  4. Test lovelace 5.x
Test lovelace 5.x
1.1k Beiträge 96 Kommentatoren 579.7k Aufrufe 78 Beobachtet
  • E Offline
    Erstam
    #875
    Ich hatte gerade mal wieder einen reproduzierbaren Absturz in der 5.0-Version mit Templates. Ich weiß, dass diese nicht funktionieren, im Beispielcode für die Karte waren aber welche drin. Es wäre toll, wenn der Adapter dabei nicht abstürzen würde. Noch toller wäre natürlich, wenn Jinja2 Templates funktionieren würden.
    host.iobroker  2025-08-24 16:54:30.635	info	Restart adapter system.adapter.lovelace.0 because enabled
    host.iobroker  2025-08-24 16:54:30.635	error	instance system.adapter.lovelace.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    lovelace.0  2025-08-24 16:54:30.517	info	terminating
    lovelace.0  2025-08-24 16:54:30.016	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    lovelace.0  2025-08-24 16:54:30.016	info	terminating
    lovelace.0  2025-08-24 16:54:30.012	info	cleaned everything up...
    lovelace.0  2025-08-24 16:54:30.010	error	Error The pattern "% if is_state('light.bed_light', 'on') %" is not a valid ID pattern
    lovelace.0  2025-08-24 16:54:30.010	error	ReplyError: Error The pattern "% if is_state('light.bed_light', 'on') %" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    lovelace.0  2025-08-24 16:54:30.008	error	unhandled promise rejection: Error The pattern "% if is_state('light.bed_light', 'on') %" is not a valid ID pattern
    lovelace.0  2025-08-24 16:54:30.008	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    lovelace.0  2025-08-24 16:54:30.005	error	Error The pattern "% if states('light.bed_light') == 'on' %" is not a valid ID pattern
    lovelace.0  2025-08-24 16:54:30.005	error	ReplyError: Error The pattern "% if states('light.bed_light') == 'on' %" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    lovelace.0  2025-08-24 16:54:30.004	error	unhandled promise rejection: Error The pattern "% if states('light.bed_light') == 'on' %" is not a valid ID pattern
    lovelace.0  2025-08-24 16:54:30.004	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker-Server  2025-08-24 16:54:29.999	warn	States 127.0.0.1:59932 Error from InMemDB: Error: The pattern "% if is_state('light.bed_light', 'on') %" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:518:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:485:21)
    host.iobroker-Server  2025-08-24 16:54:29.998	warn	States 127.0.0.1:59932 Error from InMemDB: Error: The pattern "% if states('light.bed_light') == 'on' %" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:518:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:485:21)
    GarfonsoG 1 Antwort Letzte Antwort
    • E Erstam
      GarfonsoG Offline
      GarfonsoG Offline
      Garfonso
      #876
      @erstam
      so ist das wenig hilfreich... was ich daraus ziehen kann ist nur, dass Jinja2 Templates wohl nicht funktionieren.
      Wenn du noch den code für die Karte mitliefern könntest, könnte ich versuchen den Absturz zu verhindern.
      Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
      Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
      • simatecS Offline
        simatecS Offline
        simatec
        #877
        Gibt es eine Möglichkeit den "Dashboard bearbeiten" Button auszublenden? Am Tablet an der Wand sollte hier nicht unbedingt jemand etwas ändern können...
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • simatecS simatec
          GarfonsoG Offline
          GarfonsoG Offline
          Garfonso
          schrieb am zuletzt editiert von Garfonso
          #878
          @simatec
          wenn du Authentifizierung nutzt, dann kann ein User, der keinen Schreibzugriff auf lovelace.x.configuration hat, auch am Frontend nichts ändern. -> Das ist die einfachste (und von HASS vorgesehene) Möglichkeit.
          Ohne Authentifizierung habe ich bisher noch keinen Weg gefunden, das pro Browser einzustellen. Da könnte ich noch einmal gucken, ob ich da mit browser_mod bzw. den Instanzen, die lovelace sich da mittlerweile merkt, was basteln kann. Ist aber, glaube ich, aufwendiger, weil die browserId erst nach der Anmeldung kommt und da entschieden wird, ob der User als admin geführt wird, oder nicht...
          Man wird es vermutlich über card_mod irgendwie ausblenden können. Weiß nicht genau, ob das pro Browser geht? Da muss man ein (teil) Theme basteln und das könntest du über die Objekte umstellen. Alternativ mit browser_mod in den Instanzen für den Browser die ganze titelbar ausblenden. Dann geht allerdings auch die Auswahl des Views flöten und das müsstest du in den Seiten nachbauen oder nur einen haben oder per Swipe-Navigation arbeiten, oder so.
          IMHO alles nicht so glücklich. Ich hab an einem Wandtablet das Dashboard bearbeiten halt mit drin, bei einem anderen hab ich eine eigene Instanz, die ausschließlich eine Seite für die Etage hat, wo das Tablet hängt. Authentifizierung hat das Problem, dass sie regelmäßig abläuft.... ist gerade für ein Wandtablet auch doof. Da wollte ich auch nochmal gucken, aber vermutlich hat Bluefox das aus einem guten Grund so programmiert.
          • GarfonsoG Garfonso
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            #879
            @garfonso ahh danke für die Info... teste ich mal
            • L Offline
              lessthanmore
              #880
              @Garfonso Hast du momentan einen Überblick welcher Wetteradapter noch mit lovelace läuft?
              Accuweather hat die API geändert/ eingestellt, daswetter.com geht nicht mehr.
              Mit openweathermap bekommen ich Warnmeldungen:
              lovelace.0
              2025-09-11 07:13:14.735	warn	Got duplicate for entity camera.Actual_weather_or_forecast. Overwriting old value. Was for openweathermap.0.forecast and new one is for openweathermap.0.forecast
              lovelace.0
              2025-09-11 07:13:14.735	warn	Got duplicate for entity weather.Actual_weather_or_forecast. Overwriting old value. Was for openweathermap.0.forecast and new one is for openweathermap.0.forecast
              lovelace.0
              2025-09-11 07:12:59.041	warn	Got duplicate for entity camera.Actual_weather_or_forecast. Overwriting old value. Was for openweathermap.0.forecast and new one is for openweathermap.0.forecast
              lovelace.0
              2025-09-11 07:12:59.041	warn	Got duplicate for entity weather.Actual_weather_or_forecast. Overwriting old value. Was for openweathermap.0.forecast and new one is for openweathermap.0.forecast
              Lieben Dank vorab.
              David G.D GarfonsoG 2 Antworten Letzte Antwort
              • L lessthanmore
                lovelace.0
                lovelace.0
                lovelace.0
                lovelace.0
                Lieben Dank vorab.
                David G.D Online
                David G.D Online
                David G.
                #881
                @lessthanmore
                Ich nutze den daswetter Adapter und alles klappt prima.
                L 1 Antwort Letzte Antwort
                • David G.D David G.
                  @lessthanmore
                  lessthanmore
                  #882
                  @david-g Danke, aber bei daswetter kann man sich seit einiger Zeit nicht mehr registrieren oder einloggen.
                  tiobbT 1 Antwort Letzte Antwort
                  • L lessthanmore
                    tiobbT Offline
                    tiobbT Offline
                    tiobb
                    #883
                    @lessthanmore
                    Was ist mit Weatherunderground?
                    Raspberry Pi 4 8gb
                    L 2 Antworten Letzte Antwort
                    • tiobbT tiobb
                      @lessthanmore
                      lessthanmore
                      #884
                      @tiobb Wäre jetzt meine letzte Alternative.
                      Ich teste es mal. Danke.
                      • tiobbT tiobb
                        @lessthanmore
                        lessthanmore
                        #885
                        @tiobb Hab es gerade ohne Erfolg getestet. Auch yr.no läuft nicht; hier wird keine Entität von lovelace gefunden.
                        So sieht es bei weatherunderground aus:
                        Hier fehlen die Vorhersagen. Ist der Raum und die Funktion eigentlich richtig gesetzt?
                        • astuermerA Offline
                          astuermerA Offline
                          astuermer
                          #886
                          Hab hier vor wenigen Wochen zu WeatherUnderground gewechselt. Läuft problemlos.
                          • astuermerA astuermer
                            lessthanmore
                            #887
                            @astuermer Zeigst du mir bitte einmal wie bzw. wo du den Raum any und die function Wetter hinterlegt hast?
                            astuermerA 1 Antwort Letzte Antwort
                            • L lessthanmore
                              astuermerA Offline
                              astuermerA Offline
                              astuermer
                              #888
                              @lessthanmore sagte in Test lovelace 5.x:
                              Ich hab mal den Raum "Any" angelegt.
                              Den Forecast hab ich dann diesen Raum zugeordnet sowie der Funktion "Wetter" (kann man seitlich unter "Kategorien" festlegen).
                              Als Entität in Lovelace hab ich dann "Forecast for next 4 days days and current conditions" genommen (wird eh als einziges vorgeschlagen beim Wetter Widget).
                                lessthanmore
                                schrieb am zuletzt editiert von lessthanmore
                                #889
                                @astuermer Danke, habe ich auch so (siehe mein Screenshot im vorherigen Post).
                                Aber dennoch wird bei mir nichts angezeigt.
                                Auch nach einem
                                iob upload all
                                ändert sich nichts bzw. sieht nun so aus:
                                • L lessthanmore
                                  Auch nach einem
                                  iob upload all
                                  astuermerA Offline
                                  astuermerA Offline
                                  astuermer
                                  schrieb am zuletzt editiert von astuermer
                                  #890
                                  @lessthanmore Ansonsten hab ich direkt in der Instanz noch konfiguriert:
                                  • Den API Schlüssel
                                  • Vorschau als Text für 4 Tage + Vorschau für die nächsten 4 Tage angehakt
                                  • Aktuelle Daten angehakt
                                  • Messstation eingetragen und Breiten/Längengrad
                                  • Symbole hab ich auf Default gelassen (müsste "I" sein) - die wirken sich aber nicht aus, da Lovelace seine eigenen Icons scheinbar nimmt :)
                                    • Den API Schlüssel
                                    lessthanmore
                                    #891
                                    @astuermer Das mit den Icons hat schon mal geklappt as gebracht. Hatte da das falsche Set ausgewählt.
                                    Welchen Key gibst du den an, bzw. hast du eine eigene Station?
                                    • L lessthanmore
                                      astuermerA Offline
                                      astuermerA Offline
                                      astuermer
                                      #892
                                      @lessthanmore also du meldest dich mal bei WeatherUnderground an und kannst hier Devices festlegen: https://www.wunderground.com/member/devices
                                      Name zB „ioBroker“
                                      Elevation (Höhe) und Hardware (zB Raspberry) noch auswählen.
                                      …dann hast du mal ID und Key.
                                      Das gibst du im Configfenster des Adapters bei ioBroker ein.
                                      Und Station suchst du einfach in der Suche auf WeatherUnderground. Hab einfach mal nach „Hamburg“ gesucht. Dann klickst auf den Namen der Station und es steht dann „ IHAMBU387“ als dessen Station. Die trägst du auch im Adapter ganz unten ein.
                                      Ich hab da einfach eine gesucht die am Nächsten zu mir ist.
                                        Name zB „ioBroker“
                                        lessthanmore
                                        #893
                                        @astuermer Danke nochmal. Nach einer Nacht ist nun alles auf einmal da.
                                        • L lessthanmore
                                          astuermerA Offline
                                          astuermerA Offline
                                          astuermer
                                          #894
                                          Wenn du bei den Instanzen schaust, der "WeatherUnderground" Adapter hat eine Uhr. Heißt er aktualisiert sich alle "x" Stunden... davor zeigt er einfach den gespeicherten Stand an.
