    1.0k
  • simatecS simatec
    @bishop sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
    so also ich versteh es nicht warum die Terrasse nicht funktionieren will.
    Hab mal alles neu gemacht trotzdem fährt sie nicht.
    Was mir aufgefallen ist wenn ich die Terrasse erstelle und nur das Herunterfahren auf "aus" und das Hochfahren auf "GoldenHourend" ändere speichere und schliesse steht da im Log
    2019-07-19 11:20:47.175 - info: shuttercontrol.0 starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v8.14.0
    2019-07-19 11:20:47.180 - debug: shuttercontrol.0 [{"enabled":true,"shutterName":"Wohnzimmer","name":"admin.0.WohnZi-Rollladen-Parameter.Soll-Position","triggerID":"","typeUp":"goldenhour End","typeDown":"living","type":"in- & outside temperature and direction","heightDownSun":"30","direction":"120","directionRange":"50","tempInside":"23","tempSensor":"","outsideTempSensor":"","tempOutside":"23","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""},{"enabled":true,"shutterName":"Esszimmer","name":"admin.0.EssZi-Rollladen-Parameter.Soll-Position","triggerID":"","typeUp":"living","typeDown":"living","type":"in- & outside temperature and direction","heightDownSun":"30","direction":"120","directionRange":"50","tempInside":"23","tempSensor":"","outsideTempSensor":"","tempOutside":"23","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""},{"enabled":true,"shutterName":"Kueche","name":"admin.0.Kueche-Rollladen-Parameter.Soll-Position","triggerID":"","typeUp":"living","typeDown":"living","type":"in- & outside temperature and direction","heightDownSun":"30","direction":"120","directionRange":"50","tempInside":"23","tempSensor":"","outsideTempSensor":"","tempOutside":"23","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""},{"enabled":true,"shutterName":"Kim","name":"admin.0.Kim-Rollladen-Parameter.Soll-Position","triggerID":"","typeUp":"sleep","typeDown":"sleep","type":"off","heightDownSun":"20","direction":"270","directionRange":"30","tempInside":"23","tempSensor":"","outsideTempSensor":"yr.0.forecast.day0.temperatureActual","tempOutside":"25","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""},{"enabled":true,"shutterName":"Schlafzimmer","name":"admin.0.SchlafZi-Rollladen-Parameter.Soll-Position","triggerID":"","typeUp":"sleep","typeDown":"living","type":"in- & outside temperature and direction","heightDownSun":"30","direction":"120","directionRange":"50","tempInside":"23","tempSensor":"","outsideTempSensor":"","tempOutside":"23","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""},{"enabled":false,"shutterName":"Balkon","name":"admin.0.Balkon-Rollladen-Parameter.Soll-Position","triggerID":"","typeUp":"sunrise","typeDown":"sunset","type":"in- & outside temperature and direction","heightDownSun":"30","direction":"120","directionRange":"50","tempInside":"23","tempSensor":"","outsideTempSensor":"","tempOutside":"23","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""},{"enabled":true,"shutterName":"Jan","name":"admin.0.Jan-Rollladen-Parameter.Soll-Position","triggerID":"","typeUp":"sleep","typeDown":"sleep","type":"in- & outside temperature and direction","heightDownSun":"30","direction":"120","directionRange":"50","tempInside":"23","tempSensor":"","outsideTempSensor":"","tempOutside":"23","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""},{"enabled":true,"shutterName":"Bad","name":"admin.0.Bad-Rollladen-Parameter.Soll-Position","triggerID":"","typeUp":"living","typeDown":"living","type":"off","heightDownSun":"20","direction":"110","directionRange":"50","tempInside":"23","tempSensor":"","outsideTempSensor":"yr.0.forecast.day0.temperatureActual","tempOutside":"23","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""},{"enabled":true,"shutterName":"Terrasse","name":"admin.0.Terrasse-Rollladen-Parameter.Soll-Position","triggerID":"","heightDownSun":"30","direction":"120","directionRange":"50","tempInside":"23","tempSensor":"","outsideTempSensor":"","tempOutside":"23","lightSensor":"","valueLight":"15","heightUp":"100","heightDown":"0","triggerState":"true","triggerDrive":"100","triggerChange":"off","elevation":"8","autoDrive":"off","hysteresisOutside":"5","hysteresisInside":"5","hysteresisLight":"5","currentAction":"","currentHeight":"","triggerHeight":""}]
    2019-07-19 11:20:47.185 - debug: shuttercontrol.0 trigger for outside temperature: yr.0.forecast.day0.temperatureActual
    2019-07-19 11:20:47.188 - debug: shuttercontrol.0 Shutter State: admin.0.WohnZi-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.190 - debug: shuttercontrol.0 Shutter State: admin.0.EssZi-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.190 - debug: shuttercontrol.0 Shutter State: admin.0.Kueche-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.190 - debug: shuttercontrol.0 Shutter State: admin.0.Kim-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.191 - debug: shuttercontrol.0 Shutter State: admin.0.SchlafZi-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.191 - debug: shuttercontrol.0 Shutter State: admin.0.Balkon-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.191 - debug: shuttercontrol.0 Shutter State: admin.0.Jan-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.191 - debug: shuttercontrol.0 Shutter State: admin.0.Bad-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.191 - debug: shuttercontrol.0 Shutter State: admin.0.Terrasse-Rollladen-Parameter.Soll-Position
    2019-07-19 11:20:47.439 - debug: shuttercontrol.0 save current height: 100% from Wohnzimmer
    2019-07-19 11:20:47.448 - debug: shuttercontrol.0 save current height: 100% from Esszimmer
    2019-07-19 11:20:47.448 - debug: shuttercontrol.0 save current height: 100% from Kueche
    2019-07-19 11:20:47.449 - debug: shuttercontrol.0 save current height: 100% from Kim
    2019-07-19 11:20:47.449 - debug: shuttercontrol.0 save current height: 100% from Schlafzimmer
    2019-07-19 11:20:47.450 - debug: shuttercontrol.0 save current height: 100% from Balkon
    2019-07-19 11:20:47.450 - debug: shuttercontrol.0 save current height: 100% from Jan
    2019-07-19 11:20:47.451 - debug: shuttercontrol.0 save current height: 100% from Bad
    2019-07-19 11:20:47.451 - debug: shuttercontrol.0 save current height: 100% from Terrasse
    2019-07-19 11:20:49.184 - debug: shuttercontrol.0 Sun Azimut: 126.2°
    2019-07-19 11:20:49.184 - debug: shuttercontrol.0 Sun Elevation: 51.9°
    2019-07-19 11:20:50.186 - debug: shuttercontrol.0 goldenHourEnd today: 06:27
    2019-07-19 11:20:50.187 - debug: shuttercontrol.0 goldenHour today: 20:33
    2019-07-19 11:20:50.187 - debug: shuttercontrol.0 current day: 5
    2019-07-19 11:20:50.187 - debug: shuttercontrol.0 Sunrise today: 05:39
    2019-07-19 11:20:50.187 - debug: shuttercontrol.0 Sunset today: 21:21
    2019-07-19 11:20:50.189 - debug: shuttercontrol.0 Starting up shutters GoldenHour area: 06:57
    2019-07-19 11:20:50.190 - debug: shuttercontrol.0 Shutdown shutters GoldenHour area: 21:03
    2019-07-19 11:20:50.190 - debug: shuttercontrol.0 Starting up shutters Sunrise area: 06:09
    2019-07-19 11:20:50.190 - debug: shuttercontrol.0 Shutdown shutters Sunset area: 21:51
    2019-07-19 11:20:50.202 - debug: shuttercontrol.0 Starting up shutters living area: 06:55
    2019-07-19 11:20:50.206 - debug: shuttercontrol.0 Starting up shutters sleep area: 06:30
    2019-07-19 11:20:50.210 - debug: shuttercontrol.0 Shutdown shutters living area: 21:00
    2019-07-19 11:20:50.212 - debug: shuttercontrol.0 Shutdown shutters sleep area: 18:45
    gehe ich nun wieder auf den Stift bei dem Terrassenrollladen sind die felder leer
    liegt es vieleicht daran?
    wenn ich es dann nochmal ändere bleibt es gespeichert der Rollladen fährt aber nicht.
    Wenn du den Rolladen händisch runterfahren willst, musst du den Wert für das herunterfahren eintragen. Wenn du ihn Abends z.B. auf 0% fährst, musst da auch 0 als Wert für das herunterfahren eingetragen werden. Sonst hat shuttercontrol keinen Vergleichswert
    bishop
    schrieb am zuletzt editiert von bishop
    #1105
    @simatec
    ja das habe ich schon verstanden sind alle auf Rollladenhöhe beim runterfahren 0 und Rollladenhöhe beim hochfahren 100 ist ja denke ich Standart so.
    Es steht aber kein Wert bei "Steuerung für runterfahren" und " Steuerung für hochfahren".
    Es kommt keine Meldung im debug für den Terrassen Rollladen also er Steuert ihn nicht an aber warum???
    Habe noch eine andere Frage wenn ich die einstellungen bei einem Rollladen so vornehme.
    müsste doch gleich wenn der Fensterkontakt true sendet
    den Rollladen auf 30% fahren oder?
    HomoranH simatecS 2 Antworten Letzte Antwort
    • B bishop
      @simatec
      #1106
      Ist das der zigbeee.....opened?
      Der ist doch bestimmt im geöffneten Zustand true.
      Laut erstem Screenshot ist aber true der Zustand, wenn die Rollladenautomatik normal arbeiten soll
      • B bishop
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        #1107
        @bishop
        Laut deinem Log ist der Rolladen Esszimmer auf 100%.
        Warum soll er bei Änderung des Triggers auf 30% fahren?
        Wenn er auf 0% also unten ist, fährt er auf 30%, wenn das Fenster öffnet.
        Allerdings muss ich @Homoran recht geben, true bei dem Zigbee ist meiner Meinung nach offen. Der Normalzustand ist aber false. Also geschlossen. Ändere das mal in deinen Einstellungen.
        Eventuell liegt da auch dein Problem bei der Terrassentür. Stelle da den Trigger auch mal auf false, wenn du da einen Zigbee Fensterkontakt hast
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • P Offline
          passuff
          #1108
          Könnte man dem Adapter ein Offset für die eingestellte Art des Fahrens (Sonne/Goldenhour) hinzufügen? Aktuell finde ich weder mit dem Sonnenstand noch mit der Goldenhour eine passende Einstellung.
          • P passuff
            #1109
            @passuff
            Hat er doch
            P 1 Antwort Letzte Antwort
              @passuff
              Hat er doch
              passuff
              #1110
              @Homoran
              Danke. Das hatte ich übersehen.
              • simatecS simatec
                @bishop
                bishop
                #1111
                @simatec
                Ja so geht es, es gibt noch ein anderen State von dem Zigbeesensor so geht es dann. Danke dafür
                Heute morgen ist mein Terrassenrollladen hochgefahren :)
                Dort habe ich keine Sensoren also daran konnte es nicht liegen, kann also nicht sagen warum er heute gefahren ist.
                Hoffe es bleibt so und er fährt wie es sich gehört.
                Meine Frau zick einbischen rum (nix neues) wegen dem Sonnenschutz er fährt ihr zu früh hoch.
                Da draußen sehr heiß ist und die Sonne auch Dauer runter brennt, fährt aber nach Ablauf der Himmelsrichtung der Rollladen wieder hoch was ja auch richtig ist.
                Ist wahrscheinlich mit so einem Hitzesensor besser zu realisieren oder?
                Wie verhält sich der Sonnenschutz "Himmelsrichtung + Außentemperatur"?
                Wenn ich die Außentemperatur auf 28Grad und eine Hysterese von 5% einstelle, fährt der Rollladen dann bei 31Grad Außentemperatur wenn die Himmelsrichtung vorbei ist?
                Grüße Bishop
                und vielen dank für den Adapter.
                • B bishop
                  @simatec
                  Grüße Bishop
                  #1112
                  Ja!
                  oder wenn die Außentemperatur unter 26,6°C fällt
                  W B 2 Antworten Letzte Antwort
                    Ja!
                    W Offline
                    W Offline
                    watcherkb
                    #1113
                    Also ich bin bisher sehr begeistert von dem Adapter. Es dauert zwar am Anfang bis man alle Settings verstanden hat aber es ist ok. Jetzt überlegt man sich natürlich wie man bestimmte "Varianten" von Programmen realisieren könnte. Z.B. habe ich hin und wieder den Bedarf, die Rolläden im OG auf ein bestimmtes Level zu fahren und die Rolläden im EG auf ein anderes Level, UND das soll solange bleiben bis ich die Steuerung dem Shuttercontrol wieder überlasse. Das lässt sich wahrscheinlich über ein eigenes Script besser lösen als über Shuttercontrol, oder was meint ihr?
                    CC2538+CC2592 PA-Zigbee-Funkmodul
                    • W watcherkb
                      #1114
                      @watcherkb sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
                      Das lässt sich wahrscheinlich über ein eigenes Script ... lösen
                      Sicher (oder manuell)
                      Dann wird am abend die Automatik mit der Verdunklung wieder aktiviert
                      Aus Interesse: Wozu?
                      W 1 Antwort Letzte Antwort
                        W Offline
                        W Offline
                        watcherkb
                        #1115
                        @Homoran sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
                        Aus Sicherheitsgründen. Ich habe im OG einige Fenster die über Balkon/Garage zugänglich sind. Wenn ich jetzt z.B. für ein paar Stunden außer Haus bin, öffne ich die Fenster auf Kipp und fahre die Rolläden auf ein bestimmtest Level runter, sodass noch Luft reinkommen kann.
                        • W watcherkb
                          #1116
                          @watcherkb
                          Es gibt ja auch noch die Versionen mit ...(Auto)
                          Da kannst du einen Trigger angeben, ob die Automatik außer Betrieb gesetzt werden soll.
                          Dann fahren die Rollläden erst wieder bei dem nächsten Event nach Rückstellung des Triggers
                          Das kannst du dann in deinem "Außer Haus"-Skript automatisch mit setzen
                            @watcherkb
                            W Offline
                            W Offline
                            watcherkb
                            #1117
                            @Homoran ja an sowas habe ich gedacht. Dann werde ich das mal versuchen umzusetzen.
                              Ja!
                              bishop
                              #1118
                              @Homoran
                              da wäre es nicht schlecht, gerade bei den Temperaturen das die Rollläden unten bleiben würden weil sie ja auch isoliert sind...
                              • B bishop
                                @Homoran
                                #1119
                                Und warum tun sie das nicht?
                                Woher weiß shuttercontrol, dass deine isoliert sind?
                                Meine sind es nicht
                                • P Offline
                                  passuff
                                  #1120
                                  Wofür ist die Zeitverzögerung für Fensterläden in den "Extra Einstellungen"?
                                  Die Doku gibt leider nichts her. Thread Durchsuchen kann ich im neuen Forum nicht.
                                  simatecS HomoranH 2 Antworten Letzte Antwort
                                  • P passuff
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #1121
                                    @passuff
                                    Für das fahren nach Astro
                                    • P passuff
                                      #1122
                                      @passuff sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
                                      Was?
                                      Da hat der Autor wohl gepennt
                                        Was?
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #1123
                                        Was?
                                        Wer war das denn 😂😂
                                        • simatecS simatec
                                          @passuff
                                          passuff
                                          #1124
                                          @simatec sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
                                          @passuff
                                          Das ist klar, sind ja die Astro Einstellungen. Eventuell stehe ich auf dem Schlauch...Aber was ist ein Fensterladen? Ich wüsste nicht, dass ich diese irgendwo konfigurieren könnte...
