  4. Js-controller 1.5.0 (Ann) wurde freigegeben.
67 Beiträge 21 Kommentatoren 18.5k Aufrufe 1 Beobachtet
  • sigi234S
    sigi234S
    Herzlichen Dank…........ :D
    Habe leider ein Problem seit dem update:
    viewtopic.php?f=30&p=176746#p176746
    Ist auf Windows und PI3 so…......
    Vorläufige Lösung siehe:
    viewtopic.php?f=30&p=176936#p176936
    • F
      F
      fraeggle
      Hab beim Update folgende Fehlermeldungen bekommen.
      io@ioBroker:/opt/iobroker$ sudo iobroker upgrade self
      Update js-controller from @1.4.2 to @1.5.0
      NPM version: 3.10.10
      npm install iobroker.js-controller@1.5.0 –unsafe-perm --production --save --pre fix "/opt/iobroker" (System call)
      ../src/diskusage_posix.cpp: In function ‘DiskUsage GetDiskUsage(const char*)’:
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_bsize’ [-Wmissing-field-initializers]
      struct statvfs info = {};
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_frsize’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_blocks’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_bfree’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_bavail’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_files’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_ffree’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_favail’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_fsid’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::__f_unused’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_flag’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::f_namemax’ [-Wmissing-field-initializers]
      ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statv fs::__f_spare’ [-Wmissing-field-initializers]
      Host "ioBroker" (linux) updated
      Execute: chmod -R 777 /opt/iobroker
      Chmod finished. Restart controller
      Starting node restart.js
      Weiß nur nicht was das bedeutet.
      Gruß Peter
      • apollon77A
        apollon77A
        Das sind nur Warnungen beim kompilieren eines Paketes welches native Bestandteile hat. Es ist kein Fehler gekommen, nur Warnungen also alles ok
        • HomoranH
          @sigi234:
          Habe leider ein Problem seit dem update: `
          Hast du verbotene Zeichen in den IDs?
          • sigi234S
            sigi234S
            ja vor Allem im Alexa2 Adapter:
            • HomoranH
              Kann ich erstmal keine sehen:
              `][*,;'"`<>?[/code]`
              • sigi234S
                sigi234S
                Aha ok dachte die Raute ist auch eines,
                Ich sehe ja alles aber komme nur bis zu VIS.0 dann zurück geht nicht mehr.
                Oder der Fehler:
                • arteckA
                  arteckA
                  arteck
                  schlecht
                  und HTTPS geht wieder nicht, ohne Meldung nichts…die Seite bleibt leer
                  • apollon77A
                    apollon77A
                    Bitte für alle eigenen Themen eigene GitHub issues anlegen. So beschleunigt ihr fixes bestmöglich.
                    @arteck: ich hoffe das steht auch irgendwas lesbares und nicht nur cryptisches. Vllt besser als Text als als Grafik?!
                    Gesendet vom Handy …
                    • arteckA
                      arteckA
                      arteck
                      Caught	2018-09-12 19:44:10.973	error	by controller[7]: hNdUHcXay29gO6sW12RAn7QlT6kU316E
                      Caught	2018-09-12 19:44:10.973	error	by controller[6]: hNdUHcXay29gO6sW12RAn7QlT6kU316E
                      Caught	2018-09-12 19:44:10.973	error	by controller[5]: hNdUHcXay29gO6sW12RAn7QlT6kU316E
                      Caught	2018-09-12 19:44:10.972	error	by controller[4]: hNdUHcXay29gO6sW12RAn7QlT6kU316E
                      Caught	2018-09-12 19:44:10.972	error	by controller[3]: hNdUHcXay29gO6sW12RAn7QlT6kU316E
                      Caught	2018-09-12 19:44:10.972	error	by controller[2]: hNdUHcXay29gO6sW12RAn7QlT6kU316E
                      Caught	2018-09-12 19:44:10.970	error	by controller[2]: hNdUHcXay29gO6sW12RAn7QlT6kU316E
                      Caught	2018-09-12 19:44:10.966	error	by controller[1]: hNdUHcXay29gO6sW12RAn7QlT6kU316E
                      ich kanns noch nicht mal lokalisieren woher es kommt
                      • HomoranH
                        @apollon77:
                        ich hoffe das steht … nicht nur cryptisches `
                        @arteck:
                        HTTPS geht wieder nicht `
                        Passt das irgendwie zusammen??
                        • arteckA
                          arteckA
                          arteck
                          sieht nach einer Session Id aus… jep hängt damit zusammen...
                          https://github.com/ioBroker/ioBroker.js ... issues/255
                          wenn ich die Authentifikation auschalte lädt die Seite... also Login geht wieder nicht..gleiches verhalten wie damals... Bluefox hats damals behoben.. müsste die gleiche Stelle sein :D
                          meine Zertifikate werden nicht geladen...sind aber im Ordner
                          `2018-09-12 20:31:51.974  - [31merror[39m: admin.0 uncaught exception: Cannot read property 'NPNProtocols' of undefined
                          2018-09-12 20:31:51.974  - [31merror[39m: admin.0 TypeError: Cannot read property 'NPNProtocols' of undefined
                              at new Server (https.js:15:40)
                              at Object.exports.createServer (https.js:47:10)
                              at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:173:39)
                              at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:426:32)
                              at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:457:7)
                              at /opt/iobroker/node_modules/iobroker.admin/main.js:292:29
                              at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/main.js:351:35)
                              at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                              at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                              at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          2018-09-12 20:31:51.976  - [32minfo[39m: admin.0 terminating https server on port 89
                          2018-09-12 20:31:51.981  - [32minfo[39m: admin.0 terminating
                          2018-09-12 20:31:52.015  - [31merror[39m: Caught by controller[0]: TypeError: Cannot read property 'NPNProtocols' of undefined
                          2018-09-12 20:31:52.016  - [31merror[39m: Caught by controller[0]:     at new Server (https.js:15:40)
                          2018-09-12 20:31:52.016  - [31merror[39m: Caught by controller[0]:     at Object.exports.createServer (https.js:47:10)
                          2018-09-12 20:31:52.016  - [31merror[39m: Caught by controller[0]:     at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:173:39)
                          2018-09-12 20:31:52.016  - [31merror[39m: Caught by controller[0]:     at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:426:32)
                          2018-09-12 20:31:52.016  - [31merror[39m: Caught by controller[0]:     at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:457:7)
                          2018-09-12 20:31:52.017  - [31merror[39m: Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/main.js:292:29
                          2018-09-12 20:31:52.017  - [31merror[39m: Caught by controller[0]:     at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/main.js:351:35)
                          2018-09-12 20:31:52.017  - [31merror[39m: Caught by controller[0]:     at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                          2018-09-12 20:31:52.017  - [31merror[39m: Caught by controller[0]:     at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                          2018-09-12 20:31:52.017  - [31merror[39m: Caught by controller[0]:     at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          2018-09-12 20:31:52.017  - [31merror[39m: host.iobroker instance system.adapter.admin.0 terminated with code 0 (OK)[/code]</anonymous></anonymous></anonymous></anonymous>`
                          ich bekomme diese auch nicht eingespiellt.. dann kommt der Fehler
                          `~~[code]~~Caught	2018-09-12 20:58:14.364	error	by controller[7]: EswOZs-JiPx9Ph_M8XwasXXduZvqymnJ
                          Caught	2018-09-12 20:58:14.363	error	by controller[6]: EswOZs-JiPx9Ph_M8XwasXXduZvqymnJ
                          Caught	2018-09-12 20:58:14.363	error	by controller[5]: EswOZs-JiPx9Ph_M8XwasXXduZvqymnJ
                          Caught	2018-09-12 20:58:14.363	error	by controller[4]: EswOZs-JiPx9Ph_M8XwasXXduZvqymnJ
                          Caught	2018-09-12 20:58:14.363	error	by controller[3]: EswOZs-JiPx9Ph_M8XwasXXduZvqymnJ
                          Caught	2018-09-12 20:58:14.363	error	by controller[2]: EswOZs-JiPx9Ph_M8XwasXXduZvqymnJ
                          Caught	2018-09-12 20:58:14.362	error	by controller[1]: EswOZs-JiPx9Ph_M8XwasXXduZvqymnJ
                          Caught	2018-09-12 20:58:14.359	error	by controller[0]: EswOZs-JiPx9Ph_M8XwasXXduZvqymnJ[/code]`
                          • lobomauL
                            lobomauL
                            lobomau
                            Ich habe auch die Fehler wie Artec und komme nicht über https mehr auf admin.
                            Leider finde ich nicht auf die Schnelle wie ich über Konsole die Authentifikation ändere. Ich habe versucht mal eine zweiten admin-adapter mit "npm install iobroker.admin" zu installieren. Aber das scheint es nicht zu sein. Habe ich auch schon mal in der Vergangenheit gemacht… nur wie? :roll:
                            Host: NUC8i3 mit Proxmox:
                            • Slave: Pi4
                            • lobomauL
                              lobomauL
                              lobomau
                              @lobomau:
                              Leider finde ich nicht auf die Schnelle wie ich über Konsole die Authentifikation ändere. Ich habe versucht mal eine zweiten admin-adapter mit "npm install iobroker.admin" zu installieren. Aber das scheint es nicht zu sein. Habe ich auch schon mal in der Vergangenheit gemacht… nur wie? :roll: `
                              Aufgrund des vorherigen posts war ich etwas voreilig.
                              Es lag bei mir scheinbar an der npm Version. Ich bin wieder auf 4.6.1 und es läuft wieder!
                              Die ganze Wahrheit: ich hatte nicht nur jscontroller von 1.4.2 -> 1.5 geupdatet, sondern gleichzeitig ein "apt update & upgrade" durchgeführt. Dadurch kam es zu npm 4.6.1 -> 6.4.1 und nodejs wurde auf 8.12.0 geupdatet.
                              Auf dem slave Pi3 läuft weiterhin npm 6.4.1. Lasse ich erstmal so.
                              • Slave: Pi4
                              • StabilostickS
                                StabilostickS
                                Stabilostick
                                @lobomau:
                                Die ganze Wahrheit: ich hatte nicht nur jscontroller von 1.4.2 -> 1.5 geupdatet, sondern gleichzeitig ein "apt update & upgrade" durchgeführt. Dadurch kam es zu npm 4.6.1 -> 6.4.1 und nodejs wurde auf 8.12.0 geupdatet. `
                                Welche Node.js-Version hattest Du vor dem Upgrade auf Ubuntu?
                                Ist das richtig so, dass Du nach apt update & apt upgrade direkt iobroker stop, iobroker update, iobroker upgrade, iobroker start gemacht hast? Dann den Fehler festgestellt?
                                Und dann ohne was zu ändern, ein npm install -g npm@4.6.1
                                Und dann lief es gleich wieder? Oder hast du zwischendurch noch etwas anderes gemacht?
                                • D
                                  D
                                  der_Auge
                                  Zur Info:
                                  root@NUC:/opt/iobroker# iobroker upgrade self
                                  NPM version: 4.6.1
                                  npm install iobroker.js-controller@1.5.0 --unsafe-perm --production --save --prefix "/opt/iobroker"                          (System call)
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                  npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none was installed.
                                  npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none was installed.
                                  npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none was installed.
                                  npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none was installed.
                                  Host "NUC" (linux) updated
                                  root@NUC:/opt/iobroker# npm -v
                                  4.6.1
                                  root@NUC:/opt/iobroker# nodejs -v
                                  v8.11.4
                                  root@NUC:/opt/iobroker# node -v
                                  v8.11.4
                                  Jürgen
                                  Master: DN2820FYKH (4GB) Linux NUC 4.4.0-22-generic #40-Ubuntu x86_64
                                  Slave: Linux RPi2-1 4.1.19-v7+ #858 v4.4.3 # 2.15.1
                                  SQL-DB : Linux DS 3.10.77 #7321 x86_64 synology412+
                                  Test : DS916+ VM Debian
                                  Test : Tinker mit piVCCU
                                  • AlCalzoneA
                                    AlCalzoneA
                                    AlCalzone
                                    @der_Auge:
                                    4.6.1
                                    v8.11.4
                                    v8.11.4
                                    Irgendwas verschweigst du uns. Ein reines Downgrade von npm auf 4.6.1 downgraded nicht automatisch auch nodejs von 8.12 auf 8.11.4.
                                    Ich vermute das Problem in Änderungen, die in Node 8.12 gemacht wurden.
                                    • lobomauL
                                      lobomauL
                                      lobomau
                                      @Stabilostick:
                                      @lobomau:
                                      Und dann lief es gleich wieder? Oder hast du zwischendurch noch etwas anderes gemacht? `
                                      Vor dem Update hatte ich node: v8.11.4.
                                      Meine Reihenfolge:
                                      1. iobroker stop
                                      2. apt update
                                      3. apt upgrade
                                      4. iobroker update, iobroker upgrade self, iobroker start
                                      das hatte soweit alles funktioniert auf dem slave.
                                      1. iobroker stop, iobroker reboot (vielleicht unnötig, aber irgendwie bilde ich mir ein, dass ein fresh reboot gut tut)
                                      Auf dem host mit ubuntu startete nach 4) nicht mehr der admin-Adapter und der web-Adapter (beide mit https), restliche Adapter ohne Probleme.
                                      Ein Reboot brachte auch nichts. Ein downgrade auf npm 4.6.1. hat das Problem wieder beseitigt. Hier der Fehler-log mit npm 6.4.1:
                                      2018-09-12 18:55:16.418 - [32minfo[39m: host.iobroker-ubuntu instance system.adapter.admin.0 started with pid 1354 2018-09-12 18:55:18.006 - [32minfo[39m: host.iobroker-ubuntu instance scheduled system.adapter.daswetter.0 */15 * * * * 2018-09-12 18:55:18.508 - [32minfo[39m: admin.0 starting. Version 3.5.8 in /opt/iobroker/node_modules/iobroker.admin, node: v8.12.0 2018-09-12 18:55:18.644 - [32minfo[39m: admin.0 Request actual repository... 2018-09-12 18:55:18.653 - [32minfo[39m: admin.0 requesting all states 2018-09-12 18:55:18.657 - [32minfo[39m: admin.0 requesting all objects 2018-09-12 18:55:19.653 - [32minfo[39m: host.iobroker-ubuntu Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json" 2018-09-12 18:55:21.333 - [32minfo[39m: admin.0 Repository received successfully. 2018-09-12 18:55:21.731 - [32minfo[39m: admin.0 received all states 2018-09-12 18:55:22.028 - [32minfo[39m: host.iobroker-ubuntu instance system.adapter.javascript.1 started with pid 1371 2018-09-12 18:55:24.053 - [32minfo[39m: admin.0 received all objects 2018-09-12 18:55:24.603 - [32minfo[39m: javascript.1 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.12.0 2018-09-12 18:55:24.660 - [32minfo[39m: javascript.1 requesting all states 2018-09-12 18:55:24.664 - [32minfo[39m: javascript.1 requesting all objects 2018-09-12 18:55:24.104 - [33mwarn[39m: admin.0 No repository source configured 2018-09-12 18:55:24.908 - [32minfo[39m: admin.0 created middleware 2018-09-12 18:55:24.956 - [31merror[39m: admin.0 uncaught exception: listen EACCES 0.0.0.0:80 2018-09-12 18:55:24.956 - [31merror[39m: admin.0 Error: listen EACCES 0.0.0.0:80 at Server.setupListenHandle [as _listen2] (net.js:1343:19) at listenInCluster (net.js:1401:12) at Server.listen (net.js:1485:7) at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:74:21) at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:426:32) at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:457:7) at /opt/iobroker/node_modules/iobroker.admin/main.js:292:29 at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/main.js:351:35) at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20) at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) 2018-09-12 18:55:24.957 - [32minfo[39m: admin.0 terminating https server on port 8081 2018-09-12 18:55:24.963 - [32minfo[39m: admin.0 https server listening on port 8081 2018-09-12 18:55:24.964 - [32minfo[39m: admin.0 Use link "https://localhost:8081" to configure. 2018-09-12 18:55:25.961 - [32minfo[39m: admin.0 terminating https server on port 8081 2018-09-12 18:55:26.143 - [32minfo[39m: host.iobroker-ubuntu instance system.adapter.telegram.1 started with pid 1391 2018-09-12 18:55:26.437 - [31merror[39m: Caught by controller[0]: ========================================================== 2018-09-12 18:55:26.440 - [31merror[39m: Caught by controller[0]: == greenlock.js (v2.2.0+) == 2018-09-12 18:55:26.441 - [31merror[39m: Caught by controller[0]: ========================================================== 2018-09-12 18:55:26.441 - [31merror[39m: Caught by controller[0]: Please specify 'version' option: 2018-09-12 18:55:26.441 - [31merror[39m: Caught by controller[0]: 'draft-12' for Let's Encrypt v2 and ACME draft 12 2018-09-12 18:55:26.441 - [31merror[39m: Caught by controller[0]: ('v02' is an alias of 'draft-12' 2018-09-12 18:55:26.441 - [31merror[39m: Caught by controller[0]: or 2018-09-12 18:55:26.441 - [31merror[39m: Caught by controller[0]: 'v01' for Let's Encrypt v1 (deprecated) 2018-09-12 18:55:26.442 - [31merror[39m: Caught by controller[0]: (also 'npm install --save le-acme-core' as this legacy dependency will soon be removed) 2018-09-12 18:55:26.442 - [31merror[39m: Caught by controller[0]: This will be required in versions v2.3+ 2018-09-12 18:55:26.442 - [31merror[39m: Caught by controller[0]: Detected Let's Encrypt v02 URL. Changing version to draft-12. 2018-09-12 18:55:26.442 - [31merror[39m: Caught by controller[1]: { Error: listen EACCES 0.0.0.0:80 2018-09-12 18:55:26.442 - [31merror[39m: Caught by controller[1]: at Server.setupListenHandle [as _listen2] (net.js:1343:19) 2018-09-12 18:55:26.442 - [31merror[39m: Caught by controller[1]: at listenInCluster (net.js:1401:12) 2018-09-12 18:55:26.442 - [31merror[39m: Caught by controller[1]: at Server.listen (net.js:1485:7) 2018-09-12 18:55:26.443 - [31merror[39m: Caught by controller[1]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:74:21) 2018-09-12 18:55:26.443 - [31merror[39m: Caught by controller[1]: at __construct (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:426:32) 2018-09-12 18:55:26.443 - [31merror[39m: Caught by controller[1]: at new Web (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:457:7) 2018-09-12 18:55:26.443 - [31merror[39m: Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.admin/main.js:292:29 2018-09-12 18:55:26.443 - [31merror[39m: Caught by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/main.js:351:35) 2018-09-12 18:55:26.443 - [31merror[39m: Caught by controller[1]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9) 2018-09-12 18:55:26.443 - [31merror[39m: Caught by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12) 2018-09-12 18:55:26.444 - [31merror[39m: Caught by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15) 2018-09-12 18:55:26.444 - [31merror[39m: Caught by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20) 2018-09-12 18:55:26.444 - [31merror[39m: Caught by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8) 2018-09-12 18:55:26.444 - [31merror[39m: Caught by controller[1]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15) 2018-09-12 18:55:26.444 - [31merror[39m: Caught by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) 2018-09-12 18:55:26.444 - [31merror[39m: Caught by controller[1]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12) 2018-09-12 18:55:26.444 - [31merror[39m: Caught by controller[1]: errno: 'EACCES', 2018-09-12 18:55:26.445 - [31merror[39m: Caught by controller[1]: code: 'EACCES', 2018-09-12 18:55:26.445 - [31merror[39m: Caught by controller[1]: syscall: 'listen', 2018-09-12 18:55:26.445 - [31merror[39m: Caught by controller[1]: address: '0.0.0.0', 2018-09-12 18:55:26.445 - [31merror[39m: Caught by controller[1]: port: 80 } 2018-09-12 18:55:26.445 - [31merror[39m: host.iobroker-ubuntu instance system.adapter.admin.0 terminated with code 6 (uncaught exception) 2018-09-12 18:55:26.445 - [32minfo[39m: host.iobroker-ubuntu Restart adapter system.adapter.admin.0 because enabled[/code]</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                                      • Slave: Pi4
                                      • AlCalzoneA
                                        AlCalzoneA
                                        AlCalzone
                                        Der Fehler muss woanders liegen. npm hat keinen Einfluss auf das Laufzeitverhalten von node, da es nur zur Installation von Paketen verwendet wird.
                                        EACCES 0.0.0.0:80 bedeutet, dass ein weiterer Prozess bereits den Port 80 auf allen IP-Adressen für sich beansprucht. Woran das genau liegt, kann ich jetzt aber auch nur raten.
                                        Edit: einen ähnlichen Fehler hatten wir an anderer Stelle schon mal: viewtopic.php?p=134532#p134532
                                        • StabilostickS
                                          StabilostickS
                                          Stabilostick
                                          Ist Deine Node-Version nach dem npm-Downgrade immer noch 8.12.0? Wenn sie 8.12.0 ist, tritt der Fehler nach
                                          npm i -g npm@latest
                                          und ioBroker-Neustart wieder auf?
                                          84.2k
