  4. Tester für Zigbee Adapter 2.0.x gesucht
zigbee 2.0.1
529 Beiträge 51 Kommentatoren 147.5k Aufrufe 41 Beobachtet
    @asgothian sagte in Tester für Zigbee Adapter 2.0.x gesucht:
    Welche Versionen hast du (js-Controller, nodeJS ?
    7.0.6
    20.18.3
    und gerade eben nochmal versucht
    zigbee.0
    	2025-04-22 21:54:01.838	error	uncaught exception: request.headers.split is not a function
    zigbee.0
    	2025-04-22 21:54:01.838	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
    zigbee.0
    	2025-04-22 21:54:01.838	error	request.headers.split is not a function
    host.ioBrokerpi5
    	2025-04-22 21:54:01.986	error	Caught by controller[0]: TypeError: request.headers.split is not a function
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
    host.ioBrokerpi5
    	2025-04-22 21:54:01.987	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    was immer elf elf ist 😂
    !! eins elf kenn ich ja
    FabioF Offline
    FabioF Offline
    Fabio
    schrieb am zuletzt editiert von Fabio
    #408
    @homoran sagte in Tester für Zigbee Adapter 2.0.x gesucht:
    7.0.6
    20.18.3
    ich habe die 7.0.6 und Node.js: v20.19.0
    und Sentry ist bei beiden Instanzen bei mir an und macht keine Probleme. Echt komisch.
    Evtl. mal die ganze Kiste sauber runterfahren und neu starten.
    Fabio
    Iobroker:
    • Matter over Thread Hilfe
    • arteckA arteck
      @homoran das ist sentry..was da spinnt..
      klickmal
      #409
      @arteck sagte in Tester für Zigbee Adapter 2.0.x gesucht:
      das war das einzige im log das ich zuordnen konnte!
      Also jetzt
      sentry aus!
      Check gestartet!
      Das übliche :-(
      zigbee.0
      	2025-04-23 07:51:14.338	warn	readNvBackup called
      zigbee.0
      	2025-04-23 07:51:14.344	warn	readNvBackup returns {"channel":11,"precfgkey":"weg damit","extPanID":"geändert","panID":auch}
      zigbee.0
      	2025-04-23 07:52:35.533	warn	readNvBackup called
      zigbee.0
      	2025-04-23 07:52:35.534	warn	readNvBackup returns {"channel":11,"precfgkey":"weg damit","extPanID":"geändert","panID":auch}
      zigbee.0
      	2025-04-23 07:52:45.070	error	uncaught exception: request.headers.split is not a function
      zigbee.0
      	2025-04-23 07:52:45.070	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
      zigbee.0
      	2025-04-23 07:52:45.070	error	request.headers.split is not a function
      zigbee.0
      	2025-04-23 07:52:45.085	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      host.ioBrokerpi5
      	2025-04-23 07:52:45.272	error	Caught by controller[0]: TypeError: request.headers.split is not a function
      host.ioBrokerpi5
      	2025-04-23 07:52:45.275	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.275	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.275	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.276	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.276	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
      host.ioBrokerpi5
      	2025-04-23 07:52:45.276	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      (die warn kamen mit der v3)
      FabioF AsgothianA 2 Antworten Letzte Antwort
        Also jetzt
        sentry aus!
        Check gestartet!
        Das übliche :-(
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        host.ioBrokerpi5
        FabioF Offline
        FabioF Offline
        Fabio
        #410
        @homoran hast du dein Sytem mal neu gestartet?
        Iobroker:
        • FabioF Fabio
          #411
          @fabio ja!
          mach ich aber später gerne nochmal, muss gleich weg.
          FabioF 1 Antwort Letzte Antwort
            @fabio ja!
            FabioF Offline
            FabioF Offline
            Fabio
            #412
            @homoran das brauchst du nicht wenn du es schon gemacht hast, da hängt wohl noch was anderes. Sonst läuft dein System stabil? Ich denke ja ;-)
            Herzliche Grüße
            Fabio
            Iobroker:
            • FabioF Fabio
              Herzliche Grüße
              Fabio
              arteckA Offline
              arteckA Offline
              arteck
              #413
              @fabio sagte in Tester für Zigbee Adapter 2.0.x gesucht:
              und das liesst du woraus ??
                Also jetzt
                sentry aus!
                Check gestartet!
                Das übliche :-(
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                host.ioBrokerpi5
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #414
                Ja, die sind in der V3 noch drin. Werden es aber nicht ins Stable schaffen.
                Probier bitte mal folgendes:
                • geh durch deine Zigbee Geräte durch. Meines Wissens sind es nicht so wahnsinnig viele
                • Such Dir einen Geräte typ aus (T1). Deaktiviere alle Geräte die nicht vom Typ T1 sind. Dann scan. Das ganze wiederholen mit jedem Gerätetyp den du hast (ich sehe in Deiner Liste 3 Gerätetypen.
                • sollte bei genau einem Gerätetyp (Tk) der Fehler auftreten und bei allen anderen nicht bleibt noch der 2. Test:
                  -- Reaktiviere alle Geräte.
                  -- Deaktiviere alle Geräte des Typs Tk bis auf eins. Testen. Das so lange wiederholen bis klar ist ob der Fehler an einem Gerät, einer Gruppe von Geräten oder einem Gerätetyp hängt.
                Danach bitte alle Geräte wieder aktivieren - sonst funktionieren deine Smarten Dinge nicht.
                A.
                • arteckA arteck
                  FabioF Offline
                  FabioF Offline
                  Fabio
                  #415
                  @arteck das Resultat der Versuche zeigt wohl das es evtl. wo anders hängt.
                  Iobroker:
                  • AsgothianA Asgothian
                    A.
                    #416
                    @asgothian Danke!
                    Wenn ich es richtig gemacht habe, bin ich jetzt verwirrt
                    richtig!
                    Eigentlich nur Steckdosen, Dann zum testen und helfen 1x IKEA RGB E27 und 1x IKEA FB.
                    Letztere beide zuerst deaktiviert.
                    War das einfachste
                    Dann alle Steckdosen deaktiviert und nur die FB aktiv und wachgehalten
                    nichts weiter gemacht, nur wieder deaktiviert und die RGB aktiviert
                    auch jetzt nichts weiter gemacht.
                    Würde jetzt wieder alles aktivieren und nochmal mit allem testen
                      #417
                      War jetzt zu ungeduldig, weil ich schon wieder unter etwas "Zeitdruck" stehe.
                      Hab alle Geräte wieder aktiviert!
                      Das erste wa mir auffiel, war dass die Fernbedienung erstmalig den Batteriezustand anzeigte.
                      Der check lief durch, kein Absturz!
                      Die RGB und die FB zeigten das grüne Firmware verfügbar Icon, die Steckdosen den ok-Haken
                      hab beide angetippt und es sprang sofort auf den ok-Haken.
                      im log nur die warn, die anscheinend bei jedem umdrehen aller Kacheln kommen
                      Kein Hinweis auf irgendein Update.
                      Also nochmal check
                      Die Steckdosen zeigten sofort den ok-Haken, RGB und FB rödelten sich mit "checking" tot.
                      nichts im log
                      Also das ganze Spiel nochmal.
                      RGB und FB zeigten Download verfügbar.
                      Nur die FB gestartet, diesmal Haken in blau!
                      ins log gesehen und einen älteren Eintrag gefunden
                      zigbee.0
                      	2025-04-23 11:39:42.911	error	Update of '0x000b57fffebacd87' failed ([0x000b57fffebacd87 | TRADFRI remote control] Timeout. Device did not start/finish firmware download after being notified. (Timeout - 25594 - 1 - undefined - 25 - 3 after 150000ms))
                      zigbee.0
                      	2025-04-23 11:39:45.357	error	Update of '0xd0cf5efffe298051' failed ([0xd0cf5efffe298051 | TRADFRI bulb E27 CWS opal 600lm] Timeout. Device did not start/finish firmware download after being notified. (Timeout - 34907 - 1 - undefined - 25 - 3 after 150000ms))
                      war aber vorhin nicht da.
                      Kein weitere Hinweis auf update.
                      jetzt warte ich mal
                        #418
                        Das Leben ist wie eine Pralinenschachtel. Man weiss nie was man als nächstes bekommt!
                        Hab einfach mutig weitergemacht!
                        im Gegensatz zu
                        @pk68 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                        dass sich am data code nichts geändert hat.
                        hat sich bei mir etwas geändert.
                        und zwar anscheinend mehrmals.
                        Gab also mehrere Updates
                        jetzt
                        und
                        von 2016 ... auf 2022
                          im Gegensatz zu
                          jetzt
                          und
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #419
                          @homoran Das ist durchaus normal. Dadurch das der Durchsatz im Zigbee Netz massiv begrenzt ist dauert ein Firmware-Update gerne mal 10-60 Minuten, wenn es einmal gestartet wurde.
                          Offensichtlich hast du es zu einem Zeitpunkt mal gestartet, und die Geräte haben das Update durchgezogen.
                          A.
                            A.
                            #420
                            im log war nie etwas zu sehen
                            Aber warum der Controller den Adapter jedesmal gestoppt hatte wenn ich nach upgrades gesucht hatte kann ich nicht nachvollziehen.
                            Hab eben auch nochmal versucht, nachdem ich erst vergessen hatte senty wieder zu aktivieren, diesmal mit sentry: auch slles ok 🤔
                            • AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #421
                              @homoran ganz schwer zu sagen.
                                #422
                                @asgothian ist mir klar.
                                es gibt ja keine entsprechenden Fakten
                                • FabioF Fabio
                                  7.0.6
                                  20.18.3
                                  Fabio
                                  #423
                                  da war ich echt ins Schleudern geraten.
                                  hab gerade ein update gestartet
                                  Unpacking nodejs (20.19.1-1nodesource1) over (20.19.0-1nodesource1)
                                  also hätte, wie gedacht, 20.19.0 drauf sein müssen 🤔
                                  auch danach stand noch 20.18.3 im Reiter Hosts.
                                  erst nach erneutem iob restart war das aktuell
                                    #424
                                    BULLSHIT!
                                    Jetzt crasht es wieder
                                    zigbee.0
                                    	2025-04-23 17:24:51.541	error	uncaught exception: request.headers.split is not a function
                                    zigbee.0
                                    	2025-04-23 17:24:51.541	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                                    zigbee.0
                                    	2025-04-23 17:24:51.541	error	request.headers.split is not a function
                                    zigbee.0
                                    	2025-04-23 17:24:51.556	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.763	error	Caught by controller[0]: TypeError: request.headers.split is not a function
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.765	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.765	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.765	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.765	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.765	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.766	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.766	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.766	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.766	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.766	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                                    host.ioBrokerpi5
                                    	2025-04-23 17:24:51.766	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      BULLSHIT!
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      host.ioBrokerpi5
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #425
                                      @homoran einfach so oder wieder beim Firmware Update Versuch ?
                                        #426
                                        @asgothian sorry, natürlich wieder beim Firmware check
                                        bin schon wieder weiter, aber so richtig statistisch belastbar istvdas in meinen Augen noch nicht.
                                        Habe wieder alle Typen bis auf die IKEA Inspelning deaktiviert, neuer Versuch, trotzdem Crash.
                                        Dann hatte ich eine Idee.
                                        ich hatte ja wieder sentry aktiviert, und jetzt einen iob Restart gemacht.
                                        also sentry in der Instanz dealktiviert und diesmal die Instanz neu gestartet.
                                        Danach crashte es beim Firmwarecheck aller Geräte auf einmal nicht mehr
                                        Zusatzinfo.
                                        ich hatte mittlerweile mal testweise eine der verbannten LIDL Steckdosen wieder eingebunden.
                                        Da war ein Firmwareupdate verfügbar.
                                        Hatte upgedatet ungd gehofft...
                                        Aber leider kommt immer noch die Meldung bei der Karte, dass keine Routingtabelle geladen werden kann und die Steckdose refreshed immer noch alle few seconds bis max. 2-3 Minuten
                                        (erst einige Zeit später Node update und iob restart)
                                        sehe gerade, der letzte ERRORLOG war deutlich länger
                                        zigbee.0
                                           2025-04-23 17:29:14.037	error	uncaught exception: request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.038	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                                        zigbee.0
                                           2025-04-23 17:29:14.038	error	request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.076	error	uncaught exception: request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.077	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        zigbee.0
                                           2025-04-23 17:29:14.077	error	request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.078	error	uncaught exception: request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.078	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        zigbee.0
                                           2025-04-23 17:29:14.079	error	request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.080	error	uncaught exception: request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.081	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        zigbee.0
                                           2025-04-23 17:29:14.081	error	request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.082	error	uncaught exception: request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.082	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        zigbee.0
                                           2025-04-23 17:29:14.082	error	request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.084	error	uncaught exception: request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.084	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        zigbee.0
                                           2025-04-23 17:29:14.084	error	request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.105	error	uncaught exception: request.headers.split is not a function
                                        zigbee.0
                                           2025-04-23 17:29:14.105	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        zigbee.0
                                           2025-04-23 17:29:14.105	error	request.headers.split is not a function
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.294	error	Caught by controller[0]: TypeError: request.headers.split is not a function
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[1]: TypeError: request.headers.split is not a function
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.295	error	Caught by controller[1]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at Channel.publish (node:diagnostics_channel:150:9)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at new Request (node:internal/deps/undici/undici:2008:27)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at Intercept (node:internal/deps/undici/undici:7535:20)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[1]: at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: TypeError: request.headers.split is not a function
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at Channel.publish (node:diagnostics_channel:150:9)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at new Request (node:internal/deps/undici/undici:2008:27)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at Intercept (node:internal/deps/undici/undici:7535:20)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[2]: at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[3]: TypeError: request.headers.split is not a function
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.296	error	Caught by controller[3]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at Channel.publish (node:diagnostics_channel:150:9)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at new Request (node:internal/deps/undici/undici:2008:27)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at Intercept (node:internal/deps/undici/undici:7535:20)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[3]: at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: TypeError: request.headers.split is not a function
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at Channel.publish (node:diagnostics_channel:150:9)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at new Request (node:internal/deps/undici/undici:2008:27)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at Intercept (node:internal/deps/undici/undici:7535:20)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[4]: at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[5]: TypeError: request.headers.split is not a function
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[5]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[5]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[5]: at Channel.publish (node:diagnostics_channel:150:9)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.297	error	Caught by controller[5]: at new Request (node:internal/deps/undici/undici:2008:27)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[5]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[5]: at Intercept (node:internal/deps/undici/undici:7535:20)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[5]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[5]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[5]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[5]: at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: TypeError: request.headers.split is not a function
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at Channel.publish (node:diagnostics_channel:150:9)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at new Request (node:internal/deps/undici/undici:2008:27)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at Intercept (node:internal/deps/undici/undici:7535:20)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	Caught by controller[6]: at Pool.dispatch (node:internal/deps/undici/undici:588:44)
                                        host.ioBrokerpi5
                                           2025-04-23 17:29:14.298	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #427
                                          @homoran ich bin seit Mittag jetzt auf der v20.19.1 und habe keine Probleme ich weiß nicht wie oft ich heute Firmware Update gemacht habe um zu testen, habe 2 ZigBee Instanzen und auch viele Lidl Steckdosen aber bei mir stürzt es nicht ab.
                                          Herzliche Grüße
                                          Fabio
                                          Iobroker:
