  4. Test Adapter SourceAnalytix v0.2.x
adaptertest
958 Beiträge 103 Kommentatoren 352.1k Aufrufe 71 Beobachtet
  • P Offline
    pcjogi
    #346
    HAllo zusammen ,
    ich bekomme nach der Installation des Adapters und der darauf folgenden Aktivierung folgen de Logeinträge :
    sourceanalytix.0	2019-01-27 17:09:22.469	info	terminating
    sourceanalytix.0	2019-01-27 17:09:22.460	warn	Adapter SourceAnalytix stopped !
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:150:9)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	at initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:171:29)
    sourceanalytix.0	2019-01-27 17:09:22.459	error	TypeError: Cannot read property 'toLowerCase' of undefined
    sourceanalytix.0	2019-01-27 17:09:22.459	error	uncaught exception: Cannot read property 'toLowerCase' of undefined
    sourceanalytix.0	2019-01-27 17:09:22.454	info	Activate SourceAnalytix for : javascript.0.Tasmota.GasCounter.counter
    sourceanalytix.0	2019-01-27 17:09:22.182	info	starting. Version 0.2.26 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v8.15.0</anonymous></anonymous></anonymous>
    Anwenden möchte ich den Adapter für einen Gaszähler. Der Gaszähler hat als Datenpunkt immer den aktuellen Zählerstand. Im Datenpunkt habe ich als Alias Gasverbrauch und als Messart Gas und als Masseinheit m³ angegeben.
    Mach ich etwas falsch, ist das ein Fehler oder ist das noch nicht implementiert?
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      #347
      @do1osc:
      Wenn ich das richtig verstehe, gibt es keine Gesamtauswertung ?
      Das heißt dann, man muss alle Source-Analytix Datenpunkte entsprechend per Skript selbst zusammenrechnen ? `
      was mochtest du den noch zusammenrechnen ?
      Der adapter berechnet dir werte fur Tages, Wochen, Monat,kwartal und Jahres Gesamtverbrauch/Erzeugung.
      In einer später version kannste auch die zehlerstande abspeichern, aber wonach suchst du genau ?
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        #348
        @pcjogi:
        Mach ich etwas falsch, ist das ein Fehler oder ist das noch nicht implementiert? `
        HI, nein du machst nicht falsch der Datenpunkt hat keine unit und mein adapter mag Adas noch nicht so.
        Ich werde den Fehler morgen denke ich mal raus haben, entweder darauf warten oder den state über den Bleistift eine anständige unit verpassen ;)
          do1osc
          #349
          @Dutchman:
          In einer später version kannste auch die zehlerstande abspeichern, aber wonach suchst du genau ? `
          Wenn ich richtig sehe, sind die Werte pro Steckdose, bzw. pro ausgewähltem Objekt.
          Den Gesamtverbrauch über alle ausgewählten Objekte vermisse ich irgendwie, oder habe ich einen Denkfehler ?
          Wo kann ich eigentlich alle Zählerwerte auf 0 zurücksetzen ? Geht das nur manuell ?
          Mit freundlichen Grüßen
          Sven
          • C Offline
            Creator
            #350
            Erfasst du irgendwo den Gesamtverbrauch vom Zähler?
            Dann kannst diesen nutzen. Oder halt Zusammenrechnen?
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #351
              Das konnte drauf an wie du Mist?
              Ja es ist pro Gerät, und so muss es auch sein denn sonst geht die Grundpreis Berechnung schief.
              Außerdem ist eine gesammt Aufzählung von Geräten nicht repräsentativ wenn du den gesammtverbrauch des Hauses messen möchtest musst du an der Hauptader messen (zB smartmeter).
              Dan hat du einen gesammtverbrauch und seperat pro Gerät wen gewünscht.
              Dutch
              • NegaleinN Offline
                NegaleinN Offline
                Negalein
                #352
                Hallo Dutchman!
                Erstmal danke für den Adapter. Sowas hab ich gesucht! :)
                Ich hab heute die Version 0.0.26 installiert! Hat auch einwandfrei funktioniert.
                Allerdings will der Adapter nicht starten!
                Bleibt immer auf "Rot" stehen!
                Hier ein Log dazu.
                host.ioBroker	2019-01-28 16:53:52.826	error	instance system.adapter.sourceanalytix.0 terminated with code 1 ()
                host.ioBroker	2019-01-28 16:53:52.826	error	Caught by controller[0]: at startup (bootstrap_node.js:160:9)
                host.ioBroker	2019-01-28 16:53:52.826	error	Caught by controller[0]: at run (bootstrap_node.js:394:7)
                host.ioBroker	2019-01-28 16:53:52.826	error	Caught by controller[0]: at Module.runMain (module.js:611:10)
                host.ioBroker	2019-01-28 16:53:52.826	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
                host.ioBroker	2019-01-28 16:53:52.826	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
                host.ioBroker	2019-01-28 16:53:52.826	error	Caught by controller[0]: at Module.load (module.js:494:32)
                host.ioBroker	2019-01-28 16:53:52.825	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
                host.ioBroker	2019-01-28 16:53:52.825	error	Caught by controller[0]: at Module._compile (module.js:549:28)
                host.ioBroker	2019-01-28 16:53:52.825	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
                host.ioBroker	2019-01-28 16:53:52.825	error	Caught by controller[0]: at createScript (vm.js:56:10)
                host.ioBroker	2019-01-28 16:53:52.825	error	Caught by controller[0]: SyntaxError: Unexpected token function
                host.ioBroker	2019-01-28 16:53:52.825	error	Caught by controller[0]: ^^^^^^^^
                host.ioBroker	2019-01-28 16:53:52.825	error	Caught by controller[0]: async function calculation_handler(id){
                host.ioBroker	2019-01-28 16:53:52.824	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:297
                ° Fixer ---> iob fix
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  #353
                  Hey Negalein,
                  Welche node Version benutzt du ?
                  ( Auf console node -v Eingeben)
                  • NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #354
                    @Dutchman:
                    Welche node Version benutzt du ? `
                    v6.14.4
                    Ah, gerade auf GIT gesehen, dass mind. Node 8 benötigt wird!
                    • NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #355
                      jetzt ist nur noch für mich (Anfänger) die Frage, wie ich es am einfachsten (ioBroker im Docker) upgedatet bekomme!
                      Reicht "Node" oder muss was anderes auch noch upgedatet werden?
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        #356
                        @Negalein:
                        Danke `
                        Im docker ?
                        Backup machen, neuen Container ziehen und Backup zurück.
                        Soweit ich weis haben die neueren docker Images node8
                        • NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #357
                          @Dutchman:
                          Im docker ?
                          Soweit ich weis haben die neueren docker Images node8 `
                          Ah danke!
                            Brati
                            #358
                            wie kann ich zu einem Wert alle Daten löschen. Hab meine Wasseruhr eingebunden und den Wert im Nachhinein korrigiert, jetzt natürlich einen Verbrauch von "-34.000m³". Objekte löschen half nicht, Adapter löschen auch nicht… Die Werte als Anfangswerte eintragen hat er auch nicht übernommen...
                            Brati
                            • Palm_ManiacP Offline
                              Palm_Maniac
                              #359
                              Wie hast du denn deine Wasseruhr eingebunden? Wie liest du sie aus?
                                Brati
                                #360
                                @Palm_Maniac:
                                Wie hast du denn deine Wasseruhr eingebunden? Wie liest du sie aus? `
                                viewtopic.php?t=3226#p44314
                                Läuft mittlerweile zuverlässig und die Temperatur im Wasserkessel wird auch übermittelt.
                                Grüße Brati
                                • DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  #361
                                  @Brati:
                                  Brati `
                                  Adapter stoppen, im SourceAnalytix Baum bei der device auf Papierkorb klicken jetzt wird alles zu dieser device gelöscht.
                                  Dan Adapter wieder starten, alle states werden neu erstellt mit lehren werten.
                                  Deine neuen Startwerte bleiben anwesend das diese auf dem state des Wertes eingestellt werden
                                  PS : musst du in Liter oder m3?
                                  Startwerte sind immer Kilo also wen du Liter hast da den werten geteilt durch 1000 eintragen!
                                    Brati
                                    #362
                                    @Dutchman:
                                    Startwerte sind immer Kilo also wen du Liter hast da den werten geteilt durch 1000 eintragen! `
                                    Das war der Knackpunkt. Steht jetzt ordentlich auf 0. Die Objekte zeigen allerdings "m³" an, obwohl ich "l" ausgewählt habe.
                                    Brati
                                    • DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #363
                                      @Brati:
                                      Das war der Knackpunkt. Steht jetzt ordentlich auf 0. Die Objekte zeigen allerdings "m³" an, obwohl ich "l" ausgewählt habe. `
                                      Wie erwähnt die Berechnungen sind immer in Kilo also diesem Fall m3.
                                      Die Eingabe von Liter ist nötig damit der Adapter weiß was er zur Berechnung nutzen soll ( l oder m3)
                                        Basti131
                                        #364
                                        Ich wollte den Adapter grade im Multihost nutzen, da erhalte ich im Log den Fehler:
                                        startInstance system.adapter.sourceanalytix.0: required adapter "admin" not found!
                                        Hab die Instanz dann auf den Host gepackt, wo admin liegt, hat aber auch nichts gebracht. Dann Instanz deinstalliert und versucht neu zu installieren auf dem admin- Host, allerdings schließt sich dann das Fenster wo man den Host und die Instanznummer auswählt und nichts passiert.
                                        Adapter komplett deinstalliert, neu installiert, neue Instanz auf adminHost versucht zu installieren:, Einstellungs- Fenster schließt sich wieder und Instanz wird nicht installiert.
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #365
                                          Kan das jemand reproduzieren ?
