  4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
diagrammenergieflussenergiefluss-erweitertvisvisualisierungvisualization
1.7k Beiträge 78 Kommentatoren 1.1m Aufrufe 78 Beobachtet
  • H Hotze
    Geniale Arbeit der Adapter!
    Ich habe vermutlich einen Fehler in der Animation. Die springt.
    Ein fix ist für mich nicht nötig, ich wollte nur Bescheid geben.
    {"basic":{"enable_grid":true,"enable_animation":false,"enable_area_catch":true,"enable_config_icon":true,"enable_last_id":false,"enable_icon_proxy":true,"enable_low_performance":true,"enable_ds_autocomplete":false,"enable_show_coordinates":true,"tourVisited":true,"height":271,"width":433,"animation_timer":1000,"background_color":"#D1D1D1","styles":"","font":{"family":"\"Arial\", sans-serif","size":20,"align":"middle"},"rect":{"height":100,"width":100,"corners":10},"circle":{"radius":50},"elm":{"stroke_width":5,"pos_x":50,"pos_y":50},"icon":{"width":24,"height":24},"enable_line_animation":false},"calculation":{"battery":{"dod":-1,"capacity":-1,"percent":-1,"charge":-1,"charge_prop":false,"discharge":-1,"discharge_prop":false},"consumption":{"production":[],"gridFeed":-1,"gridFeed_prop":false,"gridConsume":-1,"gridConsume_prop":false,"batteryCharge":-1,"batteryCharge_prop":false,"batteryDischarge":-1,"batteryDischarge_prop":false}},"animation":{"stroke_dasharray":"10 17 10 17 10 72","stroke_width":6,"animation_duration":2000,"stroke_linecap":"round","animation_timing_function":"linear"},"animation_configuration":{"dots":3,"gap":72,"distance":17,"length":10},"line":{"stroke_width":8,"stroke":"#000000","stroke_linecap":"square"},"elements":{"2":{"type":"text","align":"middle","subType":"datasource","id":2,"pos_x":230,"pos_y":55,"color":"rgb(0, 0, 0)","fill":"rgb(255, 206, 74)","font_family":"\"Arial\", sans-serif","font_size":18,"degree":0,"text":"ID 2","unit":"W","source":10,"shadow":"","threshold":0,"convert":false,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":11},"5":{"type":"rect","id":5,"rx":10,"height":100,"width":100,"pos_x":180,"pos_y":5,"fill":"none","color":"rgb(255, 206, 74)","stroke":2,"shadow":"rgba(0,0,0,0.7)","frame":"_self","url":"http://192.168.3.75:8082/energiefluss-erweitert/index.html?instance=0","source":-1,"position":3},"6":{"type":"icon","id":6,"icon":"mdi:solar-power-variant-outline","width":34,"height":34,"color":"rgba(0, 0, 0, 0.7)","pos_x":214,"pos_y":10,"shadow":"","position":2},"7":{"type":"rect","id":7,"rx":10,"height":100,"width":100,"pos_x":321,"pos_y":99,"fill":"none","color":"rgb(0, 181, 221)","stroke":2,"shadow":"rgba(0,0,0,0.7)","frame":"_self","url":"http://192.168.3.75:8082/energiefluss-erweitert/index.html?instance=0","source":-1,"position":0},"8":{"type":"icon","id":8,"icon":"mdi:battery-high","width":40,"height":40,"color":"rgba(0, 0, 0, 0.7)","pos_x":47,"pos_y":90,"shadow":"","position":1,"source":1},"9":{"type":"text","align":"middle","subType":"datasource","id":9,"pos_x":371,"pos_y":147,"color":"none","fill":"rgb(0, 181, 221)","font_family":"\"Arial\", sans-serif","font_size":18,"degree":0,"text":"ID 9","unit":"W","source":3,"shadow":"","threshold":0,"convert":false,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":8},"10":{"type":"text","align":"middle","id":10,"pos_x":230,"pos_y":78,"color":"none","fill":"rgba(0, 0, 0, 0.7)","font_family":"\"Arial\", sans-serif","font_size":14,"degree":0,"text":"Produktion","shadow":""},"11":{"type":"text","align":"middle","id":11,"pos_x":371,"pos_y":175,"color":"none","fill":"rgba(0, 0, 0, 0.7)","font_family":"\"Arial\", sans-serif","font_size":14,"degree":0,"text":"Verbrauch","shadow":""},"12":{"type":"icon","id":12,"icon":"mdi:home-outline","width":34,"height":34,"color":"rgba(0, 0, 0, 0.7)","pos_x":354,"pos_y":101,"shadow":"","position":0},"13":{"type":"rect","id":13,"rx":10,"height":180,"width":120,"pos_x":7,"pos_y":84,"fill":"none","color":"rgb(161, 211, 67)","stroke":2,"shadow":"rgba(0,0,0,0.7)","frame":"_self","url":"http://192.168.3.75:8082/energiefluss-erweitert/index.html?instance=0","source":1,"position":2,"fill_direction":90,"fill_type":"percent","fill_value":"rgba(161, 211, 67, 0.63)"},"14":{"type":"rect","id":14,"rx":10,"height":100,"width":100,"pos_x":180,"pos_y":164,"fill":"none","color":"rgba(97, 104, 122, 0.7)","stroke":2,"shadow":"rgba(0,0,0,0.7)","frame":"_self","url":"http://192.168.3.75:8082/energiefluss-erweitert/index.html?instance=0","source":-1,"position":1},"16":{"type":"text","align":"middle","subType":"datasource","id":16,"pos_x":58,"pos_y":140,"color":"none","fill":"rgb(0, 0, 0)","font_family":"\"Arial\", sans-serif","font_size":20,"degree":0,"text":"ID 16","unit":"Wh","source":"0","shadow":"","threshold":0,"convert":true,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":11},"18":{"type":"text","align":"middle","subType":"datasource","id":18,"pos_x":59,"pos_y":159,"color":"none","fill":"rgb(0, 0, 0)","font_family":"\"Arial\", sans-serif","font_size":18,"degree":0,"text":"ID 18","unit":"%","source":1,"shadow":"","threshold":0,"convert":false,"decimal_places":0,"source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":5},"19":{"type":"text","align":"middle","subType":"datasource","id":19,"pos_x":230,"pos_y":215,"color":"none","fill":"rgb(97, 104, 122)","font_family":"\"Arial\", sans-serif","font_size":18,"degree":0,"text":"ID 19","unit":"W","source":4,"shadow":"","threshold":0,"convert":true,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":3},"20":{"type":"icon","id":20,"icon":"mdi:electricity-from-grid","width":34,"height":34,"color":"rgba(0, 0, 0, 0.7)","pos_x":217,"pos_y":168,"shadow":"","position":3},"21":{"type":"text","align":"middle","id":21,"pos_x":230,"pos_y":237,"color":"none","fill":"rgba(0, 0, 0, 0.7)","font_family":"\"Arial\", sans-serif","font_size":14,"degree":0,"text":"Netz","shadow":""},"22":{"position":3,"id":22,"pos_x":69,"pos_y":187,"source":6,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"type":"text","align":"middle","subType":"datasource","text":"Datenquelle 22","source_option":-1,"source_option_lc":-1,"source_display":"auto","linebreak":0,"subtract":[],"add":[],"unit":"%:","source_action":-1,"color":"none","fill":"rgba(0, 0, 0, 0.7)","font_size":15,"font_family":"\"Arial\", sans-serif","prepend":"Rest bis"},"23":{"type":"text","align":"middle","subType":"datasource","id":23,"pos_x":58,"pos_y":214,"color":"none","fill":"rgb(0, 0, 0)","font_family":"\"Arial\", sans-serif","font_size":20,"degree":0,"text":"ID 16","unit":"","source":7,"shadow":"","threshold":0,"convert":true,"decimal_places":"0","source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":6,"group":null},"24":{"type":"text","align":"middle","subType":"datasource","id":24,"pos_x":58,"pos_y":236,"color":"none","fill":"rgb(0, 0, 0)","font_family":"\"Arial\", sans-serif","font_size":20,"degree":0,"text":"ID 16","unit":"Wh","source":8,"shadow":"","threshold":0,"convert":true,"decimal_places":1,"source_option":-1,"source_display":"value","action":"none","calculate_kw":"none","frame":"_overlay","position":7,"group":null},"25":{"position":4,"id":25,"pos_x":117,"pos_y":37,"source":5,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"type":"text","align":"middle","subType":"datasource","text":"Datenquelle 25","source_option":-1,"source_option_lc":-1,"source_display":"auto","linebreak":0,"subtract":[],"add":[],"unit":"W","source_action":-1,"color":"none","fill":"rgb(0, 0, 0)","font_size":20,"font_family":"\"Arial\", sans-serif","url":"","frame":"_overlay"},"26":{"position":0,"id":26,"pos_x":338,"pos_y":37,"source":9,"calculate_kw":"none","counter_animation":false,"convert":false,"decimal_places":0,"type":"text","align":"middle","subType":"datasource","text":"Datenquelle 26","source_option":-1,"source_option_lc":-1,"source_display":"auto","linebreak":0,"subtract":[],"add":[],"unit":"W","source_action":-1,"color":"none","fill":"rgb(0, 0, 0)","font_size":20,"font_family":"\"Arial\", sans-serif"}},"defs":{"path_5_7":{"type":"def","id":"path_5_7","d":"M281 55 H 356 A 15 15 0 0 1 371 70 V 98","startSlot":"right","endSlot":"top"},"path_5_13":{"type":"def","id":"path_5_13","d":"M179 55 H 81 A 14 14 0 0 0 67 69 V 83","startSlot":"left","endSlot":"top"},"path_14_7":{"type":"def","id":"path_14_7","d":"M281 234 H 356 A 15 15 0 0 0 371 219 V 200","startSlot":"right_bottom","endSlot":"bottom"},"path_5_14":{"type":"def","id":"path_5_14","d":"M230 106 V 163","startSlot":"bottom","endSlot":"top"}},"lines":{"line_path_5_7":{"type":"line","id":"line_path_5_7","href":"#path_5_7","color":"rgb(0, 0, 0)","position":2},"line_path_5_13":{"type":"line","id":"line_path_5_13","href":"#path_5_13","color":"rgb(0, 0, 0)","position":3},"line_path_14_7":{"type":"line","id":"line_path_14_7","href":"#path_14_7","color":"rgb(0, 0, 0)","position":1},"line_path_5_14":{"type":"line","id":"line_path_5_14","href":"#path_5_14","color":"rgb(0, 0, 0)","position":0}},"animations":{"anim_path_5_7":{"type":"animation","id":"anim_path_5_7","href":"#path_5_7","color":"rgb(161, 211, 67)","threshold":0,"source":9,"animation_properties":"positive","animation_type":"dots","dots":10,"power":400},"anim_path_5_13":{"type":"animation","id":"anim_path_5_13","href":"#path_5_13","color":"rgb(255, 206, 74)","threshold":0,"source":5,"animation_properties":"positive","animation_option":true,"animation_type":-1,"dots":100,"power":1600},"anim_path_14_7":{"type":"animation","id":"anim_path_14_7","href":"#path_14_7","color":"rgb(255, 0, 0)","threshold":10,"source":4,"animation_properties":"positive"},"anim_path_5_14":{"type":"animation","id":"anim_path_5_14","href":"#path_5_14","color":"rgb(255, 206, 74)","threshold":0,"source":4,"animation_properties":"negative"}},"icons":{},"datasources":{"0":{"source":"mqtt.0.b2500.S.battery.remaining_capacity","alias":"b2500/S/battery/remaining_capacity","factor":1},"1":{"source":"0_userdata.0.PVKram.Akkukapazität","alias":"Akkukapazität%","factor":1},"2":{"source":"mqtt.0.b2500.S.power.power","alias":"b2500/S/power/power","factor":1},"3":{"source":"0_userdata.0.PVKram.Hausverbrauch","alias":"Hausverbrauch","factor":1},"4":{"source":"shelly.0.shellypro3em#34987a45a8b8#1.EM0.TotalActivePower","alias":"TotalActivePower","factor":1},"5":{"source":"0_userdata.0.PVKram.Rein+Raus-","alias":"Rein+Raus-","factor":1},"6":{"source":"0_userdata.0.PVKram.EntladenBis","alias":"EntladenBis","factor":1},"7":{"source":"energiefluss-erweitert.0.calculation.battery.remaining_target","alias":"energiefluss Target of the remaining Time of the battery","factor":1},"8":{"source":"energiefluss-erweitert.0.calculation.battery.remaining_energy","alias":"energiefluss Current Power available in battery","factor":1},"9":{"source":"opendtu.0.total.power","alias":"Total power over all inverters","factor":1},"10":{"source":"mqtt.0.b2500.S.pv.power","alias":"b2500/S/pv/power","factor":1},"11":{"source":"0_userdata.0.PVKram.RestzeitAkku","alias":"RestzeitAkku","factor":1}}}
    Das gif ist schlecht geschnitten!
    Die Punkte kommen ganz normal raus und springen dann nach vorne.
    Das kann man nur einmal sehen danach fängt das gif von vorne an. Dass das gif erneut anfängt sieht man an den gelben und roten Punkten.
    Evtl habe ich auch einfach nur zu viele Punkte auf die Linie gemacht und es springt deswegen.
    SKBS Offline
    SKBS Offline
    SKB
    #1485
    @Hotze Das Springen der Punkte ist in Version 0.8.0 behoben -> https://github.com/SKB-CGN/ioBroker.energiefluss-erweitert/?tab=readme-ov-file#080-2025-10-21
    • jvfleJ jvfle
      Hallo zusammen, ich möchte hier ein Phänomen beschreiben, dass ich selber nicht lösen kann und um Hilfe bei euch bitten möchte. Ich habe mir vor ca. 2 Jahren ein Dashboard zusammengestellt, das meinen Vorstellungen und Wünschen entsprach. Es besteht aus mehreren Views. Ein View beinhaltet den Energiefluss-erweitert Adapter, der auch zu dieser Zeit von mir eingerichtet wurde und funktionierte. Nun, da ich ein View nach dem anderen abarbeite und anpasse, ist nun der Energiefluss dran. Leider muss ich feststellen, dass dieser nicht mehr geht.
      Ich habe dieses Topic durchgelesen, auch das Wiki und sonst im Web, aber dieses Fehlerbild ist offensichtlich nicht so häufig.
      Der iobroker und alle Adapter sind mit der neuesten Firmware (stable) versehen. Der iobroker läuft schon immer in einem Docker-Container auf einer Synology-NAS ohne Probleme. Der Browser ist Edge. Ich habe den Energiefluss (erw.)-Adapter bereits zweimal neu aufgesetzt, ohne Erfolg. Alle anderen Adapter funktionieren. Das Einzige, was sich in der Zwischenzeit geändert hat, ist der Umstieg von Windows 10 auf 11.
      Der Fehler zeigt sich so, dass die Steuerelemente mit einem wellenförmigen grauen Streifen im jeweiligen Feld "überrollt" werden. Das Anklicken der einzelnen Felder ist stark zeitverzögert und führt nicht zum Erfolg.
      So sieht es bei mir aus. Die grauen Balken muss man sich von links nach rechts bewegend sehen.
      Ich hoffe, ihr könnt mir helfen und bedanke mich schon einmal für eure Mühe. BG
      SKBS Offline
      SKBS Offline
      SKB
      #1486
      @jvfle Was sagt die Browser-Konsole (F12 -> Konsole) dazu und welche Version des EF ist installiert?
      • jvfleJ jvfle
        Es ist die Version 0.8.1 installiert. Ich bitte um Nachsicht, mit der Browser-Konsole kann ich nichts anfangen. Kannst du kurz sagen, was ich machen muss? Danke
        SKBS Offline
        SKBS Offline
        SKB
        #1487
        @jvfle Steht eigentlich da. Browser öffnen, EF aurufen, Taste F12 drücken (Tab Konsole anwählen).
        • jvfleJ Offline
          jvfleJ Offline
          jvfle
          #1488
          Ja, es wird nichts angezeigt bei Taste F12.
          SKBS 1 Antwort Letzte Antwort
          • jvfleJ jvfle
            SKBS Offline
            SKBS Offline
            SKB
            #1489
            @jvfle Das kann ich mir beim Besten Willen nicht vorstellen. Wie wäre es mit einem Screenshot, wo man die Konsole sieht?
            • jvfleJ jvfle
              SKBS Offline
              SKBS Offline
              SKB
              #1490
              @jvfle Ohje, ohje.
              Was steht in meinem Beitrag?
              Browser öffnen -> EF öffnen, Konfiguration öffnen, F12 drücken.
              Du öffnest VIS und lässt dir darin die Konfiguration anzeigen.
              • jvfleJ Offline
                jvfleJ Offline
                jvfle
                #1491
                So besser? Ich sag ja, bitte um Nachsicht.
                • wendy2702W Offline
                  wendy2702W Offline
                  #1492
                  Du sollst die TASTE F12 drücken.
                  Sieht dann in FF zum Beispiel so aus:
                  Wenn es sich bei deinem Problem um die scheinbar unendlich ladenden "Funktionsblöcke" geht, das habe ich auch.
                  @skb : falls es darum geht kommt bei mir mit FF das in der Konsole, sag Bescheid wenn du etwas anderes benötigst.
                  [Socket] disconnected at 12.2.2026, 11:46:30 functions.min.js:8:26357
                  [Config] Using Instance: energiefluss-erweitert.0 functions.min.js:8:18406
                  [Language] Detected System-Language: de functions.min.js:8:18672
                  Passwort-Felder sind auf einer unsicheren (http://) Seite vorhanden. Dies ist ein Sicherheitsrisiko, durch das Zugangsdaten gestohlen werden können. configuration.html
                  [Config] Loaded additional file: /_socket/info.js functions.min.js:8:138538
                  Object { instance: 0, lowPerformance: false, theme: false, namespace: "energiefluss-erweitert.0", hostname: "192.168.178.18", localMode: false, socketURL: "/", webURL: "/", wwwExtLoaded: false, devMode: false, … }
                  functions.min.js:8:17998
                  [Socket] connected at 12.2.2026, 11:46:30 functions.min.js:8:23879
                  [Language] Trying to get language from system! functions.min.js:8:24058
                  [Language] Got it from ioBroker! Translating Texts to locale de! functions.min.js:8:24310
                  [Socket] subscribed to: system.adapter.energiefluss-erweitert.0.alive at 12.2.2026, 11:46:30 functions.min.js:8:24790
                  [Config] Trying to load configuration for instance 0 from state! functions.min.js:8:42196
                  [Config] Using direct load via iconify-API! functions.min.js:8:59201
                  [Calculation] Battery configured! functions.min.js:8:62719
                  [Calculation] Consumption configured! functions.min.js:8:63269
                  [Config] Loading initial Data functions.min.js:8:43252
                  [Config] Configuration loaded in 234 ms functions.min.js:8:43610
                  [Config] Loaded additional file: js/iconify.min.js functions.min.js:8:138538
                  • wendy2702W wendy2702
                    SKBS Offline
                    SKBS Offline
                    SKB
                    #1493
                    @wendy2702 Heisst, bei dir scrollen die Animation auch, obwohl die Seite geladen wurde oder endet dies irgendwann?
                      wendy2702W Offline
                      #1494
                      die scrollen. Habe das auch nach 10 minuten noch.
                      SKBS jvfleJ 2 Antworten Letzte Antwort
                        SKBS Offline
                        SKBS Offline
                        SKB
                        #1495
                        @wendy2702 Kannst Du im Datenpunkt configuration einmal schauen, was im basic Teil steht und es hier einstellen?
                          wendy2702W Offline
                          #1496
                          Ich hoffe du meinst das:
                          {"basic":{"enable_grid":true,"enable_animation":true,"enable_area_catch":true,"enable_config_icon":true,"enable_last_id":true,"enable_icon_proxy":false,"enable_low_performance":false,"height":513,"width":745,"styles":"/* kompetter Hintergrund der Seite */\n\nhtml,\nbody {\...
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #1497
                            @wendy2702 Ja, allerdings fehlt da ja noch mehr.
                            • jvfleJ Offline
                              jvfleJ Offline
                              jvfle
                              #1498
                              Hab ich gemacht, sogar mehrmals, da kommt nichts. Screenshot 2026-02-12 152822.png
                              mickemupM 1 Antwort Letzte Antwort
                              • SKBS Offline
                                SKBS Offline
                                SKB
                                #1499
                                Dann nutze bitte einen normalen Browser wie Chrome oder Firefox. Ohne Konsole kann ich da nichts zu sagen!
                                jvfleJ 1 Antwort Letzte Antwort
                                  jvfleJ Offline
                                  jvfleJ Offline
                                  jvfle
                                  #1500
                                  @wendy2702 sagte in Support Adapter Energiefluss-erweitert v0.7.7:
                                  Ja, genau und es stoppt auch nach langer Zeit nicht. Ich hatte erst gedacht, der Adapter lädt Daten.
                                  • jvfleJ jvfle
                                    #1501
                                    @jvfle wo ist dein Output der Browserkonsole?
                                    find den grad nicht
                                    • SKBS SKB
                                      jvfleJ Offline
                                      jvfleJ Offline
                                      jvfle
                                      #1502
                                      @SKB sagte in Support Adapter Energiefluss-erweitert v0.7.7:
                                      Bei Chrome das gleiche Bild. Firefox habe ich nicht. Ich wundere mich nur, dass der Adapter wunderbar funktioniert. Ich wollte eigentlich nur den Adapter DP zuordnen. Dazu ist es aber nicht gekommen.
                                      Übrigens die Button über den Steuerelementen funktionieren.
                                      • jvfleJ jvfle
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #1503
                                        @jvfle ALLE Browser haben keine Browser-Konsole. Alle!
                                        • jvfleJ Offline
                                          jvfleJ Offline
                                          jvfle
                                          #1504
                                          Ja, aber der liegt nicht bei F12, sondern bei mir: Strg+Umschalt+I (benutze den zum ersten Mal). Ich entschuldige mich schon jetzt für meine Fragen. Nun werden auch Dateien gezeigt, sind es die?
