  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
1.6k Beiträge 101 Kommentatoren 810.9k Aufrufe 95 Beobachtet
  • M Maxtor62
    Hallo, Habe den Adapter auch mal Installiert. Komme mit den Fehlermeldungen nicht klar.
    device-watcher.0
    2025-12-12 16:15:00.189	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:14:45.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:14:30.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:14:15.141	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:14:00.140	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:13:45.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:13:30.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:13:15.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:13:00.140	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:12:45.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:12:30.143	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:12:15.138	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:12:12.127	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:12:12.076	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:12:12.074	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:12:12.055	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:12:12.048	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:12:12.036	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:12:12.029	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:12:00.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:11:45.137	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
    device-watcher.0
    2025-12-12 16:11:42.126	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:11:42.077	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:11:42.076	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:11:42.060	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:11:42.056	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:11:42.048	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    device-watcher.0
    2025-12-12 16:11:42.042	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
    Was mach ich falsch?
    D
    D
    deta
    #1529
    @Maxtor62 es sind nicht alle Adapter die beobachten.
    Ich hatte mal alle raus und dann nach und nach dazu gesetzt bis ich die nicht aktiv hatte, die den Fehler bringen.
    • arteckA
      arteckA
      arteck
      #1530
      ic hab mal LOG eingebaut.. installiert mal die GIT version
      • arteckA arteck
        D
        D
        deta
        #1531
        @arteck gemacht, was brauchst du jetzt genau?
        • arteckA
          arteckA
          arteck
          #1532
          das LOG wenn es wieder mal errors gibt
          • D
            D
            deta
            #1533
            Hallo, so langsam komme ich weiter.
            So ist es jetzt
            Jetzt ist das Problem, bei der Batterie.
            Jeder Adapter gibt es anders raus. Ist es möglich, das alle Adapert das in % ausgeben, also wie voll die Batterie noch ist? Hier z.b. Sonoff gibt % raus HM-RPC in Volt.
            • arteckA
              arteckA
              arteck
              #1534
              und dann gibts noch zwave wo es nur als isLow = true angezeigt wird.. wie stellst du dir das vor dass es gelösst werden kann
              • arteckA arteck
                D
                D
                deta
                #1535
                @arteck
                Ich weis nicht, wer das gebastelt hat in Grafana
                Wie das gelöst wurde? Es wird ja nicht nur Zigbee geben ?
                • D deta
                  @arteck
                  arteckA
                  arteckA
                  arteck
                  #1536
                  @deta sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                  ne aber derjenige hat es NUR für zigbee gebastelt, oder zumindest für die Werte die mit % kommen
                  • JB_SullivanJ
                    JB_SullivanJ
                    JB_Sullivan
                    #1537
                    Ist irgendwas zu diesem Fehler mit der Version 2.14.5 bekannt? Gibt ja leider keine genauere Beschreibung von welchem Gerät das kommen könnte.
                    device-watcher.0
                    8572	2026-01-04 17:40:02.802	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                    device-watcher.0
                    8572	2026-01-04 17:39:47.806	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                    device-watcher.0
                    8572	2026-01-04 17:39:32.801	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                    • JB_SullivanJ JB_Sullivan
                      device-watcher.0
                      device-watcher.0
                      device-watcher.0
                      S
                      S
                      Shadowhunter23
                      schrieb am zuletzt editiert von Shadowhunter23
                      #1538
                      @JB_Sullivan
                      Das Issue ist offen auf GitHub, somit heißt es warten auf @arteck
                      Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                      ioBroker Backup Analyzer
                      • arteckA
                        arteckA
                        arteck
                        #1539
                        checkt mal die neue Version...
                        für alle die Ping überwachen wollen
                        im Einstellungen von dem Ping Adapter müssen die Erweiterte Informationen aktiviert sein
                        so eine Baumstruktur müsst ihr sehen
                        Merlin123M 1 Antwort Letzte Antwort
                        • arteckA arteck
                          Merlin123M
                          Merlin123M
                          Merlin123
                          #1540
                          @arteck Das klappt.
                          Muss mal schauen, wie/ob ich diese Infos für mich sinnvoll nutzen kann. (Für was sie generell sinnvoll sind ist mir klar)
                          Beta-Tester
                          • Merlin123M
                            Merlin123M
                            Merlin123
                            #1541
                            @arteck Du hast eine kleine, aber wichtige Info nicht erwähnt...
                            Wenn man die erweiterten Informationen aktiviert ist es eine Breaking Änderung, da der bisherige DP nicht mehr existiert und in den Unterordner gewandert ist.
                            Hab ich eben mehr zufällig gemerkt.....
                            Ist nicht schlimm, sollte man aber vorher wissen
                            Beta-Tester
                            • R
                              R
                              Rushmed
                              schrieb am zuletzt editiert von Rushmed
                              #1542
                              wie errechnet der Adapter die Zeit des letzten Kontaks bei HUE Geräten?
                              MIr ist aufgefallen dass die letzten Kontakte enorm lange zurück liegen obwohl die Geräte oft genutzt werden.
                              Bspw. Lampe Spa 1 kann ich schalten und wird als online angezeigt aber der letzte Kontakt soll fast 20 kh her sein.
                              Die online Status stimmen alle, auch die der Terrasse Dots.
                              Edit:
                              Es wird wohl der DP hue.0.Lampe_Spa_1.reachable verwendet.
                              Der wurde tasächlich 2023 das letzte mal aktualisiert.
                              Edit2:
                              Ich hatte gestern von 2.13.1 auf 2.15.5 geupdated.
                              Vorher waren die HUE Zeiten korrekt, kann man das irgendwo einstellen?
                              https://github.com/iobroker-community-adapters/ioBroker.device-watcher/issues/608
                              • R Rushmed
                                Edit:
                                Edit2:
                                arteckA
                                arteckA
                                arteck
                                #1543
                                @Rushmed aus deinen wilden Informationen suche ich mal zusammen
                                der device-watcher überwacht den hue adapter .. korrekt ??
                                dieser ist definiert
                                hue: {
                                		adapterKey: 'hueDevices',
                                		selektor: 'hue.*.reachable',
                                		timeSelector: '.reachable',
                                		adapterID: 'hue',
                                		adapter: 'Philips Hue',
                                		battery: '.battery',
                                		reach: '.reachable',
                                		isLowBat: 'none',
                                und wenn der Wert im hue adapter seid 2023 nicht geändert wurde warum sollte das vorher funktioniert haben..
                                der device-watcher kann nur mit dem arbeiten was die adapter liefern.. shit in shit out
                                R 1 Antwort Letzte Antwort
                                • HiltexH
                                  HiltexH
                                  Hiltex
                                  #1544
                                  Ich habe das auch bei einigen Adaptern, zum Beispiel bei hm-rpc. Kürzlich wurde gemeldet, dass der Rollladen im BZ nicht mehr erreichbar sei.
                                  17:21 Uhr die Meldung:
                                  Das folgende Gerät ist nicht mehr erreichbar:
                                  Homematic RPC: Rolladen_BZ (445 Tage)
                                  17:22 Uhr war er wieder erreichbar:
                                  Das folgende Gerät ist wieder verfügbar:
                                  Irgendwie passt die angezeigte Zeit nicht zu meinem Verständnis. Der Rollladen war ja nicht 445 Tage offline, sondern eine Minute. Und die Zeit, wie lange er online war, als er ausgestiegen ist, ist in meinen Augen nicht wirklich relevant.
                                  Ich würde aber behaupten, dass das schon immer so war, längst bevor Arteck dankenswerterweise diesen Adapter in seine Obhut genommen hat
                                  Blog: indibit.de
                                  • arteckA arteck
                                    hue: {
                                    		adapterID: 'hue',
                                    		isLowBat: 'none',
                                    R
                                    R
                                    Rushmed
                                    #1545
                                    @arteck Wo finde ich diese Definition?
                                    Ok, hab downgegraded.
                                    Offensichtlich waren die Last seen Werte auch schon so hoch jedoch in Tagen angegeben.
                                    Korrekt ist es dennoch nicht dass die Geräte zu dieser Zeit das letzt mal gesehen worden.
                                    arteckA 2 Antworten Letzte Antwort
                                    • R Rushmed
                                      arteckA
                                      arteckA
                                      arteck
                                      #1546
                                      @Rushmed im source
                                      was steht genau in DP vom hue adapter ? oder mach mir ein extrakt von dem hue adapter
                                      https://github.com/iobroker-community-adapters/ioBroker.device-watcher/wiki/JSON-export
                                      • R
                                        R
                                        Rushmed
                                        #1547
                                        Ich sage nicht dass der Adapter bei mir eine Fehlfunktion hat. Ich bin vielmehr der Meinung dass reachable vom HUE Adapter nicht für die Berechnung von last seen taugt da er nicht bei Kontakt akualisiert wird sondern nur bei Statuswechsel.
                                        • arteckA
                                          arteckA
                                          arteck
                                          #1548
                                          und statuswechsel hat der kontakt nicht oder wie ??
                                          83.8k
