  3. Einsteigerfragen
  4. Installation
  5. Komme nach Admin 8.1.1 Update nicht mehr auf den iob [gel.]
31 Beiträge 6 Kommentatoren 1.0k Aufrufe 5 Beobachtet
  • DuffyD
    DuffyD
    Duffy
    da kommt dann:
    pi@raspberrypi:~ $ iob repo unset beta
    Repository "beta" deactivated.
    Active repo(s): stable
    Upgrade policy: none
    pi@raspberrypi:~ $ iob repo set stable
    Repository "stable" set as active.
    pi@raspberrypi:~ $ iob update
    Used repository: stable
    Adapter    "admin"        : 8.0.14   , installed 8.1.1
    Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
    Adapter    "backitup"     : 4.0.3    , installed 4.0.3
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.15.17 , installed 2.15.17
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "drag-indicator": 2.6.1   , installed 2.6.1
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.4
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hoymiles"     : 0.4.1    , installed 0.4.1
    Adapter    "ical"         : 1.21.0   , installed 1.21.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 6.0.3    , installed 6.0.3
    Adapter    "javascript"   : 10.1.3   , installed 10.1.3
    Controller "js-controller": 7.2.2    , installed 7.2.2
    Adapter    "matter"       : 1.3.1    , installed 1.3.1
    Adapter    "midea"        : 0.0.7    , installed 1.8.6
    Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "operating-hours": 1.5.1  , installed 1.5.1
    Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
    Adapter    "sainlogic"    : 1.2.10   , installed 1.2.8  [Updatable]
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "statistics"   : 5.0.0    , installed 5.0.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 5.0.5    , installed 5.0.5
    Adapter    "text2command" : 4.0.0    , installed 4.0.0
    Adapter    "trashschedule": 5.3.0    , installed 5.3.0
    Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
    Adapter    "vis-2-widgets-inventwo": 1.10.0, installed 1.10.0
    Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
    Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-icontwo"  : 2.11.6   , installed 2.11.6
    Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "zigbee"       : 3.5.5    , installed 3.5.5
    pi@raspberrypi:~ $ iob update admin@8.1.1
    Used repository: admin@8.1.1
    Error: unknown repository is active - "admin@8.1.1". Known: stable, beta
    pi@raspberrypi:~ $
    Soll ich vielleicht einfach, wie auch immer versuchen, wieder auf Admin 8.0.14 zu kommen und die Finger weg zu lassen bis ein Nachfolger kommt?
    @oliverio
    das ist ja eine riesen Liste.
    ich schicke mal das ab 17:42
    2026-10-09 17:46:39.090  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
    2026-10-09 17:46:39.091  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24
    2026-10-09 17:47:29.844  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
    2026-10-09 17:47:39.593  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
    2026-10-09 17:47:39.593  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24
    2026-10-09 17:48:47.848  - ESC[32minfoESC[39m: fritzdect.0 (3154) DECT ID: 130770157104-1 identified for command (state) : false
    2026-10-09 17:48:57.780  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
    2026-10-09 17:49:05.979  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
    2026-10-09 17:49:05.980  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24
    2026-10-09 17:49:48.230  - ESC[33mwarnESC[39m: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo  failed: No response. Device is Offline or not reachable.
    2026-10-09 17:50:29.585  - ESC[32minfoESC[39m: sonoff.0 (2974) Client [93] connection closed: closed
    2026-10-09 17:50:48.230  - ESC[33mwarnESC[39m: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo  failed: No response. Device is Offline or not reachable.
    2026-10-09 17:51:12.183  - ESC[32minfoESC[39m: sonoff.0 (2974) Client [135] reconnected. Old secret 1791550789559_5409 ==> New secret 1791561072181_459
    2026-10-09 17:51:18.001  - ESC[33mwarnESC[39m: sonoff.0 (2974) Old client 135 with secret 1791550789559_5409 sends pingreq. Ignore! Actual secret is 1791561072181_459
    2026-10-09 17:51:27.133  - ESC[32minfoESC[39m: opendtu.0 (2957) Connect to OpenDTU over websocket connection.
    2026-10-09 17:51:48.232  - ESC[33mwarnESC[39m: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo  failed: No response. Device is Offline or not reachable.
    2026-10-09 17:52:27.163  - ESC[32minfoESC[39m: opendtu.0 (2957) Connect to OpenDTU over websocket connection.
    2026-10-09 17:52:39.747  - ESC[32minfoESC[39m: sonoff.0 (2974) Client [Waschmaschine] reconnected. Old secret 1791559898492_9401 ==> New secret 1791561159733_3498
    2026-10-09 17:52:48.234  - ESC[33mwarnESC[39m: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo  failed: No response. Device is Offline or not reachable.
    2026-10-09 17:52:50.209  - ESC[32minfoESC[39m: sonoff.0 (2974) Client [93] connected with secret 1791561170209_4263
    2026-10-09 17:53:42.844  - ESC[32minfoESC[39m: sonoff.0 (2974) Client [Kaffeemaschine] reconnected. Old secret 1791559901612_949 ==> New secret 1791561222843_6279
    2026-10-09 17:53:43.951  - ESC[32minfoESC[39m: sonoff.0 (2974) Client [Bambu] reconnected. Old secret 1791559898437_8132 ==> New secret 1791561223950_5103
    2026-10-09 17:53:49.351  - ESC[32minfoESC[39m: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.157 vis.0
    2026-10-09 17:54:26.128  - ESC[32minfoESC[39m: device-watcher.0 (3113) [main] Pending rescan detected – Schleife wird wiederholt
    2026-10-09 17:54:36.937  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
    2026-10-09 17:55:00.754  - ESC[32minfoESC[39m: fritzdect.0 (3154) DECT ID: 130770157104-1 identified for command (state) : true
    2026-10-09 17:59:31.126  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
    2026-10-09 17:59:31.127  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 16.998085132034966
    2026-10-09 17:59:41.920  - ESC[32minfoESC[39m: web.0 (3373) ==> Connected system.user.admin from ::ffff:192.168.178.157
    2026-10-09 18:00:00.062  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.ical.0 in version "1.21.0" started with pid 10531
    2026-10-09 18:00:05.922  - ESC[32minfoESC[39m: ical.0 (10531) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v24.21.0, js-controller: 7.2.2
    2026-10-09 18:00:06.882  - ESC[32minfoESC[39m: ical.0 (10531) processing URL: Müllkalender 2026 https://www.bodenseekreis.de/umwelt-landnutzung/abfallentsorgung-privat/termine/abfuhrkalender/export/?tx_bodenseeawacalendar_export%5Baction%5D=export&tx_bodenseeawacalendar_export%5Bcity%5D=29&tx_bodenseeawacalendar_export%5Bcontroller%5D=Date&tx_bodenseeawacalendar_export%5Bdistrict%5D=2&tx_bodenseeawacalendar_export%5Bformat%5D=ics&tx_bodenseeawacalendar_export%5Bwastetypes%5D=1%2C4%2C5%2C16%2C10&tx_bodenseeawacalendar_export%5Byear%5D=12&cHash=9410b95f31ec5d824a1305660dfa76cc
    2026-10-09 18:00:10.088  - ESC[32minfoESC[39m: ical.0 (10531) processing URL: Kalender Maja http://p112-caldav.icloud.com/published/2/MTc0OTA0NjQ5MzIxNzQ5MC3o5FbqrGsIxq-UvmKpnEAXzEwGEW27fhZhYk-3piM-c6raW10BddpftpFtsrP_I_8uKDw2bQjt8LKiLxhtFCE
    2026-10-09 18:00:14.468  - ESC[32minfoESC[39m: ical.0 (10531) processing URL: Kalender Udo http://p40-caldav.icloud.com/published/2/MTE2MjQ1OTg0NzUxMTYyNMwnTSBDOs3OP41iUXZ1Lhq0aKYRTk6VX6xh5iD7iXpz8bRf2RoLVH5uG86xRYpf-ReclET4nAD1FM8nWRDbmUA
    2026-10-09 18:00:21.013  - ESC[32minfoESC[39m: ical.0 (10531) Terminated (NO_ERROR): Without reason
    2026-10-09 18:00:21.576  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.ical.0 having pid 10531 terminated with code 0 (NO_ERROR)
    2026-10-09 18:00:42.204  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
    2026-10-09 18:01:01.263  - ESC[32minfoESC[39m: mystrom.0 (3209) Set update interval for 34987A62B244 to 60
    2026-10-09 18:01:01.334  - ESC[32minfoESC[39m: mystrom.0 (3209) Set update interval for C8F09EBDB064 to 60
    2026-10-09 18:01:01.406  - ESC[32minfoESC[39m: mystrom.0 (3209) Set update interval for 083AF2735EC4 to 60
    2026-10-09 18:01:14.277  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
    2026-10-09 18:01:14.277  - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 16.998085132034966
    2026-10-09 18:04:02.568  - ESC[32minfoESC[39m: web.0 (3373) ==> Connected system.user.admin from ::ffff:192.168.178.188
    2026-10-09 18:04:08.591  - ESC[32minfoESC[39m: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.188 vis.0
    2026-10-09 18:05:57.538  - ESC[32minfoESC[39m: opendtu.0 (2957) Connect to OpenDTU over websocket connection.
    2026-10-09 18:06:13.368  - ESC[32minfoESC[39m: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.157 vis.0
    (END)
    Mini PC ASUS PN42 N100 / 32 GB RAM
    Node.js: v24.22.2
    NPM: 11.19.1
    js-controller 7.2.5
    Linux: Trixie
    • DuffyD Duffy
      @thomas-braun @ @oliverio
      Ich habe die Befehle von Thomas Braun ausgeführt. Noch komme ich nicht auf den iob. Jetzt kommen im Log aber Errors.
      Für die komplette Übersicht schicke ich jetzt aber nicht nur das Log File sondern noch mal die komplette iob diag.
      Script v.2026-08-30
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.18.50+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      System was installed 1095 days ago (on 2023-10-10).
      Systemuptime and Load:
       17:44:35 up  2:51,  1 user,  load average: 1.16, 1.20, 0.98
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2026-10-09 17:44:35 CEST
                 Universal time: Fri 2026-10-09 15:44:35 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         Unknown
      Display-Manager:        Not found
      Desktop:
      Session:                tty
      Boot Target:            multi-user.target
      *** MEMORY ***
      Mem:            8.2G        4.5G        1.1G         18M        2.8G        3.7G
      Swap:           209M         26M        183M
      Total:          8.4G        4.5G        1.3G
      Active iob-Instances:   31
               7818 M total memory
               4274 M used memory
               1017 M active memory
               5347 M inactive memory
               1038 M free memory
                114 M buffer memory
               2507 M swap cache
                199 M total swap
                 25 M used swap
                174 M free swap
      top - 17:44:36 up  2:51,  1 user,  load average: 1.16, 1.20, 0.98
      Tasks: 219 total,   1 running, 218 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  9.1 us,  4.5 sy,  0.0 ni, 86.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7818.7 total,   1037.6 free,   4274.8 used,   2623.1 buff/cache
      MiB Swap:    200.0 total,    174.8 free,     25.2 used.   3543.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     1.6G   11M  1.6G   1% /run
      /dev/sda2      ext4       29G   17G   12G  59% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     3.9G  7.3M  3.9G   1% /tmp
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      /dev/sda1      vfat      510M   76M  435M  15% /boot/firmware
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
      Messages concerning filesystems in dmesg (Last 15 lines only):
      [Fri Oct  9 14:53:04 2026] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
      [Fri Oct  9 14:53:07 2026] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      4.3G    /var/
      1.6G    /var/lib
      1.5G    /var/log/journal/458ebafb08a8432dbfe417c962c32f87
      1.5G    /var/log
      Archived and active journals take up 1.4G in the file system.
      /opt/iobroker/backups:
      1.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      637M    /opt/iobroker/iobroker-data/
      369M    /opt/iobroker/iobroker-data/files
      169M    /opt/iobroker/iobroker-data/backup-objects
      91M     /opt/iobroker/iobroker-data/files/vis
      85M     /opt/iobroker/iobroker-data/files/vis/widgets
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      16M     /opt/iobroker/iobroker-data/states.jsonl
      16M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-EdnNzxJx.js
      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** ZigBee Settings ***
      Zigbee Network Settings on your coordinator / in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      === ZigBee Port Overview ===
      Instance        Configured Port                     Available by-id Port                Status
      zigbee.0        ...ngle_Plus_0001-if00-port0        ...ngle_Plus_0001-if00-port0        ✓ Matching
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v24.21.0
      /usr/bin/node           v24.21.0
      /usr/bin/npm            11.19.0
      /usr/bin/npx            11.19.0
      ✓ Node.js installation is correct
      nodejs:
        Installed: 24.21.0-1nodesource1
        Candidate: 24.21.0-1nodesource1
        Version table:
       *** 24.21.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
           24.20.0-1nodesource1 1001
           24.19.0-1nodesource1 1001
           24.18.1-1nodesource1 1001
           24.18.0-1nodesource1 1001
           24.17.0-1nodesource1 1001
           24.16.0-1nodesource1 1001
           24.15.0-1nodesource1 1001
           24.14.1-1nodesource1 1001
           24.14.0-1nodesource1 1001
           24.13.1-1nodesource1 1001
           24.13.0-1nodesource1 1001
           24.12.0-1nodesource1 1001
           24.11.1-1nodesource1 1001
           24.11.0-1nodesource1 1001
           24.10.0-1nodesource1 1001
           24.9.0-1nodesource1 1001
           24.8.0-1nodesource1 1001
           24.7.0-1nodesource1 1001
           24.6.0-1nodesource1 1001
           24.5.0-1nodesource1 1001
           24.4.1-1nodesource1 1001
           24.4.0-1nodesource1 1001
           24.3.0-1nodesource1 1001
           24.1.0-1nodesource1 1001
           24.0.2-1nodesource1 1001
           24.0.1-1nodesource1 1001
           24.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u3 500
              500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
           20.19.2+dfsg-1+deb13u2 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      No known Vulnerabilities detected!
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.2.2, hostname: raspberrypi   , alive, uptime: 9981)
      Core adapters versions
      admin:          8.1.1
      javascript:     10.1.3
      nodejs modules from github:     2
      +-- iobroker.fritzdect@2.6.4 (git+ssh://git@github.com/foxthefox/ioBroker.fritzdect.git#34f52e97e85bf384e919a144d9ccd6335e5aa8e9)
      +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a)
      Adapter State
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              - disabled
      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + system.adapter.drag-indicator.0         : drag-indicator        : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
        system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              - disabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.hoymiles.0               : hoymiles              : raspberrypi                              - disabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.matter.0                 : matter                : raspberrypi                              -  enabled
        system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              - disabled
        system.adapter.midea.0                  : midea                 : raspberrypi                              - disabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
      + system.adapter.mystrom.0                : mystrom               : raspberrypi                              -  enabled
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
      + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.sainlogic.0              : sainlogic             : raspberrypi                              - disabled, port: 1847, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
        system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
        system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Adapters
      │ (index) │ id                                           │ name                          │ version   │ upgrade policy │
      │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '8.1.1'   │ 'none'         │
      │ 1       │ 'system.adapter.alexa2'                      │ 'alexa2'                      │ '3.28.3'  │ 'none'         │
      │ 2       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '4.0.3'   │ 'none'         │
      │ 3       │ 'system.adapter.device-reminder'             │ 'device-reminder'             │ '3.1.2'   │ 'none'         │
      │ 4       │ 'system.adapter.device-watcher'              │ 'device-watcher'              │ '2.15.17' │ 'none'         │
      │ 5       │ 'system.adapter.devices'                     │ 'devices'                     │ '1.2.14'  │ 'none'         │
      │ 6       │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'   │ 'none'         │
      │ 7       │ 'system.adapter.drag-indicator'              │ 'drag-indicator'              │ '2.6.1'   │ 'none'         │
      │ 8       │ 'system.adapter.echarts'                     │ 'echarts'                     │ '3.1.0'   │ 'none'         │
      │ 9       │ 'system.adapter.energiefluss'                │ 'energiefluss'                │ '3.6.2'   │ 'none'         │
      │ 10      │ 'system.adapter.energiefluss-erweitert'      │ 'energiefluss-erweitert'      │ '0.8.1'   │ 'none'         │
      │ 11      │ 'system.adapter.feiertage'                   │ 'feiertage'                   │ '1.4.0'   │ 'none'         │
      │ 12      │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0'  │ 'none'         │
      │ 13      │ 'system.adapter.fritzdect'                   │ 'fritzdect'                   │ '2.6.4'   │ 'none'         │
      │ 14      │ 'system.adapter.fullybrowser'                │ 'fullybrowser'                │ '3.1.2'   │ 'none'         │
      │ 15      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'   │ 'none'         │
      │ 16      │ 'system.adapter.hoymiles'                    │ 'hoymiles'                    │ '0.4.1'   │ 'none'         │
      │ 17      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.21.0'  │ 'none'         │
      │ 18      │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0'   │ 'none'         │
      │ 19      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'   │ 'none'         │
      │ 20      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'   │ 'none'         │
      │ 21      │ 'system.adapter.iot'                         │ 'iot'                         │ '6.0.3'   │ 'none'         │
      │ 22      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '10.1.3'  │ 'none'         │
      │ 23      │ 'system.adapter.matter'                      │ 'matter'                      │ '1.3.1'   │ 'none'         │
      │ 24      │ 'system.adapter.mercedesme'                  │ 'mercedesme'                  │ '0.7.2'   │ 'none'         │
      │ 25      │ 'system.adapter.midea'                       │ 'midea'                       │ '1.8.6'   │ 'none'         │
      │ 26      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.4'   │ 'none'         │
      │ 27      │ 'system.adapter.mystrom'                     │ 'mystrom'                     │ '0.1.0'   │ 'none'         │
      │ 28      │ 'system.adapter.net-tools'                   │ 'net-tools'                   │ '1.2.3'   │ 'none'         │
      │ 29      │ 'system.adapter.opendtu'                     │ 'opendtu'                     │ '3.1.0'   │ 'none'         │
      │ 30      │ 'system.adapter.operating-hours'             │ 'operating-hours'             │ '1.5.1'   │ 'none'         │
      │ 31      │ 'system.adapter.rpi2'                        │ 'rpi2'                        │ '3.0.2'   │ 'none'         │
      │ 32      │ 'system.adapter.sainlogic'                   │ 'sainlogic'                   │ '1.2.8'   │ 'none'         │
      │ 33      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'   │ 'none'         │
      │ 34      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'   │ 'none'         │
      │ 35      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.3.0'   │ 'none'         │
      │ 36      │ 'system.adapter.sourceanalytix'              │ 'sourceanalytix'              │ '0.4.14'  │ 'none'         │
      │ 37      │ 'system.adapter.statistics'                  │ 'statistics'                  │ '5.0.0'   │ 'none'         │
      │ 38      │ 'system.adapter.switchbot-hub'               │ 'switchbot-hub'               │ '0.1.2'   │ 'none'         │
      │ 39      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'   │ 'none'         │
      │ 40      │ 'system.adapter.telegram'                    │ 'telegram'                    │ '5.0.5'   │ 'none'         │
      │ 41      │ 'system.adapter.text2command'                │ 'text2command'                │ '4.0.0'   │ 'none'         │
      │ 42      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'   │ 'none'         │
      │ 43      │ 'system.adapter.trashschedule'               │ 'trashschedule'               │ '5.3.0'   │ 'none'         │
      │ 44      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'   │ 'none'         │
      │ 45      │ 'system.adapter.vis-2'                       │ 'vis-2'                       │ '2.13.8'  │ 'none'         │
      │ 46      │ 'system.adapter.vis-2-widgets-inventwo'      │ 'vis-2-widgets-inventwo'      │ '1.10.0'  │ 'none'         │
      │ 47      │ 'system.adapter.vis-2-widgets-material'      │ 'vis-2-widgets-material'      │ '1.6.1'   │ 'none'         │
      │ 48      │ 'system.adapter.vis-colorpicker'             │ 'vis-colorpicker'             │ '2.1.0'   │ 'none'         │
      │ 49      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'   │ 'none'         │
      │ 50      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.6'  │ 'none'         │
      │ 51      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '4.1.1'   │ 'none'         │
      │ 52      │ 'system.adapter.vis-metro'                   │ 'vis-metro'                   │ '1.2.0'   │ 'none'         │
      │ 53      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'   │ 'none'         │
      │ 54      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'   │ 'none'         │
      │ 55      │ 'system.adapter.vis-weather'                 │ 'vis-weather'                 │ '2.5.13'  │ 'none'         │
      │ 56      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'   │ 'none'         │
      │ 57      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'   │ 'none'         │
      │ 58      │ 'system.adapter.zigbee'                      │ 'zigbee'                      │ '3.5.5'   │ 'none'         │
      ioBroker-Adapter Versions and update status
      Objects and States
      Objects:        14538
      States:         13288
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
      Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B]
      Fetched 6922 B in 0s (21.1 kB/s)
      Reading package lists...
      Pending systemupdates: 0
      *** Listening Ports ***
      Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
      udp   UNCONN 0      0                          0.0.0.0:35805              0.0.0.0:*    users:(("avahi-daemon",pid=560,fd=14))
      udp   UNCONN 0      0                          0.0.0.0:48695              0.0.0.0:*    users:(("io.matter.0",pid=3414,fd=38))
      udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("io.matter.0",pid=3414,fd=40))
      udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("io.matter.0",pid=3414,fd=35))
      udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=560,fd=12))
      udp   UNCONN 0      0                                *:48695                    *:*    users:(("io.matter.0",pid=3414,fd=37))
      udp   UNCONN 0      0      [fe80::e5bd:4ca9:1707:b25b]:dhcpv6-client            *:*    users:(("NetworkManager",pid=666,fd=28))
      udp   UNCONN 0      0                                *:53826                    *:*    users:(("avahi-daemon",pid=560,fd=15))
      udp   UNCONN 0      0                                *:mdns                     *:*    users:(("io.matter.0",pid=3414,fd=41))
      udp   UNCONN 0      0                                *:mdns                     *:*    users:(("io.matter.0",pid=3414,fd=36))
      udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=560,fd=13))
      tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=793,fd=6))
      tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=2815,fd=23))
      tcp   LISTEN 0      511                        0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=2974,fd=40))
      tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=2815,fd=29))
      tcp   LISTEN 0      20                       127.0.0.1:smtp               0.0.0.0:*    users:(("exim4",pid=1088,fd=5))
      tcp   LISTEN 0      4096                             *:3000                     *:*    users:(("grafana",pid=1140,fd=82))
      tcp   LISTEN 0      4096                             *:8086                     *:*    users:(("influxd",pid=806,fd=2353))
      tcp   LISTEN 0      511                              *:8087                     *:*    users:(("io.simple-api.0",pid=3374,fd=35))
      tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=3373,fd=35))
      tcp   LISTEN 0      511                              *:48695                    *:*    users:(("io.matter.0",pid=3414,fd=39))
      tcp   LISTEN 0      20                           [::1]:smtp                  [::]:*    users:(("exim4",pid=1088,fd=6))
      tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=793,fd=7))
      2026-10-09 17:31:01.479  - info: mystrom.0 (3209) Set update interval for 083AF2735EC4 to 60
      2026-10-09 17:31:38.439  - info: sonoff.0 (2974) Client [Bambu] reconnected. Old secret 1791550789987_9437 ==> New secret 1791559898437_8132
      2026-10-09 17:31:38.493  - info: sonoff.0 (2974) Client [Waschmaschine] reconnected. Old secret 1791550790452_8393 ==> New secret 1791559898492_9401
      2026-10-09 17:31:41.612  - info: sonoff.0 (2974) Client [Kaffeemaschine] reconnected. Old secret 1791550790426_4816 ==> New secret 1791559901612_949
      2026-10-09 17:31:45.673  - info: opendtu.0 (2957) Connect to OpenDTU over websocket connection.
      2026-10-09 17:31:48.185  - info: sonoff.0 (2974) Client [93] reconnected. Old secret 1791550789780_5634 ==> New secret 1791559908185_5077
      2026-10-09 17:32:56.996  - info: fritzdect.0 (3154) DECT ID: 130770157104-1 identified for command (state) : false
      2026-10-09 17:35:22.972  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
      2026-10-09 17:35:27.784  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
      2026-10-09 17:35:27.785  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24
      2026-10-09 17:36:08.764  - info: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.156 vis.0
      2026-10-09 17:36:23.992  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
      2026-10-09 17:36:26.782  - info: opendtu.0 (2957) Connect to OpenDTU over websocket connection.
      2026-10-09 17:36:48.231  - warn: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo  failed: No response. Device is Offline or not reachable.
      2026-10-09 17:37:13.169  - info: web.0 (3373) ==> Connected system.user.admin from ::ffff:192.168.178.156
      2026-10-09 17:39:52.628  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
      2026-10-09 17:39:52.629  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24
      2026-10-09 17:42:04.682  - info: host.raspberrypi "system.adapter.admin.0" disabled
      2026-10-09 17:42:53.534  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
      2026-10-09 17:42:57.413  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
      2026-10-09 17:42:57.413  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24
      2026-10-09 17:43:17.285  - info: host.raspberrypi "system.adapter.admin.0" enabled
      2026-10-09 17:43:17.359  - error: host.raspberrypi startInstance system.adapter.admin.0 Adapter dependency not fulfilled on "raspberrypi": Invalid version of "js-controller". Installed "7.2.2", required ">=7.2.5"
      2026-10-09 17:43:28.366  - error: host.raspberrypi startInstance system.adapter.admin.0 Adapter dependency not fulfilled on "raspberrypi": Invalid version of "js-controller". Installed "7.2.2", required ">=7.2.5"
      2026-10-09 17:43:44.766  - info: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.156 vis.0
      OliverIOO
      OliverIOO
      OliverIO
      @Duffy
      @rscsb danke
      dann die vorgänger version vom admin installieren
      iobroker install admin@8.0.14
      wenn iobroker dann läuft über admin dan den js-controller und admin wieder upgraden
      Meine Adapter und Widgets
      Links im Profil
      • R rscsb
        Das ist der Grund. Entweder wieder in der Version zurück, oder js-controller auch noch updaten.
        Thomas BraunT
        Thomas BraunT
        Most Active Developer
        @rscsb sagte:
        Das ist auch der Grund, warum selektive Updates nicht empfohlen sind.
        js-controller@7.2.5 ist aber noch nicht als stable freigegeben, deswegen würde ich den admin wieder auf die stabile 8.0.14 drücken.
        Also
        iob upgrade admin@8.0.14 --debug
        • DuffyD
          DuffyD
          Duffy
          Vielen Danke ich bin wieder drauf der Abend ist gerettet.
          VG Duffy
          Node.js: v24.22.2
          NPM: 11.19.1
          js-controller 7.2.5
          Linux: Trixie
          • DuffyD Duffy
            VG Duffy
            Thomas BraunT
            Thomas BraunT
            @Duffy
            Dann würde ich künftig die Finger von solchen 'Kunststücken' im Expertenmodus lassen...
            Ein
            iob diag
            schaut nun wie aus?
            • DuffyD
              DuffyD
              Duffy
              schrieb am zuletzt editiert von Duffy
              @Thomas-Braun
              Ich muss dir ja zustimmen und mache das normalerweise auch nicht ihr warnt ja immer davor aber mein kleiner Pi hängt da glaub bös in den Seilen mit dem Admin 8.0.14.
              Hier die iob diag:
              Script v.2026-08-30
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Unknown
              Kernel          : aarch64
              Userland        : 64bit
               18:37:42 up  3:44,  1 user,  load average: 1.07, 0.97, 1.03
              CPU threads     : 4
              Current issues:
                             Local time: Fri 2026-10-09 18:37:43 CEST
                         Universal time: Fri 2026-10-09 16:37:43 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:            8.2G        5.0G        336M         14M        3.0G        3.2G
              Swap:           209M        124M         85M
              Total:          8.4G        5.1G        421M
              Active iob-Instances:   32
                       7818 M total memory
                       4754 M used memory
                       3884 M active memory
                       3243 M inactive memory
                        320 M free memory
                         29 M buffer memory
                       2820 M swap cache
                        199 M total swap
                        118 M used swap
                         81 M free swap
              top - 18:37:43 up  3:44,  1 user,  load average: 1.06, 0.97, 1.03
              Tasks: 222 total,   1 running, 221 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  2.3 us,  0.0 sy,  0.0 ni, 97.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   7818.7 total,    318.7 free,   4755.9 used,   2849.8 buff/cache
              MiB Swap:    200.0 total,     81.6 free,    118.4 used.   3062.8 avail Mem
              *** FILESYSTEM ***
              /var:
              4.3G    /var/
              1.6G    /var/lib
              1.5G    /var/log
              638M    /opt/iobroker/iobroker-data/
              17M     /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspberrypi         raspberrypi (version: 7.2.2, hostname: raspberrypi   , alive, uptime: 13162)
              admin:          8.0.14
              javascript:     10.1.3
              Adapter State
              + instance is alive
              │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '8.0.14'  │ 'none'         │
              Adapter    "admin"        : 8.0.14   , installed 8.0.14
              Objects and States
              Objects:        14544
              States:         13303
              Get:6 https://repos.influxdata.com/debian stable InRelease [6922 B]
              Hit:7 https://deb.nodesource.com/node_24.x nodistro InRelease
              Fetched 6922 B in 0s (17.5 kB/s)
              tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=11426,fd=37))
              2026-10-09 18:30:06.912  - info: ical.0 (12253) processing URL: Müllkalender 2026 https://www.bodenseekreis.de/umwelt-landnutzung/abfallentsorgung-privat/termine/abfuhrkalender/export/?tx_bodenseeawacalendar_export%5Baction%5D=export&tx_bodenseeawacalendar_export%5Bcity%5D=29&tx_bodenseeawacalendar_export%5Bcontroller%5D=Date&tx_bodenseeawacalendar_export%5Bdistrict%5D=2&tx_bodenseeawacalendar_export%5Bformat%5D=ics&tx_bodenseeawacalendar_export%5Bwastetypes%5D=1%2C4%2C5%2C16%2C10&tx_bodenseeawacalendar_export%5Byear%5D=12&cHash=9410b95f31ec5d824a1305660dfa76cc
              2026-10-09 18:30:10.166  - info: ical.0 (12253) processing URL: Kalender Maja http://p112-caldav.icloud.com/published/2/MTc0OTA0NjQ5MzIxNzQ5MC3o5FbqrGsIxq-UvmKpnEAXzEwGEW27fhZhYk-3piM-c6raW10BddpftpFtsrP_I_8uKDw2bQjt8LKiLxhtFCE
              2026-10-09 18:30:14.438  - info: ical.0 (12253) processing URL: Kalender Udo http://p40-caldav.icloud.com/published/2/MTE2MjQ1OTg0NzUxMTYyNMwnTSBDOs3OP41iUXZ1Lhq0aKYRTk6VX6xh5iD7iXpz8bRf2RoLVH5uG86xRYpf-ReclET4nAD1FM8nWRDbmUA
              2026-10-09 18:30:21.073  - info: ical.0 (12253) Terminated (NO_ERROR): Without reason
              2026-10-09 18:30:21.652  - info: host.raspberrypi instance system.adapter.ical.0 having pid 12253 terminated with code 0 (NO_ERROR)
              2026-10-09 18:30:21.669  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
              2026-10-09 18:31:01.678  - info: mystrom.0 (3209) Set update interval for 34987A62B244 to 60
              2026-10-09 18:31:01.729  - info: mystrom.0 (3209) Set update interval for C8F09EBDB064 to 60
              2026-10-09 18:31:01.799  - info: mystrom.0 (3209) Set update interval for 083AF2735EC4 to 60
              2026-10-09 18:31:06.893  - warn: zigbee.0 (3007) State value for 00158d00087468b5.y_axis has value "-956" less than min "0".
              2026-10-09 18:31:56.769  - warn: zigbee.0 (3007) State value for 00158d00087468b5.z_axis has value "-636" less than min "0".
              2026-10-09 18:33:20.852  - info: device-watcher.0 (3113) [main] Pending rescan detected – Schleife wird wiederholt
              2026-10-09 18:34:08.855  - info: sonoff.0 (2974) Client [Kaffeemaschine] connection closed: timeout
              2026-10-09 18:35:03.309  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
              2026-10-09 18:35:03.310  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 2.999853181190793
              2026-10-09 18:35:03.310  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: Birne: true
              2026-10-09 18:38:23.239  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
              2026-10-09 18:38:30.736  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
              2026-10-09 18:38:30.742  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 2.999853181190793
              2026-10-09 18:38:30.743  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: Birne: true
              2026-10-09 18:39:00.295  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false
              2026-10-09 18:39:01.438  - info: admin.0 (11426) ==> Connected system.user.admin from ::ffff:192.168.178.116
              2026-10-09 18:39:09.892  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true
              2026-10-09 18:39:09.894  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 2.999853181190793
              2026-10-09 18:39:09.896  - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: Birne: true
              Vielen Dank noch mal!
              Node.js: v24.22.2
              NPM: 11.19.1
              js-controller 7.2.5
              Linux: Trixie
              • DuffyD Duffy
                @Thomas-Braun
                Hier die iob diag:
                Script v.2026-08-30
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Unknown
                Kernel          : aarch64
                Userland        : 64bit
                CPU threads     : 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Session:                tty
                *** MEMORY ***
                Swap:           209M        124M         85M
                         7818 M total memory
                         4754 M used memory
                          320 M free memory
                           29 M buffer memory
                         2820 M swap cache
                          199 M total swap
                          118 M used swap
                           81 M free swap
                *** FILESYSTEM ***
                /var:
                4.3G    /var/
                1.6G    /var/lib
                1.5G    /var/log
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          8.0.14
                javascript:     10.1.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        14544
                States:         13303
                Thomas BraunT
                Thomas BraunT
                @Duffy sagte:
                Inwiefern?
                • DuffyD
                  DuffyD
                  Duffy
                  Das er sobald ich auf Adapter und zb updates suchen gehe die Meldung bringt die Zeit zu verlängern manchmal kommt auch unten links ne rote Meldung deren inhalt ich gerade nicht wiedergeben kann.
                  Node.js: v24.22.2
                  NPM: 11.19.1
                  js-controller 7.2.5
                  Linux: Trixie
                  OliverIOO Thomas BraunT 2 Antworten Letzte Antwort
                  • DuffyD Duffy
                    OliverIOO
                    OliverIOO
                    OliverIO
                    @Duffy
                    das sind die timeout fehler.
                    sobald du den js-controller und im anschluss den admin aktualisierst hat,
                    wird sich das verbessern
                    wenn die timeout fehler in 8.0.14 kommen,
                    dann nach dem laden einml F5 drücken, dann lädt er auch in dieser version normal.
                    nach einer stunde (oder war es 1 tag) läuft aber der cache ab, dann muss er alles erneut laden.
                    Links im Profil
                    • DuffyD Duffy
                      Thomas BraunT
                      Thomas BraunT
                      @Duffy sagte:
                      Diese Dinge sind in den Beta-Versionen angegangen worden. Warte halt noch ein paar Tage, bis die getestet werden konnten und dann im Stable für alle aufschlagen.
                      • DuffyD
                        DuffyD
                        Duffy
                        Da hast du wohl recht, allein ich hatte die Hoffnung, aber ja, ändert sich nichts an der Tatsache.
                        Node.js: v24.22.2
                        NPM: 11.19.1
                        js-controller 7.2.5
                        Linux: Trixie
                        84.2k
