  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • sigi234S Online
    sigi234S Online
    #1432
    • simatecS Online
      simatecS Online
      simatec
      #1433
      Löscht mal die Datei .update… danach startet der Adapter neu.
      Ich fixe das gleich.
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • sigi234S Online
        sigi234S Online
        #1434
        Danke, geht wieder….......
        backitup.0	2019-01-06 11:11:40.579	debug	[total] 10 00 03 */7 * *
        backitup.0	2019-01-06 11:11:40.579	info	[total] backup was activated at 03:00 every 7 day(s)
        backitup.0	2019-01-06 11:11:40.579	debug	[ccu] 10 30 04 */3 * *
        backitup.0	2019-01-06 11:11:40.577	info	[ccu] backup was activated at 04:30 every 3 day(s)
        backitup.0	2019-01-06 11:11:40.577	debug	[minimal] 10 00 02 */1 * *
        backitup.0	2019-01-06 11:11:40.566	info	[minimal] backup was activated at 02:00 every 1 day(s)
        backitup.0	2019-01-06 11:11:40.527	info	starting. Version 1.0.2 in C:/ioBroker/node_modules/iobroker.backitup, node: v8.15.0
        backitup.0	2019-01-06 11:11:40.386	debug	statesDB connected
        backitup.0	2019-01-06 11:11:40.386	debug	objectDB connected
        backitup.0	2019-01-06 11:11:16.034	debug	system.adapter.admin.0: logging true
        backitup.0	2019-01-06 11:11:14.028	debug	[total] 10 00 03 */7 * *
        backitup.0	2019-01-06 11:11:14.028	info	[total] backup was activated at 03:00 every 7 day(s)
        backitup.0	2019-01-06 11:11:14.027	debug	[ccu] 10 30 04 */3 * *
        backitup.0	2019-01-06 11:11:14.027	info	[ccu] backup was activated at 04:30 every 3 day(s)
        backitup.0	2019-01-06 11:11:14.026	debug	[minimal] 10 00 02 */1 * *
        backitup.0	2019-01-06 11:11:14.021	info	[minimal] backup was activated at 02:00 every 1 day(s)
        backitup.0	2019-01-06 11:11:13.979	info	starting. Version 1.0.2 in C:/ioBroker/node_modules/iobroker.backitup, node: v8.15.0
        backitup.0	2019-01-06 11:11:13.939	debug	statesDB connected
        backitup.0	2019-01-06 11:11:13.930	debug	objectDB connected
        • simatecS Online
          simatecS Online
          simatec
          #1435
          Hintergrund der .update ist folgender gewesen.
          Für den stop und start werden shells vom Adapter erstellt.
          Da diese automatisch angelegt werden und sich hier bei dem Update der Inhalt geändert hat, sollte die Datei .update dafür sorgen, dass die shell beim ersten Start nach dem Update gelöscht werden.
          Anscheinend ist es aber so, dass diese beim Update sowieso gelöscht sind und neu erstellt werden.
          Von daher der error, da backitup die shells nicht findet.
          Wie gesagt ich fixe das gleich, damit backitup wieder sauber läuft
          • Merlin123M Offline
            Merlin123M Offline
            Merlin123
            #1436
            Danke für den schnellen Fix!
            Gesendet von meinem CLT-L09 mit Tapatalk
            Beta-Tester
            • J Offline
              Jan1
              #1437
              Wurde die Version hoch gezählt? Ich hatte eben mal kurz wieder die 1.0.2 drauf und die hatte das selbe Problem, allerdings liegt bei mir auch keine .update im lib Verzeichnis.
              • simatecS Online
                simatecS Online
                simatec
                #1438
                Ab sofort ist die Version 1.0.3 im Github und latest verfügbar.
                1.0.3 (06.01.2019)
                (simatec) Bugfix
                • simatecS Online
                  simatecS Online
                  simatec
                  #1439
                  @Jan1:
                  Wurde die Version hoch gezählt? Ich hatte eben mal kurz wieder die 1.0.2 drauf und die hatte das selbe Problem, allerdings liegt bei mir auch keine .update im lib Verzeichnis. `
                  Dann hast du sicher die Anzeige für versteckte Dateien ausgeschaltet
                  Mit Version 1.0.3 ist der Fehler behoben.
                  • J Offline
                    Jan1
                    #1440
                    im latest hab ich immer noch die 1.0.2 drin :?:
                    und ja ich hab die Adapter eite mehrfach neu geladen ;)
                      #1441
                      wenn er das gerade gepusht hat ist es morgen im latest
                      • DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #1442
                        Habe eben auf 1.0.3 mit der Katze geupdatet und läuft wieder.
                        ..:: So long! Tom ::..
                        • simatecS Online
                          simatecS Online
                          simatec
                          #1443
                          Im latest wird es erst heute Nacht sein.
                          Für alle die Probleme haben, bitte über github updaten (oben der Button mit die Katze in den Adapter Tab)
                          Sorry nochmal für den eingeschlichenen Bug.
                          • J Offline
                            Jan1
                            #1444
                            Jou die Katz hatts gerettet :lol:
                            • bergjetB Offline
                              bergjetB Offline
                              bergjet
                              #1445
                              @simatec:
                              Sorry nochmal für den eingeschlichenen Bug. `
                              Danke, läuft.
                              homee, ioBroker, iMac, iPhone, Sonos, Alaxa
                              • bergjetB Offline
                                bergjetB Offline
                                bergjet
                                #1446
                                Habe den ioBroker zerschossen.
                                Aber mit backitup ein vollständiges Backup gemacht. Das liegt am NAS.
                                Laut Beschreibung soll ich nun diese Datei ins Wurzelverzeichnis root/ kopieren. Aber wie mache ich das?
                                • StM47S Offline
                                  StM47S Offline
                                  StM47
                                  #1447
                                  Ich würde ioBroker neu aufsetzten, dann Backitup installieren und dann das Backup direkt mit Backitup wieder herstellen.
                                  ioBroker im Docker auf Synology DiskStation DS 716+II mit DSM 6.2.1
                                  • Lightmanager Air / Lupusec XT2 Plus mit div. Fenster- u. Türkontakten, Rauch- u. Bewegungsmelder / Harmony Hub / Fritzbox 7590 OS7
                                  • schaltbare Steckdosen / Alexa Echo Dot 3 / Zigbee USB Stick / diverse Xiaomi Produkte / Xiaomi Yeelight Birnen
                                  • simatecS Online
                                    simatecS Online
                                    simatec
                                    #1448
                                    @bergjet:
                                    Laut Beschreibung soll ich nun diese Datei ins Wurzelverzeichnis root/ kopieren. Aber wie mache ich das? `
                                    Installiere backitup und stelle direkt in backitup dein backup wieder her.
                                    Dort gibt es einen Tab Restore (Wiederherstellen)
                                    Am besten du legst dein backup vorher in den Ordner /opt/iobroker/backup
                                    • bergjetB Offline
                                      bergjetB Offline
                                      bergjet
                                      #1449
                                      @simatec:
                                      Installiere backitup und stelle direkt in backitup dein backup wieder her. `
                                      Ich kann auf die ioBroker Webseite nicht mehr zugreifen, daher auch nicht installieren.
                                      • simatecS Online
                                        simatecS Online
                                        simatec
                                        #1450
                                        Dann das backup in /opt/iobroker legen und den Befehl laut doku ausführen
                                        • PeoplesP Offline
                                          PeoplesP Offline
                                          Peoples
                                          #1451
                                          @bergjet:
                                          @simatec:
                                          Ich kann auf die ioBroker Webseite nicht mehr zugreifen, daher auch nicht installieren. `
                                          So war das nicht gemeint. Sondern:
                                          • Iobroker komplett neu Installieren
                                          • Wenn alles läuft den Backitup - Adapter installieren
                                          • Via Winscp oder FTP-Programm dein Backup von deiner Nas händisch in das Verzeichnis /opt/iobroker/backups/ kopieren
                                          • Über die Adapteroberfläche dieses Backup auswählen und Widerherstellen klicken
                                          mach ich regelmäßig auf den Testsystemen dauert ca. ne Stunde
                                          Alternativ könntest du evtl. auch via putty auf deinen raspberry oder was du da hast und den Befehl via Konsole ausführen
