  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • J Offline
    jensus11
    #843
    Hi, ich möchte gerne per NFS sichern.
    Hatte das auch schon am laufen. Jetzt musste ich feststellen das mit dem neuen Update keine Backups mehr auf dem Qnap gesichert werden.
    Im Log steht folgendes:
    ! Gestartet…
    ! [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXX","pass":""}
    ! [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.8.65:/BackupNFS/ioBroker
    ! [ERROR] [mount] - [IGNORED] Error: Command failed: mount 192.168.8.65:/BackupNFS/ioBroker /opt/iobroker/backups
    ! mount.nfs: access denied by server while mounting 192.168.8.65:/BackupNFS/ioBroker
    ! [DEBUG] [minimal] start with {"type":"creator","time":"02:15","debugging":true,"everyXDays":"2","nameSuffix":"ioBroker","deleteBackupAfter":0,"extensionsEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXXXX","pass":"
    ","context":{"fileNames":[],"errors":{},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"192.168.8.65","deleteOldBackup":false,"dir":"/BackupNFS/ioBroker","user":"XXXX","pass":"XXXXXX","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXXX","pass":"XXXXXXXX"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","dir":"/backupDir"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    ! [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2018_10_07-17_25_24_ioBroker_backupiobroker.tar.gz
    ! [DEBUG] [minimal] - done
    ! [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXXX","pass":"","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
    ! [DEBUG] [cifs] - done
    ! [DEBUG] [clean] start with {"deleteBackupAfter":0}
    ! [DEBUG] [clean] - done
    ! [DEBUG] [telegram] start with {"type":"creator","time":"02:15","debugging":true,"everyXDays":"2","nameSuffix":"ioBroker","deleteBackupAfter":0,"extensionsEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXXX","pass":"
    ","context":{"fileNames":["/opt/iobroker/backups/minimal_2018_10_07-17_25_24_ioBroker_backupiobroker.tar.gz"],"errors":{},"done":["minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"192.168.8.65","deleteOldBackup":false,"dir":"/BackupNFS/ioBroker","user":"XXXXX","pass":"XXXXXXXX","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXXX","pass":"XXXXXXX"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","dir":"/backupDir"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de","time":"07 Oktober 2018 um 17:25 Uhr"},"backupDir":"/opt/iobroker/backups"}
    ! [DEBUG] [telegram] - [minimal] used Telegram-Instance: telegram.0
    ! [DEBUG] [telegram] - done
    ! [DEBUG] [history] start with {"type":"creator","time":"02:15","debugging":true,"everyXDays":"2","nameSuffix":"ioBroker","deleteBackupAfter":0,"extensionsEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXXX","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2018_10_07-17_25_24_ioBroker_backupiobroker.tar.gz"],"errors":{},"done":["minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"192.168.8.65","deleteOldBackup":false,"dir":"/BackupNFS/ioBroker","user":"XXXX","pass":"XXXXXXXXXXX","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXX","pass":"XXXXXXXXXXX"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","dir":"/backupDir"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"07 Oktober 2018 um 17:25 Uhr"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    ! [DEBUG] [history] - backitup.0.history.html
    ! [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"Local","mount":"192.168.8.65","deleteOldBackup":true,"dir":"BackupNFS/ioBroker","user":"XXXXX","pass":"
    ","backupDir":"/opt/iobroker/backups"}
    ! [ERROR] [umount] - umount: /opt/iobroker/backups: not mounted.
    ! [ERROR] [umount] - [IGNORED] Error: Command failed: umount /opt/iobroker/backups
    ! umount: /opt/iobroker/backups: not mounted.
    ! [EXIT] 0
    • simatecS Offline
      simatecS Offline
      simatec
      #844
      Das sieht mir danach aus, als ob dein Server nicht antwortet oder die Verbindung blockiert
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • dslraserD Offline
        dslraserD Offline
        dslraser
        #845
        Also ich habe nun auch nochmal alle Einstellungen probiert. Bei mir funktioniert nur FTP wie gewünscht. Backups werden in allen Varianten erstellt (NFS/Cifs…) aber nur per FTP landen die im richtigen Verzeichnis. Egal ob mit oder ohne Slash vorm Pfad.
          Dice19
          #846
          Der Ladering ist weg. Hab ein Monitor am Pi hängen, bisher kein neustart vom Pi selbst.
          Jetzt läuft oben der blaue Balken durch.
          Gestern habe ich mal auf schließen geklickt was auch geht….
          Aber nun weiter warten???
          1Stunde 15min sind vorbei ohne das was passiert ist. Der blaue Balken läuft oben immer noch durch und steht gestartet im Feld...
          • MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            #847
            Bleiben eigentlich die Backups auf /opt/iobroker/backups?
            Ich habe heute wieder ne Menge Backups löschen müssen.
            Gruß,
            Mathias
            Gesendet von meinem SM-N915FY mit Tapatalk
            IObroker auf dem NUC als VM.
            • J Offline
              jensus11
              #848
              @dslraser:
              Also ich habe nun auch nochmal alle Einstellungen probiert. Bei mir funktioniert nur FTP wie gewünscht. Backups werden in allen Varianten erstellt (NFS/Cifs…) aber nur per FTP landen die im richtigen Verzeichnis. Egal ob mit oder ohne Slash vorm Pfad. `
              Genau das gleiche habe ich bei mir auch.
              Per FTP geht super, nur die anderen Arten funktionieren nicht.(bin aber der Meinung das das schon mal ging)
              Proxmox Backup kann ich per NFS sichern.
              Hast du auch die Fehler die ich habe?
              • dslraserD Offline
                dslraserD Offline
                dslraser
                #849
                @jensus11:
                @dslraser:
                Hast du auch die Fehler die ich habe? ` Die Fehler sehen identisch aus.
                • simatecS Offline
                  simatecS Offline
                  simatec
                  #850
                  @MathiasJ:
                  Gruß,
                  Mathias
                  Gesendet von meinem SM-N915FY mit Tapatalk `
                  Wenn du per cifs oder nfs sicherst und zuvor noch backups im iobroker dir hattest, werden die nicht berücksichtigt.
                  Immer nur die NAS Option, die du ausgewählt hast.
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    #851
                    @jensus11:
                    @dslraser:
                    Dann kann kein mount ausgeführt werden.
                    Es wurde hier schon sehr oft geschrieben und steht auch in der Doku.
                    Bei cifs und nfs darf in der Pfadangabe kein / am Anfang stehen.
                    Die dementsprechenden Pakete für cifs und nfs müssen ebenfalls installiert sein.
                    Steht alles in der Doku.
                    Cifs und nfs funktionieren problemlos in der aktuellen Version.
                    Da wurde auch in den letzten Versionen nix geändert.
                    Bitte überprüft eure config und die Einstellungen auf eurem NAS.
                    Des Weiteren bitte auch die Doku genau lesen.
                    Unter Host auch nur die IP oder den Hostname vom NAS eintragen.
                    Der genaue Pfad darf da nicht rein.
                    Wie gesagt, cifs und nfs sind getestet und laufen problemlos.
                    Voraussetzung ist aber eine richtige Config vom Adapter und NAS.
                    • simatecS Offline
                      simatecS Offline
                      simatec
                      #852
                      @tobih83:
                      1Stunde 15min sind vorbei ohne das was passiert ist. Der blaue Balken läuft oben immer noch durch und steht gestartet im Feld... `
                      Wie lang hat der Vorgang gebraucht, bis iobroker wieder gestartet ist?
                        Dice19
                        #853
                        @simatec:
                        @tobih83:
                        Gesendet von iPhone mit Tapatalk `
                        Max 10min wenn nicht sogar 5-6min.
                        Seitdem läuft der Balken nur noch im Fenster und gestartet steht im Feld.
                        • simatecS Offline
                          simatecS Offline
                          simatec
                          #854
                          Dann ist der Restore erfolgreich durch.
                            Dice19
                            #855
                            Nein leider nicht.
                            Stand ist wie vorher.
                            Keine Skripte, keine Instanzen etc vorhanden
                            • simatecS Offline
                              simatecS Offline
                              simatec
                              #856
                              Dann ist das backup noch vor der Version 0.3.0 erstellt wurden.
                              Prüfe auch mal bitte die Datei, ob sie eventuell beschädigt ist.
                              Hast du eventuell noch ein minimal Backup
                                Dice19
                                #857
                                Wie kann ich das prüfen?
                                Hab ein zweites Backup hochgeladen aber er zeigt mir nur das eine an bzw das aktuellste.
                                Waren 3 Backups im Ordner aber nur eins angezeigt.
                                • simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #858
                                  Wie sehen die Dateinamen deiner Backups aus.
                                  Mach mal bitte ein Screenshot.
                                    Dice19
                                    #859
                                    @simatec:
                                    So wurde sie aufm NAS abgelegt
                                    Er zeigt mir aber nur das vom 7.10. an
                                    Die anderen nicht.
                                    Gibt es die Möglichkeit eine ältere Version von Backitup zu installieren??? Klappt es dann vielleicht??
                                    • simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #860
                                      Warum hat dein minimal von heute Nacht 296 MB?
                                      Nimm das minimal vom 3.10 und stelle es über den Restore von backitup wieder her.
                                      • simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #861
                                        @simatec:
                                        Dann sollte auch alles wieder da sein.
                                          Dice19
                                          #862
                                          Gibt es nicht die Möglichkeit eine ältere Version zu installieren von dem Adapter?
                                          Die Datei ist eine ältere von vor 2 oder 3 tagen die ich mal unbenannt hatte zum testen
                                          Habe nur die Auswahl in dem Adapter.-….
