  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.3k Aufrufe 40 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    #793
    Moin, hier mal meine Ausgabe vom aktuellsten Skript.
    ========== Langfassung ab hier markieren und kopieren ===========
    ```bash
    Script v.2026-03-10
    *** GRUNDSYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.17.9-1-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
    CPU threads     : 4
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64bit
    Systemuptime and Load:
     08:24:36 up 34 days, 16:56,  0 users,  load average: 1.01, 0.70, 0.59
    *** LEBENSZYKLUS STATUS ***
    Das Betriebssystem ist das aktuelle, stabile Debian 'trixie'!
    *** ZEIT UND ZEITZONEN ***               Local time: Thu 2026-03-12 08:24:37 CET
               Universal time: Thu 2026-03-12 07:24:37 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User und Gruppen ***
    User der 'iob diag' aufgerufen hat:
    jack
    HOME=/home/jack
    GROUPS=jack sudo users iobroker
    User der den 'js-controller' ausführt:
    iobroker[sudo] password for jack:
    HOME=/home/iobroker
    SUDO_HOME=/home/jack
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:
    *** MEMORY ***
    Mem:             12G        6.4G        5.7G        6.7M        884M        6.5G
    Swap:             0B          0B          0B
    Total:           12G        6.4G        5.7G
    Active iob-Instances:   50
            12288 M total memory
             6057 M used memory
             4592 M active memory
             1999 M inactive memory
             5393 M free memory
                0 M buffer memory
              843 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 08:24:42 up 34 days, 16:57,  0 users,  load average: 0.93, 0.69, 0.59
    Tasks:  75 total,   1 running,  74 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  6.8 us,  0.0 sy,  0.0 ni, 90.9 id,  2.3 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  12288.0 total,   5391.2 free,   6058.9 used,    844.1 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6229.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    Es wurden keine kritischen Fehler gefunden
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       25G   12G   13G  48% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    none                             tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G  372K  3.2G   1% /run
    tmpfs                            tmpfs     7.8G  6.0M  7.8G   1% /tmp
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Messages concerning filesystems in dmesg:
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    1.8G    /var/
    1.3G    /var/log/journal/d283c01113b6426689c9fe48dd9c672b
    1.3G    /var/log
    277M    /var/cache
    Archived and active journals take up 299.3M in the file system.
    /opt/iobroker/backups:
    2.5G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.5G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    651M    /opt/iobroker/iobroker-data/history
    501M    /opt/iobroker/iobroker-data/backup-objects
    269M    /opt/iobroker/iobroker-data/files/vis.0
    81M     /opt/iobroker/iobroker-data/objects.jsonl
    51M     /opt/iobroker/iobroker-data/states.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    USB-Devices by-id:
    USB-Sticks - Vermeide direkte Links zu /dev/tty* in deinen Adapter-Einstellungen,
    bevorzuge immer die Links 'by-id':
    *** ZigBee Settings ***
    ✓ zigbee.0 COM-Port stimmt mit 'by-id' überein. Sehr gut!
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    \nExtended Pan ID:
    \n*** MASKED ***
    \nPan ID:
    \n*** MASKED ***
    \nChannel:
    \n*** MASKED ***
    \nNetwork Key:
    \n*** MASKED ***
    === ZigBee-Port-Übersicht ===
    Instanz         Konfigurierter Port                 Verfügbarer by-id-Port             Status
    zigbee.0        ...936c4ce259fb3e-if00-port0        ...936c4ce259fb3e-if00-port0        ✓ Übereinstimmend
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.1
    /usr/bin/node           v22.22.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js ist korrekt installiert
    nodejs:
      Installed: 22.22.1-1nodesource1
      Candidate: 22.22.1-1nodesource1
      Version table:
     *** 22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 323440)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     7
    +-- iobroker.email@2.0.5-alpha.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.email.git#929e50908b8836bdc66e1297323324ef763bd575)
    +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
    +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
    +-- iobroker.logparser@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.logparser.git#266cccca93fd6f272ebce95e8f9e936363c30263)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
    + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
      system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
    + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
      system.adapter.nut.2                    : nut                   : ioBroker                                 - disabled
    + system.adapter.nut.3                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.open-meteo-weather.0     : open-meteo-weather    : ioBroker                                 -  enabled
    + system.adapter.open-meteo-weather.1     : open-meteo-weather    : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pirate-weather.0         : pirate-weather        : ioBroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
      system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
      system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
      system.adapter.synology.2               : synology              : ioBroker                                 - disabled, port: 5000
    + system.adapter.tagesschau.0             : tagesschau            : ioBroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 -  enabled, port: 443
      system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 - disabled
      system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-owl.0                : vis-owl               : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
      system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
      system.adapter.wettercom.0              : wettercom             : ioBroker                                 - disabled
    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
    Adapter    "brightsky"    : 0.6.6    , installed 0.6.6
    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
    Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 2.0.4    , installed 2.0.5-alpha.0
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "ping"         : 1.7.9    , installed 2.0.0
    Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
    Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
    Adapter    "rssfeed"      : 3.6.1    , installed 3.6.1
    Adapter    "shelly"       : 10.5.2   , installed 10.5.2
    Adapter    "snmp"         : 3.4.0    , installed 3.4.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tagesschau"   : 0.6.0    , installed 0.6.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "unifi-network": 1.3.1    , installed 1.3.1
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-icontwo": 1.25.0, installed 1.25.0
    Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "weather-warnings": 0.10.0, installed 0.10.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        66803
    States:         59093
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
    Reading package lists... Done
    Offene Systemupdates: 0
    *** Listening Ports ***
    Netid     State      Recv-Q     Send-Q         Local Address:Port           Peer Address:Port     Process
    udp       UNCONN     0          0                    0.0.0.0:sunrpc              0.0.0.0:*         users:(("rpcbind",pid=139,fd=5),("systemd",pid=1,fd=35))
    udp       UNCONN     0          0                    0.0.0.0:33004               0.0.0.0:*         users:(("io.snmp.0",pid=3117533,fd=30))
    udp       UNCONN     0          0                    0.0.0.0:41470               0.0.0.0:*         users:(("io.snmp.0",pid=3117533,fd=31))
    udp       UNCONN     0          0                    0.0.0.0:1900                0.0.0.0:*         users:(("io.upnp.0",pid=3118428,fd=31))
    udp       UNCONN     0          0                    0.0.0.0:51694               0.0.0.0:*         users:(("io.upnp.0",pid=3118428,fd=30))
    udp       UNCONN     0          0               192.168.1.14:mdns                0.0.0.0:*         users:(("io.tr-064.0",pid=3117618,fd=62))
    udp       UNCONN     0          0                    0.0.0.0:coap                0.0.0.0:*         users:(("io.shelly.0",pid=3117502,fd=39))
    udp       UNCONN     0          0                    0.0.0.0:6666                0.0.0.0:*         users:(("io.tuya.0",pid=3117634,fd=44))
    udp       UNCONN     0          0                    0.0.0.0:6667                0.0.0.0:*         users:(("io.tuya.0",pid=3117634,fd=45))
    udp       UNCONN     0          0                       [::]:sunrpc                 [::]:*         users:(("rpcbind",pid=139,fd=7),("systemd",pid=1,fd=37))
    tcp       LISTEN     0          4096                 0.0.0.0:sunrpc              0.0.0.0:*         users:(("rpcbind",pid=139,fd=4),("systemd",pid=1,fd=34))
    tcp       LISTEN     0          511                  0.0.0.0:9000                0.0.0.0:*         users:(("iobroker.js-con",pid=3116170,fd=29))
    tcp       LISTEN     0          511                  0.0.0.0:9001                0.0.0.0:*         users:(("iobroker.js-con",pid=3116170,fd=23))
    tcp       LISTEN     0          511                  0.0.0.0:1882                0.0.0.0:*         users:(("io.shelly.1",pid=3117518,fd=31))
    tcp       LISTEN     0          1                    0.0.0.0:9999                0.0.0.0:*         users:(("nc",pid=1156031,fd=3))
    tcp       LISTEN     0          511             192.168.1.14:8082                0.0.0.0:*         users:(("io.web.0",pid=3118942,fd=30))
    tcp       LISTEN     0          100                127.0.0.1:smtp                0.0.0.0:*         users:(("master",pid=306,fd=13))
    tcp       LISTEN     0          4096                    [::]:sunrpc                 [::]:*         users:(("rpcbind",pid=139,fd=6),("systemd",pid=1,fd=36))
    tcp       LISTEN     0          4096                       *:ssh                       *:*         users:(("sshd",pid=180,fd=3),("systemd",pid=1,fd=52))
    tcp       LISTEN     0          100                    [::1]:smtp                   [::]:*         users:(("master",pid=306,fd=14))
    tcp       LISTEN     0          511                        *:tproxy                    *:*         users:(("io.admin.0",pid=3116193,fd=32))
    tcp       LISTEN     0          511                        *:8084                      *:*         users:(("io.ws.0",pid=3118962,fd=29))
    tcp       LISTEN     0          511                        *:8087                      *:*         users:(("io.simple-api.0",pid=3118340,fd=29))
    tcp       LISTEN     0          511                        *:8093                      *:*         users:(("io.rest-api.0",pid=3589791,fd=29))
    2026-03-12 08:20:00.004  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Waeschezimmer: 11.24 g/m³
    2026-03-12 08:20:00.004  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Taupunkt in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Waeschezimmer: 16.08 °C
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Waeschezimmer] Fixed Calculation: RH_in=65.5%, Threshold=60 -> Empfehlung Lüften: true
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Waeschezimmer] Absolute Humidity Calculation: AH_in=11.24 g/m³, AH_out=6.67 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Flur gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Flur: 12.18 g/m³
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Taupunkt in Flur gespeichert in 0_userdata.0.Raumklima.Taupunkt.Flur: 17.38 °C
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Flur] Fixed Calculation: RH_in=66.5%, Threshold=60 -> Empfehlung Lüften: true
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Flur] Absolute Humidity Calculation: AH_in=12.18 g/m³, AH_out=6.67 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Schlafzimmer: 10.16 g/m³
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Taupunkt in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Schlafzimmer: 14.58 °C
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Schlafzimmer] Fixed Calculation: RH_in=52%, Threshold=60 -> Empfehlung Lüften: false
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Schlafzimmer] Absolute Humidity Calculation: AH_in=10.16 g/m³, AH_out=6.67 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Werkstatt gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Werkstatt: 8.55 g/m³
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: Taupunkt in Werkstatt gespeichert in 0_userdata.0.Raumklima.Taupunkt.Werkstatt: 11.77 °C
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Werkstatt] Fixed Calculation: RH_in=60%, Threshold=60 -> Empfehlung Lüften: true
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: [Werkstatt] Absolute Humidity Calculation: AH_in=8.55 g/m³, AH_out=6.67 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
    2026-03-12 08:20:00.005  - info: javascript.0 (3116315) script.js.Heizungen.Raumklima: runCalculation ausgelöst (10-Minuten-Intervall)
    2026-03-12 08:20:47.703  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2026-03-12 08:21:49.490  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2026-03-12 08:22:33.787  - info: javascript.0 (3116315) script.js.Ereignisse.Büroheizung: Warm Heizung-Büro ist aus
    2026-03-12 08:22:33.881  - info: javascript.0 (3116315) script.js.Ereignisse.Büroheizung: Warm Heizung-Büro ist an
    2026-03-12 08:22:55.351  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2026-03-12 08:23:00.043  - info: javascript.0 (3116315) script.js.Ereignisse.Büroheizung: Warm Heizung-Büro ist aus
    2026-03-12 08:23:59.365  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    2026-03-12 08:25:03.670  - info: javascript.0 (3116315) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
    ============ Langfassung bis hier markieren =============
    Gruß Ralf
    • NashraN Nashra
      ```bash
      Script v.2026-03-10
      *** GRUNDSYSTEM ***
        Virtualization: lxc
      OS is similar to:
      CPU threads     : 4
      Docker          : false
      Kernel          : x86_64
      Userland        : 64bit
                       RTC time: n/a
                RTC in local TZ: no
      jack
      HOME=/home/jack
      HOME=/home/iobroker
      Desktop:
      Session:
      *** MEMORY ***
      Swap:             0B          0B          0B
               6057 M used memory
               5393 M free memory
                  0 M buffer memory
                843 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      1.8G    /var/
      1.3G    /var/log
      277M    /var/cache
      USB-Devices by-id:
      zigbee.X
      \nExtended Pan ID:
      \n*** MASKED ***
      \nPan ID:
      \n*** MASKED ***
      \nChannel:
      \n*** MASKED ***
      \nNetwork Key:
      \n*** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.22
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        66803
      States:         59093
      #794
      @Nashra
      Ah, mal die --de Version. Sehr schön.
      Bei
                       RTC time: n/a
      fehlt offenbar ein Zeilensprung.
      Und bei den Netzwerkports fehlen die gebunden Ports, glaube ich. Muss ich mir später mal genauer anschauen.
      • Thomas BraunT Online
        #795
        Mal nur so zum Test, ob die neuste Version auch noch komplett in ein Forenposting passt. Es sind noch ein paar Kleinigkeiten dazu gekommen.
        Script v.2026-05-18
        *** BASE SYSTEM ***
         Static hostname: chet
               Icon name: computer
                  Kernel: Linux 6.18.29+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64bit
         23:43:24 up 2 days,  1:51,  1 user,  load average: 0.65, 0.41, 0.38
        CPU threads     : 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'trixie'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2026-05-18 23:43:24 CEST
                   Universal time: Mon 2026-05-18 21:43:24 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        echad
        HOME=/home/echad
        GROUPS=echad adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
        Desktop:
        Session:                tty
        Boot Target:            multi-user.target
        *** MEMORY ***
        Mem:            8.2G        5.6G        834M         26M        1.9G        2.6G
        Swap:           2.1G         28M        2.1G
        Total:           10G        5.6G        3.0G
        Active iob-Instances:   38
                 7818 M total memory
                 5358 M used memory
                 3593 M active memory
                 2760 M inactive memory
                  795 M free memory
                  436 M buffer memory
                 1353 M swap cache
                 2047 M total swap
                   27 M used swap
                 2020 M free swap
        top - 23:43:25 up 2 days,  1:51,  1 user,  load average: 0.76, 0.44, 0.39
        Tasks: 214 total,   1 running, 213 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  4.5 sy,  0.0 ni, 95.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7818.8 total,    795.3 free,   5358.7 used,   1789.5 buff/cache
        MiB Swap:   2048.0 total,   2020.7 free,     27.3 used.   2460.1 avail Mem
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     1.6G   23M  1.6G   2% /run
        /dev/sda2      ext4      110G   18G   87G  17% /
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-resolved.service
        tmpfs          tmpfs     3.9G  2.6M  3.9G   1% /tmp
        /dev/sda1      vfat      510M   75M  436M  15% /boot/firmware
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
        tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
        [Sat May 16 21:51:29 2026] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
        [Sat May 16 21:51:30 2026] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
        /                /dev/sda2 ext4   rw,noatime
        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        5.1G    /var/
        2.8G    /var/cache/apt
        2.8G    /var/cache
        2.6G    /var/cache/apt/archives
        302M    /var/lib
        Archived and active journals take up 45.6M in the file system.
        4.0K    /opt/iobroker/backups/
        1.1G    /opt/iobroker/iobroker-data/
        645M    /opt/iobroker/iobroker-data/history
        186M    /opt/iobroker/iobroker-data/files
        186M    /opt/iobroker/iobroker-data/backup-objects
        65M     /opt/iobroker/iobroker-data/history/20250702
        32M     /opt/iobroker/iobroker-data/objects.jsonl
        30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
        12M     /opt/iobroker/iobroker-data/history/20260518/history.0_userdata.0.stromzaehler.SML.aktuelle_wirkleistung.json
        12M     /opt/iobroker/iobroker-data/history/20260517/history.0_userdata.0.stromzaehler.SML.aktuelle_wirkleistung.json
        12M     /opt/iobroker/iobroker-data/history/20260516/history.0_userdata.0.stromzaehler.SML.aktuelle_wirkleistung.json
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
        please always prefer the links 'by-id':
        /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
        ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        === ZigBee Port Overview ===
        Instance        Configured Port                     Available by-id Port                Status
        zigbee.0        ...00_23_93_2C_A8-if00-port0        ...00_23_93_2C_A8-if00-port0        ✓ Matching
        /usr/bin/nodejs         v24.15.0
        /usr/bin/node           v24.15.0
        /usr/bin/npm            11.12.1
        /usr/bin/npx            11.12.1
        ✓ Node.js installation is correct
        nodejs:
          Installed: 24.15.0-1nodesource1
          Candidate: 24.15.0-1nodesource1
          Version table:
         *** 24.15.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
             24.14.1-1nodesource1 1001
             24.14.0-1nodesource1 1001
             24.13.1-1nodesource1 1001
             24.13.0-1nodesource1 1001
             24.12.0-1nodesource1 1001
             24.11.1-1nodesource1 1001
             24.11.0-1nodesource1 1001
             24.10.0-1nodesource1 1001
             24.9.0-1nodesource1 1001
             24.8.0-1nodesource1 1001
             24.7.0-1nodesource1 1001
             24.6.0-1nodesource1 1001
             24.5.0-1nodesource1 1001
             24.4.1-1nodesource1 1001
             24.4.0-1nodesource1 1001
             24.3.0-1nodesource1 1001
             24.1.0-1nodesource1 1001
             24.0.2-1nodesource1 1001
             24.0.1-1nodesource1 1001
             24.0.0-1nodesource1 1001
             20.19.2+dfsg-1+deb13u2 500
                500 http://deb.debian.org/debian trixie/main arm64 Packages
                500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
        No known Vulnerabilities detected!
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        chet                chet (version: 7.1.2, hostname: chet          , alive, uptime: 179522)
        js-controller:  7.1.2
        admin:          7.8.25
        javascript:     9.2.2
        nodejs modules from github:     3
        +-- iobroker.govee-app@0.0.10 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#d5e7f1703b520238db36cd1552c54cdfa89c6715)
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
        Adapter State
        + system.adapter.admin.0                  : admin                 : chet                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : chet                                     -  enabled
        + system.adapter.ankersolix2.0            : ankersolix2           : chet                                     -  enabled
        + system.adapter.awtrix-light.0           : awtrix-light          : chet                                     -  enabled
        + system.adapter.backitup.0               : backitup              : chet                                     -  enabled
        + system.adapter.ble.0                    : ble                   : chet                                     -  enabled
        + system.adapter.cloud.0                  : cloud                 : chet                                     -  enabled
        + system.adapter.echarts.0                : echarts               : chet                                     -  enabled
        + system.adapter.firetv.0                 : firetv                : chet                                     -  enabled
        + system.adapter.followthesun.0           : followthesun          : chet                                     -  enabled
        + system.adapter.govee-app.0              : govee-app             : chet                                     -  enabled
          system.adapter.govee-local.0            : govee-local           : chet                                     - disabled
        + system.adapter.history.0                : history               : chet                                     -  enabled
          system.adapter.ical.0                   : ical                  : chet                                     -  enabled
          system.adapter.iceroad.0                : iceroad               : chet                                     -  enabled
        + system.adapter.iot.0                    : iot                   : chet                                     -  enabled
        + system.adapter.javascript.0             : javascript            : chet                                     -  enabled
        + system.adapter.mihome-cloud.0           : mihome-cloud          : chet                                     -  enabled, port: 9898, bind: 0.0.0.0
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : chet                                     -  enabled, port: 54321, bind: 0.0.0.0
        + system.adapter.mihome.0                 : mihome                : chet                                     -  enabled, port: 9898, bind: 0.0.0.0
        + system.adapter.mqtt.0                   : mqtt                  : chet                                     -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.nina.0                   : nina                  : chet                                     -  enabled
        + system.adapter.notification-manager.0   : notification-manager  : chet                                     -  enabled
        + system.adapter.nuki-extended.0          : nuki-extended         : chet                                     -  enabled
        + system.adapter.nut.0                    : nut                   : chet                                     -  enabled
        + system.adapter.opendtu.0                : opendtu               : chet                                     -  enabled
          system.adapter.openweathermap.0         : openweathermap        : chet                                     -  enabled
        + system.adapter.parcel.0                 : parcel                : chet                                     -  enabled
          system.adapter.playstation.0            : playstation           : chet                                     - disabled
        + system.adapter.rpi2.0                   : rpi2                  : chet                                     -  enabled
        + system.adapter.sainlogic.0              : sainlogic             : chet                                     -  enabled, port: 45000, bind: 0.0.0.0
          system.adapter.samsung.0                : samsung               : chet                                     - disabled
          system.adapter.samsung_tizen.0          : samsung_tizen         : chet                                     - disabled, port: 8002
        + system.adapter.switchbot-hub.0          : switchbot-hub         : chet                                     -  enabled
        + system.adapter.tado.0                   : tado                  : chet                                     -  enabled
        + system.adapter.tr-064.0                 : tr-064                : chet                                     -  enabled
        + system.adapter.tradfri.0                : tradfri               : chet                                     -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : chet                                     -  enabled
        + system.adapter.tuya.0                   : tuya                  : chet                                     -  enabled
        + system.adapter.weather-warnings.0       : weather-warnings      : chet                                     -  enabled
        + system.adapter.web.0                    : web                   : chet                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : chet                                     -  enabled
        + system.adapter.ws.0                     : ws                    : chet                                     -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : chet                                     -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
        + instance is alive
        │ 0       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        │ 1       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
        │ 2       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
        │ 3       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        Active repo(s): beta
        │ (index) │ id                                    │ name                   │ version  │ upgrade policy │
        │ 0       │ 'system.adapter.admin'                │ 'admin'                │ '7.8.25' │ 'none'         │
        │ 1       │ 'system.adapter.alexa2'               │ 'alexa2'               │ '3.27.4' │ 'none'         │
        │ 2       │ 'system.adapter.ankersolix2'          │ 'ankersolix2'          │ '2.4.1'  │ 'none'         │
        │ 3       │ 'system.adapter.awtrix-light'         │ 'awtrix-light'         │ '3.0.0'  │ 'none'         │
        │ 4       │ 'system.adapter.backitup'             │ 'backitup'             │ '3.3.17' │ 'none'         │
        │ 5       │ 'system.adapter.ble'                  │ 'ble'                  │ '0.14.1' │ 'none'         │
        │ 6       │ 'system.adapter.cloud'                │ 'cloud'                │ '6.0.4'  │ 'none'         │
        │ 7       │ 'system.adapter.echarts'              │ 'echarts'              │ '3.1.0'  │ 'none'         │
        │ 8       │ 'system.adapter.firetv'               │ 'firetv'               │ '2.2.0'  │ 'none'         │
        │ 9       │ 'system.adapter.followthesun'         │ 'followthesun'         │ '0.5.2'  │ 'none'         │
        │ 10      │ 'system.adapter.govee-app'            │ 'govee-app'            │ '0.0.10' │ 'none'         │
        │ 11      │ 'system.adapter.govee-local'          │ 'govee-local'          │ '0.4.6'  │ 'none'         │
        │ 12      │ 'system.adapter.history'              │ 'history'              │ '4.0.0'  │ 'none'         │
        │ 13      │ 'system.adapter.ical'                 │ 'ical'                 │ '1.20.1' │ 'none'         │
        │ 14      │ 'system.adapter.iceroad'              │ 'iceroad'              │ '1.2.1'  │ 'none'         │
        │ 15      │ 'system.adapter.iot'                  │ 'iot'                  │ '6.0.3'  │ 'none'         │
        │ 16      │ 'system.adapter.javascript'           │ 'javascript'           │ '9.2.2'  │ 'none'         │
        │ 17      │ 'system.adapter.mihome'               │ 'mihome'               │ '1.4.0'  │ 'none'         │
        │ 18      │ 'system.adapter.mihome-cloud'         │ 'mihome-cloud'         │ '1.0.6'  │ 'none'         │
        │ 19      │ 'system.adapter.mihome-vacuum'        │ 'mihome-vacuum'        │ '5.3.0'  │ 'none'         │
        │ 20      │ 'system.adapter.mqtt'                 │ 'mqtt'                 │ '6.1.4'  │ 'none'         │
        │ 21      │ 'system.adapter.nina'                 │ 'nina'                 │ '0.0.26' │ 'none'         │
        │ 22      │ 'system.adapter.notification-manager' │ 'notification-manager' │ '1.3.0'  │ 'none'         │
        │ 23      │ 'system.adapter.nuki-extended'        │ 'nuki-extended'        │ '2.8.2'  │ 'none'         │
        │ 24      │ 'system.adapter.nut'                  │ 'nut'                  │ '1.7.0'  │ 'none'         │
        │ 25      │ 'system.adapter.opendtu'              │ 'opendtu'              │ '3.1.0'  │ 'none'         │
        │ 26      │ 'system.adapter.openweathermap'       │ 'openweathermap'       │ '1.4.0'  │ 'none'         │
        │ 27      │ 'system.adapter.parcel'               │ 'parcel'               │ '0.3.1'  │ 'none'         │
        │ 28      │ 'system.adapter.playstation'          │ 'playstation'          │ '0.0.3'  │ 'none'         │
        │ 29      │ 'system.adapter.rpi2'                 │ 'rpi2'                 │ '3.0.2'  │ 'none'         │
        │ 30      │ 'system.adapter.sainlogic'            │ 'sainlogic'            │ '1.2.1'  │ 'none'         │
        │ 31      │ 'system.adapter.samsung'              │ 'samsung'              │ '0.7.0'  │ 'none'         │
        │ 32      │ 'system.adapter.samsung_tizen'        │ 'samsung_tizen'        │ '1.1.0'  │ 'none'         │
        │ 33      │ 'system.adapter.switchbot-hub'        │ 'switchbot-hub'        │ '0.1.2'  │ 'none'         │
        │ 34      │ 'system.adapter.tado'                 │ 'tado'                 │ '0.8.4'  │ 'none'         │
        │ 35      │ 'system.adapter.tr-064'               │ 'tr-064'               │ '4.3.0'  │ 'none'         │
        │ 36      │ 'system.adapter.tradfri'              │ 'tradfri'              │ '3.1.3'  │ 'none'         │
        │ 37      │ 'system.adapter.trashschedule'        │ 'trashschedule'        │ '5.3.0'  │ 'none'         │
        │ 38      │ 'system.adapter.tuya'                 │ 'tuya'                 │ '3.17.0' │ 'none'         │
        │ 39      │ 'system.adapter.weather-warnings'     │ 'weather-warnings'     │ '0.10.1' │ 'none'         │
        │ 40      │ 'system.adapter.web'                  │ 'web'                  │ '8.1.0'  │ 'none'         │
        │ 41      │ 'system.adapter.whatsapp-cmb'         │ 'whatsapp-cmb'         │ '0.3.0'  │ 'none'         │
        │ 42      │ 'system.adapter.ws'                   │ 'ws'                   │ '4.1.0'  │ 'none'         │
        │ 43      │ 'system.adapter.zigbee'               │ 'zigbee'               │ '3.4.5'  │ 'none'         │
        ioBroker-Adapter Versions and update status
        Used repository: beta
        Adapter    "admin"        : 7.8.25   , installed 7.8.25
        Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
        Adapter    "backitup"     : 3.3.17   , installed 3.3.17
        Adapter    "ble"          : 0.14.1   , installed 0.14.1
        Adapter    "cloud"        : 6.0.4    , installed 6.0.4
        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
        Adapter    "firetv"       : 2.2.0    , installed 2.2.0
        Adapter    "followthesun" : 0.5.2    , installed 0.5.2
        Adapter    "govee-local"  : 0.4.6    , installed 0.4.6
        Adapter    "history"      : 4.0.0    , installed 4.0.0
        Adapter    "ical"         : 1.20.1   , installed 1.20.1
        Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
        Adapter    "iot"          : 6.0.3    , installed 6.0.3
        Adapter    "javascript"   : 9.2.2    , installed 9.2.2
        Controller "js-controller": 7.1.2    , installed 7.1.2
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mihome-cloud" : 1.0.6    , installed 1.0.6
        Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
        Adapter    "nina"         : 0.0.26   , installed 0.0.26
        Adapter    "notification-manager": 1.3.0, installed 1.3.0
        Adapter    "nuki-extended": 2.8.2    , installed 2.8.2
        Adapter    "nut"          : 1.7.0    , installed 1.7.0
        Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
        Adapter    "openweathermap": 1.4.0   , installed 1.4.0
        Adapter    "parcel"       : 0.3.1    , installed 0.3.1
        Adapter    "playstation"  : 0.0.3    , installed 0.0.3
        Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
        Adapter    "sainlogic"    : 1.2.1    , installed 1.2.1
        Adapter    "samsung"      : 0.7.0    , installed 0.7.0
        Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
        Adapter    "socketio"     : 7.1.3    , installed 7.1.3
        Adapter    "tado"         : 0.8.4    , installed 0.8.4
        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
        Adapter    "trashschedule": 5.3.0    , installed 5.3.0
        Adapter    "tuya"         : 3.17.0   , installed 3.17.0
        Adapter    "weather-warnings": 0.10.1, installed 0.10.1
        Adapter    "web"          : 8.1.0    , installed 8.1.0
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "ws"           : 4.1.0    , installed 4.1.0
        Adapter    "zigbee"       : 3.4.5    , installed 3.4.5
        Objects and States
        Objects:        10503
        States:         8582
        Hit:1 http://archive.raspberrypi.com/debian trixie InRelease
        Hit:2 http://deb.debian.org/debian trixie InRelease
        Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
        Hit:4 http://deb.debian.org/debian trixie-updates InRelease
        Get:5 https://cli.github.com/packages stable InRelease [3917 B]
        Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
        Hit:7 https://repo.mosquitto.org/debian trixie InRelease
        Get:8 https://pkgs.tailscale.com/stable/debian trixie InRelease
        Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
        Fetched 10.5 kB in 1s (7481 B/s)
        Pending systemupdates: 0
        udp              UNCONN             0                  0                                                  0.0.0.0:6667                                       0.0.0.0:*                users:(("io.tuya.0",pid=1728,fd=41))
        udp              UNCONN             0                  0                                               127.0.0.54:domain                                     0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=19))
        udp              UNCONN             0                  0                                               127.0.0.53:domain                                     0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=17))
        udp              UNCONN             0                  0                                                  0.0.0.0:53421                                      0.0.0.0:*                users:(("io.mihome-vacuu",pid=1568,fd=34))
        udp              UNCONN             0                  0                                                  0.0.0.0:33089                                      0.0.0.0:*                users:(("io.tradfri.0",pid=2063,fd=30))
        udp              UNCONN             0                  0                                                  0.0.0.0:41641                                      0.0.0.0:*                users:(("tailscaled",pid=935,fd=18))
        udp              UNCONN             0                  0                                            100.77.247.74:mdns                                       0.0.0.0:*                users:(("io.tr-064.0",pid=1715,fd=67))
        udp              UNCONN             0                  0                                           192.168.178.48:mdns                                       0.0.0.0:*                users:(("io.tr-064.0",pid=1715,fd=66))
        udp              UNCONN             0                  0                                                  0.0.0.0:5355                                       0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=11))
        udp              UNCONN             0                  0                                                  0.0.0.0:9898                                       0.0.0.0:*                users:(("io.mihome.0",pid=1586,fd=35))
        udp              UNCONN             0                  0                                                  0.0.0.0:6666                                       0.0.0.0:*                users:(("io.tuya.0",pid=1728,fd=40))
        udp              UNCONN             0                  0                               [fe80::121:85fe:2566:b9f0]:dhcpv6-client                                    *:*                users:(("NetworkManager",pid=666,fd=28))
        udp              UNCONN             0                  0                                                        *:41641                                            *:*                users:(("tailscaled",pid=935,fd=17))
        udp              UNCONN             0                  0                                                        *:5355                                             *:*                users:(("systemd-resolve",pid=331,fd=13))
        tcp              LISTEN             0                  100                                                0.0.0.0:1883                                       0.0.0.0:*                users:(("mosquitto",pid=1070,fd=6))
        tcp              LISTEN             0                  20                                               127.0.0.1:smtp                                       0.0.0.0:*                users:(("exim4",pid=1317,fd=5))
        tcp              LISTEN             0                  4096                                             127.0.0.1:5037                                       0.0.0.0:*                users:(("adb",pid=1517,fd=12))
        tcp              LISTEN             0                  511                                              127.0.0.1:9001                                       0.0.0.0:*                users:(("iobroker.js-con",pid=929,fd=23))
        tcp              LISTEN             0                  511                                              127.0.0.1:9000                                       0.0.0.0:*                users:(("iobroker.js-con",pid=929,fd=29))
        tcp              LISTEN             0                  4096                                               0.0.0.0:5355                                       0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=12))
        tcp              LISTEN             0                  4096                                            127.0.0.54:domain                                     0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=20))
        tcp              LISTEN             0                  128                                                0.0.0.0:ssh                                        0.0.0.0:*                users:(("sshd",pid=955,fd=6))
        tcp              LISTEN             0                  16                                                 0.0.0.0:nut                                        0.0.0.0:*                users:(("upsd",pid=941,fd=4))
        tcp              LISTEN             0                  4096                                         127.0.0.53%lo:domain                                     0.0.0.0:*                users:(("systemd-resolve",pid=331,fd=18))
        tcp              LISTEN             0                  4096                                         100.77.247.74:39029                                      0.0.0.0:*                users:(("tailscaled",pid=935,fd=23))
        tcp              LISTEN             0                  100                                                   [::]:1883                                          [::]:*                users:(("mosquitto",pid=1070,fd=7))
        tcp              LISTEN             0                  4096                                                  [::]:5355                                          [::]:*                users:(("systemd-resolve",pid=331,fd=14))
        tcp              LISTEN             0                  4096                           [fd7a:115c:a1e0::6b01:f74a]:60625                                         [::]:*                users:(("tailscaled",pid=935,fd=24))
        tcp              LISTEN             0                  128                                                   [::]:ssh                                           [::]:*                users:(("sshd",pid=955,fd=7))
        tcp              LISTEN             0                  20                                                   [::1]:smtp                                          [::]:*                users:(("exim4",pid=1317,fd=6))
        tcp              LISTEN             0                  511                                                      *:8084                                             *:*                users:(("io.ws.0",pid=2159,fd=34))
        tcp              LISTEN             0                  511                                                      *:8082                                             *:*                users:(("io.web.0",pid=1745,fd=35))
        tcp              LISTEN             0                  511                                                      *:tproxy                                           *:*                users:(("io.admin.0",pid=41326,fd=38))
        tcp              LISTEN             0                  511                                                      *:45000                                            *:*                users:(("io.sainlogic.0",pid=2014,fd=32))
        tcp              LISTEN             0                  511                                                      *:51989                                            *:*                users:(("io.nuki-extende",pid=1644,fd=37))
        2026-05-18 12:10:17.587  - info: zigbee.0 (80561) cleanup successful
        2026-05-18 12:10:17.588  - info: zigbee.0 (80561) terminating
        2026-05-18 12:10:17.595  - info: zigbee.0 (80561) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2026-05-18 12:10:32.973  - info: zigbee.0 (116693) starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v24.15.0, js-controller: 7.1.2
        2026-05-18 12:10:33.004  - info: zigbee.0 (116693) init localConfig
        2026-05-18 12:10:33.028  - info: zigbee.0 (116693) Adapter ready - starting subsystems. Adapter is running in info mode.
        2026-05-18 12:10:33.101  - info: zigbee.0 (116693) delete old Backup files. keep only last 10
        2026-05-18 12:10:33.104  - info: zigbee.0 (116693) Autostart Zigbee subsystem
        2026-05-18 12:10:33.105  - info: zigbee.0 (116693) Starting Adapter npm ...
        2026-05-18 12:10:33.127  - info: zigbee.0 (116693) Installed Version: iobroker.zigbee@3.4.5 (Converters 26.51.1 Herdsman 10.1.0)
        2026-05-18 12:10:33.129  - info: zigbee.0 (116693) configured transmit power :
        2026-05-18 12:10:33.130  - info: zigbee.0 (116693) Starting Zigbee-Herdsman
        2026-05-18 12:10:45.261  - info: zigbee.0 (116693) Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20250321 (2-1.2.7.1)
        2026-05-18 12:10:45.265  - info: zigbee.0 (116693) No devices
        2026-05-18 12:10:45.269  - info: zigbee.0 (116693) Zigbee started
        2026-05-18 12:23:20.138  - warn: nuki-extended.0 (1644) getWebApi(): Error retrieving logs: 500 - {"code":500,"description":"The server encountered an unexpected condition which prevented it from fulfilling the request","homeRef":"/","reasonPhrase":"Internal Server Error","uri":"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.5.1"}
        2026-05-18 13:16:53.120  - error: mihome-cloud.0 (1491) Error polling custom properties for Wassersensor Bad: timeout of 15000ms exceeded
        2026-05-18 13:47:02.437  - error: mihome-cloud.0 (1491) Error polling custom properties for Wohnungstür: timeout of 15000ms exceeded
        2026-05-18 15:00:14.415  - error: parcel.0 (2167) Error: read ECONNRESET
        2026-05-18 18:18:53.413  - warn: awtrix-light.0 (1875) Unable to perform action for apps.batchar.visible - API is not connected (device not reachable?)
        2026-05-18 18:37:34.018  - error: mihome-cloud.0 (1491) Error polling custom properties for Gateway: timeout of 15000ms exceeded
        2026-05-18 20:30:19.410  - warn: javascript.0 (1359) script.js.common.sonnenuntergang: Golden hour wurde getriggert
        2026-05-18 20:36:20.329  - warn: iceroad.0 (141788) get state error: Connection is closed.
        2026-05-18 20:47:03.312  - error: mihome-cloud.0 (1491) Error polling custom properties for Wassersensor: timeout of 15000ms exceeded
        2026-05-18 23:37:02.627  - error: mihome-cloud.0 (1491) Error polling custom properties for Wassersensor: timeout of 15000ms exceeded
        ============= Mark until here for C&P =============
        iob diag has finished.
        echad@chet:~ $
          Script v.2026-05-18
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64bit
          CPU threads     : 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          echad
          HOME=/home/echad
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           2.1G         28M        2.1G
                   7818 M total memory
                   5358 M used memory
                    795 M free memory
                    436 M buffer memory
                   1353 M swap cache
                   2047 M total swap
                     27 M used swap
                   2020 M free swap
          *** FILESYSTEM ***
          /var:
          5.1G    /var/
          2.8G    /var/cache/apt
          2.8G    /var/cache
          302M    /var/lib
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.8.25
          javascript:     9.2.2
          Adapter State
          + instance is alive
          Objects and States
          Objects:        10503
          States:         8582
          echad@chet:~ $
          MCU
          #796
          @Thomas-Braun Gibt es die diag auch für Windows?
          Thomas BraunT S 2 Antworten Letzte Antwort
          • M MCU
            #797
            @MCU
            Das Skript läuft nur unter Linux. Von Windows hab ich ja keine Ahnung.
            Ich weiß nicht mal, was passiert wenn man
            iob diag
            auf einem Windows aufruft.
            Aber ich meine @gaspode hatte mal mit einer Portierung (oder zumindest etwas ähnlichem) angefangen.
            • S Abwesend
              S Abwesend
              Shadowhunter23
              #798
              Du solltest den Link im ersten Beitrag noch anpassen zur neusten Version.
              Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
              ioBroker Backup Analyzer
              • S Shadowhunter23
                #799
                @Shadowhunter23
                Stimmt.
                Versuch es jetzt mal.
                • skvarelS Offline
                  skvarelS Offline
                  skvarel
                  #800
                  Jetzt musste ich das auch endlich mal testen:
                  ```bash
                  Script v.2026-05-18
                  *** GRUNDSYSTEM ***
                  Operating System: Ubuntu 24.04.4 LTS
                         Icon name: computer-desktop
                           Chassis: desktop 🖥️
                            Kernel: Linux 6.8.0-117-generic
                   Hardware Vendor: Dell Inc.
                    Hardware Model: OptiPlex 3050
                  Firmware Version: 1.6.5
                     Firmware Date: Sat 2017-09-09
                      Firmware Age: 8y 8month 1w 1d
                  OS is similar to: debian
                  model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64bit
                   08:00:11 up 1 day, 58 min,  1 user,  load average: 1.79, 1.15, 1.02
                  CPU threads     : 4
                  Das Betriebssystem mit dem Codenamen 'noble' ist unbekannt. Bitte den Status der Unterstützung eigenständig prüfen.
                                 Local time: Tue 2026-05-19 08:00:11 CEST
                             Universal time: Tue 2026-05-19 06:00:11 UTC
                                   RTC time: Tue 2026-05-19 06:00:11
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm cdrom sudo dip plugdev lxd iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev redis
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:             16G        8.3G        5.5G        5.0M        3.2G        8.4G
                  Swap:           4.3G          0B        4.3G
                  Total:           20G        8.3G        9.8G
                  Active iob-Instances:   54
                          15877 M total memory
                           7909 M used memory
                           7918 M active memory
                           1805 M inactive memory
                           5213 M free memory
                            583 M buffer memory
                           2512 M swap cache
                           4095 M total swap
                              0 M used swap
                           4095 M free swap
                  top - 08:00:11 up 1 day, 58 min,  1 user,  load average: 1.79, 1.15, 1.02
                  Tasks: 239 total,   2 running, 237 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  4.1 us,  4.1 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :  15877.7 total,   5213.0 free,   7910.1 used,   3095.6 buff/cache
                  MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   7967.6 avail Mem
                  *** FILESYSTEM ***
                  tmpfs                             tmpfs  1.6G  4.6M  1.6G   1% /run
                  /dev/mapper/ubuntu--vg-ubuntu--lv ext4   467G   20G  428G   5% /
                  /dev/nvme0n1p2                    ext4   2.0G  200M  1.6G  11% /boot
                  tmpfs                             tmpfs  1.6G   12K  1.6G   1% /run/user/1000
                  [Mon May 18 07:01:29 2026] Btrfs loaded, zoned=yes, fsverity=yes
                  [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): mounted filesystem a547182b-43b5-440e-b6fe-09323774b05c ro with ordered data mode. Quota mode: none.
                  [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): re-mounted a547182b-43b5-440e-b6fe-09323774b05c r/w.
                  [Mon May 18 07:01:30 2026] EXT4-fs (nvme0n1p2): mounted filesystem 7a71a3d0-fb5e-4ed0-8d6d-dc24002c0eef r/w with ordered data mode. Quota mode: none.
                  /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
                  `-/boot /dev/nvme0n1p2                    ext4   rw,relatime
                  /var:
                  5.1G    /var/
                  4.2G    /var/log
                  4.1G    /var/log/journal/b521ee0ca8cb46db87113e33c1d11d82
                  756M    /var/lib
                  Archived and active journals take up 4.0G in the file system.
                  252M    /opt/iobroker/backups/
                  514M    /opt/iobroker/iobroker-data/
                  327M    /opt/iobroker/iobroker-data/files
                  132M    /opt/iobroker/iobroker-data/backup-objects
                  56M     /opt/iobroker/iobroker-data/files/vis-2
                  47M     /opt/iobroker/iobroker-data/files/admin.admin
                  52M     /opt/iobroker/iobroker-data/objects.jsonl
                  19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
                  9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                  9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                  USB-Devices by-id:
                  Keine Geräte gefunden 'by-id'
                  No nvbackup.json found.
                  /usr/bin/nodejs         v22.22.2
                  /usr/bin/node           v22.22.2
                  /usr/bin/npm            10.9.7
                  /usr/bin/npx            10.9.7
                  nodejs:
                    Installed: 22.22.2-1nodesource1
                    Candidate: 22.22.2-1nodesource1
                    Version table:
                   *** 22.22.2-1nodesource1 1001
                       18.19.1+dfsg-6ubuntu5 500
                          500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                  Keine bekannten Sicherheitslücken in der Node.js-Version erkannt!
                  ioBroker Status
                  Objects type: jsonl
                  States  type: redis
                  Hosts:
                  ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 89915)
                  admin:          7.8.25
                  javascript:     9.2.2
                  nodejs modules from github:     2
                  +-- iobroker.energiefluss-erweitert@0.8.2 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#89dbb71bf0fc70044249fd6453c25194130d9971)
                  +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                  Adapter State
                  + system.adapter.autodarts.0              : autodarts             : ioBroker                                 -  enabled, port: 3180
                  + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
                  + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                  + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                  + system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
                  + system.adapter.discovergy.0             : discovergy            : ioBroker                                 -  enabled
                  + system.adapter.enpal.0                  : enpal                 : ioBroker                                 -  enabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                    system.adapter.foxesscloud.0            : foxesscloud           : ioBroker                                 - disabled
                  + system.adapter.foxesscloud.1            : foxesscloud           : ioBroker                                 -  enabled
                  + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
                  + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                  + system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
                    system.adapter.ical.4                   : ical                  : ioBroker                                 -  enabled
                  + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                  + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
                  + system.adapter.javascript.2             : javascript            : ioBroker                                 -  enabled
                  + system.adapter.javascript.3             : javascript            : ioBroker                                 -  enabled
                  + system.adapter.javascript.5             : javascript            : ioBroker                                 -  enabled
                  + system.adapter.life360ng.0              : life360ng             : ioBroker                                 -  enabled
                  + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                  + system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : ioBroker                                 - disabled, port: 16021
                  + system.adapter.operating-hours.0        : operating-hours       : ioBroker                                 -  enabled
                  + system.adapter.reolink.5                : reolink               : ioBroker                                 -  enabled
                  + system.adapter.reolink.6                : reolink               : ioBroker                                 -  enabled
                  + system.adapter.reolink.7                : reolink               : ioBroker                                 -  enabled
                  + system.adapter.reolink.8                : reolink               : ioBroker                                 -  enabled
                  + system.adapter.reolink.9                : reolink               : ioBroker                                 -  enabled
                    system.adapter.seq.0                    : seq                   : ioBroker                                 - disabled, port: 443
                    system.adapter.snmp.0                   : snmp                  : ioBroker                                 - disabled
                  + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                    system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
                  + system.adapter.sureflap.0               : sureflap              : ioBroker                                 -  enabled
                  + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tidy.0                   : tidy                  : ioBroker                                 -  enabled
                    system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
                  + system.adapter.trashschedule.1          : trashschedule         : ioBroker                                 -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
                  + system.adapter.wallpanel.0              : wallpanel             : ioBroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 -  enabled, port: 5000
                  + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                  + system.adapter.worx.0                   : worx                  : ioBroker                                 -  enabled
                  + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
                  + instance is alive
                  │ 0       │ 'Beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                  │ 1       │ 'Stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                  Active repo(s): Beta
                  │ 2       │ 'system.adapter.autodarts'              │ 'autodarts'              │ '1.0.8'   │ 'none'         │
                  │ 3       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'  │ 'none'         │
                  │ 4       │ 'system.adapter.bambulab'               │ 'bambulab'               │ '0.4.3'   │ 'none'         │
                  │ 5       │ 'system.adapter.birthdays'              │ 'birthdays'              │ '6.0.0'   │ 'none'         │
                  │ 6       │ 'system.adapter.brightsky'              │ 'brightsky'              │ '1.1.0'   │ 'none'         │
                  │ 7       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.1.2'   │ 'none'         │
                  │ 8       │ 'system.adapter.device-watcher'         │ 'device-watcher'         │ '2.15.15' │ 'none'         │
                  │ 9       │ 'system.adapter.devices'                │ 'devices'                │ '2.0.18'  │ 'none'         │
                  │ 10      │ 'system.adapter.discovergy'             │ 'discovergy'             │ '0.7.0'   │ 'none'         │
                  │ 11      │ 'system.adapter.dwd'                    │ 'dwd'                    │ '2.8.5'   │ 'none'         │
                  │ 12      │ 'system.adapter.echarts'                │ 'echarts'                │ '1.9.2'   │ 'none'         │
                  │ 13      │ 'system.adapter.egigeozone'             │ 'egigeozone'             │ '0.1.2'   │ 'none'         │
                  │ 14      │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'   │ 'none'         │
                  │ 15      │ 'system.adapter.enpal'                  │ 'enpal'                  │ '0.2.0'   │ 'none'         │
                  │ 16      │ 'system.adapter.fb-checkpresence'       │ 'fb-checkpresence'       │ '1.4.2'   │ 'none'         │
                  │ 17      │ 'system.adapter.feiertage'              │ 'feiertage'              │ '1.4.0'   │ 'none'         │
                  │ 18      │ 'system.adapter.foxesscloud'            │ 'foxesscloud'            │ '0.2.3'   │ 'none'         │
                  │ 19      │ 'system.adapter.harmony'                │ 'harmony'                │ '2.1.0'   │ 'none'         │
                  │ 20      │ 'system.adapter.hiob'                   │ 'hiob'                   │ '0.1.7'   │ 'none'         │
                  │ 21      │ 'system.adapter.hmip'                   │ 'hmip'                   │ '1.27.0'  │ 'none'         │
                  │ 22      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'  │ 'none'         │
                  │ 23      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.2'   │ 'none'         │
                  │ 24      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.2'   │ 'none'         │
                  │ 25      │ 'system.adapter.life360ng'              │ 'life360ng'              │ '1.9.0'   │ 'none'         │
                  │ 26      │ 'system.adapter.linux-control'          │ 'linux-control'          │ '1.1.6'   │ 'none'         │
                  │ 27      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'   │ 'none'         │
                  │ 28      │ 'system.adapter.motion'                 │ 'motion'                 │ '0.0.1'   │ 'none'         │
                  │ 29      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'   │ 'none'         │
                  │ 30      │ 'system.adapter.nanoleaf-lightpanels'   │ 'nanoleaf-lightpanels'   │ '1.6.0'   │ 'none'         │
                  │ 31      │ 'system.adapter.operating-hours'        │ 'operating-hours'        │ '1.5.1'   │ 'none'         │
                  │ 32      │ 'system.adapter.owntracks'              │ 'owntracks'              │ '1.1.0'   │ 'none'         │
                  │ 33      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'   │ 'none'         │
                  │ 34      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'   │ 'none'         │
                  │ 35      │ 'system.adapter.rtspstream'             │ 'rtspstream'             │ '0.0.4'   │ 'none'         │
                  │ 36      │ 'system.adapter.seq'                    │ 'seq'                    │ '1.0.2'   │ 'none'         │
                  │ 37      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1'  │ 'none'         │
                  │ 38      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'   │ 'none'         │
                  │ 39      │ 'system.adapter.snmp'                   │ 'snmp'                   │ '3.4.0'   │ 'none'         │
                  │ 40      │ 'system.adapter.socketio'               │ 'socketio'               │ '7.1.3'   │ 'none'         │
                  │ 41      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'   │ 'none'         │
                  │ 42      │ 'system.adapter.sourceanalytix'         │ 'sourceanalytix'         │ '0.4.14'  │ 'none'         │
                  │ 43      │ 'system.adapter.spotify-premium'        │ 'spotify-premium'        │ '2.0.3'   │ 'none'         │
                  │ 44      │ 'system.adapter.statistics'             │ 'statistics'             │ '2.4.0'   │ 'none'         │
                  │ 45      │ 'system.adapter.sureflap'               │ 'sureflap'               │ '3.4.2'   │ 'none'         │
                  │ 46      │ 'system.adapter.tankerkoenig'           │ 'tankerkoenig'           │ '3.4.0'   │ 'none'         │
                  │ 47      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'   │ 'none'         │
                  │ 48      │ 'system.adapter.tidy'                   │ 'tidy'                   │ '0.1.1'   │ 'none'         │
                  │ 49      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'   │ 'none'         │
                  │ 50      │ 'system.adapter.trashschedule'          │ 'trashschedule'          │ '5.3.0'   │ 'none'         │
                  │ 51      │ 'system.adapter.tuya'                   │ 'tuya'                   │ '3.17.0'  │ 'none'         │
                  │ 52      │ 'system.adapter.vis-2'                  │ 'vis-2'                  │ '2.13.19' │ 'none'         │
                  │ 53      │ 'system.adapter.vis-2-widgets-icontwo'  │ 'vis-2-widgets-icontwo'  │ '1.40.0'  │ 'none'         │
                  │ 54      │ 'system.adapter.vis-2-widgets-inventwo' │ 'vis-2-widgets-inventwo' │ '1.0.0'   │ 'none'         │
                  │ 55      │ 'system.adapter.vis-2-widgets-material' │ 'vis-2-widgets-material' │ '1.4.10'  │ 'none'         │
                  │ 56      │ 'system.adapter.vis-icontwo'            │ 'vis-icontwo'            │ '2.11.3'  │ 'none'         │
                  │ 57      │ 'system.adapter.vw-connect'             │ 'vw-connect'             │ '0.8.4'   │ 'none'         │
                  │ 58      │ 'system.adapter.wallpanel'              │ 'wallpanel'              │ '0.3.11'  │ 'none'         │
                  │ 59      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'   │ 'none'         │
                  │ 60      │ 'system.adapter.wiobrowser'             │ 'wiobrowser'             │ '2.0.2'   │ 'none'         │
                  │ 61      │ 'system.adapter.wireless-settings'      │ 'wireless-settings'      │ '1.0.2'   │ 'none'         │
                  │ 62      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'   │ 'none'         │
                  │ 63      │ 'system.adapter.worx'                   │ 'worx'                   │ '3.3.0'   │ 'none'         │
                  │ 64      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'   │ 'none'         │
                  │ 65      │ 'system.adapter.xterm'                  │ 'xterm'                  │ '3.0.2'   │ 'none'         │
                  │ 66      │ 'system.adapter.zigbee'                 │ 'zigbee'                 │ '3.0.1'   │ 'none'         │
                  │ 67      │ 'system.adapter.zigbee2mqtt'            │ 'zigbee2mqtt'            │ '3.2.1'   │ 'none'         │
                  Used repository: Beta
                  Adapter    "autodarts"    : 1.0.8    , installed 1.0.8
                  Adapter    "bambulab"     : 0.4.3    , installed 0.4.3
                  Adapter    "birthdays"    : 6.0.0    , installed 6.0.0
                  Adapter    "brightsky"    : 1.1.0    , installed 1.1.0
                  Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                  Adapter    "device-watcher": 2.15.15 , installed 2.15.15
                  Adapter    "devices"      : 2.0.18   , installed 2.0.18
                  Adapter    "discovergy"   : 0.7.0    , installed 0.7.0
                  Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
                  Adapter    "enpal"        : 0.2.0    , installed 0.2.0
                  Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                  Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
                  Adapter    "foxesscloud"  : 0.2.3    , installed 0.2.3
                  Adapter    "harmony"      : 2.1.0    , installed 2.1.0
                  Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                  Adapter    "life360ng"    : 1.9.0    , installed 1.9.0
                  Adapter    "linux-control": 1.1.5    , installed 1.1.6
                  Adapter    "matter"       : 1.0.0    , installed 1.0.0
                  Adapter    "nanoleaf-lightpanels": 1.6.0, installed 1.6.0
                  Adapter    "operating-hours": 1.5.1  , installed 1.5.1
                  Adapter    "ping"         : 2.2.4    , installed 2.2.4
                  Adapter    "reolink"      : 1.4.2    , installed 1.4.2
                  Adapter    "seq"          : 1.0.2    , installed 1.0.2
                  Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                  Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                  Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                  Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                  Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
                  Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
                  Adapter    "vis-2"        : 2.13.19  , installed 2.13.19
                  Adapter    "vis-2-widgets-icontwo": 1.40.0, installed 1.40.0
                  Adapter    "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0
                  Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                  Adapter    "vw-connect"   : 0.8.4    , installed 0.8.4
                  Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                  Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                  Adapter    "wled"         : 0.9.2    , installed 0.9.2
                  Adapter    "worx"         : 3.3.0    , installed 3.3.0
                  Adapter    "xterm"        : 3.0.2    , installed 3.0.2
                  Adapter    "zigbee2mqtt"  : 3.2.1    , installed 3.2.1
                  Objects and States
                  Objects:        22344
                  States:         23015
                  Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
                  Hit:2 https://apt.grafana.com stable InRelease
                  Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
                  Get:5 https://repos.influxdata.com/debian stable InRelease [6922 B]
                  Hit:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                  Hit:7 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                  Hit:8 https://packages.redis.io/deb noble InRelease
                  Fetched 6922 B in 1s (7773 B/s)
                  udp       UNCONN     0          0                                         0.0.0.0:61991                      0.0.0.0:*         users:(("io.harmony.0",pid=1865,fd=30))
                  udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*         users:(("io.wled.0",pid=3056,fd=22))
                  udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=41))
                  udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=35))
                  udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=38))
                  udp       UNCONN     0          0                                         0.0.0.0:5540                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=45))
                  udp       UNCONN     0          0                                         0.0.0.0:5541                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=37))
                  udp       UNCONN     0          0                                         0.0.0.0:5542                       0.0.0.0:*         users:(("io.matter.0",pid=2558,fd=47))
                  udp       UNCONN     0          0                                         0.0.0.0:6666                       0.0.0.0:*         users:(("io.tuya.0",pid=2110,fd=53))
                  udp       UNCONN     0          0                                         0.0.0.0:6667                       0.0.0.0:*         users:(("io.tuya.0",pid=2110,fd=54))
                  udp       UNCONN     0          0                                      127.0.0.54:domain                     0.0.0.0:*         users:(("systemd-resolve",pid=696,fd=16))
                  udp       UNCONN     0          0                                   127.0.0.53%lo:domain                     0.0.0.0:*         users:(("systemd-resolve",pid=696,fd=14))
                  udp       UNCONN     0          0                          192.168.130.130%enp2s0:bootpc                     0.0.0.0:*         users:(("systemd-network",pid=512,fd=24))
                  udp       UNCONN     0          0                                         0.0.0.0:sunrpc                     0.0.0.0:*         users:(("rpcbind",pid=647,fd=5),("systemd",pid=1,fd=40))
                  udp       UNCONN     0          0                                  172.18.255.255:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=25))
                  udp       UNCONN     0          0                                      172.18.0.1:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=24))
                  udp       UNCONN     0          0                                  172.17.255.255:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=21))
                  udp       UNCONN     0          0                                      172.17.0.1:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=20))
                  udp       UNCONN     0          0                                 192.168.255.255:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=16))
                  udp       UNCONN     0          0                                 192.168.130.130:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=15))
                  udp       UNCONN     0          0                                         0.0.0.0:netbios-ns                 0.0.0.0:*         users:(("nmbd",pid=991,fd=13))
                  udp       UNCONN     0          0                                  172.18.255.255:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=27))
                  udp       UNCONN     0          0                                      172.18.0.1:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=26))
                  udp       UNCONN     0          0                                  172.17.255.255:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=23))
                  udp       UNCONN     0          0                                      172.17.0.1:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=22))
                  udp       UNCONN     0          0                                 192.168.255.255:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=18))
                  udp       UNCONN     0          0                                 192.168.130.130:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=17))
                  udp       UNCONN     0          0                                         0.0.0.0:netbios-dgm                0.0.0.0:*         users:(("nmbd",pid=991,fd=14))
                  udp       UNCONN     0          0                                            [::]:mdns                          [::]:*         users:(("io.matter.0",pid=2558,fd=43))
                  udp       UNCONN     0          0                                            [::]:mdns                          [::]:*         users:(("io.matter.0",pid=2558,fd=42))
                  udp       UNCONN     0          0                                            [::]:mdns                          [::]:*         users:(("io.matter.0",pid=2558,fd=40))
                  udp       UNCONN     0          0                                            [::]:mdns                          [::]:*         users:(("io.matter.0",pid=2558,fd=39))
                  udp       UNCONN     0          0                                            [::]:5540                          [::]:*         users:(("io.matter.0",pid=2558,fd=44))
                  udp       UNCONN     0          0                                            [::]:5541                          [::]:*         users:(("io.matter.0",pid=2558,fd=36))
                  udp       UNCONN     0          0                                            [::]:5542                          [::]:*         users:(("io.matter.0",pid=2558,fd=46))
                  udp       UNCONN     0          0                                            [::]:sunrpc                        [::]:*         users:(("rpcbind",pid=647,fd=7),("systemd",pid=1,fd=42))
                  udp       UNCONN     0          0              [fe80::da9e:f3ff:fe78:3132]%enp2s0:dhcpv6-client                 [::]:*         users:(("systemd-network",pid=512,fd=22))
                  tcp       LISTEN     0          50                                        0.0.0.0:netbios-ssn                0.0.0.0:*         users:(("smbd",pid=1007,fd=31))
                  tcp       LISTEN     0          4096                                      0.0.0.0:ssh                        0.0.0.0:*         users:(("sshd",pid=2422,fd=3),("systemd",pid=1,fd=104))
                  tcp       LISTEN     0          4096                                      0.0.0.0:sunrpc                     0.0.0.0:*         users:(("rpcbind",pid=647,fd=4),("systemd",pid=1,fd=39))
                  tcp       LISTEN     0          4096                                   127.0.0.54:domain                     0.0.0.0:*         users:(("systemd-resolve",pid=696,fd=17))
                  tcp       LISTEN     0          4096                                      0.0.0.0:http                       0.0.0.0:*         users:(("docker-proxy",pid=1323,fd=7))
                  tcp       LISTEN     0          50                                        0.0.0.0:microsoft-ds               0.0.0.0:*         users:(("smbd",pid=1007,fd=30))
                  tcp       LISTEN     0          511                                       0.0.0.0:1885                       0.0.0.0:*         users:(("io.mqtt.0",pid=1949,fd=34))
                  tcp       LISTEN     0          511                                       0.0.0.0:1883                       0.0.0.0:*         users:(("io.sonoff.0",pid=2039,fd=40))
                  tcp       LISTEN     0          511                                       0.0.0.0:1882                       0.0.0.0:*         users:(("io.shelly.0",pid=2271,fd=36))
                  tcp       LISTEN     0          511                                     127.0.0.1:9001                       0.0.0.0:*         users:(("iobroker.js-con",pid=1464,fd=23))
                  tcp       LISTEN     0          4096                                    127.0.0.1:34169                      0.0.0.0:*         users:(("containerd",pid=764,fd=15))
                  tcp       LISTEN     0          511                                     127.0.0.1:redis                      0.0.0.0:*         users:(("redis-server",pid=720,fd=20))
                  tcp       LISTEN     0          4096                                127.0.0.53%lo:domain                     0.0.0.0:*         users:(("systemd-resolve",pid=696,fd=15))
                  tcp       LISTEN     0          50                                           [::]:netbios-ssn                   [::]:*         users:(("smbd",pid=1007,fd=29))
                  tcp       LISTEN     0          4096                                         [::]:ssh                           [::]:*         users:(("sshd",pid=2422,fd=4),("systemd",pid=1,fd=105))
                  tcp       LISTEN     0          4096                                         [::]:sunrpc                        [::]:*         users:(("rpcbind",pid=647,fd=6),("systemd",pid=1,fd=41))
                  tcp       LISTEN     0          4096                                         [::]:http                          [::]:*         users:(("docker-proxy",pid=1330,fd=7))
                  tcp       LISTEN     0          50                                           [::]:microsoft-ds                  [::]:*         users:(("smbd",pid=1007,fd=28))
                  tcp       LISTEN     0          4096                                            *:3000                             *:*         users:(("grafana",pid=1463,fd=26))
                  tcp       LISTEN     0          511                                             *:61991                            *:*         users:(("io.harmony.0",pid=1865,fd=29))
                  tcp       LISTEN     0          511                                         [::1]:redis                         [::]:*         users:(("redis-server",pid=720,fd=21))
                  tcp       LISTEN     0          511                                             *:8087                             *:*         users:(("io.simple-api.0",pid=2722,fd=35))
                  tcp       LISTEN     0          4096                                            *:8086                             *:*         users:(("influxd",pid=946,fd=358))
                  tcp       LISTEN     0          511                                             *:8084                             *:*         users:(("io.ws.0",pid=2881,fd=34))
                  tcp       LISTEN     0          511                                             *:8082                             *:*         users:(("io.web.0",pid=201844,fd=35))
                  tcp       LISTEN     0          511                                             *:tproxy                           *:*         users:(("io.admin.0",pid=1516,fd=39))
                  2026-05-19 07:46:20.939  - info: foxesscloud.1 (431341) terminating
                  2026-05-19 07:46:21.459  - info: host.ioBroker instance system.adapter.foxesscloud.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2026-05-19 07:46:24.912  - info: host.ioBroker instance system.adapter.foxesscloud.1 in version "0.2.3" started with pid 432358
                  2026-05-19 07:46:25.815  - info: foxesscloud.1 (432358) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.foxesscloud, node: v22.22.2, js-controller: 7.1.2
                  2026-05-19 07:46:25.875  - info: foxesscloud.1 (432358) Update interval set to 60 seconds
                  2026-05-19 07:46:46.437  - info: admin.0 (1516) ==> Connected system.user.admin from ::ffff:192.168.150.50
                  2026-05-19 07:57:40.390  - info: shelly.0 (2271) [MQTT] Client Close: 192.168.160.180 (shellypmminig3 / shellypmminig3-d0cf13d26c0c / shellypmminig3#d0cf13d26c0c#1) (false)
                  2026-05-19 07:57:42.471  - info: shelly.0 (2271) [MQTT] Device with client id "shellypmminig3-d0cf13d26c0c" connected from 192.168.160.180!
                  2026-05-19 07:57:43.576  - info: shelly.0 (2271) [MQTT] Device with client id "shellypmminig3-d0cf13d26c0c" initialized.
                  2026-05-19 08:00:00.144  - info: host.ioBroker instance system.adapter.ical.0 in version "1.20.1" started with pid 437844
                  2026-05-19 08:00:02.305  - info: ical.0 (437844) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                  2026-05-19 08:00:03.149  - info: ical.0 (437844) processing URL: Sven https://calendar.google.com/calendar/ical/...entfernt...
                  2026-05-19 08:00:04.180  - info: host.ioBroker instance system.adapter.ical.1 in version "1.20.1" started with pid 437879
                  2026-05-19 08:00:06.004  - info: ical.1 (437879) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                  2026-05-19 08:00:06.750  - info: ical.1 (437879) processing URL: Nicole https://calendar.google.com/calendar/ical/....entfernt....
                  2026-05-19 08:00:08.216  - info: host.ioBroker instance system.adapter.ical.3 in version "1.20.1" started with pid 437912
                  2026-05-19 08:00:08.495  - info: ical.0 (437844) Terminated (NO_ERROR): Without reason
                  2026-05-19 08:00:09.038  - info: host.ioBroker instance system.adapter.ical.0 having pid 437844 terminated with code 0 (NO_ERROR)
                  2026-05-19 08:00:10.002  - info: ical.3 (437912) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                  2026-05-19 08:00:10.590  - info: ical.3 (437912) processing URL: Jannis /basic.ics...entfernt... info: ical.1 (437879) Terminated (NO_ERROR): Without reason
                  2026-05-19 08:00:12.644  - info: host.ioBroker instance system.adapter.ical.1 having pid 437879 terminated with code 0 (NO_ERROR)
                  2026-05-19 08:00:15.713  - info: ical.3 (437912) Terminated (NO_ERROR): Without reason
                  2026-05-19 08:00:16.255  - info: host.ioBroker instance system.adapter.ical.3 having pid 437912 terminated with code 0 (NO_ERROR)
                  MOD-EDIT: private Daten entfernt!
                  EDIT:
                  Falls da jemand etwas komisches entdeckt, Hilfe nehme ich sehr gerne an
                  #TeamInventwo
                  Unsere Adapter:
                  • skvarelS skvarel
                    ========== Langfassung ab hier markieren und kopieren ===========
                    ```bash
                    Script v.2026-05-18
                    *** GRUNDSYSTEM ***
                     Static hostname: ioBroker
                             Chassis: desktop 🖥️
                        Architecture: x86-64
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64bit
                    Systemuptime and Load:
                    CPU threads     : 4
                    *** LEBENSZYKLUS STATUS ***
                    *** ZEIT UND ZEITZONEN ***
                                  NTP service: active
                              RTC in local TZ: no
                    *** User und Gruppen ***
                    User der 'iob diag' aufgerufen hat:
                    pi
                    HOME=/home/pi
                    User der den 'js-controller' ausführt:
                    iobroker
                    HOME=/home/iobroker
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         Unknown
                    Display-Manager:        Not found
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Swap:           4.3G          0B        4.3G
                             7909 M used memory
                             5213 M free memory
                              583 M buffer memory
                             2512 M swap cache
                             4095 M total swap
                                0 M used swap
                             4095 M free swap
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    Es wurden keine kritischen Fehler gefunden
                    *** FILESYSTEM ***
                    Filesystem                        Type   Size  Used Avail Use% Mounted on
                    tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
                    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                    Messages concerning filesystems in dmesg:
                    Show mounted filesystems:
                    TARGET  SOURCE                            FSTYPE OPTIONS
                    /var:
                    5.1G    /var/
                    4.2G    /var/log
                    756M    /var/lib
                    /opt/iobroker/backups:
                    /opt/iobroker/iobroker-data:
                    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                    USB-Devices by-id:
                    USB-Sticks - Vermeide direkte Links zu /dev/tty* in deinen Adapter-Einstellungen,
                    bevorzuge immer die Links 'by-id':
                    *** NodeJS-Installation ***
                    /usr/bin/npm            10.9.7
                    /usr/bin/npx            10.9.7
                    ✓ Node.js ist korrekt installiert
                    nodejs:
                      Version table:
                         22.22.1-1nodesource1 1001
                         22.22.0-1nodesource1 1001
                         22.21.0-1nodesource1 1001
                         22.20.0-1nodesource1 1001
                         22.19.0-1nodesource1 1001
                         22.18.0-1nodesource1 1001
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: redis
                    Hosts:
                    Core adapters versions
                    admin:          7.8.25
                    javascript:     9.2.2
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                    + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                    + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
                      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                    + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                      system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
                      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
                    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    ioBroker-Repositories
                    Objects and States
                    Objects:        22344
                    States:         23015
                    EDIT:
                    #801
                    @skvarel sagte:
                    Da fehlt dir das Paket, das die Daten für die Unterstützungszeiträume bereitstellt. Müsste per
                    iob fix
                    zu beheben sein. Ansonsten von Hand installieren:
                    sudo apt install distro-info distro-info-data
                    skvarelS 1 Antwort Letzte Antwort
                    • S Abwesend
                      S Abwesend
                      Shadowhunter23
                      #802
                      Script v.2026-05-18
                      *** BASE SYSTEM ***
                      Operating System: Debian GNU/Linux 13 (trixie)
                       Static hostname: iobroker
                             Icon name: computer-container
                               Chassis: container ☐
                        Virtualization: lxc
                                Kernel: Linux 7.0.2-4-pve
                      OS is similar to:
                      model name      : Intel(R) Core(TM) i5-10500T CPU @ 2.30GHz
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : 64bit
                       09:49:19 up 1 day, 15:01,  1 user,  load average: 0.16, 0.22, 0.25
                      CPU threads     : 6
                                     Local time: Tue 2026-05-19 09:49:19 CEST
                                 Universal time: Tue 2026-05-19 07:49:19 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      tobias
                      HOME=/home/tobias
                      GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
                      iobroker
                      [sudo] password for tobias:
                      HOME=/home/iobroker
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:             10G        6.3G        4.2G        7.0M        215M        4.4G
                      Swap:           5.4G          0B        5.4G
                      Total:           16G        6.3G        9.6G
                      Active iob-Instances:   52
                              10240 M total memory
                               6014 M used memory
                               5994 M active memory
                                  0 M inactive memory
                               4026 M free memory
                                  0 M buffer memory
                                205 M swap cache
                               5120 M total swap
                                  0 M used swap
                               5120 M free swap
                      top - 09:49:30 up 1 day, 15:01,  1 user,  load average: 0.37, 0.26, 0.27
                      Tasks:  82 total,   3 running,  79 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us,  1.6 sy,  0.0 ni, 82.0 id, 16.4 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  10240.0 total,   4025.3 free,   6015.9 used,    205.2 buff/cache
                      MiB Swap:   5120.0 total,   5120.0 free,      0.0 used.   4224.1 avail Mem
                        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                              SUB    -> The low-level unit activation state, values depend on unit type.
                      1 loaded units listed.
                      dmesg: read kernel buffer failed: Operation not permitted
                      *** FILESYSTEM ***
                      DATA/subvol-400-disk-0 zfs        20G  5.9G   15G  30% /
                      none                   tmpfs     492K  4.0K  488K   1% /dev
                      udev                   devtmpfs   15G     0   15G   0% /dev/tty
                      tmpfs                  tmpfs      16G     0   16G   0% /dev/shm
                      tmpfs                  tmpfs     6.3G  144K  6.3G   1% /run
                      tmpfs                  tmpfs      16G  6.3M   16G   1% /tmp
                      tmpfs                  tmpfs     3.2G   12K  3.2G   1% /run/user/1000
                      /      DATA/subvol-400-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
                      /var:
                      807M    /var/
                      353M    /var/lib
                      299M    /var/cache
                      297M    /var/cache/apt
                      282M    /var/lib/redis
                      Archived and active journals take up 150M in the file system.
                      154M    /opt/iobroker/backups/
                      31M     /opt/iobroker/iobroker-data/
                      20M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                      3.3M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                      2.8M    /opt/iobroker/iobroker-data/objects.jsonl
                      1.2M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-00V6sJFg.js
                      1.2M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                      1.2M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      *** ZigBee Settings ***
                      ⚠ HINT:
                      Your zigbee.0 COM-Port is NOT matching 'by-id'.
                      Please check your setting:
                      tcp
                      ⚠ HINT:
                      Your zigbee.1 COM-Port is NOT matching 'by-id'.
                      tcp
                      ⚠ HINT:
                      Your zigbee.2 COM-Port is NOT matching 'by-id'.
                      tcp
                      ⚠ HINT:
                      Your zigbee.3 COM-Port is NOT matching 'by-id'.
                      tcp
                      ⚠ HINT:
                      Your zigbee.4 COM-Port is NOT matching 'by-id'.
                      tcp
                      Zigbee Network Settings on your coordinator / in nvbackup are:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      zigbee.0        tcp://192.168.0.64:20108            -                                   tcp
                      zigbee.1        tcp://192.168.0.69:20108            -                                   tcp
                      zigbee.2        tcp://192.168.0.79:20108            -                                   tcp
                      zigbee.3        tcp://192.168.0.63:20108            -                                   tcp
                      zigbee.4        tcp://192.168.0.99:20108            -                                   tcp
                      nodejs:
                        Version table:
                              500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages
                              500 http://security.debian.org trixie-security/main amd64 Packages
                              500 http://deb.debian.org/debian trixie/main amd64 Packages
                      ioBroker Status
                      At least one iobroker host is running.
                      Objects type: redis
                      States  type: redis
                      Hosts:
                      iobroker            iobroker (version: 7.1.2, hostname: iobroker      , alive, uptime: 140480)
                      admin:          7.8.20
                      javascript:     9.2.2
                      nodejs modules from github:     6
                      +-- iobroker.ankersolix2@2.4.2 (git+ssh://git@github.com/Brainbug01/ioBroker.ankersolix2.git#0c6503878fee4fb2202dce3dc1270fb5dde93f87)
                      +-- iobroker.awtrix-light@3.0.0 (git+ssh://git@github.com/Brainbug01/ioBroker.awtrix-light.git#3c7bdf2c3842deaab4a7f97d0ee6d424c1248265)
                      +-- iobroker.echarts@3.3.0 (git+ssh://git@github.com/Brainbug01/ioBroker.echarts.git#51f634f3863a91559d6aec3482303f3f9b02bb01)
                      +-- iobroker.fb-checkpresence@1.4.3 (git+ssh://git@github.com/Brainbug01/ioBroker.fb-checkpresence.git#d788eb6899a5d79f51fa2597cd0525d45c025af5)
                      +-- iobroker.pwned-check@0.0.4 (git+ssh://git@github.com/ipod86/ioBroker.pwned-check.git#bcf513feecf5d02108d1d0cf27e08d91fcf91489)
                      | | +-- nan@2.22.0 (git+ssh://git@github.com/JCMais/nan.git#0ec2eca8b2fd7518affb3945d087e393ad839b7e)
                      Adapter State
                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      + system.adapter.ankersolix2.0            : ankersolix2           : iobroker                                 -  enabled
                      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                      + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                      + system.adapter.awtrix-light.2           : awtrix-light          : iobroker                                 -  enabled
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                      + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                      + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1883
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                      + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                      + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                      + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                      + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                      + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                      + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                      + system.adapter.pwned-check.0            : pwned-check           : iobroker                                 -  enabled
                      + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                      + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                      + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                      + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                      + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        system.adapter.vofo-speedtest.0         : vofo-speedtest        : iobroker                                 - disabled
                      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                      + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                      + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                      + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                      + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                      + instance is alive
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      │ 0       │ 'system.adapter.admin'                  │ 'admin'                  │ '7.8.20'  │ 'none'         │
                      │ 2       │ 'system.adapter.ankersolix2'            │ 'ankersolix2'            │ '2.4.2'   │ 'none'         │
                      │ 6       │ 'system.adapter.chromecast'             │ 'chromecast'             │ '4.2.0'   │ 'none'         │
                      │ 7       │ 'system.adapter.cloud'                  │ 'cloud'                  │ '6.0.4'   │ 'none'         │
                      │ 9       │ 'system.adapter.echarts'                │ 'echarts'                │ '3.1.0'   │ 'none'         │
                      │ 10      │ 'system.adapter.email'                  │ 'email'                  │ '2.0.4'   │ 'none'         │
                      │ 11      │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'   │ 'none'         │
                      │ 12      │ 'system.adapter.fb-checkpresence'       │ 'fb-checkpresence'       │ '1.4.3'   │ 'none'         │
                      │ 13      │ 'system.adapter.fritzdect'              │ 'fritzdect'              │ '2.6.2'   │ 'none'         │
                      │ 14      │ 'system.adapter.fullybrowser'           │ 'fullybrowser'           │ '3.1.5'   │ 'none'         │
                      │ 15      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'  │ 'none'         │
                      │ 16      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.2'   │ 'none'         │
                      │ 17      │ 'system.adapter.iot'                    │ 'iot'                    │ '6.0.3'   │ 'none'         │
                      │ 18      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.2'   │ 'none'         │
                      │ 19      │ 'system.adapter.lg-thinq'               │ 'lg-thinq'               │ '1.1.6'   │ 'none'         │
                      │ 21      │ 'system.adapter.mqtt-client'            │ 'mqtt-client'            │ '4.0.0'   │ 'none'         │
                      │ 22      │ 'system.adapter.mytime'                 │ 'mytime'                 │ '2.3.4'   │ 'none'         │
                      │ 23      │ 'system.adapter.netatmo'                │ 'netatmo'                │ '3.1.0'   │ 'none'         │
                      │ 24      │ 'system.adapter.notification-manager'   │ 'notification-manager'   │ '1.3.0'   │ 'none'         │
                      │ 25      │ 'system.adapter.nuki'                   │ 'nuki'                   │ '2.0.0'   │ 'none'         │
                      │ 26      │ 'system.adapter.operating-hours'        │ 'operating-hours'        │ '1.5.1'   │ 'none'         │
                      │ 27      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'   │ 'none'         │
                      │ 28      │ 'system.adapter.pushover'               │ 'pushover'               │ '5.0.0'   │ 'none'         │
                      │ 29      │ 'system.adapter.pvforecast'             │ 'pvforecast'             │ '6.1.0'   │ 'none'         │
                      │ 30      │ 'system.adapter.pwned-check'            │ 'pwned-check'            │ '0.0.4'   │ 'none'         │
                      │ 31      │ 'system.adapter.sayit'                  │ 'sayit'                  │ '5.1.0'   │ 'none'         │
                      │ 32      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1'  │ 'none'         │
                      │ 33      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'   │ 'none'         │
                      │ 34      │ 'system.adapter.socketio'               │ 'socketio'               │ '7.1.3'   │ 'none'         │
                      │ 35      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'   │ 'none'         │
                      │ 36      │ 'system.adapter.text2command'           │ 'text2command'           │ '4.0.0'   │ 'none'         │
                      │ 39      │ 'system.adapter.vis'                    │ 'vis'                    │ '1.5.6'   │ 'none'         │
                      │ 40      │ 'system.adapter.vis-icontwo'            │ 'vis-icontwo'            │ '2.11.3'  │ 'none'         │
                      │ 41      │ 'system.adapter.vis-inventwo'           │ 'vis-inventwo'           │ '4.1.0'   │ 'none'         │
                      │ 42      │ 'system.adapter.vis-materialdesign'     │ 'vis-materialdesign'     │ '0.5.9'   │ 'none'         │
                      │ 43      │ 'system.adapter.vis-timeandweather'     │ 'vis-timeandweather'     │ '1.2.2'   │ 'none'         │
                      │ 44      │ 'system.adapter.vis-weather'            │ 'vis-weather'            │ '2.5.13'  │ 'none'         │
                      │ 45      │ 'system.adapter.vofo-speedtest'         │ 'vofo-speedtest'         │ '2.0.1'   │ 'none'         │
                      │ 46      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'   │ 'none'         │
                      │ 47      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'   │ 'none'         │
                      │ 48      │ 'system.adapter.zigbee'                 │ 'zigbee'                 │ '3.4.5'   │ 'none'         │
                      Adapter    "admin"        : 7.8.25   , installed 7.8.20 [Updatable]
                      Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                      Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.2
                      Adapter    "chromecast"   : 4.2.0    , installed 4.2.0
                      Adapter    "email"        : 2.0.4    , installed 2.0.4
                      Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.3
                      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                      Adapter    "fullybrowser" : 3.1.5    , installed 3.1.5
                      Adapter    "lg-thinq"     : 1.1.6    , installed 1.1.6
                      Adapter    "mqtt-client"  : 4.0.0    , installed 4.0.0
                      Adapter    "mytime"       : 2.3.4    , installed 2.3.4
                      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                      Adapter    "pushover"     : 5.0.0    , installed 5.0.0
                      Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
                      Adapter    "sayit"        : 5.1.0    , installed 5.1.0
                      Adapter    "text2command" : 4.0.0    , installed 4.0.0
                      Adapter    "vis-inventwo" : 4.1.0    , installed 4.1.0
                      Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                      Adapter    "vofo-speedtest": 2.0.1   , installed 2.0.1
                      Objects and States
                      Objects:        16325
                      States:         14307
                      Hit:1 http://security.debian.org trixie-security InRelease
                      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                      Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease
                      Reading package lists... Done
                      *** Listening Ports ***
                      Netid          State           Recv-Q          Send-Q                   Local Address:Port                     Peer Address:Port          Process
                      udp            UNCONN          0               0                              0.0.0.0:mdns                          0.0.0.0:*              users:(("io.chromecast.0",pid=679,fd=35))
                      udp            UNCONN          0               0                              0.0.0.0:coap                          0.0.0.0:*              users:(("io.shelly.0",pid=984,fd=51))
                      udp            UNCONN          0               0                              0.0.0.0:6666                          0.0.0.0:*              users:(("io.tuya.0",pid=1116,fd=40))
                      udp            UNCONN          0               0                              0.0.0.0:6667                          0.0.0.0:*              users:(("io.tuya.0",pid=1116,fd=41))
                      udp            UNCONN          0               0                              0.0.0.0:sunrpc                        0.0.0.0:*              users:(("rpcbind",pid=151,fd=5),("systemd",pid=1,fd=90))
                      udp            UNCONN          0               0                                 [::]:sunrpc                           [::]:*              users:(("rpcbind",pid=151,fd=7),("systemd",pid=1,fd=93))
                      tcp            LISTEN          0               511                          127.0.0.1:redis                         0.0.0.0:*              users:(("redis-server",pid=18534,fd=8))
                      tcp            LISTEN          0               511                      192.168.0.222:9092                          0.0.0.0:*              users:(("io.nuki.0",pid=856,fd=31))
                      tcp            LISTEN          0               100                          127.0.0.1:smtp                          0.0.0.0:*              users:(("master",pid=373,fd=13))
                      tcp            LISTEN          0               511                            0.0.0.0:1883                          0.0.0.0:*              users:(("io.mqtt.0",pid=806,fd=35))
                      tcp            LISTEN          0               511                            0.0.0.0:1882                          0.0.0.0:*              users:(("io.shelly.1",pid=1061,fd=38))
                      tcp            LISTEN          0               4096                           0.0.0.0:sunrpc                        0.0.0.0:*              users:(("rpcbind",pid=151,fd=4),("systemd",pid=1,fd=89))
                      tcp            LISTEN          0               511                                  *:8087                                *:*              users:(("io.simple-api.0",pid=1485,fd=35))
                      tcp            LISTEN          0               511                                  *:tproxy                              *:*              users:(("io.admin.0",pid=399,fd=39))
                      tcp            LISTEN          0               511                                  *:8082                                *:*              users:(("io.web.0",pid=6365,fd=35))
                      tcp            LISTEN          0               511                              [::1]:redis                            [::]:*              users:(("redis-server",pid=18534,fd=9))
                      tcp            LISTEN          0               100                              [::1]:smtp                             [::]:*              users:(("master",pid=373,fd=14))
                      tcp            LISTEN          0               511                                  *:3000                                *:*              users:(("io.fullybrowser",pid=756,fd=30))
                      tcp            LISTEN          0               4096                              [::]:sunrpc                           [::]:*              users:(("rpcbind",pid=151,fd=6),("systemd",pid=1,fd=92))
                      tcp            LISTEN          0               511                                  *:http                                *:*              users:(("apache2",pid=137705,fd=4),("apache2",pid=137704,fd=4),("apache2",pid=208,fd=4))
                      tcp            LISTEN          0               4096                                 *:ssh                                 *:*              users:(("sshd",pid=177,fd=3),("systemd",pid=1,fd=75))
                      2026-05-19 09:33:47.008  - info: web.0 (6365) <== Disconnect system.user.admin from ::ffff:192.168.0.187 vis.0
                      2026-05-19 09:33:47.010  - info: web.0 (6365) <== Disconnect system.user.admin from ::ffff:192.168.0.187 energiefluss-erweitert.0
                      2026-05-19 09:34:12.491  - info: web.0 (6365) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:34:12.519  - info: web.0 (6365) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:34:23.824  - info: web.0 (6365) <== Disconnect system.user.admin from ::ffff:192.168.0.187 energiefluss-erweitert.0
                      2026-05-19 09:34:23.826  - info: web.0 (6365) <== Disconnect system.user.admin from ::ffff:192.168.0.187 vis.0
                      2026-05-19 09:34:25.412  - info: web.0 (6365) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:34:26.170  - info: web.0 (6365) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:34:46.347  - info: web.0 (6365) <== Disconnect system.user.admin from ::ffff:192.168.0.187 vis.0
                      2026-05-19 09:34:46.353  - info: web.0 (6365) <== Disconnect system.user.admin from ::ffff:192.168.0.187 energiefluss-erweitert.0
                      2026-05-19 09:36:18.731  - info: admin.0 (399) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:38:29.596  - info: admin.0 (399) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:38:50.211  - info: admin.0 (399) <== Disconnect system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:38:50.377  - info: admin.0 (399) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:38:53.092  - info: admin.0 (399) <== Disconnect system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:39:02.474  - info: admin.0 (399) <== Disconnect system.user.admin from ::ffff:192.168.0.187 admin
                      2026-05-19 09:40:03.946  - info: zigbee.4 (71752) Device query for '0x54ef4410003a8482' complete
                      2026-05-19 09:40:03.946  - warn: zigbee.4 (71752) Device '0x54ef4410003a8482' announced itself, trying to read its status
                      2026-05-19 09:40:03.946  - info: zigbee.4 (71752) Device query for '0x54ef4410003a8482' started
                      2026-05-19 09:44:16.740  - info: admin.0 (399) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:44:23.127  - info: admin.0 (399) <== Disconnect system.user.admin from ::ffff:192.168.0.187 admin
                      2026-05-19 09:45:35.051  - info: web.0 (6365) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:45:35.824  - info: web.0 (6365) ==> Connected system.user.admin from ::ffff:192.168.0.187
                      2026-05-19 09:45:46.331  - info: web.0 (6365) <== Disconnect system.user.admin from ::ffff:192.168.0.187 energiefluss-erweitert.0
                      2026-05-19 09:45:46.385  - info: web.0 (6365) <== Disconnect system.user.admin from ::ffff:192.168.0.187 vis.0
                      • S Shadowhunter23
                        Script v.2026-05-18
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64bit
                        CPU threads     : 6
                        *** LIFE CYCLE STATUS ***
                        Operating System is the current Debian stable version codenamed 'trixie'!
                        *** TIME AND TIMEZONES ***
                                         RTC time: n/a
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        tobias
                        HOME=/home/tobias
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Session:                tty
                        Boot Target:            multi-user.target
                        *** MEMORY ***
                        Swap:           5.4G          0B        5.4G
                                 6014 M used memory
                                    0 M inactive memory
                                 4026 M free memory
                                    0 M buffer memory
                                  205 M swap cache
                                 5120 M total swap
                                    0 M used swap
                                 5120 M free swap
                        No critical errors detected
                        *** FILESYSTEM ***
                        /var:
                        807M    /var/
                        353M    /var/lib
                        299M    /var/cache
                        297M    /var/cache/apt
                        282M    /var/lib/redis
                        USB-Devices by-id:
                        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                        please always prefer the links 'by-id':
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        ⚠ HINT:
                        tcp
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        === ZigBee Port Overview ===
                        Instance        Configured Port                     Available by-id Port                Status
                        /usr/bin/nodejs         v24.15.0
                        /usr/bin/node           v24.15.0
                        /usr/bin/npm            11.12.1
                        /usr/bin/npx            11.12.1
                        ✓ Node.js installation is correct
                        nodejs:
                          Installed: 24.15.0-1nodesource1
                          Candidate: 24.15.0-1nodesource1
                          Version table:
                         *** 24.15.0-1nodesource1 1001
                             24.14.1-1nodesource1 1001
                             24.14.0-1nodesource1 1001
                             24.13.1-1nodesource1 1001
                             24.13.0-1nodesource1 1001
                             24.12.0-1nodesource1 1001
                             24.11.1-1nodesource1 1001
                             24.11.0-1nodesource1 1001
                             24.10.0-1nodesource1 1001
                             24.9.0-1nodesource1 1001
                             24.8.0-1nodesource1 1001
                             24.7.0-1nodesource1 1001
                             24.6.0-1nodesource1 1001
                             24.5.0-1nodesource1 1001
                             24.4.1-1nodesource1 1001
                             24.4.0-1nodesource1 1001
                             24.3.0-1nodesource1 1001
                             24.1.0-1nodesource1 1001
                             24.0.2-1nodesource1 1001
                             24.0.1-1nodesource1 1001
                             24.0.0-1nodesource1 1001
                             20.19.2+dfsg-1+deb13u2 500
                        No known Vulnerabilities detected!
                        ioBroker Status
                        Objects type: redis
                        States  type: redis
                        Hosts:
                        admin:          7.8.20
                        javascript:     9.2.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        16325
                        States:         14307
                        #803
                        @Shadowhunter23
                        Schön, der Part zu Zigbee funktioniert also noch bzw. wieder.
                        Wenn die Tabelle gesichert auch bei anderen stabil funktioniert schmeiß ich den alten Teil als redundant raus.
                          @Shadowhunter23
                          #804
                          @Thomas-Braun sagte:
                          Wenn die Tabelle
                          Sollen die Ticks da drin zu sehen sein?
                            Wenn die Tabelle
                            #805
                            @Homoran
                            Welche 'Ticks'? Ich meine diese Tabelle:
                              @Homoran
                              #806
                              Oops,
                              ...und ich diese
                              @skvarel sagte:
                              Thomas BraunT skvarelS 2 Antworten Letzte Antwort
                                Oops,
                                ...und ich diese
                                @skvarel sagte:
                                │ (index) │ id                                      │ name                     │ version   │ upgrade policy │
                                │ 0       │ 'system.adapter.admin'                  │ 'admin'                  │ '7.8.25'  │ 'none'         │
                                │ 1       │ 'system.adapter.alexa2'                 │ 'alexa2'                 │ '3.27.4'  │ 'none'         │
                                #807
                                @Homoran
                                Da kann ich nix machen.
                                Das kommt wohl so aus
                                iob list adapters
                                  @skvarel sagte:
                                  iob fix
                                  skvarelS Offline
                                  skvarelS Offline
                                  skvarel
                                  #808
                                  iob fix
                                  Beides gemacht, trotzdem:
                                  #TeamInventwo
                                  Unsere Adapter:
                                  • skvarelS skvarel
                                    iob fix
                                    #809
                                    @skvarel sagte:
                                    Beides gemacht
                                    Nanu? Da muß ich dann wohl doch nochmal in den Code schauen, was da so getrieben wird...
                                    • skvarelS skvarel
                                      iob fix
                                      #810
                                      @skvarel
                                      Kannst du das bitte mal auf englisch laufen lassen? Könnte sein, dass es nur in der --de-Version auftaucht.
                                        @skvarel
                                        skvarelS Offline
                                        skvarelS Offline
                                        skvarel
                                        schrieb am zuletzt editiert von skvarel
                                        #811
                                        @skvarel
                                        Done:
                                        Unknown release codenamed 'noble'. Please check yourself if the Operating System is actively maintained.
                                        #TeamInventwo
                                        Unsere Adapter:
                                        • skvarelS skvarel
                                          @skvarel
                                          Done:
                                          #812
                                          @skvarel
                                          Mist... Dann ist da ein Fehler in der Logik. Muss ich mich heute Abend nochmal dran setzen.
                                          Note to myself:
                                          Niemals AI-Code übernehmen, wenn es eigentlich schon funktioniert...
                                          Never tatsch a running code! :-D
