  4. Fehler beim Start Javascript nach Neuinstallation
    1.0k
    6.1k
51 Beiträge 5 Kommentatoren 6.6k Aufrufe 4 Beobachtet
    matrose65
    @oliverio
    Guten Morgen
    Ich habe gestern Abend alle Scripte gestoppt und trotzdem kamen die Fehler.
    • M matrose65
      @oliverio
      Guten Morgen
      matrose65
      Jetzt habe ich die ganze Sache neu aufgesetzt.
      Also eine VM und den IOB.
      Beim Start habe ich nur den Haken beim installieren vom Javascript Adapter gesetzt.
      Und schon habe ich wieder 2 Fehler
      2025-02-04 08:31:17.335 - info: host.iobroker iobroker.js-controller version 7.0.6 js-controller starting
      2025-02-04 08:31:17.337 - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2025-02-04 08:31:17.338 - info: host.iobroker hostname: iobroker, node: v20.18.2
      2025-02-04 08:31:17.338 - info: host.iobroker ip addresses: 192.168.1.13 fe80::be24:11ff:fe8e:f452
      2025-02-04 08:31:17.590 - info: host.iobroker connected to Objects and States
      2025-02-04 08:31:17.607 - info: host.iobroker Node.js version has changed from unknown to 20.18.2
      2025-02-04 08:31:17.617 - info: host.iobroker added notifications configuration of host
      2025-02-04 08:31:17.619 - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2025-02-04 08:31:17.728 - info: host.iobroker 3 instances found
      2025-02-04 08:31:17.731 - info: host.iobroker starting 3 instances
      2025-02-04 08:31:17.803 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11091
      2025-02-04 08:31:18.654 - info: admin.0 (11091) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
      2025-02-04 08:31:18.670 - info: admin.0 (11091) requesting all objects
      2025-02-04 08:31:18.748 - info: admin.0 (11091) received all objects
      2025-02-04 08:31:18.756 - info: admin.0 (11091) Request actual repository...
      2025-02-04 08:31:18.768 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2025-02-04 08:31:18.770 - info: admin.0 (11091) socket.io server listening on port 8081
      2025-02-04 08:31:18.772 - info: admin.0 (11091) http server listening on port 8081
      2025-02-04 08:31:18.772 - info: admin.0 (11091) Use link "http://127.0.0.1:8081" to configure.
      2025-02-04 08:31:18.936 - warn: admin.0 (11091) Repository cannot be read: Active repo - stable
      2025-02-04 08:31:18.950 - warn: admin.0 (11091) Active repository "stable" cannot be read
      2025-02-04 08:31:20.314 - info: admin.0 (11091) Repository received successfully.
      2025-02-04 08:31:21.851 - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.31" started with pid 11136
      2025-02-04 08:31:22.555 - info: backitup.0 (11136) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.2, js-controller: 7.0.6
      2025-02-04 08:31:22.579 - info: backitup.0 (11136) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2025-02-04 08:31:25.870 - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started with pid 11157
      2025-02-04 08:31:26.515 - info: discovery.0 (11157) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
      2025-02-04 08:37:22.917 - info: admin.0 (11091) ==> Connected system.user.admin from ::ffff:192.168.1.121
      2025-02-04 08:39:00.544 - info: host.iobroker iobroker add javascript
      2025-02-04 08:39:01.440 - info: host.iobroker iobroker NPM version: 10.8.2
      2025-02-04 08:39:01.441 - info: host.iobroker iobroker Installing iobroker.javascript@8.8.3... (System call)
      2025-02-04 08:39:20.335 - error: host.iobroker iobroker npm error code ERR_SSL_CIPHER_OPERATION_FAILEDnpm error 800C2FCEF07F0000:error:1C800066:Provider routines:ossl_gcm_stream_update:cipher operation failed:../deps/openssl/openssl/providers/implementations/ciphers/ciphercommon_gcm.c:325:npm errornpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-02-04T07_39_01_538Z-debug-0.log
      2025-02-04 08:39:20.336 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.javascript@8.8.3: 1
      2025-02-04 08:39:21.346 - info: host.iobroker iobroker exit 25
      2025-02-04 08:39:54.620 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2025-02-04 08:39:54.622 - info: admin.0 (11091) Got terminate signal TERMINATE_YOURSELF
      2025-02-04 08:39:54.624 - info: admin.0 (11091) terminating http server on port 8081
      2025-02-04 08:39:54.626 - info: admin.0 (11091) terminating
      2025-02-04 08:39:54.626 - info: admin.0 (11091) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-02-04 08:39:54.663 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
      2025-02-04 08:39:55.127 - info: admin.0 (11091) terminating
      2025-02-04 08:39:55.145 - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-02-04 08:39:58.295 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11314
      2025-02-04 08:39:59.125 - info: admin.0 (11314) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
      2025-02-04 08:39:59.143 - info: admin.0 (11314) requesting all objects
      2025-02-04 08:39:59.393 - info: admin.0 (11314) received all objects
      2025-02-04 08:39:59.527 - info: admin.0 (11314) socket.io server listening on port 8081
      2025-02-04 08:39:59.528 - info: admin.0 (11314) http server listening on port 8081
      CodierknechtC OliverIOO HomoranH 3 Antworten Letzte Antwort
      • M matrose65
        CodierknechtC Online
        Codierknecht
        @matrose65 sagte in Fehler beim Start Javascript nach Neuinstallation:
        Wie installiert?
        Hast Du SSL und/oder Authentication konfiguriert?
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • M matrose65
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @matrose65
          Zeile 32 sieht nach einem ssl Fehler aus. Daher wird nicht oder nicht vollständig installiert.
          Meine Adapter und Widgets
          Links im Profil
          • CodierknechtC Codierknecht
            Wie installiert?
            matrose65
            @codierknecht
            Ja habe zugriff über SSL
            OliverIOO CodierknechtC 2 Antworten Letzte Antwort
            • M matrose65
                matrose65
                Hallo
                Würde ich gern raussuchen, aber jetzt ist iob abgestürzt und startet auch gerade nicht neu
                • M matrose65
                  @codierknecht
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @matrose65
                  Gemäß stackoverflow mach mal folgendes
                  npm cache clear --force
                  Wenn das nicht funktioniert, dann mal probieren die ganzen SSL Basis Zertifikate in deinem Image aktualisieren
                  https://manpages.debian.org/buster/ca-certificates/update-ca-certificates.8.en.html
                  Ich weiß ja nicht wie alt das Image ist beziehungsweise wann da das letzte Mal ein Update drüber gemacht worden ist
                  Und natürlich auch in das Detaillog einmal reinschauen, eventuell gibt es da noch Hinweise
                  Links im Profil
                  • OliverIOO OliverIO
                    @matrose65
                    matrose65
                    @oliverio
                    Ich habe jetzt das obere ausgeführt.
                    Jetzt habe ich den Javascript Adapter ohne Probleme installiert und auch gestartet.
                    Soll ich nochwas versuchen, bevor ich die Sicherung zurückspiele?
                    • M matrose65
                      @codierknecht
                      Codierknecht
                      Nur so als Anmerkung:
                      SSL im lokalen Netz ist eigentlich unnötig, solange das alles tatsächlich lokal bleibt. Eine Fehlerquelle weniger.
                      Auch Authentifizierung am ioBroker in der Web-GUI kann man sich schenken, wenn nicht gerade irgendwelche Pupertisten im Haus sind die dem Vater gerne mal einen Streich spielen.
                        matrose65
                        @codierknecht
                        Ok Danke Ja es soll alles lokal bleiben.
                        Und das mit den Pupertisten hat sich schon eine Weile erledigt
                        • M matrose65
                          @codierknecht
                          Codierknecht
                          Dann kannst Du eigentlich auf SSL und Authentifizierung verzichten.
                          Eine potenzielle Fehlerquelle weniger.
                          Hab' ich mir gedacht. Wir dürften den gleichen Jahrgang haben ;-)
                            matrose65
                            @codierknecht
                            Authentifizierung habe ich abgestellt bei SSL weis ich ehrlich nicht so richtig wie?
                            Ansonsten läuft das backup gerade zurück. Mal sehen was wird
                            Das mit dem Alter könnte laut deinem Bild passen ( 1965)
                            • M matrose65
                              @codierknecht
                              Codierknecht
                                matrose65
                                Ok das habe ich übersehen. Passt jetzt.
                                Das Backup ist zurück gespielt und es läuft alles soweit. Auch javascript.
                                Aber es ist immer nochwas nicht in Ordnung.
                                Zweimal ist der IOB neugestartet, mit den Fehlermeldungen Code 7
                                Bsp: instance system.adapter.wled.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                Danach sind alle Adapter wieder grün und es funktioniert alles.
                                Das hatte ich voher auch schon immer mal, aber selten.
                                Daher auch meine Idee das mit der SSD etwas nicht in Ordnung ist
                                • M matrose65
                                  @oliverio
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @matrose65
                                  Nein das war’s.
                                  Entweder haben sich im Cache noch Pakete mit abweichender Signatur versteckt
                                  Oder deine ssl Root Zertifikate waren veraltet, so das hier nicht überprüft werden konnte.
                                  Ich gehe mal davon aus, das Iobroker per ssl hier keine Rolle gespielt hat.
                                  Ich kenne mich jetzt mit proxmox nicht so aus, aber mal die Image Vorlagen von proxmox aktualisieren,
                                  Links im Profil
                                  • M matrose65
                                    das hat nichts mit der SSD zu tun, da lief noch ein alter Prozess, der aus irgendeinem Grund nicht korrekt beendet wurde bevor er wieder gestartet wurde.
                                      matrose65
                                      Ok Danke. Kann ich dagegen was tun? Ich meine am Ende läuft ja alles wieder, das ist sicher nicht normal
                                      • M matrose65
                                        Wenn du es verursacht hast, indem du mit einem Neustart o.ä. nicht gewartet hast bis alle Prozesse vollständig beendet waren, ja: warten.
                                        Ansonsten regelt das der Controller und wirft diese Meldung aus.
                                          matrose65
                                          Nein ich habe nichts neugestartet. Ich wollte eigentlich nur die LOGs runterladen.
                                          Da wurde die Anzeige grau und dann starten alle Adapter neu
