  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
1.6k Beiträge 101 Kommentatoren 819.1k Aufrufe 95 Beobachtet
    @fichte sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
    iobroker is not running on this host.
    Mit laufendem ioBroker könnte man mehr sehen.
    F
    F
    Fichte
    schrieb am zuletzt editiert von Fichte
    #1484
    Ja Sorry habs gesehen 🙄
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.8-2-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-9500T CPU @ 2.20GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     13:22:09 up 6 days,  2:00,  3 users,  load average: 0.88, 0.74, 0.71
    CPU threads: 6
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-09-04 13:22:09 CEST
               Universal time: Thu 2025-09-04 11:22:09 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.6G        3.3G        1.4G        143K        3.9G        5.3G
    Swap:             0B          0B          0B
    Total:          8.6G        3.3G        1.4G
    Active iob-Instances:   40
             8192 M total memory
             3154 M used memory
             3126 M active memory
             3416 M inactive memory
             1350 M free memory
                0 M buffer memory
             3687 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 13:22:10 up 6 days,  2:00,  3 users,  load average: 0.88, 0.74, 0.71
    Tasks:  74 total,   2 running,  72 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   1348.6 free,   3155.9 used,   3687.7 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   5036.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    /dev/loop0     ext4       16G  6.5G  8.3G  44% /
    none           tmpfs     492K  4.0K  488K   1% /dev
    none           tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-path/pci-0000:00:14.0-usb-0:1:1.0-port0
    udev           devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs          tmpfs      32G     0   32G   0% /dev/shm
    tmpfs          tmpfs      13G  136K   13G   1% /run
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/0
    Show mounted filesystems:
    TARGET SOURCE     FSTYPE OPTIONS
    /      /dev/loop0 ext4   rw,relatime
    /var:
    489M    /var/
    292M    /var/cache
    288M    /var/cache/apt
    213M    /var/cache/apt/archives
    147M    /var/lib
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    616M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.0G    /opt/iobroker/iobroker-data/
    1.3G    /opt/iobroker/iobroker-data/history
    528M    /opt/iobroker/iobroker-data/files
    130M    /opt/iobroker/iobroker-data/backup-objects
    104M    /opt/iobroker/iobroker-data/files/vis
    find: Failed to change directory: /root: Permission denied
    find: Failed to restore initial working directory: /root: Permission denied
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.19.0
    /usr/bin/node           v22.19.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.19.0-1nodesource1
      Candidate: 22.19.0-1nodesource1
      Version table:
     *** 22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 691)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     2
    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: ioBroker                                 -  enabled
      system.adapter.espresense.0             : espresense            : ioBroker                                 - disabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.onvif.0                  : onvif                 : ioBroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
    + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 4500, bind: 0.0.0.0
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wireless-mbus.0          : wireless-mbus         : ioBroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : ioBroker
    + system.adapter.zigbee.1                 : zigbee                : ioBroker
      system.adapter.zigbee.2                 : zigbee                : ioBroker
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "ankersolix2"  : 2.3.0    , installed 2.3.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.1  , installed 2.12.6
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
    Adapter    "espresense"   : 0.6.3    , installed 0.6.3
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "heatingcontrol": 2.12.15 , installed 2.12.15
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "radar2"       : 2.3.0    , installed 2.3.0
    Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wireless-mbus": 0.10.2   , installed 0.10.2
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects:        32934
    States:         29677
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       46074353   128666/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       46075511   128735/io.shelly.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       46074691   128769/io.sonoff.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12881      1/init
    tcp        0      0 0.0.0.0:4500            0.0.0.0:*               LISTEN      1000       46092954   129380/io.sainlogic
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       46072354   128346/iobroker.js-
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       46069613   128346/iobroker.js-
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13829      295/master
    tcp6       0      0 :::111                  :::*                    LISTEN      0          12883      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11939      1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13830      295/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       46071412   128365/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       46090902   129460/io.web.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       46074129   128561/io.broadlink
    udp        0      0 0.0.0.0:55076           0.0.0.0:*                           1000       46074132   128561/io.broadlink
    udp        0      0 0.0.0.0:56116           0.0.0.0:*                           1000       46074189   128561/io.broadlink
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       46077311   128711/io.radar2.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12882      1/init
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       46076891   128787/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       46076892   128787/io.tuya.0
    udp6       0      0 :::111                  :::*                                0          12884      1/init
    2025-09-04 13:20:25.687  - info: host.ioBroker instance system.adapter.dwd.0 having pid 129670 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-09-04 13:21:00.005  - info: device-watcher.0 (129650) Scheduled restart.
    2025-09-04 13:21:00.005  - info: device-watcher.0 (129650) cleaned everything up...
    2025-09-04 13:21:00.047  - info: device-watcher.0 (129650) terminating
    2025-09-04 13:21:00.048  - info: device-watcher.0 (129650) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2025-09-04 13:21:00.508  - info: device-watcher.0 (129650) terminating
    2025-09-04 13:21:00.602  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
    2025-09-04 13:21:00.602  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
    2025-09-04 13:21:01.909  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 129689
    2025-09-04 13:21:02.748  - info: device-watcher.0 (129689) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
    2025-09-04 13:21:02.782  - info: device-watcher.0 (129689) Number of selected adapters to monitor devices: 5. Loading data from: Nut, Shelly, Sonoff, Unifi, Zigbee ...
    2025-09-04 13:22:00.004  - info: device-watcher.0 (129689) Scheduled restart.
    2025-09-04 13:22:00.005  - info: device-watcher.0 (129689) cleaned everything up...
    2025-09-04 13:22:00.008  - info: device-watcher.0 (129689) terminating
    2025-09-04 13:22:00.008  - info: device-watcher.0 (129689) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2025-09-04 13:22:00.507  - info: device-watcher.0 (129689) terminating
    2025-09-04 13:22:00.560  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
    2025-09-04 13:22:00.560  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
    2025-09-04 13:22:01.876  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 129801
    2025-09-04 13:22:02.680  - info: device-watcher.0 (129801) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
    2025-09-04 13:22:02.716  - info: device-watcher.0 (129801) Number of selected adapters to monitor devices: 5. Loading data from: Nut, Shelly, Sonoff, Unifi, Zigbee ...
    2025-09-04 13:22:18.582  - info: zigbee.0 (128834) checking configure on message :  next attempt in -161707 seconds
    2025-09-04 13:22:18.582  - info: zigbee.0 (128834) Configure on Message for 0x00124b00234e5828
    2025-09-04 13:22:18.582  - info: zigbee.0 (128834) Configuring 0x00124b00234e5828 SNZB-03
    2025-09-04 13:22:28.595  - info: zigbee.0 (128834) Timeout trying to configure 0x00124b00234e5828 SNZB-03 (0).
    iob diag has finished.
    ilovegymI Thomas BraunT 2 Antworten Letzte Antwort
    • F Fichte
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 6
                       RTC time: n/a
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:             0B          0B          0B
               8192 M total memory
               3154 M used memory
               1350 M free memory
                  0 M buffer memory
               3687 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      489M    /var/
      292M    /var/cache
      288M    /var/cache/apt
      147M    /var/lib
      USB-Devices by-id:
      HINT:
      tcp
      HINT:
      tcp
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        32934
      States:         29677
      Pending Updates: 0
      ilovegymI
      ilovegymI
      ilovegym
      #1485
      @fichte na bei sovielen permission denied solltest du mal dein system gerade biegen oder besser neu aufsetzen..da ist grundsaetzlich viel viel schief...
      F 1 Antwort Letzte Antwort
      • ilovegymI ilovegym
        F
        F
        Fichte
        #1486
        @ilovegym sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
        Das system ist eine woche alt ohne Backup zurückspielen
        da_WoodyD ilovegymI 2 Antworten Letzte Antwort
        • F Fichte
          da_WoodyD
          da_WoodyD
          #1487
          @fichte fummelst du da als root rum?
          • F Fichte
            ilovegymI
            ilovegymI
            ilovegym
            schrieb am zuletzt editiert von ilovegym
            #1488
            Dann ging vor ner Woche so einiges schief, deshalb jetzt auch die Probleme.. schau dir die Diagnose doch mal an..
            Mein Tip: iobroker backup starten, datei sichern, komplettes System neu aufsetzen (aber richtig, schau bei Thomas Braun's Tipps) und dann iobroker wieder restoren.
            Edit: ist ne Arbeit von 2h, evtl sogar schneller, je nach System und hardware
            • F Fichte
              Script v.2025-08-09
              *** BASE SYSTEM ***
                Virtualization: lxc
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 6
                               RTC time: n/a
                        RTC in local TZ: no
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Swap:             0B          0B          0B
                       8192 M total memory
                       3154 M used memory
                       1350 M free memory
                          0 M buffer memory
                       3687 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              489M    /var/
              292M    /var/cache
              288M    /var/cache/apt
              147M    /var/lib
              USB-Devices by-id:
              HINT:
              tcp
              HINT:
              tcp
              HINT:
              tcp
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.6.17
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        32934
              States:         29677
              Pending Updates: 0
              Thomas BraunT
              Thomas BraunT
              #1489
              Da stimmt ohnehin irgendwas grundsätzliches nicht mit deinen usern:
              Da muss der user auftauchen, der 'iob diag' aufruft.
              Und auch die Meldungen zu /root: Permission denied sollten auf einem richtig aufgesetzten LXC nicht erscheinen.
              Da hätte ich auch gleich Debian 13 'Trixie' hergenommen.
              • F
                F
                Fichte
                #1490
                Da gebe ich dir Recht.! Ich setz gerade einen neuen LXC auf und mach es noch mal von vorn. Ich hab irgendwo letzte Woche etwas in den USer falsch gemacht 🙄 Ich geb rückmeldung
                • F
                  F
                  Fichte
                  #1491
                  Noch immer das selbe.
                  Habe das ding jetzt per Hand installiert und alle einstellungen händisch eingetragen.
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   22:58:56 up 3 min,  2 users,  load average: 2.07, 1.43, 1.40
                  CPU threads: 4
                                 Local time: Thu 2025-09-04 22:58:56 CEST
                             Universal time: Thu 2025-09-04 20:58:56 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  andre
                  HOME=/home/andre
                  GROUPS=andre sudo users iobroker
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:            8.6G        3.4G        4.4G        147K        774M        5.2G
                  Swap:             0B          0B          0B
                  Total:          8.6G        3.4G        4.4G
                  Active iob-Instances:   39
                           8192 M total memory
                           3253 M used memory
                           3279 M active memory
                            551 M inactive memory
                           4199 M free memory
                              0 M buffer memory
                            739 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  top - 22:58:56 up 3 min,  2 users,  load average: 2.07, 1.43, 1.40
                  Tasks:  71 total,   1 running,  70 sleeping,   0 stopped,   0 zombie
                  MiB Mem :   8192.0 total,   4198.3 free,   3254.6 used,    739.3 buff/cache
                  MiB Swap:      0.0 total,      0.0 free,      0.0 used.   4937.4 avail Mem
                  *** FILESYSTEM ***
                  /dev/loop0     ext4       16G  4.4G   11G  30% /
                  tmpfs          tmpfs      13G  140K   13G   1% /run
                  tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/1000
                  /var:
                  437M    /var/
                  256M    /var/cache
                  252M    /var/cache/apt
                  175M    /var/cache/apt/archives
                  155M    /var/lib
                  Archived and active journals take up 8.0M in the file system.
                  124M    /opt/iobroker/backups/
                  576M    /opt/iobroker/iobroker-data/
                  96M     /opt/iobroker/iobroker-data/files/vis/widgets
                  67M     /opt/iobroker/iobroker-data/files/echarts.admin
                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                  31M     /opt/iobroker/iobroker-data/objects.jsonl
                  26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                  26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                  USB-Devices by-id:
                  HINT:
                  tcp
                  HINT:
                  tcp
                  HINT:
                  tcp
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.9.3
                  /usr/bin/npx            10.9.3
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 182)
                  admin:          7.6.17
                  javascript:     8.9.2
                  Adapter State
                  + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://10.10.10.17:20108
                  + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://10.10.10.18:20108
                    system.adapter.zigbee.2                 : zigbee                : ioBroker                                 - disabled, port: tcp://10.10.10.160:6638
                  + instance is alive
                  Objects and States
                  Objects:        28232
                  States:         26499
                  Hit:1 http://security.debian.org bookworm-security InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       50671491   128/iobroker.js-con
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       50673829   128/iobroker.js-con
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       50681075   767/io.sonoff.0
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       50673641   621/io.shelly.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       50677030   651/io.mqtt.0
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          50671128   1/init
                  tcp        0      0 0.0.0.0:4500            0.0.0.0:*               LISTEN      1001       50692938   1387/io.sainlogic.0
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          50671366   295/master
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          50673752   1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          50671130   1/init
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50669194   306/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       50684708   984/io.web.0
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          50671367   295/master
                  udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       50677143   726/io.radar2.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          50671129   1/init
                  udp        0      0 0.0.0.0:33407           0.0.0.0:*                           1001       50674505   501/io.broadlink2.0
                  udp        0      0 0.0.0.0:36640           0.0.0.0:*                           1001       50669565   501/io.broadlink2.0
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       50677329   786/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       50677330   786/io.tuya.0
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       50673340   501/io.broadlink2.0
                  udp6       0      0 :::111                  :::*                                0          50671131   1/init
                  Proxmox:  ioBroker (22:58)
                  2025-09-04 22:58:48.577  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist nicht mehr erreichbar: \nProxmox:  ioBroker (22:58)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                  2025-09-04 22:59:00.004  - info: device-watcher.0 (1071) Scheduled restart.
                  2025-09-04 22:59:00.004  - info: device-watcher.0 (1071) cleaned everything up...
                  2025-09-04 22:59:00.006  - info: device-watcher.0 (1071) terminating
                  2025-09-04 22:59:00.007  - info: device-watcher.0 (1071) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2025-09-04 22:59:00.507  - info: device-watcher.0 (1071) terminating
                  2025-09-04 22:59:00.554  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
                  2025-09-04 22:59:00.554  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
                  2025-09-04 22:59:01.850  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 1806
                  2025-09-04 22:59:02.767  - info: device-watcher.0 (1806) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
                  2025-09-04 22:59:02.801  - info: device-watcher.0 (1806) Number of selected adapters to monitor devices: 6. Loading data from: Nut, Proxmox, Sonoff, Tuya, Unifi, Zigbee ...
                  2025-09-04 22:59:03.010  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                  2025-09-04 22:59:03.060  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                  2025-09-04 22:59:03.112  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                  2025-09-04 22:59:03.162  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                  2025-09-04 22:59:03.205  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                  2025-09-04 22:59:03.248  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                  2025-09-04 22:59:03.326  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                  2025-09-04 22:59:11.978  - info: device-watcher.0 (1806) Das folgende Gerät ist wieder verfügbar:
                  Proxmox:  ioBroker (22:59)
                  2025-09-04 22:59:12.023  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist wieder verfügbar: \nProxmox:  ioBroker (22:59)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                  2025-09-04 22:59:12.192  - info: device-watcher.0 (1806) Das folgende Gerät ist nicht mehr erreichbar:
                  2025-09-04 22:59:12.237  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist nicht mehr erreichbar: \nProxmox:  ioBroker (22:59)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                  • F Fichte
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    andre
                    HOME=/home/andre
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Swap:             0B          0B          0B
                             8192 M total memory
                             3253 M used memory
                             4199 M free memory
                                0 M buffer memory
                              739 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    *** FILESYSTEM ***
                    /var:
                    437M    /var/
                    256M    /var/cache
                    252M    /var/cache/apt
                    155M    /var/lib
                    USB-Devices by-id:
                    HINT:
                    tcp
                    HINT:
                    tcp
                    HINT:
                    tcp
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.9.3
                    /usr/bin/npx            10.9.3
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.6.17
                    javascript:     8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        28232
                    States:         26499
                    Pending Updates: 0
                    Thomas BraunT
                    Thomas BraunT
                    #1492
                    Zumindest die grundsätzlichen Kinken sind jetzt raus.
                    Was sagt denn
                    cd /opt/iobroker/ && npm ls cron-parser
                    • F
                      F
                      Fichte
                      #1493
                      iobroker.inst@3.0.0 /opt/iobroker
                      ├─┬ iobroker.backitup@3.3.5
                      │ ├── cron-parser@5.3.1
                      │ └─┬ node-schedule@2.1.1
                      │   └── cron-parser@4.9.0
                      ├─┬ iobroker.js-controller@7.0.7
                      └─┬ iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
                        └─┬ node-schedule@1.3.3
                          └── cron-parser@2.18.0
                      • F Fichte
                        Thomas BraunT
                        Thomas BraunT
                        #1494
                        @fichte
                        Hab den Adapter auch gerade mal installiert. Schaut hier ähnlich aus:
                        2025-09-04 23:21:15.515  - info: device-watcher.0 (1054123) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v24.7.0, js-controller: 7.0.7
                        2025-09-04 23:21:15.547  - info: device-watcher.0 (1054123) Number of selected adapters to monitor devices: 1. Loading data from: Alexa2 ...
                        2025-09-04 23:21:16.753  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 23:21:16.763  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        2025-09-04 23:21:16.867  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                        F 2 Antworten Letzte Antwort
                          @fichte
                          F
                          F
                          Fichte
                          #1495
                          Dank deines Tipps hab ich jetzt erst mal ein Sauberes System 👍
                          Jetzt Lösche ich gerade alle Adapter Rückwärts um zu sehen ob es an einem Adapter liegt.
                            @fichte
                            F
                            F
                            Fichte
                            #1496
                            Also wenn ich alle Instanzen mit CRON Job Lösche ist der Fehler nach und nach weg wie zbs. bei mir:
                            ical
                            feiertage
                            dwd
                            das wetter
                            Der Fehler tritt auch auf wenn man die Zeiten zum Abrufen der Daten wie ical ändern möchte.
                            Wie ich gesehen habe ist der Entwickler des Adapters nicht mehr hier.
                            Wird dieser Adapter von jemand anderen weitere geführt oder war es das damit.?
                            Liebe Grüße
                            • F Fichte
                              ical
                              feiertage
                              dwd
                              das wetter
                              Liebe Grüße
                              arteckA
                              arteckA
                              arteck
                              #1497
                              wenn du RICHTIG geschaut hättest würdest du festgestellt haben dass ich den pflege..
                              ich kann dir nicht folgen welche Einstellungen du meinst.. zeigmal screenshot
                              • arteckA arteck
                                F
                                F
                                Fichte
                                #1498
                                @arteck
                                Es war eine normale frage und wollte hier keinen Ankreiten, Sorry.
                                Der Fehler Erscheint bei Instanzen mit CronJobs
                                Lösche ich die Instanz ist der Fehler nach und nach weg.
                                Ich hatte Anfangs 7 solcher Instanzen und nach löschen der der einzellnen Instanzen wurden die fehler immer weniger bis gaanz weg.
                                da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
                                • F Fichte
                                  @arteck
                                  da_WoodyD
                                  da_WoodyD
                                  #1499
                                  @fichte Instanzen oder Adapter?
                                  • da_WoodyD da_Woody
                                    F
                                    F
                                    Fichte
                                    #1500
                                    @da_woody
                                    Hab es Korrigiert, ich meinte instanzen.
                                    • F Fichte
                                      @arteck
                                      Thomas BraunT
                                      Thomas BraunT
                                      #1501
                                      @fichte
                                      Du meinst Meldungen wie diese?
                                      Hat mit cron-Instanzen nichts zu tun, ich hab bei mir nur den Alexa2 mal aktiviert, der ist kein cron-Adapter.
                                      F arteckA 2 Antworten Letzte Antwort
                                        @fichte
                                        F
                                        F
                                        Fichte
                                        #1502
                                        Bei mir hängt es mit den cron-instanzen zusammen.
                                        Keine andere Instanz hängt mit dem Fehler zusammen.
                                        Hatte 7x den Fehler und nach löschen der Instanzen in verbindung mit cron werden es immer weniger.
                                        Ich hab auch genau 7 Instanzen mit cron.
                                        LG
                                          @fichte
                                          arteckA
                                          arteckA
                                          arteck
                                          #1503
                                          @thomas-braun welche adapter Einstellung ist das.. ?? die ??
                                          83.9k
