  3. Off Topic
  4. Pflege des Betriebssystems
  5. Update Konsolen Pflege
    1.6k
    1.5k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Pflege des Betriebssystems
42 Beiträge 4 Kommentatoren 577 Aufrufe 3 Beobachtet
  • J
    J
    jwedenig
    schrieb am zuletzt editiert von jwedenig
    Sorry, ich bin hier glaub ich falsch, oder kann mir wer mit diesen Error Meldungen beim Updaten helfen?
    pi@raspberrypi:~ $ sudo apt-get update
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists... Done
    pi@raspberrypi:~ $ sudo apt full-upgrade
    Calculating upgrade... Done
    The following packages will be upgraded:
      dpkg-dev libdpkg-perl xz-utils
    3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 4,092 kB of archives.
    After this operation, 8,192 B of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Err:1 http://security.debian.org/debian-security bullseye-security/main arm64 xz-utils arm64 5.2.5-2.1~deb11u2
      404  Not Found [IP: 2a04:4e42:41::644 80]
    Get:2 http://security.debian.org/debian-security bullseye-security/main arm64 dpkg-dev all 1.20.14 [2,317 kB]
    Ign:3 http://security.debian.org/debian-security bullseye-security/main arm64 libdpkg-perl all 1.20.14
    Err:3 http://security.debian.org/debian-security bullseye-security/main arm64 libdpkg-perl all 1.20.14
    Fetched 2,317 kB in 1s (4,552 kB/s)
    E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/x/xz-utils/xz-utils_5.2.5-2.1%7edeb11u2_arm64.deb  404  Not Found [IP: 2a04:4e42:41::644 80]
    E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/d/dpkg/libdpkg-perl_1.20.14_all.deb  404  Not Found [IP: 2a04:4e42:41::644 80]
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    pi@raspberrypi:~ $
    • J jwedenig
      pi@raspberrypi:~ $
      Thomas BraunT
      Thomas BraunT
      @jwedenig
      Da ist der Server Momenttan nicht erreichbar. Später nochmal versuchen.
      Dann auch auf Debian 13 'Trixie' gehen, dein Bullseye ist überfällig.
      • J
        J
        jwedenig
        ok, danke, von bullseye auf Trixie -> ein schnelles how to?
        • J jwedenig
          Thomas BraunT
          Thomas BraunT
          @jwedenig
          Ja, gibt es. Von mir geschrieben.
          • J
            J
            jwedenig
            dann such ich mal, oder hast schnell nen link, dankeee
            • J jwedenig
              Thomas BraunT
              Thomas BraunT
              @jwedenig
              Ah, Bullsyeye ist Debian 11. Da gibt es keinen Upgradepfad für.
              Es muss Debian 13 komplett neuinstalliert werden.
              • J
                J
                jwedenig
                sorry, bin hier leider voll unwissend, alles neu und dann wieder iobroker neu und und und?
                • J jwedenig
                  Thomas BraunT
                  Thomas BraunT
                  @jwedenig
                  Ja.
                  ioBroker so weit wie es noch geht updaten (inkl. nodejs auf v22), davon ein Backup ziehen, Debian 13 komplett neuinstallieren, ioBroker installieren, Backup einspielen, fertig.
                  Künftig dann die Kiste nicht mehr absaufen lassen.
                  • J
                    J
                    jwedenig
                    so schauts aus zur Zeit
                    • J jwedenig
                      Thomas BraunT
                      Thomas BraunT
                      @jwedenig
                      Gib mal die vollständige Ausgabe von
                      iob diag
                      zum Besten. Da sieht man mehr.
                      • J
                        J
                        jwedenig
                        *** iob diag is starting up, please wait ***
                        iob diag needs to be updated. Please execute 'iobroker fix' first.
                        • J jwedenig
                          Thomas BraunT
                          Thomas BraunT
                          @jwedenig sagte:
                          Tjoar... Mach das mal. Kann aber sein, dass es nicht mehr funktioniert, weil deine Paketquellen nicht mehr aktuell sind...
                          • J
                            J
                            jwedenig
                            ```bash
                            Script v.2026-08-30
                            *** BASE SYSTEM ***
                            Operating System: Debian GNU/Linux 11 (bullseye)
                               Static hostname: raspberrypi
                                     Icon name: computer
                                        Kernel: Linux 6.1.21-v8+
                                  Architecture: arm64
                            OS is similar to:
                            Model		: Raspberry Pi 4 Model B Rev 1.5
                            Docker          : false
                            Virtualization  : none
                            Unknown
                            Kernel          : aarch64
                            Userland        : 64bit
                            System was installed 1221 days ago (on 2023-05-03).
                            Systemuptime and Load:
                             17:00:15 up 36 min,  1 user,  load average: 1.37, 1.16, 1.19
                            CPU threads     : 4
                            *** LIFE CYCLE STATUS ***
                            Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            ~ Under-voltage has occurred
                            ~ Arm frequency capping has occurred
                            ~ Throttling has occurred
                            ~ Soft temperature limit has occurred
                            *** TIME AND TIMEZONES ***
                                           Local time: Sat 2026-09-05 17:00:15 CEST
                                       Universal time: Sat 2026-09-05 15:00:15 UTC
                                             RTC time: n/a
                                            Time zone: Europe/Vienna (CEST, +0200)
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                            js-controller is not running
                            *** DISPLAY-SERVER SETUP ***
                            Display-Server:		Unknown
                            Display-Manager: 	Not found
                            Desktop:
                            Session:		tty
                            Boot Target: 		multi-user.target
                            *** MEMORY ***
                            Mem:            7.8G        112M        6.5G        1.0M        1.2G        7.6G
                            Swap:            99M          0B         99M
                            Total:          7.9G        112M        6.6G
                            Active iob-Instances: 	1
                                     7811 M total memory
                                      112 M used memory
                                      333 M active memory
                                      687 M inactive memory
                                     6472 M free memory
                                      167 M buffer memory
                                     1059 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 17:00:15 up 36 min,  1 user,  load average: 1.37, 1.16, 1.19
                            Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   7811.3 total,   6471.7 free,    112.1 used,   1227.5 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7576.4 avail Mem
                            *** FAILED SERVICES ***
                              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                            * iobroker.service loaded failed failed ioBroker Server
                            1 loaded units listed.
                            *** DMESG CRITICAL ERRORS ***
                            No critical errors detected
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G   14G   15G  48% /
                            devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                            tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                            /dev/sda1      vfat      255M   33M  223M  13% /boot
                            tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                            Messages concerning filesystems in dmesg (Last 15 lines only):
                            [Sat Sep  5 16:23:50 2026] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sat Sep  5 16:23:50 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [Sat Sep  5 16:23:51 2026] EXT4-fs (sda2): re-mounted. Quota mode: none.
                            Show mounted filesystems:
                            TARGET  SOURCE    FSTYPE OPTIONS
                            /       /dev/sda2 ext4   rw,noatime
                            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            1.7G	/var/
                            1.4G	/var/log
                            1.3G	/var/log/journal/1598db5f087d4d8687cc062072e44690
                            155M	/var/lib
                            Archived and active journals take up 1.2G in the file system.
                            /opt/iobroker/backups:
                            1.3G	/opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            2.8G	/opt/iobroker/iobroker-data/
                            2.3G	/opt/iobroker/iobroker-data/history
                            285M	/opt/iobroker/iobroker-data/files
                            195M	/opt/iobroker/iobroker-data/backup-objects
                            61M	/opt/iobroker/iobroker-data/files/vis
                            32M	/opt/iobroker/iobroker-data/objects.jsonl
                            7.9M	/opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
                            7.2M	/opt/iobroker/iobroker-data/states.jsonl
                            7.1M	/opt/iobroker/iobroker-data/backup-objects/2026-09-05_15-37_objects.jsonl.gz
                            7.0M	/opt/iobroker/iobroker-data/files/vis/widgets/echarts/static/js/vendors-node_modules_mui_icons-material_esm_index_js.bfab266f.chunk.js.map
                            USB-Devices by-id:
                            USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                            please always prefer the links 'by-id':
                            /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                            *** ZigBee Settings ***
                            Zigbee Network Settings on your coordinator / in nvbackup are:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            • J jwedenig
                              ```bash
                              Script v.2026-08-30
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Unknown
                              Kernel          : aarch64
                              Userland        : 64bit
                              CPU threads     : 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              Desktop:
                              Session:		tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       7811 M total memory
                                        112 M used memory
                                        333 M active memory
                                       6472 M free memory
                                        167 M buffer memory
                                       1059 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.7G	/var/
                              1.4G	/var/log
                              155M	/var/lib
                              USB-Devices by-id:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              Thomas BraunT
                              Thomas BraunT
                              @jwedenig
                              True... Musst du JETZT machen. Hätte schon vor geraumer Zeit passieren müssen.
                              Check die Stronversorgung.
                              pi
                              Verwende im neuen System einen anderen username, also weder 'pi' noch 'iobroker'. Haste keinen schönen Vornamen?
                              Die Ausgabe ist aber unvollständig.
                              • J
                                J
                                jwedenig
                                ```bash
                                Script v.2026-08-30
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Unknown
                                Kernel          : aarch64
                                Userland        : 64bit
                                CPU threads     : 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                Desktop:
                                Session:		tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         7811 M total memory
                                          112 M used memory
                                          333 M active memory
                                         6472 M free memory
                                          167 M buffer memory
                                         1059 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                *** FILESYSTEM ***
                                /var:
                                1.7G	/var/
                                1.4G	/var/log
                                155M	/var/lib
                                USB-Devices by-id:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                === ZigBee Port Overview ===
                                Instance        Configured Port                     Available by-id Port                Status
                                zigbee.0        ...ngle_Plus_0001-if00-port0        ...ngle_Plus_0001-if00-port0        ✓ Matching
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs		v22.23.2
                                /usr/bin/node		v22.23.2
                                /usr/bin/npm		10.9.8
                                /usr/bin/npx		10.9.8
                                ✓ Node.js installation is correct
                                nodejs:
                                  Installed: 22.23.2-1nodesource1
                                  Candidate: 22.23.2-1nodesource1
                                  Version table:
                                 *** 22.23.2-1nodesource1 600
                                        500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                     22.23.1-1nodesource1 600
                                     22.23.0-1nodesource1 600
                                     22.22.3-1nodesource1 600
                                     22.22.2-1nodesource1 600
                                     22.22.1-1nodesource1 600
                                     22.22.0-1nodesource1 600
                                     22.21.0-1nodesource1 600
                                     22.20.0-1nodesource1 600
                                     22.19.0-1nodesource1 600
                                     22.18.0-1nodesource1 600
                                     22.17.1-1nodesource1 600
                                     22.17.0-1nodesource1 600
                                     22.16.0-1nodesource1 600
                                     22.15.1-1nodesource1 600
                                     22.15.0-1nodesource1 600
                                     22.14.0-1nodesource1 600
                                     22.13.1-1nodesource1 600
                                     22.13.0-1nodesource1 600
                                     22.12.0-1nodesource1 600
                                     22.11.0-1nodesource1 600
                                     22.10.0-1nodesource1 600
                                     22.9.0-1nodesource1 600
                                     22.8.0-1nodesource1 600
                                     22.7.0-1nodesource1 600
                                     22.6.0-1nodesource1 600
                                     22.5.1-1nodesource1 600
                                     22.5.0-1nodesource1 600
                                     22.4.1-1nodesource1 600
                                     22.4.0-1nodesource1 600
                                     22.3.0-1nodesource1 600
                                     22.2.0-1nodesource1 600
                                     22.1.0-1nodesource1 600
                                     22.0.0-1nodesource1 600
                                     12.22.12~dfsg-1~deb11u8 500
                                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                     12.22.12~dfsg-1~deb11u4 500
                                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                No problems detected
                                Errors in npm tree: 0
                                No known Vulnerabilities detected!
                                *** ioBroker-Installation ***
                                ioBroker Status
                                iobroker is not running on this host.
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                raspberrypi         raspberrypi (version: 7.2.2, hostname: raspberrypi   , alive, uptime: 1990)
                                Core adapters versions
                                js-controller: 	7.2.2
                                admin: 		8.0.11
                                javascript: 	10.1.3
                                nodejs modules from github: 	9
                                +-- iobroker.fusionsolar@1.2.4 (git+ssh://git@github.com/KornSW/ioBroker.fusionsolar.git#50f776fd8f991d0832be3d660de7a38a4763093d)
                                +-- iobroker.huum-sauna@0.5.0 (git+ssh://git@github.com/Chris-656/ioBroker.huum-sauna.git#29839546d990296fa85845e0dca5060f2be698ed)
                                +-- iobroker.onkyo@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.onkyo.git#c2d620441c632840b9125f08ecd7c5ef06482ead)
                                +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#056daf7c0911a454ee3f4a0f7f3b329cf70222c2)
                                +-- iobroker.switchbot-cloud@0.1.0 (git+ssh://git@github.com/kaschtn/ioBroker.switchbot-cloud.git#35cd79211d153fcbfc492f19d4a38e422b575257)
                                +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a)
                                +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                +-- iobroker.vw-connect@0.9.4 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#4321b81482d5d8ce71ce9cf87fe597a069f26852)
                                `-- wake_on_lan@1.0.0 (git+ssh://git@github.com/agnat/node_wake_on_lan.git#dd6404623ccf4bc55b0ba8788ba38312b55435a1)
                                Adapter State
                                  system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                  system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                  system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                                  system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                                  system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                                  system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                  system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                  system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                                  system.adapter.energiefluss.1           : energiefluss          : raspberrypi                              -  enabled
                                  system.adapter.evcc.0                   : evcc                  : raspberrypi                              - disabled, port: 7070
                                  system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              - disabled
                                  system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                                  system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                                  system.adapter.fusionsolar.0            : fusionsolar           : raspberrypi                              -  enabled
                                  system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
                                  system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
                                  system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                  system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                  system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                  system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 0
                                  system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                                  system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 80
                                  system.adapter.huum-sauna.0             : huum-sauna            : raspberrypi                              - disabled
                                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                  system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                  system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                  system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                  system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
                                  system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                                  system.adapter.linktap.0                : linktap               : raspberrypi                              -  enabled
                                  system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                                  system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                  system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
                                  system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              -  enabled
                                  system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
                                  system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                  system.adapter.rest-api.0               : rest-api              : raspberrypi                              -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                                  system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                  system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
                                  system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                  system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                                  system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                                  system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                                  system.adapter.switchbot-cloud.0        : switchbot-cloud       : raspberrypi                              - disabled
                                  system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              -  enabled
                                  system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                  system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.1.41, run as: admin
                                  system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                                  system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                  system.adapter.trashschedule.1          : trashschedule         : raspberrypi                              -  enabled
                                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                  system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                  system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                  system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                  system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                                  system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                + instance is alive
                                ioBroker-Repositories
                                Active repo(s): stable
                                Upgrade policy: none
                                Installed ioBroker-Adapters
                                │ (index) │ id                                  │ name                 │ version          │ upgrade policy │
                                │ 0       │ 'system.adapter.admin'              │ 'admin'              │ '8.0.11'         │ 'none'         │
                                │ 1       │ 'system.adapter.alexa2'             │ 'alexa2'             │ '3.28.3'         │ 'none'         │
                                │ 2       │ 'system.adapter.backitup'           │ 'backitup'           │ '4.0.3'          │ 'none'         │
                                │ 3       │ 'system.adapter.birthdays'          │ 'birthdays'          │ '6.1.0'          │ 'none'         │
                                │ 4       │ 'system.adapter.denon'              │ 'denon'              │ '1.15.12'        │ 'none'         │
                                │ 5       │ 'system.adapter.devices'            │ 'devices'            │ '1.2.14'         │ 'none'         │
                                │ 6       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.0.0'          │ 'none'         │
                                │ 7       │ 'system.adapter.echarts'            │ 'echarts'            │ '3.1.0'          │ 'none'         │
                                │ 8       │ 'system.adapter.energiefluss'       │ 'energiefluss'       │ '3.6.2'          │ 'none'         │
                                │ 9       │ 'system.adapter.evcc'               │ 'evcc'               │ '0.2.4'          │ 'none'         │
                                │ 10      │ 'system.adapter.fahrplan'           │ 'fahrplan'           │ '1.4.1'          │ 'none'         │
                                │ 11      │ 'system.adapter.fb-checkpresence'   │ 'fb-checkpresence'   │ '1.4.2'          │ 'none'         │
                                │ 12      │ 'system.adapter.flot'               │ 'flot'               │ '1.12.0'         │ 'none'         │
                                │ 13      │ 'system.adapter.fullybrowser'       │ 'fullybrowser'       │ '3.1.2'          │ 'none'         │
                                │ 14      │ 'system.adapter.fusionsolar'        │ 'fusionsolar'        │ '1.2.4'          │ 'none'         │
                                │ 15      │ 'system.adapter.go-e'               │ 'go-e'               │ '1.0.41'         │ 'none'         │
                                │ 16      │ 'system.adapter.heos'               │ 'heos'               │ '3.0.4'          │ 'none'         │
                                │ 17      │ 'system.adapter.history'            │ 'history'            │ '4.0.0'          │ 'none'         │
                                │ 18      │ 'system.adapter.hm-rega'            │ 'hm-rega'            │ '5.1.0'          │ 'none'         │
                                │ 19      │ 'system.adapter.hm-rpc'             │ 'hm-rpc'             │ '3.0.1'          │ 'none'         │
                                │ 20      │ 'system.adapter.homeconnect'        │ 'homeconnect'        │ '1.6.1'          │ 'none'         │
                                │ 21      │ 'system.adapter.hue'                │ 'hue'                │ '3.16.2'         │ 'none'         │
                                │ 22      │ 'system.adapter.huum-sauna'         │ 'huum-sauna'         │ '0.5.0'          │ 'none'         │
                                │ 23      │ 'system.adapter.ical'               │ 'ical'               │ '1.21.0'         │ 'none'         │
                                │ 24      │ 'system.adapter.icons-icons8'       │ 'icons-icons8'       │ '0.0.1'          │ 'none'         │
                                │ 25      │ 'system.adapter.icons-mfd-svg'      │ 'icons-mfd-svg'      │ '1.2.0'          │ 'none'         │
                                │ 26      │ 'system.adapter.info'               │ 'info'               │ '2.0.0'          │ 'none'         │
                                │ 27      │ 'system.adapter.iot'                │ 'iot'                │ '6.0.3'          │ 'none'         │
                                │ 28      │ 'system.adapter.javascript'         │ 'javascript'         │ '10.1.3'         │ 'none'         │
                                │ 29      │ 'system.adapter.lgtv'               │ 'lgtv'               │ '2.7.4'          │ 'none'         │
                                │ 30      │ 'system.adapter.linktap'            │ 'linktap'            │ '1.0.3'          │ 'none'         │
                                │ 31      │ 'system.adapter.meross'             │ 'meross'             │ '1.17.0'         │ 'none'         │
                                │ 32      │ 'system.adapter.mqtt'               │ 'mqtt'               │ '6.1.4'          │ 'none'         │
                                │ 33      │ 'system.adapter.octoprint'          │ 'octoprint'          │ '5.1.0'          │ 'none'         │
                                │ 34      │ 'system.adapter.onkyo'              │ 'onkyo'              │ '2.1.2'          │ 'none'         │
                                │ 35      │ 'system.adapter.parser'             │ 'parser'             │ '4.0.1'          │ 'none'         │
                                │ 36      │ 'system.adapter.ping'               │ 'ping'               │ '3.0.1'          │ 'none'         │
                                │ 37      │ 'system.adapter.rest-api'           │ 'rest-api'           │ '4.0.1'          │ 'none'         │
                                │ 38      │ 'system.adapter.shelly'             │ 'shelly'             │ '10.6.1'         │ 'none'         │
                                │ 39      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '3.0.7'          │ 'none'         │
                                │ 40      │ 'system.adapter.snmp'               │ 'snmp'               │ '3.4.0'          │ 'none'         │
                                │ 41      │ 'system.adapter.socketio'           │ 'socketio'           │ '7.1.3'          │ 'none'         │
                                │ 42      │ 'system.adapter.sonos'              │ 'sonos'              │ '3.0.0'          │ 'none'         │
                                │ 43      │ 'system.adapter.sourceanalytix'     │ 'sourceanalytix'     │ '0.4.15-alpha.1' │ 'none'         │
                                │ 44      │ 'system.adapter.spotify-premium'    │ 'spotify-premium'    │ '3.0.1'          │ 'none'         │
                                │ 45      │ 'system.adapter.switchbot-cloud'    │ 'switchbot-cloud'    │ '0.1.0'          │ 'none'         │
                                │ 46      │ 'system.adapter.switchbot-hub'      │ 'switchbot-hub'      │ '0.1.2'          │ 'none'         │
                                │ 47      │ 'system.adapter.telegram'           │ 'telegram'           │ '5.0.5'          │ 'none'         │
                                │ 48      │ 'system.adapter.terminal'           │ 'terminal'           │ '1.0.0'          │ 'none'         │
                                │ 49      │ 'system.adapter.text2command'       │ 'text2command'       │ '4.0.0'          │ 'none'         │
                                │ 50      │ 'system.adapter.trashschedule'      │ 'trashschedule'      │ '5.3.0'          │ 'none'         │
                                │ 51      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'          │ 'none'         │
                                │ 52      │ 'system.adapter.vis-bars'           │ 'vis-bars'           │ '0.1.4'          │ 'none'         │
                                │ 53      │ 'system.adapter.vis-canvas-gauges'  │ 'vis-canvas-gauges'  │ '1.0.1'          │ 'none'         │
                                │ 54      │ 'system.adapter.vis-history'        │ 'vis-history'        │ '1.0.0'          │ 'none'         │
                                │ 55      │ 'system.adapter.vis-hqwidgets'      │ 'vis-hqwidgets'      │ '1.6.1'          │ 'none'         │
                                │ 56      │ 'system.adapter.vis-inventwo'       │ 'vis-inventwo'       │ '4.1.1'          │ 'none'         │
                                │ 57      │ 'system.adapter.vis-jqui-mfd'       │ 'vis-jqui-mfd'       │ '1.1.3'          │ 'none'         │
                                │ 58      │ 'system.adapter.vis-justgage'       │ 'vis-justgage'       │ '2.1.7'          │ 'none'         │
                                │ 59      │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.94'         │ 'none'         │
                                │ 60      │ 'system.adapter.vis-metro'          │ 'vis-metro'          │ '1.2.0'          │ 'none'         │
                                │ 61      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'          │ 'none'         │
                                │ 62      │ 'system.adapter.vw-connect'         │ 'vw-connect'         │ '0.9.4'          │ 'none'         │
                                │ 63      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'          │ 'none'         │
                                │ 64      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'          │ 'none'         │
                                │ 65      │ 'system.adapter.zigbee'             │ 'zigbee'             │ '3.5.5'          │ 'none'         │
                                ioBroker-Adapter Versions and update status
                                Used repository: stable
                                Adapter    "admin"        : 8.0.11   , installed 8.0.11
                                Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
                                Adapter    "backitup"     : 4.0.3    , installed 4.0.3
                                Adapter    "birthdays"    : 6.1.0    , installed 6.1.0
                                Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                Adapter    "devices"      : 1.2.14   , installed 1.2.14
                                Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                                Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                                Adapter    "evcc"         : 0.2.4    , installed 0.2.4
                                Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                                Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                                Adapter    "go-e"         : 1.0.41   , installed 1.0.41
                                Adapter    "heos"         : 3.0.4    , installed 3.0.4
                                Adapter    "history"      : 4.0.0    , installed 4.0.0
                                Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
                                Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
                                Adapter    "hue"          : 3.16.2   , installed 3.16.2
                                Adapter    "huum-sauna"   : 0.5.0    , installed 0.5.0
                                Adapter    "ical"         : 1.21.0   , installed 1.21.0
                                Adapter    "iot"          : 6.0.3    , installed 6.0.3
                                Adapter    "javascript"   : 10.1.3   , installed 10.1.3
                                Controller "js-controller": 7.2.2    , installed 7.2.2
                                Adapter    "lgtv"         : 2.7.4    , installed 2.7.4
                                Adapter    "linktap"      : 1.0.3    , installed 1.0.3
                                Adapter    "meross"       : 1.17.0   , installed 1.17.0
                                Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                                Adapter    "parser"       : 4.0.1    , installed 4.0.1
                                Adapter    "ping"         : 3.0.1    , installed 3.0.1
                                Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
                                Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                                Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                                Adapter    "snmp"         : 3.4.0    , installed 3.4.0
                                Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                                Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                                Adapter    "spotify-premium": 3.0.1  , installed 3.0.1
                                Adapter    "telegram"     : 5.0.5    , installed 5.0.5
                                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                Adapter    "text2command" : 4.0.0    , installed 4.0.0
                                Adapter    "trashschedule": 5.3.0    , installed 5.3.0
                                Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
                                Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
                                Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                                Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                Adapter    "web"          : 8.0.0    , installed 8.0.0
                                Adapter    "ws"           : 4.1.0    , installed 4.1.0
                                Adapter    "zigbee"       : 3.5.5    , installed 3.5.5
                                Objects and States
                                Objects: 	22557
                                States: 	18991
                                Pending systemupdates: 3
                                *** Listening Ports ***
                                Netid State  Recv-Q Send-Q Local Address:Port          Peer Address:PortProcess
                                udp   UNCONN 0      0            0.0.0.0:44371              0.0.0.0:*    users:(("avahi-daemon",pid=395,fd=14))
                                udp   UNCONN 0      0            0.0.0.0:bootpc             0.0.0.0:*    users:(("dhcpcd",pid=786,fd=13))
                                udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=395,fd=12))
                                udp   UNCONN 0      0                  *:38790                    *:*    users:(("avahi-daemon",pid=395,fd=15))
                                udp   UNCONN 0      0                  *:dhcpv6-client            *:*    users:(("dhcpcd",pid=786,fd=16))
                                udp   UNCONN 0      0                  *:mdns                     *:*    users:(("avahi-daemon",pid=395,fd=13))
                                tcp   LISTEN 0      128          0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=526,fd=3))
                                tcp   LISTEN 0      128             [::]:ssh                   [::]:*    users:(("sshd",pid=526,fd=4))
                                2026-09-05 16:57:24.951  - warn: host.raspberrypi instance system.adapter.trashschedule.0 terminated due to SIGKILL
                                2026-09-05 16:57:24.952  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code null ()
                                2026-09-05 16:57:24.952  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGKILL
                                2026-09-05 16:57:24.952  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
                                2026-09-05 16:57:24.994  - warn: host.raspberrypi instance system.adapter.go-e.0 terminated due to SIGKILL
                                2026-09-05 16:57:24.994  - info: host.raspberrypi instance system.adapter.go-e.0 terminated with code null ()
                                2026-09-05 16:57:25.032  - warn: host.raspberrypi instance system.adapter.vw-connect.0 terminated due to SIGKILL
                                2026-09-05 16:57:25.033  - info: host.raspberrypi instance system.adapter.vw-connect.0 terminated with code null ()
                                2026-09-05 16:57:25.092  - warn: host.raspberrypi instance system.adapter.trashschedule.1 terminated due to SIGKILL
                                2026-09-05 16:57:25.092  - info: host.raspberrypi instance system.adapter.trashschedule.1 terminated with code null ()
                                2026-09-05 16:57:25.164  - warn: host.raspberrypi instance system.adapter.simple-api.0 terminated due to SIGKILL
                                2026-09-05 16:57:25.165  - info: host.raspberrypi instance system.adapter.simple-api.0 terminated with code null ()
                                2026-09-05 16:57:25.295  - warn: host.raspberrypi instance system.adapter.linktap.0 terminated due to SIGKILL
                                2026-09-05 16:57:25.296  - info: host.raspberrypi instance system.adapter.linktap.0 terminated with code null ()
                                2026-09-05 16:57:25.298  - warn: host.raspberrypi instance system.adapter.rest-api.0 terminated due to SIGKILL
                                2026-09-05 16:57:25.299  - info: host.raspberrypi instance system.adapter.rest-api.0 terminated with code null ()
                                2026-09-05 16:57:25.346  - warn: host.raspberrypi instance system.adapter.alexa2.0 terminated due to SIGKILL
                                2026-09-05 16:57:25.347  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code null ()
                                2026-09-05 16:57:25.762  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
                                2026-09-05 16:57:25.802  - warn: host.raspberrypi instance system.adapter.meross.0 terminated due to SIGKILL
                                2026-09-05 16:57:25.802  - info: host.raspberrypi instance system.adapter.meross.0 terminated with code null ()
                                2026-09-05 16:57:25.873  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                                2026-09-05 16:57:26.068  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                                2026-09-05 16:57:26.068  - info: host.raspberrypi All instances are stopped.
                                2026-09-05 16:57:26.248  - info: host.raspberrypi terminated
                                ============= Mark until here for C&P =============
                                iob diag has finished.
                                pi@raspberrypi:~ $ iobroker fix
                                • J
                                  J
                                  jwedenig
                                  ok, ich bestelle mir zuerst eine neue SSD, möchte nichts löschen, und dann gehe ich es an. Ich mache zwar regelmäßig update/upgrade, aber wann das Betriebssystem fällig ist bekomme ich nicht mit! Wie kann ich dies in Zukunft verbessern. Bin halt nicht ständig in Foren unterwegs nach dem Motto - wenn alles läuft dann läufts!
                                  • J jwedenig
                                    Thomas BraunT
                                    Thomas BraunT
                                    @jwedenig sagte:
                                    In iob diag gibt es dazu einen Check der Lebenszeit:
                                    Sollte bei dir in Rot erscheinen. Das aktuelle stable-Release wird in grüner Schrift gemeldet und wenn es Zeit wird weiter zu ziehen wird das sog. oldstable (also der Vorgänger zur aktuellen stable) in Gelb gemeldet.
                                    Alles was nicht grün ist muss angepackt werden.
                                    • J
                                      J
                                      jwedenig
                                      ok, danke, wo finde ich hier von Dir die beste Methode zum Installieren? Es gibt ja haufenweise Install-Tipps, ich hätte gerne DEINE
                                      • J jwedenig
                                        Thomas BraunT
                                        Thomas BraunT
                                        @jwedenig
                                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                        • J
                                          J
                                          jwedenig
                                          danke Dir, das funzt auch mit einer SSD über usb? oder muss ich hier was beachten, da die Anleitung für SD Karte ist? und was meintest du vorher mit Strom checken? Brauche ich ein anderes Netzteil? danke für deine Hilfe
