Komme nach Admin 8.1.1 Update nicht mehr auf den iob [gel.]
2026-10-09 17:43:17.359 - error: host.raspberrypi startInstance system.adapter.admin.0 Adapter dependency not fulfilled on "raspberrypi": Invalid version of "js-controller". Installed "7.2.2", required ">=7.2.5"Das ist der Grund. Entweder wieder in der Version zurück, oder js-controller auch noch updaten.
da kommt dann:
pi@raspberrypi:~ $ iob repo unset beta Repository "beta" deactivated. ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none pi@raspberrypi:~ $ iob repo set stable Repository "stable" set as active. ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none pi@raspberrypi:~ $ iob update Used repository: stable Adapter "admin" : 8.0.14 , installed 8.1.1 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "drag-indicator": 2.6.1 , installed 2.6.1 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "feiertage" : 1.4.0 , installed 1.4.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.4 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hoymiles" : 0.4.1 , installed 0.4.1 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "midea" : 0.0.7 , installed 1.8.6 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "net-tools" : 1.2.3 , installed 1.2.3 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "operating-hours": 1.5.1 , installed 1.5.1 Adapter "rpi2" : 3.0.2 , installed 3.0.2 Adapter "sainlogic" : 1.2.10 , installed 1.2.8 [Updatable] Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-inventwo": 1.10.0, installed 1.10.0 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-colorpicker": 2.1.0 , installed 2.1.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.13 , installed 2.5.13 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 pi@raspberrypi:~ $ iob update admin@8.1.1 Used repository: admin@8.1.1 Error: unknown repository is active - "admin@8.1.1". Known: stable, beta pi@raspberrypi:~ $Soll ich vielleicht einfach, wie auch immer versuchen, wieder auf Admin 8.0.14 zu kommen und die Finger weg zu lassen bis ein Nachfolger kommt?
das ist ja eine riesen Liste.
ich schicke mal das ab 17:42
2026-10-09 17:46:39.090 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 17:46:39.091 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24 2026-10-09 17:47:29.844 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 17:47:39.593 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 17:47:39.593 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24 2026-10-09 17:48:47.848 - ESC[32minfoESC[39m: fritzdect.0 (3154) DECT ID: 130770157104-1 identified for command (state) : false 2026-10-09 17:48:57.780 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 17:49:05.979 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 17:49:05.980 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24 2026-10-09 17:49:48.230 - ESC[33mwarnESC[39m: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo failed: No response. Device is Offline or not reachable. 2026-10-09 17:50:29.585 - ESC[32minfoESC[39m: sonoff.0 (2974) Client [93] connection closed: closed 2026-10-09 17:50:48.230 - ESC[33mwarnESC[39m: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo failed: No response. Device is Offline or not reachable. 2026-10-09 17:51:12.183 - ESC[32minfoESC[39m: sonoff.0 (2974) Client [135] reconnected. Old secret 1791550789559_5409 ==> New secret 1791561072181_459 2026-10-09 17:51:18.001 - ESC[33mwarnESC[39m: sonoff.0 (2974) Old client 135 with secret 1791550789559_5409 sends pingreq. Ignore! Actual secret is 1791561072181_459 2026-10-09 17:51:27.133 - ESC[32minfoESC[39m: opendtu.0 (2957) Connect to OpenDTU over websocket connection. 2026-10-09 17:51:48.232 - ESC[33mwarnESC[39m: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo failed: No response. Device is Offline or not reachable. 2026-10-09 17:52:27.163 - ESC[32minfoESC[39m: opendtu.0 (2957) Connect to OpenDTU over websocket connection. 2026-10-09 17:52:39.747 - ESC[32minfoESC[39m: sonoff.0 (2974) Client [Waschmaschine] reconnected. Old secret 1791559898492_9401 ==> New secret 1791561159733_3498 2026-10-09 17:52:48.234 - ESC[33mwarnESC[39m: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo failed: No response. Device is Offline or not reachable. 2026-10-09 17:52:50.209 - ESC[32minfoESC[39m: sonoff.0 (2974) Client [93] connected with secret 1791561170209_4263 2026-10-09 17:53:42.844 - ESC[32minfoESC[39m: sonoff.0 (2974) Client [Kaffeemaschine] reconnected. Old secret 1791559901612_949 ==> New secret 1791561222843_6279 2026-10-09 17:53:43.951 - ESC[32minfoESC[39m: sonoff.0 (2974) Client [Bambu] reconnected. Old secret 1791559898437_8132 ==> New secret 1791561223950_5103 2026-10-09 17:53:49.351 - ESC[32minfoESC[39m: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.157 vis.0 2026-10-09 17:54:26.128 - ESC[32minfoESC[39m: device-watcher.0 (3113) [main] Pending rescan detected – Schleife wird wiederholt 2026-10-09 17:54:36.937 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 17:55:00.754 - ESC[32minfoESC[39m: fritzdect.0 (3154) DECT ID: 130770157104-1 identified for command (state) : true 2026-10-09 17:59:31.126 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 17:59:31.127 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 16.998085132034966 2026-10-09 17:59:41.920 - ESC[32minfoESC[39m: web.0 (3373) ==> Connected system.user.admin from ::ffff:192.168.178.157 2026-10-09 18:00:00.062 - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.ical.0 in version "1.21.0" started with pid 10531 2026-10-09 18:00:05.922 - ESC[32minfoESC[39m: ical.0 (10531) starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ical, node: v24.21.0, js-controller: 7.2.2 2026-10-09 18:00:06.882 - ESC[32minfoESC[39m: ical.0 (10531) processing URL: Müllkalender 2026 https://www.bodenseekreis.de/umwelt-landnutzung/abfallentsorgung-privat/termine/abfuhrkalender/export/?tx_bodenseeawacalendar_export%5Baction%5D=export&tx_bodenseeawacalendar_export%5Bcity%5D=29&tx_bodenseeawacalendar_export%5Bcontroller%5D=Date&tx_bodenseeawacalendar_export%5Bdistrict%5D=2&tx_bodenseeawacalendar_export%5Bformat%5D=ics&tx_bodenseeawacalendar_export%5Bwastetypes%5D=1%2C4%2C5%2C16%2C10&tx_bodenseeawacalendar_export%5Byear%5D=12&cHash=9410b95f31ec5d824a1305660dfa76cc 2026-10-09 18:00:10.088 - ESC[32minfoESC[39m: ical.0 (10531) processing URL: Kalender Maja http://p112-caldav.icloud.com/published/2/MTc0OTA0NjQ5MzIxNzQ5MC3o5FbqrGsIxq-UvmKpnEAXzEwGEW27fhZhYk-3piM-c6raW10BddpftpFtsrP_I_8uKDw2bQjt8LKiLxhtFCE 2026-10-09 18:00:14.468 - ESC[32minfoESC[39m: ical.0 (10531) processing URL: Kalender Udo http://p40-caldav.icloud.com/published/2/MTE2MjQ1OTg0NzUxMTYyNMwnTSBDOs3OP41iUXZ1Lhq0aKYRTk6VX6xh5iD7iXpz8bRf2RoLVH5uG86xRYpf-ReclET4nAD1FM8nWRDbmUA 2026-10-09 18:00:21.013 - ESC[32minfoESC[39m: ical.0 (10531) Terminated (NO_ERROR): Without reason 2026-10-09 18:00:21.576 - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.ical.0 having pid 10531 terminated with code 0 (NO_ERROR) 2026-10-09 18:00:42.204 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 18:01:01.263 - ESC[32minfoESC[39m: mystrom.0 (3209) Set update interval for 34987A62B244 to 60 2026-10-09 18:01:01.334 - ESC[32minfoESC[39m: mystrom.0 (3209) Set update interval for C8F09EBDB064 to 60 2026-10-09 18:01:01.406 - ESC[32minfoESC[39m: mystrom.0 (3209) Set update interval for 083AF2735EC4 to 60 2026-10-09 18:01:14.277 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 18:01:14.277 - ESC[32minfoESC[39m: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 16.998085132034966 2026-10-09 18:04:02.568 - ESC[32minfoESC[39m: web.0 (3373) ==> Connected system.user.admin from ::ffff:192.168.178.188 2026-10-09 18:04:08.591 - ESC[32minfoESC[39m: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.188 vis.0 2026-10-09 18:05:57.538 - ESC[32minfoESC[39m: opendtu.0 (2957) Connect to OpenDTU over websocket connection. 2026-10-09 18:06:13.368 - ESC[32minfoESC[39m: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.157 vis.0 (END) -
Ich habe die Befehle von Thomas Braun ausgeführt. Noch komme ich nicht auf den iob. Jetzt kommen im Log aber Errors.
Für die komplette Übersicht schicke ich jetzt aber nicht nur das Log File sondern noch mal die komplette iob diag.Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.18.50+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 1095 days ago (on 2023-10-10). Systemuptime and Load: 17:44:35 up 2:51, 1 user, load average: 1.16, 1.20, 0.98 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Fri 2026-10-09 17:44:35 CEST Universal time: Fri 2026-10-09 15:44:35 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 8.2G 4.5G 1.1G 18M 2.8G 3.7G Swap: 209M 26M 183M Total: 8.4G 4.5G 1.3G Active iob-Instances: 31 7818 M total memory 4274 M used memory 1017 M active memory 5347 M inactive memory 1038 M free memory 114 M buffer memory 2507 M swap cache 199 M total swap 25 M used swap 174 M free swap *** top - Table Of Processes *** top - 17:44:36 up 2:51, 1 user, load average: 1.16, 1.20, 0.98 Tasks: 219 total, 1 running, 218 sleeping, 0 stopped, 0 zombie %Cpu(s): 9.1 us, 4.5 sy, 0.0 ni, 86.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7818.7 total, 1037.6 free, 4274.8 used, 2623.1 buff/cache MiB Swap: 200.0 total, 174.8 free, 25.2 used. 3543.9 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 1.6G 11M 1.6G 1% /run /dev/sda2 ext4 29G 17G 12G 59% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 3.9G 7.3M 3.9G 1% /tmp tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service /dev/sda1 vfat 510M 76M 435M 15% /boot/firmware tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 782M 8.0K 782M 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Fri Oct 9 14:53:04 2026] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none. [Fri Oct 9 14:53:07 2026] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 4.3G /var/ 1.6G /var/lib 1.5G /var/log/journal/458ebafb08a8432dbfe417c962c32f87 1.5G /var/log/journal 1.5G /var/log Archived and active journals take up 1.4G in the file system. /opt/iobroker/backups: 1.1G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 637M /opt/iobroker/iobroker-data/ 369M /opt/iobroker/iobroker-data/files 169M /opt/iobroker/iobroker-data/backup-objects 91M /opt/iobroker/iobroker-data/files/vis 85M /opt/iobroker/iobroker-data/files/vis/widgets The five largest files in iobroker-data are: 36M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 16M /opt/iobroker/iobroker-data/states.jsonl 16M /opt/iobroker/iobroker-data/files/matter.admin/assets/index-EdnNzxJx.js 9.8M /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...ngle_Plus_0001-if00-port0 ...ngle_Plus_0001-if00-port0 ✓ Matching *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: raspberrypi raspberrypi (version: 7.2.2, hostname: raspberrypi , alive, uptime: 9981) Core adapters versions js-controller: 7.2.2 admin: 8.1.1 javascript: 10.1.3 nodejs modules from github: 2 +-- iobroker.fritzdect@2.6.4 (git+ssh://git@github.com/foxthefox/ioBroker.fritzdect.git#34f52e97e85bf384e919a144d9ccd6335e5aa8e9) +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a) Adapter State system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled system.adapter.device-reminder.0 : device-reminder : raspberrypi - disabled + system.adapter.device-watcher.0 : device-watcher : raspberrypi - enabled system.adapter.devices.0 : devices : raspberrypi - enabled system.adapter.discovery.0 : discovery : raspberrypi - disabled + system.adapter.drag-indicator.0 : drag-indicator : raspberrypi - enabled + system.adapter.echarts.0 : echarts : raspberrypi - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi - enabled system.adapter.energiefluss.0 : energiefluss : raspberrypi - disabled system.adapter.feiertage.0 : feiertage : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - enabled + system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled + system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - enabled + system.adapter.history.0 : history : raspberrypi - enabled system.adapter.hoymiles.0 : hoymiles : raspberrypi - disabled system.adapter.ical.0 : ical : raspberrypi - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - enabled + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.matter.0 : matter : raspberrypi - enabled system.adapter.mercedesme.0 : mercedesme : raspberrypi - disabled system.adapter.midea.0 : midea : raspberrypi - disabled system.adapter.mqtt.0 : mqtt : raspberrypi - disabled, port: 1884, bind: 0.0.0.0 + system.adapter.mystrom.0 : mystrom : raspberrypi - enabled system.adapter.net-tools.0 : net-tools : raspberrypi - disabled + system.adapter.opendtu.0 : opendtu : raspberrypi - enabled + system.adapter.operating-hours.0 : operating-hours : raspberrypi - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled system.adapter.sainlogic.0 : sainlogic : raspberrypi - disabled, port: 1847, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled + system.adapter.statistics.0 : statistics : raspberrypi - enabled system.adapter.switchbot-hub.0 : switchbot-hub : raspberrypi - disabled + system.adapter.tankerkoenig.0 : tankerkoenig : raspberrypi - enabled + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : raspberrypi - enabled + system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi - enabled system.adapter.vis-2.0 : vis-2 : raspberrypi - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspberrypi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - enabled system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-metro.0 : vis-metro : raspberrypi - enabled system.adapter.vis-rgraph.0 : vis-rgraph : raspberrypi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled system.adapter.vis-weather.0 : vis-weather : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.1.1' │ 'none' │ │ 1 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 2 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 3 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 4 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 5 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 6 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 7 │ 'system.adapter.drag-indicator' │ 'drag-indicator' │ '2.6.1' │ 'none' │ │ 8 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 9 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 10 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 11 │ 'system.adapter.feiertage' │ 'feiertage' │ '1.4.0' │ 'none' │ │ 12 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 13 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.4' │ 'none' │ │ 14 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 15 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 16 │ 'system.adapter.hoymiles' │ 'hoymiles' │ '0.4.1' │ 'none' │ │ 17 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 18 │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0' │ 'none' │ │ 19 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 20 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 21 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 22 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 23 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 24 │ 'system.adapter.mercedesme' │ 'mercedesme' │ '0.7.2' │ 'none' │ │ 25 │ 'system.adapter.midea' │ 'midea' │ '1.8.6' │ 'none' │ │ 26 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 27 │ 'system.adapter.mystrom' │ 'mystrom' │ '0.1.0' │ 'none' │ │ 28 │ 'system.adapter.net-tools' │ 'net-tools' │ '1.2.3' │ 'none' │ │ 29 │ 'system.adapter.opendtu' │ 'opendtu' │ '3.1.0' │ 'none' │ │ 30 │ 'system.adapter.operating-hours' │ 'operating-hours' │ '1.5.1' │ 'none' │ │ 31 │ 'system.adapter.rpi2' │ 'rpi2' │ '3.0.2' │ 'none' │ │ 32 │ 'system.adapter.sainlogic' │ 'sainlogic' │ '1.2.8' │ 'none' │ │ 33 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 34 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 35 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 36 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 37 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 38 │ 'system.adapter.switchbot-hub' │ 'switchbot-hub' │ '0.1.2' │ 'none' │ │ 39 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 40 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 41 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 42 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 43 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 44 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 45 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 46 │ 'system.adapter.vis-2-widgets-inventwo' │ 'vis-2-widgets-inventwo' │ '1.10.0' │ 'none' │ │ 47 │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1' │ 'none' │ │ 48 │ 'system.adapter.vis-colorpicker' │ 'vis-colorpicker' │ '2.1.0' │ 'none' │ │ 49 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 50 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 51 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 52 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 53 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 54 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 55 │ 'system.adapter.vis-weather' │ 'vis-weather' │ '2.5.13' │ 'none' │ │ 56 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 57 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 58 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.0.14 , installed 8.1.1 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "drag-indicator": 2.6.1 , installed 2.6.1 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "feiertage" : 1.4.0 , installed 1.4.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.4 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hoymiles" : 0.4.1 , installed 0.4.1 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "midea" : 0.0.7 , installed 1.8.6 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "net-tools" : 1.2.3 , installed 1.2.3 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "operating-hours": 1.5.1 , installed 1.5.1 Adapter "rpi2" : 3.0.2 , installed 3.0.2 Adapter "sainlogic" : 1.2.10 , installed 1.2.8 [Updatable] Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-inventwo": 1.10.0, installed 1.10.0 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-colorpicker": 2.1.0 , installed 2.1.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.13 , installed 2.5.13 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 14538 States: 13288 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian-security trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 http://archive.raspberrypi.com/debian trixie InRelease Hit:5 https://apt.grafana.com stable InRelease Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B] Fetched 6922 B in 0s (21.1 kB/s) Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 0.0.0.0:35805 0.0.0.0:* users:(("avahi-daemon",pid=560,fd=14)) udp UNCONN 0 0 0.0.0.0:48695 0.0.0.0:* users:(("io.matter.0",pid=3414,fd=38)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=3414,fd=40)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=3414,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("avahi-daemon",pid=560,fd=12)) udp UNCONN 0 0 *:48695 *:* users:(("io.matter.0",pid=3414,fd=37)) udp UNCONN 0 0 [fe80::e5bd:4ca9:1707:b25b]:dhcpv6-client *:* users:(("NetworkManager",pid=666,fd=28)) udp UNCONN 0 0 *:53826 *:* users:(("avahi-daemon",pid=560,fd=15)) udp UNCONN 0 0 *:mdns *:* users:(("io.matter.0",pid=3414,fd=41)) udp UNCONN 0 0 *:mdns *:* users:(("io.matter.0",pid=3414,fd=36)) udp UNCONN 0 0 *:mdns *:* users:(("avahi-daemon",pid=560,fd=13)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=793,fd=6)) tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:* users:(("iobroker.js-con",pid=2815,fd=23)) tcp LISTEN 0 511 0.0.0.0:1883 0.0.0.0:* users:(("io.sonoff.0",pid=2974,fd=40)) tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:* users:(("iobroker.js-con",pid=2815,fd=29)) tcp LISTEN 0 20 127.0.0.1:smtp 0.0.0.0:* users:(("exim4",pid=1088,fd=5)) tcp LISTEN 0 4096 *:3000 *:* users:(("grafana",pid=1140,fd=82)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=806,fd=2353)) tcp LISTEN 0 511 *:8087 *:* users:(("io.simple-api.0",pid=3374,fd=35)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=3373,fd=35)) tcp LISTEN 0 511 *:48695 *:* users:(("io.matter.0",pid=3414,fd=39)) tcp LISTEN 0 20 [::1]:smtp [::]:* users:(("exim4",pid=1088,fd=6)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=793,fd=7)) *** Log File - Last 25 Lines *** 2026-10-09 17:31:01.479 - info: mystrom.0 (3209) Set update interval for 083AF2735EC4 to 60 2026-10-09 17:31:38.439 - info: sonoff.0 (2974) Client [Bambu] reconnected. Old secret 1791550789987_9437 ==> New secret 1791559898437_8132 2026-10-09 17:31:38.493 - info: sonoff.0 (2974) Client [Waschmaschine] reconnected. Old secret 1791550790452_8393 ==> New secret 1791559898492_9401 2026-10-09 17:31:41.612 - info: sonoff.0 (2974) Client [Kaffeemaschine] reconnected. Old secret 1791550790426_4816 ==> New secret 1791559901612_949 2026-10-09 17:31:45.673 - info: opendtu.0 (2957) Connect to OpenDTU over websocket connection. 2026-10-09 17:31:48.185 - info: sonoff.0 (2974) Client [93] reconnected. Old secret 1791550789780_5634 ==> New secret 1791559908185_5077 2026-10-09 17:32:56.996 - info: fritzdect.0 (3154) DECT ID: 130770157104-1 identified for command (state) : false 2026-10-09 17:35:22.972 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 17:35:27.784 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 17:35:27.785 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24 2026-10-09 17:36:08.764 - info: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.156 vis.0 2026-10-09 17:36:23.992 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 17:36:26.782 - info: opendtu.0 (2957) Connect to OpenDTU over websocket connection. 2026-10-09 17:36:48.231 - warn: fullybrowser.0 (3093) [REST] Fire_Küche IP 192.168.178.156: Sending command get axiosGetDevicesInfo failed: No response. Device is Offline or not reachable. 2026-10-09 17:37:13.169 - info: web.0 (3373) ==> Connected system.user.admin from ::ffff:192.168.178.156 2026-10-09 17:39:52.628 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 17:39:52.629 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24 2026-10-09 17:42:04.682 - info: host.raspberrypi "system.adapter.admin.0" disabled 2026-10-09 17:42:53.534 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 17:42:57.413 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 17:42:57.413 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 24 2026-10-09 17:43:17.285 - info: host.raspberrypi "system.adapter.admin.0" enabled 2026-10-09 17:43:17.359 - error: host.raspberrypi startInstance system.adapter.admin.0 Adapter dependency not fulfilled on "raspberrypi": Invalid version of "js-controller". Installed "7.2.2", required ">=7.2.5" 2026-10-09 17:43:28.366 - error: host.raspberrypi startInstance system.adapter.admin.0 Adapter dependency not fulfilled on "raspberrypi": Invalid version of "js-controller". Installed "7.2.2", required ">=7.2.5" 2026-10-09 17:43:44.766 - info: web.0 (3373) <== Disconnect system.user.admin from ::ffff:192.168.178.156 vis.0 -
Dann würde ich künftig die Finger von solchen 'Kunststücken' im Expertenmodus lassen...
Einiob diagschaut nun wie aus?
Ich muss dir ja zustimmen und mache das normalerweise auch nicht ihr warnt ja immer davor aber mein kleiner Pi hängt da glaub bös in den Seilen mit dem Admin 8.0.14.
Hier die iob diag:
Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.18.50+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 1095 days ago (on 2023-10-10). Systemuptime and Load: 18:37:42 up 3:44, 1 user, load average: 1.07, 0.97, 1.03 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Fri 2026-10-09 18:37:43 CEST Universal time: Fri 2026-10-09 16:37:43 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 8.2G 5.0G 336M 14M 3.0G 3.2G Swap: 209M 124M 85M Total: 8.4G 5.1G 421M Active iob-Instances: 32 7818 M total memory 4754 M used memory 3884 M active memory 3243 M inactive memory 320 M free memory 29 M buffer memory 2820 M swap cache 199 M total swap 118 M used swap 81 M free swap *** top - Table Of Processes *** top - 18:37:43 up 3:44, 1 user, load average: 1.06, 0.97, 1.03 Tasks: 222 total, 1 running, 221 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.3 us, 0.0 sy, 0.0 ni, 97.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7818.7 total, 318.7 free, 4755.9 used, 2849.8 buff/cache MiB Swap: 200.0 total, 81.6 free, 118.4 used. 3062.8 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 1.6G 11M 1.6G 1% /run /dev/sda2 ext4 29G 17G 12G 59% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 3.9G 7.3M 3.9G 1% /tmp tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service /dev/sda1 vfat 510M 76M 435M 15% /boot/firmware tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 782M 8.0K 782M 1% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Fri Oct 9 14:53:04 2026] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none. [Fri Oct 9 14:53:07 2026] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 4.3G /var/ 1.6G /var/lib 1.5G /var/log/journal/458ebafb08a8432dbfe417c962c32f87 1.5G /var/log/journal 1.5G /var/log Archived and active journals take up 1.4G in the file system. /opt/iobroker/backups: 1.1G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 638M /opt/iobroker/iobroker-data/ 369M /opt/iobroker/iobroker-data/files 169M /opt/iobroker/iobroker-data/backup-objects 91M /opt/iobroker/iobroker-data/files/vis 85M /opt/iobroker/iobroker-data/files/vis/widgets The five largest files in iobroker-data are: 36M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 17M /opt/iobroker/iobroker-data/states.jsonl 16M /opt/iobroker/iobroker-data/files/matter.admin/assets/index-EdnNzxJx.js 9.8M /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...ngle_Plus_0001-if00-port0 ...ngle_Plus_0001-if00-port0 ✓ Matching *** NodeJS-Installation *** /usr/bin/nodejs v24.21.0 /usr/bin/node v24.21.0 /usr/bin/npm 11.19.0 /usr/bin/npx 11.19.0 ✓ Node.js installation is correct nodejs: Installed: 24.21.0-1nodesource1 Candidate: 24.21.0-1nodesource1 Version table: *** 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: raspberrypi raspberrypi (version: 7.2.2, hostname: raspberrypi , alive, uptime: 13162) Core adapters versions js-controller: 7.2.2 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 2 +-- iobroker.fritzdect@2.6.4 (git+ssh://git@github.com/foxthefox/ioBroker.fritzdect.git#34f52e97e85bf384e919a144d9ccd6335e5aa8e9) +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a) Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled system.adapter.device-reminder.0 : device-reminder : raspberrypi - disabled + system.adapter.device-watcher.0 : device-watcher : raspberrypi - enabled system.adapter.devices.0 : devices : raspberrypi - enabled system.adapter.discovery.0 : discovery : raspberrypi - disabled + system.adapter.drag-indicator.0 : drag-indicator : raspberrypi - enabled + system.adapter.echarts.0 : echarts : raspberrypi - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi - enabled system.adapter.energiefluss.0 : energiefluss : raspberrypi - disabled system.adapter.feiertage.0 : feiertage : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - enabled + system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled + system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - enabled + system.adapter.history.0 : history : raspberrypi - enabled system.adapter.hoymiles.0 : hoymiles : raspberrypi - disabled system.adapter.ical.0 : ical : raspberrypi - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - enabled + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.matter.0 : matter : raspberrypi - enabled system.adapter.mercedesme.0 : mercedesme : raspberrypi - disabled system.adapter.midea.0 : midea : raspberrypi - disabled system.adapter.mqtt.0 : mqtt : raspberrypi - disabled, port: 1884, bind: 0.0.0.0 + system.adapter.mystrom.0 : mystrom : raspberrypi - enabled system.adapter.net-tools.0 : net-tools : raspberrypi - disabled + system.adapter.opendtu.0 : opendtu : raspberrypi - enabled + system.adapter.operating-hours.0 : operating-hours : raspberrypi - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled system.adapter.sainlogic.0 : sainlogic : raspberrypi - disabled, port: 1847, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled + system.adapter.statistics.0 : statistics : raspberrypi - enabled system.adapter.switchbot-hub.0 : switchbot-hub : raspberrypi - disabled + system.adapter.tankerkoenig.0 : tankerkoenig : raspberrypi - enabled + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : raspberrypi - enabled + system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi - enabled system.adapter.vis-2.0 : vis-2 : raspberrypi - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspberrypi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - enabled system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-metro.0 : vis-metro : raspberrypi - enabled system.adapter.vis-rgraph.0 : vis-rgraph : raspberrypi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled system.adapter.vis-weather.0 : vis-weather : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬───────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼───────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 1 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 2 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 3 │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2' │ 'none' │ │ 4 │ 'system.adapter.device-watcher' │ 'device-watcher' │ '2.15.17' │ 'none' │ │ 5 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 6 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 7 │ 'system.adapter.drag-indicator' │ 'drag-indicator' │ '2.6.1' │ 'none' │ │ 8 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 9 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 10 │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.1' │ 'none' │ │ 11 │ 'system.adapter.feiertage' │ 'feiertage' │ '1.4.0' │ 'none' │ │ 12 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 13 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.4' │ 'none' │ │ 14 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 15 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 16 │ 'system.adapter.hoymiles' │ 'hoymiles' │ '0.4.1' │ 'none' │ │ 17 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 18 │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0' │ 'none' │ │ 19 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 20 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 21 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 22 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 23 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 24 │ 'system.adapter.mercedesme' │ 'mercedesme' │ '0.7.2' │ 'none' │ │ 25 │ 'system.adapter.midea' │ 'midea' │ '1.8.6' │ 'none' │ │ 26 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 27 │ 'system.adapter.mystrom' │ 'mystrom' │ '0.1.0' │ 'none' │ │ 28 │ 'system.adapter.net-tools' │ 'net-tools' │ '1.2.3' │ 'none' │ │ 29 │ 'system.adapter.opendtu' │ 'opendtu' │ '3.1.0' │ 'none' │ │ 30 │ 'system.adapter.operating-hours' │ 'operating-hours' │ '1.5.1' │ 'none' │ │ 31 │ 'system.adapter.rpi2' │ 'rpi2' │ '3.0.2' │ 'none' │ │ 32 │ 'system.adapter.sainlogic' │ 'sainlogic' │ '1.2.8' │ 'none' │ │ 33 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 34 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 35 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 36 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.14' │ 'none' │ │ 37 │ 'system.adapter.statistics' │ 'statistics' │ '5.0.0' │ 'none' │ │ 38 │ 'system.adapter.switchbot-hub' │ 'switchbot-hub' │ '0.1.2' │ 'none' │ │ 39 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 40 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 41 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 42 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 43 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 44 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 45 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 46 │ 'system.adapter.vis-2-widgets-inventwo' │ 'vis-2-widgets-inventwo' │ '1.10.0' │ 'none' │ │ 47 │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.6.1' │ 'none' │ │ 48 │ 'system.adapter.vis-colorpicker' │ 'vis-colorpicker' │ '2.1.0' │ 'none' │ │ 49 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 50 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 51 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 52 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 53 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 54 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 55 │ 'system.adapter.vis-weather' │ 'vis-weather' │ '2.5.13' │ 'none' │ │ 56 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 57 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 58 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴───────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.0.14 , installed 8.0.14 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.17 , installed 2.15.17 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "drag-indicator": 2.6.1 , installed 2.6.1 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "feiertage" : 1.4.0 , installed 1.4.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.4 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hoymiles" : 0.4.1 , installed 0.4.1 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "midea" : 0.0.7 , installed 1.8.6 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "net-tools" : 1.2.3 , installed 1.2.3 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "operating-hours": 1.5.1 , installed 1.5.1 Adapter "rpi2" : 3.0.2 , installed 3.0.2 Adapter "sainlogic" : 1.2.10 , installed 1.2.8 [Updatable] Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "statistics" : 5.0.0 , installed 5.0.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-inventwo": 1.10.0, installed 1.10.0 Adapter "vis-2-widgets-material": 1.6.1, installed 1.6.1 Adapter "vis-colorpicker": 2.1.0 , installed 2.1.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-icontwo" : 2.11.6 , installed 2.11.6 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.13 , installed 2.5.13 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 14544 States: 13303 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian-security trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 http://archive.raspberrypi.com/debian trixie InRelease Hit:5 https://apt.grafana.com stable InRelease Get:6 https://repos.influxdata.com/debian stable InRelease [6922 B] Hit:7 https://deb.nodesource.com/node_24.x nodistro InRelease Fetched 6922 B in 0s (17.5 kB/s) Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 0.0.0.0:35805 0.0.0.0:* users:(("avahi-daemon",pid=560,fd=14)) udp UNCONN 0 0 0.0.0.0:48695 0.0.0.0:* users:(("io.matter.0",pid=3414,fd=38)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=3414,fd=40)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=3414,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("avahi-daemon",pid=560,fd=12)) udp UNCONN 0 0 *:48695 *:* users:(("io.matter.0",pid=3414,fd=37)) udp UNCONN 0 0 [fe80::e5bd:4ca9:1707:b25b]:dhcpv6-client *:* users:(("NetworkManager",pid=666,fd=28)) udp UNCONN 0 0 *:53826 *:* users:(("avahi-daemon",pid=560,fd=15)) udp UNCONN 0 0 *:mdns *:* users:(("io.matter.0",pid=3414,fd=41)) udp UNCONN 0 0 *:mdns *:* users:(("io.matter.0",pid=3414,fd=36)) udp UNCONN 0 0 *:mdns *:* users:(("avahi-daemon",pid=560,fd=13)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=793,fd=6)) tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:* users:(("iobroker.js-con",pid=2815,fd=23)) tcp LISTEN 0 511 0.0.0.0:1883 0.0.0.0:* users:(("io.sonoff.0",pid=2974,fd=40)) tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:* users:(("iobroker.js-con",pid=2815,fd=29)) tcp LISTEN 0 20 127.0.0.1:smtp 0.0.0.0:* users:(("exim4",pid=1088,fd=5)) tcp LISTEN 0 4096 *:3000 *:* users:(("grafana",pid=1140,fd=82)) tcp LISTEN 0 4096 *:8086 *:* users:(("influxd",pid=806,fd=2353)) tcp LISTEN 0 511 *:8087 *:* users:(("io.simple-api.0",pid=3374,fd=35)) tcp LISTEN 0 511 *:tproxy *:* users:(("io.admin.0",pid=11426,fd=37)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=3373,fd=35)) tcp LISTEN 0 511 *:48695 *:* users:(("io.matter.0",pid=3414,fd=39)) tcp LISTEN 0 20 [::1]:smtp [::]:* users:(("exim4",pid=1088,fd=6)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=793,fd=7)) *** Log File - Last 25 Lines *** 2026-10-09 18:30:06.912 - info: ical.0 (12253) processing URL: Müllkalender 2026 https://www.bodenseekreis.de/umwelt-landnutzung/abfallentsorgung-privat/termine/abfuhrkalender/export/?tx_bodenseeawacalendar_export%5Baction%5D=export&tx_bodenseeawacalendar_export%5Bcity%5D=29&tx_bodenseeawacalendar_export%5Bcontroller%5D=Date&tx_bodenseeawacalendar_export%5Bdistrict%5D=2&tx_bodenseeawacalendar_export%5Bformat%5D=ics&tx_bodenseeawacalendar_export%5Bwastetypes%5D=1%2C4%2C5%2C16%2C10&tx_bodenseeawacalendar_export%5Byear%5D=12&cHash=9410b95f31ec5d824a1305660dfa76cc 2026-10-09 18:30:10.166 - info: ical.0 (12253) processing URL: Kalender Maja http://p112-caldav.icloud.com/published/2/MTc0OTA0NjQ5MzIxNzQ5MC3o5FbqrGsIxq-UvmKpnEAXzEwGEW27fhZhYk-3piM-c6raW10BddpftpFtsrP_I_8uKDw2bQjt8LKiLxhtFCE 2026-10-09 18:30:14.438 - info: ical.0 (12253) processing URL: Kalender Udo http://p40-caldav.icloud.com/published/2/MTE2MjQ1OTg0NzUxMTYyNMwnTSBDOs3OP41iUXZ1Lhq0aKYRTk6VX6xh5iD7iXpz8bRf2RoLVH5uG86xRYpf-ReclET4nAD1FM8nWRDbmUA 2026-10-09 18:30:21.073 - info: ical.0 (12253) Terminated (NO_ERROR): Without reason 2026-10-09 18:30:21.652 - info: host.raspberrypi instance system.adapter.ical.0 having pid 12253 terminated with code 0 (NO_ERROR) 2026-10-09 18:30:21.669 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 18:31:01.678 - info: mystrom.0 (3209) Set update interval for 34987A62B244 to 60 2026-10-09 18:31:01.729 - info: mystrom.0 (3209) Set update interval for C8F09EBDB064 to 60 2026-10-09 18:31:01.799 - info: mystrom.0 (3209) Set update interval for 083AF2735EC4 to 60 2026-10-09 18:31:06.893 - warn: zigbee.0 (3007) State value for 00158d00087468b5.y_axis has value "-956" less than min "0". 2026-10-09 18:31:56.769 - warn: zigbee.0 (3007) State value for 00158d00087468b5.z_axis has value "-636" less than min "0". 2026-10-09 18:33:20.852 - info: device-watcher.0 (3113) [main] Pending rescan detected – Schleife wird wiederholt 2026-10-09 18:34:08.855 - info: sonoff.0 (2974) Client [Kaffeemaschine] connection closed: timeout 2026-10-09 18:35:03.309 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 18:35:03.310 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 2.999853181190793 2026-10-09 18:35:03.310 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: Birne: true 2026-10-09 18:38:23.239 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 18:38:30.736 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 18:38:30.742 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 2.999853181190793 2026-10-09 18:38:30.743 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: Birne: true 2026-10-09 18:39:00.295 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: false 2026-10-09 18:39:01.438 - info: admin.0 (11426) ==> Connected system.user.admin from ::ffff:192.168.178.116 2026-10-09 18:39:09.892 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: BWM: true 2026-10-09 18:39:09.894 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: 2.999853181190793 2026-10-09 18:39:09.896 - info: javascript.0 (2894) script.js.Arbeitszimmer.Licht_Arbeitszimmer: Birne: trueVielen Dank noch mal!
Hier die iob diag:
Das er sobald ich auf Adapter und zb updates suchen gehe die Meldung bringt die Zeit zu verlängern manchmal kommt auch unten links ne rote Meldung deren inhalt ich gerade nicht wiedergeben kann.
das sind die timeout fehler.
sobald du den js-controller und im anschluss den admin aktualisierst hat,
wird sich das verbessern
wenn die timeout fehler in 8.0.14 kommen,
dann nach dem laden einml F5 drücken, dann lädt er auch in dieser version normal.
nach einer stunde (oder war es 1 tag) läuft aber der cache ab, dann muss er alles erneut laden. -
Diese Dinge sind in den Beta-Versionen angegangen worden. Warte halt noch ein paar Tage, bis die getestet werden konnten und dann im Stable für alle aufschlagen.
Da hast du wohl recht, allein ich hatte die Hoffnung, aber ja, ändert sich nichts an der Tatsache.
