  4. Test ViessmannAPI v2.0.0
    6.6k
827 Beiträge 129 Kommentatoren 389.0k Aufrufe 125 Beobachtet
  • M MartyBr
    Ich habe heute die folgende Mail von Viessmann bekommen:
    Domain Change for the Viessmann API
    Dear Developer Portal user,
    As part of the continuous optimization and modernization of our services, we are currently in the process of switching our applications and websites to the new domain viessmann-climatesolutions.com. This change will also affect the domains for resources such as the Developer Portal and the API Documentation.
    For your integrations, this requires the following technical updates:
    1. API Endpoints:
    The base URI for all API calls is changing. You need to update your code to use the new domain.
    Old: https://​api.​viessmann.​com/...
    New: https://​api.​viessmann-climatesolutions.​com/...
    2. Identity and Access Management (IAM):
    The domain for our identity services will also be updated. This needs to be updated in your application to ensure authorization continues to function correctly.
    Old: https://​iam.​viessmann.​com
    New: https://​iam.​viessmann-climatesolutions.​com
    3. API Response Body:
    The uri value within the JSON response from the Features API (/iot/v2/features/...) will reflect the new viessmann​-​climatesolutions.​com domain in the future.
    The API endpoints under the new domain are already available, and we ask you to please use the new addresses with immediate effect. The old viessmann​.com domain will be deactivated during Q4/2025, by the end of the year at the latest.
    We understand that these changes may require adjustments to your existing code. To assist you in this process, we recommend referring to the API documentation.
    Support Channels:
    If you have any questions or require further assistance regarding these updates, please don't hesitate to reach out to our developer community forum or send an email to developer@viessmann-climatesolutions.com.
    We appreciate your understanding and cooperation as we continue to improve the Viessmann API.
    A Note on This Service Communication:
    You are receiving this email because you have an account with the Viessmann Developer Portal. This is a mandatory service communication regarding critical platform changes. If you no longer wish to receive these essential service updates, please send an email to revoke+api@viessmann-climatesolutions.com. Please be aware that by doing so, you may miss critical information about future platform changes that could affect the functionality of your applications. This action will not affect your Viessmann account or access to other applications like ViCare.
    All the best,
    The Viessmann Developer Portal Team
    Muss hier der Entwickler aktiv werden?
    A Online
    A Online
    Ahnungsbefreit
    #794
    @martybr Ja, die habe ich auch bekommen und ich denke, das muss in dem Adapter angepasst werden (auch wenn ich nicht in den Source Code geschaut habe).
    • madingM Offline
      madingM Offline
      mading
      #795
      als Workaround könntest du in /etc/hosts alt auf neu mappen
        sagitarius
        #796
        Ich habe das Problem, das sich die Datenpunkte in meinem Viessmann Adapter ( zumindest die, die ich nutze ) seit dem 24. August nicht mehr aktualiesiren.
        Ich denke, das es mit den Änderungen, die in dieser Mail beschrieben werden zu tun hat. Leider weis ich nicht, was nun zu tun ist. Dieses "neu mappen" klinkt interessannt, aber wie macht man das ?
        Gibt es irgendwo Infos zu diesem Thema, oder tritt dieses Problem vielleicht nur bei mir auf ?
        • S sagitarius
          BigChris
          #797
          @sagitarius
          Welche Version hast du denn vom Adapter?
          Bei war es nach einem Update auch so, ich habe dann die Version von NPM installiert. Dann ging es wieder.
          • R Offline
            Ronniboy
            #798
            Auch Ich habe das Problem, das sich die Datenpunkte in meinem Viessmann Adapter ab dem 18.8 nicht mehr aktualisieren. Da meine Heizung in Sommerbetrieb ist, ist mir dieses nicht aufgefallen.
            Eigentlich müssten doch alle Anwender dieses Problem haben.
            Meine Version 2.4.0
            B S 2 Antworten Letzte Antwort
            • R Ronniboy
              Meine Version 2.4.0
              BigChris
              schrieb am zuletzt editiert von BigChris
              #799
              @ronniboy
              Ich denke, dass viele nicht nachschauen, es nicht bemerkten. Ich habe es auch nur gemerkt, weil ich den Temperatursensor bei mir in der VIS / Ulanzi Clock benutze und verwundert war, dass es in der Nacht noch 29°C waren.
              Ich habe mir wie gesagt den aktellen Adapter aus NPM gezogen, dass ist die Version 2.4.3
              Damit kamen und kommen die Werte ohne weitere Änderungen wieder zuversichtlich rein. Ich habe es gerade noch mal verifiziert.
              FriedhofsblondF 1 Antwort Letzte Antwort
              • B BigChris
                @ronniboy
                FriedhofsblondF Offline
                Friedhofsblond
                #800
                @bigchris
                Moin,
                kann ich nicht sagen, bei mir kommen noch Daten über die API.
                • R Ronniboy
                  Meine Version 2.4.0
                  sagitarius
                  #801
                  @ronniboy
                  Danke für den Tip, ich hatte noch die Version 2.3.
                  Ich wusste nicht, das es schon eine neuere Version gibt, mit der 2.4.3, die über NVP angeboten wird scheint wieder alles zu funktionieren, vielen Dank für den Tip.
                  • P Offline
                    pasges
                    schrieb am zuletzt editiert von pasges
                    #802
                    Hallo Leute,
                    ich nutze den Adapter schon seit Jahren.
                    Seit dem 02.04.2025 13:01 Uhr kommt leider die Vorlauftemperatur nicht mehr rein von meiner Wärepumpe Vitocal 200.
                    Ich meine folgenden Punkt: viessmannapi.0.XXXX.0.features.heating.circuits.0.sensors.temperature.supply.properties.value.value,
                    Die Brauchwassertemperatur und Außentemperatur läuft wie gewohnt. Der Adapter ist auf Version 2.3.0.
                    Was könnte der Fehler sein?
                    Vielen Dank!
                    EDIT: ich habe nun gelesen, das die 2.4.3 wohl viele Probleme löst, das werde ich nun mal probieren.
                    • T tombox
                      Hi ich habe ein neuen Adapter für Viessman erstellt
                      Man benötigt eine ClientID von der Viessmann API
                      https://app.developer.viessmann-climatesolutions.com besuchen und eine Client ID mit diesen Optionen erstellen:
                      Google reCAPTCHA deaktivieren
                      Redirect URI: http://localhost:4200/
                      Die Client ID in die Einstellungen kopieren
                      Außentemperatur findet sich z.B. hier:
                      viessmannapi.0.XXXXX.0.features.heating.sensors.temperature.outside.properties.value.value
                      Weitere Beispiele siehe Unten
                      Remote Befehle sind möglich unter
                      viessmannapi.0.XXXXX.0.features.heating.dhw.temperature.main.commands.setTargetTemperature.setValue
                      Zum Installieren:
                      Via Adaptersuche
                      In den Instanzoptionen die jeweiligen Optionen einstellen.
                      Github
                      https://github.com/TA2k/ioBroker.viessmannapi
                      Kompatibilitätsliste:
                      https://documentation.viessmann.com/static/compatibility
                      Regelungen für Wand- oder Kompaktgeräte
                      Vitotronic 200, Typ HO1, HO1A, HO1B, HO1D, HO2B, HO2C
                      Vitotronic 200 RF, Typ HO1C, HO1E
                      Regelungen für bodenstehende Heizkessel
                      Vitotronic 200, Typ KO1B, KO2B, KW6, KW6A, KW6B, KW1, KW2, KW4, KW5
                      Vitotronic 300, Typ KW3
                      Regelungen für Wärmepumpen und Hybridgeräte
                      Vitotronic 200, Typ WO1A, WO1B, WO1C
                      Regelungen für Festbrennstoffkessel
                      Vitoligno 200-S mit Ecotronic (ab Softwarestand 2.03)
                      Vitoligno 250-S mit Ecotronic (ab Softwarestand 2.00)
                      Vitoligno 300-C mit Ecotronic (ab Softwarestand 2.12)
                      Vitoligno 300-P mit Vitotronic 200 FO1
                      Vitoligno 300-S mit Ecotronic (ab Softwarestand 2.04)
                      Liste aller Datenpunkte:
                      https://documentation.viessmann.com/static/iot/data-points
                      Frage zu fehlende Datenpunkte bitte direkt an Viessmann
                      https://www.viessmann-community.com/t5/The-Viessmann-API/bd-p/dev-viessmann-api
                      Beispiele:
                      Vorlauftemperatur:
                      viessmannapi.0.XXXX.features.heating.circuits.0.sensors.temperature.supply.properties.value.value,
                      Brennerstatus:
                      viessmannapi.0.XXXX.0.features.heating.burners.0.properties.active.value
                      Anzahl Zündungen:
                      viessmannapi.0.XXXXX.features.heating.burners.0.statistics.properties.starts.value
                      Betriebsstunden
                      viessmannapi.0.XXXXX.features.heating.burners.0.statistics.properties.hours.value
                      Kesseltemperatur
                      viessmannapi.0.XXXXX.features.heating.boiler.sensors.temperature.main.properties.unit.value
                      Kompressor aktiv:		viessmannapi.0.xxx.0.features.heating.compressors.0.properties.active.value
                      Heizkreispumpe aktiv:		viessmannapi.0.xxx.0.features.heating.circuits.1.circulation.pump.properties.status.value
                      Warmwasserbereitung:		viessmannapi.0.xxx.0.features.heating.dhw.charging.properties.active.value
                      Heizungsmodus:			viessmannapi.0.xxx.0.features.heating.circuits.1.operating.modes.active.properties.value.value
                      Heizprogramm:			viessmannapi.0.xxx.0.features.heating.circuits.1.operating.programs.active.properties.value.value
                      Temperatur Heizprogramm normal:	viessmannapi.0.xxx.0.features.heating.circuits.1.operating.programs.normal.properties.temperature.value
                      Temperatur Heizprogramm reduz.:	viessmannapi.0.xxx.0.features.heating.circuits.1.operating.programs.reduced.properties.temperature.value
                      Warmwasser Soll Temperatur:	viessmannapi.0.xxx.0.features.heating.dhw.temperature.properties.value.value
                      Warmwasser Ist Temperatur:	viessmannapi.0.xxx.0.features.heating.dhw.sensors.temperature.hotWaterStorage.properties.value.value
                      Temperatur Außensensor:		viessmannapi.0.xxx.0.features.heating.sensors.temperature.outside.properties.value.value
                      Statistik Kompressor Starts:	viessmannapi.0.xxx.0.features.heating.compressors.0.statistics.properties.starts.value
                      Statistik Kompressor Stunden:	viessmannapi.0.xxx.0.features.heating.compressors.0.statistics.properties.hours.value
                      Temperatursensoren der Heizkreise:   viessmannapi.0.xxxxxxx.0.features.heating.circuits.0.sensors.temperature.supply.properties.value.value
                      Primärkreis Vorlauftemperatur:		viessmann.0.xxx.0.features.heating.primaryCircuit.sensors.temperature.supply.properties.value.value
                      Sekundärkreis Vorlauftemperatur:	viessmann.0.xxx.0.features.heating.secondaryCircuit.sensors.temperature.supply.properties.value.value
                      Sekundärkreis Rücklauftemperatur:	viessmann.0.xxx.0.features.heating.secondaryCircuit.sensors.temperature.return.properties.value.value
                      ?					viessmann.0.xxx.0.features.heating.sensors.temperature.return.properties.value.value
                      Heizung an (Kompressor): viessmannapi.0.x.0.features.heating.compressors.0.properties.active.value
                      WW Temp viessmannapi.0.x.0.features.heating.dhw.sensors.temperature.hotWaterStorage.properties.value.value
                      HW Temp  viessmannapi.0.x.0.features.heating.buffer.sensors.temperature.main.properties.value.value
                      ZP features.heating.circuits.1.circulation.pump.properties.status.value
                      WP_Aussentemperatur 0.features.heating.sensors.temperature.outside.properties.value.value
                      WP_gemeinsame Vorlauftemperatur 0.features.heating.boiler.sensors.temperature.commonSupply.properties.value.value
                      WP_Temperatur Pufferspeicher 0.features.heating.buffer.sensors.temperature.main.properties.value.value
                      WP_Heizkörper_Umwälzpumpe ON/OFF 0.features.heating.circuits.0.circulation.pump.properties.status.value
                      WP_Heizkörper_Umwälzpumpe_Frostschutz 0.features.heating.circuits.0.frostprotection.properties.status.value
                      WP_Heizkörper_Niveau 0.features.heating.circuits.0.heating.curve.properties.shift.value
                      WP_Heizkörper_Neigung 0.features.heating.circuits.0.heating.curve.properties.slope.value
                      WP_Heizkörper_Zeitplan 0.features.heating.circuits.0.heating.schedule.properties.entries.value
                      WP_Heizkörper_Komfort_Solltemperatur 0.features.heating.circuits.0.operating.programs.comfortHeating.properties.temperature.value
                      WP_Heizkörper_Normal_Solltemperatur 0.features.heating.circuits.0.operating.programs.normalHeating.properties.temperature.value
                      WP_Heizkörper_Reduziert_Solltemperatur 0.features.heating.circuits.0.operating.programs.reducedHeating.properties.temperature.value
                      WP_Vorlauftemperatur Heizkörper 0.features.heating.circuits.0.sensors.temperature.supply.properties.value.value
                      ???? 0.features.heating.circuits.0.operating.programs.comfortEnergySaving.properties.reason.value
                      ???? 0.features.heating.circuits.0.operating.programs.normalEnergySaving.properties.reason.value
                      WP_Heizkörper_FBH ON/OFF 0.features.heating.circuits.1.circulation.pump.properties.status.value
                      WP_FBH_Umwälzpumpe_Frostschutz 0.features.heating.circuits.1.frostprotection.properties.status.value
                      WP_FBH_Niveau 0.features.heating.circuits.1.heating.curve.properties.shift.value
                      WP_FBH_Neigung 0.features.heating.circuits.1.heating.curve.properties.slope.value
                      WP_FBH_Zeitplan 0.features.heating.circuits.1.heating.schedule.properties.entries.value
                      WP_FBH_Komfort_Solltemperatur 0.features.heating.circuits.1.operating.programs.comfortHeating.properties.temperature.value
                      WP_FBH_Normal_Solltemperatur 0.features.heating.circuits.1.operating.programs.normalHeating.properties.temperature.value
                      WP_FBH_Reduziert_Solltemperatur 0.features.heating.circuits.1.operating.programs.reducedHeating.properties.temperature.value
                      WP_FBH_Vorlauftemperatur 0.features.heating.circuits.1.sensors.temperature.supply.properties.value.value
                      WP_Stromverbrauch_HEUTE 0.features.heating.power.consumption.summary.heating.properties.currentDay.value
                      WP_Stromverbrauch_MONAT 0.features.heating.power.consumption.summary.heating.properties.currentMonth.value
                      WP_Stromverbrauch_JAHR 0.features.heating.power.consumption.summary.heating.properties.currentYear.value
                      WP_Stromverbrauch_LETZTER_MONAT 0.features.heating.power.consumption.summary.heating.properties.lastMonth.value
                      WP_Stromverbrauch_LETZTEN_7_TAGE 0.features.heating.power.consumption.summary.heating.properties.lastSevenDays.value
                      WP_Stromverbrauch_LETZTES_JAHR 0.features.heating.power.consumption.summary.heating.properties.lastYear.value
                      WP_Primärkreis_Temperatur 0.features.heating.primaryCircuit.sensors.temperature.supply.properties.value.value
                      WP_Sekundärkreis_Temperatur 0.features.heating.secondaryCircuit.sensors.temperature.supply.properties.value.value
                      WP_Rücklauftemperatur 0.features.heating.sensors.temperature.return.properties.value.value
                      WP_Volumenstrom 0.features.heating.sensors.volumetricFlow.allengra.properties.value.value
                      Betriebsstunden Verdichter 0.features.heating.compressors.0.statistics.properties.hours.value
                      Beispiel zum setzen eines Schedule:
                      var standard = '{"mon":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"tue":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],\
                                    "wed":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"thu":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],\
                                    "fri":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"sat":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],\
                                    "sun":[{"start":"00:00","end":"24:00","mode":"standard","position":0}]}'
                      setState("viessmannapi.0.xxxxxxx.0.features.ventilation.schedule.commands.setSchedule.setValue", JSON.parse(standard));
                      Beispiel zirkulationspumpe
                      // schedule zum einschalten, allerdings nur zwischen 6 und 21 uhr
                      var pump_on = '{"mon":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"tue":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"wed":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"thu":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"fri":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"sat":[{"start":"06:00","end":"21:00","mode":"on","position":0}],"sun":[{"start":"06:00","end":"21:00","mode":"on","position":0}]}'
                      // schedule leeren - pumpe ausschalten
                      var pump_off = '{"mon":[], "tue":[],"wed":[],"thu":[],"fri":[],"sat":[],"sun":[]}'
                      setState("viessmannapi.0.xxx.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue", JSON.parse(pump_on)); // oder pump_off
                      Die Max. Heizleistung gibt es nicht als API Datenpunkt, kann nur am Gerät geändert werden.
                      Kostenlose Paket enthält:
                      Zum Installieren:
                      S Online
                      S Online
                      Skippy07
                      #803
                      @tombox sagte in Test ViessmannAPI v2.0.0:
                      https://app.developer.viessmann.com besuchen und eine Client ID mit diesen Optionen erstellen:
                      vielleicht kann man den Link mal aktualisieren, der ist veraltet. Im Adapter wird auch noch auf die alte Seite verwiesen. Danke!
                      https://app.developer.viessmann-climatesolutions.com/
                      Gruss
                      Stefan
                      • R Offline
                        Ronniboy
                        #804
                        ich habe die Version 2.4.4.
                        Jetzt erhalte ich in 2 min Takt folgende Meldungen.
                        • R Ronniboy
                          #805
                          @Ronniboy
                          Ist was für GitHub.
                          Leg ein Issue an.
                          https://github.com/TA2k/ioBroker.viessmannapi/issues
                          Und bitte keine Bildchen vom Log. Das 'richtige' Log findet sich unter
                          iob logs
                            Derda 0
                            #806
                            seit heute Morgen 1:00 Uhr liefert die API mir etliche Daten nicht mehr, z.B. features.heating.compressors.0.heat, features.heating.compressors.0.power, features.heating.heat.production.current, features.heating.heat.production.dhw, features.heating.heat.production.heating, aber features.heating.heat.production.cooling und features.heating.heat.production.summary. Bin ich da allein?
                            • N Offline
                              N Offline
                              nobbiman
                              #807
                              Bei mir erscheint nur der Wert "heating.compressors.0.power"!
                                Derda 0
                                #808
                                die Daten fehlen bei mir noch immer. Ich habe mit log-level debug nachgeschaut, welche Daten von Viessmann noch geliefert werden. Das sind fast alle bis auf diese Liste, jeweils mit Timestamp des letzten Eintrags in iobroker:
                                Verglichen habe ich mit den Features, für die Daten in iobroker vorhanden. Ein paar davon scheinen schon länger obsolet zu sein, aber vor allem die gelb hinterlegten sind sehr ärgerlich. Bin das nur ich oder fehlen die Daten bei Euch auch?
                                  Derda 0
                                  #809
                                  @tombox Habe die neueste Version von github gezogen und mit der featurelist gespielt.
                                  Featurelist = "heating.compressors.0.power." ergibt
                                  2026-02-13 14:09:38.574 - debug: viessmannapi.0 (4819) Feature filter: 327 -> 0 features
                                  " ergibt
                                  2026-02-13 14:10:20.029 - debug: viessmannapi.0 (4834) Feature filter: 327 -> 9 features
                                  und die Daten unter compressors.0 erscheinen, aber heat.* und power.* nicht.
                                  Any ideas?
                                  • D Derda 0
                                    " ergibt
                                    Any ideas?
                                    tombox
                                    #810
                                    @Derda-0 mit der aktuellen GitHub version sollte das gehen
                                    heating.compressors.,heating.boiler.
                                    Pattern Matcht
                                    heating.* heating, heating.boiler, heating.boiler.xxx, ...
                                    heating.compressors.* heating.compressors, heating.compressors.0, heating.compressors.0.power, ...
                                    heating.compressors.0.power.* heating.compressors.0.power, heating.compressors.0.power.consumption, ...
                                    heating.compressors.0.power Nur exakt heating.compressors.0.power
                                    • T tombox
                                      Pattern Matcht
                                      Derda 0
                                      #811
                                      @tombox Sorry, man sollte so was nicht zwischen Tür und Angel schreiben. Das Problem sind heating.compressors.0.heat.production.current, heating.compressors.0.power.consumption.current, heating.heat.production.current und heating.heat.production.total, die fehlen. Die anderen heat.* und compressors.* werden weiter geliefert.
                                      Die Featurelist funktioniert für mich wie beschrieben.
                                      • I Offline
                                        I Offline
                                        io2345
                                        schrieb am zuletzt editiert von io2345
                                        #812
                                        Was bedeutet diese Meldung?:
                                        viessmannapi.0
                                        2026-02-15 12:41:11.460 error Error: getaddrinfo ENOTFOUND iam.viessmann.com
                                        viessmannapi.0
                                        2026-02-15 12:41:11.354 info starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v22.22.0, js-controller: 7.0.7
                                        Außerdem steht in der Adapterübersicht: Verfügbare Version "nicht gewartet". Ist das ok so?
                                        • I io2345
                                          viessmannapi.0
                                          viessmannapi.0
                                          #813
                                          @io2345 sagte in Test ViessmannAPI v2.0.0:
                                          Das der Host unter der Adresse nicht gefunden wird.
                                          Dann hast du keine Version aus einem Repository sondern 'irgendwas von irgendwoher' installiert. Vermutlich direkt aus dem GitHub geangelt.
                                          github:	2.4.4
                                          latest:	2.4.4 for 60 days
                                          stable:	-.-.-
                                          Es gibt also keine stabile Version. Und deine 2.3.0 ist veraltet.
                                          I 1 Antwort Letzte Antwort
