  4. [gelöst]-Endlosschleife bei Adapter Installation
neue instanzadapter installation
44 Beiträge 5 Kommentatoren 5.2k Aufrufe 3 Beobachtet
  • liv-in-skyL liv-in-sky
    @ThorstenStr du hattest das fixer script angewendet ?
    liv-in-skyL Offline
    liv-in-skyL Offline
    @liv-in-sky iobroker ist auch gestoppt
      ThorstenStr
      @liv-in-sky Ja, ich habe es jetzt mal als root ausgeführt:
      odash@4.17.11 /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash
      bluebird@3.5.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird
      debug@3.2.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug
      ms@2.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms
      extend@3.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend
      serialport@6.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
      @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length
      @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk
      @serialport/parser-delimiter@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter
      @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline
      @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready
      @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex
      bindings@1.3.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings
      commander@2.20.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/commander
      debug@3.2.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug
      ms@2.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms
      nan@2.14.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan
      prebuild-install@4.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install
      detect-libc@1.0.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc
      expand-template@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template
      github-from-package@0.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package
      minimist@1.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist
      mkdirp@0.5.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp
      minimist@0.0.8 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp/node_modules/minimist
      node-abi@2.9.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi
      semver@5.7.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver
      noop-logger@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/noop-logger
      npmlog@4.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog
      are-we-there-yet@1.1.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet
      delegates@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates
      readable-stream@2.3.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream
      core-util-is@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is
      inherits@2.0.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits
      isarray@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray
      process-nextick-args@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args
      string_decoder@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder
      util-deprecate@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate
      console-control-strings@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings
      gauge@2.7.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge
      aproba@1.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba
      has-unicode@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode
      object-assign@4.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign
      signal-exit@3.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit
      string-width@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width
      code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at
      is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point
      number-is-nan@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan
      strip-ansi@3.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi
      ansi-regex@2.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex
      wide-align@1.1.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align
      set-blocking@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking
      os-homedir@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/os-homedir
      pump@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump
      end-of-stream@1.4.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream
      once@1.4.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/once
      wrappy@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy
      rc@1.2.8 /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc
      deep-extend@0.6.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend
      ini@1.3.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini
      strip-json-comments@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments
      simple-get@2.8.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get
      decompress-response@3.3.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response
      mimic-response@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response
      simple-concat@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat
      tar-fs@1.16.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs
      chownr@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr
      pump@1.0.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs/node_modules/pump
      tar-stream@1.6.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream
      bl@1.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl
      buffer-alloc@1.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer-alloc
      buffer-alloc-unsafe@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer-alloc-unsafe
      buffer-fill@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer-fill
      fs-constants@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants
      to-buffer@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/to-buffer
      xtend@4.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/xtend
      tunnel-agent@0.6.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent
      which-pm-runs@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/which-pm-runs
      promirepl@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/promirepl
      prompt-list@3.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-list
      ansi-cyan@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-cyan
      ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-wrap
      ansi-dim@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-dim
      prompt-radio@1.2.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-radio
      debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-radio/node_modules/debug
      ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-radio/node_modules/ms
      prompt-checkbox@2.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-checkbox
      debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-checkbox/node_modules/debug
      ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-checkbox/node_modules/ms
      prompt-base@4.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-base
      component-emitter@1.3.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/component-emitter
      debug@3.2.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-base/node_modules/debug
      ms@2.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-base/node_modules/ms
      koalas@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/koalas
      log-utils@0.2.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/log-utils
      ansi-colors@0.2.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-colors
      ansi-bgblack@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgblack
      ansi-bgblue@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgblue
      ansi-bgcyan@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgcyan
      ansi-bggreen@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bggreen
      ansi-bgmagenta@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgmagenta
      ansi-bgred@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgred
      ansi-bgwhite@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgwhite
      ansi-bgyellow@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bgyellow
      ansi-black@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-black
      ansi-blue@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-blue
      ansi-bold@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-bold
      ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-gray
      ansi-green@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-green
      ansi-grey@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-grey
      ansi-hidden@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-hidden
      ansi-inverse@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-inverse
      ansi-italic@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-italic
      ansi-magenta@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-magenta
      ansi-red@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-red
      ansi-reset@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-reset
      ansi-strikethrough@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-strikethrough
      ansi-underline@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-underline
      ansi-white@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-white
      ansi-yellow@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-yellow
      lazy-cache@2.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/lazy-cache
      set-getter@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-getter
      to-object-path@0.3.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/to-object-path
      kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/kind-of
      is-buffer@1.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-buffer
      error-symbol@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/error-symbol
      info-symbol@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/info-symbol
      log-ok@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/log-ok
      success-symbol@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/success-symbol
      time-stamp@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/time-stamp
      warning-symbol@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/warning-symbol
      prompt-actions@3.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-actions
      debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-actions/node_modules/debug
      ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-actions/node_modules/ms
      prompt-question@5.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question
      clone-deep@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/clone-deep
      for-own@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/for-own
      for-in@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/for-in
      is-plain-object@2.0.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-plain-object
      isobject@3.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/isobject
      kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/clone-deep/node_modules/kind-of
      shallow-clone@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/shallow-clone
      is-extendable@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-extendable
      kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/shallow-clone/node_modules/kind-of
      mixin-object@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mixin-object
      for-in@0.1.8 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mixin-object/node_modules/for-in
      debug@3.2.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/node_modules/debug
      ms@2.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/node_modules/ms
      define-property@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/define-property
      is-descriptor@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-descriptor
      is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-accessor-descriptor
      kind-of@6.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-accessor-descriptor/node_modules/kind-of
      is-data-descriptor@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-data-descriptor
      kind-of@6.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-data-descriptor/node_modules/kind-of
      kind-of@6.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-descriptor/node_modules/kind-of
      kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/node_modules/kind-of
      prompt-choices@4.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices
      arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/arr-flatten
      arr-swap@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/arr-swap
      is-number@3.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/arr-swap/node_modules/is-number
      choices-separator@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/choices-separator
      debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/choices-separator/node_modules/debug
      ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/choices-separator/node_modules/ms
      strip-color@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-color
      clone-deep@4.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/node_modules/clone-deep
      kind-of@6.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/node_modules/kind-of
      shallow-clone@3.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/node_modules/shallow-clone
      collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/collection-visit
      map-visit@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/map-visit
      object-visit@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-visit
      define-property@2.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/node_modules/define-property
      is-number@6.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-number
      pointer-symbol@1.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/pointer-symbol
      radio-symbol@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/radio-symbol
      is-windows@1.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-windows
      set-value@3.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-value
      terminal-paginator@2.0.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/terminal-paginator
      debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/terminal-paginator/node_modules/debug
      ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/terminal-paginator/node_modules/ms
      extend-shallow@2.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend-shallow
      toggle-array@1.0.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/toggle-array
      readline-ui@2.2.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui
      debug@2.6.9 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/debug
      ms@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/ms
      readline-utils@2.2.3 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-utils
      is-number@3.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-utils/node_modules/is-number
      mute-stream@0.0.7 /opt/iobroker/node_modules/iobroker.discovery/node_modules/mute-stream
      window-size@1.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/window-size
      is-number@3.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/window-size/node_modules/is-number
      string-width@2.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/string-width
      is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/is-fullwidth-code-point
      strip-ansi@4.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/strip-ansi
      ansi-regex@3.0.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/node_modules/ansi-regex
      static-extend@0.1.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend
      define-property@0.2.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/define-property
      is-descriptor@0.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-descriptor
      is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-accessor-descriptor
      kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
      is-data-descriptor@0.1.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-data-descriptor
      kind-of@3.2.2 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
      kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/node_modules/kind-of
      object-copy@0.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy
      copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.discovery/node_modules/copy-descriptor
      define-property@0.2.5 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/define-property
      is-descriptor@0.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/is-descriptor
      is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/is-accessor-descriptor
      is-data-descriptor@0.1.4 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/is-data-descriptor
      kind-of@5.1.0 /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
      iobroker.icons-fatcow-hosting@0.1.0 /opt/iobroker/node_modules/iobroker.icons-fatcow-hosting
      iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
      iobroker.info@1.3.7 /opt/iobroker/node_modules/iobroker.info
      @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/iobroker.info/node_modules/@iobroker/adapter-core
      @types/iobroker@1.4.11 /opt/iobroker/node_modules/iobroker.info/node_modules/@types/iobroker
      @types/node@12.0.10 /opt/iobroker/node_modules/iobroker.info/node_modules/@types/node
      axios@0.18.1 /opt/iobroker/node_modules/iobroker.info/node_modules/axios
      follow-redirects@1.5.10 /opt/iobroker/node_modules/iobroker.info/node_modules/follow-redirects
      debug@3.1.0 /opt/iobroker/node_modules/iobroker.info/node_modules/debug
      ms@2.0.0 /opt/iobroker/node_modules/iobroker.info/node_modules/ms
      is-buffer@2.0.3 /opt/iobroker/node_modules/iobroker.info/node_modules/is-buffer
      systeminformation@4.12.2 /opt/iobroker/node_modules/iobroker.info/node_modules/systeminformation
      iobroker.iot@0.4.3 /opt/iobroker/node_modules/iobroker.iot
      @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/@iobroker/adapter-core
      @types/iobroker@1.4.11 /opt/iobroker/node_modules/iobroker.iot/node_modules/@types/iobroker
      @types/node@12.0.10 /opt/iobroker/node_modules/iobroker.iot/node_modules/@types/iobroker/node_modules/@types/node
      aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/aws-iot-device-sdk
      crypto-js@3.1.6 /opt/iobroker/node_modules/iobroker.iot/node_modules/crypto-js
      minimist@1.2.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/minimist
      mqtt@2.15.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/mqtt
      commist@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/commist
      leven@2.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/leven
      concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/concat-stream
      buffer-from@1.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/buffer-from
      inherits@2.0.4 /opt/iobroker/node_modules/iobroker.iot/node_modules/inherits
      readable-stream@2.3.6 /opt/iobroker/node_modules/iobroker.iot/node_modules/readable-stream
      core-util-is@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/core-util-is
      isarray@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/isarray
      process-nextick-args@2.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/process-nextick-args
      safe-buffer@5.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/safe-buffer
      string_decoder@1.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/string_decoder
      util-deprecate@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/util-deprecate
      typedarray@0.0.6 /opt/iobroker/node_modules/iobroker.iot/node_modules/typedarray
      end-of-stream@1.4.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/end-of-stream
      once@1.4.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/once
      wrappy@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/wrappy
      help-me@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/help-me
      callback-stream@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/callback-stream
      glob-stream@6.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/glob-stream
      extend@3.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/extend
      glob@7.1.4 /opt/iobroker/node_modules/iobroker.iot/node_modules/glob
      fs.realpath@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/fs.realpath
      inflight@1.0.6 /opt/iobroker/node_modules/iobroker.iot/node_modules/inflight
      minimatch@3.0.4 /opt/iobroker/node_modules/iobroker.iot/node_modules/minimatch
      brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.iot/node_modules/brace-expansion
      balanced-match@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/balanced-match
      concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/concat-map
      path-is-absolute@1.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/path-is-absolute
      glob-parent@3.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/glob-parent
      is-glob@3.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-glob
      is-extglob@2.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-extglob
      path-dirname@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/path-dirname
      is-negated-glob@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-negated-glob
      ordered-read-streams@1.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/ordered-read-streams
      pumpify@1.5.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/pumpify
      duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/duplexify
      stream-shift@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/stream-shift
      pump@2.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/pump
      remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/remove-trailing-separator
      to-absolute-glob@2.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/to-absolute-glob
      is-absolute@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-absolute
      is-relative@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-relative
      is-unc-path@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-unc-path
      unc-path-regex@0.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/unc-path-regex
      is-windows@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-windows
      unique-stream@2.3.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/unique-stream
      json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/json-stable-stringify-without-jsonify
      through2-filter@3.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/through2-filter
      through2@2.0.5 /opt/iobroker/node_modules/iobroker.iot/node_modules/through2
      xtend@4.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/xtend
      mqtt-packet@5.6.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/mqtt-packet
      bl@1.2.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/bl
      reinterval@1.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/reinterval
      split2@2.2.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/split2
      websocket-stream@5.5.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/websocket-stream
      ws@3.3.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/ws
      async-limiter@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/async-limiter
      ultron@1.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/ultron
      iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/iobroker.type-detector
      request@2.88.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/request
      aws-sign2@0.7.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/aws-sign2
      aws4@1.8.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/aws4
      caseless@0.12.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/caseless
      combined-stream@1.0.8 /opt/iobroker/node_modules/iobroker.iot/node_modules/combined-stream
      delayed-stream@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/delayed-stream
      forever-agent@0.6.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/forever-agent
      form-data@2.3.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/form-data
      asynckit@0.4.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/asynckit
      mime-types@2.1.24 /opt/iobroker/node_modules/iobroker.iot/node_modules/mime-types
      mime-db@1.40.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/mime-db
      har-validator@5.1.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/har-validator
      ajv@6.10.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/ajv
      fast-deep-equal@2.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/fast-deep-equal
      fast-json-stable-stringify@2.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/fast-json-stable-stringify
      json-schema-traverse@0.4.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/json-schema-traverse
      uri-js@4.2.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/uri-js
      punycode@2.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/punycode
      har-schema@2.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/har-schema
      http-signature@1.2.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/http-signature
      assert-plus@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/assert-plus
      jsprim@1.4.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/jsprim
      extsprintf@1.3.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/extsprintf
      json-schema@0.2.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/json-schema
      verror@1.10.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/verror
      sshpk@1.16.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/sshpk
      asn1@0.2.4 /opt/iobroker/node_modules/iobroker.iot/node_modules/asn1
      safer-buffer@2.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/safer-buffer
      bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/bcrypt-pbkdf
      tweetnacl@0.14.5 /opt/iobroker/node_modules/iobroker.iot/node_modules/tweetnacl
      dashdash@1.14.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/dashdash
      ecc-jsbn@0.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/ecc-jsbn
      jsbn@0.1.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/jsbn
      getpass@0.1.7 /opt/iobroker/node_modules/iobroker.iot/node_modules/getpass
      is-typedarray@1.0.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/is-typedarray
      isstream@0.1.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/isstream
      json-stringify-safe@5.0.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/json-stringify-safe
      oauth-sign@0.9.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/oauth-sign
      performance-now@2.1.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/performance-now
      qs@6.5.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/qs
      tough-cookie@2.4.3 /opt/iobroker/node_modules/iobroker.iot/node_modules/tough-cookie
      psl@1.1.33 /opt/iobroker/node_modules/iobroker.iot/node_modules/psl
      punycode@1.4.1 /opt/iobroker/node_modules/iobroker.iot/node_modules/tough-cookie/node_modules/punycode
      tunnel-agent@0.6.0 /opt/iobroker/node_modules/iobroker.iot/node_modules/tunnel-agent
      uuid@3.3.2 /opt/iobroker/node_modules/iobroker.iot/node_modules/uuid
      iobroker.js-controller@1.5.11 /opt/iobroker/node_modules/iobroker.js-controller
      bluebird@3.5.5 /opt/iobroker/node_modules/bluebird
      daemonize2@0.4.2 /opt/iobroker/node_modules/daemonize2
      jsonwebtoken@8.5.1 /opt/iobroker/node_modules/jsonwebtoken
      jws@3.2.2 /opt/iobroker/node_modules/jws
      jwa@1.4.1 /opt/iobroker/node_modules/jwa
      buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
      ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
      lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
      lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
      lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
      lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
      lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
      lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
      lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
      ms@2.1.2 /opt/iobroker/node_modules/jsonwebtoken/node_modules/ms
      jszip@3.2.1 /opt/iobroker/node_modules/jszip
      lie@3.3.0 /opt/iobroker/node_modules/lie
      immediate@3.0.6 /opt/iobroker/node_modules/immediate
      pako@1.0.10 /opt/iobroker/node_modules/pako
      readable-stream@2.3.6 /opt/iobroker/node_modules/jszip/node_modules/readable-stream
      inherits@2.0.3 /opt/iobroker/node_modules/inherits
      isarray@1.0.0 /opt/iobroker/node_modules/jszip/node_modules/isarray
      process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
      string_decoder@1.1.1 /opt/iobroker/node_modules/jszip/node_modules/string_decoder
      util-deprecate@1.0.2 /opt/iobroker/node_modules/util-deprecate
      set-immediate-shim@1.0.1 /opt/iobroker/node_modules/set-immediate-shim
      loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
      weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
      mime@1.6.0 /opt/iobroker/node_modules/mime
      mkdirp@0.5.1 /opt/iobroker/node_modules/mkdirp
      minimist@0.0.8 /opt/iobroker/node_modules/mkdirp/node_modules/minimist
      ncp@2.0.0 /opt/iobroker/node_modules/ncp
      node-schedule@1.3.2 /opt/iobroker/node_modules/node-schedule
      cron-parser@2.12.0 /opt/iobroker/node_modules/cron-parser
      is-nan@1.2.1 /opt/iobroker/node_modules/is-nan
      define-properties@1.1.3 /opt/iobroker/node_modules/define-properties
      object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
      moment-timezone@0.5.25 /opt/iobroker/node_modules/moment-timezone
      moment@2.24.0 /opt/iobroker/node_modules/moment
      long-timeout@0.1.1 /opt/iobroker/node_modules/long-timeout
      sorted-array-functions@1.2.0 /opt/iobroker/node_modules/sorted-array-functions
      node.extend@2.0.2 /opt/iobroker/node_modules/node.extend
      has@1.0.3 /opt/iobroker/node_modules/has
      function-bind@1.1.1 /opt/iobroker/node_modules/function-bind
      is@3.3.0 /opt/iobroker/node_modules/is
      pidusage@2.0.17 /opt/iobroker/node_modules/pidusage
      prompt@1.0.0 /opt/iobroker/node_modules/prompt
      pkginfo@0.4.1 /opt/iobroker/node_modules/pkginfo
      read@1.0.7 /opt/iobroker/node_modules/read
      mute-stream@0.0.7 /opt/iobroker/node_modules/mute-stream
      revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
      utile@0.3.0 /opt/iobroker/node_modules/utile
      async@0.9.2 /opt/iobroker/node_modules/utile/node_modules/async
      deep-equal@0.2.2 /opt/iobroker/node_modules/deep-equal
      i@0.3.6 /opt/iobroker/node_modules/i
      ncp@1.0.1 /opt/iobroker/node_modules/utile/node_modules/ncp
      rimraf@2.6.3 /opt/iobroker/node_modules/rimraf
      glob@7.1.4 /opt/iobroker/node_modules/glob
      fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
      inflight@1.0.6 /opt/iobroker/node_modules/inflight
      once@1.4.0 /opt/iobroker/node_modules/once
      wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
      minimatch@3.0.4 /opt/iobroker/node_modules/minimatch
      brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
      balanced-match@1.0.0 /opt/iobroker/node_modules/balanced-match
      concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
      path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
      winston@2.1.1 /opt/iobroker/node_modules/prompt/node_modules/winston
      async@1.0.0 /opt/iobroker/node_modules/prompt/node_modules/async
      colors@1.0.3 /opt/iobroker/node_modules/prompt/node_modules/winston/node_modules/colors
      cycle@1.0.3 /opt/iobroker/node_modules/cycle
      eyes@0.1.8 /opt/iobroker/node_modules/eyes
      pkginfo@0.3.1 /opt/iobroker/node_modules/prompt/node_modules/winston/node_modules/pkginfo
      stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
      pyconf@1.1.7 /opt/iobroker/node_modules/pyconf
      safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
      socket.io@1.7.2 /opt/iobroker/node_modules/socket.io
      debug@2.3.3 /opt/iobroker/node_modules/socket.io/node_modules/debug
      ms@0.7.2 /opt/iobroker/node_modules/socket.io/node_modules/ms
      engine.io@1.8.2 /opt/iobroker/node_modules/engine.io
      accepts@1.3.3 /opt/iobroker/node_modules/engine.io/node_modules/accepts
      negotiator@0.6.1 /opt/iobroker/node_modules/engine.io/node_modules/negotiator
      debug@2.3.3 /opt/iobroker/node_modules/engine.io/node_modules/debug
      ms@0.7.2 /opt/iobroker/node_modules/engine.io/node_modules/ms
      engine.io-parser@1.3.2 /opt/iobroker/node_modules/engine.io-parser
      arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/arraybuffer.slice
      blob@0.0.4 /opt/iobroker/node_modules/blob
      has-binary@0.1.7 /opt/iobroker/node_modules/has-binary
      isarray@0.0.1 /opt/iobroker/node_modules/isarray
      wtf-8@1.0.0 /opt/iobroker/node_modules/wtf-8
      ws@1.1.1 /opt/iobroker/node_modules/ws
      options@0.0.6 /opt/iobroker/node_modules/options
      ultron@1.0.2 /opt/iobroker/node_modules/ultron
      object-assign@4.1.0 /opt/iobroker/node_modules/object-assign
      socket.io-adapter@0.5.0 /opt/iobroker/node_modules/socket.io-adapter
      debug@2.3.3 /opt/iobroker/node_modules/socket.io-adapter/node_modules/debug
      ms@0.7.2 /opt/iobroker/node_modules/socket.io-adapter/node_modules/ms
      socket.io-parser@2.3.1 /opt/iobroker/node_modules/socket.io-parser
      component-emitter@1.1.2 /opt/iobroker/node_modules/component-emitter
      debug@2.2.0 /opt/iobroker/node_modules/socket.io-parser/node_modules/debug
      ms@0.7.1 /opt/iobroker/node_modules/socket.io-parser/node_modules/ms
      json3@3.3.2 /opt/iobroker/node_modules/json3
      socket.io-client@1.7.2 /opt/iobroker/node_modules/socket.io-client
      component-emitter@1.2.1 /opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter
      debug@2.3.3 /opt/iobroker/node_modules/socket.io-client/node_modules/debug
      ms@0.7.2 /opt/iobroker/node_modules/socket.io-client/node_modules/ms
      engine.io-client@1.8.2 /opt/iobroker/node_modules/engine.io-client
      component-emitter@1.2.1 /opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter
      debug@2.3.3 /opt/iobroker/node_modules/engine.io-client/node_modules/debug
      ms@0.7.2 /opt/iobroker/node_modules/engine.io-client/node_modules/ms
      parsejson@0.0.3 /opt/iobroker/node_modules/parsejson
      xmlhttprequest-ssl@1.5.3 /opt/iobroker/node_modules/xmlhttprequest-ssl
      tar@4.4.10 /opt/iobroker/node_modules/tar
      chownr@1.1.1 /opt/iobroker/node_modules/chownr
      fs-minipass@1.2.6 /opt/iobroker/node_modules/fs-minipass
      minipass@2.3.5 /opt/iobroker/node_modules/minipass
      yallist@3.0.3 /opt/iobroker/node_modules/yallist
      minizlib@1.2.1 /opt/iobroker/node_modules/minizlib
      winston@2.4.4 /opt/iobroker/node_modules/winston
      async@1.0.0 /opt/iobroker/node_modules/winston/node_modules/async
      colors@1.0.3 /opt/iobroker/node_modules/winston/node_modules/colors
      winston-daily-rotate-file@1.7.2 /opt/iobroker/node_modules/winston-daily-rotate-file
      yargs@11.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs
      cliui@4.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/cliui
      string-width@2.1.1 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/string-width
      is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/is-fullwidth-code-point
      strip-ansi@4.0.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/strip-ansi
      ansi-regex@3.0.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/ansi-regex
      find-up@2.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/find-up
      locate-path@2.0.0 /opt/iobroker/node_modules/locate-path
      p-locate@2.0.0 /opt/iobroker/node_modules/p-locate
      p-limit@1.3.0 /opt/iobroker/node_modules/p-limit
      p-try@1.0.0 /opt/iobroker/node_modules/p-try
      path-exists@3.0.0 /opt/iobroker/node_modules/locate-path/node_modules/path-exists
      os-locale@2.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/os-locale
      execa@0.7.0 /opt/iobroker/node_modules/execa
      cross-spawn@5.1.0 /opt/iobroker/node_modules/cross-spawn
      lru-cache@4.1.5 /opt/iobroker/node_modules/lru-cache
      pseudomap@1.0.2 /opt/iobroker/node_modules/pseudomap
      yallist@2.1.2 /opt/iobroker/node_modules/lru-cache/node_modules/yallist
      shebang-command@1.2.0 /opt/iobroker/node_modules/shebang-command
      shebang-regex@1.0.0 /opt/iobroker/node_modules/shebang-regex
      which@1.3.1 /opt/iobroker/node_modules/which
      isexe@2.0.0 /opt/iobroker/node_modules/isexe
      get-stream@3.0.0 /opt/iobroker/node_modules/get-stream
      is-stream@1.1.0 /opt/iobroker/node_modules/is-stream
      npm-run-path@2.0.2 /opt/iobroker/node_modules/npm-run-path
      path-key@2.0.1 /opt/iobroker/node_modules/path-key
      p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
      signal-exit@3.0.2 /opt/iobroker/node_modules/signal-exit
      strip-eof@1.0.0 /opt/iobroker/node_modules/strip-eof
      mem@1.1.0 /opt/iobroker/node_modules/mem
      mimic-fn@1.2.0 /opt/iobroker/node_modules/mimic-fn
      which-module@2.0.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/which-module
      yargs-parser@9.0.2 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs-parser
      camelcase@4.1.0 /opt/iobroker/node_modules/iobroker.js-controller/node_modules/camelcase
      iobroker.scenes@1.1.0 /opt/iobroker/node_modules/iobroker.scenes
      node-schedule@1.3.2 /opt/iobroker/node_modules/iobroker.scenes/node_modules/node-schedule
      cron-parser@2.12.0 /opt/iobroker/node_modules/iobroker.scenes/node_modules/cron-parser
      is-nan@1.2.1 /opt/iobroker/node_modules/iobroker.scenes/node_modules/is-nan
      define-properties@1.1.3 /opt/iobroker/node_modules/iobroker.scenes/node_modules/define-properties
      object-keys@1.1.1 /opt/iobroker/node_modules/iobroker.scenes/node_modules/object-keys
      moment-timezone@0.5.25 /opt/iobroker/node_modules/iobroker.scenes/node_modules/moment-timezone
      moment@2.24.0 /opt/iobroker/node_modules/iobroker.scenes/node_modules/moment
      long-timeout@0.1.1 /opt/iobroker/node_modules/iobroker.scenes/node_modules/long-timeout
      sorted-array-functions@1.2.0 /opt/iobroker/node_modules/iobroker.scenes/node_modules/sorted-array-functions
      suncalc@1.8.0 /opt/iobroker/node_modules/iobroker.scenes/node_modules/suncalc
      iobroker.terminal@0.1.2 /opt/iobroker/node_modules/iobroker.terminal
      body-parser@1.19.0 /opt/iobroker/node_modules/body-parser
      bytes@3.1.0 /opt/iobroker/node_modules/bytes
      content-type@1.0.4 /opt/iobroker/node_modules/content-type
      debug@2.6.9 /opt/iobroker/node_modules/debug
      depd@1.1.2 /opt/iobroker/node_modules/depd
      http-errors@1.7.2 /opt/iobroker/node_modules/http-errors
      setprototypeof@1.1.1 /opt/iobroker/node_modules/setprototypeof
      statuses@1.5.0 /opt/iobroker/node_modules/statuses
      toidentifier@1.0.0 /opt/iobroker/node_modules/toidentifier
      iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
      on-finished@2.3.0 /opt/iobroker/node_modules/on-finished
      ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
      qs@6.7.0 /opt/iobroker/node_modules/qs
      raw-body@2.4.0 /opt/iobroker/node_modules/raw-body
      unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
      type-is@1.6.18 /opt/iobroker/node_modules/type-is
      media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
      commander@2.20.0 /opt/iobroker/node_modules/commander
      connect@3.7.0 /opt/iobroker/node_modules/connect
      finalhandler@1.1.2 /opt/iobroker/node_modules/finalhandler
      encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
      escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
      parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
      utils-merge@1.0.1 /opt/iobroker/node_modules/utils-merge
      connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
      express@4.17.1 /opt/iobroker/node_modules/express
      array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
      content-disposition@0.5.3 /opt/iobroker/node_modules/content-disposition
      cookie@0.4.0 /opt/iobroker/node_modules/express/node_modules/cookie
      etag@1.8.1 /opt/iobroker/node_modules/etag
      fresh@0.5.2 /opt/iobroker/node_modules/fresh
      merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
      methods@1.1.2 /opt/iobroker/node_modules/methods
      path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
      proxy-addr@2.0.5 /opt/iobroker/node_modules/proxy-addr
      forwarded@0.1.2 /opt/iobroker/node_modules/forwarded
      ipaddr.js@1.9.0 /opt/iobroker/node_modules/ipaddr.js
      range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
      send@0.17.1 /opt/iobroker/node_modules/send
      destroy@1.0.4 /opt/iobroker/node_modules/destroy
      ms@2.1.1 /opt/iobroker/node_modules/send/node_modules/ms
      serve-static@1.14.1 /opt/iobroker/node_modules/serve-static
      vary@1.1.2 /opt/iobroker/node_modules/vary
      express-session@1.16.2 /opt/iobroker/node_modules/express-session
      depd@2.0.0 /opt/iobroker/node_modules/express-session/node_modules/depd
      on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
      uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
      random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
      lodash@4.17.11 /opt/iobroker/node_modules/lodash
      nan@2.14.0 /opt/iobroker/node_modules/nan
      passport@0.2.2 /opt/iobroker/node_modules/iobroker.terminal/node_modules/passport
      passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
      pause@0.0.1 /opt/iobroker/node_modules/pause
      passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
      xtend@4.0.1 /opt/iobroker/node_modules/xtend
      iobroker.vis@1.1.10 /opt/iobroker/node_modules/iobroker.vis
      jsonwebtoken@8.5.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/jsonwebtoken
      jws@3.2.2 /opt/iobroker/node_modules/iobroker.vis/node_modules/jws
      jwa@1.4.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/jwa
      buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/buffer-equal-constant-time
      ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/iobroker.vis/node_modules/ecdsa-sig-formatter
      safe-buffer@5.1.2 /opt/iobroker/node_modules/iobroker.vis/node_modules/safe-buffer
      lodash.includes@4.3.0 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.includes
      lodash.isboolean@3.0.3 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isboolean
      lodash.isinteger@4.0.4 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isinteger
      lodash.isnumber@3.0.3 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isnumber
      lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isplainobject
      lodash.isstring@4.0.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.isstring
      lodash.once@4.1.1 /opt/iobroker/node_modules/iobroker.vis/node_modules/lodash.once
      ms@2.1.2 /opt/iobroker/node_modules/iobroker.vis/node_modules/ms
      semver@5.7.0 /opt/iobroker/node_modules/iobroker.vis/node_modules/semver
      iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
      iobroker.vis-google-fonts@0.1.0 /opt/iobroker/node_modules/iobroker.vis-google-fonts
      iobroker.vis-hqwidgets@1.1.2 /opt/iobroker/node_modules/iobroker.vis-hqwidgets
      iobroker.vis-map@1.0.2 /opt/iobroker/node_modules/iobroker.vis-map
      iobroker.vis-rgraph@0.0.2 /opt/iobroker/node_modules/iobroker.vis-rgraph
      iobroker.vis-weather@2.3.0 /opt/iobroker/node_modules/iobroker.vis-weather
      flot@2.3.2 /opt/iobroker/node_modules/flot
      file-exist@0.0.4 /opt/iobroker/node_modules/file-exist
      files-exist@1.1.0 /opt/iobroker/node_modules/files-exist
      defaults@1.0.3 /opt/iobroker/node_modules/defaults
      clone@1.0.4 /opt/iobroker/node_modules/clone
      glob@6.0.4 /opt/iobroker/node_modules/files-exist/node_modules/glob
      npm@6.9.2 /opt/iobroker/node_modules/npm
      JSONStream@1.3.5 /opt/iobroker/node_modules/npm/node_modules/JSONStream
      jsonparse@1.3.1 /opt/iobroker/node_modules/npm/node_modules/jsonparse
      through@2.3.8 /opt/iobroker/node_modules/npm/node_modules/through
      abbrev@1.1.1 /opt/iobroker/node_modules/npm/node_modules/abbrev
      ansicolors@0.3.2 /opt/iobroker/node_modules/npm/node_modules/ansicolors
      ansistyles@0.1.3 /opt/iobroker/node_modules/npm/node_modules/ansistyles
      aproba@2.0.0 /opt/iobroker/node_modules/npm/node_modules/aproba
      archy@1.0.0 /opt/iobroker/node_modules/npm/node_modules/archy
      bin-links@1.1.2 /opt/iobroker/node_modules/npm/node_modules/bin-links
      bluebird@3.5.3 /opt/iobroker/node_modules/npm/node_modules/bluebird
      cmd-shim@2.0.2 /opt/iobroker/node_modules/npm/node_modules/cmd-shim
      graceful-fs@4.1.15 /opt/iobroker/node_modules/npm/node_modules/graceful-fs
      mkdirp@0.5.1 /opt/iobroker/node_modules/npm/node_modules/mkdirp
      minimist@0.0.8 /opt/iobroker/node_modules/npm/node_modules/minimist
      gentle-fs@2.0.1 /opt/iobroker/node_modules/npm/node_modules/gentle-fs
      aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/gentle-fs/node_modules/aproba
      fs-vacuum@1.2.10 /opt/iobroker/node_modules/npm/node_modules/fs-vacuum
      path-is-inside@1.0.2 /opt/iobroker/node_modules/npm/node_modules/path-is-inside
      rimraf@2.6.3 /opt/iobroker/node_modules/npm/node_modules/rimraf
      glob@7.1.3 /opt/iobroker/node_modules/npm/node_modules/glob
      fs.realpath@1.0.0 /opt/iobroker/node_modules/npm/node_modules/fs.realpath
      inflight@1.0.6 /opt/iobroker/node_modules/npm/node_modules/inflight
      once@1.4.0 /opt/iobroker/node_modules/npm/node_modules/once
      wrappy@1.0.2 /opt/iobroker/node_modules/npm/node_modules/wrappy
      inherits@2.0.3 /opt/iobroker/node_modules/npm/node_modules/inherits
      minimatch@3.0.4 /opt/iobroker/node_modules/npm/node_modules/minimatch
      brace-expansion@1.1.11 /opt/iobroker/node_modules/npm/node_modules/brace-expansion
      balanced-match@1.0.0 /opt/iobroker/node_modules/npm/node_modules/balanced-match
      concat-map@0.0.1 /opt/iobroker/node_modules/npm/node_modules/concat-map
      path-is-absolute@1.0.1 /opt/iobroker/node_modules/npm/node_modules/path-is-absolute
      iferr@0.1.5 /opt/iobroker/node_modules/npm/node_modules/gentle-fs/node_modules/iferr
      read-cmd-shim@1.0.1 /opt/iobroker/node_modules/npm/node_modules/read-cmd-shim
      slide@1.1.6 /opt/iobroker/node_modules/npm/node_modules/slide
      write-file-atomic@2.4.2 /opt/iobroker/node_modules/npm/node_modules/write-file-atomic
      imurmurhash@0.1.4 /opt/iobroker/node_modules/npm/node_modules/imurmurhash
      signal-exit@3.0.2 /opt/iobroker/node_modules/npm/node_modules/signal-exit
      byte-size@5.0.1 /opt/iobroker/node_modules/npm/node_modules/byte-size
      cacache@11.3.2 /opt/iobroker/node_modules/npm/node_modules/cacache
      chownr@1.1.1 /opt/iobroker/node_modules/npm/node_modules/cacache/node_modules/chownr
      figgy-pudding@3.5.1 /opt/iobroker/node_modules/npm/node_modules/figgy-pudding
        ThorstenStr
        hier der 2te Teil
        lru-cache@5.1.1 /opt/iobroker/node_modules/npm/node_modules/cacache/node_modules/lru-cache
        yallist@3.0.3 /opt/iobroker/node_modules/npm/node_modules/cacache/node_modules/yallist
        mississippi@3.0.0 /opt/iobroker/node_modules/npm/node_modules/mississippi
        concat-stream@1.6.2 /opt/iobroker/node_modules/npm/node_modules/concat-stream
        buffer-from@1.0.0 /opt/iobroker/node_modules/npm/node_modules/buffer-from
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/concat-stream/node_modules/readable-stream
        core-util-is@1.0.2 /opt/iobroker/node_modules/npm/node_modules/core-util-is
        isarray@1.0.0 /opt/iobroker/node_modules/npm/node_modules/isarray
        process-nextick-args@2.0.0 /opt/iobroker/node_modules/npm/node_modules/process-nextick-args
        safe-buffer@5.1.2 /opt/iobroker/node_modules/npm/node_modules/safe-buffer
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/concat-stream/node_modules/string_decoder
        util-deprecate@1.0.2 /opt/iobroker/node_modules/npm/node_modules/util-deprecate
        typedarray@0.0.6 /opt/iobroker/node_modules/npm/node_modules/typedarray
        duplexify@3.6.0 /opt/iobroker/node_modules/npm/node_modules/duplexify
        end-of-stream@1.4.1 /opt/iobroker/node_modules/npm/node_modules/end-of-stream
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/duplexify/node_modules/readable-stream
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/duplexify/node_modules/string_decoder
        stream-shift@1.0.0 /opt/iobroker/node_modules/npm/node_modules/stream-shift
        flush-write-stream@1.0.3 /opt/iobroker/node_modules/npm/node_modules/flush-write-stream
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/flush-write-stream/node_modules/string_decoder
        from2@2.3.0 /opt/iobroker/node_modules/npm/node_modules/from2
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/from2/node_modules/readable-stream
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/from2/node_modules/string_decoder
        parallel-transform@1.1.0 /opt/iobroker/node_modules/npm/node_modules/parallel-transform
        cyclist@0.2.2 /opt/iobroker/node_modules/npm/node_modules/cyclist
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/parallel-transform/node_modules/readable-stream
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/parallel-transform/node_modules/string_decoder
        pump@3.0.0 /opt/iobroker/node_modules/npm/node_modules/pump
        pumpify@1.5.1 /opt/iobroker/node_modules/npm/node_modules/pumpify
        pump@2.0.1 /opt/iobroker/node_modules/npm/node_modules/pumpify/node_modules/pump
        stream-each@1.2.2 /opt/iobroker/node_modules/npm/node_modules/stream-each
        through2@2.0.3 /opt/iobroker/node_modules/npm/node_modules/through2
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/through2/node_modules/readable-stream
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/through2/node_modules/string_decoder
        xtend@4.0.1 /opt/iobroker/node_modules/npm/node_modules/xtend
        move-concurrently@1.0.1 /opt/iobroker/node_modules/npm/node_modules/move-concurrently
        aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/move-concurrently/node_modules/aproba
        copy-concurrently@1.0.5 /opt/iobroker/node_modules/npm/node_modules/copy-concurrently
        aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/copy-concurrently/node_modules/aproba
        fs-write-stream-atomic@1.0.10 /opt/iobroker/node_modules/npm/node_modules/fs-write-stream-atomic
        iferr@0.1.5 /opt/iobroker/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/iferr
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/readable-stream
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/string_decoder
        iferr@0.1.5 /opt/iobroker/node_modules/npm/node_modules/copy-concurrently/node_modules/iferr
        run-queue@1.0.3 /opt/iobroker/node_modules/npm/node_modules/run-queue
        aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/run-queue/node_modules/aproba
        promise-inflight@1.0.1 /opt/iobroker/node_modules/npm/node_modules/promise-inflight
        ssri@6.0.1 /opt/iobroker/node_modules/npm/node_modules/ssri
        unique-filename@1.1.1 /opt/iobroker/node_modules/npm/node_modules/cacache/node_modules/unique-filename
        unique-slug@2.0.0 /opt/iobroker/node_modules/npm/node_modules/unique-slug
        y18n@4.0.0 /opt/iobroker/node_modules/npm/node_modules/y18n
        call-limit@1.1.0 /opt/iobroker/node_modules/npm/node_modules/call-limit
        chownr@1.1.1 /opt/iobroker/node_modules/npm/node_modules/chownr
        ci-info@2.0.0 /opt/iobroker/node_modules/npm/node_modules/ci-info
        cli-columns@3.1.2 /opt/iobroker/node_modules/npm/node_modules/cli-columns
        string-width@2.1.1 /opt/iobroker/node_modules/npm/node_modules/string-width
        is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/npm/node_modules/string-width/node_modules/is-fullwidth-code-point
        strip-ansi@4.0.0 /opt/iobroker/node_modules/npm/node_modules/string-width/node_modules/strip-ansi
        ansi-regex@3.0.0 /opt/iobroker/node_modules/npm/node_modules/string-width/node_modules/ansi-regex
        strip-ansi@3.0.1 /opt/iobroker/node_modules/npm/node_modules/strip-ansi
        ansi-regex@2.1.1 /opt/iobroker/node_modules/npm/node_modules/ansi-regex
        cli-table3@0.5.1 /opt/iobroker/node_modules/npm/node_modules/cli-table3
        object-assign@4.1.1 /opt/iobroker/node_modules/npm/node_modules/object-assign
        columnify@1.5.4 /opt/iobroker/node_modules/npm/node_modules/columnify
        wcwidth@1.0.1 /opt/iobroker/node_modules/npm/node_modules/wcwidth
        defaults@1.0.3 /opt/iobroker/node_modules/npm/node_modules/defaults
        clone@1.0.4 /opt/iobroker/node_modules/npm/node_modules/clone
        config-chain@1.1.12 /opt/iobroker/node_modules/npm/node_modules/config-chain
        ini@1.3.5 /opt/iobroker/node_modules/npm/node_modules/ini
        proto-list@1.2.4 /opt/iobroker/node_modules/npm/node_modules/proto-list
        debuglog@1.0.1 /opt/iobroker/node_modules/npm/node_modules/debuglog
        detect-indent@5.0.0 /opt/iobroker/node_modules/npm/node_modules/detect-indent
        detect-newline@2.1.0 /opt/iobroker/node_modules/npm/node_modules/detect-newline
        dezalgo@1.0.3 /opt/iobroker/node_modules/npm/node_modules/dezalgo
        asap@2.0.6 /opt/iobroker/node_modules/npm/node_modules/asap
        editor@1.0.0 /opt/iobroker/node_modules/npm/node_modules/editor
        find-npm-prefix@1.0.2 /opt/iobroker/node_modules/npm/node_modules/find-npm-prefix
        has-unicode@2.0.1 /opt/iobroker/node_modules/npm/node_modules/has-unicode
        hosted-git-info@2.7.1 /opt/iobroker/node_modules/npm/node_modules/hosted-git-info
        iferr@1.0.2 /opt/iobroker/node_modules/npm/node_modules/iferr
        init-package-json@1.10.3 /opt/iobroker/node_modules/npm/node_modules/init-package-json
        npm-package-arg@6.1.0 /opt/iobroker/node_modules/npm/node_modules/npm-package-arg
        osenv@0.1.5 /opt/iobroker/node_modules/npm/node_modules/osenv
        os-homedir@1.0.2 /opt/iobroker/node_modules/npm/node_modules/os-homedir
        os-tmpdir@1.0.2 /opt/iobroker/node_modules/npm/node_modules/os-tmpdir
        semver@5.6.0 /opt/iobroker/node_modules/npm/node_modules/semver
        validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/npm/node_modules/validate-npm-package-name
        builtins@1.0.3 /opt/iobroker/node_modules/npm/node_modules/builtins
        promzard@0.3.0 /opt/iobroker/node_modules/npm/node_modules/promzard
        read@1.0.7 /opt/iobroker/node_modules/npm/node_modules/read
        mute-stream@0.0.7 /opt/iobroker/node_modules/npm/node_modules/mute-stream
        read-package-json@2.0.13 /opt/iobroker/node_modules/npm/node_modules/read-package-json
        json-parse-better-errors@1.0.2 /opt/iobroker/node_modules/npm/node_modules/json-parse-better-errors
        normalize-package-data@2.5.0 /opt/iobroker/node_modules/npm/node_modules/normalize-package-data
        resolve@1.10.0 /opt/iobroker/node_modules/npm/node_modules/normalize-package-data/node_modules/resolve
        path-parse@1.0.6 /opt/iobroker/node_modules/npm/node_modules/path-parse
        validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/npm/node_modules/validate-npm-package-license
        spdx-correct@3.0.0 /opt/iobroker/node_modules/npm/node_modules/spdx-correct
        spdx-expression-parse@3.0.0 /opt/iobroker/node_modules/npm/node_modules/spdx-expression-parse
        spdx-exceptions@2.1.0 /opt/iobroker/node_modules/npm/node_modules/spdx-exceptions
        spdx-license-ids@3.0.3 /opt/iobroker/node_modules/npm/node_modules/spdx-license-ids
        slash@1.0.0 /opt/iobroker/node_modules/npm/node_modules/slash
        is-cidr@3.0.0 /opt/iobroker/node_modules/npm/node_modules/is-cidr
        cidr-regex@2.0.10 /opt/iobroker/node_modules/npm/node_modules/cidr-regex
        ip-regex@2.1.0 /opt/iobroker/node_modules/npm/node_modules/ip-regex
        lazy-property@1.0.0 /opt/iobroker/node_modules/npm/node_modules/lazy-property
        libcipm@3.0.3 /opt/iobroker/node_modules/npm/node_modules/libcipm
        lock-verify@2.1.0 /opt/iobroker/node_modules/npm/node_modules/lock-verify
        npm-lifecycle@2.1.0 /opt/iobroker/node_modules/npm/node_modules/npm-lifecycle
        byline@5.0.0 /opt/iobroker/node_modules/npm/node_modules/byline
        node-gyp@3.8.0 /opt/iobroker/node_modules/npm/node_modules/node-gyp
        fstream@1.0.11 /opt/iobroker/node_modules/npm/node_modules/fstream
        nopt@3.0.6 /opt/iobroker/node_modules/npm/node_modules/node-gyp/node_modules/nopt
        npmlog@4.1.2 /opt/iobroker/node_modules/npm/node_modules/npmlog
        are-we-there-yet@1.1.4 /opt/iobroker/node_modules/npm/node_modules/are-we-there-yet
        delegates@1.0.0 /opt/iobroker/node_modules/npm/node_modules/delegates
        readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/are-we-there-yet/node_modules/readable-stream
        string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/are-we-there-yet/node_modules/string_decoder
        console-control-strings@1.1.0 /opt/iobroker/node_modules/npm/node_modules/console-control-strings
        gauge@2.7.4 /opt/iobroker/node_modules/npm/node_modules/gauge
        aproba@1.2.0 /opt/iobroker/node_modules/npm/node_modules/gauge/node_modules/aproba
        string-width@1.0.2 /opt/iobroker/node_modules/npm/node_modules/gauge/node_modules/string-width
        code-point-at@1.1.0 /opt/iobroker/node_modules/npm/node_modules/code-point-at
        is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/npm/node_modules/is-fullwidth-code-point
        number-is-nan@1.0.1 /opt/iobroker/node_modules/npm/node_modules/number-is-nan
        wide-align@1.1.2 /opt/iobroker/node_modules/npm/node_modules/wide-align
        string-width@1.0.2 /opt/iobroker/node_modules/npm/node_modules/wide-align/node_modules/string-width
        set-blocking@2.0.0 /opt/iobroker/node_modules/npm/node_modules/set-blocking
        request@2.88.0 /opt/iobroker/node_modules/npm/node_modules/request
        aws-sign2@0.7.0 /opt/iobroker/node_modules/npm/node_modules/aws-sign2
        aws4@1.8.0 /opt/iobroker/node_modules/npm/node_modules/aws4
        caseless@0.12.0 /opt/iobroker/node_modules/npm/node_modules/caseless
        combined-stream@1.0.6 /opt/iobroker/node_modules/npm/node_modules/combined-stream
        delayed-stream@1.0.0 /opt/iobroker/node_modules/npm/node_modules/delayed-stream
        extend@3.0.2 /opt/iobroker/node_modules/npm/node_modules/extend
        forever-agent@0.6.1 /opt/iobroker/node_modules/npm/node_modules/forever-agent
        form-data@2.3.2 /opt/iobroker/node_modules/npm/node_modules/form-data
        asynckit@0.4.0 /opt/iobroker/node_modules/npm/node_modules/asynckit
        mime-types@2.1.19 /opt/iobroker/node_modules/npm/node_modules/mime-types
        mime-db@1.35.0 /opt/iobroker/node_modules/npm/node_modules/mime-db
        har-validator@5.1.0 /opt/iobroker/node_modules/npm/node_modules/har-validator
        ajv@5.5.2 /opt/iobroker/node_modules/npm/node_modules/ajv
        co@4.6.0 /opt/iobroker/node_modules/npm/node_modules/co
        fast-deep-equal@1.1.0 /opt/iobroker/node_modules/npm/node_modules/fast-deep-equal
        fast-json-stable-stringify@2.0.0 /opt/iobroker/node_modules/npm/node_modules/fast-json-stable-stringify
        json-schema-traverse@0.3.1 /opt/iobroker/node_modules/npm/node_modules/json-schema-traverse
        har-schema@2.0.0 /opt/iobroker/node_modules/npm/node_modules/har-schema
        http-signature@1.2.0 /opt/iobroker/node_modules/npm/node_modules/http-signature
        assert-plus@1.0.0 /opt/iobroker/node_modules/npm/node_modules/assert-plus
        jsprim@1.4.1 /opt/iobroker/node_modules/npm/node_modules/jsprim
        extsprintf@1.3.0 /opt/iobroker/node_modules/npm/node_modules/extsprintf
        json-schema@0.2.3 /opt/iobroker/node_modules/npm/node_modules/json-schema
        verror@1.10.0 /opt/iobroker/node_modules/npm/node_modules/verror
        sshpk@1.14.2 /opt/iobroker/node_modules/npm/node_modules/sshpk
        asn1@0.2.4 /opt/iobroker/node_modules/npm/node_modules/asn1
        safer-buffer@2.1.2 /opt/iobroker/node_modules/npm/node_modules/safer-buffer
        dashdash@1.14.1 /opt/iobroker/node_modules/npm/node_modules/dashdash
        getpass@0.1.7 /opt/iobroker/node_modules/npm/node_modules/getpass
        is-typedarray@1.0.0 /opt/iobroker/node_modules/npm/node_modules/is-typedarray
        isstream@0.1.2 /opt/iobroker/node_modules/npm/node_modules/isstream
        json-stringify-safe@5.0.1 /opt/iobroker/node_modules/npm/node_modules/json-stringify-safe
        oauth-sign@0.9.0 /opt/iobroker/node_modules/npm/node_modules/oauth-sign
        performance-now@2.1.0 /opt/iobroker/node_modules/npm/node_modules/performance-now
        qs@6.5.2 /opt/iobroker/node_modules/npm/node_modules/qs
        tough-cookie@2.4.3 /opt/iobroker/node_modules/npm/node_modules/tough-cookie
        psl@1.1.29 /opt/iobroker/node_modules/npm/node_modules/psl
        punycode@1.4.1 /opt/iobroker/node_modules/npm/node_modules/punycode
        tunnel-agent@0.6.0 /opt/iobroker/node_modules/npm/node_modules/tunnel-agent
        uuid@3.3.2 /opt/iobroker/node_modules/npm/node_modules/uuid
        semver@5.3.0 /opt/iobroker/node_modules/npm/node_modules/node-gyp/node_modules/semver
        tar@2.2.1 /opt/iobroker/node_modules/npm/node_modules/node-gyp/node_modules/tar
        block-stream@0.0.9 /opt/iobroker/node_modules/npm/node_modules/block-stream
        which@1.3.1 /opt/iobroker/node_modules/npm/node_modules/which
        isexe@2.0.0 /opt/iobroker/node_modules/npm/node_modules/isexe
        resolve-from@4.0.0 /opt/iobroker/node_modules/npm/node_modules/resolve-from
        uid-number@0.0.6 /opt/iobroker/node_modules/npm/node_modules/uid-number
        umask@1.1.0 /opt/iobroker/node_modules/npm/node_modules/umask
        npm-logical-tree@1.2.1 /opt/iobroker/node_modules/npm/node_modules/npm-logical-tree
        pacote@9.5.0 /opt/iobroker/node_modules/npm/node_modules/pacote
        get-stream@4.1.0 /opt/iobroker/node_modules/npm/node_modules/get-stream
        lru-cache@5.1.1 /opt/iobroker/node_modules/npm/node_modules/pacote/node_modules/lru-cache
        yallist@3.0.3 /opt/iobroker/node_modules/npm/node_modules/pacote/node_modules/yallist
        make-fetch-happen@4.0.1 /opt/iobroker/node_modules/npm/node_modules/make-fetch-happen
        agentkeepalive@3.4.1 /opt/iobroker/node_modules/npm/node_modules/agentkeepalive
        humanize-ms@1.2.1 /opt/iobroker/node_modules/npm/node_modules/humanize-ms
        ms@2.1.1 /opt/iobroker/node_modules/npm/node_modules/ms
        http-cache-semantics@3.8.1 /opt/iobroker/node_modules/npm/node_modules/http-cache-semantics
        http-proxy-agent@2.1.0 /opt/iobroker/node_modules/npm/node_modules/http-proxy-agent
        agent-base@4.2.1 /opt/iobroker/node_modules/npm/node_modules/agent-base
        es6-promisify@5.0.0 /opt/iobroker/node_modules/npm/node_modules/es6-promisify
        es6-promise@4.2.6 /opt/iobroker/node_modules/npm/node_modules/es6-promise
        debug@3.1.0 /opt/iobroker/node_modules/npm/node_modules/debug
        ms@2.0.0 /opt/iobroker/node_modules/npm/node_modules/debug/node_modules/ms
        https-proxy-agent@2.2.1 /opt/iobroker/node_modules/npm/node_modules/https-proxy-agent
        lru-cache@4.1.5 /opt/iobroker/node_modules/npm/node_modules/lru-cache
        pseudomap@1.0.2 /opt/iobroker/node_modules/npm/node_modules/pseudomap
        yallist@2.1.2 /opt/iobroker/node_modules/npm/node_modules/yallist
        node-fetch-npm@2.0.2 /opt/iobroker/node_modules/npm/node_modules/node-fetch-npm
        encoding@0.1.12 /opt/iobroker/node_modules/npm/node_modules/encoding
        iconv-lite@0.4.23 /opt/iobroker/node_modules/npm/node_modules/iconv-lite
        promise-retry@1.1.1 /opt/iobroker/node_modules/npm/node_modules/promise-retry
        err-code@1.1.2 /opt/iobroker/node_modules/npm/node_modules/err-code
        retry@0.10.1 /opt/iobroker/node_modules/npm/node_modules/promise-retry/node_modules/retry
        socks-proxy-agent@4.0.1 /opt/iobroker/node_modules/npm/node_modules/socks-proxy-agent
        socks@2.2.0 /opt/iobroker/node_modules/npm/node_modules/socks
        ip@1.1.5 /opt/iobroker/node_modules/npm/node_modules/ip
        smart-buffer@4.0.1 /opt/iobroker/node_modules/npm/node_modules/smart-buffer
        minipass@2.3.5 /opt/iobroker/node_modules/npm/node_modules/pacote/node_modules/minipass
        npm-packlist@1.4.1 /opt/iobroker/node_modules/npm/node_modules/npm-packlist
        ignore-walk@3.0.1 /opt/iobroker/node_modules/npm/node_modules/ignore-walk
        npm-bundled@1.0.6 /opt/iobroker/node_modules/npm/node_modules/npm-bundled
        npm-pick-manifest@2.2.3 /opt/iobroker/node_modules/npm/node_modules/npm-pick-manifest
        npm-registry-fetch@3.9.0 /opt/iobroker/node_modules/npm/node_modules/npm-registry-fetch
        protoduck@5.0.1 /opt/iobroker/node_modules/npm/node_modules/protoduck
        genfun@5.0.0 /opt/iobroker/node_modules/npm/node_modules/genfun
        tar@4.4.8 /opt/iobroker/node_modules/npm/node_modules/tar
        chownr@1.1.1 /opt/iobroker/node_modules/npm/node_modules/tar/node_modules/chownr
        fs-minipass@1.2.5 /opt/iobroker/node_modules/npm/node_modules/fs-minipass
        minipass@2.3.3 /opt/iobroker/node_modules/npm/node_modules/minipass
        yallist@3.0.2 /opt/iobroker/node_modules/npm/node_modules/minipass/node_modules/yallist
        minipass@2.3.5 /opt/iobroker/node_modules/npm/node_modules/tar/node_modules/minipass
        yallist@3.0.3 /opt/iobroker/node_modules/npm/node_modules/tar/node_modules/yallist
        minizlib@1.1.1 /opt/iobroker/node_modules/npm/node_modules/minizlib
        unique-filename@1.1.1 /opt/iobroker/node_modules/npm/node_modules/unique-filename
        worker-farm@1.6.0 /opt/iobroker/node_modules/npm/node_modules/worker-farm
        errno@0.1.7 /opt/iobroker/node_modules/npm/node_modules/errno
        prr@1.0.1 /opt/iobroker/node_modules/npm/node_modules/prr
        libnpm@2.0.1 /opt/iobroker/node_modules/npm/node_modules/libnpm
        libnpmaccess@3.0.1 /opt/iobroker/node_modules/npm/node_modules/libnpmaccess
        aproba@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmaccess/node_modules/aproba
        libnpmconfig@1.2.1 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig
        find-up@3.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/find-up
        locate-path@3.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/locate-path
        p-locate@3.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/p-locate
        p-limit@2.1.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/p-limit
        p-try@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmconfig/node_modules/p-try
        path-exists@3.0.0 /opt/iobroker/node_modules/npm/node_modules/path-exists
        libnpmhook@5.0.2 /opt/iobroker/node_modules/npm/node_modules/libnpmhook
        libnpmorg@1.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmorg
        aproba@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmorg/node_modules/aproba
        libnpmpublish@1.1.1 /opt/iobroker/node_modules/npm/node_modules/libnpmpublish
        lodash.clonedeep@4.5.0 /opt/iobroker/node_modules/npm/node_modules/lodash.clonedeep
        libnpmsearch@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmsearch
        libnpmteam@1.0.1 /opt/iobroker/node_modules/npm/node_modules/libnpmteam
        aproba@2.0.0 /opt/iobroker/node_modules/npm/node_modules/libnpmteam/node_modules/aproba
        npm-profile@4.0.1 /opt/iobroker/node_modules/npm/node_modules/npm-profile
        stringify-package@1.0.0 /opt/iobroker/node_modules/npm/node_modules/stringify-package
        libnpx@10.2.0 /opt/iobroker/node_modules/npm/node_modules/libnpx
        dotenv@5.0.1 /opt/iobroker/node_modules/npm/node_modules/dotenv
        update-notifier@2.5.0 /opt/iobroker/node_modules/npm/node_modules/update-notifier
        boxen@1.3.0 /opt/iobroker/node_modules/npm/node_modules/boxen
        ansi-align@2.0.0 /opt/iobroker/node_modules/npm/node_modules/ansi-align
        camelcase@4.1.0 /opt/iobroker/node_modules/npm/node_modules/camelcase
        chalk@2.4.1 /opt/iobroker/node_modules/npm/node_modules/chalk
        ansi-styles@3.2.1 /opt/iobroker/node_modules/npm/node_modules/ansi-styles
        color-convert@1.9.1 /opt/iobroker/node_modules/npm/node_modules/color-convert
        color-name@1.1.3 /opt/iobroker/node_modules/npm/node_modules/color-name
        escape-string-regexp@1.0.5 /opt/iobroker/node_modules/npm/node_modules/escape-string-regexp
        supports-color@5.4.0 /opt/iobroker/node_modules/npm/node_modules/supports-color
        has-flag@3.0.0 /opt/iobroker/node_modules/npm/node_modules/has-flag
        cli-boxes@1.0.0 /opt/iobroker/node_modules/npm/node_modules/cli-boxes
        term-size@1.2.0 /opt/iobroker/node_modules/npm/node_modules/term-size
        execa@0.7.0 /opt/iobroker/node_modules/npm/node_modules/execa
        cross-spawn@5.1.0 /opt/iobroker/node_modules/npm/node_modules/cross-spawn
        shebang-command@1.2.0 /opt/iobroker/node_modules/npm/node_modules/shebang-command
        shebang-regex@1.0.0 /opt/iobroker/node_modules/npm/node_modules/shebang-regex
        get-stream@3.0.0 /opt/iobroker/node_modules/npm/node_modules/execa/node_modules/get-stream
        is-stream@1.1.0 /opt/iobroker/node_modules/npm/node_modules/is-stream
        npm-run-path@2.0.2 /opt/iobroker/node_modules/npm/node_modules/npm-run-path
        path-key@2.0.1 /opt/iobroker/node_modules/npm/node_modules/path-key
        p-finally@1.0.0 /opt/iobroker/node_modules/npm/node_modules/p-finally
        strip-eof@1.0.0 /opt/iobroker/node_modules/npm/node_modules/strip-eof
        widest-line@2.0.0 /opt/iobroker/node_modules/npm/node_modules/widest-line
        configstore@3.1.2 /opt/iobroker/node_modules/npm/node_modules/configstore
        dot-prop@4.2.0 /opt/iobroker/node_modules/npm/node_modules/dot-prop
        is-obj@1.0.1 /opt/iobroker/node_modules/npm/node_modules/is-obj
        make-dir@1.3.0 /opt/iobroker/node_modules/npm/node_modules/make-dir
        pify@3.0.0 /opt/iobroker/node_modules/npm/node_modules/pify
        unique-string@1.0.0 /opt/iobroker/node_modules/npm/node_modules/unique-string
        crypto-random-string@1.0.0 /opt/iobroker/node_modules/npm/node_modules/crypto-random-string
        xdg-basedir@3.0.0 /opt/iobroker/node_modules/npm/node_modules/xdg-basedir
        import-lazy@2.1.0 /opt/iobroker/node_modules/npm/node_modules/import-lazy
        is-ci@1.1.0 /opt/iobroker/node_modules/npm/node_modules/is-ci
        ci-info@1.6.0 /opt/iobroker/node_modules/npm/node_modules/is-ci/node_modules/ci-info
        is-installed-globally@0.1.0 /opt/iobroker/node_modules/npm/node_modules/is-installed-globally
        global-dirs@0.1.1 /opt/iobroker/node_modules/npm/node_modules/global-dirs
        is-path-inside@1.0.1 /opt/iobroker/node_modules/npm/node_modules/is-path-inside
        is-npm@1.0.0 /opt/iobroker/node_modules/npm/node_modules/is-npm
        latest-version@3.1.0 /opt/iobroker/node_modules/npm/node_modules/latest-version
        package-json@4.0.1 /opt/iobroker/node_modules/npm/node_modules/package-json
        got@6.7.1 /opt/iobroker/node_modules/npm/node_modules/got
        create-error-class@3.0.2 /opt/iobroker/node_modules/npm/node_modules/create-error-class
        capture-stack-trace@1.0.0 /opt/iobroker/node_modules/npm/node_modules/capture-stack-trace
        duplexer3@0.1.4 /opt/iobroker/node_modules/npm/node_modules/duplexer3
        get-stream@3.0.0 /opt/iobroker/node_modules/npm/node_modules/got/node_modules/get-stream
        is-redirect@1.0.0 /opt/iobroker/node_modules/npm/node_modules/is-redirect
        is-retry-allowed@1.1.0 /opt/iobroker/node_modules/npm/node_modules/is-retry-allowed
        lowercase-keys@1.0.1 /opt/iobroker/node_modules/npm/node_modules/lowercase-keys
        timed-out@4.0.1 /opt/iobroker/node_modules/npm/node_modules/timed-out
        unzip-response@2.0.1 /opt/iobroker/node_modules/npm/node_modules/unzip-response
        url-parse-lax@1.0.0 /opt/iobroker/node_modules/npm/node_modules/url-parse-lax
        prepend-http@1.0.4 /opt/iobroker/node_modules/npm/node_modules/prepend-http
        registry-auth-token@3.3.2 /opt/iobroker/node_modules/npm/node_modules/registry-auth-token
        rc@1.2.7 /opt/iobroker/node_modules/npm/node_modules/rc
        deep-extend@0.5.1 /opt/iobroker/node_modules/npm/node_modules/deep-extend
        minimist@1.2.0 /opt/iobroker/node_modules/npm/node_modules/rc/node_modules/minimist
        strip-json-comments@2.0.1 /opt/iobroker/node_modules/npm/node_modules/strip-json-comments
        registry-url@3.1.0 /opt/iobroker/node_modules/npm/node_modules/registry-url
        semver-diff@2.1.0 /opt/iobroker/node_modules/npm/node_modules/semver-diff
        yargs@11.0.0 /opt/iobroker/node_modules/npm/node_modules/yargs
        cliui@4.1.0 /opt/iobroker/node_modules/npm/node_modules/cliui
        strip-ansi@4.0.0 /opt/iobroker/node_modules/npm/node_modules/cliui/node_modules/strip-ansi
        ansi-regex@3.0.0 /opt/iobroker/node_modules/npm/node_modules/cliui/node_modules/ansi-regex
        wrap-ansi@2.1.0 /opt/iobroker/node_modules/npm/node_modules/wrap-ansi
        string-width@1.0.2 /opt/iobroker/node_modules/npm/node_modules/wrap-ansi/node_modules/string-width
        decamelize@1.2.0 /opt/iobroker/node_modules/npm/node_modules/decamelize
        find-up@2.1.0 /opt/iobroker/node_modules/npm/node_modules/find-up
        locate-path@2.0.0 /opt/iobroker/node_modules/npm/node_modules/locate-path
        p-locate@2.0.0 /opt/iobroker/node_modules/npm/node_modules/p-locate
        p-limit@1.2.0 /opt/iobroker/node_modules/npm/node_modules/p-limit
        p-try@1.0.0 /opt/iobroker/node_modules/npm/node_modules/p-try
        get-caller-file@1.0.2 /opt/iobroker/node_modules/npm/node_modules/get-caller-file
        os-locale@2.1.0 /opt/iobroker/node_modules/npm/node_modules/os-locale
        lcid@1.0.0 /opt/iobroker/node_modules/npm/node_modules/lcid
        invert-kv@1.0.0 /opt/iobroker/node_modules/npm/node_modules/invert-kv
        mem@1.1.0 /opt/iobroker/node_modules/npm/node_modules/mem
        mimic-fn@1.2.0 /opt/iobroker/node_modules/npm/node_modules/mimic-fn
        require-directory@2.1.1 /opt/iobroker/node_modules/npm/node_modules/require-directory
        require-main-filename@1.0.1 /opt/iobroker/node_modules/npm/node_modules/require-main-filename
        which-module@2.0.0 /opt/iobroker/node_modules/npm/node_modules/which-module
        y18n@3.2.1 /opt/iobroker/node_modules/npm/node_modules/yargs/node_modules/y18n
        yargs-parser@9.0.2 /opt/iobroker/node_modules/npm/node_modules/yargs-parser
        lockfile@1.0.4 /opt/iobroker/node_modules/npm/node_modules/lockfile
        lodash._baseindexof@3.1.0 /opt/iobroker/node_modules/npm/node_modules/lodash._baseindexof
        lodash._baseuniq@4.6.0 /opt/iobroker/node_modules/npm/node_modules/lodash._baseuniq
        lodash._createset@4.0.3 /opt/iobroker/node_modules/npm/node_modules/lodash._createset
        lodash._root@3.0.1 /opt/iobroker/node_modules/npm/node_modules/lodash._root
        lodash._bindcallback@3.0.1 /opt/iobroker/node_modules/npm/node_modules/lodash._bindcallback
        lodash._cacheindexof@3.0.2 /opt/iobroker/node_modules/npm/node_modules/lodash._cacheindexof
        lodash._createcache@3.1.2 /opt/iobroker/node_modules/npm/node_modules/lodash._createcache
        lodash._getnative@3.9.1 /opt/iobroker/node_modules/npm/node_modules/lodash._getnative
        lodash.restparam@3.6.1 /opt/iobroker/node_modules/npm/node_modules/lodash.restparam
        lodash.union@4.6.0 /opt/iobroker/node_modules/npm/node_modules/lodash.union
        lodash.uniq@4.5.0 /opt/iobroker/node_modules/npm/node_modules/lodash.uniq
        lodash.without@4.4.0 /opt/iobroker/node_modules/npm/node_modules/lodash.without
        meant@1.0.1 /opt/iobroker/node_modules/npm/node_modules/meant
        nopt@4.0.1 /opt/iobroker/node_modules/npm/node_modules/nopt
        npm-audit-report@1.3.2 /opt/iobroker/node_modules/npm/node_modules/npm-audit-report
        npm-cache-filename@1.0.2 /opt/iobroker/node_modules/npm/node_modules/npm-cache-filename
        npm-install-checks@3.0.0 /opt/iobroker/node_modules/npm/node_modules/npm-install-checks
        npm-user-validate@1.0.0 /opt/iobroker/node_modules/npm/node_modules/npm-user-validate
        opener@1.5.1 /opt/iobroker/node_modules/npm/node_modules/opener
        qrcode-terminal@0.12.0 /opt/iobroker/node_modules/npm/node_modules/qrcode-terminal
        query-string@6.4.0 /opt/iobroker/node_modules/npm/node_modules/query-string
        decode-uri-component@0.2.0 /opt/iobroker/node_modules/npm/node_modules/decode-uri-component
        strict-uri-encode@2.0.0 /opt/iobroker/node_modules/npm/node_modules/strict-uri-encode
        qw@1.0.1 /opt/iobroker/node_modules/npm/node_modules/qw
        read-installed@4.0.3 /opt/iobroker/node_modules/npm/node_modules/read-installed
        readdir-scoped-modules@1.0.2 /opt/iobroker/node_modules/npm/node_modules/readdir-scoped-modules
        util-extend@1.0.3 /opt/iobroker/node_modules/npm/node_modules/util-extend
        read-package-tree@5.2.2 /opt/iobroker/node_modules/npm/node_modules/read-package-tree
        readable-stream@3.2.0 /opt/iobroker/node_modules/npm/node_modules/readable-stream
        string_decoder@1.2.0 /opt/iobroker/node_modules/npm/node_modules/string_decoder
        retry@0.12.0 /opt/iobroker/node_modules/npm/node_modules/retry
        sha@3.0.0 /opt/iobroker/node_modules/npm/node_modules/sha
        sorted-object@2.0.1 /opt/iobroker/node_modules/npm/node_modules/sorted-object
        sorted-union-stream@2.1.3 /opt/iobroker/node_modules/npm/node_modules/sorted-union-stream
        from2@1.3.0 /opt/iobroker/node_modules/npm/node_modules/sorted-union-stream/node_modules/from2
        readable-stream@1.1.14 /opt/iobroker/node_modules/npm/node_modules/sorted-union-stream/node_modules/readable-stream
        isarray@0.0.1 /opt/iobroker/node_modules/npm/node_modules/sorted-union-stream/node_modules/isarray
        string_decoder@0.10.31 /opt/iobroker/node_modules/npm/node_modules
          ThorstenStr
          und der 3te:
          /sorted-union-stream/node_modules/string_decoder
          stream-iterate@1.2.0 /opt/iobroker/node_modules/npm/node_modules/stream-iterate
          readable-stream@2.3.6 /opt/iobroker/node_modules/npm/node_modules/stream-iterate/node_modules/readable-stream
          string_decoder@1.1.1 /opt/iobroker/node_modules/npm/node_modules/stream-iterate/node_modules/string_decoder
          text-table@0.2.0 /opt/iobroker/node_modules/npm/node_modules/text-table
          tiny-relative-date@1.3.0 /opt/iobroker/node_modules/npm/node_modules/tiny-relative-date
          unpipe@1.0.0 /opt/iobroker/node_modules/npm/node_modules/unpipe
          bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/npm/node_modules/bcrypt-pbkdf
          tweetnacl@0.14.5 /opt/iobroker/node_modules/npm/node_modules/tweetnacl
          colors@1.3.3 /opt/iobroker/node_modules/npm/node_modules/colors
          ecc-jsbn@0.1.2 /opt/iobroker/node_modules/npm/node_modules/ecc-jsbn
          jsbn@0.1.1 /opt/iobroker/node_modules/npm/node_modules/jsbn
          iobroker.web@2.4.1 /opt/iobroker/node_modules/iobroker.web
          body-parser@1.19.0 /opt/iobroker/node_modules/iobroker.web/node_modules/body-parser
          bytes@3.1.0 /opt/iobroker/node_modules/iobroker.web/node_modules/bytes
          content-type@1.0.4 /opt/iobroker/node_modules/iobroker.web/node_modules/content-type
          debug@2.6.9 /opt/iobroker/node_modules/iobroker.web/node_modules/debug
          ms@2.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/ms
          depd@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/depd
          http-errors@1.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/http-errors
          inherits@2.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/inherits
          setprototypeof@1.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/setprototypeof
          statuses@1.5.0 /opt/iobroker/node_modules/iobroker.web/node_modules/statuses
          toidentifier@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/toidentifier
          iconv-lite@0.4.24 /opt/iobroker/node_modules/iobroker.web/node_modules/iconv-lite
          safer-buffer@2.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/safer-buffer
          on-finished@2.3.0 /opt/iobroker/node_modules/iobroker.web/node_modules/on-finished
          ee-first@1.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/ee-first
          qs@6.7.0 /opt/iobroker/node_modules/iobroker.web/node_modules/qs
          raw-body@2.4.0 /opt/iobroker/node_modules/iobroker.web/node_modules/raw-body
          unpipe@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/unpipe
          type-is@1.6.18 /opt/iobroker/node_modules/iobroker.web/node_modules/type-is
          media-typer@0.3.0 /opt/iobroker/node_modules/iobroker.web/node_modules/media-typer
          mime-types@2.1.24 /opt/iobroker/node_modules/iobroker.web/node_modules/mime-types
          mime-db@1.40.0 /opt/iobroker/node_modules/iobroker.web/node_modules/mime-db
          connect-flash@0.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/connect-flash
          cookie-parser@1.4.4 /opt/iobroker/node_modules/iobroker.web/node_modules/cookie-parser
          cookie@0.3.1 /opt/iobroker/node_modules/iobroker.web/node_modules/cookie
          cookie-signature@1.0.6 /opt/iobroker/node_modules/iobroker.web/node_modules/cookie-signature
          express@4.17.1 /opt/iobroker/node_modules/iobroker.web/node_modules/express
          accepts@1.3.7 /opt/iobroker/node_modules/iobroker.web/node_modules/accepts
          negotiator@0.6.2 /opt/iobroker/node_modules/iobroker.web/node_modules/negotiator
          array-flatten@1.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/array-flatten
          content-disposition@0.5.3 /opt/iobroker/node_modules/iobroker.web/node_modules/content-disposition
          safe-buffer@5.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/safe-buffer
          cookie@0.4.0 /opt/iobroker/node_modules/iobroker.web/node_modules/express/node_modules/cookie
          encodeurl@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/encodeurl
          escape-html@1.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/escape-html
          etag@1.8.1 /opt/iobroker/node_modules/iobroker.web/node_modules/etag
          finalhandler@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/finalhandler
          parseurl@1.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/parseurl
          fresh@0.5.2 /opt/iobroker/node_modules/iobroker.web/node_modules/fresh
          merge-descriptors@1.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/merge-descriptors
          methods@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/methods
          path-to-regexp@0.1.7 /opt/iobroker/node_modules/iobroker.web/node_modules/path-to-regexp
          proxy-addr@2.0.5 /opt/iobroker/node_modules/iobroker.web/node_modules/proxy-addr
          forwarded@0.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/forwarded
          ipaddr.js@1.9.0 /opt/iobroker/node_modules/iobroker.web/node_modules/ipaddr.js
          range-parser@1.2.1 /opt/iobroker/node_modules/iobroker.web/node_modules/range-parser
          send@0.17.1 /opt/iobroker/node_modules/iobroker.web/node_modules/send
          destroy@1.0.4 /opt/iobroker/node_modules/iobroker.web/node_modules/destroy
          mime@1.6.0 /opt/iobroker/node_modules/iobroker.web/node_modules/mime
          ms@2.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/send/node_modules/ms
          serve-static@1.14.1 /opt/iobroker/node_modules/iobroker.web/node_modules/serve-static
          utils-merge@1.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/utils-merge
          vary@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/vary
          express-session@1.16.2 /opt/iobroker/node_modules/iobroker.web/node_modules/express-session
          depd@2.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/express-session/node_modules/depd
          on-headers@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/on-headers
          uid-safe@2.1.5 /opt/iobroker/node_modules/iobroker.web/node_modules/uid-safe
          random-bytes@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/random-bytes
          iobroker.simple-api@2.0.5 /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.simple-api
          @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/@iobroker/adapter-core
          @types/iobroker@1.4.11 /opt/iobroker/node_modules/iobroker.web/node_modules/@types/iobroker
          @types/node@12.0.10 /opt/iobroker/node_modules/iobroker.web/node_modules/@types/node
          iobroker.socketio@2.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio
          request@2.88.0 /opt/iobroker/node_modules/iobroker.web/node_modules/request
          aws-sign2@0.7.0 /opt/iobroker/node_modules/iobroker.web/node_modules/aws-sign2
          aws4@1.8.0 /opt/iobroker/node_modules/iobroker.web/node_modules/aws4
          caseless@0.12.0 /opt/iobroker/node_modules/iobroker.web/node_modules/caseless
          combined-stream@1.0.8 /opt/iobroker/node_modules/iobroker.web/node_modules/combined-stream
          delayed-stream@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/delayed-stream
          extend@3.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/extend
          forever-agent@0.6.1 /opt/iobroker/node_modules/iobroker.web/node_modules/forever-agent
          form-data@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/form-data
          asynckit@0.4.0 /opt/iobroker/node_modules/iobroker.web/node_modules/asynckit
          har-validator@5.1.3 /opt/iobroker/node_modules/iobroker.web/node_modules/har-validator
          ajv@6.10.0 /opt/iobroker/node_modules/iobroker.web/node_modules/ajv
          fast-deep-equal@2.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/fast-deep-equal
          fast-json-stable-stringify@2.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/fast-json-stable-stringify
          json-schema-traverse@0.4.1 /opt/iobroker/node_modules/iobroker.web/node_modules/json-schema-traverse
          uri-js@4.2.2 /opt/iobroker/node_modules/iobroker.web/node_modules/uri-js
          punycode@2.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/punycode
          har-schema@2.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/har-schema
          http-signature@1.2.0 /opt/iobroker/node_modules/iobroker.web/node_modules/http-signature
          assert-plus@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/assert-plus
          jsprim@1.4.1 /opt/iobroker/node_modules/iobroker.web/node_modules/jsprim
          extsprintf@1.3.0 /opt/iobroker/node_modules/iobroker.web/node_modules/extsprintf
          json-schema@0.2.3 /opt/iobroker/node_modules/iobroker.web/node_modules/json-schema
          verror@1.10.0 /opt/iobroker/node_modules/iobroker.web/node_modules/verror
          core-util-is@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/core-util-is
          sshpk@1.16.1 /opt/iobroker/node_modules/iobroker.web/node_modules/sshpk
          asn1@0.2.4 /opt/iobroker/node_modules/iobroker.web/node_modules/asn1
          bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/bcrypt-pbkdf
          tweetnacl@0.14.5 /opt/iobroker/node_modules/iobroker.web/node_modules/tweetnacl
          dashdash@1.14.1 /opt/iobroker/node_modules/iobroker.web/node_modules/dashdash
          ecc-jsbn@0.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/ecc-jsbn
          jsbn@0.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/jsbn
          getpass@0.1.7 /opt/iobroker/node_modules/iobroker.web/node_modules/getpass
          is-typedarray@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/is-typedarray
          isstream@0.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/isstream
          json-stringify-safe@5.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/json-stringify-safe
          oauth-sign@0.9.0 /opt/iobroker/node_modules/iobroker.web/node_modules/oauth-sign
          performance-now@2.1.0 /opt/iobroker/node_modules/iobroker.web/node_modules/performance-now
          qs@6.5.2 /opt/iobroker/node_modules/iobroker.web/node_modules/request/node_modules/qs
          tough-cookie@2.4.3 /opt/iobroker/node_modules/iobroker.web/node_modules/tough-cookie
          psl@1.1.33 /opt/iobroker/node_modules/iobroker.web/node_modules/psl
          punycode@1.4.1 /opt/iobroker/node_modules/iobroker.web/node_modules/tough-cookie/node_modules/punycode
          tunnel-agent@0.6.0 /opt/iobroker/node_modules/iobroker.web/node_modules/tunnel-agent
          uuid@3.3.2 /opt/iobroker/node_modules/iobroker.web/node_modules/uuid
          socket.io@1.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io
          debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io/node_modules/debug
          ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io/node_modules/ms
          engine.io@1.8.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io
          accepts@1.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io/node_modules/accepts
          negotiator@0.6.1 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io/node_modules/negotiator
          base64id@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/base64id
          debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io/node_modules/debug
          ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io/node_modules/ms
          engine.io-parser@1.3.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-parser
          after@0.8.2 /opt/iobroker/node_modules/iobroker.web/node_modules/after
          arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/iobroker.web/node_modules/arraybuffer.slice
          base64-arraybuffer@0.1.5 /opt/iobroker/node_modules/iobroker.web/node_modules/base64-arraybuffer
          blob@0.0.4 /opt/iobroker/node_modules/iobroker.web/node_modules/blob
          has-binary@0.1.7 /opt/iobroker/node_modules/iobroker.web/node_modules/has-binary
          isarray@0.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/isarray
          wtf-8@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/wtf-8
          ws@1.1.1 /opt/iobroker/node_modules/iobroker.web/node_modules/ws
          options@0.0.6 /opt/iobroker/node_modules/iobroker.web/node_modules/options
          ultron@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/ultron
          object-assign@4.1.0 /opt/iobroker/node_modules/iobroker.web/node_modules/object-assign
          socket.io-adapter@0.5.0 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-adapter
          debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-adapter/node_modules/debug
          ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-adapter/node_modules/ms
          socket.io-parser@2.3.1 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-parser
          component-emitter@1.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/component-emitter
          debug@2.2.0 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-parser/node_modules/debug
          ms@0.7.1 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-parser/node_modules/ms
          json3@3.3.2 /opt/iobroker/node_modules/iobroker.web/node_modules/json3
          socket.io-client@1.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-client
          backo2@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/backo2
          component-bind@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/component-bind
          component-emitter@1.2.1 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-client/node_modules/component-emitter
          debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-client/node_modules/debug
          ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io-client/node_modules/ms
          engine.io-client@1.8.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-client
          component-emitter@1.2.1 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-client/node_modules/component-emitter
          component-inherit@0.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/component-inherit
          debug@2.3.3 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-client/node_modules/debug
          ms@0.7.2 /opt/iobroker/node_modules/iobroker.web/node_modules/engine.io-client/node_modules/ms
          has-cors@1.1.0 /opt/iobroker/node_modules/iobroker.web/node_modules/has-cors
          indexof@0.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/indexof
          parsejson@0.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/parsejson
          better-assert@1.0.2 /opt/iobroker/node_modules/iobroker.web/node_modules/better-assert
          callsite@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/callsite
          parseqs@0.0.5 /opt/iobroker/node_modules/iobroker.web/node_modules/parseqs
          parseuri@0.0.5 /opt/iobroker/node_modules/iobroker.web/node_modules/parseuri
          xmlhttprequest-ssl@1.5.3 /opt/iobroker/node_modules/iobroker.web/node_modules/xmlhttprequest-ssl
          yeast@0.1.2 /opt/iobroker/node_modules/iobroker.web/node_modules/yeast
          object-component@0.0.3 /opt/iobroker/node_modules/iobroker.web/node_modules/object-component
          to-array@0.1.4 /opt/iobroker/node_modules/iobroker.web/node_modules/to-array
          passport@0.4.0 /opt/iobroker/node_modules/iobroker.web/node_modules/passport
          passport-strategy@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/passport-strategy
          pause@0.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/pause
          passport-local@1.0.0 /opt/iobroker/node_modules/iobroker.web/node_modules/passport-local
          passport.socketio@3.7.0 /opt/iobroker/node_modules/iobroker.web/node_modules/passport.socketio
          xtend@4.0.1 /opt/iobroker/node_modules/iobroker.web/node_modules/xtend
          copy-descriptor@0.1.1 /opt/iobroker/node_modules/copy-descriptor
          log-utils@0.2.1 /opt/iobroker/node_modules/log-utils
          ansi-colors@0.2.0 /opt/iobroker/node_modules/ansi-colors
          ansi-bgblack@0.1.1 /opt/iobroker/node_modules/ansi-bgblack
          ansi-wrap@0.1.0 /opt/iobroker/node_modules/ansi-wrap
          ansi-bgblue@0.1.1 /opt/iobroker/node_modules/ansi-bgblue
          ansi-bgcyan@0.1.1 /opt/iobroker/node_modules/ansi-bgcyan
          ansi-bggreen@0.1.1 /opt/iobroker/node_modules/ansi-bggreen
          ansi-bgmagenta@0.1.1 /opt/iobroker/node_modules/ansi-bgmagenta
          ansi-bgred@0.1.1 /opt/iobroker/node_modules/ansi-bgred
          ansi-bgwhite@0.1.1 /opt/iobroker/node_modules/ansi-bgwhite
          ansi-bgyellow@0.1.1 /opt/iobroker/node_modules/ansi-bgyellow
          ansi-black@0.1.1 /opt/iobroker/node_modules/ansi-black
          ansi-blue@0.1.1 /opt/iobroker/node_modules/ansi-blue
          ansi-bold@0.1.1 /opt/iobroker/node_modules/ansi-bold
          ansi-cyan@0.1.1 /opt/iobroker/node_modules/ansi-cyan
          ansi-dim@0.1.1 /opt/iobroker/node_modules/ansi-dim
          ansi-gray@0.1.1 /opt/iobroker/node_modules/ansi-gray
          ansi-green@0.1.1 /opt/iobroker/node_modules/ansi-green
          ansi-grey@0.1.1 /opt/iobroker/node_modules/ansi-grey
          ansi-hidden@0.1.1 /opt/iobroker/node_modules/ansi-hidden
          ansi-inverse@0.1.1 /opt/iobroker/node_modules/ansi-inverse
          ansi-italic@0.1.1 /opt/iobroker/node_modules/ansi-italic
          ansi-magenta@0.1.1 /opt/iobroker/node_modules/ansi-magenta
          ansi-red@0.1.1 /opt/iobroker/node_modules/ansi-red
          ansi-reset@0.1.1 /opt/iobroker/node_modules/ansi-reset
          ansi-strikethrough@0.1.1 /opt/iobroker/node_modules/ansi-strikethrough
          ansi-underline@0.1.1 /opt/iobroker/node_modules/ansi-underline
          ansi-white@0.1.1 /opt/iobroker/node_modules/ansi-white
          ansi-yellow@0.1.1 /opt/iobroker/node_modules/ansi-yellow
          lazy-cache@2.0.2 /opt/iobroker/node_modules/lazy-cache
          set-getter@0.1.0 /opt/iobroker/node_modules/set-getter
          to-object-path@0.3.0 /opt/iobroker/node_modules/to-object-path
          kind-of@3.2.2 /opt/iobroker/node_modules/kind-of
          is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
          error-symbol@0.1.0 /opt/iobroker/node_modules/error-symbol
          info-symbol@0.1.0 /opt/iobroker/node_modules/info-symbol
          log-ok@0.1.1 /opt/iobroker/node_modules/log-ok
          success-symbol@0.1.0 /opt/iobroker/node_modules/success-symbol
          time-stamp@1.1.0 /opt/iobroker/node_modules/time-stamp
          warning-symbol@0.1.0 /opt/iobroker/node_modules/warning-symbol
          @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/@iobroker/adapter-core
          @types/iobroker@1.4.11 /opt/iobroker/node_modules/@types/iobroker
          @types/node@12.0.10 /opt/iobroker/node_modules/@types/node
          @root/request@1.3.11 /opt/iobroker/node_modules/@root/request
          @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
          @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/@serialport/parser-cctalk
          @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/@serialport/parser-byte-length
          @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/@serialport/parser-readline
          @serialport/parser-delimiter@1.0.5 /opt/iobroker/node_modules/@serialport/parser-delimiter
          @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/@serialport/parser-ready
          @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/@serialport/parser-regex
          acme@1.3.0 /opt/iobroker/node_modules/acme
          acme-v2@1.8.2 /opt/iobroker/node_modules/acme-v2
          rsa-compat@2.0.8 /opt/iobroker/node_modules/rsa-compat
          keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
          eckles@1.4.1 /opt/iobroker/node_modules/eckles
          rasha@1.2.5 /opt/iobroker/node_modules/rasha
          aproba@1.2.0 /opt/iobroker/node_modules/aproba
          arr-flatten@1.1.0 /opt/iobroker/node_modules/arr-flatten
          async@2.6.2 /opt/iobroker/node_modules/async
          authenticate-pam@1.0.2 /opt/iobroker/node_modules/authenticate-pam
          aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/aws-iot-device-sdk
          crypto-js@3.1.6 /opt/iobroker/node_modules/crypto-js
          minimist@1.2.0 /opt/iobroker/node_modules/minimist
          mqtt@2.15.1 /opt/iobroker/node_modules/mqtt
          commist@1.1.0 /opt/iobroker/node_modules/commist
          leven@2.1.0 /opt/iobroker/node_modules/leven
          concat-stream@1.6.2 /opt/iobroker/node_modules/concat-stream
          buffer-from@1.1.1 /opt/iobroker/node_modules/buffer-from
          readable-stream@2.3.6 /opt/iobroker/node_modules/concat-stream/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/concat-stream/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/concat-stream/node_modules/string_decoder
          typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
          end-of-stream@1.4.1 /opt/iobroker/node_modules/end-of-stream
          help-me@1.1.0 /opt/iobroker/node_modules/help-me
          callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
          readable-stream@1.1.14 /opt/iobroker/node_modules/readable-stream
          string_decoder@0.10.31 /opt/iobroker/node_modules/string_decoder
          glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
          glob-parent@3.1.0 /opt/iobroker/node_modules/glob-parent
          is-glob@3.1.0 /opt/iobroker/node_modules/is-glob
          is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
          path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
          is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
          ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
          readable-stream@2.3.6 /opt/iobroker/node_modules/ordered-read-streams/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/ordered-read-streams/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/ordered-read-streams/node_modules/string_decoder
          pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
          duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
          readable-stream@2.3.6 /opt/iobroker/node_modules/duplexify/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/duplexify/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/duplexify/node_modules/string_decoder
          stream-shift@1.0.0 /opt/iobroker/node_modules/stream-shift
          pump@2.0.1 /opt/iobroker/node_modules/pump
          readable-stream@2.3.6 /opt/iobroker/node_modules/glob-stream/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/glob-stream/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/glob-stream/node_modules/string_decoder
          remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
          to-absolute-glob@2.0.2 /opt/iobroker/node_modules/to-absolute-glob
          is-absolute@1.0.0 /opt/iobroker/node_modules/is-absolute
          is-relative@1.0.0 /opt/iobroker/node_modules/is-relative
          is-unc-path@1.0.0 /opt/iobroker/node_modules/is-unc-path
          unc-path-regex@0.1.2 /opt/iobroker/node_modules/unc-path-regex
          is-windows@1.0.2 /opt/iobroker/node_modules/is-windows
          unique-stream@2.3.1 /opt/iobroker/node_modules/unique-stream
          json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify
          through2-filter@3.0.0 /opt/iobroker/node_modules/through2-filter
          through2@2.0.5 /opt/iobroker/node_modules/through2
          readable-stream@2.3.6 /opt/iobroker/node_modules/through2/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/through2/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/through2/node_modules/string_decoder
          mqtt-packet@5.6.1 /opt/iobroker/node_modules/mqtt-packet
          bl@1.2.2 /opt/iobroker/node_modules/bl
          readable-stream@2.3.6 /opt/iobroker/node_modules/bl/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/bl/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/bl/node_modules/string_decoder
          readable-stream@2.3.6 /opt/iobroker/node_modules/mqtt/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/mqtt/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/mqtt/node_modules/string_decoder
          reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
          split2@2.2.0 /opt/iobroker/node_modules/split2
          websocket-stream@5.5.0 /opt/iobroker/node_modules/websocket-stream
          readable-stream@2.3.6 /opt/iobroker/node_modules/websocket-stream/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/websocket-stream/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/websocket-stream/node_modules/string_decoder
          ws@3.3.3 /opt/iobroker/node_modules/websocket-stream/node_modules/ws
          ultron@1.1.1 /opt/iobroker/node_modules/websocket-stream/node_modules/ultron
          bindings@1.3.0 /opt/iobroker/node_modules/bindings
          buffer-alloc@1.2.0 /opt/iobroker/node_modules/buffer-alloc
          buffer-alloc-unsafe@1.1.0 /opt/iobroker/node_modules/buffer-alloc-unsafe
          buffer-fill@1.0.0 /opt/iobroker/node_modules/buffer-fill
          busboy@0.2.14 /opt/iobroker/node_modules/busboy
          dicer@0.2.5 /opt/iobroker/node_modules/dicer
          streamsearch@0.1.2 /opt/iobroker/node_modules/streamsearch
          charenc@0.0.2 /opt/iobroker/node_modules/charenc
          choices-separator@2.0.0 /opt/iobroker/node_modules/choices-separator
          strip-color@0.1.0 /opt/iobroker/node_modules/strip-color
          collection-visit@1.0.0 /opt/iobroker/node_modules/collection-visit
          map-visit@1.0.0 /opt/iobroker/node_modules/map-visit
          object-visit@1.0.1 /opt/iobroker/node_modules/object-visit
          isobject@3.0.1 /opt/iobroker/node_modules/isobject
          console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
          crypt@0.0.2 /opt/iobroker/node_modules/crypt
          decompress-response@3.3.0 /opt/iobroker/node_modules/decompress-response
          mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
          deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
          define-property@1.0.0 /opt/iobroker/node_modules/define-property
          is-descriptor@1.0.2 /opt/iobroker/node_modules/is-descriptor
          is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/is-accessor-descriptor
          kind-of@6.0.2 /opt/iobroker/node_modules/is-accessor-descriptor/node_modules/kind-of
          is-data-descriptor@1.0.0 /opt/iobroker/node_modules/is-data-descriptor
          kind-of@6.0.2 /opt/iobroker/node_modules/is-data-descriptor/node_modules/kind-of
          kind-of@6.0.2 /opt/iobroker/node_modules/is-descriptor/node_modules/kind-of
          delegates@1.0.0 /opt/iobroker/node_modules/delegates
          dgram@1.0.1 /opt/iobroker/node_modules/dgram
          diskusage@0.2.6 /opt/iobroker/node_modules/diskusage
          dns-packet@1.3.1 /opt/iobroker/node_modules/dns-packet
          ip@1.1.5 /opt/iobroker/node_modules/ip
          double-ended-queue@2.1.0-0 /opt/iobroker/node_modules/double-ended-queue
          expand-template@1.1.1 /opt/iobroker/node_modules/expand-template
          extend-shallow@2.0.1 /opt/iobroker/node_modules/extend-shallow
          is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
          for-in@1.0.2 /opt/iobroker/node_modules/for-in
          for-own@1.0.0 /opt/iobroker/node_modules/for-own
          fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
          gauge@2.7.4 /opt/iobroker/node_modules/gauge
          has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
          wide-align@1.1.3 /opt/iobroker/node_modules/wide-align
          github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
          glossy@0.1.7 /opt/iobroker/node_modules/glossy
          greenlock@2.7.1 /opt/iobroker/node_modules/greenlock
          cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
          le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
          le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
          le-store-certbot@2.2.3 /opt/iobroker/node_modules/le-store-certbot
          ini@1.3.5 /opt/iobroker/node_modules/ini
          iobroker.simple-api@2.0.5 /opt/iobroker/node_modules/iobroker.simple-api
          iobroker.socketio@2.1.1 /opt/iobroker/node_modules/iobroker.socketio
          iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.type-detector
          is-number@6.0.0 /opt/iobroker/node_modules/is-number
          is-plain-object@2.0.4 /opt/iobroker/node_modules/is-plain-object
          koalas@1.0.2 /opt/iobroker/node_modules/koalas
          md5@2.2.1 /opt/iobroker/node_modules/md5
          netmask@1.0.6 /opt/iobroker/node_modules/netmask
          node-abi@2.9.0 /opt/iobroker/node_modules/node-abi
          node-forge@0.7.6 /opt/iobroker/node_modules/node-forge
          noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
          npmlog@4.1.2 /opt/iobroker/node_modules/npmlog
          are-we-there-yet@1.1.5 /opt/iobroker/node_modules/are-we-there-yet
          readable-stream@2.3.6 /opt/iobroker/node_modules/are-we-there-yet/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/are-we-there-yet/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/are-we-there-yet/node_modules/string_decoder
          os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
          passport@0.4.0 /opt/iobroker/node_modules/passport
          passport.socketio@3.7.0 /opt/iobroker/node_modules/passport.socketio
          pointer-symbol@1.0.0 /opt/iobroker/node_modules/pointer-symbol
          prompt-actions@3.0.2 /opt/iobroker/node_modules/prompt-actions
          prompt-checkbox@2.2.0 /opt/iobroker/node_modules/prompt-checkbox
          prompt-base@4.1.0 /opt/iobroker/node_modules/prompt-base
          component-emitter@1.3.0 /opt/iobroker/node_modules/prompt-base/node_modules/component-emitter
          debug@3.2.6 /opt/iobroker/node_modules/prompt-base/node_modules/debug
          ms@2.1.2 /opt/iobroker/node_modules/prompt-base/node_modules/ms
          prompt-question@5.0.2 /opt/iobroker/node_modules/prompt-question
          clone-deep@1.0.0 /opt/iobroker/node_modules/clone-deep
          kind-of@5.1.0 /opt/iobroker/node_modules/clone-deep/node_modules/kind-of
          shallow-clone@1.0.0 /opt/iobroker/node_modules/shallow-clone
          kind-of@5.1.0 /opt/iobroker/node_modules/shallow-clone/node_modules/kind-of
          mixin-object@2.0.1 /opt/iobroker/node_modules/mixin-object
          for-in@0.1.8 /opt/iobroker/node_modules/mixin-object/node_modules/for-in
          debug@3.2.6 /opt/iobroker/node_modules/prompt-question/node_modules/debug
          ms@2.1.2 /opt/iobroker/node_modules/prompt-question/node_modules/ms
          kind-of@5.1.0 /opt/iobroker/node_modules/prompt-question/node_modules/kind-of
          prompt-choices@4.1.0 /opt/iobroker/node_modules/prompt-choices
          arr-swap@1.0.1 /opt/iobroker/node_modules/arr-swap
          is-number@3.0.0 /opt/iobroker/node_modules/arr-swap/node_modules/is-number
          clone-deep@4.0.1 /opt/iobroker/node_modules/prompt-choices/node_modules/clone-deep
          kind-of@6.0.2 /opt/iobroker/node_modules/prompt-choices/node_modules/kind-of
          shallow-clone@3.0.1 /opt/iobroker/node_modules/prompt-choices/node_modules/shallow-clone
          define-property@2.0.2 /opt/iobroker/node_modules/prompt-choices/node_modules/define-property
          radio-symbol@2.0.0 /opt/iobroker/node_modules/radio-symbol
          set-value@3.0.1 /opt/iobroker/node_modules/set-value
          terminal-paginator@2.0.2 /opt/iobroker/node_modules/terminal-paginator
          toggle-array@1.0.1 /opt/iobroker/node_modules/toggle-array
          readline-ui@2.2.3 /opt/iobroker/node_modules/readline-ui
          component-emitter@1.3.0 /opt/iobroker/node_modules/readline-ui/node_modules/component-emitter
          readline-utils@2.2.3 /opt/iobroker/node_modules/readline-utils
          is-number@3.0.0 /opt/iobroker/node_modules/readline-utils/node_modules/is-number
          window-size@1.1.1 /opt/iobroker/node_modules/window-size
          is-number@3.0.0 /opt/iobroker/node_modules/window-size/node_modules/is-number
          string-width@2.1.1 /opt/iobroker/node_modules/readline-ui/node_modules/string-width
          is-fullwidth-code-point@2.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/is-fullwidth-code-point
          strip-ansi@4.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/strip-ansi
          ansi-regex@3.0.0 /opt/iobroker/node_modules/readline-ui/node_modules/ansi-regex
          static-extend@0.1.2 /opt/iobroker/node_modules/static-extend
          define-property@0.2.5 /opt/iobroker/node_modules/static-extend/node_modules/define-property
          is-descriptor@0.1.6 /opt/iobroker/node_modules/static-extend/node_modules/is-descriptor
          is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/static-extend/node_modules/is-accessor-descriptor
          kind-of@3.2.2 /opt/iobroker/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
          is-data-descriptor@0.1.4 /opt/iobroker/node_modules/static-extend/node_modules/is-data-descriptor
          kind-of@3.2.2 /opt/iobroker/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
          kind-of@5.1.0 /opt/iobroker/node_modules/static-extend/node_modules/kind-of
          object-copy@0.1.0 /opt/iobroker/node_modules/object-copy
          define-property@0.2.5 /opt/iobroker/node_modules/object-copy/node_modules/define-property
          is-descriptor@0.1.6 /opt/iobroker/node_modules/object-copy/node_modules/is-descriptor
          is-accessor-descriptor@0.1.6 /opt/iobroker/node_modules/object-copy/node_modules/is-accessor-descriptor
          is-data-descriptor@0.1.4 /opt/iobroker/node_modules/object-copy/node_modules/is-data-descriptor
          kind-of@5.1.0 /opt/iobroker/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
          prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
          prompt-radio@1.2.1 /opt/iobroker/node_modules/prompt-radio
          redis@2.8.0 /opt/iobroker/node_modules/redis
          redis-commands@1.5.0 /opt/iobroker/node_modules/redis-commands
          redis-parser@2.6.0 /opt/iobroker/node_modules/redis-parser
          simple-concat@1.0.0 /opt/iobroker/node_modules/simple-concat
          simple-get@2.8.1 /opt/iobroker/node_modules/simple-get
          streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
          strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
          systeminformation@4.12.2 /opt/iobroker/node_modules/systeminformation
          suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
          to-buffer@1.1.1 /opt/iobroker/node_modules/to-buffer
          uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
          ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
          which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
          winston-syslog@1.2.6 /opt/iobroker/node_modules/winston-syslog
          detect-libc@1.0.3 /opt/iobroker/node_modules/detect-libc
          prebuild-install@4.0.0 /opt/iobroker/node_modules/prebuild-install
          rc@1.2.8 /opt/iobroker/node_modules/rc
          tar-fs@1.16.3 /opt/iobroker/node_modules/tar-fs
          pump@1.0.3 /opt/iobroker/node_modules/tar-fs/node_modules/pump
          tar-stream@1.6.2 /opt/iobroker/node_modules/tar-stream
          readable-stream@2.3.6 /opt/iobroker/node_modules/tar-stream/node_modules/readable-stream
          isarray@1.0.0 /opt/iobroker/node_modules/tar-stream/node_modules/isarray
          string_decoder@1.1.1 /opt/iobroker/node_modules/tar-stream/node_modules/string_decoder
          promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
          axios@0.18.1 /opt/iobroker/node_modules/axios
          follow-redirects@1.5.10 /opt/iobroker/node_modules/follow-redirects
          debug@3.1.0 /opt/iobroker/node_modules/follow-redirects/node_modules/debug
          is-buffer@2.0.3 /opt/iobroker/node_modules/axios/node_modules/is-buffer
          express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
          fs-extra@4.0.3 /opt/iobroker/node_modules/express-fileupload/node_modules/fs-extra
          mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
          debug@2.2.0 /opt/iobroker/node_modules/mdns-discovery/node_modules/debug
          ms@0.7.1 /opt/iobroker/node_modules/mdns-discovery/node_modules/ms
          node-ssdp@3.3.0 /opt/iobroker/node_modules/node-ssdp
          debug@3.2.6 /opt/iobroker/node_modules/node-ssdp/node_modules/debug
          ms@2.1.2 /opt/iobroker/node_modules/node-ssdp/node_modules/ms
          unix-dgram@0.2.3 /opt/iobroker/node_modules/unix-dgram
          bindings@1.1.1 /opt/iobroker/node_modules/unix-dgram/node_modules/bindings
          nan@2.3.5 /opt/iobroker/node_modules/unix-dgram/node_modules/nan
          le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
          rsa-compat@1.9.4 /opt/iobroker/node_modules/le-acme-core/node_modules/rsa-compat
          serialport@6.2.2 /opt/iobroker/node_modules/serialport
          debug@3.2.6 /opt/iobroker/node_modules/serialport/node_modules/debug
          ms@2.1.2 /opt/iobroker/node_modules/serialport/node_modules/ms
          root@iobroker:/opt/iobroker#
          • liv-in-skyL Offline
            liv-in-skyL Offline
            wenn fertig:
            mit root user im iobroker verzeichnis
            npm cache clear --force
            • liv-in-skyL liv-in-sky
              wenn fertig:
              ThorstenStr
              @liv-in-sky
              ok ist Durch.
              jetzt wieder Testen ?
              • T ThorstenStr
                @liv-in-sky
                ok ist Durch.
                liv-in-skyL Offline
                liv-in-skyL Offline
                @ThorstenStr am besten starte ganz neu - dann testen
                  ThorstenStr
                  @liv-in-sky
                  sieht bis jetzt sehr gut aus, auch im log keinerlei Fehlermeldungen.
                  An was war es gelegen ? oder auf wass sollte ich in Zukunft achten??
                  ich werde es jetzt ausgiebig testen und morgen berichten.
                  Bis dahin schon einmal vielen Dank für deine Hilfe 👍
                  • T ThorstenStr
                    @liv-in-sky
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @ThorstenStr jetzt hoffen wir mal, dass das ganze auch noch in ein paar tagen funktioniert - sag morgen mal bescheid, ob alles ok ist
                    ansonsten scheint es , dass node und iobroker noch nicht richtig kompliert waren - npm rebuild braucht man eigentlich bei einen update von node z.b von 8.xx auf 10.xx - das ist ein muss ! genau sagen , warum da fehler waren, kann ich dir auch nicht
                    achte darauf das du die npm befehle mit root user machst - ansonsten solltest du diese nicht gebrauchen - es gibt ja den iobroker user (durch das fixer script) der alles intern regelt (über admin) - man sollte wohl so wenig wie möglich auf der terminal ebene arbeiten (2-3 ausnahmen)
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @liv-in-sky sagte in Endlosschleife bei Adapter Installation:
                      Ähhhhh. Eigentlich nicht!
                      ==> https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo
                      @ThorstenStr Nachdem du auch npm-Befehle mit sudo ausgeführt hast, solltest du unbedingt den Fixer laufen lassen. Warum du den direkt nach der Installation ausführst, ist mir schleierhaft - schließlich soll er die Rechte genau so wiederherstellen wie die Installation es tut.
                      • AlCalzoneA AlCalzone
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @AlCalzone
                        ich zweifle sicher nicht an, was du sagst - hätte eine frage dazu: warum funktioniert dann sudo npm rebuild bei ihm nicht ? deshalb haben wir/er mit dem root user gearbeitet
                        was muss @ThorstenStr jetzt noch machen, damit er für die zukunft richtig eingestellt ist - beim letzten kontakt lief ja alles - "klopfe auf holz"
                          @AlCalzone
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          @liv-in-sky Je nachdem, wie die Berechtigungen auf dem System aussehen, kann es durchaus nötig sein, sudo zu verwenden. Das sollte aber wie im verlinkten Thread beschrieben nur eine Notlösung werden. Dein Satz klang recht pauschal nach "wenn du npm nutzt, nimm sudo".
                          Warum rebuild selbst als root nicht funktioniert, bin ich nicht sicher. Könnte am fehlenden --unsafe-perm Flag liegen.
                          Am besten 1x den Fixer laufen lassen und dann wo es geht auf root/sudo verzichten.
                            ThorstenStr
                            ich denke das mit dem Fixer habe ich falsch verstanden, daher habe ich ihn direkt nach der Installation ausgeführt.
                            Bisher läuft alles wie gehabt gut. ich werde jetzt noch einmal den Fixer ausführen und zukünftig wie in den HowTos angegeben verfahren.
                            Leider bin ich nicht so der Linux Guru, habe nur leichte Erfahrungen durch raspis gesammelt.
                            Aber dank euere Hilfe sollte jetzt alles laufen.
                            Vielen Dank
                            ich sezte den Thread auf gelöst, sollte noch etwas passieren, melde ich mich ;)
                            vielen vielen Dank
