  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • simatecS Online
    simatecS Online
    simatec
    #1971
    @steimi
    Poste mal bitte einen Log, damit ich schauen kann, wo der Fehler liegt.
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
      steimi
      #1972
      habe leider kein Log, da die Instanz nur auf Info stand. habe sie mal auf Debug gestellt und ein Backup gemacht.
      backitup.0 2019-04-12 19:07:20.440 debug [minimal/mysql] MySql File deleted!
      backitup.0 2019-04-12 19:07:20.434 debug [minimal] exec: done
      backitup.0 2019-04-12 19:07:20.430 debug [minimal/mysql] done
      backitup.0 2019-04-12 19:07:19.703 debug [minimal] exec: done
      backitup.0 2019-04-12 19:07:19.695 debug [minimal/history] backitup.0.history.html
      backitup.0 2019-04-12 19:07:19.384 debug [minimal/pushover] done
      backitup.0 2019-04-12 19:07:19.342 debug [minimal/clean] done
      backitup.0 2019-04-12 19:07:19.328 debug [minimal/cifs] [IGNORED] Path "/mnt/usb1/iobroker_backitup/iobroker_std" not found
      backitup.0 2019-04-12 19:07:19.299 debug [minimal/zigbee] done
      backitup.0 2019-04-12 19:07:19.132 debug [minimal/mysql] done
      backitup.0 2019-04-12 19:07:17.180 debug [minimal/minimal] done
      backitup.0 2019-04-12 19:07:17.135 debug [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_04_12-19_06_57_backupiobroker.tar.gz
      backitup.0 2019-04-12 19:04:26.073 info [total] backup was activated at 03:00 every 7 day(s)
      backitup.0 2019-04-12 19:04:26.059 info [ccu] backup was activated at 01:30 every 3 day(s)
      backitup.0 2019-04-12 19:04:26.011 info [minimal] backup was activated at 02:00 every 1 day(s)
      backitup.0 2019-04-12 19:04:25.762 info starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.1
      backitup.0 2019-04-12 19:04:25.599 debug statesDB connected
      backitup.0 2019-04-12 19:04:24.038 debug objectDB connected
      • S steimi
        simatecS Online
        simatecS Online
        simatec
        #1973
        @steimi
        Dein USB Pfad wird nicht gefunden.
        Prüfe mal bitte, ob der Pfad stimmt und der Stick eingehängt ist
        • simatecS simatec
          @steimi
          #1974
          @simatec sagte in Adapter: iobroker.backitup (stable Release):
          Genau
          @steimi sagte in Adapter: iobroker.backitup (stable Release):
          Aufgrund eines Fehler war das entsprechende Laufwerk nach einem Neustart des Rechners nicht gemountet.
          Die Frage lautet daher warum bekommt er in diesem Fall keine Nachricht
            Genau
            simatecS Online
            simatecS Online
            simatec
            #1975
            @Homoran
            Upps stimmt Rainer ...
            Hab ich überlesen.
            Wie man im Log sieht, wird der Fehler ignoriert.
            Ich schaue mal, dass ich das aktiviere und bei fehlenden Stick ein Fehler ausgegeben wird
            • simatecS simatec
              @Homoran
              Hab ich überlesen.
              steimi
              #1976
              @simatec danke schonmal
              • MathiasJM Offline
                MathiasJM Offline
                MathiasJ
                schrieb am zuletzt editiert von MathiasJ
                #1977
                Guten morgen,
                Kann mir jemand erzählen, welche Einstellungen ich machen muß, damit die Backups auf der Fritzbox landen?
                Einen neuen Benutzer und das Paßwort habe ich schon erstellt, auch 4 Ordner.
                Übergeordnet= Backup
                Dann Homematic, IObroker und Komplett.
                ur die Backups wollen nicht auf die fritzbox.
                Gruß,
                Mathias
                IObroker auf dem NUC als VM.
                simatecS K 2 Antworten Letzte Antwort
                • MathiasJM MathiasJ
                  Guten morgen,
                  Gruß,
                  Mathias
                  simatecS Online
                  simatecS Online
                  simatec
                  #1978
                  @MathiasJ
                  Als erstes müsste man wissen, was du genau machen willst und einen Auszug aus deiner Config dazu
                    Guten morgen,
                    Gruß,
                    Mathias
                    Kueppert
                    schrieb am zuletzt editiert von Kueppert
                    #1979
                    @MathiasJ ich hatte das gleiche Problem. Du musst in der Fritz das Anmelden per Benutzer und Passwort einstellen. Ich hatte vorher die Anmeldung nur mit Passwort eingestellt, da ging nix...
                    MathiasJM 1 Antwort Letzte Antwort
                    • K Kueppert
                      MathiasJM Offline
                      MathiasJM Offline
                      MathiasJ
                      #1980
                      Das weiß ich.
                      Ich habe da einen neuen Benutzer angelegt, der auf den Ordner backup zugreifen kann.
                      Ich habe aber statt der IP Adresse fritz.box eingegeben. Als Ordner dann:
                      fritz.nas/Name der HDD/backup/Homematic........../IObroker......./Komplett
                      Gruß,
                      Mathias
                        Das weiß ich.
                        Gruß,
                        Mathias
                        simatecS Online
                        simatecS Online
                        simatec
                        #1981
                        @MathiasJ
                        Nochmal die frage ... was hast du vor?
                        CIFS oder FTP?
                        Bitte mache genauere Angaben und poste die Logausgaben
                        • MathiasJM Offline
                          MathiasJM Offline
                          MathiasJ
                          #1982
                          CIFS habe ich vor.
                          Log kann ich nicht jetzt posten, weil ich keinen Zugriff auf die Installation habe.
                          Ich habe das gleiche angegeben als würde ich ein Backup auf meiner Synology speichern. Da gehts ja auch.
                          Anstatt die IP Adresse der NAS habe ich die IP der entfernten FB angegeben.
                          Eine weitere Frage, was mir aufgefallen ist, die Zigbee-Datenbank wird auch als backup gespeichert.
                          Nur wie bekomme ich ein restore dafür hin, sollte ich das brauchen.
                            CIFS habe ich vor.
                            simatecS Online
                            simatecS Online
                            simatec
                            #1983
                            @MathiasJ
                            Auch über die Restore Funktion von backitup
                            • MathiasJM Offline
                              MathiasJM Offline
                              MathiasJ
                              #1984
                              Dankeschön.
                              Ich werde es dann mit der FB versuchen, wenn ich auf der Installation bin.
                                klassisch
                                #1985
                                History Backup möglich?
                                mache derzeit noch ein rsync-Backup der History-Dateien. Diese liegen auf einer anderen Platte als ioBroker.
                                Da ich nicht genau weiß, wann der History einen neues Tagesverzeichnis eröffnen, mache ich ein rsync über die letzten 3 Tage.
                                Kann man so etwas auch mit dem Backitup-Adapter machen?
                                • simatecS Online
                                  simatecS Online
                                  simatec
                                  #1986
                                  Aktuell wird über Backitup keine History gesichert.
                                  Kann man aber sicherlich umsetzen.
                                  • simatecS simatec
                                    klassisch
                                    #1987
                                    Dann habe ich zumindest nichts übersehen
                                    Das wäre natürlich klasse. Ich will ja vom OPi auf Windows wechseln und da müßte ich dann einen Ersatz für mein shellscript mit rsync suchen/basteln. Mein altes ioBroker-backup shellscript würde ich aufgeben, weil es jetzt ja den Backitup-Adapter gibt.
                                    Und Backup der History-Daten auf ein NAS ist sicher ein häufiger use case.
                                    Wie gesagt mache ich derzeit kurz nach Mitternacht rsync über die letzte 3 Tage. Aus irgendwelchen Gründen haben manche Dateien im jeweiligen history-Verzeichnis noch Uhrzeiten, die nach Mitternacht sind. Mit der Methode, die letzten 3 Tage zu rsyncen, bekomme ich die alle übertragen.
                                    • MathiasJM Offline
                                      MathiasJM Offline
                                      MathiasJ
                                      #1988
                                      Das wäre keine schlechte Idee.
                                      ich möchte meine Histroy-Dateien aber auf einem USB-Stick speichern. Ich denke 32GB reichen da voll aus, weil meine Installation nicht so groß ist.
                                      Das wäre natürlich super wenn die jeden Tag, wenn ein Tagesordner geschlossen wird, mit auf der NAS landen.
                                      • hanssH Offline
                                        hanssH Offline
                                        hanss
                                        #1989
                                        ich habe gerade versucht, die mySQL Datenbank von der Sicherung zurückzuspielen (Version 1.1.4)
                                        Die Sicherungsdateien werden lokal u. über FTP gefunden, aber im LOG steht nur:
                                        backitup.0 2019-04-17 20:18:04.261 debug Test: mysql_2019_04_15-04_18_13_backupiobroker.tar.gz
                                        backitup.0 2019-04-17 20:17:57.126 debug sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                                        Die Daten wurden nicht eingespielt.
                                        • hanssH hanss
                                          simatecS Online
                                          simatecS Online
                                          simatec
                                          #1990
                                          @hanss
                                          Hast du mysqldump installiert und die richtige Pfadangabe gemacht?
                                          hanssH 1 Antwort Letzte Antwort
