  4. Adapter "smartmeter"
    1.0k
3.6k Beiträge 281 Kommentatoren 3.1m Aufrufe 162 Beobachtet
  • apollon77A Offline
    #974
    Dann musst du mal suchen in welchem node_modules Du alles "serialport" Verzeichnisse findest und dort drin ein "npm rebuild" ausführen
      mig81
      #975
      [    0.805260] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
      [    0.807572] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    0.809872] usb usb1: Product: DWC OTG Controller
      [    0.812132] usb usb1: Manufacturer: Linux 4.9.41-v7+ dwc_otg_hcd
      [    0.814398] usb usb1: SerialNumber: 3f980000.usb
      [    0.817461] hub 1-0:1.0: USB hub found
      [    0.819657] hub 1-0:1.0: 1 port detected
      [    0.822403] dwc_otg: FIQ enabled
      [    0.822407] dwc_otg: NAK holdoff enabled
      [    0.822411] dwc_otg: FIQ split-transaction FSM enabled
      [    0.822425] Module dwc_common_port init
      [    0.822659] usbcore: registered new interface driver usb-storage
      [    0.824988] mousedev: PS/2 mouse device common for all mice
      [    0.828054] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
      [    0.830598] bcm2835-cpufreq: min=600000 max=1200000
      [    0.833238] sdhci: Secure Digital Host Controller Interface driver
      [    0.835544] sdhci: Copyright(c) Pierre Ossman
      [    0.838071] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
      [    0.842658] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
      [    0.845186] sdhci-pltfm: SDHCI platform and OF driver helper
      [    0.850221] ledtrig-cpu: registered to indicate activity on CPUs
      [    0.852885] hidraw: raw HID events driver (C) Jiri Kosina
      [    0.855526] usbcore: registered new interface driver usbhid
      [    0.857980] usbhid: USB HID core driver
      [    0.861221] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
      [    0.865427] Initializing XFRM netlink socket
      [    0.867962] NET: Registered protocol family 17
      [    0.870582] Key type dns_resolver registered
      [    0.873401] Registering SWP/SWPB emulation handler
      [    0.876601] registered taskstats version 1
      [    0.879361] vc-sm: Videocore shared memory driver
      [    0.881882] [vc_sm_connected_init]: start
      [    0.884782] [vc_sm_connected_init]: end - returning 0
      [    0.893408] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 220, base_baud = 31250000) is a 16550
      [    0.898915] sdhost: log_buf @ bad07000 (fad07000)
      [    0.980353] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
      [    0.985014] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
      [    0.987449] mmc-bcm2835 3f300000.mmc: DMA channel allocated
      [    1.040415] Indeed it is in host mode hprt0 = 00021501
      [    1.102868] of_cfs_init
      [    1.105202] of_cfs_init: OK
      [    1.107827] Waiting for root device PARTUUID=b9ec6a26-02...
      [    1.119923] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    1.123713] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.125139] random: fast init done
      [    1.129350] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.134352] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    1.169682] mmc0: host does not support reading read-only switch, assuming write-enable
      [    1.179681] mmc0: new high speed SDXC card at address d555
      [    1.182516] mmcblk0: mmc0:d555 SU64G 59.5 GiB
      [    1.188600]  mmcblk0: p1 p2
      [    1.226501] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [    1.228821] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [    1.240356] usb 1-1: new high-speed USB device number 2 using dwc_otg
      [    1.242739] Indeed it is in host mode hprt0 = 00001101
      [    1.306022] mmc1: new high speed SDIO card at address 0001
      [    1.470691] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
      [    1.473091] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    1.476295] hub 1-1:1.0: USB hub found
      [    1.478690] hub 1-1:1.0: 5 ports detected
      [    1.800355] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
      [    1.930595] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
      [    1.932992] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    1.938271] smsc95xx v1.0.5
      [    2.034007] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:34:2b
      [    2.130353] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
      [    2.265154] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=ea60
      [    2.267821] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    2.270492] usb 1-1.3: Product: CP2104 USB to UART Bridge Controller
      [    2.273141] usb 1-1.3: Manufacturer: Silicon Labs
      [    2.275772] usb 1-1.3: SerialNumber: 015A9A02
      [    7.483713] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [    7.486463] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
      [    7.488980] EXT4-fs (mmcblk0p2): recovery complete
      [    7.511058] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [    7.515939] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    7.531033] devtmpfs: mounted
      [    7.535298] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
      [    7.998517] systemd[1]: System time before build time, advancing clock.
      [    8.116657] NET: Registered protocol family 10
      [    8.138668] ip_tables: (C) 2000-2006 Netfilter Core Team
      [    8.167806] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
      [    8.176550] systemd[1]: Detected architecture arm.
      [    8.189869] systemd[1]: Set hostname to <all-in-one-pi>.
      [    8.461661] systemd-sysv-generator[104]: Overwriting existing symlink /run/systemd/generator.late/iobroker.service with real service.
      [    8.779499] systemd[1]: [/lib/systemd/system/redis-server.service:14] Unknown lvalue 'RunTimeDirectory' in section 'Service'
      [    8.816711] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    8.826722] systemd[1]: Listening on fsck to fsckd communication Socket.
      [    8.850252] systemd[1]: Listening on udev Control Socket.
      [    8.857155] systemd[1]: Listening on Syslog Socket.
      [    8.863798] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
      [    8.870417] systemd[1]: Listening on Journal Socket (/dev/log).
      [    9.052072] eq3_char_loop: loading out-of-tree module taints kernel.
      [    9.074439] bcm2835_raw_uart: Driver successfully loaded for uart0_base=0x3f201000, uart0_irq=87.
      [    9.442559] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    9.663781] systemd-journald[113]: Received request to flush runtime journal from PID 1
      [   10.253496] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
      [   10.564683] usbcore: registered new interface driver brcmfmac
      [   10.602612] usbcore: registered new interface driver usbserial
      [   10.602697] usbcore: registered new interface driver usbserial_generic
      [   10.602778] usbserial: USB Serial support registered for generic
      [   10.608632] usbcore: registered new interface driver cp210x
      [   10.608736] usbserial: USB Serial support registered for cp210x</all-in-one-pi>
      Ist hier alles in Ordnung?
      Ich habe den Serialport mit –-var SerialPort = require('serialport');var SerialPort --- installiert. Den vzlogger.conf Code kopiert und damit ein neuen Scripts angelegt. Ist das so richtig?
      bekomme immer noch als Log:
      smartmeter.0	2018-09-20 15:49:16.352	info	ERROR CLOSING SERIALPORT: Error: Port is not open
      smartmeter.0	2018-09-20 15:49:16.352	warn	Error on Baudrate changeover: Error: Port is not open
      smartmeter.0	2018-09-20 15:49:16.351	info	Error: Error on Baudrate changeover: Error: Port is not open
      smartmeter.0	2018-09-20 15:49:16.300	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.11.4
      smartmeter.0	2018-09-20 15:49:11.201	info	terminating
      • StabilostickS Offline
        Stabilostick
        #976
        Wo steht beim smartmeter-Adapter was von Script anlegen?
          #977
          Ich kann in der Ausgabe sich nichts dazu finden wie der usb Name von dem usb device ist. Die letzten zwei Zeilen sehen nach dem ir Kopf aus aber gefühlt fehlt da was.
          Gesendet vom Handy …
            Marc_St
            #978
            Lesekopf gekauft, eingesteckt, den Adapter von apollon77 installiert … läuft! Danke, apollon77!
            Jetzt einfach noch ein paar Skripte für Kosten usw schreiben ... dann habe ich alles. Super!
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              #979
              @Marc_St:
              Jetzt einfach noch ein paar Skripte für Kosten usw schreiben … dann habe ich alles. Super! `
              Dafür gibt es bereits ein Strom/smartmeter Script ;)
              • P Offline
                ple
                #980
                Hallo Hallo zusammen,
                es ist mal wieder an der Zeit ein wenig zu basteln. Bisher nehmen ich die Werte vom Stromzähler mit dem Homematic LED Dingen auf.
                Aber alle 3 min, ist mir einfach zu lange, daher muss was neues her. Das Projekt bin ich schon mal angegangen, aber irgendwie aus Zeitmangel wieder aufgegeben. Nun soll es aber voran gehen.
                Kennt jemand zufällig den Itron ACE 3000 Typ 100?
                Laut Beschreibungen im Netz dürfte der garnichts haben, außer eine LED für die Impulse. Nun habe ich aber gesehen, dass der unten rechts noch S0 hat. Hab das auch mal gemessen am 21/20, der schaltet auch.
                Jetzt frag ich mich, ob der nicht auch noch D0 hat, damit ich den Smartmeter nutzen kann, welches mehr Charme bietet. Also über verriegelt sind 2 Linsen zu sehen. Kann das vielleicht sein, dass der D0 kann? Wenn ja, welchen Lesekopft sollte ich mir mal bestellen, damit ich die Werte im Iobroker bekomme, der auf einen Nuc unter Proxmox läuft?
                Falls das kein D0 ist, dann müsste ich auf die S0 Schnittstelle ausweichen und einen Wemos Zwischenhängen.
                Gruß und Danke
                Intel Nuc + Proxmox
                  Stabilostick
                  #981
                  Der ACE3000 Typ 100/110 hat bis zu zwei S0-Ausgänge. Erst der Typ 260 hat D0.
                  • P Offline
                    ple
                    #982
                    Dann sind die Dioden auf dem Bild von mir nur so da? Oder ist das für was anderes.
                    Irgendwie komisch der ganze Zähler.
                    Intel Nuc + Proxmox
                      Stabilostick
                      #983
                      siehe PN.
                      Und
                      https://www.mwatechnology.com/wp-conten … CE3000.pdf
                      • P Offline
                        ple
                        #984
                        hab schon gesehen, ich hab den 100, der ist ein Single, sollte eigentlich garnichts können, der 110 hat S0 und die Dioden sind anscheinend nur zum umproggen ob 500 oder 1000 Impulse.
                        Also doch zurück zum Wemos und noch rumscripten für den Verbrauch. :-(
                        Intel Nuc + Proxmox
                          Stabilostick
                          #985
                          Vergleich mal mit dem Typ 260 auf der Volkszähler-Webseite.
                            Stabilostick
                            #986
                            @ple:
                            tja, keine Ahnung. :-( `
                            Ich mag S0 nicht. Der absolute Zählerstand bei D0 ist Gold wert. Und auch die kurzen Messintervalle, z.B um Verbraucher direkt zu erkennen oder schnelle Regelungen zu machen.
                            Ich würde, auch um unabhängig vom Messstellenbetreiber zu sein, immer wieder einen eigenen D0 oder Modbus-Zähler o.ä. einsetzten. Ich benutze bei mir das Energy Meter von SMA.
                            • P Offline
                              ple
                              #987
                              ja, dann bin ich wieder am Anfang.
                              ich mach mich mal schlau nach dem Energy Meter.
                              Intel Nuc + Proxmox
                                #988
                                Naja kannst ja mal testen ob die LEDs was senden!!
                                Nimm einen Fotoapparat (Handys gehen nicht so gut) und halte ihn draufging schau aufs Display und mach dunkel. Wenn die was senden sieht man das meistens weil dies Ann leicht lila zu sehen sind.
                                  Stabilostick
                                  #989
                                  Der Tipp von apollon77 ist gut. Wobei der Typ 270 sendet erst etwas, wenn er eine Anfragesequenz über Infrarot bekommen hat.
                                  Das Energy Meter-20 von SMA, das ich verwende ist 7cm breit. Es benötigt einen Ethernet-Anschluss im Zählerkasten und sendet die Messwerte im Sekundentakt per Broadcast ins Netzwerk, jeweils Wirk-, Blind- und Scheinleistung pro Phase sowie Spannungen und Ströme. Und natürlich den aktuellen Verbrauch bzw. Lieferung sowie eigene Zählerstände. Es gibt dafür auch eine App im iOS-AppStore. Der Preis ist mit etwa 320€ aber eher im höheren Segment angesiedelt.
                                  https://www.photovoltaik4all.de/media/p … 0web-1.pdf
                                  Der zugehörige Adapter ist der Folgende:
                                  https://github.com/CTJaeger/ioBroker.sma-em
                                  Im Forum gibt es noch Beispiele für andere Smartmeter, die z.B. per Modbus auslesbar sind.
                                  • P Offline
                                    ple
                                    #990
                                    Ich glaub ich geh den Weg mit dem SMA Meter, schon mal danke für die Info.
                                    Intel Nuc + Proxmox
                                      Stabilostick
                                      #991
                                      Wenn Du noch etwas mehr Geld ausgibst, gibt es den SMA Homemanager 2.0
                                      Wenn Du eine PV-Anlage hast, ist der HM mit der automatischen Einschaltung von Verbrauchern abhängig vom Verbrauchsprofil der Vergangenheit und dem erwarteten Wetter echt cool.
                                      Träum: Das mit ioBroker lösen….
                                      Wie gesagt, es gibt günstigere Smartmeter....
                                      • P Offline
                                        ple
                                        #992
                                        Ne im Moment nicht, würde vielleicht kommen, wenn das Elternhaus umgebaut wird aber für meine Eigentumswohnung ein wenig zuviel.
                                        Günstigere hatte ich mir mal angesehen, wäre auch eine Option, dachte da an Mbus um später auch meine Wasserzähler mit Mbus auszurüsten sowie die Wärmemengenzähler die noch im Moment auf WM-bus laufen.
                                        Aber der SMA ist auch beruflich interessant für unser Energiemanagement, da könnte man bei nächsten Audit was zeigen zudem ist er einfach einzubinden, Netzwerk dran und gut ist.
                                        Intel Nuc + Proxmox
                                          Stabilostick
                                          #993
                                          Das Protokoll beim SMA ist public.
