  4. Kein Admin nach Update
36 Beiträge 5 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • R RJ3n53n
    iob start admin ohne Erfolg
    iob diag beötigst Du da den kompletten Ausdruck? Oder etwas bestimmtes? Der komplette Ausdruck geht über mehrere Seiten.
    Thomas BraunT
    Thomas BraunT
    @rj3n53n
    Alles...
    R 1 Antwort Letzte Antwort
      @rj3n53n
      Alles...
      R
      R
      RJ3n53n
      Sorry, hat einen Moment gedauert.
      Ich muss den Beitrag teilen.
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Hardware Vendor : Synology
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v11.0.0
      Virtualization  : docker
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       16:09:33 up 45 days, 11:50,  0 user,  load average: 2.51, 1.98, 2.03
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
      *** TIME AND TIMEZONES ***
      Sat Sep 13 14:09:33 UTC 2025
      Sat Sep 13 16:09:33 CEST 2025
      CEST +0200
      Etc/UTC
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      sudo: unable to resolve host ioBroker: Name or service not known
      HOME=/opt/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      System has not been booted with systemd as init system (PID 1). Can't operate.
      Failed to connect to bus: Host is down
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Mem:             16G        5.9G        859M        208M         10G         10G
      Swap:            12G        996M         11G
      Total:           28G        6.9G         11G
      Active iob-Instances:   32
              15854 M total memory
               5585 M used memory
               6429 M active memory
               6748 M inactive memory
                819 M free memory
                658 M buffer memory
               9395 M swap cache
              11563 M total swap
                950 M used swap
              10613 M free swap
      top - 16:09:34 up 45 days, 11:50,  0 user,  load average: 2.51, 1.98, 2.03
      Tasks:  40 total,   1 running,  39 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15854.0 total,    819.9 free,   5584.7 used,  10054.0 buff/cache
      MiB Swap:  11563.9 total,  10613.5 free,    950.5 used.  10269.3 avail Mem
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem             Type   Size  Used Avail Use% Mounted on
      none                   aufs    13T  1.4T   12T  11% /
      tmpfs                  tmpfs   64M     0   64M   0% /dev
      tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
      shm                    tmpfs   64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev_0 ext4    13T  1.4T   12T  11% /opt/iobroker
      tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/acpi
      tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/scsi
      tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/firmware
      Show mounted filesystems:
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  none        aufs   rw,relatime,si=faf9736b0331140a,dio,d
      irperm1
      |-/opt/iobroker    /dev/mapper/cachedev_0[/docker/ioBroker_mount]        ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0
      ,usrjquota=aquota.user,grpjquota=aquota.group
      |-/etc/resolv.conf /dev/mapper/cachedev_0[/@docker/containers/d3241ec779e3b13b8c77eab6b9b4347d110de1b7dfaa04ae33ac8b9de0fa5daf/resolv.conf] ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0
      |-/etc/hostname    /dev/mapper/cachedev_0[/@docker/containers/d3241ec779e3b13b8c77eab6b9b4347d110de1b7dfaa04ae33ac8b9de0fa5daf/hostname]    ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0
      `-/etc/hosts       /dev/mapper/cachedev_0[/@docker/containers/d3241ec779e3b13b8c77eab6b9b4347d110de1b7dfaa04ae33ac8b9de0fa5daf/hosts]       ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0
      /var:
      35M     /var/
      33M     /var/lib
      19M     /var/lib/apt/lists
      19M     /var/lib/apt
      14M     /var/lib/dpkg
      /opt/iobroker/backups:
      12K     /opt/iobroker/backups/
      8.0K    /opt/iobroker/backups/@eaDir
      /opt/iobroker/iobroker-data:
      662M    /opt/iobroker/iobroker-data/
      423M    /opt/iobroker/iobroker-data/files
      177M    /opt/iobroker/iobroker-data/backup-objects
      73M     /opt/iobroker/iobroker-data/files/vis-2
      56M     /opt/iobroker/iobroker-data/files/vis
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
       zigbee.X
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.19.0
      /usr/bin/node           v22.19.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.19.0-1nodesource1
        Candidate: 22.19.0-1nodesource1
        Version table:
       *** 22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
            22.0.0-1nodesource1 1001
           18.20.4+dfsg-1~deb12u1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Thomas BraunT R HomoranH 3 Antworten Letzte Antwort
      • R RJ3n53n
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Kernel          : x86_64
        Userland        : 64 bit
        Docker          : v11.0.0
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
        CEST +0200
        Etc/UTC
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/opt/iobroker
        Display-Manager:
        Desktop:
        Session:
        *** MEMORY ***
        Swap:            12G        996M         11G
        Total:           28G        6.9G         11G
                 5585 M used memory
                  819 M free memory
                  658 M buffer memory
                 9395 M swap cache
                11563 M total swap
                  950 M used swap
                10613 M free swap
        *** FILESYSTEM ***
        irperm1
        /var:
        35M     /var/
        33M     /var/lib
        19M     /var/lib/apt
        14M     /var/lib/dpkg
        USB-Devices by-id:
         zigbee.X
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        nodejs:
          Version table:
        Thomas BraunT
        Thomas BraunT
        @rj3n53n sagte in Kein Admin nach Update:
        Nein, musst du nicht.
        Die Ausgabe passt normalerweise in Gänze in ein Posting rein.
        • R RJ3n53n
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v11.0.0
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
          CEST +0200
          Etc/UTC
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          Display-Manager:
          Desktop:
          Session:
          *** MEMORY ***
          Swap:            12G        996M         11G
          Total:           28G        6.9G         11G
                   5585 M used memory
                    819 M free memory
                    658 M buffer memory
                   9395 M swap cache
                  11563 M total swap
                    950 M used swap
                  10613 M free swap
          *** FILESYSTEM ***
          irperm1
          /var:
          35M     /var/
          33M     /var/lib
          19M     /var/lib/apt
          14M     /var/lib/dpkg
          USB-Devices by-id:
           zigbee.X
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.3
          /usr/bin/npx            10.9.3
          nodejs:
            Version table:
          R
          R
          RJ3n53n
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 13447)
          Core adapters versions
          js-controller:  6.0.11
          admin:          3.7.9
          javascript:     8.9.2
          nodejs modules from github:     1
          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
          Adapter State
            system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
            system.adapter.daikin.0                 : daikin                : ioBroker                                 - disabled
            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
            system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
            system.adapter.ds18b20.0                : ds18b20               : ioBroker                                 - disabled
            system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
          + system.adapter.evcc.0                   : evcc                  : ioBroker                                 -  enabled, port: 7070
            system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
          + system.adapter.history.0                : history               : ioBroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
            system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
            system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
            system.adapter.ical.3                   : ical                  : ioBroker                                 - disabled
            system.adapter.iceroad.0                : iceroad               : ioBroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
            system.adapter.lcn.0                    : lcn                   : ioBroker                                 - disabled, port: 4114
            system.adapter.lorawan.0                : lorawan               : ioBroker                                 - disabled, port: 8883
            system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
            system.adapter.mqtt-client.0            : mqtt-client           : ioBroker                                 - disabled, port: 1883
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 192.168.178.70
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : io    : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.welcome.0                : welcome               : ioBroker                                 - disabled, port: 80, bind: 192.168.178.70, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
            system.adapter.wiffi-wz.0               : wiffi-wz              : ioBroker                                 - disabled
          + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
          Broker                                 -  enabled
          + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
            system.adapter.node-red.0               : node-red              : ioBroker                                 - disabled, port: 6335, bind: 192.168.178.70
          + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
            system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
            system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
          + system.adapter.plenticore.0             : plenticore            : ioBroker                                 -  enabled, port: 443
          + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
            system.adapter.rpi2.0                   : rpi2                  : ioBroker                                 - disabled
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
          + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
          + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 -  enabled
            system.adapter.vis-material.0           : vis-material          : ioBroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
          + system.adapter.web.0                    : web
          + instance is alive
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.7.2    , installed 3.7.9  [Updatable]
          Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.3.5    , installed 3.3.5
          Adapter    "bring"        : 1.8.4    , installed 1.8.4
          Adapter    "daikin"       : 1.5.1    , installed 1.5.1
          Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "devices"      : 1.2.8    , installed 1.2.8
          Adapter    "ds18b20"      : 3.0.1    , installed 3.0.1
          Adapter    "evcc"         : 0.2.3    , installed 0.2.3
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "ical"         : 1.16.2   , installed 1.16.2
          Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
          Controller "js-controller": 7.0.7    , installed 6.0.11 [Updatable]
          Adapter    "lcn"          : 3.0.1    , installed 3.0.1
          Adapter    "lorawan"      : 1.10.22  , installed 1.6.0  [Updatable]
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
          Adapter    "netatmo-crawler": 1.0.0  , installed 1.0.0
          Adapter    "nina"         : 0.0.25   , installed 0.0.25
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "pegelalarm"   : 1.3.9    , installed 1.3.9
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
          Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
          Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
          Adapter    "shelly"       : 10.1.0   , installed 10.1.0
          Adapter    "snmp"         : 3.3.0    , installed 3.3.0
          Adapter    "synology"     : 3.1.0    , installed 3.1.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tibberlink"   : 5.0.0    , installed 5.0.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
          Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
          Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
          Adapter    "vis-material" : 0.2.0    , installed 0.2.0
          Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 7.0.8    , installed 6.2.5  [Updatable]
          Adapter    "welcome"      : 1.0.2    , installed 1.0.2
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Objects and States
          Objects:        14283
          States:         11962
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1021077767 -
          tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47362      -
          tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47361      -
          tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47360      -
          tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          47348      -
          tcp        0      0 0.0.0.0:9002            0.0.0.0:*               LISTEN      0          181183     -
          tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN      0          102514     -
          tcp        0      0 0.0.0.0:23883           0.0.0.0:*               LISTEN      0          202376     -
          tcp        0      0 0.0.0.0:3307            0.0.0.0:*               LISTEN      66         92206      -
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          52752      -
          tcp        0      0 127.0.0.1:2380          0.0.0.0:*               LISTEN      0          140798     -
          tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          244860     -
          tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          244859     -
          tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          244858     -
          tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          244856     -
          tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          53285      -
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          24795      -
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47368      -
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47367      -
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47366      -
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          47350      -
          tcp        0      0 192.168.178.70:2001     0.0.0.0:*               LISTEN      1000       1021085318 -
          tcp        0      0 127.0.0.1:2385          0.0.0.0:*               LISTEN      0          228518     -
          tcp        0      0 192.168.178.70:50001    0.0.0.0:*               LISTEN      0          92703      -
          tcp        0      0 192.168.178.70:50002    0.0.0.0:*               LISTEN      0          95823      -
          tcp        0      0 192.168.178.70:49170    0.0.0.0:*               LISTEN      254178     92148      -
          tcp        0      0 127.0.0.1:5555          0.0.0.0:*               LISTEN      0          299981638  -
          tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN      0          171331     -
          tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          40192      -
          tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      0          824890506  -
          tcp        0      0 0.0.0.0:23000           0.0.0.0:*               LISTEN      0          202297     -
          tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         76580      -
          tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          54232      -
          tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      0          212185     -
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1021103558 -
          tcp        0      0 192.168.178.70:2010     0.0.0.0:*               LISTEN      1000       1021086258 -
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          183324     -
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47374      -
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47373      -
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47372      -
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          47352      -
          tcp        0      0 127.0.0.1:30300         0.0.0.0:*               LISTEN      0          231391     -
          tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          39166      -
          tcp        0      0 127.0.0.1:16509         0.0.0.0:*               LISTEN      0          221036     -
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          52751      -
          tcp        0      0 0.0.0.0:6335            0.0.0.0:*               LISTEN      0          1021099404 -
          tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          266626     -
          tcp        0      0 0.0.0.0:5888            0.0.0.0:*               LISTEN      0          248223     -
          tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          53264      -
          tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          41249      -
          tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          150084     -
          tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          824943935  -
          tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          30131      -
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1021077778 -
          tcp        0      0 0.0.0.0:23080           0.0.0.0:*               LISTEN      0          201307     -
          tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          47356      -
          tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          47355      -
          tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          47354      -
          tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          47346      -
          tcp6       0      0 :::5001                 :::*                    LISTEN      0          47365      -
          tcp6       0      0 :::5001                 :::*                    LISTEN      0          47364      -
          tcp6       0      0 :::5001                 :::*                    LISTEN      0          47363      -
          tcp6       0      0 :::5001                 :::*                    LISTEN      0          47349      -
          tcp6       0      0 :::9002                 :::*                    LISTEN      0          182284     -
          tcp6       0      0 :::23883                :::*                    LISTEN      0          200401     -
          tcp6       0      0 :::139                  :::*                    LISTEN      0          52750      -
          tcp6       0      0 :::5357                 :::*                    LISTEN      0          244863     -
          tcp6       0      0 :::5357                 :::*                    LISTEN      0          244862     -
          tcp6       0      0 :::5357                 :::*                    LISTEN      0          244861     -
          tcp6       0      0 :::5357                 :::*                    LISTEN      0          244857     -
          tcp6       0      0 :::4045                 :::*                    LISTEN      0          53287      -
          tcp6       0      0 :::1935                 :::*                    LISTEN      233155     101868     -
          tcp6       0      0 :::111                  :::*                    LISTEN      0          24798      -
          tcp6       0      0 :::80                   :::*                    LISTEN      0          47371      -
          tcp6       0      0 :::80                   :::*                    LISTEN      0          47370      -
          tcp6       0      0 :::80                   :::*                    LISTEN      0          47369      -
          tcp6       0      0 :::80                   :::*                    LISTEN      0          47351      -
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1021107683 -
          tcp6       0      0 :::8086                 :::*                    LISTEN      1000       1005191441 -
          tcp6       0      0 :::662                  :::*                    LISTEN      0          40196      -
          tcp6       0      0 :::3000                 :::*                    LISTEN      0          824888236  -
          tcp6       0      0 :::23000                :::*                    LISTEN      0          202304     -
          tcp6       0      0 :::3001                 :::*                    LISTEN      0          206500     -
          tcp6       0      0 :::1883                 :::*                    LISTEN      0          181200     -
          tcp6       0      0 :::443                  :::*                    LISTEN      0          47377      -
          tcp6       0      0 :::443                  :::*                    LISTEN      0          47376      -
          tcp6       0      0 :::443                  :::*                    LISTEN      0          47375      -
          tcp6       0      0 :::443                  :::*                    LISTEN      0          47353      -
          tcp6       0      0 :::892                  :::*                    LISTEN      0          39170      -
          tcp6       0      0 :::3261                 :::*                    LISTEN      0          54081      -
          tcp6       0      0 :::445                  :::*                    LISTEN      0          52749      -
          tcp6       0      0 :::5566                 :::*                    LISTEN      0          81073      -
          tcp6       0      0 :::6335                 :::*                    LISTEN      0          1021097460 -
          tcp6       0      0 :::3263                 :::*                    LISTEN      0          54080      -
          tcp6       0      0 :::5888                 :::*                    LISTEN      0          247603     -
          tcp6       0      0 :::3264                 :::*                    LISTEN      0          54082      -
          tcp6       0      0 :::3265                 :::*                    LISTEN      0          989674843  -
          tcp6       0      0 :::2049                 :::*                    LISTEN      0          53275      -
          tcp6       0      0 :::6690                 :::*                    LISTEN      0          150085     -
          tcp6       0      0 :::9443                 :::*                    LISTEN      0          824943312  -
          tcp6       0      0 :::23080                :::*                    LISTEN      0          202410     -
          tcp6       0      0 :::5000                 :::*                    LISTEN      0          47359      -
          tcp6       0      0 :::5000                 :::*                    LISTEN      0          47358      -
          tcp6       0      0 :::5000                 :::*                    LISTEN      0          47357      -
          tcp6       0      0 :::5000                 :::*                    LISTEN      0          47347      -
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          24793      -
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          37719      -
          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          1024636905 -
          udp        0      0 192.168.178.70:137      0.0.0.0:*                           0          1024636904 -
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1024636840 -
          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          1024636907 -
          udp        0      0 192.168.178.70:138      0.0.0.0:*                           0          1024636906 -
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1024636841 -
          udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          41248      -
          udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          37717      -
          udp        0      0 192.168.178.70:500      0.0.0.0:*                           0          129298     -
          udp        0      0 127.0.0.1:626           0.0.0.0:*                           0          37816      -
          udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          40190      -
          udp        0      0 0.0.0.0:41779           0.0.0.0:*                           0          1019960907 -
          udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          39164      -
          udp        0      0 192.168.178.70:1701     0.0.0.0:*                           0          125536     -
          udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          27285      -
          udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          27284      -
          udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          27283      -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          243812     -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          92706      -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           254178     92151      -
          udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          53274      -
          udp        0      0 127.0.0.1:35108         0.0.0.0:*                           254178     92149      -
          udp        0      0 127.0.0.1:43807         0.0.0.0:*                           0          92704      -
          udp        0      0 0.0.0.0:43930           0.0.0.0:*                           1000       1021092392 -
          udp        0      0 0.0.0.0:52642           0.0.0.0:*                           0          914611939  -
          udp        0      0 0.0.0.0:19996           0.0.0.0:*                           233155     102485     -
          udp        0      0 0.0.0.0:19997           0.0.0.0:*                           233155     102484     -
          udp        0      0 0.0.0.0:19998           0.0.0.0:*                           233155     102483     -
          udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         225978     -
          udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          53284      -
          udp        0      0 192.168.178.70:4500     0.0.0.0:*                           0          129299     -
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1021109873 -
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          914611937  -
          udp        0      0 0.0.0.0:54983           0.0.0.0:*                           0          24794      -
          udp        0      0 0.0.0.0:55443           0.0.0.0:*                           1000       1021094364 -
          udp        0      0 127.0.0.1:31067         0.0.0.0:*                           0          128719     -
          udp        0      0 127.0.0.1:31068         0.0.0.0:*                           0          128720     -
          udp        0      0 192.168.178.70:55900    0.0.0.0:*                           254178     92150      -
          udp        0      0 192.168.178.70:55901    0.0.0.0:*                           0          92705      -
          udp6       0      0 :::57209                :::*                                0          24797      -
          udp6       0      0 :::111                  :::*                                0          24796      -
          udp6       0      0 :::123                  :::*                                0          37720      -
          udp6       0      0 ::1:323                 :::*                                0          37718      -
          udp6       0      0 fe80::211:32ff:fec5:546 :::*                                0          387459     -
          udp6       0      0 :::662                  :::*                                0          40194      -
          udp6       0      0 :::892                  :::*                                0          39168      -
          udp6       0      0 :::2049                 :::*                                0          53276      -
          udp6       0      0 :::3702                 :::*                                99         225981     -
          udp6       0      0 :::4045                 :::*                                0          53286      -
          udp6       0      0 :::5353                 :::*                                0          914611938  -
          udp6       0      0 :::47739                :::*                                0          914611940  -
          2025-09-13 16:05:27.775  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
          2025-09-13 16:05:40.023  - info: host.ioBroker instance system.adapter.netatmo-crawler.0 in version "1.0.0" started with pid 21227
          2025-09-13 16:05:42.531  - info: netatmo-crawler.0 (21227) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.19.0, js-controller: 6.0.11
          2025-09-13 16:05:42.583  - info: netatmo-crawler.0 (21227) Getting data for stationid:70:ee:50:03:e0:ea
          2025-09-13 16:05:44.349  - info: netatmo-crawler.0 (21227) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
          2025-09-13 16:05:44.885  - info: host.ioBroker instance system.adapter.netatmo-crawler.0 having pid 21227 terminated with code 0 (NO_ERROR)
          2025-09-13 16:06:20.343  - info: shelly.0 (679) [MQTT] Device with client id "shellyplusplugs-d4d4daedddb0" connected from 10.10.30.141!
          2025-09-13 16:06:30.352  - info: shelly.0 (679) [MQTT] Client Close: 10.10.30.141 (shellyplusplugs / shellyplusplugs-d4d4daedddb0 / shellyplusplugs#d4d4daedddb0#1) (false)
          2025-09-13 16:06:37.367  - error: shelly.0 (679) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'repla
          ce')
          2025-09-13 16:06:37.368  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
          2025-09-13 16:07:04.339  - info: web.0 (774) ==> Connected system.user.admin from ::ffff:192.168.178.32
          2025-09-13 16:07:05.187  - info: web.0 (774) ==> Connected system.user.admin from ::ffff:192.168.178.32
          2025-09-13 16:07:25.485  - info: shelly.0 (679) [MQTT] Device with client id "shellyplusplugs-d4d4daedddb0" connected from 10.10.30.141!
          2025-09-13 16:07:35.479  - info: shelly.0 (679) [MQTT] Client Close: 10.10.30.141 (shellyplusplugs / shellyplusplugs-d4d4daedddb0 / shellyplusplugs#d4d4daedddb0#1) (false)
          2025-09-13 16:07:36.276  - error: shelly.0 (679) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'repla
          ce')
          2025-09-13 16:07:36.277  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
          2025-09-13 16:08:31.087  - info: shelly.0 (679) [MQTT] Device with client id "shellyplusplugs-d4d4daedddb0" connected from 10.10.30.141!
          2025-09-13 16:08:41.065  - info: shelly.0 (679) [MQTT] Client Close: 10.10.30.141 (shellyplusplugs / shellyplusplugs-d4d4daedddb0 / shellyplusplugs#d4d4daedddb0#1) (false)
          2025-09-13 16:08:41.206  - error: shelly.0 (679) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'repla
          ce')
          2025-09-13 16:08:41.206  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
          2025-09-13 16:09:34.363  - info: web.0 (774) <== Disconnect system.user.admin from ::ffff:192.168.178.32 vis.0
          2025-09-13 16:09:38.273  - info: shelly.0 (679) [MQTT] Device with client id "shellyplusplugs-d4d4daedddb0" connected from 10.10.30.141!
          2025-09-13 16:09:48.264  - info: shelly.0 (679) [MQTT] Client Close: 10.10.30.141 (shellyplusplugs / shellyplusplugs-d4d4daedddb0 / shellyplusplugs#d4d4daedddb0#1) (false)
          2025-09-13 16:09:55.928  - error: shelly.0 (679) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'repla
          ce')
          2025-09-13 16:09:55.928  - error: shelly.0 (679) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daedddb0"
          iob diag has finished.
            R
            R
            RJ3n53n
            • R RJ3n53n
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
              Kernel          : x86_64
              Userland        : 64 bit
              Docker          : v11.0.0
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 4
              CEST +0200
              Etc/UTC
              root
              HOME=/root
              GROUPS=root
              iobroker
              HOME=/opt/iobroker
              Display-Manager:
              Desktop:
              Session:
              *** MEMORY ***
              Swap:            12G        996M         11G
              Total:           28G        6.9G         11G
                       5585 M used memory
                        819 M free memory
                        658 M buffer memory
                       9395 M swap cache
                      11563 M total swap
                        950 M used swap
                      10613 M free swap
              *** FILESYSTEM ***
              irperm1
              /var:
              35M     /var/
              33M     /var/lib
              19M     /var/lib/apt
              14M     /var/lib/dpkg
              USB-Devices by-id:
               zigbee.X
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              nodejs:
                Version table:
              • R RJ3n53n
                Thomas BraunT
                Thomas BraunT
                @rj3n53n
                Damit kommste halt nicht mehr weit...
                Dringendst alles updaten. Inkl. js-controller usw.
                  @rj3n53n
                  R
                  R
                  RJ3n53n
                  Ich hatte eigentlich regelmäßige Updates gemacht, wenn sie angezeigt wurden.
                  Kann man das jetzt noch glattziehen?
                  • R RJ3n53n
                    Thomas BraunT
                    Thomas BraunT
                    Bestimmt. Aber bei Docker hab ich keine Aktien.
                      R
                      R
                      RJ3n53n
                      Im Container Manager hatte ich zeitnah jedes Update gemacht, wenn es angezeigt wurde.
                      Hab aber trotzdem vielen Dank für Deine Hilfe.
                        R
                        R
                        RJ3n53n
                        Wie kann ich das ändern?
                        • R RJ3n53n
                          keine Ahnung!
                          mit Containern kenne ich mich nicht aus, mit Docker schon gar nicht.
                          Wenn das eine native Installation wäre würde ich versuchen in kleinen Schritten die Versionen hochzubringen.
                          Ob man das bei Docker darf weiss ich nicht.
                          Ob die nötigen Versionen überhaupt noch verfügbar sind weiß ich auch nicht.
                          Wenn das eine native Installation wäre, würde ich zu einer Neuinstallation mit anschließendem wiederherstellen des letzten Backups taten.
                          Ob und wie das bei Docker geht entzieht sich meiner Kenntnis
                            keine Ahnung!
                            R
                            R
                            RJ3n53n
                            schrieb am zuletzt editiert von RJ3n53n
                            Hab trotzdem vielen Dank für Deine Antwort.
                            • CodierknechtC
                              CodierknechtC
                              Codierknecht
                              @RJ3n53n
                              Sind alle benötigten Container-Ports gemappt?
                              Läuft da 'ne Firewall?
                              Ich empfehle außerdem, das Ganze auf ein "Projekt" zu migrieren. Das lässt sich deutlich einfacher administrieren als das Gefummel an irgendwelchen Container-Einstellungen. Und zum Update muss lediglich das Projekt neu gestsartet werden.
                              Siehe hier: https://forum.iobroker.net/topic/82045/installtion-ffmpeg/6?_=1757840464651
                              HmIP|ZigBee|Tasmota|Unifi
                              Zabbix Certified Specialist
                              • CodierknechtC Codierknecht
                                @RJ3n53n
                                @codierknecht sagte in Kein Admin nach Update:
                                Sind alle benötigten Ports nach außen freigegeben?
                                @RJ3n53n
                                bitte nicht missverstehen!!
                                nicht ins Internet, nur aus dem/in den Container weitergeleitet
                                  @RJ3n53n
                                  CodierknechtC
                                  CodierknechtC
                                  Codierknecht
                                  Danke für den Hinweis. Hab's korrigiert.
                                  Nicht dass da jemand auf komische Ideen kommt ;-)
                                  • R
                                    R
                                    RJ3n53n
                                    @codierknecht
                                    An den Ports habe ich nichts geändert. Bisher hatte es ja funktioniert.
                                    Ich schaue mir gerade mal den Link an, den Du angehängt hast. Ich weiß gerade nicht, wie Du das mit ein Projekt meinst.
                                    Vielen Dank aber schon mal für den Tipp sowie den Link.
                                    • R RJ3n53n
                                      @codierknecht
                                      CodierknechtC
                                      CodierknechtC
                                      Codierknecht
                                      Ich vermute mal: Du hast das bislang über den Container-Manager als Container aufgesetzt.
                                      Dann muss man den ganzen Kram "von Hand" passend einstellen. Volumes, Ports, Variablen etc.
                                      Man kann das im Container-Manager auch als "Projekt" aufsetzen. Dann wird die komplette Konfiguration in einer YAML-Datei abgelegt. In Docker nennt sich das "Compose" und in Portainer "Stacks". Ist aber alles das gleiche.
                                      Als Quelle wählst Du "docker-compose.yml erstellen" und fügst dann den folgenden Inhalt in den Editor ein.
                                      Ein grundlegendes docker-compose.yml für ioBroker könnte so aussehen:
                                      services:
                                        iobroker:
                                          container_name: ioBroker
                                          image: buanet/iobroker:latest
                                          hostname: iobroker
                                          network_mode: "host"
                                          volumes:
                                            - /volume1/Docker/ioBroker:/opt/iobroker
                                          environment:
                                            PACKAGES: "nano"
                                            AVAHI: "true"
                                          restart: unless-stopped
                                      Muss halt ggf. etwas an die eigenen Gegebenheiten angepasst werden.
                                      Man beachte hier: Der Container läuft als "host". Man muss also keine Ports speziell mappen.
                                      Könnte allerding schiefgehen, wenn auf der Synology noch ander Dienste (WebStation, Fotos usw.) laufen, die Ports beanspruchen die auch vom ioBroker verwendet werden.
                                        services:
                                          iobroker:
                                            hostname: iobroker
                                            volumes:
                                            environment:
                                              PACKAGES: "nano"
                                              AVAHI: "true"
                                        R
                                        R
                                        RJ3n53n
                                        @codierknecht
                                        Okay, jetzt weiß ich, was Du meinst. Ja, so hatte ich das gemacht. Eingerichttet hatte ich es nach einer Anleitung. Noch bevor es bei Synology Container-Manager hieß. Da war damals auch beschrieben, welche Ports ich öffnen musste.
                                        • R RJ3n53n
                                          @codierknecht
                                          CodierknechtC
                                          CodierknechtC
                                          Codierknecht
                                          Seit DSM 7 gibt's den Container-Manager und damit auch die "Projekte".
                                          Macht das Ganze deutlich einfacher.
                                          Wenn der Container im Host-Mode läuft, muss man keine Ports mehr freigeben.
                                          Solange auf der Syno nix läuft was dem Container da in die Suppe spucken kann, spart man sich die ganze Port-Litanei.
                                          83.9k
