  4. [Aufruf] ZigBee CC253x Adapter Version 0.10.x
zigbee0.10.xadapter
373 Beiträge 27 Kommentatoren 87.7k Aufrufe 23 Beobachtet
  • M Muchul
    @Asgothian
    hast du Gelegenheit gehabt dir das anzuschauen?
    @Muchul sagte in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
    @Asgothian
    Ach ja
    npm list > npmlist.txt
    konnte ich nur mit sudo su durchführen und gibt in Putty folgendes aus:
    sener@iobroker:/opt/iobroker$ sudo su
    [sudo] Passwort für sener:
    root@iobroker:/opt/iobroker# npm list > npmlist.txt
    npm ERR! extraneous: binrpc@3.3.1 /opt/iobroker/node_modules/binrpc
    npm ERR! extraneous: dropbox-v2-api@2.1.22 /opt/iobroker/node_modules/dropbox-v2-api
    npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
    npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
    npm ERR! extraneous: homematic-xmlrpc@1.0.2 /opt/iobroker/node_modules/homematic-xmlrpc
    npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
    npm ERR! extraneous: netmask@1.0.6 /opt/iobroker/node_modules/netmask
    npm ERR! extraneous: node-pre-gyp@0.12.0 /opt/iobroker/node_modules/node-pre-gyp
    npm ERR! extraneous: node-ssdp@3.3.0 /opt/iobroker/node_modules/node-ssdp
    npm ERR! extraneous: node-telegram-bot-api@0.30.0 /opt/iobroker/node_modules/node-telegram-bot-api
    npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
    npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
    npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
    npm ERR! extraneous: targz@1.0.1 /opt/iobroker/node_modules/targz
    npm ERR! extraneous: typescript@2.9.2 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@0.0.4 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: zcl-id@0.4.0 /opt/iobroker/node_modules/zcl-id
    npm ERR! extraneous: zive@0.2.2 /opt/iobroker/node_modules/zive
    npm ERR! peer dep missing: stream-browserify@*, required by bl@0.7.0
    und hier die Datei:
    npmlist.txt
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #290
    @Muchul Angesehen habe ich es mir. Es sollte eigentlich auch Gehen. Mir ist jedenfalls nichts negatives mehr aufgefallen.
    Ich hatte dich aber auch so verstanden das
    • die Meldungen weg waren
    • die BM auch funktionieren
    A.
    • AsgothianA Asgothian
      A.
      Muchul
      #291
      @Asgothian
      Die Bwm funktionieren.
      Nur die Meldungen kommen jedes Mal, wenn sie angesprochen werden.
      • MyzerATM Offline
        MyzerATM Offline
        MyzerAT
        #292
        hab schon wieder ein Problem zu vermelden, einer meiner Thernmostate zeigt keine Batteriewerte mehr an und wenn sich das Stellrad änder bleibt es dennoch auf 0%
        lg Rudi
        Node 22.23.0
        Nodejs 22.23.0
        npm 10.9.8
        js-controller 7.2.2
        • MyzerATM MyzerAT
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #293
          @MyzerAT wenn du in der Objektansicht bei dem thermostat auf das i drückst, kommt dann eine Fehlermeldung im Log ?
          A.
          MyzerATM 1 Antwort Letzte Antwort
            A.
            MyzerATM Offline
            MyzerATM Offline
            MyzerAT
            #294
            @Asgothian
            nein
            lg Rudi
            Node 22.23.0
            Nodejs 22.23.0
            npm 10.9.8
            js-controller 7.2.2
            • MyzerATM MyzerAT
              @Asgothian
              nein
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #295
              @MyzerAT dann sollte der thermostat sauber weiter angebunden sein. Am besten du beobachtest das weiter.
              A.
                Denzel1994
                schrieb am zuletzt editiert von Denzel1994
                #296
                ich mische mich hier auch mal kurz ein.
                Ich habe derzeit zwei "Probleme":
                1. Wenn ich Gruppen nutze (bspw. 4 Birnen unter der Gruppe Deckenlampe) und dann den PowerState der Gruppe auf "true" setze, dann ändern sich die PowerStates der individuellen Birnen in den Objekten nicht. Aber alle Birnen werden entsprechend eingeschaltet. Ist das so gewollt?
                2. Ich bekomme für den IKEA TRADFRI Signalverstärker in der Netzwerkkarte kein Bild angezeigt. In der Geräteübersicht ist jedoch eins da.
                  Bildschirmfoto 2019-04-15 um 01.29.39.png Bildschirmfoto 2019-04-15 um 01.29.14.png
                zigbee-shepherd version: 2.6.3 rev 20190223
                Adapter version: 0.10.3
                node: v8.15.0
                Danke im Voraus
                Lars
                • R Offline
                  root_
                  #297
                  Ist bei mir auch so aber nur im Safari. Im Firefox wird es richtig angezeigt.
                    southparkler
                    schrieb am zuletzt editiert von southparkler
                    #298
                    Hab seit einige Tagen folgende Meldungen im Log, es ist ein Hue Dimmer (hab nur einen in Betrieb) und alle Osram Plugs betroffen.
                    zigbee.0	2019-04-17 23:13:34.248	warn	Dev 0x7cb03eaa00acab3d Plug 01 not configured yet, will try again in latest 300 sec
                    zigbee.0	2019-04-17 23:13:34.233	warn	Dev 0x7cb03eaa00ae5d26 Plug 01 not configured yet, will try again in latest 300 sec
                    zigbee.0	2019-04-17 23:13:34.216	warn	Dev 0x7cb03eaa00af20e8 Plug 01 not configured yet, will try again in latest 300 sec
                    zigbee.0	2019-04-17 23:13:34.201	warn	Dev 0x84182600000e8c2e Plug 01 not configured yet, will try again in latest 300 sec
                    zigbee.0	2019-04-17 23:13:34.163	warn	Dev 0x001788010329aee5 SML001 not configured yet, will try again in latest 300 sec
                    zigbee.0	2019-04-17 23:13:34.140	warn	Dev 0x0017880104f6ca17 RWL021 not configured yet, will try again in latest 300 sec
                    Neu anlernen der Geräte hilft nicht.
                    Die Netzwerk Karte ist auch rot und zeigt nichts mehr an, der Rest läuft aber (diverse Aqara Sensoren, Hue Bewegungsmelder...)
                    Kann mir jmd. sagen an was das liegen könnte?
                    Hab seit Gestern wieder die aktuelle Version vom Github, Probleme bestehen aber schon bissle länger.
                    iBroker läuft auf Raspi 3B über Gbit Lan
                    Geräte:
                    Licht: Hue Lampen mit Bridge, Osram Smart Plug, Tradfri Lampen über Hue, Yeelight Lampen
                    Sensoren: Xiaomi Aqara Sensoren (Zigbee Stick)
                    Heizung: Fritz!D…
                    • R root_
                      Denzel1994
                      #299
                      @root_ said in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
                      Ah hast recht. In Chrome und Firefox wird es korrekt angezeigt, nur in Safari nicht.
                      • S southparkler
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #300
                        @southparkler hast du versucht die Netzwerkkarte mit dem button in der Ecke zu aktualisieren ? Wenn ja, kannst du mal einen Screenshot zeigen ?
                          southparkler
                          #301
                          @Asgothian
                          Anbei der Screenshot. Beim Aktualisieren über den Button tut sich leider nichts. !
                          Geräte:
                          Heizung: Fritz!D…
                          • S southparkler
                            @Asgothian
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #302
                            @southparkler
                            Danke für den Screenshot. Kannst du bitte schauen ob es im entsprechenden Zeitraum Einträge im Log gibt ?
                            • F Offline
                              Findus
                              schrieb am zuletzt editiert von Findus
                              #303
                              Ich habe immer wieder die Situation, dass eingebundene Geräte plötzlich nicht mehr reagieren. z.B. TradFi remote oder Lumi Sensor. In der Netzwerkkarte werden diese Gerate rot und haben keine Verbindung mehr. Ich weiss nicht wie ich sie wieder beleben kann? Frage mich auch weshalb sie die Verbindung verlieren. Der Lumi Sensor steht 15 cm entfernt vom Coordinator (verbindet sich aber mit einer Lampe die weit entfernt ist)
                              W 1 Antwort Letzte Antwort
                                @southparkler
                                southparkler
                                #304
                                @Asgothian
                                Hab jetzt auch den Stick und Raspi ne zeitlang stromlos gemacht, keine Veränderung.
                                Anbei ein Log, erst Zigbee Neustart und dann den Button Netzwerk Karte aktualisieren gedrückt. Kommen jeweils die Warnmeldung die ich schon gepostet hab, kann aber auch Zufall sein. Die Meldungen müllen die Log Datei ja gerade zu ein.
                                Geräte:
                                Heizung: Fritz!D…
                                • F Findus
                                  W Online
                                  W Online
                                  Wildbill
                                  #305
                                  @Findus sagte in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
                                  das Problem hatte ich leider auch ab einer bestimmten Netzwerkgröße. Wiederbeleben ging bei mir aber meist, indem ich hartnäckig immer mal wieder Befehle ausgelöst hatte. Was auch half, war, die Remote mal an eine andere Stelle zu tragen, so dass sie andere Router sieht. Letztendlich wirst Du das Problem aber nicht endgültig lösen können, befürchte ich. Scheint, dass CC2531 halt irgendwann an seine Grenzen kommt. @Asgothian hatte es glaub weiter oben mal geschrieben. Ist halt nur ein Sniffer, der per Firmware zu einer anderen Aufgabe gezwungen wird...
                                  Gruss, Jürgen
                                    DaBa6
                                    schrieb am zuletzt editiert von DaBa6
                                    #306
                                    Moin zusammen,
                                    ich habe meinen Cc2531 neu geflasht, da Lampen, etc oftmals nicht geschaltet wurden. Nun läuft auf dem Stick die neuste Firmware - soweit auch problemlos für die ersten 24 Stunden.
                                    Der Zigbee-Adapter (Version 10.3) springt dann von grün auf gelb und hat keine Verbindung mehr zum Stick und beim öffnen des Adapters erscheint die Meldung „You need save and run adapter before pairing!“. Auch ein Neustart des Adapters oder Soft-Reset hilft nicht.
                                    Das einzige was hilft, ist den Stick aus dem Raspberry Pi zu ziehen und wieder einzustecken. Nach anschließendem Neustart des Zigbee-Adapters funktioniert es wieder für etwas mehr als einen Tag.
                                    Woran könnte das liegen?
                                      Kueppert
                                      #307
                                      ich habe gerade, weil ich ein Batterie-Skript schreiben wollte, festgestellt, dass bei allen meinen batteriebetriebenen Geräten unter Batterie 100% steht, egal wieviel Volt wirklich übrig sind O.o
                                      Habe den Adapter 0.10.3 aktuell laufen...jemand ne Idee wie ich das behebe?
                                      Danke und Grüße, Thorsten
                                      AsgothianA arteckA 2 Antworten Letzte Antwort
                                      • H Offline
                                        Hanni1312
                                        #308
                                        Guten Abend,
                                        ich würde gerne wissen welche Kombination aus Firmware für die Sticks und Adapter Version von IOBroker gerade empfohlen ist. Es verlieren bei mir immer mehr Geräte die Verbindung. Auf die Karte aus dem Adapter gebe ich nicht wirklich was aber auch da wird es immer schlimmer.
                                        Ich habe gerade folgendes Setup! Anmerkung 2019-04-28 223153.jpg Anmerkung 2019-04-28 223002.jpg
                                        Auf dem CC2530 befindet sich die Version vom 29.01.2019.
                                        Wie immer vielen Dank für eure Hilfe!
                                        • H Hanni1312
                                          Guten Abend,
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #309
                                          @Hanni1312
                                          Bitte bring mal den Stick auf die aktuelle Firmware von GitHub (ich empfehle immer die max-Stability version)
                                          A.
                                          H 1 Antwort Letzte Antwort
