  4. Fehler beim Start Javascript nach Neuinstallation
    1.0k
    6.1k
51 Beiträge 5 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • M matrose65
    Jetzt habe ich die ganze Sache neu aufgesetzt.
    Also eine VM und den IOB.
    Beim Start habe ich nur den Haken beim installieren vom Javascript Adapter gesetzt.
    Und schon habe ich wieder 2 Fehler
    2025-02-04 08:31:17.335 - info: host.iobroker iobroker.js-controller version 7.0.6 js-controller starting
    2025-02-04 08:31:17.337 - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-02-04 08:31:17.338 - info: host.iobroker hostname: iobroker, node: v20.18.2
    2025-02-04 08:31:17.338 - info: host.iobroker ip addresses: 192.168.1.13 fe80::be24:11ff:fe8e:f452
    2025-02-04 08:31:17.590 - info: host.iobroker connected to Objects and States
    2025-02-04 08:31:17.607 - info: host.iobroker Node.js version has changed from unknown to 20.18.2
    2025-02-04 08:31:17.617 - info: host.iobroker added notifications configuration of host
    2025-02-04 08:31:17.619 - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2025-02-04 08:31:17.728 - info: host.iobroker 3 instances found
    2025-02-04 08:31:17.731 - info: host.iobroker starting 3 instances
    2025-02-04 08:31:17.803 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11091
    2025-02-04 08:31:18.654 - info: admin.0 (11091) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
    2025-02-04 08:31:18.670 - info: admin.0 (11091) requesting all objects
    2025-02-04 08:31:18.748 - info: admin.0 (11091) received all objects
    2025-02-04 08:31:18.756 - info: admin.0 (11091) Request actual repository...
    2025-02-04 08:31:18.768 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2025-02-04 08:31:18.770 - info: admin.0 (11091) socket.io server listening on port 8081
    2025-02-04 08:31:18.772 - info: admin.0 (11091) http server listening on port 8081
    2025-02-04 08:31:18.772 - info: admin.0 (11091) Use link "http://127.0.0.1:8081" to configure.
    2025-02-04 08:31:18.936 - warn: admin.0 (11091) Repository cannot be read: Active repo - stable
    2025-02-04 08:31:18.950 - warn: admin.0 (11091) Active repository "stable" cannot be read
    2025-02-04 08:31:20.314 - info: admin.0 (11091) Repository received successfully.
    2025-02-04 08:31:21.851 - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.31" started with pid 11136
    2025-02-04 08:31:22.555 - info: backitup.0 (11136) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.2, js-controller: 7.0.6
    2025-02-04 08:31:22.579 - info: backitup.0 (11136) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-02-04 08:31:25.870 - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started with pid 11157
    2025-02-04 08:31:26.515 - info: discovery.0 (11157) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
    2025-02-04 08:37:22.917 - info: admin.0 (11091) ==> Connected system.user.admin from ::ffff:192.168.1.121
    2025-02-04 08:39:00.544 - info: host.iobroker iobroker add javascript
    2025-02-04 08:39:01.440 - info: host.iobroker iobroker NPM version: 10.8.2
    2025-02-04 08:39:01.441 - info: host.iobroker iobroker Installing iobroker.javascript@8.8.3... (System call)
    2025-02-04 08:39:20.335 - error: host.iobroker iobroker npm error code ERR_SSL_CIPHER_OPERATION_FAILEDnpm error 800C2FCEF07F0000:error:1C800066:Provider routines:ossl_gcm_stream_update:cipher operation failed:../deps/openssl/openssl/providers/implementations/ciphers/ciphercommon_gcm.c:325:npm errornpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-02-04T07_39_01_538Z-debug-0.log
    2025-02-04 08:39:20.336 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.javascript@8.8.3: 1
    2025-02-04 08:39:21.346 - info: host.iobroker iobroker exit 25
    2025-02-04 08:39:54.620 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2025-02-04 08:39:54.622 - info: admin.0 (11091) Got terminate signal TERMINATE_YOURSELF
    2025-02-04 08:39:54.624 - info: admin.0 (11091) terminating http server on port 8081
    2025-02-04 08:39:54.626 - info: admin.0 (11091) terminating
    2025-02-04 08:39:54.626 - info: admin.0 (11091) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-02-04 08:39:54.663 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
    2025-02-04 08:39:55.127 - info: admin.0 (11091) terminating
    2025-02-04 08:39:55.145 - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-02-04 08:39:58.295 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11314
    2025-02-04 08:39:59.125 - info: admin.0 (11314) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
    2025-02-04 08:39:59.143 - info: admin.0 (11314) requesting all objects
    2025-02-04 08:39:59.393 - info: admin.0 (11314) received all objects
    2025-02-04 08:39:59.527 - info: admin.0 (11314) socket.io server listening on port 8081
    2025-02-04 08:39:59.528 - info: admin.0 (11314) http server listening on port 8081
    @matrose65 sagte in Fehler beim Start Javascript nach Neuinstallation:
      matrose65
      Hallo
      Würde ich gern raussuchen, aber jetzt ist iob abgestürzt und startet auch gerade nicht neu
      • M matrose65
        @codierknecht
        Ja habe zugriff über SSL
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @matrose65
        Gemäß stackoverflow mach mal folgendes
        npm cache clear --force
        Wenn das nicht funktioniert, dann mal probieren die ganzen SSL Basis Zertifikate in deinem Image aktualisieren
        https://manpages.debian.org/buster/ca-certificates/update-ca-certificates.8.en.html
        Ich weiß ja nicht wie alt das Image ist beziehungsweise wann da das letzte Mal ein Update drüber gemacht worden ist
        Und natürlich auch in das Detaillog einmal reinschauen, eventuell gibt es da noch Hinweise
        Meine Adapter und Widgets
        Links im Profil
        • OliverIOO OliverIO
          @matrose65
          matrose65
          @oliverio
          Ich habe jetzt das obere ausgeführt.
          Jetzt habe ich den Javascript Adapter ohne Probleme installiert und auch gestartet.
          Soll ich nochwas versuchen, bevor ich die Sicherung zurückspiele?
          • M matrose65
            @codierknecht
            CodierknechtC Online
            Codierknecht
            Nur so als Anmerkung:
            SSL im lokalen Netz ist eigentlich unnötig, solange das alles tatsächlich lokal bleibt. Eine Fehlerquelle weniger.
            Auch Authentifizierung am ioBroker in der Web-GUI kann man sich schenken, wenn nicht gerade irgendwelche Pupertisten im Haus sind die dem Vater gerne mal einen Streich spielen.
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            • CodierknechtC Codierknecht
              matrose65
              @codierknecht
              Ok Danke Ja es soll alles lokal bleiben.
              Und das mit den Pupertisten hat sich schon eine Weile erledigt
              • M matrose65
                @codierknecht
                Codierknecht
                Dann kannst Du eigentlich auf SSL und Authentifizierung verzichten.
                Eine potenzielle Fehlerquelle weniger.
                Hab' ich mir gedacht. Wir dürften den gleichen Jahrgang haben ;-)
                  matrose65
                  @codierknecht
                  Authentifizierung habe ich abgestellt bei SSL weis ich ehrlich nicht so richtig wie?
                  Ansonsten läuft das backup gerade zurück. Mal sehen was wird
                  Das mit dem Alter könnte laut deinem Bild passen ( 1965)
                  • M matrose65
                    @codierknecht
                    Codierknecht
                      matrose65
                      Ok das habe ich übersehen. Passt jetzt.
                      Das Backup ist zurück gespielt und es läuft alles soweit. Auch javascript.
                      Aber es ist immer nochwas nicht in Ordnung.
                      Zweimal ist der IOB neugestartet, mit den Fehlermeldungen Code 7
                      Bsp: instance system.adapter.wled.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      Danach sind alle Adapter wieder grün und es funktioniert alles.
                      Das hatte ich voher auch schon immer mal, aber selten.
                      Daher auch meine Idee das mit der SSD etwas nicht in Ordnung ist
                      • M matrose65
                        @oliverio
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @matrose65
                        Nein das war’s.
                        Entweder haben sich im Cache noch Pakete mit abweichender Signatur versteckt
                        Oder deine ssl Root Zertifikate waren veraltet, so das hier nicht überprüft werden konnte.
                        Ich gehe mal davon aus, das Iobroker per ssl hier keine Rolle gespielt hat.
                        Ich kenne mich jetzt mit proxmox nicht so aus, aber mal die Image Vorlagen von proxmox aktualisieren,
                        Links im Profil
                        • M matrose65
                          das hat nichts mit der SSD zu tun, da lief noch ein alter Prozess, der aus irgendeinem Grund nicht korrekt beendet wurde bevor er wieder gestartet wurde.
                            matrose65
                            Ok Danke. Kann ich dagegen was tun? Ich meine am Ende läuft ja alles wieder, das ist sicher nicht normal
                            • M matrose65
                              Wenn du es verursacht hast, indem du mit einem Neustart o.ä. nicht gewartet hast bis alle Prozesse vollständig beendet waren, ja: warten.
                              Ansonsten regelt das der Controller und wirft diese Meldung aus.
                                matrose65
                                Nein ich habe nichts neugestartet. Ich wollte eigentlich nur die LOGs runterladen.
                                Da wurde die Anzeige grau und dann starten alle Adapter neu
                                • M matrose65
                                  dann ist das die Ursache.
                                  das sollte nicht sein.
                                  Wie ausgelastet ist dein Server?
                                  gsnz frisches, aktuelles iob diag in der Langfassung könnte etwas wissen
                                    @matrose65
                                    Nein das war’s.
                                    Codierknecht
                                    @oliverio sagte in Fehler beim Start Javascript nach Neuinstallation:
                                    Ich auch. Wollte es nur angemerkt haben.
                                    KISS ... Keep it simple, stupid. Alle unnötigen Fehlerquellen ausschließen.
                                      matrose65
                                      schrieb am zuletzt editiert von matrose65
                                      Hier die iodiag ausgabe
                                      Copy text starting here:
                                      ```bash
                                                              v.2025-02-02
                                      *** LIFE CYCLE STATUS ***
                                      Operating System is the current Debian stable version codenamed 'bookworm'!
                                      *** TIME AND TIMEZONES ***
                                                     Local time: Tue 2025-02-04 10:38:49 CET
                                                 Universal time: Tue 2025-02-04 09:38:49 UTC
                                                       RTC time: Tue 2025-02-04 09:38:49
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      uwe
                                      HOME=/home/uwe
                                      GROUPS=uwe cdrom floppy sudo audio dip video plugdev users netdev iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video plugdev
                                      *** DISPLAY-SERVER SETUP ***
                                      Display-Server: false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:             12G        2.1G        6.8G        573K        4.0G         10G
                                      Swap:           1.0G          0B        1.0G
                                      Total:           13G        2.1G        7.8G
                                      Active iob-Instances:   21
                                              11960 M total memory
                                               1977 M used memory
                                                550 M active memory
                                               4552 M inactive memory
                                               6449 M free memory
                                                 92 M buffer memory
                                               3756 M swap cache
                                                974 M total swap
                                                  0 M used swap
                                                974 M free swap
                                      top - 10:38:49 up  1:35,  3 users,  load average: 0.16, 0.08, 0.08
                                      Tasks: 125 total,   1 running, 123 sleeping,   1 stopped,   0 zombie
                                      %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :  11960.7 total,   6449.2 free,   1977.0 used,   3849.1 buff/cache
                                      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   9983.7 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  5.9G     0  5.9G   0% /dev
                                      tmpfs          tmpfs     1.2G  560K  1.2G   1% /run
                                      /dev/sda1      ext4       27G  6.2G   19G  25% /
                                      tmpfs          tmpfs     5.9G     0  5.9G   0% /dev/shm
                                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                      tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
                                      [Tue Feb  4 09:03:14 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Tue Feb  4 09:03:15 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET SOURCE    FSTYPE OPTIONS
                                      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                                      /var:
                                      461M    /var/
                                      248M    /var/cache
                                      241M    /var/cache/apt
                                      174M    /var/lib
                                      165M    /var/cache/apt/archives
                                      Archived and active journals take up 8.0M in the file system.
                                      /opt/iobroker/backups:
                                      12M     /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      1.2G    /opt/iobroker/iobroker-data/files
                                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      558M    /opt/iobroker/iobroke Static hostname: iobroker
                                             Icon name: computer-vm
                                               Chassis: vm 🖴
                                        Virtualization: kvm
                                                Kernel: Linux 6.1.0-30-amd64
                                          Architecture: x86-64
                                       Hardware Vendor: QEMU
                                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                                      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                                      Installation:           kvm
                                      Kernel:                 x86_64
                                      Userland:               64 bit
                                      Timezone:               Europe/Berlin (CET, +0100)
                                      User-ID:                1000
                                      Boot Target:            multi-user.target
                                      Pending OS-Updates:     0
                                      Pending iob updates:    0
                                      Nodejs-Installation:
                                      /usr/bin/nodejs         v20.18.2
                                      /usr/bin/node           v20.18.2
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      /usr/bin/corepack       0.29.4
                                      Recommended versions are nodejs 20.18.2 and npm 10.8.2
                                      nodeJS installation is correct
                                      MEMORY:
                                      Mem:             12G        2.1G        6.6G        573K        4.2G         10G
                                      Swap:           1.0G          0B        1.0G
                                      Total:           13G        2.1G        7.6G
                                      Upgrade policy: none
                                      ioBroker Core:          js-controller           7.0.6
                                                              admin                   7.4.10
                                      Objects type: jsonl
                                      States  type: jsonl
                                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.1.13, run as: admin
                                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                      Objects:                8060
                                      States:                 6994
                                      Size of iob-Database:
                                      38M     /opt/iobroker/iobroker-data/objects.jsonl
                                      17M     /opt/iobroker/iobroker-data/states.jsonl
                                      • M matrose65
                                        ```bash
        v.2025-02-02
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        uwe
                                        HOME=/home/uwe
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:           1.0G          0B        1.0G
                                                 1977 M used memory
                                                  550 M active memory
                                                 6449 M free memory
                                                   92 M buffer memory
                                                 3756 M swap cache
                                                  974 M total swap
                                                    0 M used swap
                                                  974 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        461M    /var/
                                        248M    /var/cache
                                        241M    /var/cache/apt
                                        174M    /var/lib
                                                 Chassis: vm 🖴
                                          Virtualization: kvm
                                        Installation:           kvm
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        MEMORY:
                                        Swap:           1.0G          0B        1.0G
        admin                   7.4.10
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                8060
                                        States:                 6994
                                        matrose65
                                        @matrose65
                                        Jetzt noch mal in Lang
                                        ```bash
                                        Script v.2025-02-02
                                        *** BASE SYSTEM ***
                                                 Chassis: vm 🖴
                                          Virtualization: kvm
                                        OS is similar to:
                                        model name      : QEMU Virtual CPU version 2.5+
                                        Docker          : false
                                        Virtualization  : kvm
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         10:47:34 up  1:44,  3 users,  load average: 0.00, 0.04, 0.07
                                        CPU threads: 4
                                                       Local time: Tue 2025-02-04 10:47:34 CET
                                                   Universal time: Tue 2025-02-04 09:47:34 UTC
                                                         RTC time: Tue 2025-02-04 09:47:34
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        uwe
                                        HOME=/home/uwe
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:           1.0G          0B        1.0G
                                                 1980 M used memory
                                                  655 M active memory
                                                 4608 M inactive memory
                                                 6299 M free memory
                                                   96 M buffer memory
                                                 3899 M swap cache
                                                  974 M total swap
                                                    0 M used swap
                                                  974 M free swap
                                        top - 10:47:34 up  1:44,  3 users,  load average: 0.00, 0.04, 0.07
                                        Tasks: 126 total,   3 running, 122 sleeping,   1 stopped,   0 zombie
                                        %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :  11960.7 total,   6299.3 free,   1980.0 used,   3995.9 buff/cache
                                        MiB Swap:    975.0 total,    975.0 free,      0.0 used.   9980.7 avail Mem
                                        *** FILESYSTEM ***
                                        /var:
                                        461M    /var/
                                        248M    /var/cache
                                        241M    /var/cache/apt
                                        174M    /var/lib
                                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                        24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Installed: 20.18.2-1nodesource1
                                          Candidate: 20.18.2-1nodesource1
                                          Version table:
                                         *** 20.18.2-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                             20.18.1-1nodesource1 1001
                                             20.18.0-1nodesource1 1001
                                             20.17.0-1nodesource1 1001
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             18.19.0+dfsg-6~deb12u2 500
                                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 2882)
                                        Core adapters versions
                                        admin:          7.4.10
                                        javascript:     8.8.3
                                        nodejs modules from github:     0
                                        Adapter State
                                        + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          system.adapter.bmw.0                    : bmw                   : iobroker                                 - disabled
                                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                          system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                        + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 8081
                                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                          system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                                          system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
                                          system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
                                          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
                                          system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                                        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                                        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.shelly.2                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                                          system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                                          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
                                          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
                                          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
                                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                                        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                                          system.adapter.worx.0                   : worx                  : iobroker                                 - disabled
                                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                                        Adapter    "admin"        : 7.4.10   , installed 7.4.10
                                        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                        Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
                                        Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                                        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                        Adapter    "ical"         : 1.16.1   , installed 1.16.1
                                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                        Controller "js-controller": 7.0.6    , installed 7.0.6
                                        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                        Adapter    "roborock"     : 0.6.18   , installed 0.6.18
                                        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                                        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                        Adapter    "vis-2"        : 2.9.64   , installed 2.11.2
                                        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                                        Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                                        Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                        Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                                        Adapter    "web"          : 6.2.5    , installed 6.3.0
                                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                        Adapter    "worx"         : 3.1.1    , installed 3.1.1
                                        Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
                                        Objects and States
                                        Objects:        8060
                                        States:         6994
                                        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 192.168.1.13:8082       0.0.0.0:*               LISTEN      1001       30623      4289/io.hm-rpc.0
                                        tcp        0      0 192.168.1.13:8081       0.0.0.0:*               LISTEN      1001       31125      3975/io.admin.0
                                        tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       31507      4369/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       31506      4369/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       33165      4397/io.shelly.1
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14684      1/init
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16068      527/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30326      3843/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31003      3843/iobroker.js-co
                                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       33825      4453/io.sonos.0
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       32698      4562/io.fullybrowse
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          12472      1/init
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          16070      527/sshd: /usr/sbin
                                        tcp6       0      0 :::8083                 :::*                    LISTEN      1001       33455      4592/io.web.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33472      4607/io.wled.0
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31545      4427/io.shelly.2
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15635      1/init
                                        udp6       0      0 :::111                  :::*                                0          14685      1/init
                                        2025-02-04 10:11:30.314  - info: netatmo-crawler.0 (4643) Getting data for stationid:70:ee:50:58:fd:44
                                        2025-02-04 10:11:31.157  - info: netatmo-crawler.0 (4643) Getting data for stationid:70:ee:50:2e:9d:b8
                                        2025-02-04 10:11:33.638  - info: netatmo-crawler.0 (4643) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                        2025-02-04 10:11:34.151  - info: host.iobroker instance system.adapter.netatmo-crawler.0 having pid 4643 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-02-04 10:14:55.013  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 4660
                                        2025-02-04 10:14:55.852  - info: dwd.0 (4660) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.6
                                        2025-02-04 10:14:56.245  - info: dwd.0 (4660) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2025-02-04 10:14:56.758  - info: host.iobroker instance system.adapter.dwd.0 having pid 4660 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-02-04 10:28:50.605  - info: web.0 (4592) <== Disconnect system.user.admin from ::ffff:192.168.1.144 vis-2
                                        2025-02-04 10:30:00.011  - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 4687
                                        2025-02-04 10:30:00.893  - info: ical.0 (4687) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.2, js-controller: 7.0.6
                                        2025-02-04 10:30:01.532  - info: ical.0 (4687) processing URL: Familie https://calendar.google.com/calendar/s
                                        2025-02-04 10:30:06.689  - info: ical.0 (4687) Terminated (NO_ERROR): Without reason
                                        2025-02-04 10:30:07.202  - info: host.iobroker instance system.adapter.ical.0 having pid 4687 terminated with code 0 (NO_ERROR)
                                        2025-02-04 10:34:22.254  - info: fullybrowser.0 (4562) 🗸 192.168.1.144: Command screenOn successfully set to true
                                        2025-02-04 10:34:25.135  - info: web.0 (4592) ==> Connected system.user.admin from ::ffff:192.168.1.144
                                        2025-02-04 10:34:26.576  - info: web.0 (4592) <== Disconnect system.user.admin from ::ffff:192.168.1.144 vis-2
                                        2025-02-04 10:34:27.886  - info: web.0 (4592) ==> Connected system.user.admin from ::ffff:192.168.1.144
                                        2025-02-04 10:35:55.340  - info: fullybrowser.0 (4562) 🗸 192.168.1.144: Command screenOn successfully set to true
                                        2025-02-04 10:38:24.130  - info: fullybrowser.0 (4562) 🗸 192.168.1.144: Command screenOn successfully set to true
                                        2025-02-04 10:42:54.156  - info: fullybrowser.0 (4562) 🗸 192.168.1.144: Command screenOff successfully set to true
                                        2025-02-04 10:44:55.013  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 6197
                                        2025-02-04 10:44:55.859  - info: dwd.0 (6197) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.6
                                        2025-02-04 10:44:56.258  - info: dwd.0 (6197) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2025-02-04 10:44:56.770  - info: host.iobroker instance system.adapter.dwd.0 having pid 6197 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        iob diag has finished.
                                        • M matrose65
                                          @matrose65
                                          ```bash
                                          Script v.2025-02-02
                                          *** BASE SYSTEM ***
                                                   Chassis: vm 🖴
                                            Virtualization: kvm
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          uwe
                                          HOME=/home/uwe
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:           1.0G          0B        1.0G
                                                   1980 M used memory
                                                    655 M active memory
                                                   6299 M free memory
                                                     96 M buffer memory
                                                   3899 M swap cache
                                                    974 M total swap
                                                      0 M used swap
                                                    974 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          461M    /var/
                                          248M    /var/cache
                                          241M    /var/cache/apt
                                          174M    /var/lib
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.4.10
                                          javascript:     8.8.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        8060
                                          States:         6994
                                          Pending Updates: 0
                                          ich sehe da auf Anhieb nichts böses wo ich es vermutet hatte.
                                          Reichlich freier und erst recht verfügbarer Speicher
                                          keinsterlei Belastung des Systems
        *** FILESYSTEM ***
                                          Ausreichend freier Platz auf der Platte und keinerlei Meldung zu Problemen dort.
                                          ALLERDINGS:
                                          ist dieser Port doppelt vergeben.
                                          und hier auch
