Test Adapter NSPanel-lovelace-ui v1.x.x
1.7.0 (2026-10-25)
- (ticaki) web panels: the panel UI in a web browser via http://<host>:8090/<topic>, no Tasmota needed - one web panel per address, all browsers on it stay in sync (new admin tab "Web panels")
- (ticaki) web panels: a real panel can be opened in the browser - the clone navigates on its own and shares the states tree
panels.<id>with the panel - (ticaki) web panels: standalone web panels without hardware - "Add web panel" in the panel overview (name, topic, model), configured by topic like a real panel
- (ticaki) web panels: optional PIN (
webPin) for all web panels, asked once per browser; HTTPS with the ioBroker certificates (webSecure); a FIDO2 security key can replace the PIN (HTTPS only) - (ticaki) web panels: look of the HMI - Noto Sans, Nextion font sizes, all page types, popups, the four screensaver layouts and the boot animation
- (ticaki) web panels: a lost connection to the adapter is shown (greyed out page), the browser reconnects after an adapter restart on its own
- (ticaki) admin: a button opens the web panel of a panel in a new tab (Maintain, panel settings, panel info), the host name of the links is configurable (
webHost) - (ticaki) screensaver: the indicator buttons (and the state
buttons.indicator-N) work again when the screensaver is the first page of the configuration - (ticaki) screensaver: a tap on an indicator sets
buttons.indicator-Nagain when the indicators do not act as buttons, and the command of the indicator runs once instead of twice (a switch was flipped back at once) - (ticaki) a panel that is offline gets the startup page offered every 5 s again (the panel loop never rescheduled itself)
- (ticaki) script config:
fontSize: 0on a grid item is no longer ignored
Zwei fragen
Wenn du mit dem Admin deine Seiten erstellst, warum möchtest du das globalScript nutzen?Ich möchte allerdings einen Ordner anklicken, um darauf zu kommen - nicht über das klicken nach links/rechts
Das verstehe ich nicht ganz, was du da meinst. Ordner = Channel oder Folder?
Mit klick auf Icon eine Seite öffnen?
Soll das Icon einen Status anzeigen vom Channel?@TT-Tom Vielleicht habe ich auch einfach einen Denkfehler.
Unten links "Garage" ist Pfad zur Garage. In der Garage habe ich ebenfalls ein NSPanel.
Meine Überlegung war, die eingerichtete Konfiguration der Garage im global zu speichern, dass ich auch von jedem anderen Panel darauf komme. Vielleicht denke ich zu kompliziert?
javascript.0 17:34:05.142 error Error by run: script.js.nspanel-lovelace-ui_0.nspanel_garten:351 javascript.0 17:34:05.144 error }).call(exports); javascript.0 17:34:05.146 error ^ javascript.0 17:34:05.148 error TypeError: (intermediate value)(...).call is not a function javascript.0 17:34:05.150 error at script.js.nspanel-lovelace-ui_0.nspanel_garten:351:4 javascript.0 17:34:05.151 error at Script.runInContext (node:vm:149:12) javascript.0 17:34:05.154 error Error: TypeError: id.includes is not a function javascript.0 17:34:05.155 error at getStateAsync (/opt/iobroker/node_modules/iobroker.javascript/build/lib/sandbox.js:2595:20) javascript.0 17:34:05.157 error at wrapped (/opt/iobroker/node_modules/iobroker.javascript/build/lib/sandbox.js:68:19) javascript.0 17:34:05.159 error at getStateMe (script.js.nspanel-lovelace-ui_0.nspanel_garten:175:22) javascript.0 17:34:05.161 error at script.js.nspanel-lovelace-ui_0.nspanel_garten:442:22 javascript.0 17:34:05.163 error at script.js.nspanel-lovelace-ui_0.nspanel_garten:1:1 javascript.0 17:34:05.165 error at Script.runInContext (node:vm:149:12) javascript.0 17:34:10.792 info Stopping scriptich hätte da ein Problem
keine änderung am script..
da fehlt wohl ne methode -
Error: TypeError: id.includes is not a function at getStateAsync (…/iobroker.javascript/build/lib/sandbox.js:2595:20) at wrapped (…/sandbox.js:68:19) at getStateMe (script.js.nspanel-lovelace-ui_0.nspanel_garten:175:22) ← hier at script.js.nspanel-lovelace-ui_0.nspanel_garten:442:22getStateMeist keine Funktion aus unserem codewenn du code unten einfügst, wird der vom adapter überschrieben immmer oberhalb von
/** ******************************************************************************** ******************************************************************************** ******************************************************************************** ******************************************************************************** ******************************************************************************** ******************************************************************************** ******************************************************************************** * END STOP END STOP END - No more configuration - END STOP END STOP END * ********************************************************************************bleiben
Bei mir hat in der Vergangenheit die Fehlermeldung sich auf den transpilierten Code bezogen und nicht auf ts.
- nach der funktion suchen
- Kleine Änderung und Skript neu transpilieren
Vielleicht hilft das.
ja, das sollte so funktionieren. Du musst nur in dem Script von dem Garagen Panel die main von der Global verlinken. In dem Script der anderen Panels musst du eine Navigation auf die main der Global machen.
Zeige mal deine script einstellungen.
was soll ich nach der funktion suchen.. die ist global definiert ..hmmmmmmmmmmm
da komm jetzt ein undefined um die ecke...hhhhhmmmmmmmmmmmm.. merkwürdig .. ich such mal
im skript gucken obs doch drin steht und wenn nicht noch mal transpilieren vielleicht stehts in der javascript datei.
Ansonsten weiß ich nicht, im Skript wurde kaum was gemacht -
Die EU tft Version wurde auf 6.0.2 erhöht - das sollte ohne probleme laufen, aber bringt erstmal keine vorteile im aktuell lastest.
Wer da jedoch testen will, kann gerne die ungetestet github main version installieren (mache ich auch nach dem beitrag). Die bringt folgende Änderungen mit.
EDIT:
Ok das ist wirklich zu groß. Kurz:- navflow aufgebohrt (man kann prev, next, home, parent ändern)
- icons in tft ergänzt ca. 550 Stück
- icon übersicht auf github hinzugefügt: https://ticaki.github.io/ioBroker.nspanel-lovelace-ui/
- Skript ist nicht mehr zwingend nötig
- pageChart aus Admin entfernt
Nicht zusammengefaßtes Changelog:
WORK IN PROGRESS
- (ticaki) beta TFT for the EU panel is 6.0.2
- (ticaki) web panel: the two hardware buttons below the display are 20px higher
- (ticaki) icon overview on GitHub Pages: all icons of the panel with name and glyph, searchable, marks the icons of HMI 6 and the own icons
- (ticaki) navigation flow: edit mode to create, change and remove the prev/next/home/parent links of admin pages by dragging connections between pages and clicking edges; the changes are written to the page configuration and saved with the admin save button
- (ticaki) navigation flow: the links of script pages (panel script and global script) can be edited as well - the change is stored as an override in the instance configuration (
navigationOverrides) and applied on top of the script at every start, so it survives a resend of the script; the edge menu restores the script navigation of a page; a snapshot of the script links travels with the override, and when the script delivers other links later the tab asks once per session whether to merge, keep the own change or take over the script - (ticaki) navigation flow: pages the adapter generates from a page item (e.g. the media page behind a media item) are marked with a lock and stay read-only, whatever their page item comes from; a page with an override carries a pencil, in warning colour when the script changed since
- (ticaki) navigation flow: the checkbox "show system pages" works again - it threw an error and never showed the pages
- (ticaki) chart pages: the tab "Page Chart" is gone - its pages are moved into the page configuration (tab PageConfig) at adapter start and the old table is deleted; a name already used by another page gets the suffix
_chart - (ticaki) chart pages: migrated pages keep their navigation from the script for now (deprecated, the editor shows a hint) until a navigation is assigned in the admin - script version 0.21.4 marks
ScriptConfig.PageChartas deprecated - (tt-tom17) web panel: on a grid card a short tap on a tile switches it and holding the tile opens its detail popup, like on a real panel - a light tile with a colour role (rgb, rgbSingle, rgbThree, hue, ct, dimmer) opened the popup on a tap and was switched when held
- (tt-tom17) a panel switched off via
panels.<id>.cmd.activatedis now left alone at adapter start - it no longer receives a restart request over http - (tt-tom17) a switched off panel reports the status
deactivatedinstead of keeping the status of the previous run, so the panel overview no longer shows it as running - (tt-tom17) switching
cmd.activatedis confirmed at the panel again - the acknowledgement went topanels.controller.cmd.activatedbefore - (ticaki) screensaver: the time no longer stops when other values on the screensaver change often - a trigger arriving within the update throttle was replaced by the first one and the minute update of the clock got lost
- (tt-tom17)
cmd.hideCardskeeps its stored value at adapter start - it was overwritten with the value ofcmd.activated - (ticaki) a configuration script is no longer required: a panel without a script starts with the admin configuration only (empty start page as fallback) instead of being skipped or pausing the adapter
- (ticaki) icons: updated to Material Design Icons 7.4.47 - 546 new icons (shown on the panel from TFT 6.0.2 on, older TFTs show nothing for them), new MDI names of renamed icons work as aliases; existing icons keep their glyph
- (ticaki) icons: own icons
window-tilt-variant,window-open-hinged-variant(window with muntins tilted / side hinged open, matchingwindow-closed-variant) andwindow-shutter-25,-50,-75(roller shutter partly closed) - from TFT 6.0.2 on - (ticaki) HMI 6.0.2 (eu, us-p, us-l): the icon fonts 1, 3 and 4 contain the new icons;
HMI/tools/build_hmi.pybuilds the icon fonts of a HMI fromscript/icons.json - (ticaki) blinds without an own icon show their position:
window-shutterup to 5 %,window-shutter-openfrom 95 % on, in between the nearest ofwindow-shutter-75,-50,-25(named after the closed part) - needs TFT 6.0.2; an icon set by the user is kept
Das WebPanel gefällt mir immer mehr :)
Funktioniert denn im Adapter die Konfiguration der Hardwarebuttons, oder ist das noch eine Script-Geschichte? -
Funktioniert denn im Adapter die Konfiguration der Hardwarebuttons, oder ist das noch eine Script-Geschichte?Das WebPanel gefällt mir immer mehr :)
Funktioniert denn im Adapter die Konfiguration der Hardwarebuttons, oder ist das noch eine Script-Geschichte?Hm
- das Webpanel ist ein Panel - da soll das gleiche gehen wie mit den echt Panels - sonst ein bug
- Das Webpanel hat verständlicherweise keine Relais folglich geht die standardfunktion (druck switcht relais) nicht
- Detached HW Buttons gehen
Ob man die buttons im Admin konfigurieren kann weiß ich gerade nicht - das macht afaik @tt-tom - wenn der jetzt WTF schreibt, mache ich es :)
Im Skript das zum panel gehört geht es auf jeden Fall.EDIT:
Meine neue spielerrei geht dann auch - rollladen lt. alias ohne gesetztes User Icon:
Rolladenposition icon 0 - 3 offen 3 - 37,5 25% 37,5 - 62,5 50% 62,5 - 97 75% 97 - 100 zu oder umgedreht.
noch ein EDIT - ich glaube ich runde das nach zu - bei mir 36% eher 60% zu - hm obwohl - wayne...
Funktioniert denn im Adapter die Konfiguration der Hardwarebuttons, oder ist das noch eine Script-Geschichte?Ist noch nicht im Admin.
Frage : wo sollte die Konfiguration hin? Extra Tab oder irgendwo mit einfügen.
Macht mal Vorschläge. -
@patricknitsch
Okay, dann machen wir das so. -
die Hardware Button sind jetzt im Admin.
Der Admin überschreibt das Script. Die Farbe der Button beschreibt die Konfiguration.
Grün -> enkoppelt und konfiguriert
Orange -> gekoppelt mit Relais, aber Konfiguration vorhanden
Grau -> gekoppelt mit Relais ohne Konfiguration.Liegen in de Kachel der Panel im Tab NSPanel-Einstellungen.
Ich glaube es ist selbsterklärend, Doku kommt aber noch. -
Ich glaube es ist selbsterklärend, Doku kommt aber noch.die Hardware Button sind jetzt im Admin.
Ich glaube es ist selbsterklärend, Doku kommt aber noch.Hab ich heute morgen schon mal getestet. Hat super funktioniert und war auch selbsterklärend - zumindest für mich :). Super Job!
