  4. [gelöst] Adapterinstallation - node gyp error
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
node-pre-gyp erradapter installationinstallation
47 Beiträge 6 Kommentatoren 8.3k Aufrufe 5 Beobachtet
  • sigi234S sigi234
    @Sundance sagte in Adapterinstallation schlägt fehl - node-gyp Fehler:
    sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
    sudo npm install canvas --unsafe-perm=true
    Sundance
    @sigi234 said in Adapterinstallation schlägt fehl - node-gyp Fehler:
    Das hatte ich vorhin auch schonmal probiert, schlägt leider immernoch fehl.. hier die beiden outputs:
    pi@HOME:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
    Reading package lists... Done
    Building dependency tree
    build-essential is already the newest version (12.3).
    libgif-dev is already the newest version (5.1.4-0.4).
    libjpeg-dev is already the newest version (1:1.5.1-2).
    libpango1.0-dev is already the newest version (1.40.5-1).
    librsvg2-dev is already the newest version (2.40.16-1).
    libcairo2-dev is already the newest version (1.14.8-1+rpi1).
    0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
    Und bei canvas:
    pi@HOME:~ $ sudo npm install canvas --unsafe-perm=true
    > canvas@2.5.0 install /home/pi/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
    make: Entering directory '/home/pi/node_modules/canvas/build'
      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
      COPY Release/canvas-postbuild.node
      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
    ../src/bmp/BMPParser.cc: In member function 'void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)':
    ../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       E(ptr - data > imgdOffset, "image data overlaps with another structure");
    ../src/bmp/BMPParser.cc:10:25: note: in definition of macro 'E'
     #define E(cond, msg) if(cond) return setErr(msg)
    ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       E(ptr - data + imgdSize > len, "not enough image data");
      CXX(target) Release/obj.target/canvas/src/Backends.o
      CXX(target) Release/obj.target/canvas/src/Canvas.o
      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
    ../src/CanvasRenderingContext2d.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded 'abs(double&)' is ambiguous
       double current_scale_x = abs(transforms[1]);
    In file included from /usr/include/c++/6/cstdlib:75:0,
                     from /usr/include/c++/6/ext/string_conversions.h:41,
                     from /usr/include/c++/6/bits/basic_string.h:5417,
                     from /usr/include/c++/6/string:52,
                     from /usr/include/c++/6/stdexcept:39,
                     from /usr/include/c++/6/array:39,
                     from /usr/include/c++/6/tuple:39,
                     from /usr/include/c++/6/functional:55,
                     from /usr/include/c++/6/memory:79,
                     from /root/.node-gyp/10.16.2/include/node/v8.h:21,
                     from /root/.node-gyp/10.16.2/include/node/node.h:63,
                     from ../../nan/nan.h:54,
                     from ../src/backend/Backend.h:6,
                     from ../src/Canvas.h:5,
                     from ../src/CanvasRenderingContext2d.h:6,
                     from ../src/CanvasRenderingContext2d.cc:3:
    /usr/include/stdlib.h:735:12: note: candidate: int abs(int)
     extern int abs (int __x) __THROW __attribute__ ((__const__)) __wur;
    In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,
    /usr/include/c++/6/cstdlib:180:3: note: candidate: long long int std::abs(long long int)
       abs(long long __x) { return __builtin_llabs (__x); }
    /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)
       abs(long __i) { return __builtin_labs(__i); }
    ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded 'abs(double&)' is ambiguous
       double current_scale_y = abs(transforms[2]);
    canvas.target.mk:138: recipe for target 'Release/obj.target/canvas/src/CanvasRenderingContext2d.o' failed
    make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Error 1
    make: Leaving directory '/home/pi/node_modules/canvas/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.57-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
    gyp ERR! cwd /home/pi/node_modules/canvas
    gyp ERR! node -v v10.16.2
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.57-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
    node-pre-gyp ERR! node -v v10.16.2
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.5.0 install script.
    npm ERR!     /root/.npm/_logs/2019-08-08T12_31_14_478Z-debug.log
    • S Sundance
      Und bei canvas:
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      sigi234S Online
      sigi234S Online
      Kommt das gleiche wenn du es über den Admin installierst?
      Gerade bei mir mal installiert:
      • sigi234S sigi234
        Sundance
        @sigi234 Jap, das gleiche Spiel.. host.HOME cannot install roomba:
        $ ./iobroker add roomba  --host HOME
        NPM version: 6.9.0
        npm install iobroker.roomba@1.0.0 --production --save --prefix "/opt/iobroker" (System call)
        node-pre-gyp
        node-pre-gyp
         WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN
        ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
        ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
        ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]   E(ptr - data + imgdSize > len, "not enough image data");
        ../src/CanvasRenderingContext2d.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)’:../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded ‘abs(double&)’ is ambiguous
        In file included from /usr/include/c++/6/cstdlib:75:0,                 from /usr/include/c++/6/ext/string_conversions.h:41,
                         from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:21,
                         from /home/iobroker/.node-gyp/10.16.2/include/node/node.h:63,
        ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous
        make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Fehler 1
        gyp
         ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! not ok
        node-pre-gyp
         ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! System Linux 4.19.57-v7+node-pre-gyp
        ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp
         ERR! not ok
        npm
        WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
        npm
        WARN
         optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm ERR! code ELIFECYCLEnpm ERR! errno 1
        npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
        npm ERR!
        npm
         ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_39_29_830Z-debug.log
        host.HOME install adapter roomba
        NPM version: 6.9.0
        node-pre-gyp
        node-pre-gyp
         WARN
        In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,                 from /usr/include/c++/6/bits/basic_string.h:5417,
        /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)   abs(long __i) { return __builtin_labs(__i); }
        ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous   double current_scale_y = abs(transforms[2]);
        gyp ERR!
        build error
        gyp
        gyp ERR!
        stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.19.57-v7+gyp
        gyp
        ERR! node-gyp -v v3.8.0gyp ERR! not ok
        node-pre-gyp
         ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp
         ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        node-pre-gyp
         ERR! System Linux 4.19.57-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.16.2
        npm
        npm
         WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup
        npm
        npm
        ERR!
        errno
         1npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
        npm ERR!
        npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_41_18_181Z-debug.log
        NPM version: 6.9.0
        node-pre-gyp
        node-pre-gyp
         WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
        gyp
        ERR!
        build error
        gyp
        gyp ERR!
        stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
         ERR! System Linux 4.19.57-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
        gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.16.2
        gyp ERR!
        node-pre-gyp
         ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
        node-pre-gyp
        node-pre-gyp ERR!
        node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
        npm
        npm
        WARN
        npm
        WARN
        notsup
        npm
        npm
        ERR! errno
        npm
        npm ERR!
        npm ERR!
        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_43_10_893Z-debug.log
        ERROR: host.HOME Cannot install roomba
        ERROR: process exited with code 13
        • Ralla66R Offline
          Ralla66R Offline
          Ralla66
          Error 404 wundert mich.
          Finde nur die Version 2.6.0.
          Falscher Link ?
          • Ralla66R Ralla66
            Falscher Link ?
            Sundance
            @Ralla66 Stimmt.. der Link hier müsste es wohl sein laut repo:
            https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
            Da ist im link ein "ARM" zu viel.. aber passt die Version dann überhaupt noch? Was müsste ich anpassen, damit ich es installieren kann?
            • Ralla66R Offline
              Ralla66R Offline
              Ralla66
              Der Link geht ja, versuch über die URL zu installieren.
              • Ralla66R Ralla66
                Sundance
                @Ralla66 das scheint nicht zu klappen:
                $ ./iobroker url "https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz" --debug
                install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz --production --save --prefix "/opt/iobroker" (System call)
                npm
                 ERR! code ENOPACKAGEJSON
                npm
                ERR!
                package.json Non-registry package missing package.json: https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz.npm
                 ERR! package.json
                 npm can't find a package.json file in your current directory.
                npm
                npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T13_53_17_665Z-debug.log
                process exited with code 0
                • Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  Da kann ich nicht mehr weiter helfen.
                  Dir scheint ein package.json file zu fehlen oder liegt im falschen directory.
                    Sundance
                    @Ralla66 - okay, dann gebe ich mich erstmal geschlagen! Danke trotzdem für deine Hilfe!
                    • ZefauZ Offline
                      ZefauZ Offline
                      Zefau
                      Installier mal canvas 2.6
                      • ZefauZ Zefau
                        Sundance
                        @Zefau - danke für den hinweis. hast du einen Tipp wo und wie genau ich das installieren soll? Der Fehler mit "package.json" kommt leider auch bei dem entsprechendem Link von der 2.6 Version..
                        Ich habe als root einfach folgendes gemacht:
                        npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz
                        Aber der Fehler mit dem package.json bleibt:
                        root@HOME:/home/pi# npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz
                        npm ERR! code ENOPACKAGEJSON
                        npm ERR! package.json Non-registry package missing package.json: https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-x64.tar.gz.
                        npm ERR! package.json npm can't find a package.json file in your current directory.
                        npm ERR!     /root/.npm/_logs/2019-08-08T16_25_34_957Z-debug.log
                        Hast du einen Tipp?
                        • ZefauZ Offline
                          ZefauZ Offline
                          Zefau
                          schrieb am zuletzt editiert von Zefau
                          Sorry, war noch unterwegs, daher die knappe Antwort.
                          Hast du die build-essentials installiert?
                          Danach dann einfach canvas 2.6.0 von npm:
                          sudo npm install canvas@2.6.0 --unsafe-perm=true
                          EDIT: den zweiten Befehl im iobroker.roomba Ordner ausführen. Also unter /opt/iobroker/node_modules/iobroker.roomba.
                          EDIT2: Hab jetzt den Verlauf nicht komplett gelesen, aber die fehlende package.json liegt daran, dass du in einem völlig falschen Ordner bist (/home/pi?). Die Befehle müssen im iobroker.roomba Ordner ausgeführt werden, wenn diese dafür greifen sollen.
                          • ZefauZ Zefau
                            Sundance
                            @Zefau kein Problem, danke für deine Unterstützung.
                            Auch die Installtion von 2.6.0 schlägt fehl (404), allerdings scheint das Problem in einem falschen Link in dem package zu liegen. Habe diese Issue hier gefunden: https://github.com/node-gfx/node-canvas-prebuilt/issues/84
                            Dann muss man aktuell wohl warten, bis das seitens der entwickler von node-canvas behoben ist, wenn ich das richtig verstehe?
                            • S Sundance
                              ZefauZ Offline
                              ZefauZ Offline
                              Zefau
                              @Sundance Kannst du das Log bitte posten? Welche URL wirft 404? Siehe https://github.com/node-gfx/node-canvas-prebuilt/releases welche prebuilts es gibt.
                              Die prebuilds gibt es nur für LTS Versionen von node, also v8, v10 und v12. Du solltest von v11 zurück auf v10 gehen.
                              Davon unabhängig: Wenn er keine prebuilts findet, dann kompiliert Linux eigl. selbst. Versucht das System dies bei dir gar nicht, oder kommt dann dein node-gyp Fehler?
                              • ZefauZ Zefau
                                Sundance
                                @Zefau Aktuell bin ich auf node Version 10.16.2 - müsste also passen, oder? Hier das log von der installation von canvas 2.6.0:
                                root@HOME:/home/pi# sudo npm install canvas@2.6.0 --unsafe-perm=true
                                > canvas@2.6.0 install /home/pi/node_modules/canvas
                                node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.0/canvas-v2.6.0-node-v64-linux-glibc-arm.tar.gz
                                node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                                ../src/bmp/BMPParser.cc:189:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                ../src/bmp/BMPParser.cc:204:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                ../src/Canvas.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)':
                                ../src/Canvas.cc:415:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                                     if (canvas->nBytes() > node::Buffer::kMaxLength) {
                                  CXX(target) Release/obj.target/canvas/src/closure.o
                                  CXX(target) Release/obj.target/canvas/src/color.o
                                  CXX(target) Release/obj.target/canvas/src/Image.o
                                  CXX(target) Release/obj.target/canvas/src/ImageData.o
                                  CXX(target) Release/obj.target/canvas/src/init.o
                                  CXX(target) Release/obj.target/canvas/src/register_font.o
                                  SOLINK_MODULE(target) Release/obj.target/canvas.node
                                  COPY Release/canvas.node
                                npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
                                + canvas@2.6.0
                                added 62 packages from 35 contributors and audited 741 packages in 127.47s
                                found 0 vulnerabilities
                                Ich habe danach einfach nochmal die adapter installation versucht, aber sie schlägt weiterhin mit folgendem Log fehl:
                                root@HOME:/home/pi# iobroker install iobroker.roomba
                                ^[fNPM version: 6.9.0
                                gyp ERR! not ok
                                npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
                                npm ERR! errno 1
                                npm ERR!
                                npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T18_50_01_882Z-debug.log
                                host.HOME Adapter directory "null" does not exists
                                Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                                • S Sundance
                                  + canvas@2.6.0
                                  gyp ERR! not ok
                                  npm ERR! errno 1
                                  npm ERR!
                                  ZefauZ Offline
                                  ZefauZ Offline
                                  Zefau
                                  @Sundance Sieht an sich gut aus. Die Installation von Canvas 2.6.0 läuft durch, die von 2.5.0 (die aktuell noch bei ioBroker.roomba gezogen wird) nicht.
                                  Versuch mal die aktuelle Version vom Repository zu installieren: iobroker url https://github.com/Zefau/ioBroker.roomba.
                                  Github habe ich jetzt auf 2.6.0 aktualisiert, dann sollte es passen.
                                  • ZefauZ Zefau
                                    Sundance
                                    @Zefau - Danke für das Update, jetzt hat es funktioniert! :)
                                    Adapter lies sich jetzt problemlos installieren - den 404 Fehler im Installationsdurchlauf zeigt er zwar immernoch an, aber es hat trotzdem geklappt.
                                    Vielen dank :) bin gespannt auf den Adapter
                                    ZefauZ GlasfaserG 2 Antworten Letzte Antwort
                                    • S Sundance
                                      ZefauZ Offline
                                      ZefauZ Offline
                                      Zefau
                                      @Sundance Klasse, freut mich! :)
                                      • S Sundance
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @Sundance
                                        Na dann läuft ja alles .
                                        Sundance  vor 22 Stunden 
