  4. [Neuer Adapter] LinkedDevices
adapter
464 Beiträge 68 Kommentatoren 193.5k Aufrufe 57 Beobachtet
    Ergebnis:
    linkeddevices.0	2019-05-09 19:20:56.711	debug	[createLinkedObject] keep custom settings '{"linkeddevices.0":{"enabled":true,"parentId":"hm-rpc.0.NEQ1234567.1.STATE","isLinked":false}}' for linkedObject 'linkeddevices.0.Bad.Licht.Aktor'
    linkeddevices.0	2019-05-09 19:20:56.710	debug	[createLinkedObject] using custom name 'Bad Lampe' for: 'linkeddevices.0.Bad.Licht.Aktor' (parentObj: 'hm-rpc.0.NEQ1234567.1.STATE')
    linkeddevices.0	2019-05-09 19:20:56.622	silly	[resetAllLinkedObjectsStatus] linkedObjects status {"linkeddevices.0.Bad.Licht.Taste_kurz":false,"linkeddevices.0.Bad.Fenster":false,"linkeddevices.0.Bad.Licht.Aktor":false,"linkeddevices.0.Bad.HKT.M
    linkeddevices.0	2019-05-09 19:20:56.622	debug	[resetAllLinkedObjectsStatus] 'dicLinkedObjectsStatus' items count: 6
    linkeddevices.0	2019-05-09 19:20:56.622	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.HKT.Auto_Mode'
    linkeddevices.0	2019-05-09 19:20:56.606	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.HKT.Control_Mode'
    linkeddevices.0	2019-05-09 19:20:56.606	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.HKT.Manu_Sollwert'
    linkeddevices.0	2019-05-09 19:20:56.606	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.Licht.Aktor'
    linkeddevices.0	2019-05-09 19:20:56.606	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.Fenster'
    linkeddevices.0	2019-05-09 19:20:56.591	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.Licht.Taste_kurz'
    linkeddevices.0	2019-05-09 19:20:56.575	info	[initialObjects] started...
    linkeddevices.0	2019-05-09 19:20:56.575	debug	[onReady] notDeleteDeadLinkedObjects: 'false'
    linkeddevices.0	2019-05-09 19:20:56.544	info	starting. Version 0.0.1 in C:/Program Files/ioBroker/node_modules/iobroker.linkeddevices, node: v8.15.1
    linkeddevices.0	2019-05-09 19:20:56.544	debug	statesDB connected
    linkeddevices.0	2019-05-09 19:20:56.528	debug	objectDB connected
    ScroungerS
    ScroungerS
    Scrounger
    Ok hängt genau an der gleichen Stelle und schlauer werd ich daraus auch nicht.
    Versuch mal nen 'iobroker update linkeddevices' durchzuführen und adapter neu starten. Wenn das nicht hilft, dann mal iobroker komplett neu starten.
    • ScroungerS Scrounger
      paul53P
      paul53P
      @Scrounger sagte:
      Gemacht und anschließend PC neu gestartet: Keine Änderung.
      ScroungerS 1 Antwort Letzte Antwort
        @Scrounger sagte:
        ScroungerS
        ScroungerS
        Scrounger
        ok dann lösch mal die Verlinkung mit 'hm-rpc.0.NEQ1234567.1.STATE', wenn er weiter da hängen bleibt, die nächste Verlinkung usw.
        Stell mir mal die raw daten des 'hm-rpc.0.NEQ1234567.1.STATE' zur Verfügung.
          paul53P
          paul53P
          @Scrounger Raw data
            "_id": "hm-rpc.0.NEQ1234567.1.STATE",
            "type": "state",
            "common": {
              "name": "NEQ1234567.1.STATE",
              "role": "switch",
              "type": "boolean",
              "read": true,
              "write": true,
              "desc": "Manuell erzeugt",
              "def": false
            "native": {},
            "acl": {
              "object": 1638,
              "state": 1638
            "from": "system.adapter.admin.1",
            "user": "system.user.admin",
            "ts": 1557243244184
          Log nach Deaktivierung Link für STATE
          linkeddevices.0	2019-05-09 20:07:49.471	debug	[createLinkedObject] keep custom settings '{"linkeddevices.0":{"enabled":true,"parentId":"hm-rpc.0.NEQ1234567.1.AUTO_MODE","isLinked":false}}' for linkedObject 'linkeddevices.0.Bad.HKT.Auto_Mode'
          linkeddevices.0	2019-05-09 20:07:49.470	debug	[createLinkedObject] using custom name 'Bad HKT Auto' for: 'linkeddevices.0.Bad.HKT.Auto_Mode' (parentObj: 'hm-rpc.0.NEQ1234567.1.AUTO_MODE')
          linkeddevices.0	2019-05-09 20:07:49.371	silly	[resetAllLinkedObjectsStatus] linkedObjects status {"linkeddevices.0.Bad.Licht.Taste_kurz":false,"linkeddevices.0.Bad.Fenster":false,"linkeddevices.0.Bad.Licht.Aktor":false,"linkeddevices.0.Bad.HKT.M
          linkeddevices.0	2019-05-09 20:07:49.371	debug	[resetAllLinkedObjectsStatus] 'dicLinkedObjectsStatus' items count: 6
          linkeddevices.0	2019-05-09 20:07:49.371	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.HKT.Auto_Mode'
          linkeddevices.0	2019-05-09 20:07:49.371	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.HKT.Control_Mode'
          linkeddevices.0	2019-05-09 20:07:49.371	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.HKT.Manu_Sollwert'
          linkeddevices.0	2019-05-09 20:07:49.371	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.Licht.Aktor'
          linkeddevices.0	2019-05-09 20:07:49.355	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.Fenster'
          linkeddevices.0	2019-05-09 20:07:49.355	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.Licht.Taste_kurz'
          linkeddevices.0	2019-05-09 20:07:49.339	info	[initialObjects] started...
          • ScroungerS
            ScroungerS
            Scrounger
            Mhhh, ok dann muss ich da mal noch bissle mehr error handling einbauen. Bei mir funktioniert des einwandfrei.
            Hast du inzwischen mal auf die Node v8.16.0 geupdatet, kann mir zwar nicht vorstellen das es daran liegt, aber sicher ist sicher.
              paul53P
              paul53P
              @Scrounger Habe mal den Adapter deinstalliert, wieder installiert, Links angelegt, ioBroker (PC) neu gestartet: Es werden keine Datenpunkte unter linkeddevices.0 erstellt. Log:
              linkeddevices.0	2019-05-09 21:01:38.864	debug	[createLinkedObject] using custom name 'Bad HKT Auto' for: 'linkeddevices.0.Bad.HKT.Auto' (parentObj: 'hm-rpc.0.NEQ1234567.1.AUTO_MODE')
              linkeddevices.0	2019-05-09 21:01:38.763	silly	[resetAllLinkedObjectsStatus] linkedObjects status {}
              linkeddevices.0	2019-05-09 21:01:38.763	debug	[resetAllLinkedObjectsStatus] 'dicLinkedObjectsStatus' items count: 0
              linkeddevices.0	2019-05-09 21:01:38.747	info	[initialObjects] started...
              linkeddevices.0	2019-05-09 21:01:38.747	debug	[onReady] notDeleteDeadLinkedObjects: 'true'
              linkeddevices.0	2019-05-09 21:01:38.732	info	starting. Version 0.0.1 in C:/Program Files/ioBroker/node_modules/iobroker.linkeddevices, node: v8.15.1
                ScroungerS
                ScroungerS
                Scrounger
                schrieb am zuletzt editiert von Scrounger
                So hab nochmal bissle was angepasst:
                • timestamp changes werden berücksichtig
                • weiteres debugging und error logging
                Bitte den aktuellen branch ziehen
                paul53P 3 Antworten Letzte Antwort
                  paul53P
                  paul53P
                  @Scrounger sagte:
                  Gemacht und es funktioniert auch, wenn nur der Zeitstempel aktualisiert wird 👍
                    paul53P
                    paul53P
                    @Scrounger schrieb:
                    } else if (tsDifference > 250) {
                    Weshalb > 250 ms ? HomeMatic PRESS_CONT aktualisiert den Zeitstempel alle ca. 250 ms. Damit kann es ein Problem geben.
                    Was hälst Du davon, anstelle von state.val, state.ack und state.ts für das Vermeiden einer Dauerschleife state.from auszuwerten ? Etwa so:
                    async onStateChange(id, state) {
                           if (state && state.from != 'system.adapter.' + this.namespace) {
                    		// parentObject 'state' hat sich geändert -> linkedObject 'state' ändern
                      paul53P
                      paul53P
                      @Scrounger Habe mal folgende Änderung an main.js vorgenommen und erfolgreich getestet:
                               let changedValue = state.val;
                               if (this.dicLinkedParentObjects && id in this.dicLinkedParentObjects) {
                                  let linkedObjId = this.dicLinkedParentObjects[id];
                                  // let linkedObj = await this.getForeignObjectAsync(linkedObjId);
                                  // var linkedObjState = await this.getForeignStateAsync(linkedObjId);
                                  // if (linkedObj && linkedObj.common && linkedObj.common.custom && linkedObj.common.custom[this.namespace] && linkedObj.common.custom[this.namespace].conversion) {
                                  // 	this.log.debug(`[onStateChange] linkedObject state changed ${linkedObj.common.custom[this.namespace].conversion}`)
                                  // 	changedValue = eval(`${changedValue}${linkedObj.common.custom[this.namespace].conversion}`)
                                  // 	this.log.debug(`[onStateChange] parentObject state changed ${changedValue}`)
                      	    await this.setForeignStateChanged(linkedObjId, changedValue, state.ack);
                      	    this.log.debug(`[onStateChange] parentObject state '${id}' changed to '${state.val}' (ack = ${state.ack}) --> set linkedObject state '${linkedObjId}'`)
                               // linkedObject 'state' hat sich geändert -> parentObject 'state' ändern
                               else if (this.dicLinkedObjectsStatus && id in this.dicLinkedObjectsStatus) {
                                  // @ts-ignore
                                  let parentObjId = Object.keys(this.dicLinkedParentObjects).find(key => this.dicLinkedParentObjects[key] === id);
                                  // let parentObjState = await this.getForeignStateAsync(parentObjId);
                                  // let linkedObj = await this.getForeignObjectAsync(id);
                                  // 	let conversion = this.reverseMathString(linkedObj.common.custom[this.namespace].conversion)
                                  // 	this.log.debug(`[onStateChange] linkedObject state changed ${conversion}`)
                                  // 	changedValue = eval(`${changedValue}${linkedObj.common.custom[this.namespace].conversion}*-1`)
                                  // 	this.log.debug(`[onStateChange] linkedObject state changed ${changedValue}`)
                                  // 'custom.isLinked = true'
                                  if (this.dicLinkedObjectsStatus[id] === true) {
                      		await this.setForeignStateChangedAsync(parentObjId, changedValue, state.ack);
                      		this.log.debug(`[onStateChange] linkedObject state '${id}' changed to '${state.val}' (ack = ${state.ack}) --> set parentObject state '${parentObjId}'`)
                        ScroungerS
                        ScroungerS
                        Scrounger
                        @paul53 sagte in [Neuer Adapter] LinkedDevices:
                        Die Entprellzeit von 250ms hab ich gewählt, weil der timestamp ja nur bei Buttons oder zyklischen Statusmeldung geändert wird. Das ein Button innerhalb von 250ms zweimal gedrückt wird erscheint mir unrealistisch, genauso das zyklische Statusmeldungen <250ms überhaupt sinnvoll sind.
                        Damit hab ich es auch schon mal probiert, werd aber nochmal testen.
                        Werd ich testen.
                                      // @ts-ignore
                          ScroungerS
                          ScroungerS
                          Scrounger
                          Fast perfekt ;)
                          Damit Timestamp Änderungen am linkedObject auch übertragen werden, hab ich es noch etwas modifiziert, 'setForeignStateChangedAsync' in 'setForeignStateAsync' geändert:
                          				await this.setForeignStateAsync(linkedObjId, changedValue, state.ack);
                          				// @ts-ignore
                          					await this.setForeignStateAsync(parentObjId, changedValue, state.ack);
                          Wenn deine Test erfolgreich sind, dann pack ich es nachher in den branch
                            Fast perfekt ;)
                            				// @ts-ignore
                            paul53P
                            paul53P
                            @Scrounger sagte:
                            Habe die Änderungen übernommen und anschließend alle möglichen Richtungen getestet: Es sieht gut aus !
                            • ScroungerS
                              ScroungerS
                              Scrounger
                              Änderung ist hochgealden, bitte den neusten branch verwenden.
                              Hab noch das logging bissle erweitert, damit man auch sieht welche state changes erfolgt sind
                              @paul53 : Danke für den Input!
                                paul53P
                                paul53P
                                @Scrounger Weshalb erfolgt die Konvertierung nur in eine Richtung (parent --> linked) bei "read only" ?
                                Eine Änderung in linked schreibt trotzdem in parent; allerdings ohne Konvertierung.
                                Übrigens: Eval ist böse
                                			convertedValue = convertedValue.toFixed(obj.common.custom[this.namespace].maxDecimal)
                                erzeugt einen String !!
                                  ScroungerS
                                  ScroungerS
                                  Scrounger
                                  Folgender Gedanke bei readonly Datenpunkte. Nehmen wir z.B. einen Energiecounter mit Einheit Watt. Im linkedObject will ich aber kWh als Einheit haben. Dann läuft das wie folgt ab: Hardware -> parentObject [Wh] -> linkedObject [kWh]
                                  Ich weiß wenn man per skript in das linkedObject schreibt, dann wird es nicht zurück gewandelt, aber man soll ja auch nicht per skript in read datenpunkte schreiben. Wie siehst du das?
                                  Hab noch für read & write / write datenpunkte Umrechnung eingefügt. Damit ist z.B. möglich eine Hue-Lampe "bri" mit 0-254 (=parentObject) in ein linkedObject das als Eingabe 0-100% aktzeptiert umzuwandeln. Bitte aktuellen branch ziehen hab das nochmal grad was dran geändert.
                                  Oh ok, wusste ich nicht, werd ich dann überarbeiten. Weiß jemand was man da alternativ benutzen kann?
                                    paul53P
                                    paul53P
                                    @Scrounger sagte:
                                    Wie siehst du das?
                                    Man sollte sich auf eine lineare Wandlung beschränken, die immer so dargestellt werden kann:
                                    linked = a + b * parent
                                    wobei zwei Eigabefelder erforderlich sind: Eines für a und eines für b. Bei Eingabe von b kann man auch ein führendes "/" erlauben und daraus eine Division 1/b machen.
                                    Diese Vorgehensweise hat den Vorteil, dass man die Konvertierung auch von linked nach parent machen kann und man somit nicht auf "read only" Datenpunkte beschränkt ist:
                                    parent = (linked - a) / b
                                      @Scrounger sagte:
                                      Wie siehst du das?
                                      ScroungerS
                                      ScroungerS
                                      Scrounger
                                      Das ist im aktuellen Master schon enthalten, deshalb geht ja z.B. das:
                                      Würde dann aber die Flexibilität nehmen und die usabilty ist dann auch nicht mehr so schön. Ich persönlich finde es sehr nice wenn man einfach eine Formel eingeben kann. Muss ich mal drüber nachdenken wie man das noch anders / besser implementieren kann.
                                      Zunächst muss ich mir ne alternative für eval() suchen.
                                      Wie kann ich denn im adapter ne dependency auf z.B. diese library setzen - math.js - so das die lib automatisch mit installiert wird.
                                      Und wie bekomm ich diese dann in die main.js?
                                        paul53P
                                        paul53P
                                        @Scrounger sagte:
                                        Das ist nur für die Anwender von Vorteil, die mit Formeln umgehen können und hat den Nachteil, dass die umgekehrte Richtung nicht einfach ermittelt werden kann. @Scrounger sagte in [Neuer Adapter] LinkedDevices:
                                        weil das linkedObjekt ja ein Spiegelbild des parentObjects ist und immer den gleichen Zustand wie das parentObjekt abbilden muss.
                                        • SBorgS
                                          SBorgS
                                          SBorg
                                          Bisher soweit 👍
                                          Eben wollte ich dann einen gelinkten in Node-RED auswählen, nur da erscheint er nicht in der Auswahlliste (bei Blockly bspw. schon). Trägt man ihn per Hand ein funktioniert er aber problemlos.
                                          LG SBorg ( SBorg auf GitHub)
                                          83.8k
