  4. Fehlermeldung von Node-Red
fehler
27 Beiträge 4 Kommentatoren 6.5k Aufrufe 3 Beobachtet
  • F fisch
    naja jetzt bin ich im richtigen Ordner... Jetzt kommt das hier? Habs mit sudo und ohne sudo ausgeführt.
    pi@ioBroker-Pi:/opt/iobroker $ sudo npm rebuild
    > iobroker.js-controller@1.5.12 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.9.0
    npm version >= 5: disabling package-lock
    Could not check npm version: Error: EACCES: permission denied, open '/opt/iobroker/.npmrc'
    Assuming that correct version is installed.
    > iobroker.js-controller@1.5.12 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    > bcrypt@3.0.5 install /opt/iobroker/node_modules/node-red/node_modules/bcrypt
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using request for node-pre-gyp https download
    [bcrypt] Success: "/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node" already installed
    Pass --update-binary to reinstall or --build-from-source to recompile
    > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/@serialport/bindings
    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
    gyp ERR! clean error
    gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
    gyp ERR! System Linux 4.14.34-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    gyp ERR! node -v v10.16.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the @serialport/bindings@2.0.8 install script.
    npm ERR!     /root/.npm/_logs/2019-06-19T18_28_09_606Z-debug.log
    sigi234S Online
    sigi234S Online
    @fisch sagte in Fehlermeldung von Node-Red:
    https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
    https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
    • F Offline
      fisch
      schrieb am zuletzt editiert von fisch
      Fixer ist erfolgreich durchgelaufen....
      das andere verstehe ich nicht ganz :-(
      danke für euren support!!
      für jetzt gerade nochmal den npm rebuild aus....
      EDIT: jetzt läuft es erst mal durch
      • F fisch
        sigi234S Online
        sigi234S Online
        Das wird schon..........
        • F Offline
          fisch
          ich verliere irgendwie gerade die Hoffnung :-(
          lief jetzt ziemlich lange durch...
          Abe jetzt kommt das
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR! unix-dgram@0.2.3 install: `node-gyp rebuild`
          • F fisch
            Abe jetzt kommt das
            gyp ERR! not ok
            npm ERR! errno 1
            sigi234S Online
            sigi234S Online
            @fisch
            Neu starten, kommst du dann in den Admin?
            • F Offline
              fisch
              So jetzt geht auch Node-Red wieder!!! Habe den Adapter komplett gelöscht und erneut installiert!
              eine kleinen Fehler habe ich noch in Node-red.. Wenn ich den noch weg bekommen würde . das ppm rebmild habe ich schon versucht... :-(
              Error: The module '/opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/build/Release/rcswitch.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 48. This version of Node.js requiresNODE_MODULE_VERSION 64. Please try re-compiling or re-installingth
              • F fisch
                Jan1
                @fisch
                kann es sein dass Du 2 verschieden Node Versionen laufen hast? Denn der Fehler dürfte nach einer kompletten Neuinstallation des Adapter überhaupt nicht auftauchen.
                • F Offline
                  fisch
                  nein habe ich nicht am laufen...es liegt an dem RSSwitch von Node-Red ..funktioniert mit Node>10 nicht..Das Problem haben noch mehr..:-(
                  • F fisch
                    Jan1
                    @fisch
                    ich habe Node-Red mit Node 10 ohne Fehler laufen, somit stimmt das nicht.
                    root@Beelink:~# node -v
                    v10.16.0
                    root@Beelink:~# nodejs -v
                    v10.16.0
                    root@Beelink:~# npm -v
                    6.9.0
                    root@Beelink:~#
                    F 1 Antwort Letzte Antwort
                    • J Jan1
                      @fisch
                      v10.16.0
                      v10.16.0
                      6.9.0
                      root@Beelink:~#
                      fisch
                      @Jan1
                      mein Node-Red läuft doch auch ! Nur eine Node RC-Switch eben nicht...Kannst es ja mal ausprobieren....dann wirst sehen, dass es am RC-Switch liegt.
                      Alles andre in Node_Red läuft ja ;-)
                      • F fisch
                        @Jan1
                        Jan1
                        @fisch
                        dann habe ich Dich falsch verstanden.
                        Von welcher Node RC-Switch sprichst Du? denn bei der "node-red-contrib-rcswitch2" steht das dabei "It should be compatible with all versions of Node.js starting from 0.10.x.". Wobei ich die dirkt über Node-RED nicht installiert bekomme.
                        • F Offline
                          fisch
                          @Jan1 said in Fehlermeldung von Node-Red:
                          genau den meine ich ! Wie gesagt...bringt eben dann diese Fehlermeldung!
                          Im GitHub dem dem Teil berichten noch mehrere von diesem Problem..
                          • F fisch
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            @fisch Die Fehlermeldung besagt, dass das Modul gegen eine alte Node-Version kompiliert wurde - danach hast du ein Update gefahren. Das erfordert eine erneute Kompilierung des betreffenden Moduls. Wenn es mit npm rebuild nicht klappt, dann dürfte das (analog zu Z-Wave) gehen:
                            cd /opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/
                            npm i --production
                            • AlCalzoneA AlCalzone
                              npm i --production
                              fisch
                              @AlCalzone said in Fehlermeldung von Node-Red:
                              npm i --production
                              Oh, jetzt erst deine Antwort gelesen.... Danke erstmal dafür!
                              Habe das ganze nun neu installieren wollen -jetzt bekomme ich das hier..
                              2019-06-24T11:23:49.737Z installieren : node-red-contrib-rcswitch2 0.1.1
                              2019-06-24T11:23:49.763Z npm install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-rcswitch2@0.1.1
                              2019-06-24T11:24:33.889Z [out]
                              2019-06-24T11:24:33.889Z [out] > rcswitch@0.3.1 install /opt/iobroker/iobroker-data/node-red/node_modules/rcswitch
                              2019-06-24T11:24:33.889Z [out] > node-gyp rebuild
                              2019-06-24T11:24:37.626Z [out] make: Verzeichnis „/opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/build“ wird betreten
                              2019-06-24T11:24:37.631Z [out]   CXX(target) Release/obj.target/rcswitch/src/rcswitch.o
                              2019-06-24T11:24:45.896Z [out]   CXX(target) Release/obj.target/rcswitch/src/RCSwitchNode.o
                              2019-06-24T11:24:49.088Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                              2019-06-24T11:24:49.088Z [err] ../src/RCSwitchNode.cpp: In static member function ‘static void RCSwitchNode::SwitchOp(const Nan::FunctionCallbackInfo<v8::Value>&, bool)’:
                              2019-06-24T11:24:49.088Z [err] ../src/RCSwitchNode.cpp:46:35: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.088Z [err]        switchOp2(group->Int32Value(), swtch->Int32Value());
                              2019-06-24T11:24:49.088Z [err]                                    ^
                              2019-06-24T11:24:49.088Z [err] ../src/RCSwitchNode.h:19:69: note: in definition of macro ‘switchOp2’
                              2019-06-24T11:24:49.088Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                              2019-06-24T11:24:49.088Z [err]        ^~
                              2019-06-24T11:24:49.089Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.089Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.089Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.089Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.089Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.089Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.089Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.089Z [err]                                               ^
                              2019-06-24T11:24:49.089Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.089Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.089Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.089Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                              2019-06-24T11:24:49.089Z [err] ../src/RCSwitchNode.cpp:46:56: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.089Z [err]        switchOp2(group->Int32Value(), swtch->Int32Value());
                              2019-06-24T11:24:49.089Z [err] ../src/RCSwitchNode.h:19:75: note: in definition of macro ‘switchOp2’
                              2019-06-24T11:24:49.089Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                              2019-06-24T11:24:49.089Z [err] ../src/RCSwitchNode.cpp:46:35: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.089Z [err] ../src/RCSwitchNode.h:19:112: note: in definition of macro ‘switchOp2’
                              2019-06-24T11:24:49.090Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.090Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.090Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.090Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.090Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.090Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.090Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.090Z [err]                                               ^
                              2019-06-24T11:24:49.090Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.090Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.090Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.090Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                              2019-06-24T11:24:49.090Z [err] ../src/RCSwitchNode.cpp:46:56: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.090Z [err]        switchOp2(group->Int32Value(), swtch->Int32Value());
                              2019-06-24T11:24:49.090Z [err] ../src/RCSwitchNode.h:19:118: note: in definition of macro ‘switchOp2’
                              2019-06-24T11:24:49.090Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                              2019-06-24T11:24:49.091Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                              2019-06-24T11:24:49.091Z [err] ../src/RCSwitchNode.cpp:52:46: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.091Z [err]          switchOp2(*sGroup, swtch->Int32Value());
                              2019-06-24T11:24:49.091Z [err]                                               ^
                              2019-06-24T11:24:49.091Z [err] ../src/RCSwitchNode.h:19:75: note: in definition of macro ‘switchOp2’
                              2019-06-24T11:24:49.091Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                              2019-06-24T11:24:49.091Z [err]        ^~
                              2019-06-24T11:24:49.091Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.091Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.091Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.091Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.091Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.091Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.091Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.091Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.091Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.091Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.092Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                              2019-06-24T11:24:49.092Z [err] ../src/RCSwitchNode.cpp:52:46: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.092Z [err]          switchOp2(*sGroup, swtch->Int32Value());
                              2019-06-24T11:24:49.092Z [err]                                               ^
                              2019-06-24T11:24:49.092Z [err] ../src/RCSwitchNode.h:19:118: note: in definition of macro ‘switchOp2’
                              2019-06-24T11:24:49.092Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                              2019-06-24T11:24:49.092Z [err]        ^~
                              2019-06-24T11:24:49.092Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.092Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.092Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.092Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.092Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.092Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.092Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.092Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.092Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.092Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.094Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                              2019-06-24T11:24:49.094Z [err] ../src/RCSwitchNode.cpp:65:48: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.094Z [err]          switchOp3(*(*v8str), group->Int32Value(), devce->Int32Value());
                              2019-06-24T11:24:49.094Z [err]                                                 ^
                              2019-06-24T11:24:49.094Z [err] ../src/RCSwitchNode.h:20:79: note: in definition of macro ‘switchOp3’
                              2019-06-24T11:24:49.094Z [err]    #define switchOp3(p1, p2, p3) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2), (p3)); else thiz->rcswitch.switchOff((p1), (p2), (p3)); }
                              2019-06-24T11:24:49.094Z [err]        ^~
                              2019-06-24T11:24:49.094Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.094Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.094Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.094Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.094Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.094Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.094Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.094Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.094Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.094Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.094Z [err] ../src/RCSwitchNode.cpp:65:69: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.094Z [err] ../src/RCSwitchNode.h:20:85: note: in definition of macro ‘switchOp3’
                              2019-06-24T11:24:49.095Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                              2019-06-24T11:24:49.095Z [err] ../src/RCSwitchNode.cpp:65:48: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.095Z [err]          switchOp3(*(*v8str), group->Int32Value(), devce->Int32Value());
                              2019-06-24T11:24:49.095Z [err]                                                 ^
                              2019-06-24T11:24:49.095Z [err] ../src/RCSwitchNode.h:20:128: note: in definition of macro ‘switchOp3’
                              2019-06-24T11:24:49.095Z [err]    #define switchOp3(p1, p2, p3) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2), (p3)); else thiz->rcswitch.switchOff((p1), (p2), (p3)); }
                              2019-06-24T11:24:49.095Z [err]        ^~
                              2019-06-24T11:24:49.095Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.095Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.095Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.095Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.095Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.095Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.095Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.095Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.095Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.095Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.097Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                              2019-06-24T11:24:49.097Z [err] ../src/RCSwitchNode.cpp:65:69: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.097Z [err]          switchOp3(*(*v8str), group->Int32Value(), devce->Int32Value());
                              2019-06-24T11:24:49.097Z [err]        ^
                              2019-06-24T11:24:49.097Z [err] ../src/RCSwitchNode.h:20:134: note: in definition of macro ‘switchOp3’
                              2019-06-24T11:24:49.097Z [err]    #define switchOp3(p1, p2, p3) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2), (p3)); else thiz->rcswitch.switchOff((p1), (p2), (p3)); }
                              2019-06-24T11:24:49.097Z [err]        ^~
                              2019-06-24T11:24:49.097Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.097Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.097Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.097Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.097Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.097Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.097Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.097Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.097Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.097Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.101Z [err] ../src/RCSwitchNode.cpp: In static member function ‘static void RCSwitchNode::New(const Nan::FunctionCallbackInfo<v8::Value>&)’:
                              2019-06-24T11:24:49.101Z [err] ../src/RCSwitchNode.cpp:83:59: error: no matching function for call to ‘v8::Function::NewInstance(const int&, v8::Local<v8::Value> [0])’
                              2019-06-24T11:24:49.101Z [err]      info.GetReturnValue().Set(cons->NewInstance(argc, argv));
                              2019-06-24T11:24:49.101Z [err]                                                            ^
                              2019-06-24T11:24:49.102Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
                              2019-06-24T11:24:49.102Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.102Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.102Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.102Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
                              2019-06-24T11:24:49.102Z [err]    V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
                              2019-06-24T11:24:49.102Z [err]                                             ^~~~~~~~~~~
                              2019-06-24T11:24:49.102Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
                              2019-06-24T11:24:49.102Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
                              2019-06-24T11:24:49.102Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
                              2019-06-24T11:24:49.106Z [err] ../src/RCSwitchNode.cpp: In static member function ‘static void RCSwitchNode::EnableTransmit(const Nan::FunctionCallbackInfo<v8::Value>&)’:
                              2019-06-24T11:24:49.106Z [err] ../src/RCSwitchNode.cpp:115:52: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.106Z [err]      obj->rcswitch.enableTransmit(pinNr->Int32Value());
                              2019-06-24T11:24:49.106Z [err]                                                     ^
                              2019-06-24T11:24:49.106Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.106Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.106Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.106Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.106Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.106Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.106Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.106Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.106Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.106Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.108Z [err] ../src/RCSwitchNode.cpp: In static member function ‘static void RCSwitchNode::SetProtocol(v8::Local<v8::String>, v8::Local<v8::Value>, const Nan::PropertyCallbackInfo<v8::Value>&)’:
                              2019-06-24T11:24:49.108Z [err] ../src/RCSwitchNode.cpp:144:49: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              2019-06-24T11:24:49.108Z [err]      obj->rcswitch.setProtocol(value->Int32Value());
                              2019-06-24T11:24:49.108Z [err]                                                  ^
                              2019-06-24T11:24:49.109Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                              2019-06-24T11:24:49.109Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                              2019-06-24T11:24:49.109Z [err]                  from ../../nan/nan.h:54,
                              2019-06-24T11:24:49.109Z [err]                  from ../src/RCSwitchNode.h:4,
                              2019-06-24T11:24:49.109Z [err]                  from ../src/RCSwitchNode.cpp:1:
                              2019-06-24T11:24:49.109Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                              2019-06-24T11:24:49.109Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              2019-06-24T11:24:49.109Z [err]                                               ^
                              2019-06-24T11:24:49.109Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              2019-06-24T11:24:49.109Z [err]    declarator __attribute__((deprecated(message)))
                              2019-06-24T11:24:49.109Z [err]    ^~~~~~~~~~
                              2019-06-24T11:24:49.564Z [out] rcswitch.target.mk:103: die Regel für Ziel „Release/obj.target/rcswitch/src/RCSwitchNode.o“ scheiterte
                              2019-06-24T11:24:49.564Z [out] make: Verzeichnis „/opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/build“ wird verlassen
                              2019-06-24T11:24:49.565Z [err] make: *** [Release/obj.target/rcswitch/src/RCSwitchNode.o] Fehler 1
                              2019-06-24T11:24:49.570Z [err] gyp
                              2019-06-24T11:24:49.571Z [err]
                              2019-06-24T11:24:49.571Z [err] ERR! build error
                              2019-06-24T11:24:49.574Z [err] gyp ERR! stack Error: `make` failed with exit code: 2
                              2019-06-24T11:24:49.577Z [err]  stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                              2019-06-24T11:24:49.577Z [err] gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                              2019-06-24T11:24:49.577Z [err] gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                              2019-06-24T11:24:49.577Z [err] gyp ERR! System Linux 4.14.34-v7+
                              2019-06-24T11:24:49.577Z [err] gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              2019-06-24T11:24:49.577Z [err] gyp ERR! cwd /opt/iobroker/iobroker-data/node-red/node_modules/rcswitch
                              2019-06-24T11:24:49.578Z [err] gyp ERR! node -v
                              2019-06-24T11:24:49.578Z [err]  v10.16.0
                              2019-06-24T11:24:49.578Z [err] ERR!
                              2019-06-24T11:24:49.578Z [err] node-gyp -v v3.8.0
                              2019-06-24T11:24:49.579Z [err] not ok
                              2019-06-24T11:24:52.559Z [err] npm
                              2019-06-24T11:24:52.559Z [err]  WARN discord.js@11.5.1 requires a peer of bufferutil@^4.0.0 but none is installed. You must install peer dependencies yourself.
                              2019-06-24T11:24:52.560Z [err]  discord.js@11.5.1 requires a peer of erlpack@discordapp/erlpack but none is installed. You must install peer dependencies yourself.
                              2019-06-24T11:24:52.560Z [err] npm
                              2019-06-24T11:24:52.560Z [err]  WARN
                              2019-06-24T11:24:52.560Z [err]  discord.js@11.5.1 requires a peer of libsodium-wrappers@^0.7.3 but none is installed. You must install peer dependencies yourself.
                              2019-06-24T11:24:52.560Z [err]  discord.js@11.5.1 requires a peer of node-opus@^0.2.7 but none is installed. You must install peer dependencies yourself.
                              2019-06-24T11:24:52.561Z [err]  WARN
                              2019-06-24T11:24:52.561Z [err]  discord.js@11.5.1 requires a peer of opusscript@^0.0.6 but none is installed. You must install peer dependencies yourself.
                              2019-06-24T11:24:52.561Z [err] npm
                              2019-06-24T11:24:52.561Z [err]  discord.js@11.5.1 requires a peer of sodium@^2.0.3 but none is installed. You must install peer dependencies yourself.
                              2019-06-24T11:24:52.562Z [err]  discord.js@11.5.1 requires a peer of @discordjs/uws@^10.149.0 but none is installed. You must install peer dependencies yourself.
                              2019-06-24T11:24:52.562Z [err] npm
                              2019-06-24T11:24:52.562Z [err]  WARN
                              2019-06-24T11:24:52.562Z [err]  node-red-project@0.0.1 No repository field.
                              2019-06-24T11:24:52.563Z [err]  node-red-project@0.0.1 No license field.
                              2019-06-24T11:24:53.205Z [err] npm ERR! code ELIFECYCLE
                              2019-06-24T11:24:53.205Z [err] ERR! errno 1
                              2019-06-24T11:24:53.206Z [err] npm
                              2019-06-24T11:24:53.206Z [err]  ERR! rcswitch@0.3.1 install: `node-gyp rebuild`
                              2019-06-24T11:24:53.206Z [err] npm ERR!
                              2019-06-24T11:24:53.206Z [err]  Exit status 1
                              2019-06-24T11:24:53.207Z [err] npm
                              2019-06-24T11:24:53.207Z [err]  ERR!
                              2019-06-24T11:24:53.207Z [err] npm ERR!
                              2019-06-24T11:24:53.207Z [err]  Failed at the rcswitch@0.3.1 install script.
                              2019-06-24T11:24:53.208Z [err] npm
                              2019-06-24T11:24:53.208Z [err] ERR!
                              2019-06-24T11:24:53.208Z [err]  This is probably not a problem with npm. There is likely additional logging output above.
                              2019-06-24T11:24:53.794Z [err]
                              2019-06-24T11:24:53.795Z [err] npm ERR! A complete log of this run can be found in:
                              2019-06-24T11:24:53.795Z [err] ERR!     /home/iobroker/.npm/_logs/2019-06-24T11_24_53_226Z-debug.log
                              2019-06-24T11:24:53.830Z rc=1
                              • F fisch
                                npm i --production
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @fisch Das klingt mir schwer danach dass das Modul nicht mit Node 10 kompatibel ist.
