  4. Kein Admin nach Update
36 Beiträge 5 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • R RJ3n53n
    Sorry, hat einen Moment gedauert.
    Ich muss den Beitrag teilen.
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Hardware Vendor : Synology
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v11.0.0
    Virtualization  : docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     16:09:33 up 45 days, 11:50,  0 user,  load average: 2.51, 1.98, 2.03
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
    Sat Sep 13 14:09:33 UTC 2025
    Sat Sep 13 16:09:33 CEST 2025
    CEST +0200
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    sudo: unable to resolve host ioBroker: Name or service not known
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    System has not been booted with systemd as init system (PID 1). Can't operate.
    Failed to connect to bus: Host is down
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:             16G        5.9G        859M        208M         10G         10G
    Swap:            12G        996M         11G
    Total:           28G        6.9G         11G
    Active iob-Instances:   32
            15854 M total memory
             5585 M used memory
             6429 M active memory
             6748 M inactive memory
              819 M free memory
              658 M buffer memory
             9395 M swap cache
            11563 M total swap
              950 M used swap
            10613 M free swap
    top - 16:09:34 up 45 days, 11:50,  0 user,  load average: 2.51, 1.98, 2.03
    Tasks:  40 total,   1 running,  39 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15854.0 total,    819.9 free,   5584.7 used,  10054.0 buff/cache
    MiB Swap:  11563.9 total,  10613.5 free,    950.5 used.  10269.3 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    none                   aufs    13T  1.4T   12T  11% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 ext4    13T  1.4T   12T  11% /opt/iobroker
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/acpi
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/scsi
    tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/firmware
    Show mounted filesystems:
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  none        aufs   rw,relatime,si=faf9736b0331140a,dio,d
    irperm1
    |-/opt/iobroker    /dev/mapper/cachedev_0[/docker/ioBroker_mount]        ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0
    ,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@docker/containers/d3241ec779e3b13b8c77eab6b9b4347d110de1b7dfaa04ae33ac8b9de0fa5daf/resolv.conf] ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0
    |-/etc/hostname    /dev/mapper/cachedev_0[/@docker/containers/d3241ec779e3b13b8c77eab6b9b4347d110de1b7dfaa04ae33ac8b9de0fa5daf/hostname]    ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0
    `-/etc/hosts       /dev/mapper/cachedev_0[/@docker/containers/d3241ec779e3b13b8c77eab6b9b4347d110de1b7dfaa04ae33ac8b9de0fa5daf/hosts]       ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0
    /var:
    35M     /var/
    33M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    14M     /var/lib/dpkg
    /opt/iobroker/backups:
    12K     /opt/iobroker/backups/
    8.0K    /opt/iobroker/backups/@eaDir
    /opt/iobroker/iobroker-data:
    662M    /opt/iobroker/iobroker-data/
    423M    /opt/iobroker/iobroker-data/files
    177M    /opt/iobroker/iobroker-data/backup-objects
    73M     /opt/iobroker/iobroker-data/files/vis-2
    56M     /opt/iobroker/iobroker-data/files/vis
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
     zigbee.X
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.19.0
    /usr/bin/node           v22.19.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.19.0-1nodesource1
      Candidate: 22.19.0-1nodesource1
      Version table:
     *** 22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
          22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @rj3n53n sagte in Kein Admin nach Update:
    Nein, musst du nicht.
    Die Ausgabe passt normalerweise in Gänze in ein Posting rein.
    R 1 Antwort Letzte Antwort
    • R RJ3n53n
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v11.0.0
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
      CEST +0200
      Etc/UTC
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/opt/iobroker
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Swap:            12G        996M         11G
      Total:           28G        6.9G         11G
               5585 M used memory
                819 M free memory
                658 M buffer memory
               9395 M swap cache
              11563 M total swap
                950 M used swap
              10613 M free swap
      *** FILESYSTEM ***
      irperm1
      /var:
      35M     /var/
      33M     /var/lib
      19M     /var/lib/apt
      14M     /var/lib/dpkg
      USB-Devices by-id:
       zigbee.X
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
      R
      R
      RJ3n53n
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 13447)
      Core adapters versions
      js-controller:  6.0.11
      admin:          3.7.9
      javascript:     8.9.2
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
        system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
        system.adapter.daikin.0                 : daikin                : ioBroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
        system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
        system.adapter.ds18b20.0                : ds18b20               : ioBroker                                 - disabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      + system.adapter.evcc.0                   : evcc                  : ioBroker                                 -  enabled, port: 7070
        system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.3                   : ical                  : ioBroker                                 - disabled
        system.adapter.iceroad.0                : iceroad               : ioBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.lcn.0                    : lcn                   : ioBroker                                 - disabled, port: 4114
        system.adapter.lorawan.0                : lorawan               : ioBroker                                 - disabled, port: 8883
        system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
        system.adapter.mqtt-client.0            : mqtt-client           : ioBroker                                 - disabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 192.168.178.70
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : io    : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.welcome.0                : welcome               : ioBroker                                 - disabled, port: 80, bind: 192.168.178.70, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
        system.adapter.wiffi-wz.0               : wiffi-wz              : ioBroker                                 - disabled
      + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
      Broker                                 -  enabled
      + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
        system.adapter.node-red.0               : node-red              : ioBroker                                 - disabled, port: 6335, bind: 192.168.178.70
      + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
        system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
        system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      + system.adapter.plenticore.0             : plenticore            : ioBroker                                 -  enabled, port: 443
      + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
        system.adapter.rpi2.0                   : rpi2                  : ioBroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
      + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
      + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : ioBroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
      + system.adapter.web.0                    : web
      + instance is alive
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.2    , installed 3.7.9  [Updatable]
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "daikin"       : 1.5.1    , installed 1.5.1
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "devices"      : 1.2.8    , installed 1.2.8
      Adapter    "ds18b20"      : 3.0.1    , installed 3.0.1
      Adapter    "evcc"         : 0.2.3    , installed 0.2.3
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 6.0.11 [Updatable]
      Adapter    "lcn"          : 3.0.1    , installed 3.0.1
      Adapter    "lorawan"      : 1.10.22  , installed 1.6.0  [Updatable]
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
      Adapter    "netatmo-crawler": 1.0.0  , installed 1.0.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "pegelalarm"   : 1.3.9    , installed 1.3.9
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "snmp"         : 3.3.0    , installed 3.3.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tibberlink"   : 5.0.0    , installed 5.0.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 6.2.5  [Updatable]
      Adapter    "welcome"      : 1.0.2    , installed 1.0.2
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Objects and States
      Objects:        14283
      States:         11962
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1021077767 -
      tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47362      -
      tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47361      -
      tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47360      -
      tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47348      -
      tcp        0      0 0.0.0.0:9002            0.0.0.0:*               LISTEN      0          181183     -
      tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN      0          102514     -
      tcp        0      0 0.0.0.0:23883           0.0.0.0:*               LISTEN      0          202376     -
      tcp        0      0 0.0.0.0:3307            0.0.0.0:*               LISTEN      66         92206      -
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          52752      -
      tcp        0      0 127.0.0.1:2380          0.0.0.0:*               LISTEN      0          140798     -
      tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          244860     -
      tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          244859     -
      tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          244858     -
      tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          244856     -
      tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          53285      -
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          24795      -
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47368      -
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47367      -
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47366      -
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47350      -
      tcp        0      0 192.168.178.70:2001     0.0.0.0:*               LISTEN      1000       1021085318 -
      tcp        0      0 127.0.0.1:2385          0.0.0.0:*               LISTEN      0          228518     -
      tcp        0      0 192.168.178.70:50001    0.0.0.0:*               LISTEN      0          92703      -
      tcp        0      0 192.168.178.70:50002    0.0.0.0:*               LISTEN      0          95823      -
      tcp        0      0 192.168.178.70:49170    0.0.0.0:*               LISTEN      254178     92148      -
      tcp        0      0 127.0.0.1:5555          0.0.0.0:*               LISTEN      0          299981638  -
      tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN      0          171331     -
      tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          40192      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      0          824890506  -
      tcp        0      0 0.0.0.0:23000           0.0.0.0:*               LISTEN      0          202297     -
      tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         76580      -
      tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          54232      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      0          212185     -
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1021103558 -
      tcp        0      0 192.168.178.70:2010     0.0.0.0:*               LISTEN      1000       1021086258 -
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          183324     -
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47374      -
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47373      -
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47372      -
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47352      -
      tcp        0      0 127.0.0.1:30300         0.0.0.0:*               LISTEN      0          231391     -
      tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          39166      -
      tcp        0      0 127.0.0.1:16509         0.0.0.0:*               LISTEN      0          221036     -
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          52751      -
      tcp        0      0 0.0.0.0:6335            0.0.0.0:*               LISTEN      0          1021099404 -
      tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          266626     -
      tcp        0      0 0.0.0.0:5888            0.0.0.0:*               LISTEN      0          248223     -
      tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          53264      -
      tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          41249      -
      tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          150084     -
      tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          824943935  -
      tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          30131      -
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1021077778 -
      tcp        0      0 0.0.0.0:23080           0.0.0.0:*               LISTEN      0          201307     -
      tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          47356      -
      tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          47355      -
      tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          47354      -
      tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          47346      -
      tcp6       0      0 :::5001                 :::*                    LISTEN      0          47365      -
      tcp6       0      0 :::5001                 :::*                    LISTEN      0          47364      -
      tcp6       0      0 :::5001                 :::*                    LISTEN      0          47363      -
      tcp6       0      0 :::5001                 :::*                    LISTEN      0          47349      -
      tcp6       0      0 :::9002                 :::*                    LISTEN      0          182284     -
      tcp6       0      0 :::23883                :::*                    LISTEN      0          200401     -
      tcp6       0      0 :::139                  :::*                    LISTEN      0          52750      -
      tcp6       0      0 :::5357                 :::*                    LISTEN      0          244863     -
      tcp6       0      0 :::5357                 :::*                    LISTEN      0          244862     -
      tcp6       0      0 :::5357                 :::*                    LISTEN      0          244861     -
      tcp6       0      0 :::5357                 :::*                    LISTEN      0          244857     -
      tcp6       0      0 :::4045                 :::*                    LISTEN      0          53287      -
      tcp6       0      0 :::1935                 :::*                    LISTEN      233155     101868     -
      tcp6       0      0 :::111                  :::*                    LISTEN      0          24798      -
      tcp6       0      0 :::80                   :::*                    LISTEN      0          47371      -
      tcp6       0      0 :::80                   :::*                    LISTEN      0          47370      -
      tcp6       0      0 :::80                   :::*                    LISTEN      0          47369      -
      tcp6       0      0 :::80                   :::*                    LISTEN      0          47351      -
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1021107683 -
      tcp6       0      0 :::8086                 :::*                    LISTEN      1000       1005191441 -
      tcp6       0      0 :::662                  :::*                    LISTEN      0          40196      -
      tcp6       0      0 :::3000                 :::*                    LISTEN      0          824888236  -
      tcp6       0      0 :::23000                :::*                    LISTEN      0          202304     -
      tcp6       0      0 :::3001                 :::*                    LISTEN      0          206500     -
      tcp6       0      0 :::1883                 :::*                    LISTEN      0          181200     -
      tcp6       0      0 :::443                  :::*                    LISTEN      0          47377      -
      tcp6       0      0 :::443                  :::*                    LISTEN      0          47376      -
      tcp6       0      0 :::443                  :::*                    LISTEN      0          47375      -
      tcp6       0      0 :::443                  :::*                    LISTEN      0          47353      -
      tcp6       0      0 :::892                  :::*                    LISTEN      0          39170      -
      tcp6       0      0 :::3261                 :::*                    LISTEN      0          54081      -
      tcp6       0      0 :::445                  :::*                    LISTEN      0          52749      -
      tcp6       0      0 :::5566                 :::*                    LISTEN      0          81073      -
      tcp6       0      0 :::6335                 :::*                    LISTEN      0          1021097460 -
      tcp6       0      0 :::3263                 :::*                    LISTEN      0          54080      -
      tcp6       0      0 :::5888                 :::*                    LISTEN      0          247603     -
      tcp6       0      0 :::3264                 :::*                    LISTEN      0          54082      -
      tcp6       0      0 :::3265                 :::*                    LISTEN      0          989674843  -
      tcp6       0      0 :::2049                 :::*                    LISTEN      0          53275      -
      tcp6       0      0 :::6690                 :::*                    LISTEN      0          150085     -
      tcp6       0      0 :::9443                 :::*                    LISTEN      0          824943312  -
      tcp6       0      0 :::23080                :::*                    LISTEN      0          202410     -
      tcp6       0      0 :::5000                 :::*                    LISTEN      0          47359      -
      tcp6       0      0 :::5000                 :::*                    LISTEN      0          47358      -
      tcp6       0      0 :::5000                 :::*                    LISTEN      0          47357      -
      tcp6       0      0 :::5000                 :::*                    LISTEN      0          47347      -
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          24793      -
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          37719      -
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          1024636905 -
      udp        0      0 192.168.178.70:137      0.0.0.0:*                           0          1024636904 -
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1024636840 -
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          1024636907 -
      udp        0      0 192.168.178.70:138      0.0.0.0:*                           0          1024636906 -
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1024636841 -
      udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          41248      -
      udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          37717      -
      udp        0      0 192.168.178.70:500      0.0.0.0:*                           0          129298     -
      udp        0      0 127.0.0.1:626           0.0.0.0:*                           0          37816      -
      udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          40190      -
      udp        0      0 0.0.0.0:41779           0.0.0.0:*                           0          1019960907 -
      udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          39164      -
      udp        0      0 192.168.178.70:1701     0.0.0.0:*                           0          125536     -
      udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          27285      -
      udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          27284      -
      udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          27283      -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          243812     -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          92706      -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           254178     92151      -
      udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          53274      -
      udp        0      0 127.0.0.1:35108         0.0.0.0:*                           254178     92149      -
      udp        0      0 127.0.0.1:43807         0.0.0.0:*                           0          92704      -
      udp        0      0 0.0.0.0:43930           0.0.0.0:*                           1000       1021092392 -
      udp        0      0 0.0.0.0:52642           0.0.0.0:*                           0          914611939  -
      udp        0      0 0.0.0.0:19996           0.0.0.0:*                           233155     102485     -
      udp        0      0 0.0.0.0:19997           0.0.0.0:*                           233155     102484     -
      udp        0      0 0.0.0.0:19998           0.0.0.0:*                           233155     102483     -
      udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         225978     -
      udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          53284      -
      udp        0      0 192.168.178.70:4500     0.0.0.0:*                           0          129299     -
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1021109873 -
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          914611937  -
      udp        0      0 0.0.0.0:54983           0.0.0.0:*                           0          24794      -
      udp        0      0 0.0.0.0:55443           0.0.0.0:*                           1000       1021094364 -
      udp        0      0 127.0.0.1:31067         0.0.0.0:*                           0          128719     -
      udp        0      0 127.0.0.1:31068         0.0.0.0:*                           0          128720     -
      udp        0      0 192.168.178.70:55900    0.0.0.0:*                           254178     92150      -
      udp        0      0 192.168.178.70:55901    0.0.0.0:*                           0          92705      -
      udp6       0      0 :::57209                :::*                                0          24797      -
      udp6       0      0 :::111                  :::*                                0          24796      -
      udp6       0      0 :::123                  :::*                                0          37720      -
      udp6       0      0 ::1:323                 :::*                                0          37718      -
      udp6       0      0 fe80::211:32ff:fec5:546 :::*                                0          387459     -
      udp6       0      0 :::662                  :::*                                0          40194      -
      udp6       0      0 :::892                  :::*                                0          39168      -
      udp6       0      0 :::2049                 :::*                                0          53276      -
      udp6       0      0 :::3702                 :::*                                99         225981     -
      udp6       0      0 :::4045                 :::*                                0          53286      -
      udp6       0      0 :::5353                 :::*                                0          914611938  -
      udp6       0      0 :::47739                :::*                                0          914611940  -
      2025-09-13 16:05:27.775  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
      2025-09-13 16:05:40.023  - info: host.ioBroker instance system.adapter.netatmo-crawler.0 in version "1.0.0" started with pid 21227
      2025-09-13 16:05:42.531  - info: netatmo-crawler.0 (21227) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.19.0, js-controller: 6.0.11
      2025-09-13 16:05:42.583  - info: netatmo-crawler.0 (21227) Getting data for stationid:70:ee:50:03:e0:ea
      2025-09-13 16:05:44.349  - info: netatmo-crawler.0 (21227) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
      2025-09-13 16:05:44.885  - info: host.ioBroker instance system.adapter.netatmo-crawler.0 having pid 21227 terminated with code 0 (NO_ERROR)
      2025-09-13 16:06:20.343  - info: shelly.0 (679) [MQTT] Device with client id "shellyplusplugs-d4d4daedddb0" connected from 10.10.30.141!
      2025-09-13 16:06:30.352  - info: shelly.0 (679) [MQTT] Client Close: 10.10.30.141 (shellyplusplugs / shellyplusplugs-d4d4daedddb0 / shellyplusplugs#d4d4daedddb0#1) (false)
      2025-09-13 16:06:37.367  - error: shelly.0 (679) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'repla
      ce')
      2025-09-13 16:06:37.368  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
      2025-09-13 16:07:04.339  - info: web.0 (774) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2025-09-13 16:07:05.187  - info: web.0 (774) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2025-09-13 16:07:25.485  - info: shelly.0 (679) [MQTT] Device with client id "shellyplusplugs-d4d4daedddb0" connected from 10.10.30.141!
      2025-09-13 16:07:35.479  - info: shelly.0 (679) [MQTT] Client Close: 10.10.30.141 (shellyplusplugs / shellyplusplugs-d4d4daedddb0 / shellyplusplugs#d4d4daedddb0#1) (false)
      2025-09-13 16:07:36.276  - error: shelly.0 (679) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'repla
      ce')
      2025-09-13 16:07:36.277  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
      2025-09-13 16:08:31.087  - info: shelly.0 (679) [MQTT] Device with client id "shellyplusplugs-d4d4daedddb0" connected from 10.10.30.141!
      2025-09-13 16:08:41.065  - info: shelly.0 (679) [MQTT] Client Close: 10.10.30.141 (shellyplusplugs / shellyplusplugs-d4d4daedddb0 / shellyplusplugs#d4d4daedddb0#1) (false)
      2025-09-13 16:08:41.206  - error: shelly.0 (679) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'repla
      ce')
      2025-09-13 16:08:41.206  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
      2025-09-13 16:09:34.363  - info: web.0 (774) <== Disconnect system.user.admin from ::ffff:192.168.178.32 vis.0
      2025-09-13 16:09:38.273  - info: shelly.0 (679) [MQTT] Device with client id "shellyplusplugs-d4d4daedddb0" connected from 10.10.30.141!
      2025-09-13 16:09:48.264  - info: shelly.0 (679) [MQTT] Client Close: 10.10.30.141 (shellyplusplugs / shellyplusplugs-d4d4daedddb0 / shellyplusplugs#d4d4daedddb0#1) (false)
      2025-09-13 16:09:55.928  - error: shelly.0 (679) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'repla
      ce')
      2025-09-13 16:09:55.928  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
      iob diag has finished.
        R
        R
        RJ3n53n
        • R RJ3n53n
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v11.0.0
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
          CEST +0200
          Etc/UTC
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          Display-Manager:
          Desktop:
          Session:
          *** MEMORY ***
          Swap:            12G        996M         11G
          Total:           28G        6.9G         11G
                   5585 M used memory
                    819 M free memory
                    658 M buffer memory
                   9395 M swap cache
                  11563 M total swap
                    950 M used swap
                  10613 M free swap
          *** FILESYSTEM ***
          irperm1
          /var:
          35M     /var/
          33M     /var/lib
          19M     /var/lib/apt
          14M     /var/lib/dpkg
          USB-Devices by-id:
           zigbee.X
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.3
          /usr/bin/npx            10.9.3
          nodejs:
            Version table:
          • R RJ3n53n
            Thomas BraunT
            Thomas BraunT
            @rj3n53n
            Damit kommste halt nicht mehr weit...
            Dringendst alles updaten. Inkl. js-controller usw.
              @rj3n53n
              R
              R
              RJ3n53n
              Ich hatte eigentlich regelmäßige Updates gemacht, wenn sie angezeigt wurden.
              Kann man das jetzt noch glattziehen?
              • R RJ3n53n
                Thomas BraunT
                Thomas BraunT
                Bestimmt. Aber bei Docker hab ich keine Aktien.
                  R
                  R
                  RJ3n53n
                  Im Container Manager hatte ich zeitnah jedes Update gemacht, wenn es angezeigt wurde.
                  Hab aber trotzdem vielen Dank für Deine Hilfe.
                    R
                    R
                    RJ3n53n
                    Wie kann ich das ändern?
                    • R RJ3n53n
                      keine Ahnung!
                      mit Containern kenne ich mich nicht aus, mit Docker schon gar nicht.
                      Wenn das eine native Installation wäre würde ich versuchen in kleinen Schritten die Versionen hochzubringen.
                      Ob man das bei Docker darf weiss ich nicht.
                      Ob die nötigen Versionen überhaupt noch verfügbar sind weiß ich auch nicht.
                      Wenn das eine native Installation wäre, würde ich zu einer Neuinstallation mit anschließendem wiederherstellen des letzten Backups taten.
                      Ob und wie das bei Docker geht entzieht sich meiner Kenntnis
                        keine Ahnung!
                        R
                        R
                        RJ3n53n
                        schrieb am zuletzt editiert von RJ3n53n
                        Hab trotzdem vielen Dank für Deine Antwort.
                        • CodierknechtC
                          CodierknechtC
                          Codierknecht
                          @RJ3n53n
                          Sind alle benötigten Container-Ports gemappt?
                          Läuft da 'ne Firewall?
                          Ich empfehle außerdem, das Ganze auf ein "Projekt" zu migrieren. Das lässt sich deutlich einfacher administrieren als das Gefummel an irgendwelchen Container-Einstellungen. Und zum Update muss lediglich das Projekt neu gestsartet werden.
                          Siehe hier: https://forum.iobroker.net/topic/82045/installtion-ffmpeg/6?_=1757840464651
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          • CodierknechtC Codierknecht
                            @RJ3n53n
                            @codierknecht sagte in Kein Admin nach Update:
                            Sind alle benötigten Ports nach außen freigegeben?
                            @RJ3n53n
                            bitte nicht missverstehen!!
                            nicht ins Internet, nur aus dem/in den Container weitergeleitet
                              @RJ3n53n
                              CodierknechtC
                              CodierknechtC
                              Codierknecht
                              Danke für den Hinweis. Hab's korrigiert.
                              Nicht dass da jemand auf komische Ideen kommt ;-)
                              • R
                                R
                                RJ3n53n
                                @codierknecht
                                An den Ports habe ich nichts geändert. Bisher hatte es ja funktioniert.
                                Ich schaue mir gerade mal den Link an, den Du angehängt hast. Ich weiß gerade nicht, wie Du das mit ein Projekt meinst.
                                Vielen Dank aber schon mal für den Tipp sowie den Link.
                                • R RJ3n53n
                                  @codierknecht
                                  CodierknechtC
                                  CodierknechtC
                                  Codierknecht
                                  Ich vermute mal: Du hast das bislang über den Container-Manager als Container aufgesetzt.
                                  Dann muss man den ganzen Kram "von Hand" passend einstellen. Volumes, Ports, Variablen etc.
                                  Man kann das im Container-Manager auch als "Projekt" aufsetzen. Dann wird die komplette Konfiguration in einer YAML-Datei abgelegt. In Docker nennt sich das "Compose" und in Portainer "Stacks". Ist aber alles das gleiche.
                                  Als Quelle wählst Du "docker-compose.yml erstellen" und fügst dann den folgenden Inhalt in den Editor ein.
                                  Ein grundlegendes docker-compose.yml für ioBroker könnte so aussehen:
                                  services:
                                    iobroker:
                                      container_name: ioBroker
                                      image: buanet/iobroker:latest
                                      hostname: iobroker
                                      network_mode: "host"
                                      volumes:
                                        - /volume1/Docker/ioBroker:/opt/iobroker
                                      environment:
                                        PACKAGES: "nano"
                                        AVAHI: "true"
                                      restart: unless-stopped
                                  Muss halt ggf. etwas an die eigenen Gegebenheiten angepasst werden.
                                  Man beachte hier: Der Container läuft als "host". Man muss also keine Ports speziell mappen.
                                  Könnte allerding schiefgehen, wenn auf der Synology noch ander Dienste (WebStation, Fotos usw.) laufen, die Ports beanspruchen die auch vom ioBroker verwendet werden.
                                    services:
                                      iobroker:
                                        hostname: iobroker
                                        volumes:
                                        environment:
                                          PACKAGES: "nano"
                                          AVAHI: "true"
                                    R
                                    R
                                    RJ3n53n
                                    @codierknecht
                                    Okay, jetzt weiß ich, was Du meinst. Ja, so hatte ich das gemacht. Eingerichttet hatte ich es nach einer Anleitung. Noch bevor es bei Synology Container-Manager hieß. Da war damals auch beschrieben, welche Ports ich öffnen musste.
                                    • R RJ3n53n
                                      @codierknecht
                                      CodierknechtC
                                      CodierknechtC
                                      Codierknecht
                                      Seit DSM 7 gibt's den Container-Manager und damit auch die "Projekte".
                                      Macht das Ganze deutlich einfacher.
                                      Wenn der Container im Host-Mode läuft, muss man keine Ports mehr freigeben.
                                      Solange auf der Syno nix läuft was dem Container da in die Suppe spucken kann, spart man sich die ganze Port-Litanei.
                                        R
                                        R
                                        RJ3n53n
                                        @codierknecht
                                        Ich hab da ein oder andere auf der Syno am Laufen. Aber auch da gab es bisher keine Probleme.
                                        • R RJ3n53n
                                          @codierknecht
                                          CodierknechtC
                                          CodierknechtC
                                          Codierknecht
                                          @rj3n53n
                                          Solange die Ports sich da nicht in die Quere kommen, passt das.
                                          R HomoranH 2 Antworten Letzte Antwort
                                          84.1k
