  4. [How-to] Node.js für ioBroker richtig updaten
    apollon77A
installationlinuxnodenode.jsnodejswindows
1.1k Beiträge 106 Kommentatoren 933.0k Aufrufe 112 Beobachtet
  • A Adnim
    @apollon77 Habe den Log Auszug wieder rausgesucht. Sah so aus. Rebuild hat Tausend Sachen angezeigt dazu habe ich keinen Log leider. Gefunzt hat es danach aber nicht.
    2019-06-15 08:52:07.738  - error: Caught by controller[0]: internal/modules/cjs/loader.js:805
    2019-06-15 08:52:07.738  - error: Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2019-06-15 08:52:07.738  - error: Caught by controller[0]:                  ^
    2019-06-15 08:52:07.738  - error: Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/iobroker.sql/node_modules/mmmagic/build/Release/magic.node'
    2019-06-15 08:52:07.738  - error: Caught by controller[0]: was compiled against a different Node.js version using
    2019-06-15 08:52:07.738  - error: Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
    2019-06-15 08:52:07.738  - error: Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
    2019-06-15 08:52:07.738  - error: Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2019-06-15 08:52:07.738  - error: Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18)
    2019-06-15 08:52:07.738  - error: Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
    2019-06-15 08:52:07.738  - error: Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    2019-06-15 08:52:07.738  - error: Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    2019-06-15 08:52:07.738  - error: Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:690:17)
    2019-06-15 08:52:07.739  - error: Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:25:18)
    2019-06-15 08:52:07.739  - error: Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/node_modules/mmmagic/lib/index.js:1:13)
    2019-06-15 08:52:07.739  - error: Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:776:30)
    2019-06-15 08:52:07.739  - error: Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
    2019-06-15 08:52:07.739  - error: Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
    2019-06-15 08:52:07.739  - error: host.iobroker1 instance system.adapter.sql.0 terminated with code 1 ()
    2019-06-15 08:52:07.739  - info: host.iobroker1 Restart adapter system.adapter.sql.0 because enabled
    Beim Update meines Slaves RPI gab es hinterher auch noch probleme. NPM Rebuild hat immer abgebrochen. Fehlermeldung(BSP das kam zu diversen Node Paketen):
    2019-06-15 09:45:31.633  - info: iobroker make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
    2019-06-15 09:45:31.638  - info: iobroker gyp
    2019-06-15 09:45:31.647  - info: iobroker  ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.42-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
    gyp ERR! node -v v10.16.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    NPM Rebuild LOG
    gyp ERR! build error
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! unix-dgram@0.2.3 install: `node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the unix-dgram@0.2.3 install script.
    Entweder reichte Manuelles nachinstallieren per npm i node-gyp prebuild im jeweiligen Ordner oder der ganze adapter musste runter. Unix Dgram habe ich laut der Anleitung auch nochmal drüber installiert.Es funzt alles trotzdem läuft NPM rebuild auch auf dem Slave nicht durch. Was ist da bei mir anders?
    apollon77A
    apollon77A
    #132
    @Adnim also vor allem zu Unix-dgram gibt es Infos im zweiten post. Bitte lesen!!
    • A Adnim
      Habe nochmal nen neuen Container gemacht mit Debian 9 . Dort alles gemäß https://www.iobroker.net/#de/documentation/install/linux.md installiert.
      Minimal Backup eingespielt. Da kommt ein ähnlicher beim Installieren der Adapter im Iobroker LOG
      iobroker 2019-06-16 10:04:36.852 info npm
      iobroker 2019-06-16 10:04:36.463 info
      iobroker 2019-06-16 10:04:36.463 info ERR! not ok
      iobroker 2019-06-16 10:04:36.463 info node-gyp -v v3.8.0gyp
      iobroker 2019-06-16 10:04:36.463 info node -v v10.16.0gyp ERR!
      iobroker 2019-06-16 10:04:36.463 info gyp ERR!
      Kann man nicht Node-GYP irgendwo zentral aktualisieren?
      apollon77A
      apollon77A
      #133
      @Adnim bitte vollständige Meldung Posten node-gyp ist nicht die ursache des Problems und komme mir nodejs mir und passt daher dazu wie es sein soll.
      Die Frage ist bei welcher nativen Library es Problem gibt. Die muss man prüfen und beheben.
        @Stabilostick
        root@IoBroker:/opt/iobroker# npm ls rpi-gpio
        iobroker.inst@2.0.3 /opt/iobroker
        └─┬ iobroker.rpi2@1.0.0
         └── rpi-gpio@1.0.0
        dann wäre ja die einfachste Lösung, ich deinstalliere den Adapter, da er momentan nicht mehr in Gebrauch ist.
        Dieser war noch aus der Raspberry Zeit und Multihostbetrieb.
        smartboartS
        smartboartS
        smartboart
        #134
        @crunchip Hallo, bekomme die GPIO auch nicht mehr zum laufen nach dem Update...
        Alles andere hat prima geklappt...
        hier der log zum Thema wie bekomme ich meine gpio inputs wieder eingelesen...
        rpi-gpio und epoll machen hier probleme...
        wegen der admin Rechte für die gpio ist das installationsfixer skript keine option...habs trotzdem laufen lassen. hat auch nix gebracht...
        pi@192.168.1.47's password:
        Linux ioBroker-RasPi 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l
        permitted by applicable law.
        Last login: Mon Jun 17 16:02:36 2019 from 192.168.1.27
        pi@ioBroker-RasPi:~ $ cd /opt/iobroker
        pi@ioBroker-RasPi:/opt/iobroker $ sudo iobroker stop
        Stopping iobroker controller daemon...
        iobroker controller daemon stopped.
        No "killall.sh" script found. Just stop.
        pi@ioBroker-RasPi:/opt/iobroker $ cd
        pi@ioBroker-RasPi:~ $ npm ls rpi-gpio
        /home/pi
        └── (empty)
        pi@ioBroker-RasPi:/opt/iobroker $ npm ls rpi-gpio
        iobroker.inst@1.1.2 /opt/iobroker
          └── UNMET OPTIONAL DEPENDENCY rpi-gpio@^1.0.0
        pi@ioBroker-RasPi:/opt/iobroker $ cd /opt/iobroker/iobroker.rpi2
        -bash: cd: /opt/iobroker/iobroker.rpi2: Datei oder Verzeichnis nicht gefunden
        pi@ioBroker-RasPi:/opt/iobroker $ cd /opt/iobroker/node_modulse/iobroker.rpi2
        -bash: cd: /opt/iobroker/node_modulse/iobroker.rpi2: Datei oder Verzeichnis nich                      t gefunden
        pi@ioBroker-RasPi:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.rpi2
        pi@ioBroker-RasPi:/opt/iobroker/node_modules/iobroker.rpi2 $ npm install rpi-gpi                      o
        > epoll@0.1.22 install /opt/iobroker/node_modules/iobroker.rpi2/node_modules/epo                      ll
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/iobroker.rpi2/node_modules/epoll/b                      uild“ wird betreten
          CXX(target) Release/obj.target/epoll/src/epoll.o
        In file included from ../../nan/nan.h:192:0,
                         from ../src/epoll.cc:15:
        ../../nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Lo                      cal<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribu                      te)’:
        ../../nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member nam                      ed ‘ForceSet’
           return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
        In file included from ../src/epoll.cc:15:0:
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v                      8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Is                      olate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value                      >*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarati                      ons]
                 v8::Isolate::GetCurrent(), target, func, argc, argv);
        In file included from ../src/epoll.cc:12:0:
        /home/pi/.node-gyp/10.16.0/include/node/node.h:177:50: note: declared here
                         NODE_EXTERN v8::Local<v8::Value> MakeCallback(
        /home/pi/.node-gyp/10.16.0/include/node/node.h:91:42: note: in definition of mac                      ro ‘NODE_DEPRECATED’
             __attribute__((deprecated(message))) declarator
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v                      8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Is                      olate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*                      )’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declaration                      s]
                 v8::Isolate::GetCurrent(), target, symbol, argc, argv);
        /home/pi/.node-gyp/10.16.0/include/node/node.h:170:50: note: declared here
        ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v                      8::Object>, const char*, int, v8::Local<v8::Value>*)’:
        ../../nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Is                      olate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is depr                      ecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                 v8::Isolate::GetCurrent(), target, method, argc, argv);
        /home/pi/.node-gyp/10.16.0/include/node/node.h:163:50: note: declared here
        ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v                      8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
        ../../nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Is                      olate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value                      >*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarati                      ons]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE E                      poll::Add(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:210:44: warning: ‘int32_t v8::Value::Int32Value() const’ is depr                      ecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Add(info[0]->Int32Value(), info[1]->Int32Value());
        In file included from /home/pi/.node-gyp/10.16.0/include/node/v8.h:26:0,
                         from ../src/epoll.cc:11:
        /home/pi/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
           V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
        /home/pi/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of                       macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../src/epoll.cc:210:67: warning: ‘int32_t v8::Value::Int32Value() const’ is depr                      ecated: Use maybe version [-Wdeprecated-declarations]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE E                      poll::Modify(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:230:47: warning: ‘int32_t v8::Value::Int32Value() const’ is depr                      ecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());
        ../src/epoll.cc:230:70: warning: ‘int32_t v8::Value::Int32Value() const’ is depr                      ecated: Use maybe version [-Wdeprecated-declarations]
        ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE E                      poll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/epoll.cc:247:47: warning: ‘int32_t v8::Value::Int32Value() const’ is depr                      ecated: Use maybe version [-Wdeprecated-declarations]
           int err = epoll->Remove(info[0]->Int32Value());
        epoll.target.mk:101: die Regel für Ziel „Release/obj.target/epoll/src/epoll.o“ s                      cheiterte
        make: *** [Release/obj.target/epoll/src/epoll.o] Fehler 1
        make: Verzeichnis „/opt/iobroker/node_modules/iobroker.rpi2/node_modules/epoll/b                      uild“ wird verlassen
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module                      s/node-gyp/lib/build.js:262:23)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces                      s.js:248:12)
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy                      p/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rpi2/node_modules/epoll
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR! epoll@0.1.22 install: `node-gyp rebuild`
        npm ERR!
        npm ERR! Failed at the epoll@0.1.22 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional log                      ging output above.
        npm ERR!     /home/pi/.npm/_logs/2019-06-17T14_19_01_263Z-debug.log
        pi@ioBroker-RasPi:/opt/iobroker/node_modules/iobroker.rpi2 $ sudo npm install rp                      i-gpio
        > node-gyp rebuild
        gyp WARN EACCES user "root" does not have permission to access the dev dir "/roo                      t/.node-gyp/10.16.0"
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/n                      ode_modules/iobroker.rpi2/node_modules/epoll/.node-gyp"
        gyp WARN install got an error, rolling back install
        gyp ERR! configure error
        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modul                      es/iobroker.rpi2/node_modules/epoll/.node-gyp'
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        npm ERR!     /root/.npm/_logs/2019-06-17T14_25_14_382Z-debug.log
        pi@ioBroker-RasPi:/opt/iobroker/node_modules/iobroker.rpi2 $ sudo npm install ep                      oll
        > epoll@0.1.22 install /opt/iobroker/node_modules/iobroker.rpi2/node_modules/rpi                      -gpio/node_modules/epoll
        > node-gyp rebuild
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/n                      ode_modules/iobroker.rpi2/node_modules/rpi-gpio/node_modules/epoll/.node-gyp"
        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modul                      es/iobroker.rpi2/node_modules/rpi-gpio/node_modules/epoll/.node-gyp'
        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rpi2/node_modules/rpi-gpio/node                      _modules/epoll
        gyp ERR! not ok
        > epoll@2.0.9 install /opt/iobroker/node_modules/iobroker.rpi2/node_modules/epol                      l
        > node-gyp rebuild
        gyp ERR! not ok
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 (node_modules/rpi-g                      pio/node_modules/epoll):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 install: `node-gyp                       rebuild`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        npm ERR! errno 1
        npm ERR! epoll@2.0.9 install: `node-gyp rebuild`
        npm ERR!
        npm ERR! Failed at the epoll@2.0.9 install script.
        npm ERR!     /root/.npm/_logs/2019-06-17T14_26_06_404Z-debug.log
        > node-gyp rebuild
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        npm ERR!     /root/.npm/_logs/2019-06-17T14_26_44_239Z-debug.log
        pi@ioBroker-RasPi:/opt/iobroker/node_modules/iobroker.rpi2 $ cd
        pi@ioBroker-RasPi:~ $ sudo reboot
        crunchipC StabilostickS 2 Antworten Letzte Antwort
        • smartboartS smartboart
          /home/pi
          └── (empty)
          > node-gyp rebuild
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          > node-gyp rebuild
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          > node-gyp rebuild
          gyp ERR! not ok
          > node-gyp rebuild
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          > node-gyp rebuild
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          crunchipC
          crunchipC
          Developer Global Moderator Most Active Forum Testing
          #135
          @smartboart mit diesen ganzen Rechteproblemen blick ich selbst nicht durch.
          Ich hatte bei mir eine alte Root Installation.
          Ich habe das bei mir nicht weiter verfolgt und den Adapter gelöscht, da er aktuell nicht in gebrauch ist.
          vllt kann ja @Stabilostick mal gucken
            smartboartS
            smartboartS
            smartboart
            #136
            @crunchip sind denn noch andere mit von der Partie bei Problemen mit dem Raspi und dem rpi Adapter bzw. dem einlesen der GPIO mit den Versionen Node.js
            node.js v10.16.0 NPM 6.9.0? Funktioniert das bei irgendwem oder ist das ein generelles Problem mit dem adapter und den Admin Rechten oder der kompatibilität der Abhängikeiten des Adapters?
              crunchipC
              crunchipC
              #137
              @smartboart das weiss ich leider nicht, bisher hab ich diesbezüglich nichts gelesen, das irgendwer damit Probleme hat.
              Du kannst folgendes machen.
              Den Adapter einmal löschen und neu installieren, damit die benötigten node module neu geladen werden.
              • MathiasJM
                MathiasJM
                MathiasJ
                #138
                Das wäre auch für mich interessant. Obwohl es bei mir wahrscheinlich nicht zum Tragen kommt.
                Ich habe IObroker komplett platt gemacht und neu installiert. Beim einspielen des Backups werden die Adapter sowieso neu installiert.
                IObroker auf dem NUC als VM.
                • StabilostickS Stabilostick
                  @Mic sagte in [How-to] Node.js für ioBroker richtig updaten:
                  Ah, Du bist einer welcher, der die Sicherheit seines Systems täglich aufs neue herausfordert, indem Du als root-User arbeitest. 😈
                  npm i acme-dns-01-cli
                  Hattest Du das im ioBroker-Ordner (z.B. /opt/iobroker) ausgeführt?
                  Wegen root-User: Versuche es ggf. einmal mit dem ioBroker-Fixer, der einige Berechtigungen und Einstellungen korrigiert:
                  curl -sL https://iobroker.net/fix.sh | bash -
                  MicM
                  MicM
                  Mic
                  #139
                  @Stabilostick sagte in [How-to] Node.js für ioBroker richtig updaten:
                  Danke für Deine Antwort. ☺
                  Hat nichts gebracht, ich werde wohl mal gelegentlich eine Neuinstallation durchlaufen lassen. Geht ja relativ fix, außerhalt der Wartezeit nach Einspielen ioBroker-Backup.
                  • MicM Mic
                    crunchipC
                    crunchipC
                    #140
                    @Mic mich hat er auch schon bekehrt😉
                      /home/pi
                      └── (empty)
                      > node-gyp rebuild
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      > node-gyp rebuild
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      > node-gyp rebuild
                      gyp ERR! not ok
                      > node-gyp rebuild
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      > node-gyp rebuild
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      StabilostickS
                      StabilostickS
                      Stabilostick
                      schrieb am zuletzt editiert von Stabilostick
                      #141
                      @smartboart
                      Hi, bin gerade nicht am Rechner. rpi-gpio hat als Abhängigkeit epoll. Ich meine, dass bei epoll eine neuere Version für Node 10 benötigt wird. Gibt es nicht ein rpi-gpio@2.0.0 oder neuer? Der rpi2-Adapter müsste auch mit einem neueren rpi-gpio umgehen können.
                      apollon77A MathiasJM 2 Antworten Letzte Antwort
                        @smartboart
                        apollon77A
                        apollon77A
                        #142
                        @Stabilostick macht doch mal ein GitHub issue auf?‘
                        • WinniW
                          WinniW
                          Winni
                          #143
                          Wollte es nur nochmal erwähnt haben, der sma-em Adapter funktioniert nicht mit node 10.x, was sehr schade ist, weil dieser Adapter extrem nützlich ist, sofern man ein sma engerymeter hat, siehe:
                          https://forum.iobroker.net/topic/23121/problem-mit-iobroker-sma-em-adapter-nach-node-update
                          • WinniW Winni
                            apollon77A
                            apollon77A
                            #144
                            @Winni dann GitHub issue auf machen. Mit dem Link am besten ;-)
                              @smartboart
                              MathiasJM
                              MathiasJM
                              MathiasJ
                              #145
                              @Stabilostick
                              ich habe gerade rein geschaut.
                              Mit rpi2 funktionieren alle meine GPIO's
                              Meine IObroker-Installation ist auf dem neuesten Stand.
                              • MathiasJM MathiasJ
                                @Stabilostick
                                smartboartS
                                smartboartS
                                smartboart
                                schrieb am zuletzt editiert von smartboart
                                #146
                                @MathiasJ hi, danke für deine Überprüfung... wie hast du das denn getestet? Hängen da Taster oder Relais dranne und werden die weiterhin angesteuert und eingelesen. oder hast du dir nur die states angeschaut ob sie angelegt werden? Das alleine sagt nämlich nichts aus...
                                  MathiasJM
                                  MathiasJM
                                  MathiasJ
                                  #147
                                  @smartboart
                                  Ich habe mich erst mal nur die states angeschaut.
                                  Die Tests folgen dann am Wochenende.
                                  Ich muß sowieso nur mit Relais arbeiten, weil der Slave als Bewässerung draußen am Balkon arbeiten soll.
                                  Gruß,
                                  Mathias
                                  • B
                                    B
                                    bommel_030
                                    #148
                                    Ich habe nach der Anleitung hier aktualisiert und habe folgenden Fehler bekommen:
                                    /home/bommel/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                                    ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/epoll.cc:247:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                    In file included from /home/bommel/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                    /home/bommel/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
                                    epoll.target.mk:101: recipe for target 'Release/obj.target/epoll/src/epoll.o' failed
                                    make: *** [Release/obj.target/epoll/src/epoll.o] Error 1
                                    make: Leaving directory '/opt/iobroker/node_modules/epoll/build'
                                    gyp ERR! System Linux 4.4.174-rockchip64
                                    gyp ERR! cwd /opt/iobroker/node_modules/epoll
                                    gyp ERR! not ok
                                    npm ERR! errno 1
                                    npm ERR!
                                    bommel@rock64:/opt/iobroker$
                                    Mehr konnte ich von dem Log nicht retten. Leider oder vielleicht zum Glück gab es kurz danach einen längeren Stromausfall. Danach ist der ioBroker normal hochgefahren und läuft bis jetzt ohne Fehler.
                                    Vielleicht hat einer der Fachleute ja nen Tip ob man das weiter untersuchen sollte oder einfach laufen lassen kann.
                                    • B bommel_030
                                      gyp ERR! not ok
                                      npm ERR! errno 1
                                      npm ERR!
                                      apollon77A
                                      apollon77A
                                      #149
                                      @bommel_030 Kann es sein das epoll eine Abhängigkeit vom rpi2 Adapter ist? Wenn ja muss der eine Aktualisierung bekommen.
                                      B crunchipC 2 Antworten Letzte Antwort
                                      • apollon77A apollon77
                                        B
                                        B
                                        bommel_030
                                        #150
                                        @apollon77
                                        Gute Frage... Der ist zwar noch installiert aber nicht mehr aktiv weil iobroker mittlerweile auf nem rock64 werkelt. Wenn ich den starte wird er so oder so meckern.
                                        Werde ihn Mal deinstallieren. Soll ich npm rebuild dann nochmal durchlaufen lassen? Wenn er ohne Fehler abschließt müsste es ja an dem Adapter gelegen haben.
                                          crunchipC
                                          crunchipC
                                          #151
                                          @apollon77 ja
                                          84.0k
