  3. Entwicklung
  4. [Adapter] Neuer radar2-Adapter
adapterradar2 adapter
840 Beiträge 80 Kommentatoren 366.7k Aufrufe 54 Beobachtet
  • rantanplanR
    rantanplanR
    rantanplan
    Bei mir wird es auch nicht angezeigt.
    Hier ein Auszug aus dem LOG
    2019-02-11 23:05:38.271 - info: iobroker url "https://github.com/frankjoke/ioBroker.radar2"
    2019-02-11 23:05:40.524 - info: iobroker install https://github.com/frankjoke/ioBroker.radar2/tarball/master
    2019-02-11 23:05:45.865 - info: iobroker npm install https://github.com/frankjoke/ioBroker.radar2/tarball/master --production --save --prefix "C:/ioBroker" (System call)
    2019-02-11 23:06:00.036 - info: host.myHost instance system.adapter.yr.0 started with pid 6132
    2019-02-11 23:06:05.176 - info: yr.0 starting. Version 2.0.3 in C:/ioBroker/node_modules/iobroker.yr, node: v6.10.0
    2019-02-11 23:06:06.036 - info: yr.0 got weather data from yr.no
    2019-02-11 23:06:11.209 - info: host.myHost instance system.adapter.yr.0 terminated with code 0 (OK)
    2019-02-11 23:07:47.411 - info: iobroker npm ERR! Windows_NT 10.0.16299npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "node-pre-gyp"
    npm ERR! node v6.10.0
    npm ERR! npm v3.10.10
    npm ERR! path C:\ioBroker\node_modules\.staging\@abandonware\bluetooth-hci-socket-32336d5a
    npm ERR! code EBUSY
    npm ERR! errno -4082
    npm ERR! syscall rmdir
    2019-02-11 23:07:47.411 - info: iobroker npm ERR! EBUSY: resource busy or locked, rmdir 'C:\ioBroker\node_modules\.staging\@abandonware\bluetooth-hci-socket-32336d5a'npm ERR!
    npm ERR! If you need help, you may report this error at:
    npm ERR!
    2019-02-11 23:07:47.614 - info: iobroker npm ERR! Please include the following file with any support request:
    npm ERR! C:\ioBroker\node_modules\.staging\@abandonware\bluetooth-hci-socket-32336d5a\npm-debug.log
    2019-02-11 23:07:48.223 - info: iobroker npm
    2019-02-11 23:07:48.223 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules\iobroker.radar2\node_modules\@abandonware\noble\node_modules\xpc-connection):npm WARN notsup
    2019-02-11 23:07:48.223 - info: iobroker SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
    2019-02-11 23:07:48.223 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules\iobroker.radar2\node_modules\@abandonware\bluetooth-hci-socket):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: `npm install node-pre-gyp`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 4294963214
    2019-02-11 23:07:48.239 - info: iobroker npm ERR! Windows_NT 10.0.16299npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "https://github.com/frankjoke/ioBroker.radar2/tarball/master" "--production" "--save" "--prefix" "C:/ioBroker"
    Rantanplan
    • SegwayS
      SegwayS
      Segway
      keine Installation möglich und kein Adapter in der Adapterliste trotz install von dem Link:
      host.IoBTest 2019-02-12 12:27:01.369 info Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      iobroker 2019-02-12 12:27:00.427 info exit 0
      iobroker 2019-02-12 12:27:00.358 info found 50 vulnerabilities (36 low, 14 high) run npm audit fix to fix them, or npm audit for details
      iobroker 2019-02-12 12:27:00.354 info + iobroker.radar2@0.1.2added 102 packages from 57 contributors and audited 3514 packages in 92.284s
      iobroker 2019-02-12 12:27:00.349 info
      iobroker 2019-02-12 12:27:00.348 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      iobroker 2019-02-12 12:27:00.348 info WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 (node_modules/node-bluetooth):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 install: node-gyp configure build
      iobroker 2019-02-12 12:27:00.348 info optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"d
      iobroker 2019-02-12 12:27:00.347 info npm WARN
      iobroker 2019-02-12 12:26:57.858 info ERR! not ok
      iobroker 2019-02-12 12:26:57.857 info gyp
      iobroker 2019-02-12 12:26:57.857 info gyp ERR! node-gyp -v v3.8.0
      iobroker 2019-02-12 12:26:57.857 info /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v10.15.0
      iobroker 2019-02-12 12:26:57.857 info gyp ERR! cwd
      iobroker 2019-02-12 12:26:57.857 info gyp ERR! System Linux 4.9.0-7-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
      iobroker 2019-02-12 12:26:57.855 info ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
      iobroker 2019-02-12 12:26:57.854 info gyp
      iobroker 2019-02-12 12:26:57.854 info gyp ERR! stack at ChildProcess.emit (events.js:182:13)
      iobroker 2019-02-12 12:26:57.854 info stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      iobroker 2019-02-12 12:26:57.853 info gyp ERR!
      iobroker 2019-02-12 12:26:57.852 info ERR! build error
      iobroker 2019-02-12 12:26:57.851 info gyp
      iobroker 2019-02-12 12:26:57.847 info make: *** [Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1
      iobroker 2019-02-12 12:26:57.846 info BluetoothSerialPort.target.mk:107: die Regel für Ziel „Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o“ scheitertemake: Verzeichnis „/opt/iobroker/node_modules/node-bluetooth/build“ wird
      iobroker 2019-02-12 12:26:57.841 info compilation terminated.
      iobroker 2019-02-12 12:26:57.841 info ^
      iobroker 2019-02-12 12:26:57.841 info ../src/linux/DeviceINQ.cc:35:37: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden #include <bluetooth/bluetooth.h>
      iobroker 2019-02-12 12:26:57.609 info CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o
      iobroker 2019-02-12 12:26:55.519 info CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o
      iobroker 2019-02-12 12:26:55.516 info make: Verzeichnis „/opt/iobroker/node_modules/node-bluetooth/build“ wird betreten
      iobroker 2019-02-12 12:26:54.139 info > node-gyp configure build
      iobroker 2019-02-12 12:26:54.139 info > node-bluetooth@1.2.5 install /opt/iobroker/node_modules/node-bluetooth
      iobroker 2019-02-12 12:26:54.105 info make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build“ wird verlassen
      iobroker 2019-02-12 12:26:54.089 info TOUCH Release/obj.target/action_after_build.stamp
      iobroker 2019-02-12 12:26:54.068 info COPY /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node
      iobroker 2019-02-12 12:26:54.049 info COPY Release/binding.node
      iobroker 2019-02-12 12:26:53.813 info SOLINK_MODULE(target) Release/obj.target/binding.node
      iobroker 2019-02-12 12:26:52.202 info ^~~~~~~~~~
      iobroker 2019-02-12 12:26:52.202 info declarator attribute((deprecated(message)))
      iobroker 2019-02-12 12:26:52.202 info /home/iobroker/.node-gyp/10.15.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
      iobroker 2019-02-12 12:26:52.202 info V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);
      iobroker 2019-02-12 12:26:52.202 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:2476:46: note: declared here
      iobroker 2019-02-12 12:26:52.202 info from ../src/BluetoothHciSocket.cpp:7:
      iobroker 2019-02-12 12:26:52.202 info from /home/iobroker/.node-gyp/10.15.0/include/node/node_buffer.h:25,
      iobroker 2019-02-12 12:26:52.202 info from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63,
      iobroker 2019-02-12 12:26:52.202 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:26:0,
      iobroker 2019-02-12 12:26:52.202 info devId = arg0->IntegerValue();
      iobroker 2019-02-12 12:26:52.202 info ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:418:34: warning: ‘i
      iobroker 2019-02-12 12:26:52.202 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:26:0, from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63,
      iobroker 2019-02-12 12:26:52.201 info ^
      iobroker 2019-02-12 12:26:52.201 info devId = arg0->IntegerValue();
      iobroker 2019-02-12 12:26:52.201 info ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:396:34: warning: ‘in
      iobroker 2019-02-12 12:26:52.191 info ^~~~~~~~~~~~
      iobroker 2019-02-12 12:26:52.191 info NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
      iobroker 2019-02-12 12:26:52.191 info ../../../nan/nan.h:980:46: note: declared here
      iobroker 2019-02-12 12:26:52.191 info In file included from ../src/BluetoothHciSocket.cpp:8:0:
      iobroker 2019-02-12 12:26:52.191 info Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      iobroker 2019-02-12 12:26:52.191 info ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:283:93: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Local<v8::Obje
      iobroker 2019-02-12 12:26:52.188 info ^~~~~~~~~~~~
      iobroker 2019-02-12 12:26:52.188 info NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
      iobroker 2019-02-12 12:26:52.188 info ../../../nan/nan.h:980:46: note: declared here
      iobroker 2019-02-12 12:26:52.188 info In file included from ../src/BluetoothHciSocket.cpp:8:0:
      iobroker 2019-02-12 12:26:52.188 info Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      iobroker 2019-02-12 12:26:52.188 info ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:252:95: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::L
      iobroker 2019-02-12 12:26:50.324 info CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
      iobroker 2019-02-12 12:26:50.323 info make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build“ wird betreten
      iobroker 2019-02-12 12:26:48.144 info Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v64-linux-x64.tar.gz node-pre-gyp WARN Pre-built binaries not found
      iobroker 2019-02-12 12:26:48.143 info node-pre-gyp WARN
      iobroker 2019-02-12 12:26:46.909 info WARN Using request for node-pre-gyp https download
      iobroker 2019-02-12 12:26:46.908 info
      iobroker 2019-02-12 12:26:46.908 info node-pre-gyp
      iobroker 2019-02-12 12:26:46.125 info > node-pre-gyp install --fallback-to-build
      iobroker 2019-02-12 12:26:46.125 info > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      iobroker 2019-02-12 12:26:46.093 info make: Verzeichnis „/opt/iobroker/node_modules/usb/build“ wird verlassen
      iobroker 2019-02-12 12:26:46.081 info TOUCH Release/obj.target/action_after_build.stamp
      iobroker 2019-02-12 12:26:46.061 info COPY /opt/iobroker/node_modules/usb/src/binding/usb_bindings.node
      iobroker 2019-02-12 12:26:46.040 info COPY Release/usb_bindings.node
      iobroker 2019-02-12 12:26:45.705 info SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
      iobroker 2019-02-12 12:26:44.609 info ^~~~~~~~~~~~
      iobroker 2019-02-12 12:26:44.609 info NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
      iobroker 2019-02-12 12:26:44.609 info ../../nan/nan.h:959:46: note: declared here
      iobroker 2019-02-12 12:26:44.609 info from ../src/transfer.cc:1:
      iobroker 2019-02-12 12:26:44.609 info from ../src/node_usb.h:21,
      iobroker 2019-02-12 12:26:44.609 info In file included from ../src/helpers.h:3:0,
      iobroker 2019-02-12 12:26:44.609 info Nan::MakeCallback(self->handle(), Nan::New(self->v8callback), 3, argv);
      iobroker 2019-02-12 12:26:44.609 info ../src/transfer.cc: In function ‘void handleCompletion(Transfer*)’:../src/transfer.cc:126:72: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8:
      iobroker 2019-02-12 12:26:44.600 info ^~~~~
      iobroker 2019-02-12 12:26:44.600 info Local<Object> Value::ToObject() const {
      iobroker 2019-02-12 12:26:44.600 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10046:15: note: declared here
      iobroker 2019-02-12 12:26:44.600 info from ../src/transfer.cc:1:
      iobroker 2019-02-12 12:26:44.600 info In file included from ../src/node_usb.h:12:0,
      iobroker 2019-02-12 12:26:44.600 info Local<Object> buffer_obj = info[0]->ToObject();
      iobroker 2019-02-12 12:26:44.600 info ../src/transfer.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Transfer_Submit(Nan::NAN_METHOD_ARGS_TYPE)’:../src/transfer.cc:58:47: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is depr
      iobroker 2019-02-12 12:26:42.776 info CXX(target) Release/obj.target/usb_bindings/src/transfer.o
      iobroker 2019-02-12 12:26:39.924 info ^~~~~~~~~~~~
      iobroker 2019-02-12 12:26:39.924 info NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
      iobroker 2019-02-12 12:26:39.924 info ../../nan/nan.h:959:46: note: declared here
      iobroker 2019-02-12 12:26:39.924 info from ../src/device.cc:1:
      iobroker 2019-02-12 12:26:39.924 info from ../src/node_usb.h:21,
      iobroker 2019-02-12 12:26:39.924 info In file included from ../src/helpers.h:3:0,
      iobroker 2019-02-12 12:26:39.924 info Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);
      iobroker 2019-02-12 12:26:39.924 info ../src/device.cc: In static member function ‘static void Req::default_after(uv_work_t*)’:../src/device.cc:237:64: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Local<v8:
      iobroker 2019-02-12 12:26:37.909 info CXX(target) Release/obj.target/usb_bindings/src/device.o
      iobroker 2019-02-12 12:26:36.311 info ^~~~~
      iobroker 2019-02-12 12:26:36.311 info Local<Object> Value::ToObject() const {
      iobroker 2019-02-12 12:26:36.311 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10046:15: note: declared here
      iobroker 2019-02-12 12:26:36.311 info In file included from ../src/node_usb.h:12:0, from ../src/node_usb.cc:1:
      iobroker 2019-02-12 12:26:36.310 info ^
      iobroker 2019-02-12 12:26:36.310 info e->ToObject()->Set(Nan::New<String>("errno").ToLocalChecked(), Nan::New<Integer>(errorno));
      iobroker 2019-02-12 12:26:36.310 info ../src/node_usb.cc: In function ‘v8::Localv8::Value libusbException(int)’:../src/node_usb.cc:301:14: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-
      iobroker 2019-02-12 12:26:36.192 info ^~~~~~~~~~~~
      iobroker 2019-02-12 12:26:36.192 info NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
      iobroker 2019-02-12 12:26:36.192 info ../../nan/nan.h:1001:46: note: declared here
      iobroker 2019-02-12 12:26:36.192 info from ../src/node_usb.cc:1:
      iobroker 2019-02-12 12:26:36.192 info from ../src/node_usb.h:21,
      iobroker 2019-02-12 12:26:36.192 info In file included from ../src/helpers.h:3:0,
      iobroker 2019-02-12 12:26:36.192 info Nan::MakeCallback(Nan::New(hotplugThis), "emit", 2, argv);
      iobroker 2019-02-12 12:26:36.192 info ../src/node_usb.cc: In function ‘void handleHotplug(std::pair<libusb_device*, libusb_hotplug_event>)’:../src/node_usb.cc:151:58: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object
      iobroker 2019-02-12 12:26:36.166 info ^~~~~~~~~~
      iobroker 2019-02-12 12:26:36.166 info declarator attribute((deprecated(message)))
      iobroker 2019-02-12 12:26:36.166 info /home/iobroker/.node-gyp/10.15.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
      iobroker 2019-02-12 12:26:36.166 info V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
      iobroker 2019-02-12 12:26:36.166 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:2477:47: note: declared here
      iobroker 2019-02-12 12:26:36.166 info from ../src/node_usb.cc:1:
      iobroker 2019-02-12 12:26:36.166 info from ../src/node_usb.h:12,
      iobroker 2019-02-12 12:26:36.166 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:26:0,
      iobroker 2019-02-12 12:26:36.166 info libusb_set_debug(usb_context, info[0]->Uint32Value());
      iobroker 2019-02-12 12:26:36.166 info ../src/node_usb.cc:103:53: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      iobroker 2019-02-12 12:26:36.166 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:26:0, from ../src/node_usb.h:12,
      iobroker 2019-02-12 12:26:36.165 info ^
      iobroker 2019-02-12 12:26:36.165 info if (info.Length() != 1 || !info[0]->IsUint32() || info[0]->Uint32Value() > 4) {
      iobroker 2019-02-12 12:26:36.165 info ../src/node_usb.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetDebugLevel(Nan::NAN_METHOD_ARGS_TYPE)’:../src/node_usb.cc:99:73: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use
      iobroker 2019-02-12 12:26:34.212 info CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
      iobroker 2019-02-12 12:26:34.189 info COPY Release/usb.a
      iobroker 2019-02-12 12:26:34.140 info AR(target) Release/obj.target/usb.a
      iobroker 2019-02-12 12:26:33.735 info CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
      iobroker 2019-02-12 12:26:31.894 info CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
      iobroker 2019-02-12 12:26:31.740 info CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
      iobroker 2019-02-12 12:26:31.571 info CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
      iobroker 2019-02-12 12:26:31.334 info CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
      iobroker 2019-02-12 12:26:31.147 info CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
      iobroker 2019-02-12 12:26:30.444 info CC(target) Release/obj.target/libusb/libusb/libusb/io.o
      iobroker 2019-02-12 12:26:30.176 info CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
      iobroker 2019-02-12 12:26:29.493 info CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
      iobroker 2019-02-12 12:26:27.748 info CC(target) Release/obj.target/libusb/libusb/libusb/core.o
      iobroker 2019-02-12 12:26:27.746 info make: Verzeichnis „/opt/iobroker/node_modules/usb/build“ wird betreten
      iobroker 2019-02-12 12:26:25.471 info Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v64-linux-x64.tar.gz node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node
      iobroker 2019-02-12 12:26:25.470 info node-pre-gyp WARN
      iobroker 2019-02-12 12:26:24.694 info WARN Using request for node-pre-gyp https download
      iobroker 2019-02-12 12:26:24.691 info node-pre-gyp
      iobroker 2019-02-12 12:26:23.331 info > node-pre-gyp install --fallback-to-build
      iobroker 2019-02-12 12:26:23.331 info > usb@1.5.0 install /opt/iobroker/node_modules/usb
      iobroker 2019-02-12 12:26:23.299 info make: Verzeichnis „/opt/iobroker/node_modules/raw-socket/build“ wird verlassen
      iobroker 2019-02-12 12:26:23.276 info COPY Release/raw.node
      iobroker 2019-02-12 12:26:22.945 info SOLINK_MODULE(target) Release/obj.target/raw.node
      iobroker 2019-02-12 12:26:20.587 info ^~~~~
      iobroker 2019-02-12 12:26:20.587 info Local<Object> Value::ToObject() const {
      iobroker 2019-02-12 12:26:20.587 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10046:15: note: declared here
      iobroker 2019-02-12 12:26:20.587 info from ../src/raw.cc:6:
      iobroker 2019-02-12 12:26:20.587 info from ../src/raw.h:21,
      iobroker 2019-02-12 12:26:20.587 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63:0,
      iobroker 2019-02-12 12:26:20.587 info Local<Object> buffer = info[2]->ToObject ();
      iobroker 2019-02-12 12:26:20.587 info ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::SetOption(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:727:45: warning: ‘v8::Localv8::Object v8::Value::To
      iobroker 2019-02-12 12:26:20.580 info ^~~~~
      iobroker 2019-02-12 12:26:20.580 info Local<Object> Value::ToObject() const {
      iobroker 2019-02-12 12:26:20.580 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10046:15: note: declared here
      iobroker 2019-02-12 12:26:20.580 info from ../src/raw.cc:6:
      iobroker 2019-02-12 12:26:20.580 info from ../src/raw.h:21,
      iobroker 2019-02-12 12:26:20.580 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63:0,
      iobroker 2019-02-12 12:26:20.580 info buffer = info[0]->ToObject ();
      iobroker 2019-02-12 12:26:20.580 info ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::Send(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:650:30: warning: ‘v8::Localv8::Object v8::Value::ToObjec
      iobroker 2019-02-12 12:26:20.568 info ^~~~~
      iobroker 2019-02-12 12:26:20.568 info Local<Object> Value::ToObject() const {
      iobroker 2019-02-12 12:26:20.568 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10046:15: note: declared here
      iobroker 2019-02-12 12:26:20.568 info from ../src/raw.cc:6:
      iobroker 2019-02-12 12:26:20.568 info from ../src/raw.h:21,
      iobroker 2019-02-12 12:26:20.568 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63:0,
      iobroker 2019-02-12 12:26:20.568 info buffer = info[0]->ToObject ();
      iobroker 2019-02-12 12:26:20.568 info ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::Recv(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:557:31: warning: ‘v8::Localv8::Object v8::Value::ToObjec
      iobroker 2019-02-12 12:26:20.565 info ^~~~~
      iobroker 2019-02-12 12:26:20.565 info Local<Boolean> Value::ToBoolean() const {
      iobroker 2019-02-12 12:26:20.565 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10034:16: note: declared here
      iobroker 2019-02-12 12:26:20.565 info from ../src/raw.cc:6:
      iobroker 2019-02-12 12:26:20.565 info from ../src/raw.h:21,
      iobroker 2019-02-12 12:26:20.565 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63:0,
      iobroker 2019-02-12 12:26:20.565 info ../src/raw.cc:515:40: warning: ‘v8::Localv8::Boolean v8::Value::ToBoolean() const’ is deprecated: Use maybe version [-Wdeprecated-declarations] bool pause_send = info[1]->ToBoolean ()->Value ();
      iobroker 2019-02-12 12:26:20.564 info ^~~~~
      iobroker 2019-02-12 12:26:20.564 info Local<Boolean> Value::ToBoolean() const {
      iobroker 2019-02-12 12:26:20.564 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10034:16: note: declared here
      iobroker 2019-02-12 12:26:20.564 info from ../src/raw.cc:6:
      iobroker 2019-02-12 12:26:20.564 info from ../src/raw.h:21,
      iobroker 2019-02-12 12:26:20.564 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63:0,
      iobroker 2019-02-12 12:26:20.564 info bool pause_recv = info[0]->ToBoolean ()->Value ();
      iobroker 2019-02-12 12:26:20.564 info ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::Pause(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:509:40: warning: ‘v8::Localv8::Boolean v8::Value::ToBoo
      iobroker 2019-02-12 12:26:20.551 info ^~~~~
      iobroker 2019-02-12 12:26:20.551 info Local<Object> Value::ToObject() const {
      iobroker 2019-02-12 12:26:20.551 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10046:15: note: declared here
      iobroker 2019-02-12 12:26:20.551 info from ../src/raw.cc:6:
      iobroker 2019-02-12 12:26:20.551 info from ../src/raw.h:21,
      iobroker 2019-02-12 12:26:20.551 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63:0,
      iobroker 2019-02-12 12:26:20.551 info Local<Object> buffer = info[2]->ToObject ();
      iobroker 2019-02-12 12:26:20.551 info ../src/raw.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE raw::SocketWrap::GetOption(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:388:44: warning: ‘v8::Localv8::Object v8::Value::To
      iobroker 2019-02-12 12:26:20.502 info ^~~~~
      iobroker 2019-02-12 12:26:20.502 info Local<Object> Value::ToObject() const {
      iobroker 2019-02-12 12:26:20.502 info /home/iobroker/.node-gyp/10.15.0/include/node/v8.h:10046:15: note: declared here
      iobroker 2019-02-12 12:26:20.502 info from ../src/raw.cc:6:
      iobroker 2019-02-12 12:26:20.502 info from ../src/raw.h:21,
      iobroker 2019-02-12 12:26:20.502 info In file included from /home/iobroker/.node-gyp/10.15.0/include/node/node.h:63:0,
      iobroker 2019-02-12 12:26:20.502 info Local<Object> buffer = info[1]->ToObject ();
      iobroker 2019-02-12 12:26:20.502 info ../src/raw.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE raw::CreateChecksum(Nan::NAN_METHOD_ARGS_TYPE)’:../src/raw.cc:82:44: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated
      iobroker 2019-02-12 12:26:16.620 info CXX(target) Release/obj.target/raw/src/raw.o
      iobroker 2019-02-12 12:26:16.595 info make: Verzeichnis „/opt/iobroker/node_modules/raw-socket/build“ wird betreten
      iobroker 2019-02-12 12:26:11.097 info > node-gyp rebuild
      iobroker 2019-02-12 12:26:11.097 info > raw-socket@1.6.4 install /opt/iobroker/node_modules/raw-socket
      iobroker 2019-02-12 12:26:10.911 info found 0 vulnerabilities
      iobroker 2019-02-12 12:26:10.909 info + node-pre-gyp@0.12.0added 66 packages from 25 contributors and audited 97 packages in 6.978s
      iobroker 2019-02-12 12:26:10.905 info created a lockfile as package-lock.json. You should commit this file.
      iobroker 2019-02-12 12:26:10.904 info npm notice
      iobroker 2019-02-12 12:26:01.498 info > npm install node-pre-gyp
      iobroker 2019-02-12 12:26:01.498 info > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      iobroker 2019-02-12 12:25:26.384 info npm install https://github.com/frankjoke/ioBroker.radar2/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      iobroker 2019-02-12 12:25:25.420 info install https://github.com/frankjoke/ioBroker.radar2/tarball/master
      iobroker 2019-02-12 12:25:24.907 info url "https://github.com/frankjoke/ioBroker.radar2" --debug
      Gruß Dirk
      • arteckA
        arteckA
        arteck
        ahhh.. jetzt ja
        also wenn ihr den Adapter vom GIT NEU über die Katze installiert habt und noch kein Adapter installiert war müsst ihr es nochmal über die Katze diesmal über die Option GIT machen.. da steht dieser in der Liste jetzt erst aufgelistet...
        • frankjokeF
          frankjokeF
          frankjoke
          zum Laden von Git:
          In Admin.Adapter auf das Äffchen cklicken und dort dann auf BELIEBIG und dann https://github.com/frankjoke/ioBroker.radar2.
          Das versichert dass von Git die neueste Version geladen wird, auch wenn diese nicht als neue NPM zur Verfügung steht.
          Übrigens, hab zuerst Beta2 von 0.1.2 hochgeladen, mal sehen ob die beiden welche NICHTS sehen doch was hinkriegen!
          Grundsätzlich ist das sehr komisch da der Adapter beim Start Ausgaben macht, bevor er wirklich startet.
          Haben eure Rechner Zugang zum externen Netzt? Hoffentlich schon, sonst funktioniert einiges nicht da der Adapter sich Infos von dort holt.
          wenn nichts zu sehen ist dann bitte mal so starten:
          node /opt/iobroker/node_modules/iobroker.radar2/radar2.js --force --logs --nolazy --debug
          dann sollte er ungefähr so anfangen:
          Adapter initialization started...
          starting main:[Function: main]
          found '@abandonware/noble'
          found 'node-bluetooth'
          Frank,
          NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
          Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
          rantanplanR 1 Antwort Letzte Antwort
          • frankjokeF frankjoke
            zum Laden von Git:
            rantanplanR
            rantanplanR
            rantanplan
            @frankjoke said in [Adapter] Neuer radar2-Adapter:
            zum Laden von Git:
            Das versichert dass von Git die neueste Version geladen wird, auch wenn diese nicht als neue NPM > zur Verfügung steht.
            Schon mehrmals gemacht. Kein Erfolg.
            Für Windows passen die Pfade nicht. Da gibt es kein "/opt/iobroker/...." müsste /iobroker/..." lauten.
            Zudem gibt es bei mir kein Verzeichnis ".../iobroker.radar2/....".
            Da existiert nur das vom alten Adapter ".../iobroker.radar/....
            Hier die Fehlermeldung.
            PS C:\> node /iobroker/node_modules/iobroker.radar2/radar2.js --force --logs --nolazy --debug
            module.js:471
                throw err;
            Error: Cannot find module 'C:\iobroker\node_modules\iobroker.radar2\radar2.js'
                at Function.Module._resolveFilename (module.js:469:15)
                at Function.Module._load (module.js:417:25)
                at Module.runMain (module.js:604:10)
                at run (bootstrap_node.js:394:7)
                at startup (bootstrap_node.js:149:9)
                at bootstrap_node.js:509:3
            PS C:\>
            Rantanplan
            • SegwayS
              SegwayS
              Segway
              schrieb am zuletzt editiert von Segway
              Bei mir gehts einfach nicht
              iobroker 2019-02-12 18:02:03.767 info compilation terminated.
              iobroker 2019-02-12 18:02:03.767 info ^
              iobroker 2019-02-12 18:02:03.767 info ../src/linux/DeviceINQ.cc:35:37: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden #include <bluetooth/bluetooth.h>
              iobroker 2019-02-12 18:01:31.158 info npm install https://github.com/frankjoke/ioBroker.radar2/tarball/master --production --save --prefix "/opt/iobroker" (System call)
              iobroker 2019-02-12 18:01:30.322 info install https://github.com/frankjoke/ioBroker.radar2/tarball/master
              iobroker 2019-02-12 18:01:29.806 info url "https://github.com/frankjoke/ioBroker.radar2"
              EDIT:
              so nun konnte ich es installieren; aber nur weil der Adapter nun im Admin angezeigt wurde und ich auch eine Instanz anlegen konnte.....ich teste weiter
              Gruß Dirk
              frankjokeF 1 Antwort Letzte Antwort
              • SegwayS
                SegwayS
                Segway
                muss da was unter Objekte angelegt sein ?
                Gruß Dirk
                SegwayS 1 Antwort Letzte Antwort
                • SegwayS Segway
                  EDIT:
                  frankjokeF
                  frankjokeF
                  frankjoke
                  schrieb am zuletzt editiert von frankjoke
                  @Segway said in [Adapter] Neuer radar2-Adapter:
                  EDIT:
                  So bitte, hab vergessen euch zu fragen dass ihr IMMER dazuschreibt welches System & Betriebssystem ihr verwendet!
                  @rantanplan, du scheinst Windows zu verwenden, konnte selbst nicht unter Windows testen, nur mit dem automatischen Tester der aber keine Fehler Anzeigt! Der Pfad ist unter Windows anders, hab leider keine Installation momentan für Windows, muss mir erst eine VM bauen aber brauch 'nen Win10 key :(.
                  @Segway, dein Problem scheint schon bei der NPM-Installation aufzutreten. Leider kenne ich das auch von einem externen Testprogramm und habe auch schon einen Case beim Entwickler von node-bluetooth gemacht aber die Einzige Antwort war bis jetzt ob man alle Treiber unter Linux installiert hat, also:
                  sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev
                  Frank,
                  • rantanplanR
                    rantanplanR
                    rantanplan
                    schrieb am zuletzt editiert von rantanplan
                    Hmm, im Admin wird mir radar2 immer noch nicht angezeigt.
                    Die Installatin von Radar v1.2.1 verlief damals problemlos.
                    Na, ich warte mal ab, keine Panik.
                    [EDIT]
                    Habe gerade festgestellt, das die v1.2.1 keine Einstellungen speichert. Das hat aber mal funktioniert.
                    Rantanplan
                    • AsgothianA
                      AsgothianA
                      Asgothian
                      Nach der Installation von Github musst du ggf. manuell noch eine Instanz erzeugen. Ansonsten kommt da auch nix.
                      Schau mal in der Instanz-Liste, ob da eine 1 bei "installiert" steht (blauer Kreis im Screenshot)
                      • SegwayS Segway
                        SegwayS
                        SegwayS
                        Segway
                        Ich finde den Adapter nun nicht unter Objekte. Ich dachte der legt da automatisch was an ???
                        Gruß Dirk
                        • AsgothianA Asgothian
                          frankjokeF
                          frankjokeF
                          frankjoke
                          @Asgothian said in [Adapter] Neuer radar2-Adapter:
                          Ja, das stimmt leider bei manchen ioBroker-Installationen!
                          Jetzt kommts auch drauf an welche Verssion du hast, bei meinen kann ich mit iobroker add radar2 eine Instanz dazukreieren.
                          Manchmal muss auch ein iobroker upload radar2 gemacht werden.
                          Wenn allerdings ein Fehler bei der Git-Installation durch npm eintritt dann hilft's nichts da der Adapter dann nicht von git geladen wird! Du kannst das auf der Kommandozeile mal mit iobroker url https://github.com/frankjoke/ioBroker.radar2/tarball/master probieren (das ist die Kommandozeilenversion vom git-Affen) und life sehen ob nur warnings kommen oder ein kompletter Abbruch mit einem Error!
                          Frank,
                          • crunchipC
                            crunchipC
                            Developer Global Moderator Most Active Forum Testing
                            habe soeben radar Adapter ausgeschaltet, radar2 von git installiert und instanz hinzugefügt, verlief alles fehlerfrei
                            Geräte eingetragen und Instanz gestartet, habe jedoch nun folgende Meldung
                            	instance system.adapter.radar2.0 terminated due to SIGSEGV
                            	instance system.adapter.radar2.0 terminated with code null ()
                              @MathiasJ said in [Adapter] Neuer radar2-Adapter:
                              radar2 ist installiert, aber irgentwie steige ich da nicht durch.
                              ich werde als anwesend getriggrt, aber
                              wie verhält es sich nun mit Blockly?
                              Ich sehe mathias.here........BT, früher stand da true oder false.
                              Edit:
                              läuft jetzt etwas anders.
                              habe den Fehler gefunden.
                              Gruß,
                              Mathias
                              Ja Matthias, mathias ist selbst ein boolscher state und zeigt and ob wer hier war, bzw nich länger als die Abwesenheitszeit weg war.
                              die mathias.here zeigt nur an ob BT oder/und IP da war. Wenn du den Hostnamen deines Handy's (z.b. galaxyS7matthias) in die IP eingibst wirst auch informiert wenn sich das Telefon in dein W-Lan einloggt.
                              mathias.lasthere zeigt wann das Gerät (egal mit BT oder IP) das letzte mal gesehen wurde.
                              apollon77A
                              apollon77A
                              Das ist aber vom Objektdesign nicht sauber und eigentlich unsupported ... Würde ich an Deiner Stelle ändern. Nur States (also die unterste Objektebene) hat einen Wert. Alles oben drüber ist ein channel oder ein device als Objekttyp und hat keinen Wert.
                              Ich weiss das das aktuell nicht verhindert wird, aber versprechen würde ich es auch nicht das das mal kommt.
                              • padrinoP
                                padrinoP
                                padrino
                                könnte man nicht auf etwas mit "probe requests" machen um sich selbst zu erkennen?
                                Muss ja nicht immer nur der Postbote sein. ;)
                                CU,
                                padrino
                                • MathiasJM
                                  MathiasJM
                                  MathiasJ
                                  Was vielleicht auch interessant wäre:
                                  Bei Radar 1 waren auch G-Tags aufgelistet, die nicht anwesend waren. Das fehlt mir jetzt bei Radar 2.
                                  Hintergrund:
                                  Mein Bruder hat einen G-Tag. Er bringt ihn aber nur mit, um das Haus zu hüten, wenn ich auf Reisen bin.
                                  Ich kann jetzt aber kein Programm via Blockly schreiben weil ja dieser G-Tag nicht aufgeführt ist.
                                  Gruß,
                                  Mathias
                                  IObroker auf dem NUC als VM.
                                    frankjokeF
                                    frankjokeF
                                    frankjoke
                                    @crunchip said in [Adapter] Neuer radar2-Adapter:
                                    Hast du:
                                    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                                    sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
                                    ausgeführt? Anders kann ich mir das nicht vorstellen, außer du hast nicht Linux!
                                    Frank,
                                    • MathiasJM MathiasJ
                                      Hintergrund:
                                      Gruß,
                                      Mathias
                                      frankjokeF
                                      frankjokeF
                                      frankjoke
                                      Hintergrund:
                                      Gruß,
                                      Mathias
                                      Du kannst diesen G-Tag ja eintragen, hast hoffentlich seine BT-Mac-Adresse?
                                      Frank,
                                      MathiasJM 1 Antwort Letzte Antwort
                                      • padrinoP padrino
                                        CU,
                                        padrino
                                        frankjokeF
                                        frankjokeF
                                        frankjoke
                                        @padrino said in [Adapter] Neuer radar2-Adapter:
                                        CU,
                                        padrino
                                        Verstehe ich nicht ganz, was meinst du mit 'sich selbst'?
                                        Wenn du dein Handy meinst dann kannst ja:
                                        • den Hostnamen oder die IP-Adresse (wenn dein Router immer die gleiche vergibt)
                                        • Die ip-Mac-Adresse deines Handy's
                                        • und die BT-Adresse
                                          eingeben. Dann wirst du, egal ob mit Wlan oder Bluetooth erkannt.
                                        Frank,
                                          Hast du:
                                          crunchipC
                                          crunchipC
                                          @frankjoke Fehler war nach ca. Einer Viertel Std plötzlich weg und läuft nun.
                                          33.2k
                                          84.3k
