  3. Einsteigerfragen
  4. Installation
  5. Phantastische Repositories und wo sie zu finden sind
36 Beiträge 9 Kommentatoren 13.9k Aufrufe 20 Beobachtet
  • MartinPM MartinP
    Erster Run
    ioBroker nodejs fixer 2026-01-31
    You requested to install latest version from nodejs v22 tree.
    Your current setup is:
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 100
         20.19.2+dfsg-1 500
            500 http://ftp.debian.org/debian trixie/main amd64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are missing the nodesource.list or
    you want to change your current nodejs version: v22.22.0 ?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    You are running nodejs v22.22.0. Do you want to install latest version from nodejs v.22 tree?
    rm: cannot remove '': No such file or directory
    Stopping ioBroker now
    ioBroker has been stopped
    Removing dfsg-nodejs
    *** These repos are active on your system:
    Hit:1 http://ftp.debian.org/debian trixie InRelease
    Hit:2 http://ftp.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org trixie-security InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Get:5 https://repos.influxdata.com/debian stable InRelease [6913 B]
    Fetched 6913 B in 0s (15.8 kB/s)
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://ftp.debian.org/debian trixie InRelease
    Hit:3 http://ftp.debian.org/debian trixie-updates InRelease
    Get:4 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
    Hit:5 https://apt.grafana.com stable InRelease
    Get:6 https://repos.influxdata.com/debian stable InRelease [6913 B]
    Get:7 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [9068 B]
    Fetched 28.1 kB in 1s (54.7 kB/s)
    Installing nodejs now!
    Installing latest nodejs v22 release
    SUCCESS!
    v22.22.0 has been installed! You are using the latest nodejs@22 release now!
    COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
    add node-aead-crypto-win32-x64-msvc 3.0.1
    add node-aead-crypto-win32-ia32-msvc 3.0.1
    add node-aead-crypto-win32-arm64-msvc 3.0.1
    add node-aead-crypto-linux-arm64-musl 3.0.1
    add node-aead-crypto-linux-arm64-gnu 3.0.1
    add node-aead-crypto-linux-arm-gnueabihf 3.0.1
    add node-aead-crypto-darwin-x64 3.0.1
    add node-aead-crypto-darwin-universal 3.0.1
    add node-aead-crypto-darwin-arm64 3.0.1
    add node-aead-crypto-android-arm64 3.0.1
    add node-aead-crypto-android-arm-eabi 3.0.1
    add fsevents 2.3.3
    add @img/sharp-win32-x64 0.34.5
    add @img/sharp-win32-ia32 0.34.5
    add @img/sharp-win32-arm64 0.34.5
    add @img/sharp-wasm32 0.34.5
    add @img/sharp-linuxmusl-arm64 0.34.5
    add @img/sharp-linux-s390x 0.34.5
    add @img/sharp-linux-riscv64 0.34.5
    add @img/sharp-linux-ppc64 0.34.5
    add @img/sharp-linux-arm64 0.34.5
    add @img/sharp-linux-arm 0.34.5
    add @img/sharp-libvips-linuxmusl-arm64 1.2.4
    add @img/sharp-libvips-linux-s390x 1.2.4
    add @img/sharp-libvips-linux-riscv64 1.2.4
    add @img/sharp-libvips-linux-ppc64 1.2.4
    add @img/sharp-libvips-linux-arm64 1.2.4
    add @img/sharp-libvips-linux-arm 1.2.4
    add @img/sharp-libvips-darwin-x64 1.2.4
    add @img/sharp-libvips-darwin-arm64 1.2.4
    add @img/sharp-darwin-x64 0.34.5
    add @img/sharp-darwin-arm64 0.34.5
    add @emnapi/runtime 1.8.1
    add tslib 2.8.1
    added 34 packages in 11s
    217 packages are looking for funding
      run `npm fund` for details
    *** You need to manually restart your container/virtual machine now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    martin@iobroker-test-sicher:~$
    Dann Reboot
    Erstmal passiert bei iob diag nicht viel (läuft jetzt vielleich 4 Minuten auf meiner lahmen N3000 Krücke)
    *** iob diag is starting up, please wait ***
    The state system.host.iobroker-test-sicher.versions.nodeNewestNext was not found!
    The state system.host.iobroker-test-sicher.versions.npmNewestNext was not found!
    Bis auf diese Warnungen zu Beginn sieht aber alles auf den ersten Blick Sauber aus.
    EDIT: Beim zweiten Durchlauf kamen die "...not found!" Warnungen nicht mehr
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker-test-sicher
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.17.9-1-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Celeron(R) CPU  N3000  @ 1.04GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     14:05:33 up 3 min,  0 users,  load average: 9.30, 7.11, 4.48
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-02-09 14:05:34 CET
               Universal time: Mon 2026-02-09 13:05:34 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    martin
    HOME=/home/martin
    GROUPS=martin sudo iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/martin
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            6.4G        2.2G        3.5G        770K        805M        4.3G
    Swap:           6.4G          0B        6.4G
    Total:           12G        2.2G        9.9G
    Active iob-Instances:   10
             6144 M total memory
             2078 M used memory
             2503 M active memory
              230 M inactive memory
             3297 M free memory
                0 M buffer memory
              768 M swap cache
             6144 M total swap
                0 M used swap
             6144 M free swap
    top - 14:05:35 up 3 min,  0 users,  load average: 8.64, 7.01, 4.46
    Tasks:  57 total,   2 running,  55 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 55.2 us, 41.4 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  3.4 si,  0.0 st
    MiB Mem :   6144.0 total,   3294.2 free,   2081.8 used,    768.6 buff/cache
    MiB Swap:   6144.0 total,   6144.0 free,      0.0 used.   4062.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4       63G   29G   31G  49% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  100K  1.6G   1% /run
    tmpfs                            tmpfs     3.9G  648K  3.9G   1% /tmp
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
    /var:
    7.1G    /var/
    3.5G    /var/log/journal/d439bcaaab604c09ae284e4b626b2033
    3.5G    /var/log
    2.6G    /var/lib
    Archived and active journals take up 1.7G in the file system.
    /opt/iobroker/backups:
    14G     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    357M    /opt/iobroker/iobroker-data/
    199M    /opt/iobroker/iobroker-data/files
    109M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    41M     /opt/iobroker/iobroker-data/objects.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    8.5M    /opt/iobroker/iobroker-data/states.jsonl
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
    7.5M    /opt/iobroker/iobroker-data/files/flexcharts/echarts.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Version table:
     *** 22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker-test-sicher iobroker-test-sicher (version: 7.0.7, hostname: iobroker-test-sicher, alive, uptime: 256)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.11
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-test-sicher                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iobroker-test-sicher                     -  enabled
      system.adapter.backitup.0               : backitup              : iobroker-test-sicher                     -  enabled
      system.adapter.discovery.0              : discovery             : iobroker-test-sicher                     -  enabled
    + system.adapter.email.0                  : email                 : iobroker-test-sicher                     -  enabled
      system.adapter.ems-esp.0                : ems-esp               : iobroker-test-sicher                     -  enabled
      system.adapter.fahrplan.0               : fahrplan              : iobroker-test-sicher                     - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-test-sicher                     -  enabled
      system.adapter.flexcharts.0             : flexcharts            : iobroker-test-sicher                     -  enabled
      system.adapter.frigate.0                : frigate               : iobroker-test-sicher                     - disabled
      system.adapter.fritzdect.0              : fritzdect             : iobroker-test-sicher                     -  enabled
      system.adapter.ical.0                   : ical                  : iobroker-test-sicher                     -  enabled
      system.adapter.ical.1                   : ical                  : iobroker-test-sicher                     -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker-test-sicher                     -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker-test-sicher                     -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker-test-sicher                     -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker-test-sicher                     -  enabled
      system.adapter.meross.0                 : meross                : iobroker-test-sicher                     -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-test-sicher                     -  enabled, port: 1888
      system.adapter.mqtt-client.1            : mqtt-client           : iobroker-test-sicher                     - disabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-test-sicher                     -  enabled, port: 1888, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : iobroker-test-sicher                     - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.operating-hours.0        : operating-hours       : iobroker-test-sicher                     -  enabled
      system.adapter.parser.0                 : parser                : iobroker-test-sicher                     - disabled
      system.adapter.ping.0                   : ping                  : iobroker-test-sicher                     -  enabled
      system.adapter.reolink.0                : reolink               : iobroker-test-sicher                     -  enabled
      system.adapter.reolink.1                : reolink               : iobroker-test-sicher                     -  enabled
      system.adapter.simple-api.0             : simple-api            : iobroker-test-sicher                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.snmp.0                   : snmp                  : iobroker-test-sicher                     -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker-test-sicher                     -  enabled, port: 1892, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : iobroker-test-sicher                     -  enabled
      system.adapter.tradfri.0                : tradfri               : iobroker-test-sicher                     -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker-test-sicher                     -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker-test-sicher                     -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-test-sicher                     -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-test-sicher                     -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-test-sicher                     -  enabled
      system.adapter.web.0                    : web                   : iobroker-test-sicher                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "benchmark"    : 1.3.0    , installed 1.3.0
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "ems-esp"      : 7.0.1    , installed 7.0.1
    Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
    Adapter    "frigate"      : 1.3.2    , installed 1.3.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "operating-hours": 1.4.0  , installed 1.4.0
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "snmp"         : 3.3.0    , installed 3.3.0
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "zigbee2mqtt"  : 3.0.10   , installed 3.0.10
    Objects and States
    Objects:        3825
    States:         3402
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Fetched 6913 B in 1s (8192 B/s)
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5381338    1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5382084    317/master
    tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       5391946    542/io.sonoff.0
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       5391952    531/io.mqtt.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5383697    340/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5383702    340/iobroker.js-con
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        5383733    339/grafana
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       5396821    732/io.simple-api.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        5382602    104/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5386763    374/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       5396953    706/io.web.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          5381340    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5380857    1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5382085    317/master
    udp        0      0 0.0.0.0:48753           0.0.0.0:*                           1001       5396372    624/io.snmp.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          5381937    229/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5381339    1/init
    udp        0      0 0.0.0.0:33351           0.0.0.0:*                           1001       5396129    717/io.tradfri.0
    udp6       0      0 :::111                  :::*                                0          5381341    1/init
    udp6       0      0 fe80::b0e1:8dff:fe5:546 :::*                                0          5383296    324/dhclient
    2026-02-09 14:05:09.015  - error: reolink.0 (781) Set mail notification: Value not supported!
    2026-02-09 14:05:11.029  - info: fb-checkpresence.0 (766) createMemberObjects finished successfully
    2026-02-09 14:05:11.040  - info: fb-checkpresence.0 (766) states successfully subscribed
    2026-02-09 14:05:11.046  - info: fb-checkpresence.0 (766) loop successfully started
    2026-02-09 14:05:11.331  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 3.945371775417299 Kompressorbezug 0.659
    2026-02-09 14:05:13.012  - info: ems-esp.0 (644) url1:http://192.168.2.151/api/boiler
    2026-02-09 14:05:21.292  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 3.9402173913043477 Kompressorbezug 0.736
    2026-02-09 14:05:41.515  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 4.130162703379224 Kompressorbezug 0.799
    2026-02-09 14:05:51.437  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 4.0221914008321775 Kompressorbezug 0.721
    2026-02-09 14:05:52.507  - info: mqtt.0 (531) Client [frigate] connected with secret 1770642352500_2281
    2026-02-09 14:05:52.519  - info: mqtt.0 (531) Client [frigate] subscribes on "frig1/#" with regex /^frig1\..*/
    2026-02-09 14:05:52.533  - info: mqtt.0 (531) Client [frigate] subscribes on "frig1/#"  with regex /^mqtt\.0\.frig1\..*/
    2026-02-09 14:05:52.745  - info: mqtt.0 (531) Client [frigate] publishOnSubscribe send all known states
    2026-02-09 14:06:01.313  - info: javascript.0 (396) script.js.Energiezaehler.FoxEssBalkon: STATUS: 200
    2026-02-09 14:06:01.360  - info: javascript.0 (396) script.js.Energiezaehler.FoxEssBalkon: { unit: 'kW', name: 'PVPower', variable: 'pvPower', value: 0.325 }
    2026-02-09 14:06:02.467  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 3.800786369593709 Kompressorbezug 0.763
    2026-02-09 14:06:09.374  - info: ems-esp.0 (644) url1:http://192.168.2.151/api/thermostat
    2026-02-09 14:06:11.298  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 4.046242774566474 Kompressorbezug 0.692
    2026-02-09 14:06:11.798  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: Wert: 4.2 Heizkurvenpunkt - DampedTemp: 4.2 Selflowtemp: 39 File: heizkurvenpunkte_21.txt
    2026-02-09 14:06:21.291  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 4.040404040404041 Kompressorbezug 0.693
    2026-02-09 14:06:25.385  - info: ems-esp.0 (644) end of initializing EMS-ESP states
    2026-02-09 14:06:25.395  - info: ems-esp.0 (644) ems  : polling every 60 secs
    2026-02-09 14:07:02.239  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 4.111405835543767 Kompressorbezug 0.754
    2026-02-09 14:07:21.289  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 4.138851802403204 Kompressorbezug 0.749
    2026-02-09 14:07:41.289  - info: javascript.0 (396) script.js.Energiezaehler.Waermepumpe: COP 4.123711340206185 Kompressorbezug 0.679
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @MartinP sagte in Phantastische Repositories und wo sie zu finden sind:
    Hier schlägt sich das etwas andere Setup über nodejs-update nieder:
    Bei nodesoure sind die da etwas weniger rabiat (oder Bescheidener) und setzen die Prio statt auf 1001 nur auf 600.
    Damit würden aber Downgrades von höheren Versionen als die aktuelle Empfehlung für den ioBroker nicht mehr so einfach über nodejs-update funktionieren.
    • MartinPM
      MartinPM
      MartinP
      Soll ich da noch den Issue im JS-Controller aufmachen?
      Bisher läuft alles solide durch, seit dem Update.
      Alle selbstgemachten LXC-Container mit Debian als Unterbau und der PVE sind auf Trixie..
      Problemkind ist ein Turnkey-Linux Fileserver... Die meinen, man solle statt ein Update zu machen einfach einen neuen Container herunterladen..
      Muss ich mich einlesen, was das Übertragen der Konfiguration angeht.
      Zwei Contauner mit Ubuntu Unterbau sind auf noble, und das sollte bis auf Weiteres noch aktuell sein...
      Bei Docker muss ich noch schauen, ob da auch etwas umkonfiguriert werden muss...
      • MartinPM MartinP
        haus-automatisierungH
        Wäre ja schon cool, wenn diese Objekte direkt erstellt würden. Anscheinend dauert es ja eine Weile bis diese Prüfung stattfindet.
        Ist aber eher Kosmetik, weil das diag Script ja einfach nur "zu früh" nach den Infos gefragt hatte.
        📚 Meine Dokumentation
        • K
          K
          Kanumouse
          Ich brauche mal eure Hilfe.
          Wollte gerade unter "Trixie" Grafana installieren, funktioniert leider nicht.
          Bei "sudo apt-get install -y apt-transport-https software-properties-common wget" bringt er immer "Unable to locate package software-properties-common".
          Wie löse ich das Problem?
          • K Kanumouse
            Thomas BraunT
            Thomas BraunT
            @Kanumouse
            Lass die Zeile weg. Die Pakete sind ohnehin veraltet. Ich weiß gar nicht, warum die das in ihrer Anleitung noch drin haben.
              @Kanumouse
              K
              K
              Kanumouse
              @Thomas-Braun
              Danke für die schnelle Rückmeldung - Installation hat geklappt.
              • K Kanumouse
                @Thomas-Braun
                Thomas BraunT
                Thomas BraunT
                @Kanumouse
                Ich hab gerade noch ein paar Änderungen hinzugefügt. Die grafana-Leutchens scheinen alle Nas' lang da was zu ändern.
                • FreunderNachtF
                  FreunderNachtF
                  FreunderNacht
                  Besten Dank für die Zusammenstellung 👍
                  Intel NUC mit Proxmox
                  IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
                  Influx DB
                  Grafana
                  PiHole
                  PiVPN
                  • DuffyD
                    DuffyD
                    Duffy
                    Hallo Thomas Braun,
                    ich versuche gerade eine neue Maschine für mein Smart Home einzurichten.
                    Ich habe dazu Debian und iob installiert über den Backup Adapter die Einstellungen auf den neuen Rechner geholt und bin jetzt dran influx zu installieren. Hier kommt nun folgende Meldung:
                    Was soll mir die Meldung sagen bzw was soll ich auswählen?
                    Ich habe zuvor kein Influx installiert oder hat der Backup adapter das für mich gemacht?
                    Mini PC ASUS PN42 N100 / 32 GB RAM
                    Node.js: v24.22.2
                    NPM: 11.19.1
                    js-controller 7.2.5
                    Linux: Trixie
                    • DuffyD Duffy
                      Hallo Thomas Braun,
                      Thomas BraunT
                      Thomas BraunT
                      @Duffy
                      Ich würde die Version des Paketbetreuers installieren.
                      • DuffyD
                        DuffyD
                        Duffy
                        Danke dir vielmals für die schnelle Antwort.
                        Node.js: v24.22.2
                        NPM: 11.19.1
                        js-controller 7.2.5
                        Linux: Trixie
                        • DuffyD Duffy
                          Thomas BraunT
                          Thomas BraunT
                          Und die längere Erklärung ist:
                          Eigentlich schaut man sich die Unterschiede zwischen den Versionen an. Insbesondere, wenn es sich um Dateien handelt, in denen mal selber systemindividuelle Einstellungen getätigt hat.
                          Das ist aber bei der influxdata.list eher nicht der Fall. Hier wird wohl nur vom Paketbetreuer ein neuer Key reingezogen, deswegen verwendet man dessen geänderte Konfigurationsdatei in diesem Fall.
                          • DuffyD
                            DuffyD
                            Duffy
                            Das system war sozusagen Jungfräulich ich hatte da noch gar nichts mit Influx dran gemacht.
                            Ich hatte die mir die Unterschiede mal anzeigen lassen aber nur Bahnhof verstanden.
                            Node.js: v24.22.2
                            NPM: 11.19.1
                            js-controller 7.2.5
                            Linux: Trixie
                            • DuffyD Duffy
                              Thomas BraunT
                              Thomas BraunT
                              @Duffy sagte:
                              Ja, deswegen zieht man dann ja auch die aktuellste Version der Datei rein.
                              DuffyD 1 Antwort Letzte Antwort
                                @Duffy sagte:
                                DuffyD
                                DuffyD
                                Duffy
                                @Thomas-Braun
                                aber woher kommt den dan die "alte" Datei wenn ich noch gar nichts mit Influx installieret hatte?
                                Node.js: v24.22.2
                                NPM: 11.19.1
                                js-controller 7.2.5
                                Linux: Trixie
                                haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                                • DuffyD Duffy
                                  @Thomas-Braun
                                  haselchenH
                                  haselchenH
                                  haselchen
                                  @Duffy
                                  Vermutlich , weil Du im BackitUp Adapter Influx angehakt hast zur Sicherung.
                                  Ich kann Dir nur ans Herz legen, Dich mal intensiv mit der Materie zu beschäftigen.
                                  Es ist schon auffällig, dass jede noch so kleine Abweichung ein Thema für Dich hier ist.
                                  • DuffyD Duffy
                                    @Thomas-Braun
                                    Thomas BraunT
                                    Thomas BraunT
                                    @Duffy sagte:
                                    Die legst du ja mit der Zeile
                                    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                    selber erstmal an. Und wenn du dann aus dieser Quelle das Paket für influx ziehst hat dieses Paket wiederum eine influxdata.list im Beutel. Und die ist leicht anders als die von dir manuell angelegte Datei. Deswegen auch die Meldung.
                                    • DuffyD Duffy
                                      Hallo Thomas Braun,
                                      Thomas BraunT
                                      Thomas BraunT
                                      @Duffy
                                      Steht übrigens genau so auch oben als Kommentar dabei...
                                      Falls es zu Rückfragen kommen sollte, dass neue Dateien einen anderen Inhalt haben und welche übernommen werden soll, nehmt die Version vom Paketersteller. Hintergrund:
                                      Influxdb bringt nun ein eigenes Paket mit den Schlüsseln mit und hält die dann künftig darüber aktuell.
                                      84.2k
