  4. [gelöst] Adapterinstallation - node gyp error
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
node-pre-gyp erradapter installationinstallation
47 Beiträge 6 Kommentatoren 8.3k Aufrufe 5 Beobachtet
  • S Sundance
    @Glasfaser Ja, das hatte ich schon probiert vorhin.. ironischerweise kommen bei der Canvas installation gemäß dem Befehl aus der Installationsanleitung die gleichen Fehler (zumindest auf den ersten Blick):
    root@HOME:~# cd /opt/iobroker
    root@HOME:/opt/iobroker# sudo npm install canvas --unsafe-perm=true
    > canvas@2.5.0 install /opt/iobroker/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
    make: Entering directory '/opt/iobroker/node_modules/canvas/build'
      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
      COPY Release/canvas-postbuild.node
      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
    ../src/bmp/BMPParser.cc: In member function 'void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)':
    ../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       E(ptr - data > imgdOffset, "image data overlaps with another structure");
    ../src/bmp/BMPParser.cc:10:25: note: in definition of macro 'E'
     #define E(cond, msg) if(cond) return setErr(msg)
    ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       E(ptr - data + imgdSize > len, "not enough image data");
      CXX(target) Release/obj.target/canvas/src/Backends.o
      CXX(target) Release/obj.target/canvas/src/Canvas.o
      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
    ../src/CanvasRenderingContext2d.cc: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded 'abs(double&)' is ambiguous
       double current_scale_x = abs(transforms[1]);
    In file included from /usr/include/c++/6/cstdlib:75:0,
                     from /usr/include/c++/6/ext/string_conversions.h:41,
                     from /usr/include/c++/6/bits/basic_string.h:5417,
                     from /usr/include/c++/6/string:52,
                     from /usr/include/c++/6/stdexcept:39,
                     from /usr/include/c++/6/array:39,
                     from /usr/include/c++/6/tuple:39,
                     from /usr/include/c++/6/functional:55,
                     from /usr/include/c++/6/memory:79,
                     from /root/.node-gyp/10.16.2/include/node/v8.h:21,
                     from /root/.node-gyp/10.16.2/include/node/node.h:63,
                     from ../../nan/nan.h:54,
                     from ../src/backend/Backend.h:6,
                     from ../src/Canvas.h:5,
                     from ../src/CanvasRenderingContext2d.h:6,
                     from ../src/CanvasRenderingContext2d.cc:3:
    /usr/include/stdlib.h:735:12: note: candidate: int abs(int)
     extern int abs (int __x) __THROW __attribute__ ((__const__)) __wur;
    In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,
    /usr/include/c++/6/cstdlib:180:3: note: candidate: long long int std::abs(long long int)
       abs(long long __x) { return __builtin_llabs (__x); }
    /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)
       abs(long __i) { return __builtin_labs(__i); }
    ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded 'abs(double&)' is ambiguous
       double current_scale_y = abs(transforms[2]);
    canvas.target.mk:138: recipe for target 'Release/obj.target/canvas/src/CanvasRenderingContext2d.o' failed
    make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.57-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v10.16.2
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.57-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v10.16.2
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.5.0 install script.
    npm ERR!     /root/.npm/_logs/2019-08-08T11_38_50_244Z-debug.log
    Allerdings steht in der Anleitung auch, dass man Canvas in den iobroker.roomba Ordner erstellen soll. Der existiert aber bei mir (noch) nicht, zumindest nicht in /opt/iobroker/node_modules/ - oder muss der woanders hin? Muss ich den vorher händisch erstellen, oder bringt das nix?
    Sorry, ich bin lost :D Danke für deine Geduld
    Beste Grüße
    Florian
    GlasfaserG Offline
    GlasfaserG Offline
    @Sundance
    Hast Du eingentlich schon mal wieder versucht roomba über die Konsole ganz normal zu installieren !?
    • GlasfaserG Glasfaser
      @Sundance
      Sundance
      @Glasfaser Ja, habe es grade nochmal probiert.. aber die Fehler bleiben leider bestehen. Die Canvas Installation schlägt nachwievor fehl.. manuell installiert bekomme ich sie auch nicht.
      Ich habe grade nochmal die Verzeichnisberechtigungen "bereinigt", aber es hat leider nicht geholfen.
      Hast du noch eine Idee? In meinem letzten Installations-log Scheint es auch Probleme zu geben, einfache Ordner zu erstellen:
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.2"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
      gyp ERR! configure error
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
      Es hilft nicht, diese Ordner händisch zu erstellen, oder?
      • S Sundance
        sigi234S Online
        sigi234S Online
        @Sundance sagte in Adapterinstallation schlägt fehl - node-gyp Fehler:
        einfach mal den Installations-Fixer anwenden: curl -sL https://iobroker.net/fix.sh | bash -
        • sigi234S sigi234
          Sundance
          @sigi234 Danke, Das hat das "permission denied" Problem behoben - aber den Rest leider nicht..
          root@HOME:/opt/iobroker# iobroker install iobroker.roomba
          NPM version: 6.9.0
          npm install iobroker.roomba@1.0.0 --production --save --prefix "/opt/iobroker" (System call)
                           from /home/iobroker/.node-gyp/10.16.2/include/node/v8.h:21,
                           from /home/iobroker/.node-gyp/10.16.2/include/node/node.h:63,
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_06_49_697Z-debug.log
          host.HOME Adapter directory "null" does not exists
          Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
          Gibt es außer einer kompletten Neuinstallation noch irgendwas, was ich testen könnte?
          Danke und beste grüße
          Sundance
          • S Sundance
            NPM version: 6.9.0
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            Sundance
            sigi234S Online
            sigi234S Online
            @Sundance
            Was sagt :
            node -v
            npm -v
            iobroker list instances
            • sigi234S sigi234
              @Sundance
              Was sagt :
              node -v
              npm -v
              Sundance
              @sigi234
              Hier die drei Ausgaben:
              pi@HOME:~ $ node -v
              v10.16.2
              pi@HOME:~ $ npm -v
              6.9.0
              pi@HOME:~ $ iobroker list instances
              + system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.cloud.0                 : cloud       - disabled
              + system.adapter.discovery.0             : discovery   -  enabled
                system.adapter.ham.0                   : ham         -  enabled
              + system.adapter.history.0               : history     -  enabled
              + system.adapter.hm-rega.0               : hm-rega     -  enabled
              + system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 0
              + system.adapter.hm-rpc.1                : hm-rpc      -  enabled, port: 0
              + system.adapter.hue.0                   : hue         -  enabled, port: 80
                system.adapter.info.0                  : info        -  enabled
                system.adapter.iot.0                   : iot         - disabled
              + system.adapter.javascript.0            : javascript  -  enabled
                system.adapter.mobile.0                : mobile      - disabled
                system.adapter.node-red.0              : node-red    -  enabled, port: 1880, bind: 0.0.0.0
                system.adapter.sayit.0                 : sayit       -  enabled, port: 0
                system.adapter.sonos.0                 : sonos       -  enabled
                system.adapter.tr-064.0                : tr-064      -  enabled
              + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.web.1                   : web         -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                system.adapter.zigbee.0                : zigbee      -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019366630-if00
              + instance is alive
              • S Sundance
                @sigi234
                pi@HOME:~ $ node -v
                v10.16.2
                pi@HOME:~ $ npm -v
                6.9.0
                + instance is alive
                sigi234S Online
                sigi234S Online
                @Sundance
                Das passt Alles, ioBroker neu starten......
                • sigi234S sigi234
                  @Sundance
                  Sundance
                  @sigi234 Habe ich gemacht - Installation nochmal versucht, gleiche Fehler wie vorher.. Gibt es noch etwas, was ich versuchen kann?
                  Danke vorab für deine Hilfe!
                  • S Sundance
                    sigi234S Online
                    sigi234S Online
                    Was für welcher ? Was geht nicht, bzw. funktioniert nicht?
                    In den Admin kommst du normal rein?
                    • sigi234S sigi234
                      Sundance
                      schrieb am zuletzt editiert von Sundance
                      @sigi234
                      Hier der aktuelle Fehler-output aus dem Terminal:
                      pi@HOME:~ $ iobroker install iobroker.roomba
                      NPM version: 6.9.0
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_17_48_762Z-debug.log
                      In Admin komme ich normal rein, dort funktioniert auch alles wunderbar - allerdings hatte die Installation über Admin nie geklappt, daher habe ich es nun immer über die Konsole probiert. Leider bisher ohne Erfolg..
                      Habe es hier zwar als user "Pi" installiert - per root kommen aber die gleichen fehler.
                      • S Sundance
                        @sigi234
                        NPM version: 6.9.0
                        gyp ERR! not ok
                        npm ERR! errno 1
                        npm ERR!
                        sigi234S Online
                        sigi234S Online
                        sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                        • sigi234S sigi234
                          Sundance
                          @sigi234 said in Adapterinstallation schlägt fehl - node-gyp Fehler:
                          Das hatte ich vorhin auch schonmal probiert, schlägt leider immernoch fehl.. hier die beiden outputs:
                          pi@HOME:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                          Reading package lists... Done
                          Building dependency tree
                          build-essential is already the newest version (12.3).
                          libgif-dev is already the newest version (5.1.4-0.4).
                          libjpeg-dev is already the newest version (1:1.5.1-2).
                          libpango1.0-dev is already the newest version (1.40.5-1).
                          librsvg2-dev is already the newest version (2.40.16-1).
                          libcairo2-dev is already the newest version (1.14.8-1+rpi1).
                          0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
                          Und bei canvas:
                          pi@HOME:~ $ sudo npm install canvas --unsafe-perm=true
                          > canvas@2.5.0 install /home/pi/node_modules/canvas
                          make: Entering directory '/home/pi/node_modules/canvas/build'
                          make: Leaving directory '/home/pi/node_modules/canvas/build'
                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                          gyp ERR! cwd /home/pi/node_modules/canvas
                          gyp ERR! not ok
                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
                          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                          node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                          node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                          npm WARN pi No description
                          npm WARN pi No repository field.
                          npm WARN pi No README data
                          npm WARN pi No license field.
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR!     /root/.npm/_logs/2019-08-08T12_31_14_478Z-debug.log
                          • S Sundance
                            Und bei canvas:
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            sigi234S Online
                            sigi234S Online
                            Kommt das gleiche wenn du es über den Admin installierst?
                            Gerade bei mir mal installiert:
                            • sigi234S sigi234
                              Sundance
                              @sigi234 Jap, das gleiche Spiel.. host.HOME cannot install roomba:
                              $ ./iobroker add roomba  --host HOME
                              NPM version: 6.9.0
                              node-pre-gyp
                              node-pre-gyp
                               WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN
                              ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                              ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                              ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]   E(ptr - data + imgdSize > len, "not enough image data");
                              ../src/CanvasRenderingContext2d.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Context2d::DrawImage(Nan::NAN_METHOD_ARGS_TYPE)’:../src/CanvasRenderingContext2d.cc:1291:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                              In file included from /usr/include/c++/6/cstdlib:75:0,                 from /usr/include/c++/6/ext/string_conversions.h:41,
                              ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous
                              make: *** [Release/obj.target/canvas/src/CanvasRenderingContext2d.o] Fehler 1
                              gyp
                               ERR! build error
                              gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvas
                              gyp ERR! not ok
                              node-pre-gyp
                               ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                              node-pre-gyp ERR! System Linux 4.19.57-v7+node-pre-gyp
                              ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                              node-pre-gyp
                               ERR! not ok
                              npm
                              npm
                              WARN
                               optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              npm ERR! code ELIFECYCLEnpm ERR! errno 1
                              npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
                              npm ERR!
                              npm
                               ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_39_29_830Z-debug.log
                              host.HOME install adapter roomba
                              NPM version: 6.9.0
                              node-pre-gyp
                              node-pre-gyp
                               WARN
                              In file included from /usr/include/c++/6/ext/string_conversions.h:41:0,                 from /usr/include/c++/6/bits/basic_string.h:5417,
                              /usr/include/c++/6/cstdlib:172:3: note: candidate: long int std::abs(long int)   abs(long __i) { return __builtin_labs(__i); }
                              ../src/CanvasRenderingContext2d.cc:1292:45: error: call of overloaded ‘abs(double&)’ is ambiguous   double current_scale_y = abs(transforms[2]);
                              gyp ERR!
                              build error
                              gyp
                              gyp ERR!
                              stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                              gyp ERR! System Linux 4.19.57-v7+gyp
                              gyp
                              ERR! node-gyp -v v3.8.0gyp ERR! not ok
                              node-pre-gyp
                               ERR! build error
                              node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp
                               ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                              node-pre-gyp
                               ERR! System Linux 4.19.57-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                              node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.16.2
                              npm
                              npm
                               WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup
                              npm
                              npm
                              ERR!
                              errno
                               1npm ERR! canvas@2.5.0 install: `node-pre-gyp install --fallback-to-build`
                              npm ERR!
                              npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_41_18_181Z-debug.log
                              NPM version: 6.9.0
                              node-pre-gyp
                              node-pre-gyp
                               WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.5.0 and node@10.16.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                              gyp
                              ERR!
                              build error
                              gyp
                              gyp ERR!
                              stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
                               ERR! System Linux 4.19.57-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
                              gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.16.2
                              gyp ERR!
                              node-pre-gyp
                               ERR! build error
                              node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                              node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
                              node-pre-gyp
                              node-pre-gyp ERR!
                              node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                              npm
                              npm
                              WARN
                              npm
                              WARN
                              notsup
                              npm
                              npm
                              ERR! errno
                              npm
                              npm ERR!
                              npm ERR!
                              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T12_43_10_893Z-debug.log
                              ERROR: host.HOME Cannot install roomba
                              ERROR: process exited with code 13
                              • Ralla66R Offline
                                Ralla66R Offline
                                Ralla66
                                Error 404 wundert mich.
                                Finde nur die Version 2.6.0.
                                Falscher Link ?
                                • Ralla66R Ralla66
                                  Falscher Link ?
                                  Sundance
                                  @Ralla66 Stimmt.. der Link hier müsste es wohl sein laut repo:
                                  https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                                  Da ist im link ein "ARM" zu viel.. aber passt die Version dann überhaupt noch? Was müsste ich anpassen, damit ich es installieren kann?
                                  • Ralla66R Offline
                                    Ralla66R Offline
                                    Ralla66
                                    Der Link geht ja, versuch über die URL zu installieren.
                                    • Ralla66R Ralla66
                                      Sundance
                                      @Ralla66 das scheint nicht zu klappen:
                                      $ ./iobroker url "https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz" --debug
                                      install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz
                                      npm install https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz --production --save --prefix "/opt/iobroker" (System call)
                                      npm
                                       ERR! code ENOPACKAGEJSON
                                      npm
                                      ERR!
                                      package.json Non-registry package missing package.json: https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.5.0/canvas-v2.5.0-node-v64-linux-glibc-x64.tar.gz.npm
                                       ERR! package.json
                                       npm can't find a package.json file in your current directory.
                                      npm
                                      npm ERR!     /home/iobroker/.npm/_logs/2019-08-08T13_53_17_665Z-debug.log
                                      process exited with code 0
                                      • Ralla66R Offline
                                        Ralla66R Offline
                                        Ralla66
                                        Da kann ich nicht mehr weiter helfen.
                                        Dir scheint ein package.json file zu fehlen oder liegt im falschen directory.
                                          Sundance
                                          @Ralla66 - okay, dann gebe ich mich erstmal geschlagen! Danke trotzdem für deine Hilfe!
