[Tutorial] VIS Fritzbox Status & Up/Downloadanzeige
Funtioniert leider immer noch nicht.
Ich hab das JavaSkript nicht in "global" einsortiert, sondern in meiner Standard-Struktur.
schedule("*/1 * * * * *", function () { setState( "upnp.0.FritzBox_6460.WANDevice.WANCommonInterfaceConfig.GetAddonInfos",'send'); setState( "upnp.0.FritzBox_6460.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties",'send'); setState( "upnp.0.FritzBox_6460.WANDevice.WANConnectionDevice.WANIPConnection.GetExternalIPAddress",'send'); setState( "upnp.0.FritzBox_6460.WANDevice.WANConnectionDevice.WANIPConnection.GetStatusInfo",'send'); }); -
Automatisches Abonnent angehakt im UPNP Adapter ?
Zeig bitte mal die Objekt-Übersicht.
Da habe ich andere Werte drinnen als du…..........
PhysicalLinkStatus
UpnpControlEnabled
Guten Abend
Script, Up/Downloadanzeige, Vis funktioniert alles.
Jedoch bekomm ich permanent folgende Fehlermeldungen.
! host.ioBroker-RasPi 2018-09-19 19:16:48.481 info Restart adapter system.adapter.upnp.0 because enabled
! host.ioBroker-RasPi 2018-09-19 19:16:48.481 error instance system.adapter.upnp.0 terminated with code 0 (OK)
! Caught 2018-09-19 19:16:48.481 error by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
! Caught 2018-09-19 19:16:48.481 error by controller[0]: at WebSocket.emit (events.js:214:7)
! Caught 2018-09-19 19:16:48.481 error by controller[0]: at emitTwo (events.js:126:13)
! Caught 2018-09-19 19:16:48.481 error by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
! Caught 2018-09-19 19:16:48.480 error by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
! Caught 2018-09-19 19:16:48.480 error by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
! Caught 2018-09-19 19:16:48.480 error by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
! Caught 2018-09-19 19:16:48.480 error by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! Caught 2018-09-19 19:16:48.480 error by controller[0]: at WS. <anonymous>(/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
! Caught 2018-09-19 19:16:48.480 error by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
! Caught 2018-09-19 19:16:48.480 error by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! Caught 2018-09-19 19:16:48.479 error by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
! Caught 2018-09-19 19:16:48.479 error by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
! Caught 2018-09-19 19:16:48.479 error by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
! Caught 2018-09-19 19:16:48.479 error by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
! Caught 2018-09-19 19:16:48.479 error by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
! Caught 2018-09-19 19:16:48.478 error by controller[0]: RangeError: Maximum call stack size exceeded
! upnp.0 2018-09-19 19:16:48.134 info terminating
! upnp.0 2018-09-19 19:16:48.055 info cleaned everything up…
! upnp.0 2018-09-19 19:16:48.055 info Alive and sid states cleared
! upnp.0 2018-09-19 19:16:48.049 error at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
! upnp.0 2018-09-19 19:16:48.049 error at WebSocket.emit (events.js:214:7)
! upnp.0 2018-09-19 19:16:48.049 error at emitTwo (events.js:126:13)
! upnp.0 2018-09-19 19:16:48.049 error at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
! upnp.0 2018-09-19 19:16:48.049 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
! upnp.0 2018-09-19 19:16:48.049 error at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
! upnp.0 2018-09-19 19:16:48.049 error at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
! upnp.0 2018-09-19 19:16:48.049 error at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! upnp.0 2018-09-19 19:16:48.049 error at WS. <anonymous>(/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
! upnp.0 2018-09-19 19:16:48.049 error at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
! upnp.0 2018-09-19 19:16:48.049 error at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! upnp.0 2018-09-19 19:16:48.049 error at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
! upnp.0 2018-09-19 19:16:48.049 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
! upnp.0 2018-09-19 19:16:48.049 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
! upnp.0 2018-09-19 19:16:48.049 error at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
! upnp.0 2018-09-19 19:16:48.049 error at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
! upnp.0 2018-09-19 19:16:48.049 error RangeError: Maximum call stack size exceeded
! upnp.0 2018-09-19 19:16:48.048 error uncaught exception: Maximum call stack size exceeded</anonymous></anonymous></anonymous></anonymous>
Habe die Abfrage dann von 10 auf 20 Sek. gesetzt, jedoch auch ohne Erfolg.! host.ioBroker-RasPi 2018-09-19 19:32:05.427 error Caught by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
! host.ioBroker-RasPi 2018-09-19 19:32:05.427 error Caught by controller[0]: at WebSocket.emit (events.js:214:7)
! host.ioBroker-RasPi 2018-09-19 19:32:05.427 error Caught by controller[0]: at emitTwo (events.js:126:13)
! host.ioBroker-RasPi 2018-09-19 19:32:05.427 error Caught by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
! host.ioBroker-RasPi 2018-09-19 19:32:05.427 error Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
! host.ioBroker-RasPi 2018-09-19 19:32:05.427 error Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
! host.ioBroker-RasPi 2018-09-19 19:32:05.426 error Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
! host.ioBroker-RasPi 2018-09-19 19:32:05.426 error Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! host.ioBroker-RasPi 2018-09-19 19:32:05.426 error Caught by controller[0]: at WS. <anonymous>(/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
! host.ioBroker-RasPi 2018-09-19 19:32:05.426 error Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
! host.ioBroker-RasPi 2018-09-19 19:32:05.426 error Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
! host.ioBroker-RasPi 2018-09-19 19:32:05.426 error Caught by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
! host.ioBroker-RasPi 2018-09-19 19:32:05.426 error Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
! host.ioBroker-RasPi 2018-09-19 19:32:05.426 error Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
! host.ioBroker-RasPi 2018-09-19 19:32:05.425 error Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
! host.ioBroker-RasPi 2018-09-19 19:32:05.425 error Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
! host.ioBroker-RasPi 2018-09-19 19:32:05.425 error Caught by controller[0]: RangeError: Maximum call stack size exceeded
! >! host.ioBroker-RasPi 2018-09-19 19:32:05.427 error Caught by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
! host.ioBroker-RasPi 2018-09-19 19:32:04.047 info iobroker _restart
! host.ioBroker-RasPi 2018-09-19 19:32:04.046 error RangeError: Maximum call stack size exceeded at new Uint8Array (native) at new FastBuffer (buffer.js:38:5) at Function.Buffer.alloc (buffer.js:245:10) at new Buffer (buffer.js:156:19)
! host.ioBroker-RasPi 2018-09-19 19:32:04.045 error uncaught exception: Maximum call stack size exceeded</anonymous></anonymous></anonymous></anonymous>! upnp.0 2018-09-19 19:38:02.422 warn Error sending SOAP request: Error: connect ETIMEDOUT 192.168.178.1:49000
Was kann ich da noch probieren?Gruss
Hallo, ich finde den Fehler nicht…
Ich bekomme keine Anzeigen angezeigt, es bleibt alles leer.
Siehe Dateien..
Jemand eine Idee?
Cu Deta
9403_screenshot_20181101_162206.png -
Siehe Dateien..
Jemand eine Idee?
Cu Deta `
Moin,
Hast du den Fehler gefunden? ich habe das selbe Problem… habe gemerkt wenn ich den Java-Script von global in den common-Ordner lege werden alle Daten abgerufen und auch richtig geschrieben.
MfG Paul
Hatte keine Zeit mehr in lezter Zeit da weiter zu suchen! Ich kann es bei Gelegenheit mal probieren. Danke für den Tip.
Moin zsaummen,
gibt es hier auch welche die bei vodafone sind (Kabeldeutschland) wo der Up/Download nicht gezählt wird… Weil alles wird angezeigt nur eben nicht was ich verbraucht habe. ( Box von KD ist die 6490 )
Danke für eure Info `
Habe auch eine 6490 bei VF/KD. Sehe auch keinen Verbrauch
Ok, danke dir für deine Info. Dann muss es ja an KD (Vodafone) oder am Image von der KD-FritzBox liegen …. Ärgerlich :roll:
Moin zsaummen,
Habe auch eine 6490 bei VF/KD. Sehe auch keinen Verbrauch `
Moin zsaummen,
Welches Fritz OS hast du auf der 6490, aktuell ist auch für die OS 7.01.
Oder ist da eine angepasste Version drauf von Vodafone.
Also meine hat noch
Die ist ja von KD angepasst, man könnte die Box ja rooten aber das lass ich lieber `
Nö, wenn Du alle Zugangsdaten hast dann kann man auch mit einer normalen Fritz da dran d.h.entweder mal ne andere besorgen zum testen oder das OS in vorhandener eben rooten mit aktuellem
OS von AVM. Hatte mal vor vielen Jahren eine von 1und1. Nach Umzug zur Teledumm, der Fritz
das aktuellste OS verpasst und lief.
Joar, aber man weiß ja nicht ob dieses unser Problem löst das er Verbrauch gezählt wird. `
Muß aber, da der Verbrauch die Fritz speichert und nicht Vf ;) -
Naa, er wird ja auch jetzt gespeichert. Nur eben nicht ausgelsen von Upnp.
daten.png `
Dann liegt es vielleicht am OS von Df. Habe unter 7.01 und auch der aktuellen Beta 07.08-64610 BETA keine Probleme gehabt.
Was ich aber anmerken muß, unter 7.01 wurde der Datenpunkt für Gast-Wlan nicht aktualisiert, mit der Beta ist das Problem
behoben. Könnte also auch sein das unter deinem 6.87 dort ein Bug ist aber das weiß jetzt nur AVM.
