  4. [Aufruf] Neuer Adapter ioBroker.pi-hole
adaptertestpi-hole
97 Beiträge 16 Kommentatoren 26.7k Aufrufe 25 Beobachtet
  • SBorgS Offline
    SBorgS Offline
    SBorg
    Nice + Danke 👍
    Daten kommen, aber wenn ich den PI stoppen möchte:
    pi-hole.0	2019-05-25 22:20:37.349	info	cleaned everything up...
    pi-hole.0	2019-05-25 22:20:37.347	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    pi-hole.0	2019-05-25 22:20:37.347	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.pi-hole/main.js:28:29)
    pi-hole.0	2019-05-25 22:20:37.347	error	TypeError: Cannot read property 'val' of null
    pi-hole.0	2019-05-25 22:20:37.346	error	uncaught exception: Cannot read property 'val' of null
    Habe den Adapter nochmal neu gestartet, da ich mir nicht sicher war, ob der API-Token gleich übernommen wird.
    LG SBorg ( SBorg auf GitHub)
    unltdnetworxU 1 Antwort Letzte Antwort
    • SBorgS SBorg
      Nice + Danke 👍
      unltdnetworxU Offline
      unltdnetworx
      @SBorg
      Danke für dein Feedback. Ich hab eine Verdacht. Trage bitte beim Stoppen eine Zahl ein. 0 für dauerhaft oder eine höhere Zahl für die Sekunden zum Pausieren.
      Werde ich demnächst beheben. Also dauerhaft stoppen, falls keine Zahl darin steht.
      Gruß, Michael
      Weitere Infos im Profil.
      Wenn euch der Beitrag weitergeholfen hat, könnt ihr die Bewertung rechts unten im Beitrag nutzen.
      • SBorgS Offline
        SBorgS Offline
        SBorg
        schrieb am zuletzt editiert von SBorg
        Falls du darauf abzielst
        pi-hole.0	2019-05-25 22:35:39.940	error	uncaught exception: Cannot read property 'val' of null
        Der Fehler bleibt trotzdem. Habe es mal mit 0 und 30 probiert, Fehler wie oben.
        Edit Ist schon spät.... Kaum macht man es richtig geht es auch ^^
        • SBorgS SBorg
          unltdnetworx
          @SBorg
          Aufgrund Zeitmangel habe ich die vorübergehende Deaktivierung herausgenommen. Jetzt klappt es, aber nur dauerhaft.
          Fix kommt bald.
          Gruß, Michael
          • unltdnetworxU unltdnetworx
            @SBorg
            Fix kommt bald.
            SBorgS Offline
            SBorgS Offline
            SBorg
            @unltdnetworx sagte in [Aufruf] Neuer Adapter ioBroker.pi-hole:
            Aufgrund Zeitmangel...
            Es ist Wochenende und IMO hängt kein Leben davon ab... ;)
            Sieht aber so gut aus. Gibt die API ev. auch noch her ob eine neue Version, WEB oder FTL verfügbar ist, oder habe ich den/die Datenpunkt(e) schlichtweg übersehen?
            • SBorgS SBorg
              unltdnetworx
              @SBorg
              Im Moment sind das alle Werte, die verfügbar sind. Plus noch nicht implementierte experimentelle Werte ohne genauere Informationen dazu.
              Also leider nein.
              Gruß, Michael
              • SBorgS Offline
                SBorgS Offline
                SBorg
                Danke und schade.
                Ich frage nur mal (sonst schreibe ich mir bei Gelegenheit ein kleines Bash-Skript dafür) wie es bei dir mit parsen von Webseiten aussieht, bzw. ob du es dir später vorstellen kannst.
                PI_Hole-IP/admin/index.php:
                Nach <!-- Version Infos --> oder <div class="pull-right hidden-xs hidden-sm"> kommen die Versions-Infos. Die könnte man speichern oder einfach nach Update (denke ich, bei mir steht gerade keins an) durchsuchen.
                unltdnetworxU P 3 Antworten Letzte Antwort
                • SBorgS SBorg
                  Danke und schade.
                  unltdnetworx
                  @SBorg
                  Parsen ist halt Aufwand. Gehen würde es und wäre mein Plan gewesen, falls es keine API gegeben hätte. Werde mal schauen.
                  Gruß, Michael
                    stephan61
                    Hallo habe den adapter installiert
                    was muss ich beim anmelde bildschirm eingeben ?
                    Gruß Stephan
                    BBTownB unltdnetworxU 2 Antworten Letzte Antwort
                    • S stephan61
                      Gruß Stephan
                      BBTownB Offline
                      BBTownB Offline
                      BBTown
                      schrieb am zuletzt editiert von BBTown
                      @stephan61 du wirst sicherlich den Token nicht wie gefordert eingetragen haben
                      • S stephan61
                        Gruß Stephan
                        unltdnetworx
                        @stephan61
                        Das Fenster sieht nach normaler ioBroker Anmeldung aus. Session vllt. abgelaufen?
                        Gruß, Michael
                        • SBorgS SBorg
                          Danke und schade.
                          unltdnetworx
                          @SBorg
                          Nochmal zu den Updates. Das wäre in der Tat nice to have, Aber grundsätzlich macht pi-hole die Updates doch einmal pro Woche automatisch, oder?
                          Gruß, Michael
                          • SBorgS Offline
                            SBorgS Offline
                            SBorg
                            @unltdnetworx
                            Nicht das ich wüsste!? Bspw. die Domain-Blacklist etc. schon, aber z.B. FTL musst du doch per Hand pihole -up updaten, da hier auch gelegentlich Abfragen auf der Console zu beantworten sind?
                            Ich stelle bei mir (bin halt ITler^^) gerade so langsam alles um, damit ich alles zentral an einem Ort habe und nicht immer an zig Stellen nachschauen muss. Extra wegen mir brauchst du das aber nicht implementieren, bekomme ich auch mit einem kleinen "Hack" geregelt 😀
                            • SBorgS SBorg
                              @unltdnetworx
                              unltdnetworx
                              @SBorg
                              Nein, nein. Sehe das genauso. Sollte schon ganzheitlich sein.
                              Gruß, Michael
                                SevenUp
                                Anfänger-Frage: Was muss ich noch nachinstallieren/aktualisieren?
                                host.iobrokervm
                                2019-05-26 16:29:11.096
                                info
                                Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                iobroker
                                2019-05-26 16:29:10.961
                                info
                                exit 0
                                iobroker
                                2019-05-26 16:29:10.905
                                info
                                found 57 vulnerabilities (40 low, 2 moderate, 15 high) run `npm audit fix` to fix them, or `npm audit` for details
                                iobroker
                                2019-05-26 16:29:10.902
                                info
                                + iobroker.pi-hole@0.0.1updated 1 package and audited 6873 packages in 17.128s
                                iobroker
                                2019-05-26 16:29:10.896
                                info
                                svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
                                iobroker
                                2019-05-26 16:29:10.892
                                info
                                WARN
                                iobroker
                                2019-05-26 16:29:10.890
                                info
                                npm
                                iobroker
                                2019-05-26 16:29:10.888
                                info
                                bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                                iobroker
                                2019-05-26 16:29:10.886
                                info
                                WARN
                                iobroker
                                2019-05-26 16:29:10.884
                                info
                                iobroker
                                2019-05-26 16:29:10.882
                                info
                                npm
                                iobroker
                                2019-05-26 16:28:52.917
                                info
                                npm install https://github.com/unltdnetworx/ioBroker.pi-hole/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                                iobroker
                                2019-05-26 16:28:52.475
                                info
                                iobroker
                                2019-05-26 16:28:52.125
                                info
                                url "https://github.com/unltdnetworx/ioBroker.pi-hole" --debug
                                • S SevenUp
                                  host.iobrokervm
                                  info
                                  iobroker
                                  info
                                  exit 0
                                  iobroker
                                  info
                                  iobroker
                                  info
                                  iobroker
                                  info
                                  iobroker
                                  info
                                  WARN
                                  iobroker
                                  info
                                  npm
                                  iobroker
                                  info
                                  iobroker
                                  info
                                  WARN
                                  iobroker
                                  info
                                  iobroker
                                  info
                                  npm
                                  iobroker
                                  info
                                  iobroker
                                  info
                                  iobroker
                                  info
                                  unltdnetworx
                                  @SevenUp
                                  Ich schau mir das die Tage mal an. Evtl. fehlt eine Abhängigkeit bei der Installation.
                                  Gruß, Michael
                                  • SBorgS SBorg
                                    @unltdnetworx
                                    unltdnetworx
                                    @SBorg
                                    Hab mich nochmal etwas eingelesen. Es gibt momentan eine neue RESTful API, die die alte Version ersetzen wird. Diese neue API wird voraussichtlich alle gewünschten Funktionen beinhalten, ist aber noch wip, also work in progress und weder dokumentiert noch fertig. Dazu ist auch die Development Version von pi-hole nötig. Dann ist auch das Pflegen der Black- und Whitelist, Updates etc. möglich.
                                    Von daher werde ich mich noch um die zeitgesteuerte Deaktivierung des Filters kümmern und mit Einführung der neuen Version auch auch an einer neue Version des Adapters arbeiten. Eine umständliche und Ressourcen beanspruchende Lösung für Updates finde ich daher nicht mehr zweckmäßig noch einzuarbeiten.
                                    Ich hoffe die fehlende Funktion in Kürze nachzureichen und hoffe dann auf Rückmeldungen zur Stabilität, damit der Adapter in die Stable-Version gehen kann. Version 1.0.0 wäre dann eine klare Abgrenzung zur neuen Version.
                                    Gruß, Michael
                                    • S SevenUp
                                      host.iobrokervm
                                      info
                                      iobroker
                                      info
                                      exit 0
                                      iobroker
                                      info
                                      iobroker
                                      info
                                      iobroker
                                      info
                                      iobroker
                                      info
                                      WARN
                                      iobroker
                                      info
                                      npm
                                      iobroker
                                      info
                                      iobroker
                                      info
                                      WARN
                                      iobroker
                                      info
                                      iobroker
                                      info
                                      npm
                                      iobroker
                                      info
                                      iobroker
                                      info
                                      iobroker
                                      info
                                      unltdnetworx
                                      @SevenUp
                                      Probier bitte jetzt nochmal zu installieren. Hatte eine zu installierende Abhängigkeit übersehen.
                                      Gruß, Michael
                                        @SBorg
                                        SBorgS Offline
                                        SBorgS Offline
                                        SBorg
                                        Dito. Wenn es in der neuen API dann eh integriert ist, ergibt das zum jetzigen Zeitpunkt auch keinerlei Sinn mehr. Ist ja auch nicht so, dass die Funktion absolut über lebenswichtig wäre :)
                                        • unltdnetworxU Offline
                                          unltdnetworx
                                          Neue Version 0.1.0 auf Github veröffentlicht. Werde auch Antrag auf Aufnahme im latest-Repo stellen.
                                          Jetzt funktioniert auch die zeitlich befristete Deaktivierung. Der Deaktivieren-Button wird nicht mehr angelegt. Bei Änderung des Wertes in "Deaktivieren" wird der Filter sofort für die angegebene Zeit deaktiviert. Bitte 0 für dauerhaft eintragen oder einen Ganzzahlenwert für eine befristete Deaktivierung in Sekunden.
                                          Bitte um Rückmeldung, ob alles stabil läuft, damit auch Stable-Repo folgen kann.
                                          Vielen Dank.
                                          Gruß, Michael
