  3. Entwicklung
  4. Adapter Worx Landroid v3.x.x
    6.3k
814 Beiträge 91 Kommentatoren 248.1k Aufrufe 78 Beobachtet
  • Dr. BakteriusD Online
    Dr. Bakterius
    #564
    Nachdem es eh schon egal ist, habe ich es gerade gewagt den Adapter neu von GIT zu installieren und mich zu verbinden. Die App ist nach wie vor nirgends installiert.
    Folgendes Log:
    2025-07-03 08:48:44.913 - debug: worx.0 (1151037) Redis Objects: Use Redis connection: 127.0.0.1:6379
    2025-07-03 08:48:44.924 - debug: worx.0 (1151037) Objects client ready ... initialize now
    2025-07-03 08:48:44.924 - debug: worx.0 (1151037) Objects create System PubSub Client
    2025-07-03 08:48:44.925 - debug: worx.0 (1151037) Objects create User PubSub Client
    2025-07-03 08:48:44.980 - debug: worx.0 (1151037) Objects client initialize lua scripts
    2025-07-03 08:48:44.983 - debug: worx.0 (1151037) Objects connected to redis: 127.0.0.1:6379
    2025-07-03 08:48:44.988 - debug: worx.0 (1151037) Redis States: Use Redis connection: 127.0.0.1:9000
    2025-07-03 08:48:45.004 - debug: worx.0 (1151037) States create System PubSub Client
    2025-07-03 08:48:45.005 - debug: worx.0 (1151037) States create User PubSub Client
    2025-07-03 08:48:45.075 - debug: worx.0 (1151037) States connected to redis: 127.0.0.1:9000
    2025-07-03 08:48:45.098 - debug: worx.0 (1151037) Plugin sentry Initialize Plugin (enabled=true)
    2025-07-03 08:48:45.274 - info: worx.0 (1151037) starting. Version 3.2.6 (non-npm: iobroker-community-adapters/ioBroker.worx) in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.3, js-controller: 7.0.6
    2025-07-03 08:48:45.297 - debug: worx.0 (1151037) Use old blocking data!
    2025-07-03 08:48:45.346 - debug: worx.0 (1151037) Save user and password!!
    2025-07-03 08:48:45.348 - debug: worx.0 (1151037) Server have not been changed!
    2025-07-03 08:48:45.377 - info: worx.0 (1151037) Login to worx
    2025-07-03 08:48:45.377 - debug: worx.0 (1151037) Session value: 0
    2025-07-03 08:48:45.377 - info: worx.0 (1151037) Start login
    2025-07-03 08:48:46.028 - debug: worx.0 (1151037) {"token_type":"Bearer","expires_in":3600,"access_token":"***"}
    2025-07-03 08:48:46.028 - debug: worx.0 (1151037) Login Header: {"date":"Thu, 03 Jul 2025 06:48:46 GMT","content-type":"application/json; charset=UTF-8","transfer-encoding":"chunked","connection":"keep-alive","cf-ray":"***","vary":"Accept-Encoding","pragma":"no-cache","cache-control":"no-cache, no-store, max-age=0, must-revalidate","expires":"Mon, 01 Jan 1990 00:00:00 GMT","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
    2025-07-03 08:48:46.029 - info: worx.0 (1151037) Connected to worx server
    2025-07-03 08:48:46.399 - error: worx.0 (1151037) AxiosError: Request failed with status code 429
    2025-07-03 08:48:46.399 - info: worx.0 (1151037) The maximum number of requests has been reached!
    2025-07-03 08:48:46.400 - error: worx.0 (1151037) Device Header: {"date":"Thu, 03 Jul 2025 06:48:46 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"keep-alive","server":"nginx","retry-after":"65013","x-ratelimit-throttle":"true","cache-control":"no-cache, private","x-robots-tag":"noindex, nofollow"}
    2025-07-03 08:48:46.400 - error: worx.0 (1151037) Device retry-after: 18:03:33
    2025-07-03 08:48:46.400 - error: worx.0 (1151037) {"message":"Too Many Attempts."}
    2025-07-03 08:48:46.488 - info: worx.0 (1151037) Start MQTT connection
    2025-07-03 08:48:46.488 - warn: worx.0 (1151037) No mower found to start mqtt
    2025-07-03 08:48:46.489 - debug: worx.0 (1151037) Start refreshTokenInterval!
    2025-07-03 08:48:46.489 - info: worx.0 (1151037) Start check devices object!
    @Lucky_ESA: Wenn ich das richtig verstehe, sollte die Sperre morgen um 02:52:19 Uhr aufgehoben werden? Ich habe den Adapter mal gestoppt und werde weder die App installieren noch einen Login bei Worx versuchen. Soll der Mäher auch abgeschaltet werden? Und wie nach Ablauf der Zeit am Besten vorgehen? Kannst du noch Infos gebrauchen?
    L 1 Antwort Letzte Antwort
    • L Lucky_ESA
      Das ist korrekt. Worx hat die Sperrzeit geändert. Daher können sich User auch bereits wieder einloggen. Das wäre ja mal positives.
      S Online
      S Online
      schmuh
      #565
      @lucky_esa
      Vielleicht habe die auch die Sperrzeit nach oben geändert 😠
      Device Header: {"date":"Thu, 03 Jul 2025 07:41:19 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","server":"nginx","retry-after":"5156320","x-ratelimit-throttle":"true","cache-control":"no-cache, private","x-robots-tag":"noindex, nofollow"}
      Demnach noch knapp 60 Tage! 😥 Auf Supportmails bekomme ich seit Tagen nur Standard Antworten.
        MartyBr
        #566
        Mich hat es nun auch (natürlich im Urlaub) auch erwischt. Ich habe an Mail an Positec geschrieben und warte auf Antwort. Den Adapter habe ich seit einigen Tagen aus. Die App habe ich entfernt und warte ca. 48 Stunden auf einen neuen Versuch.
        Martin
        Homematic und Homematic IP
        • M manny4566
          @lucky_esa
          weiß nicht, ob es hilft.
          der kommt trotzdem direkt wieder nach dem Adapter Start. Und der Adapter bleibt gelb.
          worx.0
          2025-07-02 19:45:09.239	error	AxiosError: timeout of 5000ms exceeded
          L Online
          L Online
          Lucky_ESA
          #567
          @manny4566 sagte in Adapter Worx Landroid v3.x.x:
          @lucky_esa
          worx.0
          Hier stimmt was mit deiner Internet Verbindung nicht. Kannst du dich den auf id.worx.com einloggen?
          • S schmuh
            @lucky_esa
            L Online
            L Online
            Lucky_ESA
            #568
            @schmuh sagte in Adapter Worx Landroid v3.x.x:
            @lucky_esa
            Hier weiter den Sipport nerven. Am besten täglich.
            Gruß//Lucky
              Folgendes Log:
              L Online
              L Online
              Lucky_ESA
              #569
              @dr-bakterius Da zeigt dein Log. Dann hoffen wir mal das nicht eine neue Sperre kommt.
              • K ktsalti
                @lucky_esa
                Ich habe heute folgende Antwort von Worx erhalten:
                vielen Dank, dass Sie sich an den Worx Support gewandt haben.
                Unsere Kollegen an der Fachabteilung arbeiten zurzeit an einer Lösung. Bitte überprüfen Sie, ob Sie morgen Zugriff an den App und an unsere Webseite haben. Wir bitten um Ihr Geduld und Verständnis über diesen Fall.
                Für Rückfragen stehen wir Ihnen jederzeit zur Verfügung.
                Ihr Worx Support-Team
                Ich habe trotzdem versucht den Adapter zu startet - heute eine andere Fehlermeldung:
                Token Header: {"date":"Wed, 02 Jul 2025 19:18:07 GMT","content-type":"text/plain","content-length":"21","connection":"close","cf-ray":"95907cba59fdb813-WAW","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
                naja, da hilft wohl nur weiter abwarten ;/
                L Online
                L Online
                Lucky_ESA
                #570
                @ktsalti Du befindest dich noch in der 24h Sperre. Vor dem nächsten Start bitte erst den roten Button in der Instanzeisntellung drücken.
                • N Offline
                  N Offline
                  netfriend
                  #571
                  Ich habe die vom Support per Mail genannte Sperrzeit abgewartet und nun versucht, nach Neuinstallation der App diese zu starten. Immer noch der selbe Fehler.
                  Daraufhin habe ich den Adapter gestartet in der Hoffnung, zu erfahren, ob sich an der Sperrzeit etwas geändert hat.
                  Allerdings wird mir kein "Device-Header" angezeigt, sondern das
                  Hat noch jemand ne Idee?
                  • N netfriend
                    #572
                    @netfriend 86400 sind exakt 24h
                    N 1 Antwort Letzte Antwort
                      N Offline
                      N Offline
                      netfriend
                      #573
                      @homoran Ist mir bewusst. Mir wurde aber ein Datum und eine Uhrzeit vom Support genannt, bis wann die Sperre gelten soll. Wenn man es danach versucht, erhält man wieder 24h ??? Versteh ich nicht. Was willst Du mir damit sagen. Jeder Versuch erzeugt eine Sperre von 24h ohne dass man es jemals genutzt hat? 🤔
                      N L 2 Antworten Letzte Antwort
                      • N netfriend
                        N Offline
                        N Offline
                        nullfreizeit
                        #574
                        @netfriend
                        So ist es bei mir auch. Würde mich freuen wenn ihr uns an euren Tricks teilhaben lassen könnt
                        • WebrangerW Offline
                          WebrangerW Offline
                          Webranger
                          #575
                          Ist das neu?
                          Adapter kann ich Starten und läuft aber er findet nun keinen Mäher mehr.
                          App geht nicht und auf https://id.worx.com/ kommt immer noch "429 TOO MANY REQUESTS"
                          2025-07-03 21:25:04.649 - info: worx.1 (89811) Login to worx
                          2025-07-03 21:25:04.702 - debug: worx.1 (89811) Session value: 0
                          2025-07-03 21:25:04.702 - info: worx.1 (89811) Start login
                          2025-07-03 21:25:05.506 - debug: worx.1 (89811) {"
                          Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                          • WebrangerW Webranger
                            Ist das neu?
                            L Online
                            L Online
                            Lucky_ESA
                            #576
                            @webranger Unverzüglich dein Token löschen. Wir haben hier schon genug Probleme
                            WebrangerW HomoranH 2 Antworten Letzte Antwort
                            • L Lucky_ESA
                              WebrangerW Offline
                              WebrangerW Offline
                              Webranger
                              #577
                              @lucky_esa Du meinst die Sitzungsdaten löschen mit dem roten Button? Das hab ich gemacht vorm Starten. Oder meinst du was anderes
                              Thomas BraunT L 2 Antworten Letzte Antwort
                              • N netfriend
                                L Online
                                L Online
                                Lucky_ESA
                                #578
                                @netfriend Gerne erkläre ich es erneut.
                                Der Adapter und die APP gehen wie folgt vor:
                                1. Login -> Wenn die 24h Sperre nicht vorhanden ist alles OK -> Token kommt
                                2. API Abfrage deiner Daten -> Das ist die 72 Tage Sperre. Wenn diese noch nicht abgelaufen ist dann wird der Login erneut für 24h gesperrt
                                Ihr müsst dem Support sagen das ihr > 60 Tage gesperrt seit.
                                  #579
                                  @webranger
                                  Nein, in Zeile 4 steht dein Zugangsschlüssel drin. Nimm den raus.
                                  • L Lucky_ESA
                                    #580
                                    @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                                    ich hab mal sicherheitshalber alles gelöscht
                                      saeft_2003
                                      #581
                                      Ich bin jetzt für 59 Tage gesperrt.
                                      worx.0
                                      2025-07-03 14:21:47.480	error	{"message":"Too Many Attempts."}
                                      worx.0
                                      2025-07-03 14:21:47.480	error	Device retry-after: 59d - 11:38:12
                                      worx.0
                                      2025-07-03 14:21:47.479	error	Device Header: {"date":"Thu, 03 Jul 2025 12:21:47 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"keep-alive","server":"nginx","retry-after":"5139492","x-ratelimit-throttle":"true","cache-control":"no-cache, private","x-robots-tag":"noindex, nofollow"}
                                      Das ist die Antwort vom „support“. Was meint ihr wie ich jetzt reagieren soll?
                                      vielen Dank für Ihre Rückmeldung.
                                      Der Hersteller arbeitet zurzeit an einer Lösung. Wir bitten Sie noch um etwas Geduld.
                                      Wenn Sie weitere Fragen haben, zögern Sie bitte nicht, uns zu kontaktieren. Um die Ticketnummer und den Verlauf beizubehalten, antworten Sie bitte auf diese Nachricht. Andernfalls wird ein neues Ticket eröffnet und Ihr Anliegen wird erneut behandelt.
                                      Ihr Worx Support Team
                                      Um Ihnen unkompliziert und schnell weiterhelfen zu können, nutzen sie bitte unseren Livechat:
                                      https://eu.worx.com/de-de/support-fuer-landroid/
                                      Mit freundlichen Grüßen
                                      Anke Tanner
                                      Tel.: +4922195673161
                                        L Online
                                        L Online
                                        Lucky_ESA
                                        #582
                                        @webranger sagte in Adapter Worx Landroid v3.x.x:
                                        Das muss hier jeder verstehen. Ich kann diesen Token nehmen und die nächste DDOS Attacke auf Worx starten. Werde die Logausgabe rauswerfen.
                                        Biite niemals, überhaupt nicht, auf keinen Fall den Token und den Refresh Token irgendwo posten
                                        falke69F 1 Antwort Letzte Antwort
                                        • EvilElsE Offline
                                          EvilElsE Offline
                                          EvilEls
                                          #583
                                          Nachdem meine Device retry-after: Sperre abgelaufen war (Support nerven), habe ich mir neue IP besorgt und auf https://id.worx.com/user/applications
                                          die Lagacy App rausgeschmissen.
                                          Dann im Adapter roten Button, danach Adapter gestartet:
                                          2025-07-04 00:18:13.524	info	Start Update for all devices
                                          2025-07-04 00:18:13.523	info	Request Counter: 1
                                          2025-07-04 00:18:13.244	info	Start check devices object!
                                          2025-07-04 00:18:13.082	info	Start MQTT connection
                                          2025-07-04 00:18:13.014	info	Autolock found! Create State : AutoLockTimer
                                          2025-07-04 00:18:13.013	info	Autolock found! Create State : AutoLock
                                          2025-07-04 00:18:13.005	info	ACS Module found! Create State : US.ACS_Status
                                          2025-07-04 00:18:13.002	info	ACS Module found! Create State : US.ACS
                                          2025-07-04 00:18:12.998	info	ACS Module found! Create State : US
                                          2025-07-04 00:18:12.991	info	Torque control found, create states...
                                          2025-07-04 00:18:12.632	info	Create product folder and states for WR165E
                                          2025-07-04 00:18:12.215	info	Create folder activityLog and set states.
                                          2025-07-04 00:18:12.204	info	No new Firmware found, create dummy states...
                                          2025-07-04 00:18:12.201	info	No new Firmware found, check states...
                                          2025-07-04 00:18:12.193	info	PartyModus found, create states...
                                          2025-07-04 00:18:12.191	info	OneTimeShedule found, create states...
                                          2025-07-04 00:18:12.168	info	DoubleShedule found, create states...
                                          2025-07-04 00:18:11.987	info	Multi-ZoneKeeper found! Create State : zoneKeeper
                                          2025-07-04 00:18:11.913	info	Found device M with id xxx
                                          2025-07-04 00:18:11.912	info	Found 1 devices
                                          2025-07-04 00:18:11.701	info	Connected to worx server
                                          2025-07-04 00:18:11.114	info	Start login
                                          2025-07-04 00:18:11.111	info	Login to worx
                                          2025-07-04 00:18:10.960	info	starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.1, js-controller: 7.0.7
                                          Kein Fehler mehr.
                                          Adapter Neustarts ebenfalls problemlos.
                                          Einstellungen über Adapter ändern klappt auch:
                                          2025-07-04 00:36:10.999	debug	Test Status: 1
                                          2025-07-04 00:36:10.966	debug	GET MQTT DATA from API: {xxx}
                                          2025-07-04 00:36:10.961	debug	Set new timestamp
                                          2025-07-04 00:36:10.961	debug	lastCommand_start: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0},"request":1751582169180,"response":0,"action":"worx.0.xxx.mower.partyModus","user":"iobroker"}}
                                          2025-07-04 00:36:10.960	debug	Request ID 57099 has been passed to the mower
                                          2025-07-04 00:36:10.960	debug	Worxcloud MQTT get Message for mower M (xxx)
                                          2025-07-04 00:36:10.960	debug	topic: PRM100/xxx/commandOut
                                          2025-07-04 00:36:10.960	debug	Mower MQTT: {xxx}
                                          2025-07-04 00:36:10.785	debug	Test Status: 1
                                          2025-07-04 00:36:10.762	debug	GET MQTT DATA from API: {xxx}
                                          2025-07-04 00:36:10.760	debug	Update this.deviceArray: 0
                                          2025-07-04 00:36:10.760	debug	Index Update: 0
                                          2025-07-04 00:36:10.561	info	Start Update for all devices
                                          2025-07-04 00:36:10.560	debug	Mower Endpoint : iot.eu-west-1.worxlandroid.com with user id xxx and mqtt registered true iot_registered true online true
                                          2025-07-04 00:36:10.558	debug	MQTT connected to: iot.eu-west-1.worxlandroid.com
                                          2025-07-04 00:36:10.557	debug	MQTT connection: {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}
                                          2025-07-04 00:36:10.229	debug	MQTT reconnect
                                          2025-07-04 00:36:09.228	debug	Offline
                                          2025-07-04 00:36:09.184	debug	sendData: {"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}
                                          2025-07-04 00:36:09.184	debug	this.mqtt_response_check: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0},"request":1751582169180,"response":0,"action":"worx.0.xxx.mower.partyModus","user":"iobroker"}}
                                          2025-07-04 00:36:09.177	debug	lastCommand_start: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}}
                                          2025-07-04 00:36:09.176	debug	Start MQTT ping: {"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}
                                          2025-07-04 00:36:09.176	debug	length: 0
                                          2025-07-04 00:36:09.176	info	Request Counter: 2
                                          2025-07-04 00:36:09.175	debug	Worxcloud MQTT sendMessage to xxx Message: {"sc":{ "m":1, "distm": 0}}
                                          2025-07-04 00:36:09.175	debug	state change: id_____ worx.0.xxx.mower.partyModus Mower xxx_____partyModus______{xxx}
                                          2025-07-04 00:36:09.174	debug	this.modules! {"xxx":{"edgeCut":false,"notify":true,"notify_excluded":["4","5","16","18"],"tq":0,"channel":true,"US":{"enabled":1},"al":{"lvl":0,"t":300},"al_last":300}}
                                          2025-07-04 00:36:09.174	debug	Request SN: xxx
                                          App ist seit Tagen deinstalliert.
                                          Nach Neuinstallation funktioniert diese auch wieder.
                                          Nachdem ich einen neuen Account erstellt hatte, war ich schon einmal so weit.
                                          Mal sehen, wie lange das nun funktioniert.
                                          Letztens hielt es für 3 oder 4 Tage.
                                          D M H 3 Antworten Letzte Antwort
