  4. Fehler beim Start Javascript nach Neuinstallation
    1.0k
    6.1k
51 Beiträge 5 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • M matrose65
    Jetzt habe ich die ganze Sache neu aufgesetzt.
    Also eine VM und den IOB.
    Beim Start habe ich nur den Haken beim installieren vom Javascript Adapter gesetzt.
    Und schon habe ich wieder 2 Fehler
    2025-02-04 08:31:17.335 - info: host.iobroker iobroker.js-controller version 7.0.6 js-controller starting
    2025-02-04 08:31:17.337 - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-02-04 08:31:17.338 - info: host.iobroker hostname: iobroker, node: v20.18.2
    2025-02-04 08:31:17.338 - info: host.iobroker ip addresses: 192.168.1.13 fe80::be24:11ff:fe8e:f452
    2025-02-04 08:31:17.590 - info: host.iobroker connected to Objects and States
    2025-02-04 08:31:17.607 - info: host.iobroker Node.js version has changed from unknown to 20.18.2
    2025-02-04 08:31:17.617 - info: host.iobroker added notifications configuration of host
    2025-02-04 08:31:17.619 - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2025-02-04 08:31:17.728 - info: host.iobroker 3 instances found
    2025-02-04 08:31:17.731 - info: host.iobroker starting 3 instances
    2025-02-04 08:31:17.803 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11091
    2025-02-04 08:31:18.654 - info: admin.0 (11091) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
    2025-02-04 08:31:18.670 - info: admin.0 (11091) requesting all objects
    2025-02-04 08:31:18.748 - info: admin.0 (11091) received all objects
    2025-02-04 08:31:18.756 - info: admin.0 (11091) Request actual repository...
    2025-02-04 08:31:18.768 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2025-02-04 08:31:18.770 - info: admin.0 (11091) socket.io server listening on port 8081
    2025-02-04 08:31:18.772 - info: admin.0 (11091) http server listening on port 8081
    2025-02-04 08:31:18.772 - info: admin.0 (11091) Use link "http://127.0.0.1:8081" to configure.
    2025-02-04 08:31:18.936 - warn: admin.0 (11091) Repository cannot be read: Active repo - stable
    2025-02-04 08:31:18.950 - warn: admin.0 (11091) Active repository "stable" cannot be read
    2025-02-04 08:31:20.314 - info: admin.0 (11091) Repository received successfully.
    2025-02-04 08:31:21.851 - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.31" started with pid 11136
    2025-02-04 08:31:22.555 - info: backitup.0 (11136) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.2, js-controller: 7.0.6
    2025-02-04 08:31:22.579 - info: backitup.0 (11136) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-02-04 08:31:25.870 - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started with pid 11157
    2025-02-04 08:31:26.515 - info: discovery.0 (11157) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
    2025-02-04 08:37:22.917 - info: admin.0 (11091) ==> Connected system.user.admin from ::ffff:192.168.1.121
    2025-02-04 08:39:00.544 - info: host.iobroker iobroker add javascript
    2025-02-04 08:39:01.440 - info: host.iobroker iobroker NPM version: 10.8.2
    2025-02-04 08:39:01.441 - info: host.iobroker iobroker Installing iobroker.javascript@8.8.3... (System call)
    2025-02-04 08:39:20.335 - error: host.iobroker iobroker npm error code ERR_SSL_CIPHER_OPERATION_FAILEDnpm error 800C2FCEF07F0000:error:1C800066:Provider routines:ossl_gcm_stream_update:cipher operation failed:../deps/openssl/openssl/providers/implementations/ciphers/ciphercommon_gcm.c:325:npm errornpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-02-04T07_39_01_538Z-debug-0.log
    2025-02-04 08:39:20.336 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.javascript@8.8.3: 1
    2025-02-04 08:39:21.346 - info: host.iobroker iobroker exit 25
    2025-02-04 08:39:54.620 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2025-02-04 08:39:54.622 - info: admin.0 (11091) Got terminate signal TERMINATE_YOURSELF
    2025-02-04 08:39:54.624 - info: admin.0 (11091) terminating http server on port 8081
    2025-02-04 08:39:54.626 - info: admin.0 (11091) terminating
    2025-02-04 08:39:54.626 - info: admin.0 (11091) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-02-04 08:39:54.663 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2025-02-04 08:39:55.127 - info: admin.0 (11091) terminating
    2025-02-04 08:39:55.145 - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-02-04 08:39:58.295 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11314
    2025-02-04 08:39:59.125 - info: admin.0 (11314) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
    2025-02-04 08:39:59.143 - info: admin.0 (11314) requesting all objects
    2025-02-04 08:39:59.393 - info: admin.0 (11314) received all objects
    2025-02-04 08:39:59.527 - info: admin.0 (11314) socket.io server listening on port 8081
    2025-02-04 08:39:59.528 - info: admin.0 (11314) http server listening on port 8081
    CodierknechtC Offline
    Codierknecht
    @matrose65 sagte in Fehler beim Start Javascript nach Neuinstallation:
    Wie installiert?
    Hast Du SSL und/oder Authentication konfiguriert?
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • M matrose65
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @matrose65
      Zeile 32 sieht nach einem ssl Fehler aus. Daher wird nicht oder nicht vollständig installiert.
      Meine Adapter und Widgets
      Links im Profil
      • CodierknechtC Codierknecht
        Wie installiert?
        matrose65
        @codierknecht
        Ja habe zugriff über SSL
        OliverIOO CodierknechtC 2 Antworten Letzte Antwort
        • M matrose65
            matrose65
            Hallo
            Würde ich gern raussuchen, aber jetzt ist iob abgestürzt und startet auch gerade nicht neu
            • M matrose65
              @codierknecht
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @matrose65
              Gemäß stackoverflow mach mal folgendes
              npm cache clear --force
              Wenn das nicht funktioniert, dann mal probieren die ganzen SSL Basis Zertifikate in deinem Image aktualisieren
              https://manpages.debian.org/buster/ca-certificates/update-ca-certificates.8.en.html
              Ich weiß ja nicht wie alt das Image ist beziehungsweise wann da das letzte Mal ein Update drüber gemacht worden ist
              Und natürlich auch in das Detaillog einmal reinschauen, eventuell gibt es da noch Hinweise
              Links im Profil
              • OliverIOO OliverIO
                @matrose65
                matrose65
                @oliverio
                Ich habe jetzt das obere ausgeführt.
                Jetzt habe ich den Javascript Adapter ohne Probleme installiert und auch gestartet.
                Soll ich nochwas versuchen, bevor ich die Sicherung zurückspiele?
                • M matrose65
                  @codierknecht
                  Codierknecht
                  Nur so als Anmerkung:
                  SSL im lokalen Netz ist eigentlich unnötig, solange das alles tatsächlich lokal bleibt. Eine Fehlerquelle weniger.
                  Auch Authentifizierung am ioBroker in der Web-GUI kann man sich schenken, wenn nicht gerade irgendwelche Pupertisten im Haus sind die dem Vater gerne mal einen Streich spielen.
                    matrose65
                    @codierknecht
                    Ok Danke Ja es soll alles lokal bleiben.
                    Und das mit den Pupertisten hat sich schon eine Weile erledigt
                    • M matrose65
                      @codierknecht
                      Codierknecht
                      Dann kannst Du eigentlich auf SSL und Authentifizierung verzichten.
                      Eine potenzielle Fehlerquelle weniger.
                      Hab' ich mir gedacht. Wir dürften den gleichen Jahrgang haben ;-)
                        matrose65
                        @codierknecht
                        Authentifizierung habe ich abgestellt bei SSL weis ich ehrlich nicht so richtig wie?
                        Ansonsten läuft das backup gerade zurück. Mal sehen was wird
                        Das mit dem Alter könnte laut deinem Bild passen ( 1965)
                        • M matrose65
                          @codierknecht
                          Codierknecht
                            matrose65
                            Ok das habe ich übersehen. Passt jetzt.
                            Das Backup ist zurück gespielt und es läuft alles soweit. Auch javascript.
                            Aber es ist immer nochwas nicht in Ordnung.
                            Zweimal ist der IOB neugestartet, mit den Fehlermeldungen Code 7
                            Bsp: instance system.adapter.wled.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            Danach sind alle Adapter wieder grün und es funktioniert alles.
                            Das hatte ich voher auch schon immer mal, aber selten.
                            Daher auch meine Idee das mit der SSD etwas nicht in Ordnung ist
                            • M matrose65
                              @oliverio
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @matrose65
                              Nein das war’s.
                              Entweder haben sich im Cache noch Pakete mit abweichender Signatur versteckt
                              Oder deine ssl Root Zertifikate waren veraltet, so das hier nicht überprüft werden konnte.
                              Ich gehe mal davon aus, das Iobroker per ssl hier keine Rolle gespielt hat.
                              Ich kenne mich jetzt mit proxmox nicht so aus, aber mal die Image Vorlagen von proxmox aktualisieren,
                              Links im Profil
                              • M matrose65
                                das hat nichts mit der SSD zu tun, da lief noch ein alter Prozess, der aus irgendeinem Grund nicht korrekt beendet wurde bevor er wieder gestartet wurde.
                                  matrose65
                                  Ok Danke. Kann ich dagegen was tun? Ich meine am Ende läuft ja alles wieder, das ist sicher nicht normal
                                  • M matrose65
                                    Wenn du es verursacht hast, indem du mit einem Neustart o.ä. nicht gewartet hast bis alle Prozesse vollständig beendet waren, ja: warten.
                                    Ansonsten regelt das der Controller und wirft diese Meldung aus.
                                      matrose65
                                      Nein ich habe nichts neugestartet. Ich wollte eigentlich nur die LOGs runterladen.
                                      Da wurde die Anzeige grau und dann starten alle Adapter neu
                                      • M matrose65
                                        dann ist das die Ursache.
                                        das sollte nicht sein.
                                        Wie ausgelastet ist dein Server?
                                        gsnz frisches, aktuelles iob diag in der Langfassung könnte etwas wissen
                                          @matrose65
                                          Nein das war’s.
                                          Codierknecht
                                          @oliverio sagte in Fehler beim Start Javascript nach Neuinstallation:
                                          Ich auch. Wollte es nur angemerkt haben.
                                          KISS ... Keep it simple, stupid. Alle unnötigen Fehlerquellen ausschließen.
