  4. Fehlermeldung von Node-Red
fehler
27 Beiträge 4 Kommentatoren 6.5k Aufrufe 3 Beobachtet
  • F fisch
    habs jetzt mal im Ordner von Node Red ausgeführt...
    gebracht hat es leider nicht...
    hier noch mehr Fehlermeldungen...
    node-red.2	2019-06-19 20:06:53.186	error	at EmulatedDevice.emit (events.js:198:13)
    node-red.2	2019-06-19 20:06:53.186	error	at EmulatedDevice.<anonymous> (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-wemo-emulator/index.js:90:26)
    node-red.2	2019-06-19 20:06:53.186	error	at Object.Node.send (/opt/iobroker/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:224:14)
    node-red.2	2019-06-19 20:06:53.186	error	at RCSwitchNode.Node.receive (/opt/iobroker/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:237:14)
    node-red.2	2019-06-19 20:06:53.186	error	at RCSwitchNode.EventEmitter.emit (domain.js:448:20)
    node-red.2	2019-06-19 20:06:53.186	error	at RCSwitchNode.emit (events.js:198:13)
    node-red.2	2019-06-19 20:06:53.186	error	at RCSwitchNode.<anonymous> (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-rcswitch2/rcswitch/rcswitch.js:17:17)
    node-red.2	2019-06-19 20:06:53.186	error	at require (internal/modules/cjs/helpers.js:25:18)
    node-red.2	2019-06-19 20:06:53.186	error	at Module.require (internal/modules/cjs/loader.js:690:17)
    node-red.2	2019-06-19 20:06:53.186	error	at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    node-red.2	2019-06-19 20:06:53.186	error	at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    node-red.2	2019-06-19 20:06:53.186	error	at Module.load (internal/modules/cjs/loader.js:653:32)
    node-red.2	2019-06-19 20:06:53.186	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
    node-red.2	2019-06-19 20:06:53.186	error	at Module._compile (internal/modules/cjs/loader.js:776:30)
    node-red.2	2019-06-19 20:06:53.186	error	at Object.<anonymous> (/opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/index.js:1:35)
    node-red.2	2019-06-19 20:06:53.186	error	at bindings (/opt/iobroker/iobroker-data/node-red/node_modules/bindings/bindings.js:81:44)
    node-red.2	2019-06-19 20:06:53.186	error	at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18)
    node-red.2	2019-06-19 20:06:53.186	error	the module (for instance, using `npm rebuild` or `npm install`).
    node-red.2	2019-06-19 20:06:53.186	error	NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
    node-red.2	2019-06-19 20:06:53.186	error	NODE_MODULE_VERSION 48. This version of Node.js requires
    node-red.2	2019-06-19 20:06:53.186	error	was compiled against a different Node.js version using
    node-red.2	2019-06-19 20:06:53.186	error	19 Jun 20:06:53 - [error] [rcswitch:Nachtlicht.OnOff] Error: The module '/opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/build/Release/rcswitch.node'
    homee.0	2019-06-19 20:06:53.024	info	initialize 1 nodes```
    code_text
    sigi234S Online
    sigi234S Online
    @fisch sagte in Fehlermeldung von Node-Red:
    Nein, im Host Ordner..........
    • F Offline
      fisch
      alos hier
      pi@ioBroker-Pi:/opt/iobroker $ npm rebuild
      • F fisch
        alos hier
        Jan1
        @fisch
        Ja, wenn im falschen Verzeichnis bist, bringt der Befehl nur Fehler.
        • F Offline
          fisch
          schrieb am zuletzt editiert von fisch
          naja jetzt bin ich im richtigen Ordner... Jetzt kommt das hier? Habs mit sudo und ohne sudo ausgeführt.
          pi@ioBroker-Pi:/opt/iobroker $ sudo npm rebuild
          > iobroker.js-controller@1.5.12 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.9.0
          npm version >= 5: disabling package-lock
          Could not check npm version: Error: EACCES: permission denied, open '/opt/iobroker/.npmrc'
          Assuming that correct version is installed.
          > iobroker.js-controller@1.5.12 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          > bcrypt@3.0.5 install /opt/iobroker/node_modules/node-red/node_modules/bcrypt
          > node-pre-gyp install --fallback-to-build
          node-pre-gyp WARN Using request for node-pre-gyp https download
          [bcrypt] Success: "/opt/iobroker/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node" already installed
          Pass --update-binary to reinstall or --build-from-source to recompile
          > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/@serialport/bindings
          > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
          prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
          gyp ERR! clean error
          gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
          gyp ERR! System Linux 4.14.34-v7+
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
          gyp ERR! node -v v10.16.0
          gyp ERR! node-gyp -v v3.8.0
          gyp ERR! not ok
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the @serialport/bindings@2.0.8 install script.
          npm ERR!     /root/.npm/_logs/2019-06-19T18_28_09_606Z-debug.log
          J sigi234S 2 Antworten Letzte Antwort
          • F fisch
            NPM version: 6.9.0
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            Jan1
            @fisch
            Hast den Fixer schon laufen lassen, weil hier werden Rechtefehler angemeckert.
            • F fisch
              NPM version: 6.9.0
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              sigi234S Online
              sigi234S Online
              https://forum.iobroker.net/topic/20211/iobroker-installation-fixer-beta-verfügbar
              https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
              • F Offline
                fisch
                Fixer ist erfolgreich durchgelaufen....
                das andere verstehe ich nicht ganz :-(
                danke für euren support!!
                für jetzt gerade nochmal den npm rebuild aus....
                EDIT: jetzt läuft es erst mal durch
                • F fisch
                  sigi234S Online
                  sigi234S Online
                  Das wird schon..........
                  • F Offline
                    fisch
                    ich verliere irgendwie gerade die Hoffnung :-(
                    lief jetzt ziemlich lange durch...
                    Abe jetzt kommt das
                    gyp ERR! build error
                    gyp ERR! stack Error: `make` failed with exit code: 2
                    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                    gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR! unix-dgram@0.2.3 install: `node-gyp rebuild`
                    • F fisch
                      Abe jetzt kommt das
                      gyp ERR! not ok
                      npm ERR! errno 1
                      sigi234S Online
                      sigi234S Online
                      @fisch
                      Neu starten, kommst du dann in den Admin?
                      • F Offline
                        fisch
                        So jetzt geht auch Node-Red wieder!!! Habe den Adapter komplett gelöscht und erneut installiert!
                        eine kleinen Fehler habe ich noch in Node-red.. Wenn ich den noch weg bekommen würde . das ppm rebmild habe ich schon versucht... :-(
                        Error: The module '/opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/build/Release/rcswitch.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 48. This version of Node.js requiresNODE_MODULE_VERSION 64. Please try re-compiling or re-installingth
                        • F fisch
                          Jan1
                          @fisch
                          kann es sein dass Du 2 verschieden Node Versionen laufen hast? Denn der Fehler dürfte nach einer kompletten Neuinstallation des Adapter überhaupt nicht auftauchen.
                          • F Offline
                            fisch
                            nein habe ich nicht am laufen...es liegt an dem RSSwitch von Node-Red ..funktioniert mit Node>10 nicht..Das Problem haben noch mehr..:-(
                            • F fisch
                              Jan1
                              @fisch
                              ich habe Node-Red mit Node 10 ohne Fehler laufen, somit stimmt das nicht.
                              root@Beelink:~# node -v
                              v10.16.0
                              root@Beelink:~# nodejs -v
                              v10.16.0
                              root@Beelink:~# npm -v
                              6.9.0
                              root@Beelink:~#
                              F 1 Antwort Letzte Antwort
                              • J Jan1
                                @fisch
                                v10.16.0
                                v10.16.0
                                6.9.0
                                root@Beelink:~#
                                fisch
                                @Jan1
                                mein Node-Red läuft doch auch ! Nur eine Node RC-Switch eben nicht...Kannst es ja mal ausprobieren....dann wirst sehen, dass es am RC-Switch liegt.
                                Alles andre in Node_Red läuft ja ;-)
                                • F fisch
                                  @Jan1
                                  Jan1
                                  @fisch
                                  dann habe ich Dich falsch verstanden.
                                  Von welcher Node RC-Switch sprichst Du? denn bei der "node-red-contrib-rcswitch2" steht das dabei "It should be compatible with all versions of Node.js starting from 0.10.x.". Wobei ich die dirkt über Node-RED nicht installiert bekomme.
                                  • F Offline
                                    fisch
                                    @Jan1 said in Fehlermeldung von Node-Red:
                                    genau den meine ich ! Wie gesagt...bringt eben dann diese Fehlermeldung!
                                    Im GitHub dem dem Teil berichten noch mehrere von diesem Problem..
                                    • F fisch
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      @fisch Die Fehlermeldung besagt, dass das Modul gegen eine alte Node-Version kompiliert wurde - danach hast du ein Update gefahren. Das erfordert eine erneute Kompilierung des betreffenden Moduls. Wenn es mit npm rebuild nicht klappt, dann dürfte das (analog zu Z-Wave) gehen:
                                      cd /opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/
                                      npm i --production
                                      • AlCalzoneA AlCalzone
                                        npm i --production
                                        fisch
                                        @AlCalzone said in Fehlermeldung von Node-Red:
                                        npm i --production
                                        Oh, jetzt erst deine Antwort gelesen.... Danke erstmal dafür!
                                        Habe das ganze nun neu installieren wollen -jetzt bekomme ich das hier..
                                        2019-06-24T11:23:49.737Z installieren : node-red-contrib-rcswitch2 0.1.1
                                        2019-06-24T11:23:49.763Z npm install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-rcswitch2@0.1.1
                                        2019-06-24T11:24:33.889Z [out]
                                        2019-06-24T11:24:33.889Z [out] > rcswitch@0.3.1 install /opt/iobroker/iobroker-data/node-red/node_modules/rcswitch
                                        2019-06-24T11:24:33.889Z [out] > node-gyp rebuild
                                        2019-06-24T11:24:37.626Z [out] make: Verzeichnis „/opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/build“ wird betreten
                                        2019-06-24T11:24:37.631Z [out]   CXX(target) Release/obj.target/rcswitch/src/rcswitch.o
                                        2019-06-24T11:24:45.896Z [out]   CXX(target) Release/obj.target/rcswitch/src/RCSwitchNode.o
                                        2019-06-24T11:24:49.088Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                                        2019-06-24T11:24:49.088Z [err] ../src/RCSwitchNode.cpp: In static member function ‘static void RCSwitchNode::SwitchOp(const Nan::FunctionCallbackInfo<v8::Value>&, bool)’:
                                        2019-06-24T11:24:49.088Z [err] ../src/RCSwitchNode.cpp:46:35: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.088Z [err]        switchOp2(group->Int32Value(), swtch->Int32Value());
                                        2019-06-24T11:24:49.088Z [err]                                    ^
                                        2019-06-24T11:24:49.088Z [err] ../src/RCSwitchNode.h:19:69: note: in definition of macro ‘switchOp2’
                                        2019-06-24T11:24:49.088Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                                        2019-06-24T11:24:49.088Z [err]        ^~
                                        2019-06-24T11:24:49.089Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.089Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.089Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.089Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.089Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.089Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.089Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.089Z [err]                                               ^
                                        2019-06-24T11:24:49.089Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.089Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.089Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.089Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                                        2019-06-24T11:24:49.089Z [err] ../src/RCSwitchNode.cpp:46:56: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.089Z [err]        switchOp2(group->Int32Value(), swtch->Int32Value());
                                        2019-06-24T11:24:49.089Z [err] ../src/RCSwitchNode.h:19:75: note: in definition of macro ‘switchOp2’
                                        2019-06-24T11:24:49.089Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                                        2019-06-24T11:24:49.089Z [err] ../src/RCSwitchNode.cpp:46:35: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.089Z [err] ../src/RCSwitchNode.h:19:112: note: in definition of macro ‘switchOp2’
                                        2019-06-24T11:24:49.090Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.090Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.090Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.090Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.090Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.090Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.090Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.090Z [err]                                               ^
                                        2019-06-24T11:24:49.090Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.090Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.090Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.090Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                                        2019-06-24T11:24:49.090Z [err] ../src/RCSwitchNode.cpp:46:56: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.090Z [err]        switchOp2(group->Int32Value(), swtch->Int32Value());
                                        2019-06-24T11:24:49.090Z [err] ../src/RCSwitchNode.h:19:118: note: in definition of macro ‘switchOp2’
                                        2019-06-24T11:24:49.090Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                                        2019-06-24T11:24:49.091Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                                        2019-06-24T11:24:49.091Z [err] ../src/RCSwitchNode.cpp:52:46: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.091Z [err]          switchOp2(*sGroup, swtch->Int32Value());
                                        2019-06-24T11:24:49.091Z [err]                                               ^
                                        2019-06-24T11:24:49.091Z [err] ../src/RCSwitchNode.h:19:75: note: in definition of macro ‘switchOp2’
                                        2019-06-24T11:24:49.091Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                                        2019-06-24T11:24:49.091Z [err]        ^~
                                        2019-06-24T11:24:49.091Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.091Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.091Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.091Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.091Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.091Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.091Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.091Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.091Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.091Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.092Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                                        2019-06-24T11:24:49.092Z [err] ../src/RCSwitchNode.cpp:52:46: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.092Z [err]          switchOp2(*sGroup, swtch->Int32Value());
                                        2019-06-24T11:24:49.092Z [err]                                               ^
                                        2019-06-24T11:24:49.092Z [err] ../src/RCSwitchNode.h:19:118: note: in definition of macro ‘switchOp2’
                                        2019-06-24T11:24:49.092Z [err]    #define switchOp2(p1, p2) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2)); else thiz->rcswitch.switchOff((p1), (p2)); }
                                        2019-06-24T11:24:49.092Z [err]        ^~
                                        2019-06-24T11:24:49.092Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.092Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.092Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.092Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.092Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.092Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.092Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.092Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.092Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.092Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.094Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                                        2019-06-24T11:24:49.094Z [err] ../src/RCSwitchNode.cpp:65:48: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.094Z [err]          switchOp3(*(*v8str), group->Int32Value(), devce->Int32Value());
                                        2019-06-24T11:24:49.094Z [err]                                                 ^
                                        2019-06-24T11:24:49.094Z [err] ../src/RCSwitchNode.h:20:79: note: in definition of macro ‘switchOp3’
                                        2019-06-24T11:24:49.094Z [err]    #define switchOp3(p1, p2, p3) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2), (p3)); else thiz->rcswitch.switchOff((p1), (p2), (p3)); }
                                        2019-06-24T11:24:49.094Z [err]        ^~
                                        2019-06-24T11:24:49.094Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.094Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.094Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.094Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.094Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.094Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.094Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.094Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.094Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.094Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.094Z [err] ../src/RCSwitchNode.cpp:65:69: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.094Z [err] ../src/RCSwitchNode.h:20:85: note: in definition of macro ‘switchOp3’
                                        2019-06-24T11:24:49.095Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                                        2019-06-24T11:24:49.095Z [err] ../src/RCSwitchNode.cpp:65:48: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.095Z [err]          switchOp3(*(*v8str), group->Int32Value(), devce->Int32Value());
                                        2019-06-24T11:24:49.095Z [err]                                                 ^
                                        2019-06-24T11:24:49.095Z [err] ../src/RCSwitchNode.h:20:128: note: in definition of macro ‘switchOp3’
                                        2019-06-24T11:24:49.095Z [err]    #define switchOp3(p1, p2, p3) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2), (p3)); else thiz->rcswitch.switchOff((p1), (p2), (p3)); }
                                        2019-06-24T11:24:49.095Z [err]        ^~
                                        2019-06-24T11:24:49.095Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.095Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.095Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.095Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.095Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.095Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.095Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.095Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.095Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.095Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.097Z [err] In file included from ../src/RCSwitchNode.cpp:1:0:
                                        2019-06-24T11:24:49.097Z [err] ../src/RCSwitchNode.cpp:65:69: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.097Z [err]          switchOp3(*(*v8str), group->Int32Value(), devce->Int32Value());
                                        2019-06-24T11:24:49.097Z [err]        ^
                                        2019-06-24T11:24:49.097Z [err] ../src/RCSwitchNode.h:20:134: note: in definition of macro ‘switchOp3’
                                        2019-06-24T11:24:49.097Z [err]    #define switchOp3(p1, p2, p3) { if(switchOn) thiz->rcswitch.switchOn((p1), (p2), (p3)); else thiz->rcswitch.switchOff((p1), (p2), (p3)); }
                                        2019-06-24T11:24:49.097Z [err]        ^~
                                        2019-06-24T11:24:49.097Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.097Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.097Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.097Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.097Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.097Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.097Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.097Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.097Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.097Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.101Z [err] ../src/RCSwitchNode.cpp: In static member function ‘static void RCSwitchNode::New(const Nan::FunctionCallbackInfo<v8::Value>&)’:
                                        2019-06-24T11:24:49.101Z [err] ../src/RCSwitchNode.cpp:83:59: error: no matching function for call to ‘v8::Function::NewInstance(const int&, v8::Local<v8::Value> [0])’
                                        2019-06-24T11:24:49.101Z [err]      info.GetReturnValue().Set(cons->NewInstance(argc, argv));
                                        2019-06-24T11:24:49.101Z [err]                                                            ^
                                        2019-06-24T11:24:49.102Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
                                        2019-06-24T11:24:49.102Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.102Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.102Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.102Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
                                        2019-06-24T11:24:49.102Z [err]    V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
                                        2019-06-24T11:24:49.102Z [err]                                             ^~~~~~~~~~~
                                        2019-06-24T11:24:49.102Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
                                        2019-06-24T11:24:49.102Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
                                        2019-06-24T11:24:49.102Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
                                        2019-06-24T11:24:49.106Z [err] ../src/RCSwitchNode.cpp: In static member function ‘static void RCSwitchNode::EnableTransmit(const Nan::FunctionCallbackInfo<v8::Value>&)’:
                                        2019-06-24T11:24:49.106Z [err] ../src/RCSwitchNode.cpp:115:52: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.106Z [err]      obj->rcswitch.enableTransmit(pinNr->Int32Value());
                                        2019-06-24T11:24:49.106Z [err]                                                     ^
                                        2019-06-24T11:24:49.106Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.106Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.106Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.106Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.106Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.106Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.106Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.106Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.106Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.106Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.108Z [err] ../src/RCSwitchNode.cpp: In static member function ‘static void RCSwitchNode::SetProtocol(v8::Local<v8::String>, v8::Local<v8::Value>, const Nan::PropertyCallbackInfo<v8::Value>&)’:
                                        2019-06-24T11:24:49.108Z [err] ../src/RCSwitchNode.cpp:144:49: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                        2019-06-24T11:24:49.108Z [err]      obj->rcswitch.setProtocol(value->Int32Value());
                                        2019-06-24T11:24:49.108Z [err]                                                  ^
                                        2019-06-24T11:24:49.109Z [err] In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                        2019-06-24T11:24:49.109Z [err]                  from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                                        2019-06-24T11:24:49.109Z [err]                  from ../../nan/nan.h:54,
                                        2019-06-24T11:24:49.109Z [err]                  from ../src/RCSwitchNode.h:4,
                                        2019-06-24T11:24:49.109Z [err]                  from ../src/RCSwitchNode.cpp:1:
                                        2019-06-24T11:24:49.109Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                        2019-06-24T11:24:49.109Z [err]    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                                        2019-06-24T11:24:49.109Z [err]                                               ^
                                        2019-06-24T11:24:49.109Z [err] /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                        2019-06-24T11:24:49.109Z [err]    declarator __attribute__((deprecated(message)))
                                        2019-06-24T11:24:49.109Z [err]    ^~~~~~~~~~
                                        2019-06-24T11:24:49.564Z [out] rcswitch.target.mk:103: die Regel für Ziel „Release/obj.target/rcswitch/src/RCSwitchNode.o“ scheiterte
                                        2019-06-24T11:24:49.564Z [out] make: Verzeichnis „/opt/iobroker/iobroker-data/node-red/node_modules/rcswitch/build“ wird verlassen
                                        2019-06-24T11:24:49.565Z [err] make: *** [Release/obj.target/rcswitch/src/RCSwitchNode.o] Fehler 1
                                        2019-06-24T11:24:49.570Z [err] gyp
                                        2019-06-24T11:24:49.571Z [err]
                                        2019-06-24T11:24:49.571Z [err] ERR! build error
                                        2019-06-24T11:24:49.574Z [err] gyp ERR! stack Error: `make` failed with exit code: 2
                                        2019-06-24T11:24:49.577Z [err]  stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                                        2019-06-24T11:24:49.577Z [err] gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                                        2019-06-24T11:24:49.577Z [err] gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                        2019-06-24T11:24:49.577Z [err] gyp ERR! System Linux 4.14.34-v7+
                                        2019-06-24T11:24:49.577Z [err] gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                        2019-06-24T11:24:49.577Z [err] gyp ERR! cwd /opt/iobroker/iobroker-data/node-red/node_modules/rcswitch
                                        2019-06-24T11:24:49.578Z [err] gyp ERR! node -v
                                        2019-06-24T11:24:49.578Z [err]  v10.16.0
                                        2019-06-24T11:24:49.578Z [err] ERR!
                                        2019-06-24T11:24:49.578Z [err] node-gyp -v v3.8.0
                                        2019-06-24T11:24:49.579Z [err] not ok
                                        2019-06-24T11:24:52.559Z [err] npm
                                        2019-06-24T11:24:52.559Z [err]  WARN discord.js@11.5.1 requires a peer of bufferutil@^4.0.0 but none is installed. You must install peer dependencies yourself.
                                        2019-06-24T11:24:52.560Z [err]  discord.js@11.5.1 requires a peer of erlpack@discordapp/erlpack but none is installed. You must install peer dependencies yourself.
                                        2019-06-24T11:24:52.560Z [err] npm
                                        2019-06-24T11:24:52.560Z [err]  WARN
                                        2019-06-24T11:24:52.560Z [err]  discord.js@11.5.1 requires a peer of libsodium-wrappers@^0.7.3 but none is installed. You must install peer dependencies yourself.
                                        2019-06-24T11:24:52.560Z [err]  discord.js@11.5.1 requires a peer of node-opus@^0.2.7 but none is installed. You must install peer dependencies yourself.
                                        2019-06-24T11:24:52.561Z [err]  WARN
                                        2019-06-24T11:24:52.561Z [err]  discord.js@11.5.1 requires a peer of opusscript@^0.0.6 but none is installed. You must install peer dependencies yourself.
                                        2019-06-24T11:24:52.561Z [err] npm
                                        2019-06-24T11:24:52.561Z [err]  discord.js@11.5.1 requires a peer of sodium@^2.0.3 but none is installed. You must install peer dependencies yourself.
                                        2019-06-24T11:24:52.562Z [err]  discord.js@11.5.1 requires a peer of @discordjs/uws@^10.149.0 but none is installed. You must install peer dependencies yourself.
                                        2019-06-24T11:24:52.562Z [err] npm
                                        2019-06-24T11:24:52.562Z [err]  WARN
                                        2019-06-24T11:24:52.562Z [err]  node-red-project@0.0.1 No repository field.
                                        2019-06-24T11:24:52.563Z [err]  node-red-project@0.0.1 No license field.
                                        2019-06-24T11:24:53.205Z [err] npm ERR! code ELIFECYCLE
                                        2019-06-24T11:24:53.205Z [err] ERR! errno 1
                                        2019-06-24T11:24:53.206Z [err] npm
                                        2019-06-24T11:24:53.206Z [err]  ERR! rcswitch@0.3.1 install: `node-gyp rebuild`
                                        2019-06-24T11:24:53.206Z [err] npm ERR!
                                        2019-06-24T11:24:53.206Z [err]  Exit status 1
                                        2019-06-24T11:24:53.207Z [err] npm
                                        2019-06-24T11:24:53.207Z [err]  ERR!
                                        2019-06-24T11:24:53.207Z [err] npm ERR!
                                        2019-06-24T11:24:53.207Z [err]  Failed at the rcswitch@0.3.1 install script.
                                        2019-06-24T11:24:53.208Z [err] npm
                                        2019-06-24T11:24:53.208Z [err] ERR!
                                        2019-06-24T11:24:53.208Z [err]  This is probably not a problem with npm. There is likely additional logging output above.
                                        2019-06-24T11:24:53.794Z [err]
                                        2019-06-24T11:24:53.795Z [err] npm ERR! A complete log of this run can be found in:
                                        2019-06-24T11:24:53.795Z [err] ERR!     /home/iobroker/.npm/_logs/2019-06-24T11_24_53_226Z-debug.log
                                        2019-06-24T11:24:53.830Z rc=1
                                        • F fisch
                                          npm i --production
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          @fisch Das klingt mir schwer danach dass das Modul nicht mit Node 10 kompatibel ist.
