  3. Off Topic
  4. Ulanzi TC001 mit Awtrix Light
awtrixulanzitc001
244 Beiträge 37 Kommentatoren 90.3k Aufrufe 35 Beobachtet
    Spiecky
    #222
    Hier noch das Script von der "Wetter-App":
    // v0.2
    const displayTemp = true;
    const appName = 'weather';
    const objIdIcon = 'openweathermap.0.forecast.current.icon';
    const objIdText = 'openweathermap.0.forecast.current.state';
    const objIdTemp = 'hm-rpc.1.00281D898A7B6B.1.ACTUAL_TEMPERATURE';
    const iconMapping = {
        '01d': '11201', // clear sky day
        '01n': '52163', // clear sky night
        '02d': '22315', // few clouds day
        '02n': '26088', // few clouds night
        '03d': '22378', // scattered clouds day
        '03n': '21907', // scattered clouds night
        '04d': '13852', // broken clouds day
        '04n': '52159', // broken clouds night
        '09d': '43706', // shower rain day
        '09n': '43739', // shower rain night
        '10d': '22257', // rain day
        '10n': '72',    // rain night
        '11d': '43733', // thunderstorm day
        '11n': '43748', // thunderstorm night
        '13d': '43732', // snow day
        '13n': '26090', // snow night
        '50d': '43708', // mist day
        '50n': '43741', // mist night
    async function refreshExpertApp() {
        try {
            const iconState = await getStateAsync(objIdIcon);
            if (iconState && iconState.ack && iconState.val) {
                const icon = /([0-9]{2}[d|n]{1})/.exec(iconState.val)[0];
                if (iconMapping[icon]) {
                    await setStateAsync(`awtrix-light.0.apps.${appName}.icon`, { val: iconMapping[icon] });
            let temp = 0;
            const tempState = await getStateAsync(objIdTemp);
            if (tempState && tempState.ack && tempState.val) {
                temp = tempState.val;
            if (temp > 30) {
                await setStateAsync(`awtrix-light.0.apps.${appName}.textColor`, { val: '#bd2020' });
            } else if (temp < 0) {
                await setStateAsync(`awtrix-light.0.apps.${appName}.textColor`, { val: '#236fd9' });
            } else {
                await setStateAsync(`awtrix-light.0.apps.${appName}.textColor`, { val: '#ffffff' });
            const textState = await getStateAsync(objIdText);
            if (textState && textState.ack && textState.val) {
                if (displayTemp) {
                    await setStateAsync(`awtrix-light.0.apps.${appName}.text`, { val: `${textState.val}  ${formatValue(temp, 1)} °C` });
                } else {
                    await setStateAsync(`awtrix-light.0.apps.${appName}.text`, { val: textState.val });
        } catch (err) {
            console.error(err);
    on({ id: [objIdIcon, objIdText, objIdTemp], change: 'ne' }, refreshExpertApp);
    // Init on startup
    refreshExpertApp();
    ESP8266E 1 Antwort Letzte Antwort
    • S Spiecky
      // v0.2
          try {
              let temp = 0;
              if (temp > 30) {
              } else {
                  if (displayTemp) {
                  } else {
          } catch (err) {
              console.error(err);
      // Init on startup
      refreshExpertApp();
      ESP8266E Offline
      ESP8266E Offline
      ESP8266
      schrieb am zuletzt editiert von ESP8266
      #223
      @spiecky , ist doch einfach. Nimm ein Triggerbaustein verknüpfe ihn mit dem Regenmelder Datenpunkt. Stelle den Trigger so, das er auf true und false reagiert.
      Erstell dir unter Users.0 einen Datenpunkt mit dem Namen Regen mit boolean.
      Falls Regen auf true, dann aktualisiere Regen mit "Es regnet".
      Falls Regen auf false, dann aktualisiere Regen mit "Es regnet nicht". Oder den Befehl weg lassen.
      Im Adapter unter Apps (Asche auf mein Haupt) erstellst du dir eine "regen" App und gibtst den Pfad zu Regen an. Icon selber machen oder eins auswählen.
      Fertig.
      • S Spiecky
        @esp8266 Sorry, mein Fehler. Dachte in diesem Thread wird der Adapter Awtrix-Light "behandelt". Peinlich. Kein Wunder das mich keiner versteht hahahaha.....Also ich habe den Adapter Awtrix-Light installiert und in dem gibt es Apps. Einmal die Normalen Benutzerdefinierten Apps und die Experten Apps. Jetzt habe ich mir dort nach Anleitung eine Experten erstellt, über die man dann per Script die aktuellen Wetterdaten aus z.B. Openweather auf der Uhr anzeigen lassen kann. Das Script passt dann die Icons usw. entsprechend an. Dort habe ich auch noch meinen Aussentempwert reinbekommen.
        Jetzt würde ich aber noch gerne meinen Regensensor mit einbinden, in dem eine Art Regen als "Hintergrund läuft", wenn es regnet. Bei den Benutzerdefinierten Apps kann man z.B. einen Hintergrundeffekt aktivieren.
        Falls der Thread hier nichts mit dem Adapter zu tun hat - ignoriert/löscht das ganze einfach ;-)
        haus-automatisierungH Offline
        #224
        @spiecky sagte in Ulanzi TC001 mit Awtrix Light:
        Dafür habe ich in den Experten-Apps noch keinen Datenpunkt bereitgestellt.
        📚 Meine Dokumentation
          Spiecky
          #225
          @haus-automatisierung Stimmt ;-) hahaha.....ja, kein Problem. Der aktuelle Adapter ist schon mega. Vielen Dank dafür. Hatte gehofft man kann das "ganz einfach" im Script "mitschicken" oder selber manuell einen Datenpunkt unter den Objekten bei der Wetter-Experten-App hinzufügen, den man dann per Blockly steuert.
          Muss zugeben, bin noch nicht dahinter gekommen wie das ganze zusammen arbeitet. Also der Adapter, die Datenpunkte, das Script und die Ulanzi/Awtrix. Aber man lernt ja nie aus.......
          Vielen Dank schon mal.
          • ESP8266E ESP8266
            Fertig.
            Spiecky
            #226
            @esp8266 Hi, super Ansatz/Idee, aaaaaaber ;-) ich wollte die Anzahl der angezeigten Apps gerne klein halten, da ich die Ulanzi hauptsächlich als Uhr (wie altmodisch) nutze und es dann immer so lange dauert, bis die Uhrzeit angezeigt wird. Deshalb wollte ich das als nette/hübsche zusätzliche Option in der schon angezeigten Wetter Anzeige einbauen. Ich habe das jetzt erstmal mit einem blauen Marker gelöst. Ist aber optisch nicht so aufregend und nicht speziell genug ;-)
            Trotzdem vielen Dank für die Hilfe. Ich muss mich da noch etwas "reinfuchsen" Irgendwie finde ich darüber nur leider nicht so viel im Netz. Ist jetzt aber auch nicht lebensnotwendig :-)
            HALH 1 Antwort Letzte Antwort
            • S Spiecky
              HALH Offline
              HALH Offline
              HAL
              #227
              Auch ich nutze hauptsächlich die Uhrenanzeige. Gäbe es eine Möglichkeit jeweils die Uhr anzuzeigen, dann eine andere Anzeige, und wieder die Uhr usw. ? Praktische jede zweite Anzeige wäre die Uhr.
              Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
              (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
              • HALH HAL
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #228
                @hal sagte in Ulanzi TC001 mit Awtrix Light:
                Ja, selber eine app mit DP Uhr schreiben
                Danke.
                • bahnuhrB bahnuhr
                  S Nicht stören
                  S Nicht stören
                  stenmic
                  #229
                  hab die Uhr jetzt auch seit ein paar Tagen. Danke für den Adapter.
                  Hättet ihr bedenken, die Uhr dauerhaft am Netzteil zu betreiben trotz eingebauten Akku?
                  Möchte irgendwie ungern am Display rumföhnen.
                  W JLegJ 2 Antworten Letzte Antwort
                  • S stenmic
                    W Offline
                    W Offline
                    Wildbill
                    #230
                    @stenmic Läuft bei mir seit vielen Monaten dauerhaft an 230V. Akku ist eingebaut geblieben. Uhr läuft 24/7 durch, einzig, wenn niemand im Raum ist, wird das Display ausgeschaltet.
                    Gruss, Jürgen
                    • S stenmic
                      JLegJ Offline
                      JLegJ Offline
                      JLeg
                      #231
                      @stenmic läuft bei mir seit 4 Monaten problemlos - wird abends in "deep sleep" geschickt, sodass sie zum Sonnenaufgang wieder aufwacht (PV-Anzeige). Letzteres funktionierte bei mir nur mit Netzteil (Akku drin gelassen) - so aber bislang 100% zuverlässig.
                      (Verbrauch im Deepsleep: 0,7W - nur mit "Display aus" waren's etliche W mehr...)
                      • JLegJ JLeg
                        S Nicht stören
                        S Nicht stören
                        stenmic
                        #232
                        @jleg deep sleep funktioniert nur über Eingabe der Sekunden , oder?
                        JLegJ 1 Antwort Letzte Antwort
                        • S stenmic
                          JLegJ Offline
                          JLegJ Offline
                          JLeg
                          #233
                          @stenmic Ja, ich habe dafür ein kleines Blockly ("seconds2dawn") gebastelt (gibt ja einen bequemen "Daum/Zeit"-Block), plus 2 "Astro"-Trigger für "Sonnenaufgang" und "Nacht"...
                          • JLegJ JLeg
                            HALH Offline
                            HALH Offline
                            HAL
                            #234
                            @jleg spricht etwas dagegen mittels "awtrix-light.0.display.power" das Display nachts auszuschalten und morgens wieder ein ?
                            • HALH HAL
                              JLegJ Offline
                              JLegJ Offline
                              JLeg
                              #235
                              nein, dann ist zumindest ja "Licht aus" - ansonsten läuft die Ulanzi intern natürlich "normal" weiter, d.h. die Stromersparnis beschränkt sich auf die LEDs. Mir waren's halt ein paar Watt zuviel... ;)
                              • S smarthome2020
                                @chka sagte in Ulanzi TC001 mit Awtrix Light:
                                gibt es eigentlich eine Möglichkeit das der ulanzi startet, wenn er per usb-c strom bekommt?
                                ich finde nix darüber
                                Klar, geht. Ich habe den Akku entfernt und nutze die Ulanzi nun nur mit einem ESP32. Das original-Board habe ich also ersetzt, da es mit Stepdown-Converter bei mir nicht funktioniert hat. Läuft aber prima. Die Sensoren habe ich mal nicht mit eingebunden, da ich sie eh nicht brauche.
                                S Nicht stören
                                S Nicht stören
                                stenmic
                                #236
                                @smarthome2020 sagte in Ulanzi TC001 mit Awtrix Light:
                                Kannst du beschreiben, wie du das gemacht hast, oder gibt es einen Link zum "Umbau" auf ESP32?
                                Wäre cool
                                • S stenmic
                                  Wäre cool
                                  ESP8266E Offline
                                  ESP8266E Offline
                                  ESP8266
                                  #237
                                  @stenmic, verstehe die Aussage eh nicht. In der Ulanzi ist doch sowiso ein ESP32 verbaut
                                  Dann wird sie gemacht und die User sind dann verschwunden wenn es um Fragen geht.
                                  Bin mal gespannt, ob sich einer wegen dem Umbau meldet. Glaube ich eher nicht.
                                  • ESP8266E ESP8266
                                    #238
                                    @esp8266 Geht darum, dass man dann den Laderegler, den Akku usw los wird. Braucht man ja eigentlich alles nicht wirklich.
                                      ESP8266E Offline
                                      ESP8266E Offline
                                      ESP8266
                                      #239
                                      @haus-automatisierung , den Laderegler und Co. kann ich von der Platine entfernen.
                                      Dazu benötige ich kein Umbau. Aber es wird ja explizit von einem Umbau geschrieben mit einem ESP32. 🤔
                                      ...und darüber hätte ich gern ein HowTo oder zumindest eine Antwort.. Andere würde das auch intressieren.
                                      • ESP8266E ESP8266
                                        #240
                                        @esp8266 Ja zeig mal. Ich habe noch keinen stabilen Betrieb ohne Akku hinbekommen.
                                        ESP8266E FabioF 3 Antworten Letzte Antwort
                                          ESP8266E Offline
                                          ESP8266E Offline
                                          ESP8266
                                          #241
                                          @haus-automatisierung ,was soll ich zeigen? Ich habe bisher noch nichts an den beiden Ulanzi´s gemacht, aber man könnte statt den Akku ein Goldcap/Supercap einbauen als Stabilsierung. Dann wäre die Gefahr mit dem Akku gebannt. 500 F wären schon mal eine Hausnummer.
