  4. Fehler bei js-controller update nach 1.2.5
    apollon77A
17 Beiträge 8 Kommentatoren 4.9k Aufrufe
  • J
    J
    jhg
    Ich habe es mit der Variante versucht:
    sudo iobroker stop
    sudo iobroker update
    sudo iobroker upgrade self
    In github steht schon die 1.2.6.
    Aber so mutig wollte ich nicht sein.
    • HomoranH
      Mir ging es leider ähnlich:
      root@ioBroker-VM2:/opt/iobroker# iobroker upgrade self
      Update js-controller from @1.2.3 to @1.2.5
      npm install iobroker.js-controller@1.2.5 --production --prefix "/opt/iobroker" (System call)
      npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
      Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
      fs.js:1061
      return binding.unlink(pathModule._makeLong(path));
      ! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
      at Object.fs.unlinkSync (fs.js:1061:18)
      at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:130:24)
      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:630:27
      at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:662:15)
      at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3099:5)
      at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
      at Module._compile (module.js:652:30)
      at Object.Module._extensions..js (module.js:663:10)
      at Module.load (module.js:565:32)
      at tryModuleLoad (module.js:505:12)
      npm WARN npm@2.15.12 had bundled packages that do not match the required version(s). They have been replaced with non-bundled versions.
      ! npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@1.2.5 install: node iobroker.js setup first
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@1.2.5 install script.
      ! npm ERR! A complete log of this run can be found in:
      npm ERR! /root/.npm/_logs/2018-03-07T14_32_46_714Z-debug.log
      Host "ioBroker-VM2" (linux) updated
      Execute: chmod -R 777 /opt/iobroker
      Chmod finished. Restart controller
      Starting node restart.js</anonymous>
      Wobei das anscheinend etwas anderes ist.
      User xy mit sudo su.
      Und der Versuch ioBroker zu starten:
      root@ioBroker-VM2:/opt/iobroker# iobroker restart
      module.js:549
          throw err;
      >! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (module.js:547:15)
          at Function.Module._load (module.js:474:25)
          at Function.Module.runMain (module.js:693:10)
          at startup (bootstrap_node.js:188:16)
          at bootstrap_node.js:609:3
      root@ioBroker-VM2:/opt/iobroker# npm install iobroker.js-controller
      >! > iobroker.js-controller@1.2.5 install /opt/iobroker/node_modules/iobroker.js-controller
      >! fs.js:1061
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@1.2.5 install: `node iobroker.js setup first`
      npm ERR!
      npm ERR!     /root/.npm/_logs/2018-03-07T14_34_54_819Z-debug.log
      module.js:549
          throw err;
          at bootstrap_node.js:609:3</anonymous>
      • Espace0401E
        Espace0401E
        Espace0401
        @jhg:
        sudo iobroker stop
        Aber so mutig wollte ich nicht sein. `
        Ich habe es auch mit dieser Methode gemacht. Anschließend hatte ich aber wieder vom Admin die Version 2.09 drauf. Habe diesen dann anschließend wieder auf die Version 3.23 geupdated.
        Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
        • eric2905E
          eric2905E
          eric2905
          @mikiline:
          Wenn ich sehe es gibt ein Update, dann schaue oder suche ich nicht erst noch im Web ob das Update nun freigegeben ist oder nicht.
          Hab nämlich auch gerade aktualisieren wollen und hab nun wieder etwas mehr arbeit um alles hinzubiegen ;)
          Meiner Meinung nach sollte das Update auch erst angezeigt werden wenn es denn freigegeben ist und nicht vorher `
          Na ja, der 1.2.5 ist im Latest-Repository und nicht im Stable.
          Wer sein System auf das Latest-Repo umstellt, sollte wissen, das er (freiwillig) an Feldtests teilnimmt, die auch schon mal in die Hose gehen können. Das ist im Forum schon einige Male so geschrieben worden.
          Gruß,
          Eric
          • M
            M
            mikiline
            @eric2905:
            @mikiline:
            Gruß,
            Eric `
            Da geb ich Dir Recht!
            Hab eben nachgeschaut und festgestellt das es genau so ist wie Du sagst
            • J
              J
              jhg
              des Risikos mit der latest bin ich mir sehr wohl bewusst.
              Dafür habe ich ein Backup.
              Mein System läuft nach solch einem Problem innerhalb von 15 min wieder fehlerfrei.
              Aber gerade weil es ein Test ist, ist es doch wichtig den Fehler hier zu benennen, eben damit er korrigiert wird,
              für diejenigen die nicht testen wollen.
              Seite heute ist im latest auch die 1.2.6. muss ich mal schauen, wie es mit der aussieht.
              • eric2905E
                eric2905E
                eric2905
                @jhg:
                für diejenigen die nicht testen wollen. `
                Na klar sollen Fehler gemeldet werden - dafür finden die Tests ja statt.
                Mir ging es um den Satz "Meiner Meinung nach sollte das Update auch erst angezeigt werden wenn es denn freigegeben ist und nicht vorher".
                Gruß,
                Eric
                • arteckA
                  arteckA
                  arteck
                  @eric2905:
                  @mikiline:
                  Gruß,
                  Eric `
                  sag ich doch … ist nicht freigegeben..
                  • K
                    K
                    knopers1
                    ich möchte auch den js-controller auf die 1.2.5 installieren. Bevor ich das Teil gleich abschiesse, was ist jetzt die bessere Variante um es upzudaten?
                    Mit der ersten Version "upgrade self" habt Ihr wenig Erfolg gehabt. Soll ich lieber die Variante zwei ausprobieren?
                    cd /opt/iobroker
                    sudo iobroker stop
                    cd /opt/iobroker
                    sudo iobroker stop
                    • lobomauL
                      lobomauL
                      lobomau
                      @knopers1:
                      cd /opt/iobroker
                      sudo iobroker stop
                      cd /opt/iobroker
                      sudo iobroker stop
                      Bei meinem Brix taucht das Problem beim Update des js-controllers regelmäßig auf und ich muss immer zusätzlich "npm install iobroker.js-controller" durchführen. Damit läuft es dann ohne Probleme.
                      Siehe "Alter Hut":
                      http://forum.iobroker.net/viewtopic.php … ler#p74841
                      P.S. habe eben das Update nachgeschoben von 1.2.5 -> 1.2.6. Dabei habe ich das Update nun über Adapter in ioBroker durchgeführt. Ist wohl jetzt eine Möglichkeit des neuen Admin-Adapter dies so durchzuführen. Doch wegen des auftretenden Fehler musste ich dann doch über die Konsole "npm install iobroker.js-controller" nachschieben.
                      Host: NUC8i3 mit Proxmox:
                      • Slave: Pi4
                      • K
                        K
                        knopers1
                        ja, bei mir auch…
                        mit
                        cd /opt/iobroker
                        sudo iobroker stop
                        habe ich den js-controller zerschossen.
                        Ein erneuter:
                        bringt es wieder i.O.
                        • J
                          J
                          jhg
                          @eric2905:
                          @jhg:
                          Gruß,
                          Eric `
                          Ist okay, habe ich aber nicht geschrieben.
                          84.1k
