiAgICByZWFkOiAgdHJ1ZSwgCiAgICB3cml0ZTogdHJ1ZSwKICAgIHR5cGU6ICJib29sZWFuIgp9KTsK</field>
               </block>
                 <next>
                     <value name="OID0">
                       </shadow>
                     </value>
                         <next>
                               </block>
                             </value>
                             <next>
                                 <next>
                                       </block>
                                     </value>
                                     <next>
                                         <next>
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <next>
                       <block type="on_ext" id="-%D(m5Tx1yDfcgPLwE~G">
                         <value name="OID0">
                           <shadow type="field_oid" id="G}(7|Z+O3jf?*]]I6H97">
                             <field name="oid">javascript.0.TV_Sender.02ZDF</field>
                           </shadow>
                         </value>
                           <block type="comment" id="h~KocXJou47$iIaih:),">
                             <next>
                               <block type="control" id="K/bbLYWd}|80b5`^zbkj">
                                   <block type="logic_boolean" id="N0CSoV3Gx/L/YJs}u+H;">
                                   </block>
                                 </value>
                                 <next>
                                   <block type="comment" id="5y/:aVQ3wI]bonx]XUl^">
                                     <next>
                                       <block type="control" id="PZYO;Y???wW%2#0_1BOY">
                                           <block type="logic_boolean" id="cj[DxOkmTl3IkHENM=_:">
                                           </block>
                                         </value>
                                         <next>
                                           <block type="comment" id="O+$m9nry}/%8JzX!+)2%">
                                             <next>
                                               <block type="control" id="5Qy@NW*4}u0cZS.sb(X)">
                                                   <block type="logic_boolean" id="mFGd*Dzf,AOX5(MQvbLp">
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
              </xml>
                mavier
                hat bei den objekten funktioniert und auch auf meinem button, als ich diesen mit dem neuen tv_sender objekt verbunden habe.
                dann werd ich das ganzen mal erweitern.
                ich danke dir.
                • M mavier
                  ich danke dir.
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  ich danke dir.
                  Gern geschehen.
                  dann stelle den Thread noch auf gelöst.
                    mavier
                    schrieb am zuletzt editiert von mavier
                    warum kann ich im script editor nichts bearbeiten? read-only sagt der mir. copy/paste ginge da am schnellsten. oder kann ich nur diese blöcke kopieren?
                    und wo kann ich den thread als gelöst markieren?
                    • M mavier
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      @mavier
                      was meinst Du ? Die Blöcke, oder in der Funktion ?
                      Blöcke, rechte Maustaste/kopieren
                      Funktion
                      Teil markieren und rechte Maustaste/kopieren
                      ganzes Blockly kopieren, Blockly anklicken, dann oben links auf die drei Punkte, Script kopieren
                      • M mavier
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        in Deinem ersten Beitrag, die Überschrift bearbeiten
                        die drei Punkte anklicken
                        dann
                          mavier
                          also irgendwie bekomme ich das mit dem kopieren nicht hin, oder es ist schon zu spät. wenn ich im blockly die blöcke sehe, kann ich oben rechts auf die js-ansicht wechseln. aber diesen kann ich nicht editieren, da kommt immer die meldung, dass dies im read-oly mode nicht möglich ist. und im blockmodus kann ich zwar kopieren, aber dort wo jetzt 01ARD steht kann ich nichts anderes auswählen. muss ich für jeden sender ein eigenes script erstellen?
                          wo die funktion "datenpunkte anlegen" erstellt wird, wird dort auch das senderobjekt erzeugt? weiter unten wird die funktion aufgerufen und die tasten werden übermittelt. so habe ich das jetzt verstanden. aber ich bräuchte doch auch jedesmal eine neue funktion "datenpunkte anlegen", für jeden sender. bin grad verwirrt... und muss das skript dann immer laufen? oder reicht es nur einmal, damit das objekt für den button erstellt wird.
                          • M mavier
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            @mavier
                            hier habe ich doch alles dazu geschrieben.
                            Ja, das Script läuft immer und wird mit dem Trigger (jeweiliger Button) ausgelöst.
                            https://forum.iobroker.net/topic/24369/per-button-mehere-objectids-nacheinander-senden/22
                              mavier
                              oben bei objekt id steht jetzt 01ARD. damit wird doch das objekt erzeugt, welches ich dann im vis als aktion auf den button lege. und nach erste taste usw trage ich die entsprechenden tasten ein die "gedrückt" werden sollen. aber wenn ich den ganzen block kopiere kann ich oben bei objekt id nicht eine weitere auswählen, da nur eine existiert. die einzige lösung die mir einfällt ist für jeden sender ein eigenes skript erstellen und alle nacheinander starten.
                              • M mavier
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                @mavier
                                jaha, liest Du eigentlich was ich schreibe ?
                                Du musst in der Funktion weitere Button erstellen und die dann im weiteren Verlauf auswählen
                                • M mavier
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  da wird es nicht erzeugt, das ist der Trigger der überwacht wird. Das ist der erstellte Button aus der Funktion. Wird der Button gedrückt (aktualisiert) dann wird der Inhalt des dazugehörigen abgearbeitet, sprich, Deine ausgewählten Tasten werden gedrückt.
                                    mavier
                                    oh man, da stand ich aber echt aufm schlauch. hatte das mit dem "datenpunkt anlegen" ignoriert.
                                    sorry sorry, aber jetzt hab ichs und danke dir für deine hilfe und deine geduld :)
