  3. Entwicklung
  4. ZigBee CC253x - neue/unbekannte Geräte - ab 0.10.x
adapter
304 Beiträge 42 Kommentatoren 70.6k Aufrufe 29 Beobachtet
  • M MrLee
    @arteck
    Versionsnummer ist immernoch 0.10.3?
    Nach github update kommt bei mir:
    host.iobroker_host	2019-05-22 12:25:12.913	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker_host	2019-05-22 12:25:12.913	error	instance system.adapter.zigbee.0 terminated with code 1 ()
    Caught	2019-05-22 12:25:12.913	error	by controller[0]: at Object.<anonymous> (/usr/local/iobroker/node_modules/iobroker.zigbee/main.js:20:23)
    Caught	2019-05-22 12:25:12.913	error	by controller[0]: at require (internal/module.js:20:19)
    Caught	2019-05-22 12:25:12.913	error	by controller[0]: at Module.require (module.js:504:17)
    Caught	2019-05-22 12:25:12.913	error	by controller[0]: at Function.Module._load (module.js:445:3)
    Caught	2019-05-22 12:25:12.913	error	by controller[0]: at tryModuleLoad (module.js:453:12)
    Caught	2019-05-22 12:25:12.913	error	by controller[0]: at Module.load (module.js:494:32)
    Caught	2019-05-22 12:25:12.912	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    Caught	2019-05-22 12:25:12.912	error	by controller[0]: at Module._compile (module.js:549:28)
    Caught	2019-05-22 12:25:12.912	error	by controller[0]: at Object.runInThisContext (vm.js:97:10)
    Caught	2019-05-22 12:25:12.912	error	by controller[0]: at createScript (vm.js:56:10)
    Caught	2019-05-22 12:25:12.912	error	by controller[0]: SyntaxError: Unexpected token {
    Caught	2019-05-22 12:25:12.912	error	by controller[0]: ^
    Caught	2019-05-22 12:25:12.912	error	by controller[0]: {
    Caught	2019-05-22 12:25:12.911	error	by controller[0]: /usr/local/iobroker/node_modules/iobroker.zigbee/lib/devstates.js:2940
    host.iobroker_host	2019-05-22 12:25:12.124	info	instance system.adapter.zigbee.0 started with pid 14047
    host.iobroker_host	2019-05-22 12:25:09.691	info	instance system.adapter.zigbee.0 terminated with code 0 (OK)
    Bin erstmal wieder zurück...
    bis denne & Danke
    Mr.Lee
    arteckA Offline
    arteckA Offline
    arteck
    #150
    @MrLee ahh komma vergessen... jetzt
    • arteckA arteck
      @Muchul @MrLee so einmal mein Repo installieren zum Testen : https://github.com/arteck/ioBroker.zigbee
      @chrisblu dein RWM ist noch nicht im Converter.. kein plan was der liefert.. solltest vielleicht erst um Aufnahme bitten im Projekt https://github.com/Koenkk/zigbee-shepherd-converters
      chrisblu
      #151
      @arteck: Danke, ich versuchs mal da.
      Viele Grüße, Christian
        Muchul
        #152
        @arteck ,
        vielen Dank. Es funktioniert alles.
        Super.
        • ? Offline
          #153
          Gibt es keine Anleitung wie die devstates.js erweitert wird?
          im Zigbee-shepherd sieht das in devices.js so aus:
          zigbeeModel: ['lumi.curtain'],
          model: 'ZNCLDJ11LM',
          description: 'Aqara curtain motor',
          supports: 'open, close, stop, position',
          vendor: 'Xiaomi',
          fromZigbee: [
          fz.ZNCLDJ11LM_curtain_genAnalogOutput_change, fz.ZNCLDJ11LM_curtain_genAnalogOutput_report,
          fz.ignore_closuresWindowCovering_change, fz.closuresWindowCovering_report,
          fz.ignore_basic_change, fz.ignore_basic_report,
          toZigbee: [tz.ZNCLDJ11LM_control],
          Vielleicht so ähnlich?
          vendor: 'Xiaomi',
          models: ['lumi.curtain'],
          icon: 'img/curtain.png',
          // TODO:
          states: [states.open, states.close, states.stop, states.position],
          Bild im /IMG Verzeicnis ist drin
          im Admin Tool steuerbar:
          dev-selector zigbee.0.00158d0002ec2804
          ep-selector 1
          cid-selector 6
          cmd-type-selector funktional
          dev-send-btn click
            vendor: 'Xiaomi',
            fromZigbee: [
            vendor: 'Xiaomi',
            // TODO:
            ep-selector 1
            cid-selector 6
            dev-send-btn click
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #154
            @J_Paul
            Du musst da leider mehr tun. Die States.open, close, stop und position existieren bisher nicht, die müssen auch noch erzeugt werden.
            Dazu musst du schauen in welchen mapping-einträgen der zigbee-shepherd die Daten sendet / erwartet, um diese dann an den iobroker weiter zu geben.
            A.
            • ? Offline
              #155
              Wenn ich da irgendetwas forschen soll, sag Bescheid. Kenne das vom shelly Adapter...
              frank2604F 1 Antwort Letzte Antwort
              • arteckA arteck
                Heiko BleyH Offline
                Heiko BleyH Offline
                Heiko Bley
                #156
                @arteck said in ZigBee CC253x Adapter - nur neue/unbekannte Geräte - ab Adapter 0.10.x:
                Ich hatte gesehen, Du hattest auch den Kontakt mit aufgenommen.
                Habe Dein Repo gerade mal installiert, und habe nun folgende Fehler im Log.
                Aber funktionieren tut er:
                zigbee.0	2019-05-23 17:38:35.073	warn	Dev 0x00158d0001cc71e2 CSW_ADUROLIGHT not configured yet, will try again in latest 300 sec
                zigbee.0	2019-05-23 17:38:22.072	error	Zigbee publish to '0x00158d0001cc71e2', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 240. MAC transaction expired.
                Vielleicht sagt Dir das was, oder kannst mir helfen was ich machen sollte.
                Vielen Dank.
                Heiko
                  Severinius
                  #157
                  @arteck brauchst Du von mir noch Informationen bzgl. der SmartThings Sensoren. Habe ja alle vorhanden Infos in den anderen Post gepackt.
                  Vielen Dank im voraus,
                  Hanno
                  • Heiko BleyH Heiko Bley
                    Vielen Dank.
                    Heiko
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #158
                    @Heiko-Bley das ist kein Fehler.. der muss sich die Konfiguration ziehen.. manachmal dauert es ein weilchen..
                    Heiko BleyH 1 Antwort Letzte Antwort
                    • arteckA arteck
                      Heiko BleyH Offline
                      Heiko BleyH Offline
                      Heiko Bley
                      #159
                      Hallo @arteck ,
                      OK, aber wenn ich in der Instanz auf Info klicke kommt dieser Fehler:
                      zigbee.0	2019-05-24 20:41:13.963	error	Zigbee publish to '0x00158d0001cc71e2', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 240. MAC transaction expired.
                      und die Meldung:
                      zigbee.0	2019-05-24 20:40:26.961	warn	Dev 0x00158d0001cc71e2 CSW_ADUROLIGHT not configured yet, will try again in latest 300 sec
                      unter Objekte habe ich folgendes stehen:
                      00158d0001cc71e2	Briefkasten
                      battery	Battery percent &nbsp;	edit
                      contact	state Contact event zigbee.0/admin	ok	2019-05-23 17:35:09.794	2019-05-23 17:35:09.794	false
                      link_quality	state Link quality zigbee.0/admin	ok	2019-05-24 14:58:35.267	2019-05-24 14:58:35.267	107
                      opened	state Is open zigbee.0/admin	ok	2019-05-23 17:35:09.795	2019-05-23 17:35:09.795	true
                      voltage	Battery voltage &nbsp;
                      ist leider auch immer noch da, habe extra mal etwas länger gewartet.
                      Er funktioniert aber sonst wunderbar.
                      Und nochmals vielen Dank, das ihr sowas in eurer Freiszeit für uns alle macht.
                      Heiko
                      • C Offline
                        chrisblu
                        #160
                        Hallo Zusammen,
                        ich würde gerne noch mal auf die Bitron Rauchmelder zurückkommen. Ich habe mir unter github durchgelesen, wie man neue Geräte in den Converter einfügt, komme da aber nicht weiter.
                        Auf meine Frage unter den Issues hat sich leider niemand gemeldet:
                        https://github.com/Koenkk/zigbee-shepherd-converters/issues/213#issuecomment-495244126.
                        Daher hier noch mal die Frage, ob es hier jemanden gibt, der mich irgendwie leiten könnte, diese Dinger in den Shepherd-Converter einzufügen. Ich kann rumprobieren, habe aber nicht genug Kenntnisse, den Konverter selber zu erstellen.
                        Ich kann auch gerne einen Rauchmelder zum probieren zur Verfügung stellen.
                        Viele Grüße,
                        Christian
                        • arteckA arteck
                          MrLee
                          #161
                          MoiN!
                          Soory, jetzt gerade erst zu gekommen...
                          Installiert, upload...läuft.
                          Leider wird das Gerät immernoch als unbekannt erkannt. Keine States.
                          Mr.Lee
                          • M MrLee
                            MoiN!
                            Mr.Lee
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #162
                            @MrLee dann weiter versuchen.. es muss ein name in der Kachel stehen
                            • S Severinius
                              Hanno
                              Severinius
                              #163
                              @arteck
                              Ist generell eine Integrierung der SmartThings Sensoren geplant?
                              Müsste mich andernfalls nach anderen Sensoren umschauen.
                              Aktuell werden meine wichtigen Türen (Haustür etc.) damit überwacht. Im Zuge der Umstellung auf ioBroker (weg von SmartThings) habe ich mein Gateway bereits abgebaut und daher werden diese Sensoren nicht mehr überwacht!
                              Würde mich über eine Antwort freuen!
                              Vielen Dank,
                              Hanno
                                MrLee
                                schrieb am zuletzt editiert von MrLee
                                #164
                                Hi!
                                @arteck : Wenn Du mal dabei bist, bitte füge Support für die LTC014 hinzu
                                https://www.amazon.de/Philips-Panelleuchte-Dimmschalter-kompatibel-Energieklasse/dp/B07FXT4XH6/ref=sr_1_fkmr0_2?__mk_de_DE=ÅMÅŽÕÑ&keywords=osram%2Baurelle&qid=1559746318&s=gateway&sr=8-2-fkmr0&th=1
                                Osram Aurelle LTC014
                                https://github.com/Koenkk/zigbee-shepherd-converters/issues/473
                                Anpassung da identisch zur Runden Lampe(LTC001):
                                        vendor: 'Philips',
                                        models: ['LTC001', 'LTC014'],
                                        icon: 'img/philips_white_ambiance_being.png',
                                        states: lightStatesWithColortemp,
                                        syncStates: [sync.brightness],
                                Getestet und läuft soweit.
                                Danke!
                                Mr.Lee
                                • arteckA arteck
                                  MrLee
                                  #165
                                  @arteck
                                  Moin!
                                  Danke, Name steht drin...gibt aber trotzdem:
                                  zigbee.0	2019-06-05 16:56:20.949	error	Unknown device model FB56-ZCW20FB1.2 emit event devChange with data:{"cid":"genBasic","data":{"swBuildId":"1.0.0","hwVersion":1}}
                                  zigbee.0	2019-06-05 16:56:20.948	error	Unknown device model FB56-ZCW20FB1.2 emit event devChange with data:{"cid":"genBasic","data":{"swBuildId":"1.0.0","hwVersion":1}}
                                  zigbee.0	2019-06-05 16:56:20.945	error	Unknown device model FB56-ZCW20FB1.2 emit event readRsp with data:{"cid":"genBasic","data":{"swBuildId":"1.0.0","hwVersion":1}}
                                    frank2604F Offline
                                    frank2604F Offline
                                    frank2604
                                    #166
                                    @J_Paul
                                    Hi, interpretiere ich das richtig, dass Ihr an der Einbindung des Aqara Curtain Motor dran sein? Ich habe für unseren Neubau auch schon 3 Stück hier liegen und möchte das Aqara Gateway gerne vermeiden.
                                    Danke und Grüße
                                    Frank
                                    Intel NUC8 i3, Proxmox, VM Ubuntu, ioBroker
                                    Philips HUE, Homematic CCU3, Zigbee, Yamaha MusicCast, Vorwerk ...
                                    ? 2 Antworten Letzte Antwort
                                    • frank2604F frank2604
                                      @J_Paul
                                      Danke und Grüße
                                      Frank
                                      #167
                                      @frank2604
                                      Hallo Frank,
                                      diese Frage könnten andere besser beantworten. Technisch ist es wohl möglich die Geräte einzubinden. Ich selbst bin nicht in der Lage die nötigen Einträge in die devstates.js einzufügen, hatte nur angeboten unterstützend mitzuwirken, zu probieren/testen. Bei GB habe ich ein Gateway im Warenkorb und versuche es grad vorsichtig als Nachtlicht zu verkaufen. Alternative wäre der Dooya Motor mit einem Shelly2.5 wenn man bei iobroker bleiben möchte.
                                      • J Offline
                                        Julian
                                        schrieb am zuletzt editiert von Julian
                                        #168
                                        Modellbezeichnung: LED1733G7, TRÅDFRI WS 1912 21633
                                        String: zigbee.0 new dev 0x14b457fffe4dfe0d 18466 TRADFRI bulb E14 WS opal 600lm
                                        Funktionen: an/aus, dimmen, Farbtemperatur ändern
                                        Link zum Produkt:
                                        https://www.ikea.com/de/de/p/tradfri-led-leuchtmittel-e14-600-lm-kabellos-dimmbar-weissspektrum-opalweiss-80408585/
                                        • J Julian
                                          Link zum Produkt:
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #169
                                          @Julian check mal mein Repo
