  4. [gelöst]-Endlosschleife bei Adapter Installation
neue instanzadapter installation
44 Beiträge 5 Kommentatoren 5.2k Aufrufe 3 Beobachtet
  • liv-in-skyL liv-in-sky
    @liv-in-sky iobroker ist auch gestoppt
    ThorstenStr
    @liv-in-sky Ja, ich habe es jetzt mal als root ausgeführt:
    odash@4.17.11 /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash
    bluebird@3.5.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird
    debug@3.2.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug
    ms@2.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms
    extend@3.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend
    serialport@6.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
    @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length
    @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk
    @serialport/parser-delimiter@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter
    @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline
    @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready
    @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex
    bindings@1.3.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings
    commander@2.20.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/commander
    debug@3.2.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug
    ms@2.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms
    nan@2.14.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan
    prebuild-install@4.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install
    detect-libc@1.0.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc
    expand-template@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template
    github-from-package@0.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package
    minimist@1.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist
    mkdirp@0.5.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp
    minimist@0.0.8 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp/node_modules/minimist
    node-abi@2.9.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi
    semver@5.7.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver
    noop-logger@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/noop-logger
    npmlog@4.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog
    are-we-there-yet@1.1.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet
    delegates@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates
    readable-stream@2.3.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream
    core-util-is@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is
    inherits@2.0.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits
    isarray@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray
    process-nextick-args@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args
    string_decoder@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder
    util-deprecate@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate
    console-control-strings@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings
    gauge@2.7.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge
    aproba@1.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba
    has-unicode@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode
    object-assign@4.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign
    signal-exit@3.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit
    string-width@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width
    code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at
    is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point
    number-is-nan@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan
    strip-ansi@3.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi
    ansi-regex@2.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex
    wide-align@1.1.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align
    set-blocking@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking
    os-homedir@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/os-homedir
    pump@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump
    end-of-stream@1.4.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream
    once@1.4.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/once
    wrappy@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy
    rc@1.2.8 /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc
    deep-extend@0.6.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend
    ini@1.3.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini
    strip-json-comments@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments
    simple-get@2.8.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get
    decompress-response@3.3.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response
    mimic-response@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response
    simple-concat@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat
    tar-fs@1.16.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs
    chownr@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr
    pump@1.0.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs/node_modules/pump
    tar-stream@1.6.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream
    bl@1.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl
    buffer-alloc@1.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer-alloc
    buffer-alloc-unsafe@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer-alloc-unsafe
    buffer-fill@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer-fill
    fs-constants@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants
    to-buffer@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/to-buffer
    xtend@4.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/xtend
    tunnel-agent@0.6.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent
    which-pm-runs@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/which-pm-runs
    promirepl@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/promirepl
    prompt-list@3.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-list
    ansi-cyan@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-cyan
    ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-wrap
    ansi-dim@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-dim
    prompt-radio@1.2.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-radio
    debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-radio/node_modules/debug
    ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-radio/node_modules/ms
    prompt-checkbox@2.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-checkbox
    debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-checkbox/node_modules/debug
    ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-checkbox/node_modules/ms
    prompt-base@4.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-base
    component-emitter@1.3.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/component-emitter
    debug@3.2.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-base/node_modules/debug
    ms@2.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-base/node_modules/ms
    koalas@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/koalas
    log-utils@0.2.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/log-utils
    ansi-colors@0.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-colors
    ansi-bgblack@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgblack
    ansi-bgblue@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgblue
    ansi-bgcyan@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgcyan
    ansi-bggreen@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bggreen
    ansi-bgmagenta@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgmagenta
    ansi-bgred@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgred
    ansi-bgwhite@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgwhite
    ansi-bgyellow@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgyellow
    ansi-black@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-black
    ansi-blue@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-blue
    ansi-bold@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bold
    ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-gray
    ansi-green@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-green
    ansi-grey@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-grey
    ansi-hidden@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-hidden
    ansi-inverse@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-inverse
    ansi-italic@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-italic
    ansi-magenta@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-magenta
    ansi-red@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-red
    ansi-reset@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-reset
    ansi-strikethrough@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-strikethrough
    ansi-underline@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-underline
    ansi-white@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-white
    ansi-yellow@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-yellow
    lazy-cache@2.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/lazy-cache
    set-getter@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-getter
    to-object-path@0.3.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/to-object-path
    kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/kind-of
    is-buffer@1.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-buffer
    error-symbol@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/error-symbol
    info-symbol@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/info-symbol
    log-ok@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/log-ok
    success-symbol@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/success-symbol
    time-stamp@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/time-stamp
    warning-symbol@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/warning-symbol
    prompt-actions@3.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-actions
    debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-actions/node_modules/debug
    ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-actions/node_modules/ms
    prompt-question@5.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question
    clone-deep@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/clone-deep
    for-own@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/for-own
    for-in@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/for-in
    is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-plain-object
    isobject@3.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/isobject
    kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/clone-deep/node_modules/kind-of
    shallow-clone@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/shallow-clone
    is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-extendable
    kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/shallow-clone/node_modules/kind-of
    mixin-object@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mixin-object
    for-in@0.1.8 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mixin-object/node_modules/for-in
    debug@3.2.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/node_modules/debug
    ms@2.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/node_modules/ms
    define-property@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/define-property
    is-descriptor@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-descriptor
    is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-accessor-descriptor
    kind-of@6.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-accessor-descriptor/node_modules/kind-of
    is-data-descriptor@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-data-descriptor
    kind-of@6.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-data-descriptor/node_modules/kind-of
    kind-of@6.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-descriptor/node_modules/kind-of
    kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/node_modules/kind-of
    prompt-choices@4.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices
    arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/arr-flatten
    arr-swap@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/arr-swap
    is-number@3.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/arr-swap/node_modules/is-number
    choices-separator@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/choices-separator
    debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/choices-separator/node_modules/debug
    ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/choices-separator/node_modules/ms
    strip-color@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-color
    clone-deep@4.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/node_modules/clone-deep
    kind-of@6.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/node_modules/kind-of
    shallow-clone@3.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/node_modules/shallow-clone
    collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/collection-visit
    map-visit@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/map-visit
    object-visit@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-visit
    define-property@2.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/node_modules/define-property
    is-number@6.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-number
    pointer-symbol@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/pointer-symbol
    radio-symbol@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/radio-symbol
    is-windows@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-windows
    set-value@3.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-value
    terminal-paginator@2.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/terminal-paginator
    debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/terminal-paginator/node_modules/debug
    ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/terminal-paginator/node_modules/ms
    extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend-shallow
    toggle-array@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/toggle-array
    readline-ui@2.2.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui
    debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/debug
    ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/ms
    readline-utils@2.2.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-utils
    is-number@3.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-utils/node_modules/is-number
    mute-stream@0.0.7 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mute-stream
    window-size@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/window-size
    is-number@3.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/window-size/node_modules/is-number
    string-width@2.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/string-width
    is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/is-fullwidth-code-point
    strip-ansi@4.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/strip-ansi
    ansi-regex@3.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/ansi-regex
    static-extend@0.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend
    define-property@0.2.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/define-property
    is-descriptor@0.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-descriptor
    is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-accessor-descriptor
    kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
    is-data-descriptor@0.1.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-data-descriptor
    kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
    kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/kind-of
    object-copy@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy
    copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/copy-descriptor
    define-property@0.2.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/define-property
    is-descriptor@0.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/is-descriptor
    is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/is-accessor-descriptor
    is-data-descriptor@0.1.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/is-data-descriptor
    kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
    iobroker.icons-fatcow-hosting@0.1.0 /opt/iobroker/node_modules/iobroker.icons-fatcow-hosting
    iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
    iobroker.info@1.3.7 /opt/iobroker/node_modules/iobroker.info
    @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/iobroker.info/node_modules/@iobroker/adapter-core
    @types/iobroker@1.4.11 /opt/iobroker/node_modules/iobroker.info/node_modules/@types/iobroker
    @types/node@12.0.10 /opt/iobroker/node_modules/iobroker.info/node_modules/@types/node
    axios@0.18.1 /opt/iobroker/node_modules/iobroker.info/node_modules/axios
    follow-redirects@1.5.10 /opt/iobroker/node_modules/iobroker.info/node_modules/follow-redirects
    debug@3.1.0 /opt/iobroker/node_modules/iobroker.info/node_modules/debug
    ms@2.0.0 /opt/iobroker/node_modules/iobroker.info/node_modules/ms
    is-buffer@2.0.3 /opt/iobroker/node_modules/iobroker.info/node_modules/is-buffer
    systeminformation@4.12.2 /opt/iobroker/node_modules/iobroker.info/node_modules/systeminformation
    iobroker.iot@0.4.3 /opt/iobroker/node_modules/iobroker.iot
    @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/@iobroker/adapter-core
    @types/iobroker@1.4.11 /opt/iobroker/node_modules/iobroker.iot/node_modules/@types/iobroker
    @types/node@12.0.10 /opt/iobroker/node_modules/iobroker.iot/node_modules/@types/iobroker/node_modules/@types/node
    aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/aws-iot-device-sdk
    crypto-js@3.1.6 /opt/iobroker/node_modules/iobroker.iot/node_modules/crypto-js
    minimist@1.2.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/minimist
    mqtt@2.15.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/mqtt
    commist@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/commist
    leven@2.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/leven
    concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/concat-stream
    buffer-from@1.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/buffer-from
    inherits@2.0.4 /opt/iobroker/node_modules/iobroker.iot/node_modules/inherits
    readable-stream@2.3.6 /opt/iobroker/node_modules/iobroker.iot/node_modules/readable-stream
    core-util-is@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/core-util-is
    isarray@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/isarray
    process-nextick-args@2.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/process-nextick-args
    safe-buffer@5.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/safe-buffer
    string_decoder@1.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/string_decoder
    util-deprecate@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/util-deprecate
    typedarray@0.0.6 /opt/iobroker/node_modules/iobroker.iot/node_modules/typedarray
    end-of-stream@1.4.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/end-of-stream
    once@1.4.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/once
    wrappy@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/wrappy
    help-me@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/help-me
    callback-stream@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/callback-stream
    glob-stream@6.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/glob-stream
    extend@3.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/extend
    glob@7.1.4 /opt/iobroker/node_modules/iobroker.iot/node_modules/glob
    fs.realpath@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/fs.realpath
    inflight@1.0.6 /opt/iobroker/node_modules/iobroker.iot/node_modules/inflight
    minimatch@3.0.4 /opt/iobroker/node_modules/iobroker.iot/node_modules/minimatch
    brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.iot/node_modules/brace-expansion
    balanced-match@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/balanced-match
    concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/concat-map
    path-is-absolute@1.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/path-is-absolute
    glob-parent@3.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/glob-parent
    is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-glob
    is-extglob@2.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-extglob
    path-dirname@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/path-dirname
    is-negated-glob@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-negated-glob
    ordered-read-streams@1.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/ordered-read-streams
    pumpify@1.5.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/pumpify
    duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/duplexify
    stream-shift@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/stream-shift
    pump@2.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/pump
    remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/remove-trailing-separator
    to-absolute-glob@2.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/to-absolute-glob
    is-absolute@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-absolute
    is-relative@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-relative
    is-unc-path@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-unc-path
    unc-path-regex@0.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/unc-path-regex
    is-windows@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-windows
    unique-stream@2.3.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/unique-stream
    json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/json-stable-stringify-without-jsonify
    through2-filter@3.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/through2-filter
    through2@2.0.5 /opt/iobroker/node_modules/iobroker.iot/node_modules/through2
    xtend@4.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/xtend
    mqtt-packet@5.6.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/mqtt-packet
    bl@1.2.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/bl
    reinterval@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/reinterval
    split2@2.2.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/split2
    websocket-stream@5.5.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/websocket-stream
    ws@3.3.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/ws
    async-limiter@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/async-limiter
    ultron@1.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/ultron
    iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/iobroker.type-detector
    request@2.88.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/request
    aws-sign2@0.7.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/aws-sign2
    aws4@1.8.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/aws4
    caseless@0.12.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/caseless
    combined-stream@1.0.8 /opt/iobroker/node_modules/iobroker.iot/node_modules/combined-stream
    delayed-stream@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/delayed-stream
    forever-agent@0.6.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/forever-agent
    form-data@2.3.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/form-data
    asynckit@0.4.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/asynckit
    mime-types@2.1.24 /opt/iobroker/node_modules/iobroker.iot/node_modules/mime-types
    mime-db@1.40.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/mime-db
    har-validator@5.1.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/har-validator
    ajv@6.10.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/ajv
    fast-deep-equal@2.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/fast-deep-equal
    fast-json-stable-stringify@2.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/fast-json-stable-stringify
    json-schema-traverse@0.4.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/json-schema-traverse
    uri-js@4.2.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/uri-js
    punycode@2.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/punycode
    har-schema@2.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/har-schema
    http-signature@1.2.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/http-signature
    assert-plus@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/assert-plus
    jsprim@1.4.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/jsprim
    extsprintf@1.3.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/extsprintf
    json-schema@0.2.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/json-schema
    verror@1.10.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/verror
    sshpk@1.16.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/sshpk
    asn1@0.2.4 /opt/iobroker/node_modules/iobroker.iot/node_modules/asn1
    safer-buffer@2.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/safer-buffer
    bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/bcrypt-pbkdf
    tweetnacl@0.14.5 /opt/iobroker/node_modules/iobroker.iot/node_modules/tweetnacl
    dashdash@1.14.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/dashdash
    ecc-jsbn@0.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/ecc-jsbn
    jsbn@0.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/jsbn
    getpass@0.1.7 /opt/iobroker/node_modules/iobroker.iot/node_modules/getpass
    is-typedarray@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-typedarray
    isstream@0.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/isstream
    json-stringify-safe@5.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/json-stringify-safe
    oauth-sign@0.9.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/oauth-sign
    performance-now@2.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/performance-now
    qs@6.5.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/qs
    tough-cookie@2.4.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/tough-cookie
    psl@1.1.33 /opt/iobroker/node_modules/iobroker.iot/node_modules/psl
    punycode@1.4.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/tough-cookie/node_modules/punycode
    tunnel-agent@0.6.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/tunnel-agent
    uuid@3.3.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/uuid
    iobroker.js-controller@1.5.11 /opt/iobroker/node_modules/iobroker.js-controller
    bluebird@3.5.5 /opt/iobroker/node_modules/bluebird
    daemonize2@0.4.2 /opt/iobroker/node_modules/daemonize2
    jsonwebtoken@8.5.1 /opt/iobroker/node_modules/jsonwebtoken
    jws@3.2.2 /opt/iobroker/node_modules/jws
    jwa@1.4.1 /opt/iobroker/node_modules/jwa
    buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
    ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
    lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
    lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
    lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
    lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
    lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
    lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
    lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
    ms@2.1.2 /opt/iobroker/node_modules/jsonwebtoken/node_modules/ms
    jszip@3.2.1 /opt/iobroker/node_modules/jszip
    lie@3.3.0 /opt/iobroker/node_modules/lie
    immediate@3.0.6 /opt/iobroker/node_modules/immediate
    pako@1.0.10 /opt/iobroker/node_modules/pako
    readable-stream@2.3.6 /opt/iobroker/node_modules/jszip/node_modules/readable-stream
    inherits@2.0.3 /opt/iobroker/node_modules/inherits
    isarray@1.0.0 /opt/iobroker/node_modules/jszip/node_modules/isarray
    process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
    string_decoder@1.1.1 /opt/iobroker/node_modules/jszip/node_modules/string_decoder
    util-deprecate@1.0.2 /opt/iobroker/node_modules/util-deprecate
    set-immediate-shim@1.0.1 /opt/iobroker/node_modules/set-immediate-shim
    loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
    weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
    mime@1.6.0 /opt/iobroker/node_modules/mime
    mkdirp@0.5.1 /opt/iobroker/node_modules/mkdirp
    minimist@0.0.8 /opt/iobroker/node_modules/mkdirp/node_modules/minimist
    ncp@2.0.0 /opt/iobroker/node_modules/ncp
    node-schedule@1.3.2 /opt/iobroker/node_modules/node-schedule
    cron-parser@2.12.0 /opt/iobroker/node_modules/cron-parser
    is-nan@1.2.1 /opt/iobroker/node_modules/is-nan
    define-properties@1.1.3 /opt/iobroker/node_modules/define-properties
    object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
    moment-timezone@0.5.25 /opt/iobroker/node_modules/moment-timezone
    moment@2.24.0 /opt/iobroker/node_modules/moment
    long-timeout@0.1.1 /opt/iobroker/node_modules/long-timeout
    sorted-array-functions@1.2.0 /opt/iobroker/node_modules/sorted-array-functions
    node.extend@2.0.2 /opt/iobroker/node_modules/node.extend
    has@1.0.3 /opt/iobroker/node_modules/has
    function-bind@1.1.1 /opt/iobroker/node_modules/function-bind
    is@3.3.0 /opt/iobroker/node_modules/is
    pidusage@2.0.17 /opt/iobroker/node_modules/pidusage
    prompt@1.0.0 /opt/iobroker/node_modules/prompt
    pkginfo@0.4.1 /opt/iobroker/node_modules/pkginfo
    read@1.0.7 /opt/iobroker/node_modules/read
    mute-stream@0.0.7 /opt/iobroker/node_modules/mute-stream
    revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
    utile@0.3.0 /opt/iobroker/node_modules/utile
    async@0.9.2 /opt/iobroker/node_modules/utile/node_modules/async
    deep-equal@0.2.2 /opt/iobroker/node_modules/deep-equal
    i@0.3.6 /opt/iobroker/node_modules/i
    ncp@1.0.1 /opt/iobroker/node_modules/utile/node_modules/ncp
    rimraf@2.6.3 /opt/iobroker/node_modules/rimraf
    glob@7.1.4 /opt/iobroker/node_modules/glob
    fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
    inflight@1.0.6 /opt/iobroker/node_modules/inflight
    once@1.4.0 /opt/iobroker/node_modules/once
    wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
    minimatch@3.0.4 /opt/iobroker/node_modules/minimatch
    brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
    balanced-match@1.0.0 /opt/iobroker/node_modules/balanced-match
    concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
    path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
    winston@2.1.1 /opt/iobroker/node_modules/prompt/node_modules/winston
    async@1.0.0 /opt/iobroker/node_modules/prompt/node_modules/async
    colors@1.0.3 /opt/iobroker/node_modules/prompt/node_modules/winston/node_modules/colors
    cycle@1.0.3 /opt/iobroker/node_modules/cycle
    eyes@0.1.8 /opt/iobroker/node_modules/eyes
    pkginfo@0.3.1 /opt/iobroker/node_modules/prompt/node_modules/winston/node_modules/pkginfo
    stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
    pyconf@1.1.7 /opt/iobroker/node_modules/pyconf
    safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
    socket.io@1.7.2 /opt/iobroker/node_modules/socket.io
    debug@2.3.3 /opt/iobroker/node_modules/socket.io/node_modules/debug
    ms@0.7.2 /opt/iobroker/node_modules/socket.io/node_modules/ms
    engine.io@1.8.2 /opt/iobroker/node_modules/engine.io
    accepts@1.3.3 /opt/iobroker/node_modules/engine.io/node_modules/accepts
    negotiator@0.6.1 /opt/iobroker/node_modules/engine.io/node_modules/negotiator
    debug@2.3.3 /opt/iobroker/node_modules/engine.io/node_modules/debug
    ms@0.7.2 /opt/iobroker/node_modules/engine.io/node_modules/ms
    engine.io-parser@1.3.2 /opt/iobroker/node_modules/engine.io-parser
    arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/arraybuffer.slice
    blob@0.0.4 /opt/iobroker/node_modules/blob
    has-binary@0.1.7 /opt/iobroker/node_modules/has-binary
    isarray@0.0.1 /opt/iobroker/node_modules/isarray
    wtf-8@1.0.0 /opt/iobroker/node_modules/wtf-8
    ws@1.1.1 /opt/iobroker/node_modules/ws
    options@0.0.6 /opt/iobroker/node_modules/options
    ultron@1.0.2 /opt/iobroker/node_modules/ultron
    object-assign@4.1.0 /opt/iobroker/node_modules/object-assign
    socket.io-adapter@0.5.0 /opt/iobroker/node_modules/socket.io-adapter
    debug@2.3.3 /opt/iobroker/node_modules/socket.io-adapter/node_modules/debug
    ms@0.7.2 /opt/iobroker/node_modules/socket.io-adapter/node_modules/ms
    socket.io-parser@2.3.1 /opt/iobroker/node_modules/socket.io-parser
    component-emitter@1.1.2 /opt/iobroker/node_modules/component-emitter
    debug@2.2.0 /opt/iobroker/node_modules/socket.io-parser/node_modules/debug
    ms@0.7.1 /opt/iobroker/node_modules/socket.io-parser/node_modules/ms
    json3@3.3.2 /opt/iobroker/node_modules/json3
    socket.io-client@1.7.2 /opt/iobroker/node_modules/socket.io-client
    component-emitter@1.2.1 /opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter
    debug@2.3.3 /opt/iobroker/node_modules/socket.io-client/node_modules/debug
    ms@0.7.2 /opt/iobroker/node_modules/socket.io-client/node_modules/ms
    engine.io-client@1.8.2 /opt/iobroker/node_modules/engine.io-client
    component-emitter@1.2.1 /opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter
    debug@2.3.3 /opt/iobroker/node_modules/engine.io-client/node_modules/debug
    ms@0.7.2 /opt/iobroker/node_modules/engine.io-client/node_modules/ms
    parsejson@0.0.3 /opt/iobroker/node_modules/parsejson
    xmlhttprequest-ssl@1.5.3 /opt/iobroker/node_modules/xmlhttprequest-ssl
    tar@4.4.10 /opt/iobroker/node_modules/tar
    chownr@1.1.1 /opt/iobroker/node_modules/chownr
    fs-minipass@1.2.6 /opt/iobroker/node_modules/fs-minipass
    minipass@2.3.5 /opt/iobroker/node_modules/minipass
    yallist@3.0.3 /opt/iobroker/node_modules/yallist
    minizlib@1.2.1 /opt/iobroker/node_modules/minizlib
    winston@2.4.4 /opt/iobroker/node_modules/winston
    async@1.0.0 /opt/iobroker/node_modules/winston/node_modules/async
    colors@1.0.3 /opt/iobroker/node_modules/winston/node_modules/colors
    winston-daily-rotate-file@1.7.2 /opt/iobroker/node_modules/winston-daily-rotate-file
    yargs@11.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs
    cliui@4.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/cliui
    string-width@2.1.1 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/string-width
    is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/is-fullwidth-code-point
    strip-ansi@4.0.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/strip-ansi
    ansi-regex@3.0.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/ansi-regex
    find-up@2.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/find-up
    locate-path@2.0.0 /opt/iobroker/node_modules/locate-path
    p-locate@2.0.0 /opt/iobroker/node_modules/p-locate
    p-limit@1.3.0 /opt/iobroker/node_modules/p-limit
    p-try@1.0.0 /opt/iobroker/node_modules/p-try
    path-exists@3.0.0 /opt/iobroker/node_modules/locate-path/node_modules/path-exists
    os-locale@2.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/os-locale
    execa@0.7.0 /opt/iobroker/node_modules/execa
    cross-spawn@5.1.0 /opt/iobroker/node_modules/cross-spawn
    lru-cache@4.1.5 /opt/iobroker/node_modules/lru-cache
    pseudomap@1.0.2 /opt/iobroker/node_modules/pseudomap
    yallist@2.1.2 /opt/iobroker/node_modules/lru-cache/node_modules/yallist
    shebang-command@1.2.0 /opt/iobroker/node_modules/shebang-command
    shebang-regex@1.0.0 /opt/iobroker/node_modules/shebang-regex
    which@1.3.1 /opt/iobroker/node_modules/which
    isexe@2.0.0 /opt/iobroker/node_modules/isexe
    get-stream@3.0.0 /opt/iobroker/node_modules/get-stream
    is-stream@1.1.0 /opt/iobroker/node_modules/is-stream
    npm-run-path@2.0.2 /opt/iobroker/node_modules/npm-run-path
    path-key@2.0.1 /opt/iobroker/node_modules/path-key
    p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
    signal-exit@3.0.2 /opt/iobroker/node_modules/signal-exit
    strip-eof@1.0.0 /opt/iobroker/node_modules/strip-eof
    mem@1.1.0 /opt/iobroker/node_modules/mem
    mimic-fn@1.2.0 /opt/iobroker/node_modules/mimic-fn
    which-module@2.0.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/which-module
    yargs-parser@9.0.2 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs-parser
    camelcase@4.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/camelcase
    iobroker.scenes@1.1.0 /opt/iobroker/node_modules/iobroker.scenes
    node-schedule@1.3.2 /opt/iobroker/node_modules/iobroker.scenes/node_modules/node-schedule
    cron-parser@2.12.0 /opt/iobroker/node_modules/iobroker.scenes/node_modules/cron-parser
    is-nan@1.2.1 /opt/iobroker/node_modules/iobroker.scenes/node_modules/is-nan
    define-properties@1.1.3 /opt/iobroker/node_modules/iobroker.scenes/node_modules/define-properties
    object-keys@1.1.1 /opt/iobroker/node_modules/iobroker.scenes/node_modules/object-keys
    moment-timezone@0.5.25 /opt/iobroker/node_modules/iobroker.scenes/node_modules/moment-timezone
    moment@2.24.0 /opt/iobroker/node_modules/iobroker.scenes/node_modules/moment
    long-timeout@0.1.1 /opt/iobroker/node_modules/iobroker.scenes/node_modules/long-timeout
    sorted-array-functions@1.2.0 /opt/iobroker/node_modules/iobroker.scenes/node_modules/sorted-array-functions
    suncalc@1.8.0 /opt/iobroker/node_modules/iobroker.scenes/node_modules/suncalc
    iobroker.terminal@0.1.2 /opt/iobroker/node_modules/iobroker.terminal
    body-parser@1.19.0 /opt/iobroker/node_modules/body-parser
    bytes@3.1.0 /opt/iobroker/node_modules/bytes
    content-type@1.0.4 /opt/iobroker/node_modules/content-type
    debug@2.6.9 /opt/iobroker/node_modules/debug
    depd@1.1.2 /opt/iobroker/node_modules/depd
    http-errors@1.7.2 /opt/iobroker/node_modules/http-errors
    setprototypeof@1.1.1 /opt/iobroker/node_modules/setprototypeof
    statuses@1.5.0 /opt/iobroker/node_modules/statuses
    toidentifier@1.0.0 /opt/iobroker/node_modules/toidentifier
    iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
    on-finished@2.3.0 /opt/iobroker/node_modules/on-finished
    ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
    qs@6.7.0 /opt/iobroker/node_modules/qs
    raw-body@2.4.0 /opt/iobroker/node_modules/raw-body
    unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
    type-is@1.6.18 /opt/iobroker/node_modules/type-is
    media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
    commander@2.20.0 /opt/iobroker/node_modules/commander
    connect@3.7.0 /opt/iobroker/node_modules/connect
    finalhandler@1.1.2 /opt/iobroker/node_modules/finalhandler
    encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
    escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
    parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
    utils-merge@1.0.1 /opt/iobroker/node_modules/utils-merge
    connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
    express@4.17.1 /opt/iobroker/node_modules/express
    array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
    content-disposition@0.5.3 /opt/iobroker/node_modules/content-disposition
    cookie@0.4.0 /opt/iobroker/node_modules/express/node_modules/cookie
    etag@1.8.1 /opt/iobroker/node_modules/etag
    fresh@0.5.2 /opt/iobroker/node_modules/fresh
    merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
    methods@1.1.2 /opt/iobroker/node_modules/methods
    path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
    proxy-addr@2.0.5 /opt/iobroker/node_modules/proxy-addr
    forwarded@0.1.2 /opt/iobroker/node_modules/forwarded
    ipaddr.js@1.9.0 /opt/iobroker/node_modules/ipaddr.js
    range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
    send@0.17.1 /opt/iobroker/node_modules/send
    destroy@1.0.4 /opt/iobroker/node_modules/destroy
    ms@2.1.1 /opt/iobroker/node_modules/send/node_modules/ms
    serve-static@1.14.1 /opt/iobroker/node_modules/serve-static
    vary@1.1.2 /opt/iobroker/node_modules/vary
    express-session@1.16.2 /opt/iobroker/node_modules/express-session
    depd@2.0.0 /opt/iobroker/node_modules/express-session/node_modules/depd
    on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
    uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
    random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
    lodash@4.17.11 /opt/iobroker/node_modules/lodash
    nan@2.14.0 /opt/iobroker/node_modules/nan
    passport@0.2.2 /opt/iobroker/node_modules/iobroker.terminal/node_modules/passport
    passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
    pause@0.0.1 /opt/iobroker/node_modules/pause
    passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
    xtend@4.0.1 /opt/iobroker/node_modules/xtend
    iobroker.vis@1.1.10 /opt/iobroker/node_modules/iobroker.vis
    jsonwebtoken@8.5.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/jsonwebtoken
    jws@3.2.2 /opt/iobroker/node_modules/iobroker.vis/node_modules/jws
    jwa@1.4.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/jwa
    buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/buffer-equal-constant-time
    ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/iobroker.vis/node_modules/ecdsa-sig-formatter
    safe-buffer@5.1.2 /opt/iobroker/node_modules/iobroker.vis/node_modules/safe-buffer
    lodash.includes@4.3.0 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.includes
    lodash.isboolean@3.0.3 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isboolean
    lodash.isinteger@4.0.4 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isinteger
    lodash.isnumber@3.0.3 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isnumber
    lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isplainobject
    lodash.isstring@4.0.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isstring
    lodash.once@4.1.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.once
    ms@2.1.2 /opt/iobroker/node_modules/iobroker.vis/node_modules/ms
    semver@5.7.0 /opt/iobroker/node_modules/iobroker.vis/node_modules/semver
    iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
    iobroker.vis-google-fonts@0.1.0 /opt/iobroker/node_modules/iobroker.vis-google-fonts
    iobroker.vis-hqwidgets@1.1.2 /opt/iobroker/node_modules/iobroker.vis-hqwidgets
    iobroker.vis-map@1.0.2 /opt/iobroker/node_modules/iobroker.vis-map
    iobroker.vis-rgraph@0.0.2 /opt/iobroker/node_modules/iobroker.vis-rgraph
    iobroker.vis-weather@2.3.0 /opt/iobroker/node_modules/iobroker.vis-weather
    flot@2.3.2 /opt/iobroker/node_modules/flot
    file-exist@0.0.4 /opt/iobroker/node_modules/file-exist
    files-exist@1.1.0 /opt/iobroker/node_modules/files-exist
    defaults@1.0.3 /opt/iobroker/node_modules/defaults
    clone@1.0.4 /opt/iobroker/node_modules/clone
    glob@6.0.4 /opt/iobroker/node_modules/files-exist/node_modules/glob
    npm@6.9.2 /opt/iobroker/node_modules/npm
    JSONStream@1.3.5 /opt/iobroker/node_modules/npm/node_modules/JSONStream
    jsonparse@1.3.1 /opt/iobroker/node_modules/npm/node_modules/jsonparse
    through@2.3.8 /opt/iobroker/node_modules/npm/node_modules/through
    abbrev@1.1.1 /opt/iobroker/node_modules/npm/node_modules/abbrev
    ansicolors@0.3.2 /opt/iobroker/node_modules/npm/node_modules/ansicolors
    ansistyles@0.1.3 /opt/iobroker/node_modules/npm/node_modules/ansistyles
    aproba@2.0.0 /opt/iobroker/node_modules/npm/node_modules/aproba
    archy@1.0.0 /opt/iobroker/node_modules/npm/node_modules/archy
    bin-links@1.1.2 /opt/iobroker/node_modules/npm/node_modules/bin-links
    bluebird@3.5.3 /opt/iobroker/node_modules/npm/node_modules/bluebird
    cmd-shim@2.0.2 /opt/iobroker/node_modules/npm/node_modules/cmd-shim
    graceful-fs@4.1.15 /opt/iobroker/node_modules/npm/node_modules/graceful-fs
    mkdirp@0.5.1 /opt/iobroker/node_modules/npm/node_modules/mkdirp
    minimist@0.0.8 /opt/iobroker/node_modules/npm/node_modules/minimist
    gentle-fs@2.0.1 /opt/iobroker/node_modules/npm/node_modules/gentle-fs
    aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/gentle-fs/node_modules/aproba
    fs-vacuum@1.2.10 /opt/iobroker/node_modules/npm/node_modules/fs-vacuum
    path-is-inside@1.0.2 /opt/iobroker/node_modules/npm/node_modules/path-is-inside
    rimraf@2.6.3 /opt/iobroker/node_modules/npm/node_modules/rimraf
    glob@7.1.3 /opt/iobroker/node_modules/npm/node_modules/glob
    fs.realpath@1.0.0 /opt/iobroker/node_modules/npm/node_modules/fs.realpath
    inflight@1.0.6 /opt/iobroker/node_modules/npm/node_modules/inflight
    once@1.4.0 /opt/iobroker/node_modules/npm/node_modules/once
    wrappy@1.0.2 /opt/iobroker/node_modules/npm/node_modules/wrappy
    inherits@2.0.3 /opt/iobroker/node_modules/npm/node_modules/inherits
    minimatch@3.0.4 /opt/iobroker/node_modules/npm/node_modules/minimatch
    brace-expansion@1.1.11 /opt/iobroker/node_modules/npm/node_modules/brace-expansion
    balanced-match@1.0.0 /opt/iobroker/node_modules/npm/node_modules/balanced-match
    concat-map@0.0.1 /opt/iobroker/node_modules/npm/node_modules/concat-map
    path-is-absolute@1.0.1 /opt/iobroker/node_modules/npm/node_modules/path-is-absolute
    iferr@0.1.5 /opt/iobroker/node_modules/npm/node_modules/gentle-fs/node_modules/iferr
    read-cmd-shim@1.0.1 /opt/iobroker/node_modules/npm/node_modules/read-cmd-shim
    slide@1.1.6 /opt/iobroker/node_modules/npm/node_modules/slide
    write-file-atomic@2.4.2 /opt/iobroker/node_modules/npm/node_modules/write-file-atomic
    imurmurhash@0.1.4 /opt/iobroker/node_modules/npm/node_modules/imurmurhash
    signal-exit@3.0.2 /opt/iobroker/node_modules/npm/node_modules/signal-exit
    byte-size@5.0.1 /opt/iobroker/node_modules/npm/node_modules/byte-size
    cacache@11.3.2 /opt/iobroker/node_modules/npm/node_modules/cacache
    chownr@1.1.1 /opt/iobroker/node_modules/npm/node_modules/cacache/node_modules/chownr
    figgy-pudding@3.5.1 /opt/iobroker/node_modules/npm/node_modules/figgy-pudding
      ThorstenStr
      hier der 2te Teil
      lru-cache@5.1.1 /opt/iobroker/node_modules/npm/node_modules/cacache/node_modules/lru-cache
      yallist@3.0.3 /opt/iobroker/node_modules/npm/node_modules/cacache/node_modules/yallist
      mississippi@3.0.0 /opt/iobroker/node_modules/npm/node_modules/mississippi
      concat-stream@1.6.2 /opt/iobroker/node_modules/npm/node_modules/concat-stream
      buffer-from@1.0.0 /opt/iobroker/node_modules/npm/node_modules/buffer-from
      readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/concat-stream/node_modules/readable-stream
      core-util-is@1.0.2 /opt/iobroker/node_modules/npm/node_modules/core-util-is
      isarray@1.0.0 /opt/iobroker/node_modules/npm/node_modules/isarray
      process-nextick-args@2.0.0 /opt/iobroker/node_modules/npm/node_modules/process-nextick-args
      safe-buffer@5.1.2 /opt/iobroker/node_modules/npm/node_modules/safe-buffer
      string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/concat-stream/node_modules/string_decoder
      util-deprecate@1.0.2 /opt/iobroker/node_modules/npm/node_modules/util-deprecate
      typedarray@0.0.6 /opt/iobroker/node_modules/npm/node_modules/typedarray
      duplexify@3.6.0 /opt/iobroker/node_modules/npm/node_modules/duplexify
      end-of-stream@1.4.1 /opt/iobroker/node_modules/npm/node_modules/end-of-stream
      readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/duplexify/node_modules/readable-stream
      string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/duplexify/node_modules/string_decoder
      stream-shift@1.0.0 /opt/iobroker/node_modules/npm/node_modules/stream-shift
      flush-write-stream@1.0.3 /opt/iobroker/node_modules/npm/node_modules/flush-write-stream
      readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream
      string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/flush-write-stream/node_modules/string_decoder
      from2@2.3.0 /opt/iobroker/node_modules/npm/node_modules/from2
      readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/from2/node_modules/readable-stream
      string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/from2/node_modules/string_decoder
      parallel-transform@1.1.0 /opt/iobroker/node_modules/npm/node_modules/parallel-transform
      cyclist@0.2.2 /opt/iobroker/node_modules/npm/node_modules/cyclist
      readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/parallel-transform/node_modules/readable-stream
      string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/parallel-transform/node_modules/string_decoder
      pump@3.0.0 /opt/iobroker/node_modules/npm/node_modules/pump
      pumpify@1.5.1 /opt/iobroker/node_modules/npm/node_modules/pumpify
      pump@2.0.1 /opt/iobroker/node_modules/npm/node_modules/pumpify/node_modules/pump
      stream-each@1.2.2 /opt/iobroker/node_modules/npm/node_modules/stream-each
      through2@2.0.3 /opt/iobroker/node_modules/npm/node_modules/through2
      readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/through2/node_modules/readable-stream
      string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/through2/node_modules/string_decoder
      xtend@4.0.1 /opt/iobroker/node_modules/npm/node_modules/xtend
      move-concurrently@1.0.1 /opt/iobroker/node_modules/npm/node_modules/move-concurrently
      aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/move-concurrently/node_modules/aproba
      copy-concurrently@1.0.5 /opt/iobroker/node_modules/npm/node_modules/copy-concurrently
      aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/copy-concurrently/node_modules/aproba
      fs-write-stream-atomic@1.0.10 /opt/iobroker/node_modules/npm/node_modules/fs-write-stream-atomic
      iferr@0.1.5 /opt/iobroker/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/iferr
      readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/readable-stream
      string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/string_decoder
      iferr@0.1.5 /opt/iobroker/node_modules/npm/node_modules/copy-concurrently/node_modules/iferr
      run-queue@1.0.3 /opt/iobroker/node_modules/npm/node_modules/run-queue
      aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/run-queue/node_modules/aproba
      promise-inflight@1.0.1 /opt/iobroker/node_modules/npm/node_modules/promise-inflight
      ssri@6.0.1 /opt/iobroker/node_modules/npm/node_modules/ssri
      unique-filename@1.1.1 /opt/iobroker/node_modules/npm/node_modules/cacache/node_modules/unique-filename
      unique-slug@2.0.0 /opt/iobroker/node_modules/npm/node_modules/unique-slug
      y18n@4.0.0 /opt/iobroker/node_modules/npm/node_modules/y18n
      call-limit@1.1.0 /opt/iobroker/node_modules/npm/node_modules/call-limit
      chownr@1.1.1 /opt/iobroker/node_modules/npm/node_modules/chownr
      ci-info@2.0.0 /opt/iobroker/node_modules/npm/node_modules/ci-info
      cli-columns@3.1.2 /opt/iobroker/node_modules/npm/node_modules/cli-columns
      string-width@2.1.1 /opt/iobroker/node_modules/npm/node_modules/string-width
      is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/npm/node_modules/string-width/node_modules/is-fullwidth-code-point
      strip-ansi@4.0.0 /opt/iobroker/node_modules/npm/node_modules/string-width/node_modules/strip-ansi
      ansi-regex@3.0.0 /opt/iobroker/node_modules/npm/node_modules/string-width/node_modules/ansi-regex
      strip-ansi@3.0.1 /opt/iobroker/node_modules/npm/node_modules/strip-ansi
      ansi-regex@2.1.1 /opt/iobroker/node_modules/npm/node_modules/ansi-regex
      cli-table3@0.5.1 /opt/iobroker/node_modules/npm/node_modules/cli-table3
      object-assign@4.1.1 /opt/iobroker/node_modules/npm/node_modules/object-assign
      columnify@1.5.4 /opt/iobroker/node_modules/npm/node_modules/columnify
      wcwidth@1.0.1 /opt/iobroker/node_modules/npm/node_modules/wcwidth
      defaults@1.0.3 /opt/iobroker/node_modules/npm/node_modules/defaults
      clone@1.0.4 /opt/iobroker/node_modules/npm/node_modules/clone
      config-chain@1.1.12 /opt/iobroker/node_modules/npm/node_modules/config-chain
      ini@1.3.5 /opt/iobroker/node_modules/npm/node_modules/ini
      proto-list@1.2.4 /opt/iobroker/node_modules/npm/node_modules/proto-list
      debuglog@1.0.1 /opt/iobroker/node_modules/npm/node_modules/debuglog
      detect-indent@5.0.0 /opt/iobroker/node_modules/npm/node_modules/detect-indent
      detect-newline@2.1.0 /opt/iobroker/node_modules/npm/node_modules/detect-newline
      dezalgo@1.0.3 /opt/iobroker/node_modules/npm/node_modules/dezalgo
      asap@2.0.6 /opt/iobroker/node_modules/npm/node_modules/asap
      editor@1.0.0 /opt/iobroker/node_modules/npm/node_modules/editor
      find-npm-prefix@1.0.2 /opt/iobroker/node_modules/npm/node_modules/find-npm-prefix
      has-unicode@2.0.1 /opt/iobroker/node_modules/npm/node_modules/has-unicode
      hosted-git-info@2.7.1 /opt/iobroker/node_modules/npm/node_modules/hosted-git-info
      iferr@1.0.2 /opt/iobroker/node_modules/npm/node_modules/iferr
      init-package-json@1.10.3 /opt/iobroker/node_modules/npm/node_modules/init-package-json
      npm-package-arg@6.1.0 /opt/iobroker/node_modules/npm/node_modules/npm-package-arg
      osenv@0.1.5 /opt/iobroker/node_modules/npm/node_modules/osenv
      os-homedir@1.0.2 /opt/iobroker/node_modules/npm/node_modules/os-homedir
      os-tmpdir@1.0.2 /opt/iobroker/node_modules/npm/node_modules/os-tmpdir
      semver@5.6.0 /opt/iobroker/node_modules/npm/node_modules/semver
      validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/npm/node_modules/validate-npm-package-name
      builtins@1.0.3 /opt/iobroker/node_modules/npm/node_modules/builtins
      promzard@0.3.0 /opt/iobroker/node_modules/npm/node_modules/promzard
      read@1.0.7 /opt/iobroker/node_modules/npm/node_modules/read
      mute-stream@0.0.7 /opt/iobroker/node_modules/npm/node_modules/mute-stream
      read-package-json@2.0.13 /opt/iobroker/node_modules/npm/node_modules/read-package-json
      json-parse-better-errors@1.0.2 /opt/iobroker/node_modules/npm/node_modules/json-parse-better-errors
      normalize-package-data@2.5.0 /opt/iobroker/node_modules/npm/node_modules/normalize-package-data
      resolve@1.10.0 /opt/iobroker/node_modules/npm/node_modules/normalize-package-data/node_modules/resolve
      path-parse@1.0.6 /opt/iobroker/node_modules/npm/node_modules/path-parse
      validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/npm/node_modules/validate-npm-package-license
      spdx-correct@3.0.0 /opt/iobroker/node_modules/npm/node_modules/spdx-correct
      spdx-expression-parse@3.0.0 /opt/iobroker/node_modules/npm/node_modules/spdx-expression-parse
      spdx-exceptions@2.1.0 /opt/iobroker/node_modules/npm/node_modules/spdx-exceptions
      spdx-license-ids@3.0.3 /opt/iobroker/node_modules/npm/node_modules/spdx-license-ids
      slash@1.0.0 /opt/iobroker/node_modules/npm/node_modules/slash
      is-cidr@3.0.0 /opt/iobroker/node_modules/npm/node_modules/is-cidr
      cidr-regex@2.0.10 /opt/iobroker/node_modules/npm/node_modules/cidr-regex
      ip-regex@2.1.0 /opt/iobroker/node_modules/npm/node_modules/ip-regex
      lazy-property@1.0.0 /opt/iobroker/node_modules/npm/node_modules/lazy-property
      libcipm@3.0.3 /opt/iobroker/node_modules/npm/node_modules/libcipm
      lock-verify@2.1.0 /opt/iobroker/node_modules/npm/node_modules/lock-verify
      npm-lifecycle@2.1.0 /opt/iobroker/node_modules/npm/node_modules/npm-lifecycle
      byline@5.0.0 /opt/iobroker/node_modules/npm/node_modules/byline
      node-gyp@3.8.0 /opt/iobroker/node_modules/npm/node_modules/node-gyp
      fstream@1.0.11 /opt/iobroker/node_modules/npm/node_modules/fstream
      nopt@3.0.6 /opt/iobroker/node_modules/npm/node_modules/node-gyp/node_modules/nopt
      npmlog@4.1.2 /opt/iobroker/node_modules/npm/node_modules/npmlog
      are-we-there-yet@1.1.4 /opt/iobroker/node_modules/npm/node_modules/are-we-there-yet
      delegates@1.0.0 /opt/iobroker/node_modules/npm/node_modules/delegates
      readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/are-we-there-yet/node_modules/readable-stream
      string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/are-we-there-yet/node_modules/string_decoder
      console-control-strings@1.1.0 /opt/iobroker/node_modules/npm/node_modules/console-control-strings
      gauge@2.7.4 /opt/iobroker/node_modules/npm/node_modules/gauge
      aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/gauge/node_modules/aproba
      string-width@1.0.2 /opt/iobroker/node_modules/npm/node_modules/gauge/node_modules/string-width
      code-point-at@1.1.0 /opt/iobroker/node_modules/npm/node_modules/code-point-at
      is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/npm/node_modules/is-fullwidth-code-point
      number-is-nan@1.0.1 /opt/iobroker/node_modules/npm/node_modules/number-is-nan
      wide-align@1.1.2 /opt/iobroker/node_modules/npm/node_modules/wide-align
      string-width@1.0.2 /opt/iobroker/node_modules/npm/node_modules/wide-align/node_modules/string-width
      set-blocking@2.0.0 /opt/iobroker/node_modules/npm/node_modules/set-blocking
      request@2.88.0 /opt/iobroker/node_modules/npm/node_modules/request
      aws-sign2@0.7.0 /opt/iobroker/node_modules/npm/node_modules/aws-sign2
      aws4@1.8.0 /opt/iobroker/node_modules/npm/node_modules/aws4
      caseless@0.12.0 /opt/iobroker/node_modules/npm/node_modules/caseless
      combined-stream@1.0.6 /opt/iobroker/node_modules/npm/node_modules/combined-stream
      delayed-stream@1.0.0 /opt/iobroker/node_modules/npm/node_modules/delayed-stream
      extend@3.0.2 /opt/iobroker/node_modules/npm/node_modules/extend
      forever-agent@0.6.1 /opt/iobroker/node_modules/npm/node_modules/forever-agent
      form-data@2.3.2 /opt/iobroker/node_modules/npm/node_modules/form-data
      asynckit@0.4.0 /opt/iobroker/node_modules/npm/node_modules/asynckit
      mime-types@2.1.19 /opt/iobroker/node_modules/npm/node_modules/mime-types
      mime-db@1.35.0 /opt/iobroker/node_modules/npm/node_modules/mime-db
      har-validator@5.1.0 /opt/iobroker/node_modules/npm/node_modules/har-validator
      ajv@5.5.2 /opt/iobroker/node_modules/npm/node_modules/ajv
      co@4.6.0 /opt/iobroker/node_modules/npm/node_modules/co
      fast-deep-equal@1.1.0 /opt/iobroker/node_modules/npm/node_modules/fast-deep-equal
      fast-json-stable-stringify@2.0.0 /opt/iobroker/node_modules/npm/node_modules/fast-json-stable-stringify
      json-schema-traverse@0.3.1 /opt/iobroker/node_modules/npm/node_modules/json-schema-traverse
      har-schema@2.0.0 /opt/iobroker/node_modules/npm/node_modules/har-schema
      http-signature@1.2.0 /opt/iobroker/node_modules/npm/node_modules/http-signature
      assert-plus@1.0.0 /opt/iobroker/node_modules/npm/node_modules/assert-plus
      jsprim@1.4.1 /opt/iobroker/node_modules/npm/node_modules/jsprim
      extsprintf@1.3.0 /opt/iobroker/node_modules/npm/node_modules/extsprintf
      json-schema@0.2.3 /opt/iobroker/node_modules/npm/node_modules/json-schema
      verror@1.10.0 /opt/iobroker/node_modules/npm/node_modules/verror
      sshpk@1.14.2 /opt/iobroker/node_modules/npm/node_modules/sshpk
      asn1@0.2.4 /opt/iobroker/node_modules/npm/node_modules/asn1
      safer-buffer@2.1.2 /opt/iobroker/node_modules/npm/node_modules/safer-buffer
      dashdash@1.14.1 /opt/iobroker/node_modules/npm/node_modules/dashdash
      getpass@0.1.7 /opt/iobroker/node_modules/npm/node_modules/getpass
      is-typedarray@1.0.0 /opt/iobroker/node_modules/npm/node_modules/is-typedarray
      isstream@0.1.2 /opt/iobroker/node_modules/npm/node_modules/isstream
      json-stringify-safe@5.0.1 /opt/iobroker/node_modules/npm/node_modules/json-stringify-safe
      oauth-sign@0.9.0 /opt/iobroker/node_modules/npm/node_modules/oauth-sign
      performance-now@2.1.0 /opt/iobroker/node_modules/npm/node_modules/performance-now
      qs@6.5.2 /opt/iobroker/node_modules/npm/node_modules/qs
      tough-cookie@2.4.3 /opt/iobroker/node_modules/npm/node_modules/tough-cookie
      psl@1.1.29 /opt/iobroker/node_modules/npm/node_modules/psl
      punycode@1.4.1 /opt/iobroker/node_modules/npm/node_modules/punycode
      tunnel-agent@0.6.0 /opt/iobroker/node_modules/npm/node_modules/tunnel-agent
      uuid@3.3.2 /opt/iobroker/node_modules/npm/node_modules/uuid
      semver@5.3.0 /opt/iobroker/node_modules/npm/node_modules/node-gyp/node_modules/semver
      tar@2.2.1 /opt/iobroker/node_modules/npm/node_modules/node-gyp/node_modules/tar
      block-stream@0.0.9 /opt/iobroker/node_modules/npm/node_modules/block-stream
      which@1.3.1 /opt/iobroker/node_modules/npm/node_modules/which
      isexe@2.0.0 /opt/iobroker/node_modules/npm/node_modules/isexe
      resolve-from@4.0.0 /opt/iobroker/node_modules/npm/node_modules/resolve-from
      uid-number@0.0.6 /opt/iobroker/node_modules/npm/node_modules/uid-number
      umask@1.1.0 /opt/iobroker/node_modules/npm/node_modules/umask
      npm-logical-tree@1.2.1 /opt/iobroker/node_modules/npm/node_modules/npm-logical-tree
      pacote@9.5.0 /opt/iobroker/node_modules/npm/node_modules/pacote
      get-stream@4.1.0 /opt/iobroker/node_modules/npm/node_modules/get-stream
      lru-cache@5.1.1 /opt/iobroker/node_modules/npm/node_modules/pacote/node_modules/lru-cache
      yallist@3.0.3 /opt/iobroker/node_modules/npm/node_modules/pacote/node_modules/yallist
      make-fetch-happen@4.0.1 /opt/iobroker/node_modules/npm/node_modules/make-fetch-happen
      agentkeepalive@3.4.1 /opt/iobroker/node_modules/npm/node_modules/agentkeepalive
      humanize-ms@1.2.1 /opt/iobroker/node_modules/npm/node_modules/humanize-ms
      ms@2.1.1 /opt/iobroker/node_modules/npm/node_modules/ms
      http-cache-semantics@3.8.1 /opt/iobroker/node_modules/npm/node_modules/http-cache-semantics
      http-proxy-agent@2.1.0 /opt/iobroker/node_modules/npm/node_modules/http-proxy-agent
      agent-base@4.2.1 /opt/iobroker/node_modules/npm/node_modules/agent-base
      es6-promisify@5.0.0 /opt/iobroker/node_modules/npm/node_modules/es6-promisify
      es6-promise@4.2.6 /opt/iobroker/node_modules/npm/node_modules/es6-promise
      debug@3.1.0 /opt/iobroker/node_modules/npm/node_modules/debug
      ms@2.0.0 /opt/iobroker/node_modules/npm/node_modules/debug/node_modules/ms
      https-proxy-agent@2.2.1 /opt/iobroker/node_modules/npm/node_modules/https-proxy-agent
      lru-cache@4.1.5 /opt/iobroker/node_modules/npm/node_modules/lru-cache
      pseudomap@1.0.2 /opt/iobroker/node_modules/npm/node_modules/pseudomap
      yallist@2.1.2 /opt/iobroker/node_modules/npm/node_modules/yallist
      node-fetch-npm@2.0.2 /opt/iobroker/node_modules/npm/node_modules/node-fetch-npm
      encoding@0.1.12 /opt/iobroker/node_modules/npm/node_modules/encoding
      iconv-lite@0.4.23 /opt/iobroker/node_modules/npm/node_modules/iconv-lite
      promise-retry@1.1.1 /opt/iobroker/node_modules/npm/node_modules/promise-retry
      err-code@1.1.2 /opt/iobroker/node_modules/npm/node_modules/err-code
      retry@0.10.1 /opt/iobroker/node_modules/npm/node_modules/promise-retry/node_modules/retry
      socks-proxy-agent@4.0.1 /opt/iobroker/node_modules/npm/node_modules/socks-proxy-agent
      socks@2.2.0 /opt/iobroker/node_modules/npm/node_modules/socks
      ip@1.1.5 /opt/iobroker/node_modules/npm/node_modules/ip
      smart-buffer@4.0.1 /opt/iobroker/node_modules/npm/node_modules/smart-buffer
      minipass@2.3.5 /opt/iobroker/node_modules/npm/node_modules/pacote/node_modules/minipass
      npm-packlist@1.4.1 /opt/iobroker/node_modules/npm/node_modules/npm-packlist
      ignore-walk@3.0.1 /opt/iobroker/node_modules/npm/node_modules/ignore-walk
      npm-bundled@1.0.6 /opt/iobroker/node_modules/npm/node_modules/npm-bundled
      npm-pick-manifest@2.2.3 /opt/iobroker/node_modules/npm/node_modules/npm-pick-manifest
      npm-registry-fetch@3.9.0 /opt/iobroker/node_modules/npm/node_modules/npm-registry-fetch
      protoduck@5.0.1 /opt/iobroker/node_modules/npm/node_modules/protoduck
      genfun@5.0.0 /opt/iobroker/node_modules/npm/node_modules/genfun
      tar@4.4.8 /opt/iobroker/node_modules/npm/node_modules/tar
      chownr@1.1.1 /opt/iobroker/node_modules/npm/node_modules/tar/node_modules/chownr
      fs-minipass@1.2.5 /opt/iobroker/node_modules/npm/node_modules/fs-minipass
      minipass@2.3.3 /opt/iobroker/node_modules/npm/node_modules/minipass
      yallist@3.0.2 /opt/iobroker/node_modules/npm/node_modules/minipass/node_modules/yallist
      minipass@2.3.5 /opt/iobroker/node_modules/npm/node_modules/tar/node_modules/minipass
      yallist@3.0.3 /opt/iobroker/node_modules/npm/node_modules/tar/node_modules/yallist
      minizlib@1.1.1 /opt/iobroker/node_modules/npm/node_modules/minizlib
      unique-filename@1.1.1 /opt/iobroker/node_modules/npm/node_modules/unique-filename
      worker-farm@1.6.0 /opt/iobroker/node_modules/npm/node_modules/worker-farm
      errno@0.1.7 /opt/iobroker/node_modules/npm/node_modules/errno
      prr@1.0.1 /opt/iobroker/node_modules/npm/node_modules/prr
      libnpm@2.0.1 /opt/iobroker/node_modules/npm/node_modules/libnpm
      libnpmaccess@3.0.1 /opt/iobroker/node_modules/npm/node_modules/libnpmaccess
      aproba@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmaccess/node_modules/aproba
      libnpmconfig@1.2.1 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig
      find-up@3.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/find-up
      locate-path@3.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/locate-path
      p-locate@3.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/p-locate
      p-limit@2.1.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/p-limit
      p-try@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/p-try
      path-exists@3.0.0 /opt/iobroker/node_modules/npm/node_modules/path-exists
      libnpmhook@5.0.2 /opt/iobroker/node_modules/npm/node_modules/libnpmhook
      libnpmorg@1.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmorg
      aproba@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmorg/node_modules/aproba
      libnpmpublish@1.1.1 /opt/iobroker/node_modules/npm/node_modules/libnpmpublish
      lodash.clonedeep@4.5.0 /opt/iobroker/node_modules/npm/node_modules/lodash.clonedeep
      libnpmsearch@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmsearch
      libnpmteam@1.0.1 /opt/iobroker/node_modules/npm/node_modules/libnpmteam
      aproba@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmteam/node_modules/aproba
      npm-profile@4.0.1 /opt/iobroker/node_modules/npm/node_modules/npm-profile
      stringify-package@1.0.0 /opt/iobroker/node_modules/npm/node_modules/stringify-package
      libnpx@10.2.0 /opt/iobroker/node_modules/npm/node_modules/libnpx
      dotenv@5.0.1 /opt/iobroker/node_modules/npm/node_modules/dotenv
      update-notifier@2.5.0 /opt/iobroker/node_modules/npm/node_modules/update-notifier
      boxen@1.3.0 /opt/iobroker/node_modules/npm/node_modules/boxen
      ansi-align@2.0.0 /opt/iobroker/node_modules/npm/node_modules/ansi-align
      camelcase@4.1.0 /opt/iobroker/node_modules/npm/node_modules/camelcase
      chalk@2.4.1 /opt/iobroker/node_modules/npm/node_modules/chalk
      ansi-styles@3.2.1 /opt/iobroker/node_modules/npm/node_modules/ansi-styles
      color-convert@1.9.1 /opt/iobroker/node_modules/npm/node_modules/color-convert
      color-name@1.1.3 /opt/iobroker/node_modules/npm/node_modules/color-name
      escape-string-regexp@1.0.5 /opt/iobroker/node_modules/npm/node_modules/escape-string-regexp
      supports-color@5.4.0 /opt/iobroker/node_modules/npm/node_modules/supports-color
      has-flag@3.0.0 /opt/iobroker/node_modules/npm/node_modules/has-flag
      cli-boxes@1.0.0 /opt/iobroker/node_modules/npm/node_modules/cli-boxes
      term-size@1.2.0 /opt/iobroker/node_modules/npm/node_modules/term-size
      execa@0.7.0 /opt/iobroker/node_modules/npm/node_modules/execa
      cross-spawn@5.1.0 /opt/iobroker/node_modules/npm/node_modules/cross-spawn
      shebang-command@1.2.0 /opt/iobroker/node_modules/npm/node_modules/shebang-command
      shebang-regex@1.0.0 /opt/iobroker/node_modules/npm/node_modules/shebang-regex
      get-stream@3.0.0 /opt/iobroker/node_modules/npm/node_modules/execa/node_modules/get-stream
      is-stream@1.1.0 /opt/iobroker/node_modules/npm/node_modules/is-stream
      npm-run-path@2.0.2 /opt/iobroker/node_modules/npm/node_modules/npm-run-path
      path-key@2.0.1 /opt/iobroker/node_modules/npm/node_modules/path-key
      p-finally@1.0.0 /opt/iobroker/node_modules/npm/node_modules/p-finally
      strip-eof@1.0.0 /opt/iobroker/node_modules/npm/node_modules/strip-eof
      widest-line@2.0.0 /opt/iobroker/node_modules/npm/node_modules/widest-line
      configstore@3.1.2 /opt/iobroker/node_modules/npm/node_modules/configstore
      dot-prop@4.2.0 /opt/iobroker/node_modules/npm/node_modules/dot-prop
      is-obj@1.0.1 /opt/iobroker/node_modules/npm/node_modules/is-obj
      make-dir@1.3.0 /opt/iobroker/node_modules/npm/node_modules/make-dir
      pify@3.0.0 /opt/iobroker/node_modules/npm/node_modules/pify
      unique-string@1.0.0 /opt/iobroker/node_modules/npm/node_modules/unique-string
      crypto-random-string@1.0.0 /opt/iobroker/node_modules/npm/node_modules/crypto-random-string
      xdg-basedir@3.0.0 /opt/iobroker/node_modules/npm/node_modules/xdg-basedir
      import-lazy@2.1.0 /opt/iobroker/node_modules/npm/node_modules/import-lazy
      is-ci@1.1.0 /opt/iobroker/node_modules/npm/node_modules/is-ci
      ci-info@1.6.0 /opt/iobroker/node_modules/npm/node_modules/is-ci/node_modules/ci-info
      is-installed-globally@0.1.0 /opt/iobroker/node_modules/npm/node_modules/is-installed-globally
      global-dirs@0.1.1 /opt/iobroker/node_modules/npm/node_modules/global-dirs
      is-path-inside@1.0.1 /opt/iobroker/node_modules/npm/node_modules/is-path-inside
      is-npm@1.0.0 /opt/iobroker/node_modules/npm/node_modules/is-npm
      latest-version@3.1.0 /opt/iobroker/node_modules/npm/node_modules/latest-version
      package-json@4.0.1 /opt/iobroker/node_modules/npm/node_modules/package-json
      got@6.7.1 /opt/iobroker/node_modules/npm/node_modules/got
      create-error-class@3.0.2 /opt/iobroker/node_modules/npm/node_modules/create-error-class
      capture-stack-trace@1.0.0 /opt/iobroker/node_modules/npm/node_modules/capture-stack-trace
      duplexer3@0.1.4 /opt/iobroker/node_modules/npm/node_modules/duplexer3
      get-stream@3.0.0 /opt/iobroker/node_modules/npm/node_modules/got/node_modules/get-stream
      is-redirect@1.0.0 /opt/iobroker/node_modules/npm/node_modules/is-redirect
      is-retry-allowed@1.1.0 /opt/iobroker/node_modules/npm/node_modules/is-retry-allowed
      lowercase-keys@1.0.1 /opt/iobroker/node_modules/npm/node_modules/lowercase-keys
      timed-out@4.0.1 /opt/iobroker/node_modules/npm/node_modules/timed-out
      unzip-response@2.0.1 /opt/iobroker/node_modules/npm/node_modules/unzip-response
      url-parse-lax@1.0.0 /opt/iobroker/node_modules/npm/node_modules/url-parse-lax
      prepend-http@1.0.4 /opt/iobroker/node_modules/npm/node_modules/prepend-http
      registry-auth-token@3.3.2 /opt/iobroker/node_modules/npm/node_modules/registry-auth-token
      rc@1.2.7 /opt/iobroker/node_modules/npm/node_modules/rc
      deep-extend@0.5.1 /opt/iobroker/node_modules/npm/node_modules/deep-extend
      minimist@1.2.0 /opt/iobroker/node_modules/npm/node_modules/rc/node_modules/minimist
      strip-json-comments@2.0.1 /opt/iobroker/node_modules/npm/node_modules/strip-json-comments
      registry-url@3.1.0 /opt/iobroker/node_modules/npm/node_modules/registry-url
      semver-diff@2.1.0 /opt/iobroker/node_modules/npm/node_modules/semver-diff
      yargs@11.0.0 /opt/iobroker/node_modules/npm/node_modules/yargs
      cliui@4.1.0 /opt/iobroker/node_modules/npm/node_modules/cliui
      strip-ansi@4.0.0 /opt/iobroker/node_modules/npm/node_modules/cliui/node_modules/strip-ansi
      ansi-regex@3.0.0 /opt/iobroker/node_modules/npm/node_modules/cliui/node_modules/ansi-regex
      wrap-ansi@2.1.0 /opt/iobroker/node_modules/npm/node_modules/wrap-ansi
      string-width@1.0.2 /opt/iobroker/node_modules/npm/node_modules/wrap-ansi/node_modules/string-width
      decamelize@1.2.0 /opt/iobroker/node_modules/npm/node_modules/decamelize
      find-up@2.1.0 /opt/iobroker/node_modules/npm/node_modules/find-up
      locate-path@2.0.0 /opt/iobroker/node_modules/npm/node_modules/locate-path
      p-locate@2.0.0 /opt/iobroker/node_modules/npm/node_modules/p-locate
      p-limit@1.2.0 /opt/iobroker/node_modules/npm/node_modules/p-limit
      p-try@1.0.0 /opt/iobroker/node_modules/npm/node_modules/p-try
      get-caller-file@1.0.2 /opt/iobroker/node_modules/npm/node_modules/get-caller-file
      os-locale@2.1.0 /opt/iobroker/node_modules/npm/node_modules/os-locale
      lcid@1.0.0 /opt/iobroker/node_modules/npm/node_modules/lcid
      invert-kv@1.0.0 /opt/iobroker/node_modules/npm/node_modules/invert-kv
      mem@1.1.0 /opt/iobroker/node_modules/npm/node_modules/mem
      mimic-fn@1.2.0 /opt/iobroker/node_modules/npm/node_modules/mimic-fn
      require-directory@2.1.1 /opt/iobroker/node_modules/npm/node_modules/require-directory
      require-main-filename@1.0.1 /opt/iobroker/node_modules/npm/node_modules/require-main-filename
      which-module@2.0.0 /opt/iobroker/node_modules/npm/node_modules/which-module
      y18n@3.2.1 /opt/iobroker/node_modules/npm/node_modules/yargs/node_modules/y18n
      yargs-parser@9.0.2 /opt/iobroker/node_modules/npm/node_modules/yargs-parser
      lockfile@1.0.4 /opt/iobroker/node_modules/npm/node_modules/lockfile
      lodash._baseindexof@3.1.0 /opt/iobroker/node_modules/npm/node_modules/lodash._baseindexof
      lodash._baseuniq@4.6.0 /opt/iobroker/node_modules/npm/node_modules/lodash._baseuniq
      lodash._createset@4.0.3 /opt/iobroker/node_modules/npm/node_modules/lodash._createset
      lodash._root@3.0.1 /opt/iobroker/node_modules/npm/node_modules/lodash._root
      lodash._bindcallback@3.0.1 /opt/iobroker/node_modules/npm/node_modules/lodash._bindcallback
      lodash._cacheindexof@3.0.2 /opt/iobroker/node_modules/npm/node_modules/lodash._cacheindexof
      lodash._createcache@3.1.2 /opt/iobroker/node_modules/npm/node_modules/lodash._createcache
      lodash._getnative@3.9.1 /opt/iobroker/node_modules/npm/node_modules/lodash._getnative
      lodash.restparam@3.6.1 /opt/iobroker/node_modules/npm/node_modules/lodash.restparam
      lodash.union@4.6.0 /opt/iobroker/node_modules/npm/node_modules/lodash.union
      lodash.uniq@4.5.0 /opt/iobroker/node_modules/npm/node_modules/lodash.uniq
      lodash.without@4.4.0 /opt/iobroker/node_modules/npm/node_modules/lodash.without
      meant@1.0.1 /opt/iobroker/node_modules/npm/node_modules/meant
      nopt@4.0.1 /opt/iobroker/node_modules/npm/node_modules/nopt
      npm-audit-report@1.3.2 /opt/iobroker/node_modules/npm/node_modules/npm-audit-report
      npm-cache-filename@1.0.2 /opt/iobroker/node_modules/npm/node_modules/npm-cache-filename
      npm-install-checks@3.0.0 /opt/iobroker/node_modules/npm/node_modules/npm-install-checks
      npm-user-validate@1.0.0 /opt/iobroker/node_modules/npm/node_modules/npm-user-validate
      opener@1.5.1 /opt/iobroker/node_modules/npm/node_modules/opener
      qrcode-terminal@0.12.0 /opt/iobroker/node_modules/npm/node_modules/qrcode-terminal
      query-string@6.4.0 /opt/iobroker/node_modules/npm/node_modules/query-string
      decode-uri-component@0.2.0 /opt/iobroker/node_modules/npm/node_modules/decode-uri-component
      strict-uri-encode@2.0.0 /opt/iobroker/node_modules/npm/node_modules/strict-uri-encode
      qw@1.0.1 /opt/iobroker/node_modules/npm/node_modules/qw
      read-installed@4.0.3 /opt/iobroker/node_modules/npm/node_modules/read-installed
      readdir-scoped-modules@1.0.2 /opt/iobroker/node_modules/npm/node_modules/readdir-scoped-modules
      util-extend@1.0.3 /opt/iobroker/node_modules/npm/node_modules/util-extend
      read-package-tree@5.2.2 /opt/iobroker/node_modules/npm/node_modules/read-package-tree
      readable-stream@3.2.0 /opt/iobroker/node_modules/npm/node_modules/readable-stream
      string_decoder@1.2.0 /opt/iobroker/node_modules/npm/node_modules/string_decoder
      retry@0.12.0 /opt/iobroker/node_modules/npm/node_modules/retry
      sha@3.0.0 /opt/iobroker/node_modules/npm/node_modules/sha
      sorted-object@2.0.1 /opt/iobroker/node_modules/npm/node_modules/sorted-object
      sorted-union-stream@2.1.3 /opt/iobroker/node_modules/npm/node_modules/sorted-union-stream
      from2@1.3.0 /opt/iobroker/node_modules/npm/node_modules/sorted-union-stream/node_modules/from2
      readable-stream@1.1.14 /opt/iobroker/node_modules/npm/node_modules/sorted-union-stream/node_modules/readable-stream
      isarray@0.0.1 /opt/iobroker/node_modules/npm/node_modules/sorted-union-stream/node_modules/isarray
      string_decoder@0.10.31 /opt/iobroker/node_modules/npm/node_modules
        ThorstenStr
        und der 3te:
        /sorted-union-stream/node_modules/string_decoder
        stream-iterate@1.2.0 /opt/iobroker/node_modules/npm/node_modules/stream-iterate
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/stream-iterate/node_modules/readable-stream
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/stream-iterate/node_modules/string_decoder
        text-table@0.2.0 /opt/iobroker/node_modules/npm/node_modules/text-table
        tiny-relative-date@1.3.0 /opt/iobroker/node_modules/npm/node_modules/tiny-relative-date
        unpipe@1.0.0 /opt/iobroker/node_modules/npm/node_modules/unpipe
        bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/npm/node_modules/bcrypt-pbkdf
        tweetnacl@0.14.5 /opt/iobroker/node_modules/npm/node_modules/tweetnacl
        colors@1.3.3 /opt/iobroker/node_modules/npm/node_modules/colors
        ecc-jsbn@0.1.2 /opt/iobroker/node_modules/npm/node_modules/ecc-jsbn
        jsbn@0.1.1 /opt/iobroker/node_modules/npm/node_modules/jsbn
        iobroker.web@2.4.1 /opt/iobroker/node_modules/iobroker.web
        body-parser@1.19.0 /opt/iobroker/node_modules/iobroker.web/node_modules/body-parser
        bytes@3.1.0 /opt/iobroker/node_modules/iobroker.web/node_modules/bytes
        content-type@1.0.4 /opt/iobroker/node_modules/iobroker.web/node_modules/content-type
        debug@2.6.9 /opt/iobroker/node_modules/iobroker.web/node_modules/debug
        ms@2.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/ms
        depd@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/depd
        http-errors@1.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/http-errors
        inherits@2.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/inherits
        setprototypeof@1.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/setprototypeof
        statuses@1.5.0 /opt/iobroker/node_modules/iobroker.web/node_modules/statuses
        toidentifier@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/toidentifier
        iconv-lite@0.4.24 /opt/iobroker/node_modules/iobroker.web/node_modules/iconv-lite
        safer-buffer@2.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/safer-buffer
        on-finished@2.3.0 /opt/iobroker/node_modules/iobroker.web/node_modules/on-finished
        ee-first@1.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/ee-first
        qs@6.7.0 /opt/iobroker/node_modules/iobroker.web/node_modules/qs
        raw-body@2.4.0 /opt/iobroker/node_modules/iobroker.web/node_modules/raw-body
        unpipe@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/unpipe
        type-is@1.6.18 /opt/iobroker/node_modules/iobroker.web/node_modules/type-is
        media-typer@0.3.0 /opt/iobroker/node_modules/iobroker.web/node_modules/media-typer
        mime-types@2.1.24 /opt/iobroker/node_modules/iobroker.web/node_modules/mime-types
        mime-db@1.40.0 /opt/iobroker/node_modules/iobroker.web/node_modules/mime-db
        connect-flash@0.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/connect-flash
        cookie-parser@1.4.4 /opt/iobroker/node_modules/iobroker.web/node_modules/cookie-parser
        cookie@0.3.1 /opt/iobroker/node_modules/iobroker.web/node_modules/cookie
        cookie-signature@1.0.6 /opt/iobroker/node_modules/iobroker.web/node_modules/cookie-signature
        express@4.17.1 /opt/iobroker/node_modules/iobroker.web/node_modules/express
        accepts@1.3.7 /opt/iobroker/node_modules/iobroker.web/node_modules/accepts
        negotiator@0.6.2 /opt/iobroker/node_modules/iobroker.web/node_modules/negotiator
        array-flatten@1.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/array-flatten
        content-disposition@0.5.3 /opt/iobroker/node_modules/iobroker.web/node_modules/content-disposition
        safe-buffer@5.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/safe-buffer
        cookie@0.4.0 /opt/iobroker/node_modules/iobroker.web/node_modules/express/node_modules/cookie
        encodeurl@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/encodeurl
        escape-html@1.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/escape-html
        etag@1.8.1 /opt/iobroker/node_modules/iobroker.web/node_modules/etag
        finalhandler@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/finalhandler
        parseurl@1.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/parseurl
        fresh@0.5.2 /opt/iobroker/node_modules/iobroker.web/node_modules/fresh
        merge-descriptors@1.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/merge-descriptors
        methods@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/methods
        path-to-regexp@0.1.7 /opt/iobroker/node_modules/iobroker.web/node_modules/path-to-regexp
        proxy-addr@2.0.5 /opt/iobroker/node_modules/iobroker.web/node_modules/proxy-addr
        forwarded@0.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/forwarded
        ipaddr.js@1.9.0 /opt/iobroker/node_modules/iobroker.web/node_modules/ipaddr.js
        range-parser@1.2.1 /opt/iobroker/node_modules/iobroker.web/node_modules/range-parser
        send@0.17.1 /opt/iobroker/node_modules/iobroker.web/node_modules/send
        destroy@1.0.4 /opt/iobroker/node_modules/iobroker.web/node_modules/destroy
        mime@1.6.0 /opt/iobroker/node_modules/iobroker.web/node_modules/mime
        ms@2.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/send/node_modules/ms
        serve-static@1.14.1 /opt/iobroker/node_modules/iobroker.web/node_modules/serve-static
        utils-merge@1.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/utils-merge
        vary@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/vary
        express-session@1.16.2 /opt/iobroker/node_modules/iobroker.web/node_modules/express-session
        depd@2.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/express-session/node_modules/depd
        on-headers@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/on-headers
        uid-safe@2.1.5 /opt/iobroker/node_modules/iobroker.web/node_modules/uid-safe
        random-bytes@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/random-bytes
        iobroker.simple-api@2.0.5 /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.simple-api
        @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/@iobroker/adapter-core
        @types/iobroker@1.4.11 /opt/iobroker/node_modules/iobroker.web/node_modules/@types/iobroker
        @types/node@12.0.10 /opt/iobroker/node_modules/iobroker.web/node_modules/@types/node
        iobroker.socketio@2.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio
        request@2.88.0 /opt/iobroker/node_modules/iobroker.web/node_modules/request
        aws-sign2@0.7.0 /opt/iobroker/node_modules/iobroker.web/node_modules/aws-sign2
        aws4@1.8.0 /opt/iobroker/node_modules/iobroker.web/node_modules/aws4
        caseless@0.12.0 /opt/iobroker/node_modules/iobroker.web/node_modules/caseless
        combined-stream@1.0.8 /opt/iobroker/node_modules/iobroker.web/node_modules/combined-stream
        delayed-stream@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/delayed-stream
        extend@3.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/extend
        forever-agent@0.6.1 /opt/iobroker/node_modules/iobroker.web/node_modules/forever-agent
        form-data@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/form-data
        asynckit@0.4.0 /opt/iobroker/node_modules/iobroker.web/node_modules/asynckit
        har-validator@5.1.3 /opt/iobroker/node_modules/iobroker.web/node_modules/har-validator
        ajv@6.10.0 /opt/iobroker/node_modules/iobroker.web/node_modules/ajv
        fast-deep-equal@2.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/fast-deep-equal
        fast-json-stable-stringify@2.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/fast-json-stable-stringify
        json-schema-traverse@0.4.1 /opt/iobroker/node_modules/iobroker.web/node_modules/json-schema-traverse
        uri-js@4.2.2 /opt/iobroker/node_modules/iobroker.web/node_modules/uri-js
        punycode@2.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/punycode
        har-schema@2.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/har-schema
        http-signature@1.2.0 /opt/iobroker/node_modules/iobroker.web/node_modules/http-signature
        assert-plus@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/assert-plus
        jsprim@1.4.1 /opt/iobroker/node_modules/iobroker.web/node_modules/jsprim
        extsprintf@1.3.0 /opt/iobroker/node_modules/iobroker.web/node_modules/extsprintf
        json-schema@0.2.3 /opt/iobroker/node_modules/iobroker.web/node_modules/json-schema
        verror@1.10.0 /opt/iobroker/node_modules/iobroker.web/node_modules/verror
        core-util-is@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/core-util-is
        sshpk@1.16.1 /opt/iobroker/node_modules/iobroker.web/node_modules/sshpk
        asn1@0.2.4 /opt/iobroker/node_modules/iobroker.web/node_modules/asn1
        bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/bcrypt-pbkdf
        tweetnacl@0.14.5 /opt/iobroker/node_modules/iobroker.web/node_modules/tweetnacl
        dashdash@1.14.1 /opt/iobroker/node_modules/iobroker.web/node_modules/dashdash
        ecc-jsbn@0.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/ecc-jsbn
        jsbn@0.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/jsbn
        getpass@0.1.7 /opt/iobroker/node_modules/iobroker.web/node_modules/getpass
        is-typedarray@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/is-typedarray
        isstream@0.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/isstream
        json-stringify-safe@5.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/json-stringify-safe
        oauth-sign@0.9.0 /opt/iobroker/node_modules/iobroker.web/node_modules/oauth-sign
        performance-now@2.1.0 /opt/iobroker/node_modules/iobroker.web/node_modules/performance-now
        qs@6.5.2 /opt/iobroker/node_modules/iobroker.web/node_modules/request/node_modules/qs
        tough-cookie@2.4.3 /opt/iobroker/node_modules/iobroker.web/node_modules/tough-cookie
        psl@1.1.33 /opt/iobroker/node_modules/iobroker.web/node_modules/psl
        punycode@1.4.1 /opt/iobroker/node_modules/iobroker.web/node_modules/tough-cookie/node_modules/punycode
        tunnel-agent@0.6.0 /opt/iobroker/node_modules/iobroker.web/node_modules/tunnel-agent
        uuid@3.3.2 /opt/iobroker/node_modules/iobroker.web/node_modules/uuid
        socket.io@1.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io
        debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io/node_modules/debug
        ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io/node_modules/ms
        engine.io@1.8.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io
        accepts@1.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io/node_modules/accepts
        negotiator@0.6.1 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io/node_modules/negotiator
        base64id@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/base64id
        debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io/node_modules/debug
        ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io/node_modules/ms
        engine.io-parser@1.3.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-parser
        after@0.8.2 /opt/iobroker/node_modules/iobroker.web/node_modules/after
        arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/iobroker.web/node_modules/arraybuffer.slice
        base64-arraybuffer@0.1.5 /opt/iobroker/node_modules/iobroker.web/node_modules/base64-arraybuffer
        blob@0.0.4 /opt/iobroker/node_modules/iobroker.web/node_modules/blob
        has-binary@0.1.7 /opt/iobroker/node_modules/iobroker.web/node_modules/has-binary
        isarray@0.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/isarray
        wtf-8@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/wtf-8
        ws@1.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/ws
        options@0.0.6 /opt/iobroker/node_modules/iobroker.web/node_modules/options
        ultron@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/ultron
        object-assign@4.1.0 /opt/iobroker/node_modules/iobroker.web/node_modules/object-assign
        socket.io-adapter@0.5.0 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-adapter
        debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-adapter/node_modules/debug
        ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-adapter/node_modules/ms
        socket.io-parser@2.3.1 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-parser
        component-emitter@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/component-emitter
        debug@2.2.0 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-parser/node_modules/debug
        ms@0.7.1 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-parser/node_modules/ms
        json3@3.3.2 /opt/iobroker/node_modules/iobroker.web/node_modules/json3
        socket.io-client@1.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-client
        backo2@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/backo2
        component-bind@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/component-bind
        component-emitter@1.2.1 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-client/node_modules/component-emitter
        debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-client/node_modules/debug
        ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-client/node_modules/ms
        engine.io-client@1.8.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-client
        component-emitter@1.2.1 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-client/node_modules/component-emitter
        component-inherit@0.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/component-inherit
        debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-client/node_modules/debug
        ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-client/node_modules/ms
        has-cors@1.1.0 /opt/iobroker/node_modules/iobroker.web/node_modules/has-cors
        indexof@0.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/indexof
        parsejson@0.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/parsejson
        better-assert@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/better-assert
        callsite@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/callsite
        parseqs@0.0.5 /opt/iobroker/node_modules/iobroker.web/node_modules/parseqs
        parseuri@0.0.5 /opt/iobroker/node_modules/iobroker.web/node_modules/parseuri
        xmlhttprequest-ssl@1.5.3 /opt/iobroker/node_modules/iobroker.web/node_modules/xmlhttprequest-ssl
        yeast@0.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/yeast
        object-component@0.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/object-component
        to-array@0.1.4 /opt/iobroker/node_modules/iobroker.web/node_modules/to-array
        passport@0.4.0 /opt/iobroker/node_modules/iobroker.web/node_modules/passport
        passport-strategy@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/passport-strategy
        pause@0.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/pause
        passport-local@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/passport-local
        passport.socketio@3.7.0 /opt/iobroker/node_modules/iobroker.web/node_modules/passport.socketio
        xtend@4.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/xtend
        copy-descriptor@0.1.1 /opt/iobroker/node_modules/copy-descriptor
        log-utils@0.2.1 /opt/iobroker/node_modules/log-utils
        ansi-colors@0.2.0 /opt/iobroker/node_modules/ansi-colors
        ansi-bgblack@0.1.1 /opt/iobroker/node_modules/ansi-bgblack
        ansi-wrap@0.1.0 /opt/iobroker/node_modules/ansi-wrap
        ansi-bgblue@0.1.1 /opt/iobroker/node_modules/ansi-bgblue
        ansi-bgcyan@0.1.1 /opt/iobroker/node_modules/ansi-bgcyan
        ansi-bggreen@0.1.1 /opt/iobroker/node_modules/ansi-bggreen
        ansi-bgmagenta@0.1.1 /opt/iobroker/node_modules/ansi-bgmagenta
        ansi-bgred@0.1.1 /opt/iobroker/node_modules/ansi-bgred
        ansi-bgwhite@0.1.1 /opt/iobroker/node_modules/ansi-bgwhite
        ansi-bgyellow@0.1.1 /opt/iobroker/node_modules/ansi-bgyellow
        ansi-black@0.1.1 /opt/iobroker/node_modules/ansi-black
        ansi-blue@0.1.1 /opt/iobroker/node_modules/ansi-blue
        ansi-bold@0.1.1 /opt/iobroker/node_modules/ansi-bold
        ansi-cyan@0.1.1 /opt/iobroker/node_modules/ansi-cyan
        ansi-dim@0.1.1 /opt/iobroker/node_modules/ansi-dim
        ansi-gray@0.1.1 /opt/iobroker/node_modules/ansi-gray
        ansi-green@0.1.1 /opt/iobroker/node_modules/ansi-green
        ansi-grey@0.1.1 /opt/iobroker/node_modules/ansi-grey
        ansi-hidden@0.1.1 /opt/iobroker/node_modules/ansi-hidden
        ansi-inverse@0.1.1 /opt/iobroker/node_modules/ansi-inverse
        ansi-italic@0.1.1 /opt/iobroker/node_modules/ansi-italic
        ansi-magenta@0.1.1 /opt/iobroker/node_modules/ansi-magenta
        ansi-red@0.1.1 /opt/iobroker/node_modules/ansi-red
        ansi-reset@0.1.1 /opt/iobroker/node_modules/ansi-reset
        ansi-strikethrough@0.1.1 /opt/iobroker/node_modules/ansi-strikethrough
        ansi-underline@0.1.1 /opt/iobroker/node_modules/ansi-underline
        ansi-white@0.1.1 /opt/iobroker/node_modules/ansi-white
        ansi-yellow@0.1.1 /opt/iobroker/node_modules/ansi-yellow
        lazy-cache@2.0.2 /opt/iobroker/node_modules/lazy-cache
        set-getter@0.1.0 /opt/iobroker/node_modules/set-getter
        to-object-path@0.3.0 /opt/iobroker/node_modules/to-object-path
        kind-of@3.2.2 /opt/iobroker/node_modules/kind-of
        is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
        error-symbol@0.1.0 /opt/iobroker/node_modules/error-symbol
        info-symbol@0.1.0 /opt/iobroker/node_modules/info-symbol
        log-ok@0.1.1 /opt/iobroker/node_modules/log-ok
        success-symbol@0.1.0 /opt/iobroker/node_modules/success-symbol
        time-stamp@1.1.0 /opt/iobroker/node_modules/time-stamp
        warning-symbol@0.1.0 /opt/iobroker/node_modules/warning-symbol
        @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/@iobroker/adapter-core
        @types/iobroker@1.4.11 /opt/iobroker/node_modules/@types/iobroker
        @types/node@12.0.10 /opt/iobroker/node_modules/@types/node
        @root/request@1.3.11 /opt/iobroker/node_modules/@root/request
        @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
        @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/@serialport/parser-cctalk
        @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/@serialport/parser-byte-length
        @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/@serialport/parser-readline
        @serialport/parser-delimiter@1.0.5 /opt/iobroker/node_modules/@serialport/parser-delimiter
        @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/@serialport/parser-ready
        @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/@serialport/parser-regex
        acme@1.3.0 /opt/iobroker/node_modules/acme
        acme-v2@1.8.2 /opt/iobroker/node_modules/acme-v2
        rsa-compat@2.0.8 /opt/iobroker/node_modules/rsa-compat
        keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
        eckles@1.4.1 /opt/iobroker/node_modules/eckles
        rasha@1.2.5 /opt/iobroker/node_modules/rasha
        aproba@1.2.0 /opt/iobroker/node_modules/aproba
        arr-flatten@1.1.0 /opt/iobroker/node_modules/arr-flatten
        async@2.6.2 /opt/iobroker/node_modules/async
        authenticate-pam@1.0.2 /opt/iobroker/node_modules/authenticate-pam
        aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/aws-iot-device-sdk
        crypto-js@3.1.6 /opt/iobroker/node_modules/crypto-js
        minimist@1.2.0 /opt/iobroker/node_modules/minimist
        mqtt@2.15.1 /opt/iobroker/node_modules/mqtt
        commist@1.1.0 /opt/iobroker/node_modules/commist
        leven@2.1.0 /opt/iobroker/node_modules/leven
        concat-stream@1.6.2 /opt/iobroker/node_modules/concat-stream
        buffer-from@1.1.1 /opt/iobroker/node_modules/buffer-from
        readable-stream@2.3.6 /opt/iobroker/node_modules/concat-stream/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/concat-stream/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/concat-stream/node_modules/string_decoder
        typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
        end-of-stream@1.4.1 /opt/iobroker/node_modules/end-of-stream
        help-me@1.1.0 /opt/iobroker/node_modules/help-me
        callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
        readable-stream@1.1.14 /opt/iobroker/node_modules/readable-stream
        string_decoder@0.10.31 /opt/iobroker/node_modules/string_decoder
        glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
        glob-parent@3.1.0 /opt/iobroker/node_modules/glob-parent
        is-glob@3.1.0 /opt/iobroker/node_modules/is-glob
        is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
        path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
        is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
        ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
        readable-stream@2.3.6 /opt/iobroker/node_modules/ordered-read-streams/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/ordered-read-streams/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/ordered-read-streams/node_modules/string_decoder
        pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
        duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
        readable-stream@2.3.6 /opt/iobroker/node_modules/duplexify/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/duplexify/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/duplexify/node_modules/string_decoder
        stream-shift@1.0.0 /opt/iobroker/node_modules/stream-shift
        pump@2.0.1 /opt/iobroker/node_modules/pump
        readable-stream@2.3.6 /opt/iobroker/node_modules/glob-stream/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/glob-stream/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/glob-stream/node_modules/string_decoder
        remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
        to-absolute-glob@2.0.2 /opt/iobroker/node_modules/to-absolute-glob
        is-absolute@1.0.0 /opt/iobroker/node_modules/is-absolute
        is-relative@1.0.0 /opt/iobroker/node_modules/is-relative
        is-unc-path@1.0.0 /opt/iobroker/node_modules/is-unc-path
        unc-path-regex@0.1.2 /opt/iobroker/node_modules/unc-path-regex
        is-windows@1.0.2 /opt/iobroker/node_modules/is-windows
        unique-stream@2.3.1 /opt/iobroker/node_modules/unique-stream
        json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify
        through2-filter@3.0.0 /opt/iobroker/node_modules/through2-filter
        through2@2.0.5 /opt/iobroker/node_modules/through2
        readable-stream@2.3.6 /opt/iobroker/node_modules/through2/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/through2/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/through2/node_modules/string_decoder
        mqtt-packet@5.6.1 /opt/iobroker/node_modules/mqtt-packet
        bl@1.2.2 /opt/iobroker/node_modules/bl
        readable-stream@2.3.6 /opt/iobroker/node_modules/bl/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/bl/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/bl/node_modules/string_decoder
        readable-stream@2.3.6 /opt/iobroker/node_modules/mqtt/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/mqtt/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/mqtt/node_modules/string_decoder
        reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
        split2@2.2.0 /opt/iobroker/node_modules/split2
        websocket-stream@5.5.0 /opt/iobroker/node_modules/websocket-stream
        readable-stream@2.3.6 /opt/iobroker/node_modules/websocket-stream/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/websocket-stream/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/websocket-stream/node_modules/string_decoder
        ws@3.3.3 /opt/iobroker/node_modules/websocket-stream/node_modules/ws
        ultron@1.1.1 /opt/iobroker/node_modules/websocket-stream/node_modules/ultron
        bindings@1.3.0 /opt/iobroker/node_modules/bindings
        buffer-alloc@1.2.0 /opt/iobroker/node_modules/buffer-alloc
        buffer-alloc-unsafe@1.1.0 /opt/iobroker/node_modules/buffer-alloc-unsafe
        buffer-fill@1.0.0 /opt/iobroker/node_modules/buffer-fill
        busboy@0.2.14 /opt/iobroker/node_modules/busboy
        dicer@0.2.5 /opt/iobroker/node_modules/dicer
        streamsearch@0.1.2 /opt/iobroker/node_modules/streamsearch
        charenc@0.0.2 /opt/iobroker/node_modules/charenc
        choices-separator@2.0.0 /opt/iobroker/node_modules/choices-separator
        strip-color@0.1.0 /opt/iobroker/node_modules/strip-color
        collection-visit@1.0.0 /opt/iobroker/node_modules/collection-visit
        map-visit@1.0.0 /opt/iobroker/node_modules/map-visit
        object-visit@1.0.1 /opt/iobroker/node_modules/object-visit
        isobject@3.0.1 /opt/iobroker/node_modules/isobject
        console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
        crypt@0.0.2 /opt/iobroker/node_modules/crypt
        decompress-response@3.3.0 /opt/iobroker/node_modules/decompress-response
        mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
        deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
        define-property@1.0.0 /opt/iobroker/node_modules/define-property
        is-descriptor@1.0.2 /opt/iobroker/node_modules/is-descriptor
        is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/is-accessor-descriptor
        kind-of@6.0.2 /opt/iobroker/node_modules/is-accessor-descriptor/node_modules/kind-of
        is-data-descriptor@1.0.0 /opt/iobroker/node_modules/is-data-descriptor
        kind-of@6.0.2 /opt/iobroker/node_modules/is-data-descriptor/node_modules/kind-of
        kind-of@6.0.2 /opt/iobroker/node_modules/is-descriptor/node_modules/kind-of
        delegates@1.0.0 /opt/iobroker/node_modules/delegates
        dgram@1.0.1 /opt/iobroker/node_modules/dgram
        diskusage@0.2.6 /opt/iobroker/node_modules/diskusage
        dns-packet@1.3.1 /opt/iobroker/node_modules/dns-packet
        ip@1.1.5 /opt/iobroker/node_modules/ip
        double-ended-queue@2.1.0-0 /opt/iobroker/node_modules/double-ended-queue
        expand-template@1.1.1 /opt/iobroker/node_modules/expand-template
        extend-shallow@2.0.1 /opt/iobroker/node_modules/extend-shallow
        is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
        for-in@1.0.2 /opt/iobroker/node_modules/for-in
        for-own@1.0.0 /opt/iobroker/node_modules/for-own
        fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
        gauge@2.7.4 /opt/iobroker/node_modules/gauge
        has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
        wide-align@1.1.3 /opt/iobroker/node_modules/wide-align
        github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
        glossy@0.1.7 /opt/iobroker/node_modules/glossy
        greenlock@2.7.1 /opt/iobroker/node_modules/greenlock
        cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
        le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
        le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
        le-store-certbot@2.2.3 /opt/iobroker/node_modules/le-store-certbot
        ini@1.3.5 /opt/iobroker/node_modules/ini
        iobroker.simple-api@2.0.5 /opt/iobroker/node_modules/iobroker.simple-api
        iobroker.socketio@2.1.1 /opt/iobroker/node_modules/iobroker.socketio
        iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.type-detector
        is-number@6.0.0 /opt/iobroker/node_modules/is-number
        is-plain-object@2.0.4 /opt/iobroker/node_modules/is-plain-object
        koalas@1.0.2 /opt/iobroker/node_modules/koalas
        md5@2.2.1 /opt/iobroker/node_modules/md5
        netmask@1.0.6 /opt/iobroker/node_modules/netmask
        node-abi@2.9.0 /opt/iobroker/node_modules/node-abi
        node-forge@0.7.6 /opt/iobroker/node_modules/node-forge
        noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
        npmlog@4.1.2 /opt/iobroker/node_modules/npmlog
        are-we-there-yet@1.1.5 /opt/iobroker/node_modules/are-we-there-yet
        readable-stream@2.3.6 /opt/iobroker/node_modules/are-we-there-yet/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/are-we-there-yet/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/are-we-there-yet/node_modules/string_decoder
        os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
        passport@0.4.0 /opt/iobroker/node_modules/passport
        passport.socketio@3.7.0 /opt/iobroker/node_modules/passport.socketio
        pointer-symbol@1.0.0 /opt/iobroker/node_modules/pointer-symbol
        prompt-actions@3.0.2 /opt/iobroker/node_modules/prompt-actions
        prompt-checkbox@2.2.0 /opt/iobroker/node_modules/prompt-checkbox
        prompt-base@4.1.0 /opt/iobroker/node_modules/prompt-base
        component-emitter@1.3.0 /opt/iobroker/node_modules/prompt-base/node_modules/component-emitter
        debug@3.2.6 /opt/iobroker/node_modules/prompt-base/node_modules/debug
        ms@2.1.2 /opt/iobroker/node_modules/prompt-base/node_modules/ms
        prompt-question@5.0.2 /opt/iobroker/node_modules/prompt-question
        clone-deep@1.0.0 /opt/iobroker/node_modules/clone-deep
        kind-of@5.1.0 /opt/iobroker/node_modules/clone-deep/node_modules/kind-of
        shallow-clone@1.0.0 /opt/iobroker/node_modules/shallow-clone
        kind-of@5.1.0 /opt/iobroker/node_modules/shallow-clone/node_modules/kind-of
        mixin-object@2.0.1 /opt/iobroker/node_modules/mixin-object
        for-in@0.1.8 /opt/iobroker/node_modules/mixin-object/node_modules/for-in
        debug@3.2.6 /opt/iobroker/node_modules/prompt-question/node_modules/debug
        ms@2.1.2 /opt/iobroker/node_modules/prompt-question/node_modules/ms
        kind-of@5.1.0 /opt/iobroker/node_modules/prompt-question/node_modules/kind-of
        prompt-choices@4.1.0 /opt/iobroker/node_modules/prompt-choices
        arr-swap@1.0.1 /opt/iobroker/node_modules/arr-swap
        is-number@3.0.0 /opt/iobroker/node_modules/arr-swap/node_modules/is-number
        clone-deep@4.0.1 /opt/iobroker/node_modules/prompt-choices/node_modules/clone-deep
        kind-of@6.0.2 /opt/iobroker/node_modules/prompt-choices/node_modules/kind-of
        shallow-clone@3.0.1 /opt/iobroker/node_modules/prompt-choices/node_modules/shallow-clone
        define-property@2.0.2 /opt/iobroker/node_modules/prompt-choices/node_modules/define-property
        radio-symbol@2.0.0 /opt/iobroker/node_modules/radio-symbol
        set-value@3.0.1 /opt/iobroker/node_modules/set-value
        terminal-paginator@2.0.2 /opt/iobroker/node_modules/terminal-paginator
        toggle-array@1.0.1 /opt/iobroker/node_modules/toggle-array
        readline-ui@2.2.3 /opt/iobroker/node_modules/readline-ui
        component-emitter@1.3.0 /opt/iobroker/node_modules/readline-ui/node_modules/component-emitter
        readline-utils@2.2.3 /opt/iobroker/node_modules/readline-utils
        is-number@3.0.0 /opt/iobroker/node_modules/readline-utils/node_modules/is-number
        window-size@1.1.1 /opt/iobroker/node_modules/window-size
        is-number@3.0.0 /opt/iobroker/node_modules/window-size/node_modules/is-number
        string-width@2.1.1 /opt/iobroker/node_modules/readline-ui/node_modules/string-width
        is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/is-fullwidth-code-point
        strip-ansi@4.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/strip-ansi
        ansi-regex@3.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/ansi-regex
        static-extend@0.1.2 /opt/iobroker/node_modules/static-extend
        define-property@0.2.5 /opt/iobroker/node_modules/static-extend/node_modules/define-property
        is-descriptor@0.1.6 /opt/iobroker/node_modules/static-extend/node_modules/is-descriptor
        is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/static-extend/node_modules/is-accessor-descriptor
        kind-of@3.2.2 /opt/iobroker/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
        is-data-descriptor@0.1.4 /opt/iobroker/node_modules/static-extend/node_modules/is-data-descriptor
        kind-of@3.2.2 /opt/iobroker/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
        kind-of@5.1.0 /opt/iobroker/node_modules/static-extend/node_modules/kind-of
        object-copy@0.1.0 /opt/iobroker/node_modules/object-copy
        define-property@0.2.5 /opt/iobroker/node_modules/object-copy/node_modules/define-property
        is-descriptor@0.1.6 /opt/iobroker/node_modules/object-copy/node_modules/is-descriptor
        is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/object-copy/node_modules/is-accessor-descriptor
        is-data-descriptor@0.1.4 /opt/iobroker/node_modules/object-copy/node_modules/is-data-descriptor
        kind-of@5.1.0 /opt/iobroker/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
        prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
        prompt-radio@1.2.1 /opt/iobroker/node_modules/prompt-radio
        redis@2.8.0 /opt/iobroker/node_modules/redis
        redis-commands@1.5.0 /opt/iobroker/node_modules/redis-commands
        redis-parser@2.6.0 /opt/iobroker/node_modules/redis-parser
        simple-concat@1.0.0 /opt/iobroker/node_modules/simple-concat
        simple-get@2.8.1 /opt/iobroker/node_modules/simple-get
        streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
        strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
        systeminformation@4.12.2 /opt/iobroker/node_modules/systeminformation
        suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
        to-buffer@1.1.1 /opt/iobroker/node_modules/to-buffer
        uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
        ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
        which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
        winston-syslog@1.2.6 /opt/iobroker/node_modules/winston-syslog
        detect-libc@1.0.3 /opt/iobroker/node_modules/detect-libc
        prebuild-install@4.0.0 /opt/iobroker/node_modules/prebuild-install
        rc@1.2.8 /opt/iobroker/node_modules/rc
        tar-fs@1.16.3 /opt/iobroker/node_modules/tar-fs
        pump@1.0.3 /opt/iobroker/node_modules/tar-fs/node_modules/pump
        tar-stream@1.6.2 /opt/iobroker/node_modules/tar-stream
        readable-stream@2.3.6 /opt/iobroker/node_modules/tar-stream/node_modules/readable-stream
        isarray@1.0.0 /opt/iobroker/node_modules/tar-stream/node_modules/isarray
        string_decoder@1.1.1 /opt/iobroker/node_modules/tar-stream/node_modules/string_decoder
        promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
        axios@0.18.1 /opt/iobroker/node_modules/axios
        follow-redirects@1.5.10 /opt/iobroker/node_modules/follow-redirects
        debug@3.1.0 /opt/iobroker/node_modules/follow-redirects/node_modules/debug
        is-buffer@2.0.3 /opt/iobroker/node_modules/axios/node_modules/is-buffer
        express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
        fs-extra@4.0.3 /opt/iobroker/node_modules/express-fileupload/node_modules/fs-extra
        mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
        debug@2.2.0 /opt/iobroker/node_modules/mdns-discovery/node_modules/debug
        ms@0.7.1 /opt/iobroker/node_modules/mdns-discovery/node_modules/ms
        node-ssdp@3.3.0 /opt/iobroker/node_modules/node-ssdp
        debug@3.2.6 /opt/iobroker/node_modules/node-ssdp/node_modules/debug
        ms@2.1.2 /opt/iobroker/node_modules/node-ssdp/node_modules/ms
        unix-dgram@0.2.3 /opt/iobroker/node_modules/unix-dgram
        bindings@1.1.1 /opt/iobroker/node_modules/unix-dgram/node_modules/bindings
        nan@2.3.5 /opt/iobroker/node_modules/unix-dgram/node_modules/nan
        le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
        rsa-compat@1.9.4 /opt/iobroker/node_modules/le-acme-core/node_modules/rsa-compat
        serialport@6.2.2 /opt/iobroker/node_modules/serialport
        debug@3.2.6 /opt/iobroker/node_modules/serialport/node_modules/debug
        ms@2.1.2 /opt/iobroker/node_modules/serialport/node_modules/ms
        root@iobroker:/opt/iobroker#
        • liv-in-skyL Offline
          liv-in-skyL Offline
          wenn fertig:
          mit root user im iobroker verzeichnis
          npm cache clear --force
          • liv-in-skyL liv-in-sky
            wenn fertig:
            ThorstenStr
            @liv-in-sky
            ok ist Durch.
            jetzt wieder Testen ?
            • T ThorstenStr
              @liv-in-sky
              ok ist Durch.
              liv-in-skyL Offline
              liv-in-skyL Offline
              @ThorstenStr am besten starte ganz neu - dann testen
                ThorstenStr
                @liv-in-sky
                sieht bis jetzt sehr gut aus, auch im log keinerlei Fehlermeldungen.
                An was war es gelegen ? oder auf wass sollte ich in Zukunft achten??
                ich werde es jetzt ausgiebig testen und morgen berichten.
                Bis dahin schon einmal vielen Dank für deine Hilfe 👍
                • T ThorstenStr
                  @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @ThorstenStr jetzt hoffen wir mal, dass das ganze auch noch in ein paar tagen funktioniert - sag morgen mal bescheid, ob alles ok ist
                  ansonsten scheint es , dass node und iobroker noch nicht richtig kompliert waren - npm rebuild braucht man eigentlich bei einen update von node z.b von 8.xx auf 10.xx - das ist ein muss ! genau sagen , warum da fehler waren, kann ich dir auch nicht
                  achte darauf das du die npm befehle mit root user machst - ansonsten solltest du diese nicht gebrauchen - es gibt ja den iobroker user (durch das fixer script) der alles intern regelt (über admin) - man sollte wohl so wenig wie möglich auf der terminal ebene arbeiten (2-3 ausnahmen)
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @liv-in-sky sagte in Endlosschleife bei Adapter Installation:
                    Ähhhhh. Eigentlich nicht!
                    ==> https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo
                    @ThorstenStr Nachdem du auch npm-Befehle mit sudo ausgeführt hast, solltest du unbedingt den Fixer laufen lassen. Warum du den direkt nach der Installation ausführst, ist mir schleierhaft - schließlich soll er die Rechte genau so wiederherstellen wie die Installation es tut.
                    • AlCalzoneA AlCalzone
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @AlCalzone
                      ich zweifle sicher nicht an, was du sagst - hätte eine frage dazu: warum funktioniert dann sudo npm rebuild bei ihm nicht ? deshalb haben wir/er mit dem root user gearbeitet
                      was muss @ThorstenStr jetzt noch machen, damit er für die zukunft richtig eingestellt ist - beim letzten kontakt lief ja alles - "klopfe auf holz"
                        @AlCalzone
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @liv-in-sky Je nachdem, wie die Berechtigungen auf dem System aussehen, kann es durchaus nötig sein, sudo zu verwenden. Das sollte aber wie im verlinkten Thread beschrieben nur eine Notlösung werden. Dein Satz klang recht pauschal nach "wenn du npm nutzt, nimm sudo".
                        Warum rebuild selbst als root nicht funktioniert, bin ich nicht sicher. Könnte am fehlenden --unsafe-perm Flag liegen.
                        Am besten 1x den Fixer laufen lassen und dann wo es geht auf root/sudo verzichten.
                          ThorstenStr
                          ich denke das mit dem Fixer habe ich falsch verstanden, daher habe ich ihn direkt nach der Installation ausgeführt.
                          Bisher läuft alles wie gehabt gut. ich werde jetzt noch einmal den Fixer ausführen und zukünftig wie in den HowTos angegeben verfahren.
                          Leider bin ich nicht so der Linux Guru, habe nur leichte Erfahrungen durch raspis gesammelt.
                          Aber dank euere Hilfe sollte jetzt alles laufen.
                          Vielen Dank
                          ich sezte den Thread auf gelöst, sollte noch etwas passieren, melde ich mich ;)
                          vielen vielen Dank
