  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • chucky666C Online
    chucky666C Online
    chucky666
    #356
    er zeigt mir viele Fehler an , macht aber das backup und packt es auf das Nas
    <code>backitup.0	2018-07-23 22:12:42.381	error	[minimal] * Connection #0 to host 192.168.178.50 left intact
    backitup.0	2018-07-23 22:12:42.380	error	[minimal] < 226 Transfer complete.
    backitup.0	2018-07-23 22:12:42.365	error	[minimal] * Remembering we are in dir "Disk/Iobroker/"
    backitup.0	2018-07-23 22:12:42.363	error	[minimal] * We are completely uploaded and fine
    backitup.0	2018-07-23 22:12:42.340	error	[minimal] } [16384 bytes data]
    backitup.0	2018-07-23 22:12:42.339	error	[minimal] < 150 Opening BINARY mode data connection for 'minimal-2018_07_23-22_12_20_backupiobroker.tar.gz'.
    backitup.0	2018-07-23 22:12:42.332	error	[minimal] > STOR minimal-2018_07_23-22_12_20_backupiobroker.tar.gz
    backitup.0	2018-07-23 22:12:42.330	error	[minimal] < 200 Type set to I.
    backitup.0	2018-07-23 22:12:42.329	error	[minimal] > TYPE I
    backitup.0	2018-07-23 22:12:42.328	error	[minimal] * Connected to 192.168.178.50 (192.168.178.50) port 21 (#0)
    backitup.0	2018-07-23 22:12:42.318	error	[minimal] * Connecting to 192.168.178.50 (192.168.178.50) port 55536
    backitup.0	2018-07-23 22:12:42.317	error	[minimal] * Trying 192.168.178.50...
    backitup.0	2018-07-23 22:12:42.316	error	[minimal] < 227 Entering Passive Mode (192,168,178,50,216,240)
    backitup.0	2018-07-23 22:12:42.315	error	[minimal] * Connect data stream passively
    backitup.0	2018-07-23 22:12:42.314	error	[minimal] > PASV
    backitup.0	2018-07-23 22:12:42.314	error	[minimal] < 250 CWD command successful.
    backitup.0	2018-07-23 22:12:42.313	error	[minimal] > CWD Iobroker
    backitup.0	2018-07-23 22:12:42.310	error	[minimal] < 250 CWD command successful.
    backitup.0	2018-07-23 22:12:42.287	error	[minimal] * ftp_perform ends with SECONDARY: 0
    backitup.0	2018-07-23 22:12:42.286	error	[minimal] > CWD Disk
    backitup.0	2018-07-23 22:12:42.273	error	[minimal] * Entry path is '/'
    backitup.0	2018-07-23 22:12:42.271	error	[minimal] < 257 "/" is current directory.
    backitup.0	2018-07-23 22:12:42.162	error	[minimal] > PWD
    backitup.0	2018-07-23 22:12:42.159	error	[minimal] < 230 User admin logged in./code]</code>
    • simatecS Offline
      simatecS Offline
      simatec
      #357
      Wo zeigt er die Fehler an?
      Im Log?
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • chucky666C Online
        chucky666C Online
        chucky666
        #358
        Ja genau im log
        Gesendet von iPad mit Tapatalk Pro
        • simatecS Offline
          simatecS Offline
          simatec
          #359
          Von welcher Version bist du auf 0.2.4 gewechselt?
          Hast du nach dem Update aus dem github noch einmal ein upload vom Adapter gemacht?
          Probiere mal eine weitere Instanz vom Adapter zu installieren und teste es damit mal bitte
          • chucky666C Online
            chucky666C Online
            chucky666
            #360
            Da mein System geschrottet war , musste ich alles neu machen .
            2.4 ist die erste Version die ich installiert habe auf dem System
            • simatecS Offline
              simatecS Offline
              simatec
              #361
              OK schauen wir uns mal an.
              Keine dieser Meldungen ist ein error. Darum wundern mich die Meldungen.
              • chucky666C Online
                chucky666C Online
                chucky666
                #362
                Auch mit einer weiteren Instanz kommen diese Meldungen.
                Backup wird gemacht und auf das NAS kopiert
                • PeoplesP Offline
                  PeoplesP Offline
                  Peoples
                  #363
                  @chucky666:
                  Also rein Inhaltlich lese ich das so als wären das alles Statusmeldungen die eben mit einem error vorne dran stehen. Oder siehst du das anders, denn ein wirklicher Fehler steh da ja nicht oder? Kommt aber bei mir auch wenn ich das über die Konsole ausführe
                  • chucky666C Online
                    chucky666C Online
                    chucky666
                    #364
                    Habe ich mir auch gedacht
                    • simatecS Offline
                      simatecS Offline
                      simatec
                      #365
                      So wie ich das sehe betrifft es alles den ftp Upload.
                      Da haben wir ein Pull Request von bluefox bekommen, der das beheben sollte.
                      • chucky666C Online
                        chucky666C Online
                        chucky666
                        #366
                        Ok Danke , und Danke für den geilen Adapter
                        • PeoplesP Offline
                          PeoplesP Offline
                          Peoples
                          #367
                          Was komisch ist, die Meldung sollte nicht auftauchen da hier:
                                      if (text[0] == '*' || text[0] == '<' || text[0] == '>') {
                          Eigentlich alles abgefangen werden sollte, ich werde mal suchen
                          • J Offline
                            JackWolfskind
                            #368
                            Der Adapter erstellt jetzt fleissig Backups, aber übertragen per FTP oder CIFS wo anders hin geht leider nicht. Kann das sein das FTP und CIFS im Standard Raspberry/ioBroker Image gar nicht installiert bzw. enabled ist?
                            Dummerweise habe ich auch noch festgestellt das meine SD Karte mal wieder vollläuft von daher kann ich zu allem Unglück auch nix mehr installieren, d.h. ich hab ein Backup aber komme leider nicht ran :shock:
                              #369
                              @JackWolfskind:
                              Kann das sein das FTP und CIFS im Standard Raspberry/ioBroker Image gar nicht installiert bzw. enabled ist? `
                              Ja! (siehe oben!) Da war ich auch dran gescheitert.
                              apt install cifs-utils)
                              auch nicht mit filezilla auf den PC sichern??
                              und dann die unnötigen Backups löschen
                              • J Offline
                                JackWolfskind
                                #370
                                Moin Rainer,
                                cifs-utils ist sogar schon drauf - da werde ich mich mal in die config einlesen und hoffentlich so drankommen 8-)
                                Filezilla lässt mich vom PC leider nicht auf den RPi, fehlt wohl mal wieder irgendwas im Linux :roll:
                                  #371
                                  @JackWolfskind:
                                  Filezilla lässt mich vom PC leider nicht auf den RPi, fehlt wohl mal wieder irgendwas im Linux :roll: `
                                  Die Standardimages haben (siehe ReadMe) keinen Rootzugang per ftp; nur für den User pi
                                  Damit klappt es aber.
                                  @JackWolfskind:
                                  da werde ich mich mal in die config einlesen und hoffentlich so drankommen 8-) `
                                  Da muss nichts konfiguriert werden. Wie sind denn deine Konfigs im Adapter?
                                  • J Offline
                                    JackWolfskind
                                    #372
                                    @Homoran:
                                    Damit klappt es aber. `
                                    Achso, das erkärt schonmal das Problem mit FTP zum RPi. Dann muss ich das heute abend nochmal zuhause mit Filezilla ausprobieren.
                                    @Homoran:
                                    Da muss nichts konfiguriert werden. Wie sind denn deine Konfigs im Adapter? `
                                    Dachte eigentlich ich hätte endlich die krude Syntax kapiert :lol:
                                    Egal ob CIFS oder FTP, Host und User eingetragen…
                                    und den Pfad ohne führendes "/" und per "/" statt " " auch bei CIFS:
                                    Pfad/Verzeichnis
                                    Aber wenn ich mir dei Daten per FTP runterziehen kann dann setzt ich den Pi mit dem neuesten Image auf eine großen Karte neu auf und spiele das Backup zurück...
                                    Wird eigentlich die Historie Datenbank mit gebackupt?
                                      #373
                                      @JackWolfskind:
                                      Wird eigentlich die Historie Datenbank mit gebackupt? `
                                      Nein!
                                      diese Daten kannst du auch per filezilla runterziehen und wieder auf die neue Installation übernehmen.
                                      @JackWolfskind:
                                      Pfad/Verzeichnis `
                                      Ein Screenshot wäre erhellender :lol:
                                      • sigi234S Online
                                        sigi234S Online
                                        #374
                                        ` > Hallo,
                                        warum habe ich das Backitup in Alexa? `
                                        gibt es da schon eine Lösung?
                                        viewtopic.php?f=23&t=15256&p=161354#p161381
                                        • F Offline
                                          fraeggle
                                          #375
                                          @Homoran:
                                          @JackWolfskind:
                                          Nein!
                                          Rainer `
                                          Hmm im kompletten ist das bei mir aber drin.
                                          Gruß Peter
