  4. Anfrage Tahoma/Somfy IO Adapter
611 Beiträge 103 Kommentatoren 306.3k Aufrufe 86 Beobachtet
    Matt77CHE
    #577
    Bei mir scheint der Adapter seit einigen Tagen nicht mehr zu funktionieren;
    Vorher konnte ich ohne Probleme die Aussenrollos bedienen, seit einigen Tagen geht nichts mehr...:
    tahoma.0
    2024-12-07 09:30:44.154	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup/gateways with payload:{}
    tahoma.0
    2024-12-07 09:30:44.139	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
    tahoma.0
    2024-12-07 09:30:44.139	debug	Update gateway status for id undefined
    tahoma.0
    2024-12-07 09:30:14.138	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup/gateways with payload:{}
    tahoma.0
    2024-12-07 09:30:14.098	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
    tahoma.0
    2024-12-07 09:30:14.098	debug	Update gateway status for id undefined
    tahoma.0
    2024-12-07 09:30:04.185	warn	{"error":{"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.93","port":8443}}
    tahoma.0
    2024-12-07 09:30:04.185	warn	setup failed!
    tahoma.0
    2024-12-07 09:30:04.184	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup with payload:{}
    tahoma.0
    2024-12-07 09:30:04.149	debug	stateChange tahoma.0.update {"val":false,"ack":true,"ts":1733560204147,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1733508840950}
    tahoma.0
    2024-12-07 09:30:04.148	debug	stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1733560204147,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1733560204147}
    tahoma.0
    2024-12-07 09:30:04.098	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup with payload:{}
    tahoma.0
    2024-12-07 09:30:04.097	info	Using stored bearer token 6618c48391938be89f0d
    tahoma.0
    2024-12-07 09:30:04.096	info	Adapter will connect to Tahoma Box via local API.
    tahoma.0
    2024-12-07 09:30:04.095	debug	[START] Started Adapter
    • G Offline
      Gre4t0ne
      #578
      Bei mir funktioniert der Adapter ABER das Protokoll wird mit folgenden Warnings überschwemmt:
      025-01-02 21:31:58.979	warn	Body: {"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""}
      tahoma.0
      2025-01-02 21:31:58.978	warn	Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Thu, 02 Jan 2025 20:31:58 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2080-0101-7321.local:8443","port":"8443","hostname":"gateway-2080-0101-7321.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","href":"https://gateway-2080-0101-7321.local:8443/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 66f2f74093e4a56b44ac","Content-type":"application/json","accept":"application/json","content-length":2}}}
      tahoma.0
      2025-01-02 21:31:58.978	warn	error during request: null, request path: events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch with payload:{}
      tahoma.0
      2025-01-02 21:31:39.043	warn	Body: {"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""}
      tahoma.0
      2025-01-02 21:31:39.042	warn	Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"\"No registered event listener.\""},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Thu, 02 Jan 2025 20:31:39 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2080-0101-7321.local:8443","port":"8443","hostname":"gateway-2080-0101-7321.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch","href":"https://gateway-2080-0101-7321.local:8443/enduser-mobile-web/1/enduserAPI/events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 66f2f74093e4a56b44ac","Content-type":"application/json","accept":"application/json","content-length":2}}}
      tahoma.0
      2025-01-02 21:31:39.042	warn	error during request: null, request path: events/9aac0498-8cbd-4cc9-884b-33532b7fce55/fetch with payload:{}
      oberfraggerO G 2 Antworten Letzte Antwort
      • G Gre4t0ne
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        oberfraggerO Offline
        oberfragger
        #579
        @gre4t0ne Bei mir kein Problem (hab den nur kurz für 1ne Minute gestartet).
        H 1 Antwort Letzte Antwort
        • oberfraggerO oberfragger
          Honnkoponko
          #580
          @oberfragger
          verwendest du Adapter in Lokal Modus via PIN oder ohne PIN?
          Bei mir mit PIN Lokal geht nicht.
          oberfraggerO 1 Antwort Letzte Antwort
          • H Honnkoponko
            @oberfragger
            oberfragger
            #581
            @honnkoponko Nichts lokales. Über die Cloud. Ich habe ein Connectivity Kit.
            https://shop.somfy.de/somfy-connectivity-kit.html
            • G Offline
              Gukerl
              schrieb am zuletzt editiert von Gukerl
              #582
              Ich habe die Tahoma Switch, der Development Mode ist eingeschalten. Im Adapter verwende ich die Standard Einstellungen, Benutzer, Passwort + PIN der Tahoma-Box (z. B. 1234-5678-9012) in den "lokale API Einstellungen".
              Leider bekomme ich beim Start des Adapter immer diese Meldung. Den Adapter habe ich bereits einmal deinstalliert und neu installiert, dann gab's auch wieder ein Token.
              Gibt's irgendwas, das ich falsch machen könnte? Die Box Selbst hat eine fixe IP und ich hab sie sogar per Fritzbox adapter-xxxx-xxxx-xxxx (Pin) genannt.
              Danke für Tipps, Andi :)
              Edit: Neue Fehlermeldung ist aufgetaucht, als ich bim nicht laufenden Adapter was geändert und gespeichert habe:
              tahoma has an invalid jsonConfig:
              [{"instancePath":"/items/basicSettingsTab/items/note","schemaPath":"#/patternProperties/%5E.%2B/allOf/37/then/oneOf","keyword":"oneOf","params":{"passingSchemas":[0,1]},"message":"must match exactly one schema in oneOf"},{"instancePath":"/items/basicSettingsTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                Murphys234d
                schrieb am zuletzt editiert von Murphys234d
                #583
                Achtung: Lokale Api wird wohl mit aktuellem Tahoma Update deaktiviert.
                Ich habe jetzt aus 2 Richtungen gehört, dass mit dem letzten Update nicht nur die angekündigte iftt Unterstützung sondern auch die lokale Api der Tahoma deaktiviert wird.
                Hoffentlich wird es noch gefixt, aber wartet erstmal mit dem Update wenn ihr sie nutzt.
                T G 2 Antworten Letzte Antwort
                • M Murphys234d
                  T Nicht stören
                  T Nicht stören
                  toralt
                  #584
                  @murphys234d HA warnt ebenfalls aktiv und dort funktioniert nur noch der Cloudzugriff nach Update. Ich denke auch, dass das den ioBroker Adapter 1:1 betrifft.
                  << ioBroker im Docker auf Synology DS1821+, 10GBit, 32GB RAM>>
                  ioT4dbI 1 Antwort Letzte Antwort
                  • T toralt
                    ioT4dbI Online
                    ioT4dbI Online
                    ioT4db
                    #585
                    @toralt @Murphys234d ich hab das Update leider schon gemacht. Bei mir ist es so, dass die lokale API nicht komplett deaktiviert wurde, aber scheinbar nicht mehr alle Objekte aktualisiert werden.
                    Raffstores kann ich weiterhin lokal steuern, aber bspw. der Sonnensensor kann nicht mehr lokal abgerufen werden, so scheint es.
                    • ioT4dbI ioT4db
                      Murphys234d
                      #586
                      @iot4db Ich drück die Daumen, dass sie es doch noch wieder fixen.
                      Sonst bleibt wohl nur der Weg über die Cloud.
                      • M Murphys234d
                        Gukerl
                        #587
                        @murphys234d said in Anfrage Tahoma/Somfy IO Adapter:
                        Interessant, denn ich hab den Entwicklermodus erst vor ein paar Tagen aktiviert, als Info bekommt man noch diesen Link: https://github.com/Somfy-Developer
                        Allerdings führt dieser in ein 504 Gateway Time-out, scheint also nicht mehr aktiv zu sein.
                        • G Gre4t0ne
                          tahoma.0
                          tahoma.0
                          tahoma.0
                          tahoma.0
                          tahoma.0
                          gammler2003
                          #588
                          @gre4t0ne Ich habe exakt die selbe Situation - der Adapter funktioniert, aber spuckt in ständig diese Fehlermeldung aus. Ich nutze den Zugang über die lokale API auf eine Tahoma Classic.
                          Gibt es hier in der Runde Ideen, woran das liegen könnte? Vielen Dank euch vorab.
                          • G gammler2003
                            Kanumouse
                            #589
                            Ich habe den gleichen Fehler.
                            Es kommt immer folgende Warnmeldung:
                            Response: {"statusCode":400,"body":"{\"errorCode\":\"UNSPECIFIED_ERROR\",\"error\":\"Unknown object.\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization, Content-Type","content-length":"59","connection":"close","date":"Sat, 01 Feb 2025 15:15:17 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-2052-7119-6399:8443","port":"8443","hostname":"gateway-2052-7119-6399","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/setup","path":"/enduser-mobile-web/1/enduserAPI/setup","href":"https://gateway-2052-7119-6399:8443/enduser-mobile-web/1/enduserAPI/setup"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 65823c3daa66f8769349","Content-type":"application/json"}}}
                            G 1 Antwort Letzte Antwort
                            • K Kanumouse
                              Gukerl
                              #590
                              Es scheint, als hätte Tahoma die API abgedreht.
                              https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues/161
                              LG, Andi
                              • G Gukerl
                                LG, Andi
                                gammler2003
                                #591
                                @gukerl Mit dem aktuellen Update der Tahoma scheint das Problem wieder behoben zu sein. So wird es zumindest auf Github diskutiert und ich bekomme nach dem Update auf meiner Classic auch keine Fehlermeldungen mehr.
                                • G gammler2003
                                  Gukerl
                                  #592
                                  @gammler2003 Vielen DANK für den Hinweis.
                                  Was aber immer noch beim Starten des Adapters passiert:
                                  tahoma has an invalid jsonConfig: [{"instancePath":"/items/basicSettingsTab/items/note","schemaPath":"#/patternProperties/%5E.%2B/allOf/37/then/oneOf","keyword":"oneOf","params":{"passingSchemas":[0,1]},"message":"must match exactly one schema in oneOf"},{"instancePath":"/items/basicSettingsTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                                  Auffällig auch, steuere ich die Somfy Außenrollo mit der Fernbedienung, mache etwas finster, wird der core:ClosureState erst nach einem Neustart des Adapters übernommen. Umgekehrt, die Jalousie mit dem Adapter geht zumindest mit Somfy gar nicht. Bei meinen Velux Dachflächenfenstern klappt es wieder wunderbar.
                                  Zusammengefasst scheint die API nicht ganz durchgängig zu sein.
                                  LG, Andi
                                  • G Gukerl
                                    LG, Andi
                                    ioT4dbI Online
                                    ioT4dbI Online
                                    ioT4db
                                    #593
                                    moin. das meiste scheint wieder zu laufen mit der API. Außer die "actionGroups", die funktionieren jedenfalls bei mir nur über die cloud, nicht aber per API.
                                    Ist das bei jemand anderes auch so?
                                    • ioT4dbI ioT4db
                                      gammler2003
                                      #594
                                      @iot4db Ist bei mir auch so. Ich meine aber, dass das über die lokale API noch nie möglich war.
                                      • W Offline
                                        W Offline
                                        WJ49
                                        schrieb am zuletzt editiert von WJ49
                                        #595
                                        ich habe 15 Velux Rolläden auf dem Dach und mir jetzt die Tahoma Switch zugelegt, mit dem Tahoma Adapter im iobroker verbunden. Über die lokale API.
                                        Unter Jarvis habe ich es so realisiert:
                                        a1a81a89-8b1c-423d-8e52-6ba324ac2c68-1739696097252-d5e44f05-1ca8-413a-a386-3eadff77f037-grafik.png
                                        6123197b-6148-46f5-9cc0-1b27491571ec-1739696159812-af9fdec9-c74a-4a32-9aeb-9ac64c50dedb-grafik.png
                                        Das funktioniert wunderbar. Hier meine Frage:
                                        Wenn ich die Rolläden im Script Blockly über command steuere-open oder steuere-close fahren möchte, stürzt die Tahoma Instanz ab.
                                        Nutze ich aber den state closureState mit 0% oder 100% läuft es.
                                        Wieso kann ich im script die commands nicht nutzen aber einen state zum steuern?
                                        Freue mich auf Eure Antworten.
                                        Gruß Wilfried
                                        • JailobeamJ Offline
                                          JailobeamJ Offline
                                          Jailobeam
                                          #596
                                          Hey Zusammen,
                                          Ich habe seit gestern das problem das meine Box nicht mehr auf gateway-xxxx-xxxx-xxxx als hostnamen reagiert sondern nur auf xxxx-xxxx-xxxx somit ist die lokale api tot und lässt sich nicht verbinden.
                                          hat jemand eine idee wie man es lösen könnte ?
                                          XXXX ist natürlich meine Pin von der BOX die ich auch pingen kann und die Api per Browser erreiche aber nur ohne gateway- vor der Pin
                                          tahoma.0
                                          	2025-04-10 16:34:33.539	warn	error during request: Error: getaddrinfo ENOTFOUND gateway-XXXX-XXXX-XXXX, request path: setup/gateways with payload:{}
                                          tahoma.0
                                          	2025-04-10 16:34:33.537	debug	GET request on https://gateway-XXXX-XXXX-XXXX:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                                          tahoma.0
                                          	2025-04-10 16:34:33.537	debug	Update gateway status for id undefined
                                          ExcodiburE 1 Antwort Letzte Antwort
