  4. ioBroker startet jeden Tag neu
35 Beiträge 7 Kommentatoren 1.4k Aufrufe 6 Beobachtet
    thomke67
    kann mir jemand erklären, warum ioBroker jeden Tag einen Restart macht, wenn das Repository neu geladen wurde?
    Nach dem Restart kommt ein Haufen Fehlermeldungen, was recht nervig ist. Was muss ich tun, um das abzustellen?
    ioBroker läuft auf einem Raspi4 mit 4GB und 120GB SSD. Installiert ist weiterhin piVCCU im Container. Das OS ist Trixie.
    Und hier mein Log:
    2026-03-24 11:13:12.261 - info: history.0 (2387) Delete old history /opt/iobroker/history/20250323/history.fb-checkpresence.0.familyMembers.Thomas.presence.json
    2026-03-24 11:13:28.340 - info: admin.0 (2369) Adapter rating updated
    2026-03-24 11:13:43.027 - info: admin.0 (2369) ==> Connected system.user.admin from ::ffff:192.xxx.xxx.xx
    2026-03-24 11:14:15.622 - info: admin.0 (2369) Request actual repository...
    2026-03-24 11:14:16.796 - info: host.raspberrypi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2026-03-24 11:14:26.697 - info: admin.0 (2369) Repository received successfully.
    2026-03-24 11:17:02.186 - info: host.raspberrypi iobroker.js-controller version 7.0.7 js-controller starting
    2026-03-24 11:17:02.193 - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2026-03-24 11:17:02.195 - info: host.raspberrypi hostname: raspberrypi, node: v22.22.1
    2026-03-24 11:17:02.196 - info: host.raspberrypi ip addresses: 192.xxx.xxx.xx fd4f:3bf0:a6.......e80::dea6:32ff:fe47:92b6
    2026-03-24 11:17:04.740 - info: host.raspberrypi connected to Objects and States
    2026-03-24 11:17:04.784 - info: host.raspberrypi added notifications configuration of host
    2026-03-24 11:17:05.913 - info: host.raspberrypi 51 instances found
    2026-03-24 11:17:06.003 - info: host.raspberrypi starting 39 instances
    2026-03-24 11:17:07.091 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
    2026-03-24 11:17:07.369 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
    2026-03-24 11:17:07.387 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
    2026-03-24 11:17:07.452 - info: host.raspberrypi instance system.adapter.admin.0 in version "7.7.22" started with pid 1806
    2026-03-24 11:17:07.464 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
    2026-03-24 11:17:07.517 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
    2026-03-24 11:17:07.569 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
    2026-03-24 11:17:07.620 - info: host.raspberrypi Some obsolete host states deleted.
    2026-03-24 11:17:10.999 - info: host.raspberrypi instance system.adapter.history.0 in version "3.0.1" started with pid 2013
    2026-03-24 11:17:12.750 - error: admin.0 (1806) admin.0 already running
    2026-03-24 11:17:12.755 - warn: admin.0 (1806) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:13.533 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:13.533 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2026-03-24 11:17:13.921 - error: history.0 (2013) history.0 already running
    2026-03-24 11:17:13.925 - warn: history.0 (2013) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:14.892 - info: host.raspberrypi instance system.adapter.javascript.0 in version "9.0.18" started with pid 2032
    2026-03-24 11:17:15.050 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:15.051 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
    2026-03-24 11:17:18.962 - info: host.raspberrypi instance system.adapter.scenes.0 in version "3.2.3" started with pid 2049
    2026-03-24 11:17:19.163 - error: javascript.0 (2032) javascript.0 already running
    2026-03-24 11:17:19.168 - warn: javascript.0 (2032) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:19.901 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:19.902 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2026-03-24 11:17:21.405 - error: scenes.0 (2049) scenes.0 already running
    2026-03-24 11:17:21.409 - warn: scenes.0 (2049) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:22.123 - error: host.raspberrypi instance system.adapter.scenes.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:22.124 - info: host.raspberrypi Restart adapter system.adapter.scenes.0 because enabled
    2026-03-24 11:17:23.008 - info: host.raspberrypi instance system.adapter.telegram.0 in version "4.1.0" started with pid 2170
    2026-03-24 11:17:27.039 - info: host.raspberrypi instance system.adapter.whatsapp-cmb.0 in version "0.3.0" started with pid 2242
    2026-03-24 11:17:27.333 - error: telegram.0 (2170) telegram.0 already running
    2026-03-24 11:17:27.339 - warn: telegram.0 (2170) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:28.079 - error: host.raspberrypi Caught by controller[0]: (node:2170) [DEP0040] DeprecationWarning: The punycode module is deprecated. Please use a userland alternative instead.
    2026-03-24 11:17:28.079 - error: host.raspberrypi Caught by controller[0]: (Use node --trace-deprecation ... to show where the warning was created)
    2026-03-24 11:17:28.080 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:28.081 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    2026-03-24 11:17:31.181 - info: host.raspberrypi instance system.adapter.backitup.0 in version "3.3.14" started with pid 2266
    2026-03-24 11:17:31.627 - error: whatsapp-cmb.0 (2242) whatsapp-cmb.0 already running
    2026-03-24 11:17:31.636 - warn: whatsapp-cmb.0 (2242) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:32.396 - error: host.raspberrypi Caught by controller[0]: (node:2242) [DEP0040] DeprecationWarning: The punycode module is deprecated. Please use a userland alternative instead.
    2026-03-24 11:17:32.397 - error: host.raspberrypi Caught by controller[0]: (Use node --trace-deprecation ... to show where the warning was created)
    2026-03-24 11:17:32.398 - error: host.raspberrypi instance system.adapter.whatsapp-cmb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:32.399 - info: host.raspberrypi Restart adapter system.adapter.whatsapp-cmb.0 because enabled
    2026-03-24 11:17:35.655 - info: host.raspberrypi instance system.adapter.alexa2.0 in version "3.27.4" started with pid 2288
    2026-03-24 11:17:36.274 - error: backitup.0 (2266) backitup.0 already running
    2026-03-24 11:17:36.300 - warn: backitup.0 (2266) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:37.249 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:37.250 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
    2026-03-24 11:17:39.361 - info: host.raspberrypi instance system.adapter.cloud.0 in version "5.0.1" started with pid 2306
    2026-03-24 11:17:40.614 - error: alexa2.0 (2288) alexa2.0 already running
    2026-03-24 11:17:40.634 - warn: alexa2.0 (2288) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:41.460 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:41.463 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
    2026-03-24 11:17:43.500 - info: host.raspberrypi instance scheduled system.adapter.feiertage.0 0 3 3 * * *
    2026-03-24 11:17:43.538 - info: host.raspberrypi instance system.adapter.feiertage.0 in version "1.3.0" started with pid 2369
    2026-03-24 11:17:45.060 - info: host.raspberrypi instance system.adapter.admin.0 in version "7.7.22" started with pid 2380
    2026-03-24 11:17:48.385 - error: cloud.0 (2306) cloud.0 already running
    2026-03-24 11:17:48.392 - warn: cloud.0 (2306) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-03-24 11:17:48.411 - info: host.raspberrypi instance system.adapter.history.0 in version "3.0.1" started with pid 2400
    2026-03-24 11:17:48.682 - info: host.raspberrypi instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 2408
    2026-03-24 11:17:49.244 - error: host.raspberrypi instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-03-24 11:17:49.248 - info: host.raspberrypi Restart adapter system.adapter.cloud.0 because enabled
    2026-03-24 11:17:51.164 - info: feiertage.0 (2369) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v22.22.1, js-controller: 7.0.7
    2026-03-24 11:17:56.796 - info: host.raspberrypi instance system.adapter.javascript.0 in version "9.0.18" started with pid 2486
    2026-03-24 11:17:57.031 - info: host.raspberrypi instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 2493
    2026-03-24 11:17:57.174 - info: host.raspberrypi instance system.adapter.scenes.0 in version "3.2.3" started with pid 2501
    2026-03-24 11:17:57.611 - info: host.raspberrypi instance system.adapter.hm-rpc.1 in version "2.0.2" started with pid 2509
    2026-03-24 11:17:57.810 - error: hm-rega.0 (2408) hm-rega.0 already running
    usw.
    Gruß,
    Thomas
    • Adaptername: Javascript
    • Link zu Adapterrepository: Stable
    • Adapterversion: 9.0.18
    • js-controller Version: ...
    • Admin Version: 7.7.22
    • Hardwaresystem: Pi4
    • Arbeitsspeicher: 4GB
    • Festplattenart: 120GB SSD
    • Betriebssystem: Trixie
    • Nodejs-Version: v22.22.0
    • NPM-Version: 10.9.4
    • Installationsart: Manuell
    • Image, Docker genutzt: Nein, aber Container für Homematic (pivCCU)
    • Ort, Name der Imagedatei: ...
    Linux User bitte hier den Output von iob diag einfügen.
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.75+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     10:15:28 up 1 day, 11:17,  1 user,  load average: 0.95, 0.77, 0.66
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-04-13 10:15:29 CEST
               Universal time: Mon 2026-04-13 08:15:29 UTC
                     RTC time: Mon 2026-04-13 08:15:29
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    thomas
    HOME=/home/thomas
    GROUPS=thomas adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/thomas
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        3.2G        231M        4.4M        624M        765M
    Swap:           209M        207M        1.9M
    Total:          4.2G        3.4G        233M
    Active iob-Instances:   32
             3795 M total memory
             3065 M used memory
             1983 M active memory
             1393 M inactive memory
              220 M free memory
               91 M buffer memory
              504 M swap cache
              199 M total swap
              198 M used swap
                1 M free swap
    top - 10:15:29 up 1 day, 11:17,  1 user,  load average: 0.95, 0.77, 0.66
    Tasks: 241 total,   4 running, 237 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 27.7 us,  4.3 sy,  0.0 ni, 66.0 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.7 total,    219.8 free,   3066.0 used,    596.4 buff/cache
    MiB Swap:    200.0 total,      1.9 free,    198.1 used.    729.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    3 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M   11M  749M   2% /run
    /dev/sda2      ext4      110G  7.3G   97G   8% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.9G  3.2M  1.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/sda1      vfat      510M   76M  435M  15% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     380M  8.0K  380M   1% /run/user/1000
    [Sat Apr 11 22:57:57 2026] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Sat Apr 11 22:58:28 2026] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.4G    /var/
    867M    /var/lib
    676M    /var/lib/piVCCU3
    620M    /var/lib/piVCCU3/rootfs
    288M    /var/lib/piVCCU3/rootfs/opt
    Archived and active journals take up 126.8M in the file system.
    /opt/iobroker/backups:
    41M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    431M    /opt/iobroker/iobroker-data/
    298M    /opt/iobroker/iobroker-data/files
    102M    /opt/iobroker/iobroker-data/backup-objects
    56M     /opt/iobroker/iobroker-data/files/mytime.admin/custom
    32M     /opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    13M     /opt/iobroker/iobroker-data/states.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    The current Node.js version (v22.22.0) is vulnerable to the following CVEs:
    CVE-2026-21637(high): A flaw in Node.js TLS error handling leaves `SNICallback` invocations unprotected against synchronous exceptions, while the equivalent ALPN and PSK callbacks were already addressed in CVE-2026-21637. This represents an incomplete fix of that prior vulnerability.
    When an `SNICallback` throws synchronously on unexpected input the exception bypasses TLS error handlers and propagates as an uncaught exception, crashing the Node.js process.
    * This vulnerability affects all Node.js versions that received the CVE-2026-21637 fix, including **20.x, 22.x, 24.x, and 25.x**, on any TLS server where `SNICallback` may throw on unexpected `servername` input.
    Patched versions: ^20.20.2 || ^22.22.2 || ^24.14.1 || ^25.8.2
    CVE-2026-21710(high): A flaw in Node.js HTTP request handling causes an uncaught `TypeError` when a request is received with a header named `__proto__` and the application accesses `req.headersDistinct`.
    When this occurs, `dest["__proto__"]` resolves to `Object.prototype` rather than `undefined`, causing `.push()` to be called on a non-array. This exception is thrown synchronously inside a property getter and cannot be intercepted by `error` event listeners, meaning it cannot be handled without wrapping every `req.headersDistinct` access in a `try/catch`.
    * This vulnerability affects all Node.js HTTP servers on **20.x, 22.x, 24.x, and v25.x**
    CVE-2026-21713(medium): A flaw in Node.js HMAC verification uses a non-constant-time comparison when validating user-provided signatures, potentially leaking timing information proportional to the number of matching bytes. Under certain threat models where high-resolution timing measurements are possible, this behavior could be exploited as a timing oracle to infer HMAC values.
    Node.js already provides timing-safe comparison primitives used elsewhere in the codebase, indicating this is an oversight rather than an intentional design decision.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x**.
    CVE-2026-21714(medium): A memory leak occurs in Node.js HTTP/2 servers when a client sends WINDOW_UPDATE frames on stream 0 (connection-level) that cause the flow control window to exceed the maximum value of 2³¹-1. The server correctly sends a GOAWAY frame, but the Http2Session object is never cleaned up.
    This vulnerability affects HTTP2 users on Node.js 20, 22, 24 and 25.
    CVE-2026-21715(low): A flaw in Node.js Permission Model filesystem enforcement leaves `fs.realpathSync.native()` without the required read permission checks, while all comparable filesystem functions correctly enforce them.
    As a result, code running under `--permission` with restricted `--allow-fs-read` can still use `fs.realpathSync.native()` to check file existence, resolve symlink targets, and enumerate filesystem paths outside of permitted directories.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-read` is intentionally restricted.
    CVE-2026-21716(low): An incomplete fix for CVE-2024-36137 leaves `FileHandle.chmod()` and `FileHandle.chown()` in the promises API without the required permission checks, while their callback-based equivalents (`fs.fchmod()`, `fs.fchown()`) were correctly patched.
    As a result, code running under `--permission` with restricted `--allow-fs-write` can still use promise-based `FileHandle` methods to modify file permissions and ownership on already-open file descriptors, bypassing the intended write restrictions.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-write` is intentionally restricted.
    CVE-2026-21717(medium): A flaw in V8's string hashing mechanism causes integer-like strings to be hashed to their numeric value, making hash collisions trivially predictable. By crafting a request that causes many such collisions in V8's internal string table, an attacker can significantly degrade performance of the Node.js process.
    The most common trigger is any endpoint that calls `JSON.parse()` on attacker-controlled input, as JSON parsing automatically internalizes short strings into the affected hash table.
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 127024)
    Core adapters versions
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.1       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
    + system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mytime.0                 : mytime                : raspberrypi                              -  enabled
    + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
    + system.adapter.panasonic-viera.0        : panasonic-viera       : raspberrypi                              -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.tr-064.1                 : tr-064                : raspberrypi                              - disabled
    + system.adapter.tr-064.2                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
    + system.adapter.wallpanel.0              : wallpanel             : raspberrypi                              -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "ical"         : 1.19.7   , installed 1.19.7
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "mytime"       : 2.3.2    , installed 2.3.2
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
    Adapter    "pegelalarm"   : 1.3.12   , installed 1.3.12
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "rpi2"         : 3.0.2    , installed 2.4.0  [Updatable]
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        11945
    States:         10544
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending systemupdates: 22
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8529       1271/exim4
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          9255       1088/dnsmasq
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8540       932/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8533       932/iobroker.js-con
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11725      2981/io.mqtt.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7114       940/sshd: /usr/sbin
    tcp        0      0 192.168.178.101:2001    0.0.0.0:*               LISTEN      1001       13692      2913/io.hm-rpc.0
    tcp        0      0 192.168.178.101:2010    0.0.0.0:*               LISTEN      1001       13698      2925/io.hm-rpc.1
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8530       1271/exim4
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14091      3434/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11388      2356/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7116       940/sshd: /usr/sbin
    tcp6       0      0 fc42:5009:ba4b:5ab0::53 :::*                    LISTEN      0          9257       1088/dnsmasq
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12222      3453/io.homekit-con
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6701       563/avahi-daemon: r
    udp        0      0 0.0.0.0:54747           0.0.0.0:*                           104        6703       563/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11842      3152/io.shelly.0
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          9254       1088/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          9250       1088/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          7334       859/dhclient
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       13228      3208/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       13229      3208/io.tuya.0
    udp6       0      0 :::5353                 :::*                                104        6702       563/avahi-daemon: r
    udp6       0      0 :::38797                :::*                                104        6704       563/avahi-daemon: r
    udp6       0      0 fc42:5009:ba4b:5ab0::53 :::*                                0          9256       1088/dnsmasq
    2026-04-13 10:00:25.617  - info: host.raspberrypi instance system.adapter.pegelalarm.0 having pid 175520 terminated with code 0 (NO_ERROR)
    2026-04-13 10:00:35.162  - warn: javascript.0 (2441) script.js.Warnungen.Warnungs-Ansage: LautstärkeEchoPlusVolume 40;  LautstärkeEchoPlus  50
    2026-04-13 10:00:35.163  - warn: javascript.0 (2441) script.js.Warnungen.Warnungs-Ansage: Die Steckdose für die Waschmaschine wurde eingeschaltet.
    2026-04-13 10:00:43.168  - warn: javascript.0 (2441) script.js.Warnungen.Warnungs-Ansage: LautstärkeEchoPlusVolume zurück auf 40
    2026-04-13 10:06:18.037  - warn: javascript.0 (2441) script.js.Warnungen.Waschmaschine: Waschmaschine eingeschaltet. Power: 30.9 Watt.
    2026-04-13 10:08:56.479  - info: admin.0 (2356) ==> Connected system.user.admin from ::ffff:192.168.178.21
    2026-04-13 10:09:53.320  - info: history.0 (2372) Delete old history "/opt/iobroker/history/20260311/history.alias.0.Waschküche.Waschmaschine.Power.json"
    2026-04-13 10:09:53.322  - info: history.0 (2372) Delete old history "/opt/iobroker/history/20260312/history.alias.0.Waschküche.Waschmaschine.Power.json"
    2026-04-13 10:09:53.367  - info: history.0 (2372) Delete old history "/opt/iobroker/history/20260110/history.tankerkoenig.0.stations.3.diesel.feed.json"
    2026-04-13 10:10:00.041  - warn: javascript.0 (2441) script.js.Warnungen.Automatiken_abfragen: Alle Automatiken laufen!
    2026-04-13 10:11:24.042  - info: host.raspberrypi instance system.adapter.yr.0 in version "5.3.0" started with pid 176497
    2026-04-13 10:11:27.207  - info: yr.0 (176497) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v22.22.0, js-controller: 7.0.7
    2026-04-13 10:11:27.239  - info: yr.0 (176497) longitude/longitude not set, get data from system
    2026-04-13 10:11:27.277  - info: yr.0 (176497) system latitude: 51.5852404 longitude: 8.06143603824582
    2026-04-13 10:12:01.781  - info: yr.0 (176497) Data updated.
    2026-04-13 10:12:01.783  - info: yr.0 (176497) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-04-13 10:12:02.344  - info: host.raspberrypi instance system.adapter.yr.0 having pid 176497 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-04-13 10:15:08.041  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 176882
    2026-04-13 10:15:11.184  - info: dwd.0 (176882) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.0.7
    2026-04-13 10:15:11.807  - info: dwd.0 (176882) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-04-13 10:15:12.068  - info: host.raspberrypi instance system.adapter.pegelalarm.0 in version "1.3.12" started with pid 176900
    2026-04-13 10:15:12.355  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 176882 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-04-13 10:15:15.206  - info: pegelalarm.0 (176900) starting. Version 1.3.12 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v22.22.0, js-controller: 7.0.7
    2026-04-13 10:15:24.387  - info: pegelalarm.0 (176900) Terminated (NO_ERROR): Without reason
    2026-04-13 10:15:24.940  - info: host.raspberrypi instance system.adapter.pegelalarm.0 having pid 176900 terminated with code 0 (NO_ERROR)
    Gruß,
    Thomas
    • T thomke67
      Und hier mein Log:
      usw.
      Gruß,
      Thomas
      Script v.2026-01-31
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      thomas
      HOME=/home/thomas
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               3795 M total memory
               3065 M used memory
                220 M free memory
                 91 M buffer memory
                504 M swap cache
                199 M total swap
                198 M used swap
                  1 M free swap
      *** FILESYSTEM ***
      /var:
      1.4G    /var/
      867M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.22
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11945
      States:         10544
      HomoranH Offline
      HomoranH Offline
      @thomke67 sagte:
      Bitte updaten!
      Wenn dann immer noch
      @thomke67 sagte:
      Mit allen Sicherheitslücken läuft, ein iob nodejs-update 22 hinterher
        thomke67
        Alles gemacht. Danke für den Hinweis. Jetzt nochmal ein iob diag log oder abwarten?
        Gruß,
        Thomas
        • T thomke67
          HomoranH Offline
          HomoranH Offline
          @thomke67 sagte:
          Bitte!
          Sonst ieht man ja nicht, ob und was sich geändert hat
            thomke67
            Bitte schön:
            Script v.2026-01-31
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
             10:56:26 up 20 min,  1 user,  load average: 1.09, 1.18, 1.24
            CPU threads: 4
            Current issues:
                           Local time: Mon 2026-04-13 10:56:26 CEST
                       Universal time: Mon 2026-04-13 08:56:26 UTC
                             RTC time: Mon 2026-04-13 08:56:26
                          NTP service: active
                      RTC in local TZ: no
            thomas
            HOME=/home/thomas
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:            4.0G        3.0G        411M        8.1M        669M        987M
            Swap:           209M        6.3M        203M
            Total:          4.2G        3.0G        615M
                     3795 M total memory
                     2853 M used memory
                     1919 M active memory
                     1294 M inactive memory
                      392 M free memory
                       43 M buffer memory
                      595 M swap cache
                      199 M total swap
                        6 M used swap
                      193 M free swap
            top - 10:56:27 up 20 min,  1 user,  load average: 1.09, 1.17, 1.23
            Tasks: 246 total,   2 running, 244 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  2.0 us,  4.0 sy,  0.0 ni, 92.0 id,  2.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3795.7 total,    391.4 free,   2854.7 used,    639.3 buff/cache
            MiB Swap:    200.0 total,    194.0 free,      6.0 used.    941.0 avail Mem
            *** FILESYSTEM ***
            /dev/sda2      ext4      110G  7.4G   97G   8% /
            tmpfs          tmpfs     1.9G  3.0M  1.9G   1% /tmp
            [Mon Apr 13 10:35:53 2026] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
            [Mon Apr 13 10:36:24 2026] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
            /var:
            1.4G    /var/
            867M    /var/lib
            Archived and active journals take up 127.1M in the file system.
            451M    /opt/iobroker/iobroker-data/
            300M    /opt/iobroker/iobroker-data/files
            32M     /opt/iobroker/iobroker-data/objects.jsonl
            20M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            /usr/bin/nodejs         v22.22.2
            /usr/bin/node           v22.22.2
            /usr/bin/npm            10.9.7
            /usr/bin/npx            10.9.7
            nodejs:
              Installed: 22.22.2-1nodesource1
              Candidate: 22.22.2-1nodesource1
              Version table:
             *** 22.22.2-1nodesource1 1001
                 22.22.1-1nodesource1 1001
                 20.19.2+dfsg-1 500
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 1208)
            admin:          7.7.22
            javascript:     9.0.18
            Adapter State
            + instance is alive
            Adapter    "history"      : 4.0.0    , installed 4.0.0
            Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
            Objects and States
            Objects:        11942
            States:         10551
            Pending systemupdates: 0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8492       1125/sshd: /usr/sbi
            tcp        0      0 192.168.178.101:2010    0.0.0.0:*               LISTEN      1001       10958      2678/io.hm-rpc.1
            tcp        0      0 192.168.178.101:2001    0.0.0.0:*               LISTEN      1001       10071      2618/io.hm-rpc.0
            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          8546       1295/dnsmasq
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6956       1080/iobroker.js-co
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6973       1080/iobroker.js-co
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       12402      2955/io.mqtt.0
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6944       1416/exim4
            tcp6       0      0 :::22                   :::*                    LISTEN      0          8498       1125/sshd: /usr/sbi
            tcp6       0      0 fc42:5009:ba4b:5ab0::53 :::*                    LISTEN      0          8548       1295/dnsmasq
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6945       1416/exim4
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15605      3397/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8900       1939/io.admin.0
            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          8545       1295/dnsmasq
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          8541       1295/dnsmasq
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          5828       1005/dhclient
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       12680      3149/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       12681      3149/io.tuya.0
            udp        0      0 0.0.0.0:52403           0.0.0.0:*                           104        7236       581/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       13134      3491/io.homekit-con
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7234       581/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       12556      3071/io.shelly.0
            udp6       0      0 fc42:5009:ba4b:5ab0::53 :::*                                0          8547       1295/dnsmasq
            udp6       0      0 :::45163                :::*                                104        7237       581/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        7235       581/avahi-daemon: r
            2026-04-13 10:45:58.325  - info: pegelalarm.0 (4446) starting. Version 1.3.12 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v22.22.2, js-controller: 7.0.7
            2026-04-13 10:45:59.054  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 4466
            2026-04-13 10:46:02.372  - info: dwd.0 (4466) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.2, js-controller: 7.0.7
            2026-04-13 10:46:03.084  - info: dwd.0 (4466) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2026-04-13 10:46:03.633  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 4466 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2026-04-13 10:46:08.185  - info: pegelalarm.0 (4446) Terminated (NO_ERROR): Without reason
            2026-04-13 10:46:08.725  - info: host.raspberrypi instance system.adapter.pegelalarm.0 having pid 4446 terminated with code 0 (NO_ERROR)
            2026-04-13 10:46:22.602  - warn: fb-checkpresence.0 (3282) getAllFbObjects: Hostname of fritzbox device 92:1D:54:C3:FA:5D is empty!
            2026-04-13 10:46:22.608  - warn: fb-checkpresence.0 (3282) getAllFbObjects: To delete this device in the fritzbox please add the device manually in the fritzbox with a hostname and the shown mac-address. After a reboot you can hopefully delete the device.
            2026-04-13 10:51:00.034  - info: tr-064.0 (3093) Scheduled restart.
            2026-04-13 10:51:00.085  - info: tr-064.0 (3093) terminating
            2026-04-13 10:51:00.088  - info: tr-064.0 (3093) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2026-04-13 10:51:00.543  - info: tr-064.0 (3093) terminating
            2026-04-13 10:51:00.787  - info: host.raspberrypi instance system.adapter.tr-064.0 scheduled normal terminated and will be restarted on schedule.
            2026-04-13 10:51:00.788  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2026-04-13 10:51:02.753  - info: host.raspberrypi instance system.adapter.tr-064.0 in version "4.3.0" started with pid 5219
            2026-04-13 10:51:06.211  - info: tr-064.0 (5219) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v22.22.2, js-controller: 7.0.7
            2026-04-13 10:53:31.045  - warn: javascript.0 (2175) script.js.System.Fenster_und_Türen_zählen: Verschluss gestartet
            2026-04-13 10:56:54.036  - info: host.raspberrypi instance system.adapter.yr.0 in version "5.3.0" started with pid 6273
            2026-04-13 10:56:57.863  - info: yr.0 (6273) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v22.22.2, js-controller: 7.0.7
            2026-04-13 10:56:57.900  - info: yr.0 (6273) longitude/longitude not set, get data from system
            2026-04-13 10:56:57.945  - info: yr.0 (6273) system latitude: 51.5852404 longitude: 8.06143603824582
            2026-04-13 10:57:26.326  - info: yr.0 (6273) Data updated.
            2026-04-13 10:57:26.330  - info: yr.0 (6273) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2026-04-13 10:57:26.877  - info: host.raspberrypi instance system.adapter.yr.0 having pid 6273 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            Gruß,
            Thomas
            • T thomke67
              Bitte schön:
              Script v.2026-01-31
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                            NTP service: active
                        RTC in local TZ: no
              thomas
              HOME=/home/thomas
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       3795 M total memory
                       2853 M used memory
                        392 M free memory
                         43 M buffer memory
                        595 M swap cache
                        199 M total swap
                          6 M used swap
                        193 M free swap
              *** FILESYSTEM ***
              /var:
              1.4G    /var/
              867M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.9.7
              /usr/bin/npx            10.9.7
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.22
              javascript:     9.0.18
              Adapter State
              + instance is alive
              Objects and States
              Objects:        11942
              States:         10551
              HomoranH Offline
              HomoranH Offline
              @thomke67 sagte:
              Was ist denn da los?
              Zeig das mal.
              Nicht dass ich damit was anfangen kann, aber vielleicht @thomas-braun
                thomke67
                [Mon Apr 13 10:35:53 2026] systemd[1]: Legacy cgroup v1 configured. This will stop being supported soon.
                [Mon Apr 13 10:35:53 2026] systemd[1]: Will proceed with cgroup v2 after 30 s.
                [Mon Apr 13 10:35:53 2026] systemd[1]: Set systemd.unified_cgroup_hierarchy=1 to switch to cgroup v2 or set SYSTEMD_CGROUP_ENABLE_LEGACY_FORCE=1 to reenable v1 temporarily.
                MOD-EDIT:Code in code-tags gesetzt!
                Gruß,
                Thomas
                • T thomke67
                  @thomke67
                  Dir könnte der Arbeitsspeicher ausgehen. 32 Instanzen ioBroker + piVCCU eingedost, da bleibt dann nix mehr übrig, wenn RAM-hungrige Dinge wie ein Backup laufen.
                  Im Dauerbetrieb sieht man das hier ganz gut:
                  *** MEMORY ***
                  765M verfügbar ist halt schnell weggeschnupft.
                  Das System stoppt dann aus 'Selbsterhaltungstrieb' unnötige Speicherfresser wie den ioBroker erstmal.
                  Kiste updaten:
                    @thomke67
                    *** MEMORY ***
                    Kiste updaten:
                    thomke67
                    @Thomas-Braun sagte:
                    Kiste updaten:
                    Das ist passiert
                    Gruß,
                    Thomas
                      thomke67
                      weil ich nichts weiter hier lese, wollte ich mal nachfragen, ob es mir als einzigem so geht.
                      Jeden Tag zu unterschiedlichen Zeiten wird das Repository neu geladen und dann geht das Drama los. Alles startet durch. Hier der Ausschnitt eines Logs von heute.
                      Ich habe verstanden, dass mein System an der Grenze liegt, aber ich habe auch beobachtet, dass dies erst seit dem Update zu Trixie passiert. Ist da ein Zusammenhang?
                      Ansonsten habe ich über Jahre nichts Neues installiert und nie das Problem gehabt.
                      2026-05-05 20:05:36.110 - info: admin.0 (2232) Request actual repository...
                      2026-05-05 20:05:37.801 - info: host.raspberrypi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                      2026-05-05 20:07:49.123 - info: host.raspberrypi iobroker.js-controller version 7.0.7 js-controller starting
                      2026-05-05 20:07:49.130 - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                      2026-05-05 20:07:49.132 - info: host.raspberrypi hostname: raspberrypi, node: v22.22.2
                      2026-05-05 20:07:49.133 - info: host.raspberrypi ip addresses: 192.xxx.xxx.101 fd4f:3bf0:a698:0:dea6:3xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                      2026-05-05 20:07:52.112 - info: host.raspberrypi connected to Objects and States
                      2026-05-05 20:07:52.157 - info: host.raspberrypi added notifications configuration of host
                      2026-05-05 20:07:53.178 - info: host.raspberrypi 50 instances found
                      2026-05-05 20:07:53.258 - info: host.raspberrypi starting 38 instances
                      2026-05-05 20:07:54.404 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                      2026-05-05 20:07:54.610 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                      2026-05-05 20:07:54.626 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                      2026-05-05 20:07:54.691 - info: host.raspberrypi instance system.adapter.admin.0 in version "7.7.22" started with pid 1806
                      2026-05-05 20:07:54.702 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                      2026-05-05 20:07:54.755 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                      2026-05-05 20:07:54.809 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                      2026-05-05 20:07:54.862 - info: host.raspberrypi Some obsolete host states deleted.
                      2026-05-05 20:07:58.497 - info: host.raspberrypi instance system.adapter.history.0 in version "4.0.0" started with pid 2015
                      2026-05-05 20:08:00.105 - error: admin.0 (1806) admin.0 already running
                      2026-05-05 20:08:00.109 - warn: admin.0 (1806) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:00.873 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:00.874 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                      2026-05-05 20:08:01.255 - error: history.0 (2015) history.0 already running
                      2026-05-05 20:08:01.259 - warn: history.0 (2015) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:02.571 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:02.572 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
                      2026-05-05 20:08:02.598 - info: host.raspberrypi instance system.adapter.javascript.0 in version "9.0.18" started with pid 2035
                      2026-05-05 20:08:06.555 - info: host.raspberrypi instance system.adapter.scenes.0 in version "4.0.4" started with pid 2051
                      2026-05-05 20:08:06.790 - error: javascript.0 (2035) javascript.0 already running
                      2026-05-05 20:08:06.795 - warn: javascript.0 (2035) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:07.520 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:07.521 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
                      2026-05-05 20:08:09.163 - error: scenes.0 (2051) scenes.0 already running
                      2026-05-05 20:08:09.168 - warn: scenes.0 (2051) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:10.539 - error: host.raspberrypi instance system.adapter.scenes.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:10.540 - info: host.raspberrypi Restart adapter system.adapter.scenes.0 because enabled
                      2026-05-05 20:08:10.571 - info: host.raspberrypi instance system.adapter.telegram.0 in version "4.1.0" started with pid 2192
                      2026-05-05 20:08:14.947 - info: host.raspberrypi instance system.adapter.backitup.0 in version "3.3.14" started with pid 2247
                      2026-05-05 20:08:15.460 - error: telegram.0 (2192) telegram.0 already running
                      2026-05-05 20:08:15.466 - warn: telegram.0 (2192) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:16.315 - error: host.raspberrypi Caught by controller[0]: (node:2192) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                      2026-05-05 20:08:16.316 - error: host.raspberrypi Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
                      2026-05-05 20:08:16.317 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:16.317 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
                      2026-05-05 20:08:18.896 - info: host.raspberrypi instance system.adapter.alexa2.0 in version "3.27.4" started with pid 2273
                      2026-05-05 20:08:19.565 - error: backitup.0 (2247) backitup.0 already running
                      2026-05-05 20:08:19.586 - warn: backitup.0 (2247) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:20.471 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:20.472 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
                      2026-05-05 20:08:22.946 - info: host.raspberrypi instance system.adapter.cloud.0 in version "5.0.1" started with pid 2291
                      2026-05-05 20:08:24.167 - error: alexa2.0 (2273) alexa2.0 already running
                      2026-05-05 20:08:24.174 - warn: alexa2.0 (2273) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:24.958 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:24.959 - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
                      2026-05-05 20:08:27.123 - info: host.raspberrypi instance scheduled system.adapter.feiertage.0 0 3 3 * * *
                      2026-05-05 20:08:27.150 - info: host.raspberrypi instance system.adapter.feiertage.0 in version "1.3.0" started with pid 2309
                      2026-05-05 20:08:27.870 - error: cloud.0 (2291) cloud.0 already running
                      2026-05-05 20:08:27.877 - warn: cloud.0 (2291) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:28.662 - error: host.raspberrypi instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:28.663 - info: host.raspberrypi Restart adapter system.adapter.cloud.0 because enabled
                      2026-05-05 20:08:32.751 - info: host.raspberrypi instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 2372
                      2026-05-05 20:08:34.683 - info: host.raspberrypi instance system.adapter.admin.0 in version "7.7.22" started with pid 2383
                      2026-05-05 20:08:35.947 - info: host.raspberrypi instance system.adapter.history.0 in version "4.0.0" started with pid 2398
                      2026-05-05 20:08:36.006 - info: host.raspberrypi instance system.adapter.hm-rpc.0 in version "3.0.1" started with pid 2404
                      2026-05-05 20:08:45.056 - error: hm-rega.0 (2372) hm-rega.0 already running
                      2026-05-05 20:08:45.064 - warn: hm-rega.0 (2372) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:45.458 - info: host.raspberrypi instance system.adapter.hm-rpc.1 in version "3.0.1" started with pid 2494
                      2026-05-05 20:08:46.263 - info: feiertage.0 (2309) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v22.22.2, js-controller: 7.0.7
                      2026-05-05 20:08:46.866 - info: host.raspberrypi instance system.adapter.javascript.0 in version "9.0.18" started with pid 2580
                      2026-05-05 20:08:47.816 - info: host.raspberrypi instance scheduled system.adapter.ical.0 13 0 * * *
                      2026-05-05 20:08:47.841 - info: host.raspberrypi instance system.adapter.ical.0 in version "1.20.0" started with pid 2609
                      2026-05-05 20:08:49.478 - info: host.raspberrypi instance system.adapter.scenes.0 in version "4.0.4" started with pid 2631
                      2026-05-05 20:08:49.490 - error: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:49.491 - info: host.raspberrypi Restart adapter system.adapter.hm-rega.0 because enabled
                      2026-05-05 20:08:50.899 - error: hm-rpc.0 (2404) hm-rpc.0 already running
                      2026-05-05 20:08:50.919 - warn: hm-rpc.0 (2404) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:08:53.499 - info: host.raspberrypi instance scheduled system.adapter.ical.1 */30 * * * *
                      2026-05-05 20:08:53.549 - info: host.raspberrypi instance system.adapter.ical.1 in version "1.20.0" started with pid 2676
                      2026-05-05 20:08:55.704 - error: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:08:55.706 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                      2026-05-05 20:08:57.397 - info: host.raspberrypi instance system.adapter.telegram.0 in version "4.1.0" started with pid 2689
                      2026-05-05 20:08:58.092 - info: host.raspberrypi instance scheduled system.adapter.ical.2 30 0 0 * * *
                      2026-05-05 20:08:58.109 - info: host.raspberrypi instance system.adapter.ical.2 in version "1.20.0" started with pid 2697
                      2026-05-05 20:08:59.098 - error: hm-rpc.1 (2494) hm-rpc.1 already running
                      2026-05-05 20:08:59.107 - warn: hm-rpc.1 (2494) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2026-05-05 20:09:02.791 - error: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2026-05-05 20:09:02.792 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
                      2026-05-05 20:09:03.525 - info: host.raspberrypi instance system.adapter.backitup.0 in version "3.3.14" started with pid 2715
                      2026-05-05 20:09:03.701 - info: host.raspberrypi instance system.adapter.mqtt.0 in version "6.1.4" started with pid 2723
                      2026-05-05 20:09:04.681 - info: host.raspberrypi instance system.adapter.alexa2.0 in version "3.27.4" started with pid 2731
                      2026-05-05 20:09:05.088 - info: host.raspberrypi instance system.adapter.panasonic-viera.0 in version "2.1.0" started with pid 2740
                      2026-05-05 20:09:05.093 - info: feiertage.0 (2309) Next holiday: Christi Himmelfahrt (Vatertag) is in 9 days on 14.05.2026
                      2026-05-05 20:09:05.244 - info: host.raspberrypi instance scheduled system.adapter.pegelalarm.0 */120 * * * *
                      2026-05-05 20:09:05.271 - info: host.raspberrypi instance system.adapter.pegelalarm.0 in version "1.3.12" started with pid 2746
                      2026-05-05 20:09:05.463 - info: host.raspberrypi instance system.adapter.cloud.0 in version "5.0.1" started with pid 2754
                      2026-05-05 20:09:10.877 - info: feiertage.0 (2309) all objects written
                      2026-05-05 20:09:12.182 - info: feiertage.0 (2309) Terminated (NO_ERROR): Without reason
                      2026-05-05 20:09:12.361 - info: host.raspberrypi instance system.adapter.ping.0 in version "1.7.9" started with pid 2788
                      2026-05-05 20:09:13.329 - info: history.0 (2398) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.history, node: v22.22.2, js-controller: 7.0.7
                      2026-05-05 20:09:14.149 - info: host.raspberrypi instance system.adapter.rpi2.0 in version "3.0.2" started with pid 2800
                      2026-05-05 20:09:14.169 - info: host.raspberrypi instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
                      Hat keiner eine Idee?
                      Gruß,
                      Thomas
                      • T thomke67
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @thomke67 nee, es geht vielen so bis sie einsehen, das 4 GB Ram irgendwann nicht mehr aussreichen.
                        Als Denkanstoß, wieviel GB hatte ein Windows vor etlichen Jahren benötigt und wieviel benötigt es heutzutage, ohne am System etwas geändert zu haben?
                        Letztendlich bleibt dir nur
                        • unnötiges abschalten z.b discovery, wobei du eh schon einiges deaktiviert hast
                        • Aufrüsten auf mehr Arbeitsspeicher ist wohl eher treffend
                          thomke67
                          schrieb am zuletzt editiert von thomke67
                          Ich habe gerade gelesen, dass man auch die Swap Größe verändern kann. Ich habe gerade mal nachgesehen und bin erstaunt, dass ich nur 200MB Swap habe, obwohl eine 120GB SSD (fast leer....) anstatt einer SD-Karte dran hängt. Wie kann ich das vergrößern?
                          Ich habe auch gesehen, dass man mehr RAM auflöten kann, aber das kann ich nicht!
                          Ansonsten bleibt nur ein Neukauf.
                          Gruß,
                          Thomas
                          crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                          • ilovegymI Offline
                            ilovegymI Offline
                            ilovegym
                            mit mehr Swap wirst du nicht gluecklich, ich empfehle neukauf, das Teil hat sein Geld verdient und ist einfach nicht mehr aktuell.
                            • T thomke67
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @thomke67 sagte:
                              und was möchtest du dadurch erreichen? swap dient mehr oder weniger als Notfall und bremst letztendlich auch nur dein System aus. Glaube nicht das es Zielführend ist den PI kontinuierlich auf "Notbetrieb" laufen zu lassen
                              • T thomke67
                                @thomke67 sagte:
                                'Früher' wurde das so voreingestellt. Dann hat man es auf 512MB erhöht, bevor man in den letzten Neuinstallationen auf ZRAM mit 2,1 GB umgeschwenkt ist.
                                Das rettet dich aber nicht dauerhaft. Wie die Vorredner schon sagten, das dient nur als 'Notausgang' für kurzfristige Spitzen. Wenn dein physischer Arbeitsspeicher (nachdem du allen unnötigen Klimbimm stillgelegt hast) auf Dauer nicht ausreicht kannst du dem nur mit mehr physischem RAM beikommen.
                                  @thomke67 sagte:
                                  thomke67
                                  @Thomas-Braun, wie kann ich denn dann auf ZRAM umstellen? Gibt es dazu eine Anleitung?
                                  Dann habe ich etwas Zeit, um auf ein zukunftsorientiertes System umzusiedeln.
                                  Gruß,
                                  Thomas
                                  Thomas BraunT Samson71S 2 Antworten Letzte Antwort
                                  • T thomke67
                                    @thomke67
                                    https://github.com/raspberrypi/rpi-swap
                                    • T thomke67
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      @thomke67
                                      ZRAM legt im Arbeitsspeicher Swap an (statt auf der SD-Karte), wenn ich das richtig verstanden habe. Wenn Dir bei Deinem "alten" PI4 die jetzigen 4GB schon nicht mehr ausreichen, wieviel willst Du davon dann noch zusätzlich opfern? Dann beschneidest Du sie damit noch zusätzlich.
                                      Markus
                                      Bitte beachten:
                                        @thomke67
                                        thomke67
                                        @thomke67
                                        Danke schon mal für den Link, aber als nicht Linux User, kannst du mir bitte kurz erklären, wie ich es installiere? Danke!
                                        Gruß,
                                        Thomas
                                        • T thomke67
                                          @thomke67
                                          @thomke67
                                          Das Paket einfach über deinen Paketmanager installieren.
                                          crunchipC T 2 Antworten Letzte Antwort
