  4. Wunsch: Pollenflug-(Adapter/wasauchimmer)
269 Beiträge 45 Kommentatoren 91.9k Aufrufe 21 Beobachtet
  • SmarthomeMFS
    SmarthomeMFS
    SmarthomeMF
    #214
    Hallo
    Hatte das Skript das ganze letzte Jahr am laufen
    // Polleninfo auswerten heute und die nächsten Tage
    // Version 1.4
    • Initiale Optionen
      interface iRequestOptions {
      url: string;
      headers: any;
    var baseUrl: string = "https://www.wetteronline.de/pollen/perg";
    var baseObjPath: string = 'wetter.pollenvorhersage';
    • Globale TypeScript Definitionen
      Die folgenden Funktionen sind bei mir in einem globalen script.
      Wenn man diese global definieren will, muss man das lokal referenzieren mit:
      declare function isPrimitive(obj:any):boolean
      declare function logDebug(...param: any[]):void;
      declare function logInfo(...param: any[]):void;
      declare function logWarning(...param: any[]):void;
      declare function logError(...param: any[]):void;
    • Function for check if a object is a primitive object (string, number, etc)
    • @param obj any object to check if it is a primitive object
    • @returns boolean which is true if object in parameter is a primitive object
      function isPrimitive(obj:any):boolean {
      return (obj !== Object(obj));
    • write any objects given as parameter to log as debug
    • @param param a nist of different objects
      function logDebug(...param: any[]):void {
      if (arguments.length > 0) {
      var text:string[] = [];
      for (var i = 0; i < arguments.length; i++) {
      if (typeof arguments[i] === 'string' || arguments[i] instanceof String) {
      text.push(arguments[i]);
      } else if(arguments[i] === null) {
      text.push('null');
      } else if(arguments[i] === undefined) {
      text.push('undefined');
      } else if (isPrimitive(arguments[i])) {
      } else {
      text.push(JSON.stringify(arguments[i]));
      //enum close bracket cannot be found in "channel[state.id=
      .TEMPERATURE](rooms=WZ|Wohnung|Wohnzimmer"
      log(text.join(' '), 'debug');
    • write any objects given as parameter to log as Information
      function logInfo(...param: any[]):void {
      text.push('null');
      } else {
      log(text.join(' '), 'info');
      setState("javascript.0.Ereignisliste.event",'INFO|'+text.join(' '));
      //logEnhanced(logtext, 'info');
      //console.debug(p);
      //logs(logtext,loglevels.debug);
    • write any objects given as parameter to log as warning
      function logWarning(...param: any[]):void {
      text.push('null');
      } else {
      log(text.join(' '), 'warn');
      setState("javascript.0.Ereignisliste.event",'WARN|'+text.join(' '));
      //logEnhanced(logtext, 'warn');
      //console.warn(p);
      //logs(logtext,loglevels.warn);
    • write any objects given as parameter to log as error
      function logError(...param: any[]):void {
      text.push('null');
      } else {
      log(text.join(' '), 'error');
      setState("javascript.0.Ereignisliste.event",'ERROR|'+text.join(' '));
      // Lokale TypeScript Definitionen
      import request = require("request");
    var Pollenarten:string[] = ['Erle','Hasel','Pappel','Weide','Ulme','Birke','Buche','Ampfer','Roggen','Gräser','Eiche','Wegerich','Beifuß','Ambrosia'];
    var tageVorhersage = ['d0','d1','d2','d3','d4','d5'];
    var tageVorhersageName = ['heute','morgen','übermorgen','heute + 3','heute + 4','heute + 5'];
    function stripTags(data:string):string {
    return data.replace(/( |<([^>]+)>)/ig, "");
    function getDate(days: number): string { // Eingabe 0, 1, 2, ...
    var jetzt = new Date();
    jetzt.setHours(0);
    jetzt.setMinutes(0);
    jetzt.setSeconds(0);
    jetzt.setMilliseconds(0);
    var newdate = new Date();
    newdate.setTime(jetzt.getTime() + (24 * 60 * 60 * 1000 * days) ); // heute + anzahl tage ins Millisekunden
    var date :string = newdate.getDate().toString();
    var month: string = (newdate.getMonth()+1).toString();
    var year: string = newdate.getFullYear().toString();
    date = (date.length < 2) ? '0' + date : date;
    month = (month.length < 2) ? '0' + month : month;
    var result:string = year+month+date;
    logDebug('Datum in Link: ', result);
    return (result); // Ausgabe z.B. 20160506
    function GetPollenIndex(pflanze:string, html:string):number {
    var code ={'kein':0, 'schwach':1, 'mäßig':2, 'stark':3};
    var result:string= "";
    var start:number =html.indexOf(pflanze)+pflanze.length;
    result=html.slice(start);
    result=result.trim();
    //logDebug('result for ',pflanze,html.slice(0,600));
    var stop:number =result.indexOf(' ');
    result=result.slice(0,stop);
    logDebug('pflanze=',pflanze,'code=',result);
    return code[result];
    function initializePollenwetter(baseObj:string, name:string):void {
    createState(baseObj,0,false, {
    type: "string",
    role: 'json',
    read: true,
    write: false});
    for(var i=0;i<Pollenarten.length;i++) {
      createState(baseObj + '.' + Pollenarten[i].toLowerCase(),0,false, {
         name: 'Pollenart '+ Pollenarten[i],
         type: "number",
         role: 'value',
         read: true,
         write: false});
    function removeOldPollenwetter():void {
    deleteState(baseObjPath + '.' + Pollenarten[i].toLowerCase());
    function readPollenwetterForDay(day:number, baseObj:string):void {
    logDebug("Start");
    try {
    var options:iRequestOptions = {
    url: ((day>0) ? baseUrl + '?fcdatstr=' + getDate(day) : baseUrl), // korrekten Link erstellen ,
    headers: {
    'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:40.0) Gecko/20100101 Firefox/40.1'
    request(options, function (error, response, body):void {
    if (!error && response.statusCode == 200) { // kein Fehler, Inhalt in body
    body=body.replace(/\t/g, ' ');
    body=body.replace(/(\n|\r)/g, '');
    var start:number =body.indexOf('<ul id="pollentable">');
    if (start>-1) { body=body.slice(start); }
    body=stripTags(body);
    //logDebug('body',body);
    let pobj:any = {};
    for(let i=0;i<Pollenarten.length;i++) {
    let pi:number = GetPollenIndex(Pollenarten[i],body);
    pobj[Pollenarten[i].toLowerCase()] = pi;
    setState(baseObj+'.'+Pollenarten[i].toLowerCase(),pi);
    setState(baseObj,JSON.stringify(pobj));
    } else {
    logInfo("StatusCode="+response.statusCode);
    logError(error); // Error beim Einlesen
    } catch (e) {
    logError('Fehler (try) leseWebseite: ' + e);
    function readPollenwetter() {
    for (let d:number = 0; d < tageVorhersage.length; d++) {
    let path: string = baseObjPath + '.' + tageVorhersage[d];
    initializePollenwetter(path, tageVorhersageName[d]);
    readPollenwetterForDay(d, path);
    removeOldPollenwetter();
    readPollenwetter();
    schedule("5 0 * * *", readPollenwetter);
    nun nach dem Winter habe ich es wieder gestartet!
    nun gleich einen ERROR
    [s=]```
    20:20:23.749	error	javascript.0 script.js.common.Polleninfo compile failed:
     at script.js.common.Polleninfo:9
    ```[/s]
    Das ich gerade gesehen habe das es auch bereits einen Adapter gibt habe ich ihn probiert.
    Nur geht das nicht weil ich aus österreich bin und dafür keine Eonstellungen giebt.
    Was bedeutet der Error.
    Max
    ioBroker auf einem NUC ,16GB RAM, 120GB SSD) mit Proxmox
    Cloud Pro, iot, Alexa, Sonos, sonoff, Fronius, Harmony, Doorbird, Shelly, Hue, Loxone, Mihome, …
    • SmarthomeMFS
      SmarthomeMFS
      SmarthomeMF
      #215
      Max
      • SBorgS
        SBorgS
        SBorg
        #216
        Du kannst die letzten ~50 Posts bei Interesse dazu lesen, oder kurz und schmerzlos: der Aufbau der Seite hat sich geändert und der Parser funktioniert nicht mehr...
        LG SBorg ( SBorg auf GitHub)
        • SBorgS SBorg
          #217
          @SBorg
          und wenn jemand Zeit, Lust und die Fähigkeit hat das Skript zu modifizieren (mir fehlt vor allem letzteres), habe ich schon mal etwas vorbereitet
          Mit dem Regex
          day0="(\w+)
          erhält man für die 14 Pollenarten die heutige Warnstufe
          Ändert man day0 auf day1 ist das die morgige Warnstufe, day2 übermorgen usw.
          Als Ergebnis kommen vier verschiedene Worte heraus: noburden, weakburden, moderateburden und strongborden, was den Intensitäten 0-3 entspricht, was dann noch umgerechnet werden muss.
          Mit dem Parser geht es leider nicht, da kommt 503-forbidden.
          (Oder kann man im Aufruf der Adresse einen Useragent mitgeben?)
          Die entsprechenden Pollenarten erhält man mit
          xt">(\w+)
          Wobei ich davon ausgehe, dass sich die Reihenfolge nicht ändert und man einfach 0=Erle, 1=Hasel usw. festlegen kännte
          SBorgS AlCalzoneA 2 Antworten Letzte Antwort
            @SBorg
            Mit dem Regex
            day0="(\w+)
            xt">(\w+)
            SBorgS
            SBorgS
            SBorg
            #218
            @Homoran sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
            Nicht das ich wüsste. Ich gebe ihn bei meinem Shell-Script auch per wget mit.
              @SBorg
              Mit dem Regex
              day0="(\w+)
              xt">(\w+)
              AlCalzoneA
              AlCalzoneA
              AlCalzone
              #219
              Natürlich:
              https://github.com/request/request#custom-http-headers
              • SBorgS
                SBorgS
                SBorg
                #220
                @Homoran meinte aber IMO beim Parser-Adapter...?
                • SBorgS SBorg
                  #221
                  @SBorg
                  So ist es
                  • AlCalzoneA
                    AlCalzoneA
                    AlCalzone
                    #222
                    Ok da bin ich raus 😓
                    • AlCalzoneA AlCalzone
                      #223
                      @AlCalzone
                      und ich bei einem Skript ;-)
                      • SBorgS
                        SBorgS
                        SBorg
                        #224
                        Wie sehr willst du es denn? 😇
                        Out-of-the-box kann ich dir höchstens mein Shell-Script anbieten:
                        Ist halt kein Adapter, benutzt Simpel-API und wird per crontab getriggert. Kann dafür aber jeden Ort, liefert was WetterOnline anbietet, allerdings meinen Bedürfnissen angepasst.
                        • SpikeNbgS
                          SpikeNbgS
                          SpikeNbg
                          #225
                          ich war mal so frei und hab es soweit mir möglich an die neue Website Struktur angepasst.
                          Noch ein Dank an alle die das Skript erstellt und Verbesserungen eingebracht haben! 👍
                          Hier meine angepasste Version zum neuen Seitenlayout von Wetteronline:
                          // Angepasste Version von Spike - Vielen Dank an steinwedel, pix, robsdobs, und wer noch so dran war :)
                          // basierend auf Original Version 1.52 -> angepasste Version 1.0 - 15.03.2019
                          // @ts-check
                          "use strict";
                          ///< script> var exports = {}; < / script>
                          * Initiale Optionen
                          //Welcher Ort soll abgefragt werden?
                          var baseUrl: string = "https://www.wetteronline.de/pollen/hierdeinenStadtnamenrein";
                          //Wo sollen die Daten unter javascript.0... abgelegt werden?
                          * Globale TypeScript Definitionen
                          		url: string;
                          		headers: any;
                           * Function for check if a object is a primitive object (string, number, etc)
                           * @param	obj		   any object to check if it is a primitive object
                           * @returns			  boolean which is true if object in parameter is a primitive object
                           * write any objects given as parameter to log as debug
                           * @param	param	   a nist of different objects
                          				text.push('null');
                          			} else {
                          			//enum close bracket cannot be found in "channel[state.id=*.TEMPERATURE](rooms=WZ|Wohnung|Wohnzimmer"
                           * write any objects given as parameter to log as Information
                          				text.push('null');
                          			} else {
                          		setState('javascript.' + instance + '.Ereignisliste.event','INFO|'+text.join(' '));
                          	//console.debug(p);
                           * write any objects given as parameter to log as warning
                          				text.push('null');
                          			} else {
                          		setState('javascript.' + instance + '.Ereignisliste.event','WARN|'+text.join(' '));
                          	//console.warn(p);
                           * write any objects given as parameter to log as error
                          				text.push('null');
                          			} else {
                          		setState('javascript.' + instance + '.Ereignisliste.event','ERROR|'+text.join(' '));
                          * Lokale TypeScript Definitionen
                          //import request = require("request");
                          var tageVorhersage = ['d0','d1','d2','d3','d4','d5','d6'];
                          var tageVorhersageName = ['heute','morgen','übermorgen','heute + 3','heute + 4','heute + 5','heute + 6'];
                          	return data.replace(/(&nbsp;|<([^>]+)>)/ig, "");
                          	jetzt.setHours(0);
                          function GetPollenIndex(pflanze:string, html:string, day:number):number {
                          	var code ={'noburden':0, 'weakburden':1, 'moderateburden':2, 'strongburden':3};
                          	html=html.slice(start);
                          	start = html.indexOf('data-day' + day);
                          	var ende:number =html.indexOf("burden") + 6;
                          	result=html.substring(0,ende).replace("data-day" + day + '="',"");
                          	createState(baseObj, '', false, {
                          		type: "string",
                          		role: 'json',
                          		desc: 'Pollenflug',
                          		read: true,
                          		write: false});
                          		createState(baseObj + '.' + Pollenarten[i].toLowerCase(), 0, false, {
                          			type: "number",
                          			role: 'value',
                          			desc: 'Pollenart ' + Pollenarten[i],
                          			read: true,
                          			write: false});
                          	createState(baseObj+'.count.gt0', 0, false, {
                          		name: 'Anzahl Pollen größer 0',
                          		type: "number",
                          		role: 'value',
                          		desc: 'Anzahl Pollen',
                          		read: true,
                          		write: false});
                          	for(let i=0;i<4;i++) {
                          		createState(baseObj+'.text.'+i.toString(), '', false, {
                          			name: 'Liste Pollen größern ' + String(i),
                          			type: "string",
                          			role: 'text',
                          			desc: 'Pollenübersicht',
                          			read: true,
                          			write: false});
                          		createState(baseObj+'.html.'+i.toString(), '', false, {
                          			name: 'Liste Pollen größern ' + String(i) + ' (html)',
                          			type: "string",
                          			role: 'html',
                          			read: true,
                          			write: false});
                          		createState(baseObj+'.count.'+i.toString(), 0, false, {
                          			name: 'Anzahl Pollen mit ' + String(i),
                          			type: "number",
                          			role: 'value',
                          			read: true,
                          			write: false});
                          /* function removeOldPollenwetter():void {
                          function readPollenwetterForAllDays():void {
                          	//logDebug("Start",day,baseObj);
                              try {
                          			url: baseUrl,
                          			headers: {
                                  //log(options.url);
                                          var start:number =body.indexOf('text">Erle</div>');
                                          var ende:number =body.indexOf('id="burden_icons_legend_headline">');
                          				if (start>-1) { body=body.substring(start, ende); }
                                          let pobj:any = {};
                          				let pot = ['','','',''];
                          				let poh = ['','','',''];
                          				let poc = [0,0,0,0];
                          				let cnt =0;
                                          for(let day=0;day<tageVorhersage.length;day++) {
                                              let baseObj: string = baseObjPath + '.' + tageVorhersage[day];
                                              initializePollenwetter(baseObj, tageVorhersageName[day]);
                                                  let pi:number = GetPollenIndex(Pollenarten[i],body, day);
                                                  if (pi>0) { cnt++; }
                                                  poc[pi]++;
                                                  pot[pi] = pot[pi] + Pollenarten[i] + '\r\n';
                                                  poh[pi] = poh[pi] + Pollenarten[i] + '<br/>';
                                              setState(baseObj+'.count.gt0',cnt);
                                                  setState(baseObj+'.text.'+i.toString(),pot[i]);
                                                  setState(baseObj+'.html.'+i.toString(),poh[i]);
                                                  setState(baseObj+'.count.'+i.toString(),poc[i]);
                          			} else {
                          	} catch (e) {
                          	readPollenwetterForAllDays();
                          //removeOldPollenwetter();
                          readPollenwetter();
                           # *  *  * *  *  command to execute
                           # ¦ ¦ ¦ ¦ +----- day of week (0 - 6) (0 to 6 are Sunday to Saturday, or use names; 7 is Sunday, the same as 0)
                           # ¦ ¦ ¦ +---------- month (1 - 12)
                           # ¦ ¦ +--------------- day of month (1 - 31)
                           # ¦ +-------------------- hour (0 - 23)
                           # +------------------------- min (0 - 59)
                          Denkt dran, eure Stadt wieder einzutragen und evtl. wohin ihr die Daten hinschreiben wollt. Findet ihr gleich unter "Initiale Optionen"..
                          Viel Spaß damit und ein schönes Wochenende!
                          sigi234S HomoranH 3 Antworten Letzte Antwort
                          • SpikeNbgS SpikeNbg
                            // @ts-check
                            "use strict";
                            * Initiale Optionen
                            		url: string;
                            		headers: any;
                            				text.push('null');
                            			} else {
                            				text.push('null');
                            			} else {
                            	//console.debug(p);
                            				text.push('null');
                            			} else {
                            	//console.warn(p);
                            				text.push('null');
                            			} else {
                            	jetzt.setHours(0);
                            		type: "string",
                            		role: 'json',
                            		desc: 'Pollenflug',
                            		read: true,
                            		write: false});
                            			type: "number",
                            			role: 'value',
                            			read: true,
                            			write: false});
                            		type: "number",
                            		role: 'value',
                            		read: true,
                            		write: false});
                            			type: "string",
                            			role: 'text',
                            			read: true,
                            			write: false});
                            			type: "string",
                            			role: 'html',
                            			read: true,
                            			write: false});
                            			type: "number",
                            			role: 'value',
                            			read: true,
                            			write: false});
                                try {
                            			url: baseUrl,
                            			headers: {
                                    //log(options.url);
                                            let pobj:any = {};
                            				let cnt =0;
                                                    poc[pi]++;
                            			} else {
                            	} catch (e) {
                            readPollenwetter();
                            sigi234S
                            sigi234S
                            #226
                            @SpikeNbg
                            14:15:48.050	info	javascript.0 Stop script script.js.Test.Pollenflug
                            14:15:48.070	info	javascript.0 Start javascript script.js.Test.Pollenflug
                            14:15:48.070	error	javascript.0 script.js.Test.Pollenflug compile failed:
                             at script.js.Test.Pollenflug:14
                            EDIT: Ist ja ein TS!
                            SpikeNbgS 1 Antwort Letzte Antwort
                              // @ts-check
                              "use strict";
                              * Initiale Optionen
                              		url: string;
                              		headers: any;
                              				text.push('null');
                              			} else {
                              				text.push('null');
                              			} else {
                              	//console.debug(p);
                              				text.push('null');
                              			} else {
                              	//console.warn(p);
                              				text.push('null');
                              			} else {
                              	jetzt.setHours(0);
                              		type: "string",
                              		role: 'json',
                              		desc: 'Pollenflug',
                              		read: true,
                              		write: false});
                              			type: "number",
                              			role: 'value',
                              			read: true,
                              			write: false});
                              		type: "number",
                              		role: 'value',
                              		read: true,
                              		write: false});
                              			type: "string",
                              			role: 'text',
                              			read: true,
                              			write: false});
                              			type: "string",
                              			role: 'html',
                              			read: true,
                              			write: false});
                              			type: "number",
                              			role: 'value',
                              			read: true,
                              			write: false});
                                  try {
                              			url: baseUrl,
                              			headers: {
                                      //log(options.url);
                                              let pobj:any = {};
                              				let cnt =0;
                                                      poc[pi]++;
                              			} else {
                              	} catch (e) {
                              readPollenwetter();
                              #227
                              @SpikeNbg
                              Danke erst einmal, bei mir kommen Ergebnisse, aber auch ganz viele:
                              19:15:04.737	warn	javascript.0 at Request._callback (script.js.Wetter_und_Klima.Pollenskript_neu:296:25)
                                @SpikeNbg
                                SpikeNbgS
                                SpikeNbgS
                                SpikeNbg
                                schrieb am zuletzt editiert von SpikeNbg
                                #228
                                @Homoran
                                von diesen Warnings hatte ich mit der alten Version des Skripts ganz viele, im Endeffekt genau so viele wie er Werte gesetzt hat.
                                Ich hab dann mal die alte Struktur komplett gelöscht und vom neuen Skript (automatisch) wieder neu anlegen lassen. Danach kamen sie nicht mehr..
                                Stimmen denn die Ergebnisse in der Objektstruktur? (müsstest du mit der Webseite vergleichen)
                                • sigi234S sigi234
                                  @SpikeNbg
                                  SpikeNbgS
                                  SpikeNbgS
                                  SpikeNbg
                                  #229
                                  @sigi234
                                  Hi! Ja genau, ist ein TypeScript
                                    @Homoran
                                    #230
                                    @SpikeNbg
                                    ich habe gerade mal im log nachgesehen, da steht dann noch u.a. (von unten nach oben):
                                    javascript.0	2019-03-15 19:15:04.563	warn	at Request._callback (script.js.Wetter_und_Klima.Pollenskript_neu:296:25)
                                    javascript.0	2019-03-15 19:15:04.563	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                                    javascript.0	2019-03-15 19:15:04.563	warn	Wrong type of javascript.0.wetter.neu.pollenvorhersage.d6.ambrosia: "undefined". Please fix, while deprecated and will not work in next versions.
                                    ich habe alle States neu anlegen lassen, in einem neuen Pfad
                                    • SpikeNbgS
                                      SpikeNbgS
                                      SpikeNbg
                                      #231
                                      Hab den Fehler.. Es gibt jetzt nur noch 6 Tage, nicht mehr 7. (also d0 bis d5, früher d0 bis d6)
                                      Danke fürs Bescheid geben, komisch nur, dass ich die Warnings heute Mittag nicht gesehen hab 😇
                                      Hier ist die Version 1.1:
                                      // basierend auf Original Version 1.52 -> angepasste Version 1.1 - 15.03.2019
                                      // @ts-check
                                      "use strict";
                                      * Initiale Optionen
                                      		url: string;
                                      		headers: any;
                                      				text.push('null');
                                      			} else {
                                      				text.push('null');
                                      			} else {
                                      	//console.debug(p);
                                      				text.push('null');
                                      			} else {
                                      	//console.warn(p);
                                      				text.push('null');
                                      			} else {
                                      	jetzt.setHours(0);
                                      	var code ={'noburden':0, 'weakburden':1, 'moderateburden':2, 'strongburden':3, '':0};
                                      	// log("Pflanze: " + pflanze + ", Tag: " + day + ": "  + result + " > " + code[result]);
                                      		type: "string",
                                      		role: 'json',
                                      		desc: 'Pollenflug',
                                      		read: true,
                                      		write: false});
                                      			type: "number",
                                      			role: 'value',
                                      			read: true,
                                      			write: false});
                                      		type: "number",
                                      		role: 'value',
                                      		read: true,
                                      		write: false});
                                      			type: "string",
                                      			role: 'text',
                                      			read: true,
                                      			write: false});
                                      			type: "string",
                                      			role: 'html',
                                      			read: true,
                                      			write: false});
                                      			type: "number",
                                      			role: 'value',
                                      			read: true,
                                      			write: false});
                                          try {
                                      			url: baseUrl,
                                      			headers: {
                                              //log(options.url);
                                                      let pobj:any = {};
                                      				let cnt =0;
                                                              poc[pi]++;
                                      			} else {
                                      	} catch (e) {
                                      readPollenwetter();
                                      HomoranH NashraN F 3 Antworten Letzte Antwort
                                        // @ts-check
                                        "use strict";
                                        * Initiale Optionen
                                        		url: string;
                                        		headers: any;
                                        				text.push('null');
                                        			} else {
                                        				text.push('null');
                                        			} else {
                                        	//console.debug(p);
                                        				text.push('null');
                                        			} else {
                                        	//console.warn(p);
                                        				text.push('null');
                                        			} else {
                                        	jetzt.setHours(0);
                                        		type: "string",
                                        		role: 'json',
                                        		desc: 'Pollenflug',
                                        		read: true,
                                        		write: false});
                                        			type: "number",
                                        			role: 'value',
                                        			read: true,
                                        			write: false});
                                        		type: "number",
                                        		role: 'value',
                                        		read: true,
                                        		write: false});
                                        			type: "string",
                                        			role: 'text',
                                        			read: true,
                                        			write: false});
                                        			type: "string",
                                        			role: 'html',
                                        			read: true,
                                        			write: false});
                                        			type: "number",
                                        			role: 'value',
                                        			read: true,
                                        			write: false});
                                            try {
                                        			url: baseUrl,
                                        			headers: {
                                                //log(options.url);
                                                        let pobj:any = {};
                                        				let cnt =0;
        poc[pi]++;
                                        			} else {
                                        	} catch (e) {
                                        readPollenwetter();
                                        #232
                                        @SpikeNbg
                                        Super!
                                        läuft.
                                        Bei der ersten Runde kommen die Fehler noch - war auch zu erwarten, danach läuft's sauber durch.
                                        @SpikeNbg sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
                                        Vielleicht haben die eben erst die Seite geändert.
                                        Sigi hatte ja auch keine Fehler! )oder?)
                                        • SmarthomeMFS
                                          SmarthomeMFS
                                          SmarthomeMF
                                          #233
                                          Hallo
                                          und danke für die arbeit.
                                          Habe das Skript am laufen bekomme aber eine menge error!
                                          javascript.0	2019-03-15 19:52:38.602	error	at TCP.onread (net.js:601:20)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Socket.Readable.push (_stream_readable.js:208:10)
                                          javascript.0	2019-03-15 19:52:38.602	error	at readableAddChunk (_stream_readable.js:250:11)
                                          javascript.0	2019-03-15 19:52:38.602	error	at addChunk (_stream_readable.js:263:12)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Socket.emit (events.js:211:7)
                                          javascript.0	2019-03-15 19:52:38.602	error	at emitOne (events.js:116:13)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
                                          javascript.0	2019-03-15 19:52:38.602	error	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
                                          javascript.0	2019-03-15 19:52:38.602	error	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
                                          javascript.0	2019-03-15 19:52:38.602	error	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
                                          javascript.0	2019-03-15 19:52:38.602	error	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                                          javascript.0	2019-03-15 19:52:38.602	error	at WebSocket.emit (events.js:214:7)
                                          javascript.0	2019-03-15 19:52:38.602	error	at emitTwo (events.js:126:13)
                                          javascript.0	2019-03-15 19:52:38.602	error	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                                          javascript.0	2019-03-15 19:52:38.602	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                                          javascript.0	2019-03-15 19:52:38.602	error	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                                          javascript.0	2019-03-15 19:52:38.602	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                                          javascript.0	2019-03-15 19:52:38.602	error	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                          javascript.0	2019-03-15 19:52:38.602	error	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                                          javascript.0	2019-03-15 19:52:38.602	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Socket.adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:745:17)
                                          javascript.0	2019-03-15 19:52:38.601	error	at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1123:17)
                                          javascript.0	2019-03-15 19:52:38.601	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1070:37)
                                          javascript.0	2019-03-15 19:52:38.601	error	at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:878:28)
                                          javascript.0	2019-03-15 19:52:38.601	error	at Object.createScript (vm.js:80:10)
                                          javascript.0	2019-03-15 19:52:38.601	error	SyntaxError: Unexpected token :
                                          javascript.0	2019-03-15 19:52:38.601	error	^
                                          javascript.0	2019-03-15 19:52:38.601	error	var baseUrl: string = "https://www.wetteronline.de/pollen/perg";
                                          javascript.0	2019-03-15 19:52:38.601	error	at script.js.common.Polleninfo_2:14
                                          javascript.0	2019-03-15 19:52:38.601	error	script.js.common.Polleninfo_2 compile failed:
                                          was passt da nicht?
                                          Max
