  4. Javascript Adapter Skripte werden nicht geladen
23 Beiträge 7 Kommentatoren 3.7k Aufrufe
  • E Offline
    Elektroman
    Moin,
    bei mir steht das im Log:
    Caught 2018-02-25 08:13:14.230 error by controller[1]: at emitOne (events.js:96:13)
    Caught 2018-02-25 08:13:14.229 error by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8)
    Caught 2018-02-25 08:13:14.229 error by controller[1]: at Request.emit (events.js:188:7)
    Caught 2018-02-25 08:13:14.229 error by controller[1]: at emitOne (events.js:101:20)
    Caught 2018-02-25 08:13:14.229 error by controller[1]: at Request. (script.js.Wohn-_und_Esszimmer.Tablets_AN:16:49)
    Caught 2018-02-25 08:13:14.228 error by controller[1]: ReferenceError: e is not defined
    Caught 2018-02-25 08:13:14.228 error by controller[0]: at emitErrorNT (net.js:1281:8)
    Caught 2018-02-25 08:13:14.228 error by controller[0]: at Socket.emit (events.js:188:7)
    Caught 2018-02-25 08:13:14.228 error by controller[0]: at emitOne (events.js:96:13)
    Caught 2018-02-25 08:13:14.227 error by controller[0]: at Socket.socketErrorListener (_http_client.js:310:9)
    Caught 2018-02-25 08:13:14.227 error by controller[0]: at ClientRequest.emit (events.js:188:7)
    Caught 2018-02-25 08:13:14.227 error by controller[0]: at emitOne (events.js:96:13)
    Caught 2018-02-25 08:13:14.226 error by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8)
    Caught 2018-02-25 08:13:14.226 error by controller[0]: at Request.emit (events.js:188:7)
    Caught 2018-02-25 08:13:14.225 error by controller[0]: at emitOne (events.js:101:20)
    Caught 2018-02-25 08:13:14.224 error by controller[0]: at Request. (script.js.Wohn-_und_Esszimmer.Tablets_AN:16:49)
    Caught 2018-02-25 08:13:14.223 error by controller[0]: ReferenceError: e is not defined
    javascript.1 2018-02-25 08:13:14.164 info terminating
    javascript.1 2018-02-25 08:13:13.669 error at TCP._handle.close [as _onclose] (net.js:497:12)
    javascript.1 2018-02-25 08:13:13.669 error at Socket.emit (events.js:188:7)
    javascript.1 2018-02-25 08:13:13.669 error at emitOne (events.js:101:20)
    javascript.1 2018-02-25 08:13:13.669 error at Socket.socketCloseListener (_http_client.js:286:9)
    javascript.1 2018-02-25 08:13:13.669 error at ClientRequest.emit (events.js:188:7)
    javascript.1 2018-02-25 08:13:13.669 error at emitOne (events.js:96:13)
    javascript.1 2018-02-25 08:13:13.669 error at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8)
    javascript.1 2018-02-25 08:13:13.669 error at Request.emit (events.js:188:7)
    javascript.1 2018-02-25 08:13:13.669 error at Request. (script.js.Wohn-_und_Esszimmer.Tablets_AN:16:49)
    javascript.1 2018-02-25 08:13:13.669 error ReferenceError: e is not defined
    javascript.1 2018-02-25 08:13:13.669 error uncaught exception: e is not defined
    javascript.1 2018-02-25 08:13:13.662 error at emitErrorNT (net.js:1281:8)
    javascript.1 2018-02-25 08:13:13.662 error at Socket.emit (events.js:188:7)
    javascript.1 2018-02-25 08:13:13.662 error at emitOne (events.js:96:13)
    javascript.1 2018-02-25 08:13:13.662 error at Socket.socketErrorListener (_http_client.js:310:9)
    javascript.1 2018-02-25 08:13:13.662 error at ClientRequest.emit (events.js:188:7)
    javascript.1 2018-02-25 08:13:13.662 error at Request.onRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:878:8)
    javascript.1 2018-02-25 08:13:13.662 error at Request.emit (events.js:188:7)
    javascript.1 2018-02-25 08:13:13.662 error at emitOne (events.js:101:20)
    javascript.1 2018-02-25 08:13:13.662 error at Request. (script.js.Wohn-_und_Esszimmer.Tablets_AN:16:49)
    javascript.1 2018-02-25 08:13:13.662 error ReferenceError: e is not defined
    javascript.1 2018-02-25 08:13:13.660 error uncaught exception: e is not defined
    MOD-Edit by eric2905, Bitte Log-Auszüge immer in CODE- und ggf. SPOILER-Tags setzen
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Moin,
      @Elektroman:
      bei mir steht das im Log `
      das sieht aus, als ob Du einen Fehler in einem Script hast. Schau mal in die dritte Zeile von unten in Deinem Log-Auszug - da steht der Name des Scriptes.
      Gruß,
      Eric
      • E Offline
        Elektroman
        Moin Eric,
        Danke für die schnelle Hilfe
        Das Skript weckt meine Android Tablets auf. Läuft aber schon lange ohne Probleme
        Bei mir läuft ja auch eigentlich alles. Das ganze System zickt nur etwas rum Java Adapter kurzfristig immer mal wieder auf rot
        [emoji848]
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Deaktiviere mal das Script und schaue dann, ob es weiter so bleibt. Dann deaktiviere ein Script nach dem anderen.
          Oder umgekehrt … alle aus und dann eins nach dem anderen wieder aktivieren.
          Gruß,
          Eric
          Von unterwegs getippert
            Wenn ich als js-legastheniker das log richtig deute scheint entweder ein "e" abgetrennt worden zu sein, oder der Adapter interpretiert es so.
            Starte als erstes einfach mal die js Instanz neu.
            Gruß Rainer
            • E Offline
              Elektroman
              Ja danke,
              Ich habe mal etwas aufgeräumt [emoji12] Sachen die ich nicht mehr brauche gelöscht usw.
              Bis jetzt läuft es wieder rund [emoji106]
              • eric2905E Offline
                eric2905E Offline
                eric2905
                Leg Dir doch eine zweite JavaScript-Instanz an - habe ich auch gemacht.
                In der Instanz 0 läuft alles, was produktiv ist und laufen muss.
                Die Instanz 1 ist zum Basteln. Spinnt da was rum, ist nur die Instanz 1 betroffen und die Scripte der Instanz 0 laufen weiter.
                Gruß,
                Eric
                • sigi234S Online
                  sigi234S Online
                  @eric2905:
                  Hallo SIGI,
                  @sigi234:
                  Warum hilft mir niemand, warum bekomme ich keine Antworten von den Verantwortlichen.
                  Warum meldet sich keiner? `
                  nun mach mal langsam hier ….
                  Rund 10 Stunden nach Deiner Meldung so ein Post loszulassen, in einem Forum was ausschließlich von Freiwilligen unterstützt wird, ist schon heftig. :(
                  Wenn Du für einen Support irgendwo Geld bezahlst, und den Wochenenden-Aufschlag mit einberechnest, dann kannst Du solche Forderungen stellen. Aber hier sind nur Freiwillige unterwegs und dann empfinde ich es schon als unverschämt, so um die Ecke zu kommen .....
                  Aber zur Sache:
                  Welche Updates hast Du gemacht?
                  Won welcher Version auf welche?
                  Hast Du mal das Backup zurückgespielt und es dann nochmal versucht?
                  Was hast Du am System verändert, bevor Du irgendwelche Updates gemacht hast?
                  Was hast Du in dem anderen Browser-Reiter, in dem Du auch ioBroker-Admin aufgerufen hast, aktiv oder getan?
                  Stell den Admin bitte erst mal so ein, das man auch sehen kann, das Du tatsächlich alles auf dem aktuellen Stand hast.
                  Es fehlen soviel Infos, das Du bei einem bezahlten Support jetzt schon das erste Ticket verballert hättest.
                  Denk mal über die Art und Weise nach ...
                  Gruß,
                  Eric
                  Von unterwegs getippert `
                  Danke für die Hilfe,
                  das letzte was ich gemacht habe bzw. bevor es angefangen hat ist das ich den Ical umgestellt habe.
                  Probiert habe ich fast alles, bis auf ein Backup einspielen. Ich überlege ob ich Iobroker neu installieren soll, will aber meine Daten nicht verlieren. ( Views,Scripte,usw…)
                  Achso , ein update auf die Npm 3.10.10 hab ich auch gemacht.
                  Diesen Fehler bekomme ich immer:
                  host.MedionPc	2018-02-25 11:02:21.330	error	Cannot parse C:/ioBroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: SyntaxError: Unexpected end of JSON input
                  C:\iobroker>node node_modules/iobroker.js-controller/iobroker.js list instances
                  system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alexa.0                 : alexa       -  enabled
                  system.adapter.cloud.0                 : cloud       -  enabled
                  system.adapter.daswetter.0             : daswetter   -  enabled
                  system.adapter.discovery.0             : discovery   -  enabled
                  system.adapter.dwd.0                   : dwd         -  enabled
                  system.adapter.email.0                 : email       -  enabled
                  system.adapter.flot.0                  : flot        - disabled
                  system.adapter.fullcalendar.0          : fullcalendar -  enabled
                  system.adapter.history.0               : history     -  enabled
                  system.adapter.hm-rega.0               : hm-rega     -  enabled
                  system.adapter.hm-rpc.0                : hm-rpc      -  enabled, port: 18701
                  system.adapter.hm-rpc.1                : hm-rpc      -  enabled, port: 12001
                  system.adapter.hue.0                   : hue         -  enabled, port: 80
                  system.adapter.ical.0                  : ical        -  enabled
                  system.adapter.ical.1                  : ical        -  enabled
                  system.adapter.ical.2                  : ical        -  enabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png - disabled
                  system.adapter.icons-fatcow-hosting.0  : icons-fatcow-hosting - disabled
                  system.adapter.icons-icons8.0          : icons-icons8 - disabled
                  system.adapter.icons-material-png.0    : icons-material-png -  enabled
                  system.adapter.icons-material-svg.0    : icons-material-svg -  enabled
                  system.adapter.icons-mfd-png.0         : icons-mfd-png - disabled
                  system.adapter.icons-mfd-svg.0         : icons-mfd-svg - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png - disabled
                  system.adapter.info.0                  : info        -  enabled
                  system.adapter.javascript.0            : javascript  -  enabled
                  system.adapter.kodi.0                  : kodi        - disabled, port: 9090
                  system.adapter.musiccast.0             : musiccast   -  enabled
                  system.adapter.philips-tv.0            : philips-tv  - disabled
                  system.adapter.ping.0                  : ping        -  enabled
                  system.adapter.proxy.0                 : proxy       -  enabled
                  system.adapter.pushsafer.0             : pushsafer   -  enabled
                  system.adapter.rickshaw.0              : rickshaw    - disabled
                  system.adapter.samsung.0               : samsung     - disabled
                  system.adapter.sayit.0                 : sayit       -  enabled, port: 0
                  system.adapter.scenes.0                : scenes      -  enabled
                  system.adapter.simple-api.0            : simple-api  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  system.adapter.socketio.0              : socketio    -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  system.adapter.systeminfo.0            : systeminfo  -  enabled
                  system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                  system.adapter.text2command.0          : text2command -  enabled
                  system.adapter.upnp.0                  : upnp        -  enabled
                  system.adapter.vis-bars.0              : vis-bars    - disabled
                  system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges - disabled
                  system.adapter.vis-colorpicker.0       : vis-colorpicker - disabled
                  system.adapter.vis-fancyswitch.0       : vis-fancyswitch - disabled
                  system.adapter.vis-history.0           : vis-history - disabled
                  system.adapter.vis-hqwidgets.0         : vis-hqwidgets - disabled
                  system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd - disabled
                  system.adapter.vis-justgage.0          : vis-justgage - disabled
                  system.adapter.vis-lcars.0             : vis-lcars   - disabled
                  system.adapter.vis-map.0               : vis-map     - disabled
                  system.adapter.vis-material.0          : vis-material -  enabled
                  system.adapter.vis-metro.0             : vis-metro   - disabled
                  system.adapter.vis-players.0           : vis-players - disabled
                  system.adapter.vis-rgraph.0            : vis-rgraph  - disabled
                  system.adapter.vis-timeandweather.0    : vis-timeandweather - disabled
                  system.adapter.vis-weather.0           : vis-weather -  enabled
                  system.adapter.vis.0                   : vis         -  enabled
                  system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.yamaha.0                : yamaha      -  enabled
                  system.adapter.yr.0                    : yr          -  enabled
                  • eric2905E Offline
                    eric2905E Offline
                    eric2905
                    Was meinst Du mit „iCal umgestellt“?
                    Ah, Update npm …das dürfte die essentielle Info sein ...
                    Nach einem npm-Update haben einige Adapter immer Probleme und müssen neu kompiliert werden (steht schon ein paar Mal im Forum). Dafür gibt es für Linux das „reinstall.sh“ Script. Ob es was äh Lichtes für Windows gibt, weiß ich nicht.
                    Da müssen jetzt die Windows-Spezies ran.
                    Gruß,
                    Eric
                    • sigi234S Online
                      sigi234S Online
                      Die History Daten verändert und teilweise Aufzeichnungen deaktiviert.
                      • wendy2702W Online
                        wendy2702W Online
                        Ich erinnere mich verschwommen das AlCazone mal Hilfestellung nach Windows Upgrades gegeben hat.
                        Vielleicht ist hier etwas hilfreiches dabei:
                        http://forum.iobroker.net/search.php?ke … bmit=Suche
                        Falls noch nicht gesucht wurde.
                        • eric2905E Offline
                          eric2905E Offline
                          eric2905
                          @sigi234:
                          Die History Daten verändert und teilweise Aufzeichnungen deaktiviert. `
                          Also nichts am iCal umgestellt, sondern an dessen Datenpunkten im Reiter „Objekte“ in Bezug auf deren Historisierung?
                          Irgendwie verstehe ich immer noch nicht, was Du nun wo und wie genau gemacht hast (abgesehen vom npm-Update).
                          Gruß,
                          Eric
                          • AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            @wendy2702:
                            Ich erinnere mich verschwommen das AlCazone mal Hilfestellung nach Windows Upgrades gegeben hat. `
                            Habe ich? :shock: Ich hab ja nichtmal Windows-ioBroker ;)
                            • wendy2702W Online
                              wendy2702W Online
                              :mrgreen:
                              Wie Geil:
                              http://forum.iobroker.net/viewtopic.php … sh#p100215
                              Hatte schon gedacht ich wäre noch nicht wach… puh
                              • sigi234S Online
                                sigi234S Online
                                @eric2905:
                                @sigi234:
                                Gruß,
                                Eric
                                Hallo, ich habe jetzt Iobroker NEU installiert ( hab einfach den Iobroker Ordner gelöscht - war eh Komplet gesichert). Geht alles wieder…...Muss aber jetzt alles nachkonfigurieren.
                                Das einzige was mich noch zu grübeln bringt ist wie ich meine alten Skripte wieder importieren kann.
                                Danke für die Hilfe.
                                Sigi
                                • eric2905E Offline
                                  eric2905E Offline
                                  eric2905
                                  Die JavaScripte hättest Du vorher sichern / exportieren sollen (oder mit dem Adapter js2fs immer als Kopie irgendwo ablegen).
                                  Im Nachgang denke ich, das Dir dies hier helfen könnte:
                                  http://forum.iobroker.net/viewtopic.php?t=1284
                                  Aber vielleicht hat ja jemand anders noch eine Idee.
                                  Gruß,
                                  Eric
                                  • sigi234S Online
                                    sigi234S Online
                                    @eric2905:
                                    Die JavaScripte hättest Du vorher sichern / exportieren sollen (oder mit dem Adapter js2fs immer als Kopie irgendwo ablegen). `
                                    Habe ich gesichert, Skripte importiert und es funktioniert. :D
