Fehler bei js-controller update nach 1.2.5
habe eben versucht auf meinem Multihost-System den js-controller nach 1.2.5 zu aktualisieren.
Beim Slave ging das beim Master allerdings nicht.
Dort habe ich folgende Fehlermeldung erhalten.
Update js-controller from @1.2.3 to @1.2.5 npm install iobroker.js-controller@1.2.5 --production --prefix "/opt/iobroker" (System call) npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json' Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json' npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/aws-sdk/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.ical/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.sayit/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-ical/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/virtual-tsc/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.ical/node_modules/request/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.ical/node_modules/request/node_modules/http-signature/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/http-signature/package.json' npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.ical/node_modules/node-ical/node_modules/request/node_modules/http-signature/package.json' npm WARN virtual-tsc@0.3.4 requires a peer of @types/node@* but none was installed. npm WARN coffee-compiler@0.3.2 requires a peer of coffee-script@>=1.6.2 but none was installed. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: certpem@1.0.1 (node_modules/certpem): npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Refusing to delete /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/.bin/certpem: is outside /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/certpem and not a link npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/.bin/certpem npm WARN optional SKIPPING OPTIONAL DEPENDENCY: rsa-compat@1.2.7 (node_modules/rsa-compat): npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Refusing to delete /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/.bin/rsa-keygen-js: is outside /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat and not a link npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/.bin/rsa-keygen-js npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/.bin/ncp npm ERR! code EEXIST npm ERR! Refusing to delete /opt/iobroker/node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/.bin/ncp: is outside /opt/iobroker/node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/ncp and not a link npm ERR! File exists: /opt/iobroker/node_modules/iobroker.js-controller/node_modules/prompt/node_modules/utile/node_modules/.bin/ncp npm ERR! Move it away, and try again. npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-03-07T07_47_32_925Z-debug.log Host "ioB-Master" (linux) updated Execute: chmod -R 777 /opt/iobroker Chmod finished. Restart controller Starting node restart.js Cannot save /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json' root@ioB-Master:/opt/iobroker# iobroker start module.js:471 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (module.js:469:15) at Function.Module._load (module.js:417:25) at Module.runMain (module.js:604:10) at run (bootstrap_node.js:383:7) at startup (bootstrap_node.js:149:9) at bootstrap_node.js:496:3Nun habe ich auf dem Master das Backup zurückgespielt und es läuft wieder.
Aber eben auf 1.2.3 und der Slave auf 1.2.5.
Irgendjemand eine Idee, wie ich auf 1.2.5 aktualisieren kann?
dir ist klar dass 1.2.5 noch nicht freigegeben ist `
Hmmm…. wieso sollte das klar sein?
Wenn ich sehe es gibt ein Update, dann schaue oder suche ich nicht erst noch im Web ob das Update nun freigegeben ist oder nicht.
Hab nämlich auch gerade aktualisieren wollen und hab nun wieder etwas mehr arbeit um alles hinzubiegen ;)
Meiner Meinung nach sollte das Update auch erst angezeigt werden wenn es denn freigegeben ist und nicht vorher
Edit:
Mit beschriebener Update Methode kam bei mir auch die Fehlermeldung.
Danach den JS-Controller neu installiert und nun ist die Version 1.2.5 auch installiert :-)
@jhg:Irgendjemand eine Idee, wie ich auf 1.2.5 aktualisieren kann? `
Wie hast du es denn gemacht?per Console mit
cd /opt/iobroker sudo iobroker upgrade selfoder
cd /opt/iobroker npm install iobroker.js-controllerdir ist klar dass 1.2.5 noch nicht freigegeben ist `
Doch ist es!Meiner Meinung nach sollte das Update auch erst angezeigt werden wenn es denn freigegeben ist und nicht vorher `
Ist auch so, wobei wenn du das Repo latest hast, du bereit bist evtl. etwas Testing zu machen.Mit beschriebener Update Methode `
welche?Gruß
Mir ging es leider ähnlich:
root@ioBroker-VM2:/opt/iobroker# iobroker upgrade self
Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
fs.js:1061
return binding.unlink(pathModule._makeLong(path));
! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
at Object.fs.unlinkSync (fs.js:1061:18)
at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:130:24)
at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:630:27
at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:662:15)
at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3099:5)
at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
at Module._compile (module.js:652:30)
at Object.Module._extensions..js (module.js:663:10)
at Module.load (module.js:565:32)
at tryModuleLoad (module.js:505:12)
npm WARN npm@2.15.12 had bundled packages that do not match the required version(s). They have been replaced with non-bundled versions.
! npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! iobroker.js-controller@1.2.5 install:node iobroker.js setup first
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the iobroker.js-controller@1.2.5 install script.
! npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2018-03-07T14_32_46_714Z-debug.log
Host "ioBroker-VM2" (linux) updated
Starting node restart.js</anonymous>Wobei das anscheinend etwas anderes ist. User xy mit sudo su. Und der Versuch ioBroker zu starten: >! ```` root@ioBroker-VM2:/opt/iobroker# iobroker restart module.js:549 throw err; ^ >! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (module.js:547:15) at Function.Module._load (module.js:474:25) at Function.Module.runMain (module.js:693:10) at startup (bootstrap_node.js:188:16) at bootstrap_node.js:609:3 root@ioBroker-VM2:/opt/iobroker# npm install iobroker.js-controller >! > iobroker.js-controller@1.2.5 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first >! fs.js:1061 return binding.unlink(pathModule._makeLong(path)); ^ >! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat' at Object.fs.unlinkSync (fs.js:1061:18) at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:130:24) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:630:27 at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:662:15) at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3099:5) at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100) at Module._compile (module.js:652:30) at Object.Module._extensions..js (module.js:663:10) at Module.load (module.js:565:32) at tryModuleLoad (module.js:505:12) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! iobroker.js-controller@1.2.5 install: `node iobroker.js setup first` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.js-controller@1.2.5 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. >! npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-03-07T14_34_54_819Z-debug.log root@ioBroker-VM2:/opt/iobroker# iobroker restart module.js:549 throw err; ^ >! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (module.js:547:15) at Function.Module._load (module.js:474:25) at Function.Module.runMain (module.js:693:10) at startup (bootstrap_node.js:188:16) at bootstrap_node.js:609:3</anonymous> -
@jhg:Ich habe es mit der Variante versucht:
sudo iobroker stop
sudo iobroker update
In github steht schon die 1.2.6.
Aber so mutig wollte ich nicht sein. `
Ich habe es auch mit dieser Methode gemacht. Anschließend hatte ich aber wieder vom Admin die Version 2.09 drauf. Habe diesen dann anschließend wieder auf die Version 3.23 geupdated.
Na ja, der 1.2.5 ist im Latest-Repository und nicht im Stable.Wer sein System auf das Latest-Repo umstellt, sollte wissen, das er (freiwillig) an Feldtests teilnimmt, die auch schon mal in die Hose gehen können. Das ist im Forum schon einige Male so geschrieben worden.
Gruß,
Eric
Gruß,
Eric `
Da geb ich Dir Recht!
Hab eben nachgeschaut und festgestellt das es genau so ist wie Du sagst
des Risikos mit der latest bin ich mir sehr wohl bewusst.
Dafür habe ich ein Backup.
Mein System läuft nach solch einem Problem innerhalb von 15 min wieder fehlerfrei.
Aber gerade weil es ein Test ist, ist es doch wichtig den Fehler hier zu benennen, eben damit er korrigiert wird,
für diejenigen die nicht testen wollen.
Seite heute ist im latest auch die 1.2.6. muss ich mal schauen, wie es mit der aussieht.
@jhg:Aber gerade weil es ein Test ist, ist es doch wichtig den Fehler hier zu benennen, eben damit er korrigiert wird,
für diejenigen die nicht testen wollen. `
Na klar sollen Fehler gemeldet werden - dafür finden die Tests ja statt.Mir ging es um den Satz "Meiner Meinung nach sollte das Update auch erst angezeigt werden wenn es denn freigegeben ist und nicht vorher".
Gruß,
Eric
Gruß,
Eric `
sag ich doch … ist nicht freigegeben..
ich möchte auch den js-controller auf die 1.2.5 installieren. Bevor ich das Teil gleich abschiesse, was ist jetzt die bessere Variante um es upzudaten?
Mit der ersten Version "upgrade self" habt Ihr wenig Erfolg gehabt. Soll ich lieber die Variante zwei ausprobieren?
cd /opt/iobroker sudo iobroker stop sudo iobroker update sudo iobroker upgrade selfcd /opt/iobroker sudo iobroker stop sudo iobroker update npm install iobroker.js-controller -
cd /opt/iobroker sudo iobroker stop sudo iobroker update sudo iobroker upgrade selfcd /opt/iobroker sudo iobroker stop sudo iobroker update npm install iobroker.js-controller ```` `Bei meinem Brix taucht das Problem beim Update des js-controllers regelmäßig auf und ich muss immer zusätzlich "npm install iobroker.js-controller" durchführen. Damit läuft es dann ohne Probleme.
Siehe "Alter Hut":
http://forum.iobroker.net/viewtopic.php … ler#p74841
P.S. habe eben das Update nachgeschoben von 1.2.5 -> 1.2.6. Dabei habe ich das Update nun über Adapter in ioBroker durchgeführt. Ist wohl jetzt eine Möglichkeit des neuen Admin-Adapter dies so durchzuführen. Doch wegen des auftretenden Fehler musste ich dann doch über die Konsole "npm install iobroker.js-controller" nachschieben.
Gruß,
Eric `
Ist okay, habe ich aber nicht geschrieben.
