  4. NPM komplettes Update machen?
32 Beiträge 4 Kommentatoren 6.5k Aufrufe 3 Beobachtet
  • M mooly
    Ja, das stimmt wohl.
    pi@raspberrypi:/opt/iobroker $ node -v
    node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
    18.19.0 hat nicht funktioniert, gleicher Fehler.
    ioBroker nodejs fixer 2024-05-23
    You requested to install latest version from nodejs v18 tree.
    Your current setup is:
    nodejs: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    /usr/bin/corepack
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 20.14.0-1nodesource1
      Candidate: 20.14.0-1nodesource1
      Version table:
     *** 20.14.0-1nodesource1 100
         10.24.0~dfsg-1~deb10u3 500
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs . Do you want to install latest version from nodejs v.18 tree?
    @Thomas-Braun er scheint die alte Version nicht zu installieren...
    @mooly
    Dann was aktuelles installieren, mit deinem Backup umziehen.
      @mooly sagte in NPM komplettes Update machen?:
      Hab ich jetzt das ganze System zerschossen...
      @homoran sagte in NPM komplettes Update machen?:
      was sagt iob diag in der Langfassung?
      damit wüssten wir deutlich mehr.
      mooly
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model		: Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       14:52:03 up 2 min,  1 user,  load average: 3.02, 1.11, 0.41
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2024-06-20 14:52:03 CEST
                 Universal time: Thu 2024-06-20 12:52:03 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:           3.8G        1.3G        1.8G        8.0M        672M        2.3G
      Swap:           99M          0B         99M
      Total:         3.9G        1.3G        1.9G
      Active iob-Instances: 	15
               3837 M total memory
               1342 M used memory
                214 M active memory
               1666 M inactive memory
               1822 M free memory
                115 M buffer memory
                557 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 14:52:04 up 2 min,  1 user,  load average: 3.02, 1.11, 0.41
      Tasks: 162 total,   5 running, 157 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 68.5 us, 12.3 sy,  0.0 ni, 17.8 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
      MiB Mem :   3837.7 total,   1797.7 free,   1367.4 used,    672.6 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2310.0 avail Mem
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * lightdm.service loaded failed failed Light Display Manager
      1 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4      110G   17G   89G  16% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      [Thu Jun 20 14:49:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:14:A2:2C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Thu Jun 20 14:50:01 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Jun 20 14:50:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Thu Jun 20 14:50:02 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET                                SOURCE     FSTYPE     OPTIONS
      /                                     /dev/sda2  ext4       rw,noatime
      |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
      | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
      |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
      | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
      | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
      | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
      | | `-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
      | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
      | `-/sys/kernel/config                configfs   configfs   rw,relatime
      |-/proc                               proc       proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=37,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
      | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
      | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
      `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.5G	/var/
      2.0G	/var/cache/apt/archives
      2.0G	/var/cache/apt
      2.0G	/var/cache
      260M	/var/lib
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      287M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      743M	/opt/iobroker/iobroker-data/
      360M	/opt/iobroker/iobroker-data/files
      204M	/opt/iobroker/iobroker-data/history
      126M	/opt/iobroker/iobroker-data/backup-objects
      57M	/opt/iobroker/iobroker-data/files/javascript.admin
      38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
      28M	/opt/iobroker/iobroker-data/objects.jsonl
      22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      13M	/opt/iobroker/iobroker-data/states.jsonl
      9.6M	/opt/iobroker/iobroker-data/files/vis.0/WohnEss301022.png
      USB-Devices by-id:
      /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
      /dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO75C42C-if00-port0
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.20.3
      /usr/bin/node 		v18.20.3
      /usr/bin/npm 		10.7.0
      /usr/bin/npx 		10.7.0
      /usr/bin/corepack 	0.28.0
      nodejs:
        Installed: 18.20.3-1nodesource1
        Candidate: 18.20.3-1nodesource1
        Version table:
       *** 18.20.3-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	6.0.5
      admin: 		6.17.14
      javascript: 	7.8.0
      nodejs modules from github: 	0
      Adapter State
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
        system.adapter.enocean.0                : enocean               : raspberrypi                              -  enabled
        system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
        system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
        system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
        system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
      + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
      + system.adapter.tahoma.0                 : tahoma                : raspberrypi                              -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.17.14  , installed 6.17.14
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.5    , installed 2.11.0 [Updatable]
      Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
      Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
      Adapter    "enocean"      : 0.9.3    , installed 0.9.3
      Adapter    "eusec"        : 1.2.1    , installed 1.2.1
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "iot"          : 3.3.0    , installed 3.2.2  [Updatable]
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 8.6.0    , installed 7.8.0  [Updatable]
      Controller "js-controller": 6.0.5    , installed 6.0.5
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.1  [Updatable]
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "nuki"         : 2.0.0    , installed 1.6.0  [Updatable]
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
      Adapter    "ring"         : 5.0.10   , installed 5.0.10
      Adapter    "scenes"       : 3.0.4    , installed 2.4.2  [Updatable]
      Adapter    "shelly"       : 7.0.0    , installed 6.8.0  [Updatable]
      Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
      Adapter    "tado"         : 0.5.4    , installed 0.5.4
      Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.3.7  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
      Adapter    "vis-map"      : 1.1.0    , installed 1.0.5  [Updatable]
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.7.0, installed 3.6.0 [Updatable]
      Adapter    "web"          : 6.2.6    , installed 6.2.3  [Updatable]
      Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects: 	6795
      States: 	5643
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://repo.homebridge.io stable InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:39793         0.0.0.0:*               LISTEN      1001       22982      1144/io.yahka.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17272      625/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16965      439/cupsd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20193      940/io.mqtt.0
      tcp        0      0 127.0.0.1:34751         0.0.0.0:*               LISTEN      1001       22978      1144/io.yahka.0
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       21698      960/io.shelly.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19732      613/iobroker.js-con
      tcp        0      0 127.0.0.1:38473         0.0.0.0:*               LISTEN      1001       23309      1144/io.yahka.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20777      613/iobroker.js-con
      tcp        0      0 127.0.0.1:41775         0.0.0.0:*               LISTEN      1001       23166      1144/io.yahka.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21089      710/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22650      1064/io.web.0
      tcp6       0      0 :::38389                :::*                    LISTEN      1001       24210      1144/io.yahka.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17274      625/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16964      439/cupsd
      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       29129      2768/go2rtc
      tcp6       0      0 :::8581                 :::*                    LISTEN      116        19012      683/hb-service
      tcp6       0      0 :::51399                :::*                    LISTEN      116        19063      717/homebridge
      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       29123      2768/go2rtc
      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       29126      2768/go2rtc
      udp        0      0 0.0.0.0:43996           0.0.0.0:*                           1001       29045      1791/io.eusec.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       21600      893/io.radar2.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17043      612/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17531      472/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        19064      717/homebridge
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        19009      683/hb-service
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15689      418/avahi-daemon: r
      udp        0      0 0.0.0.0:60685           0.0.0.0:*                           108        15691      418/avahi-daemon: r
      udp        0      0 0.0.0.0:35679           0.0.0.0:*                           1001       29040      1791/io.eusec.0
      udp6       0      0 :::5353                 :::*                                108        15690      418/avahi-daemon: r
      udp6       0      0 :::58643                :::*                                108        15692      418/avahi-daemon: r
      udp6       0      0 :::8555                 :::*                                1001       29127      2768/go2rtc
      2024-06-20 14:51:58.764  - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
      2024-06-20 14:52:00.990  - info: iot.0 (1244) Connection changed: connect "pascal_pbennoit_de"
      2024-06-20 14:52:01.369  - info: host.raspberrypi instance system.adapter.pvforecast.0 started with pid 2067
      2024-06-20 14:52:01.733  - info: tado.0 (1508) starting. Version 0.5.4 in /opt/iobroker/node_modules/iobroker.tado, node: v18.20.3, js-controller: 6.0.5
      2024-06-20 14:52:01.867  - info: tado.0 (1508) Started with JSON-Explorer version 0.1.15
      2024-06-20 14:52:04.148  - info: tado.0 (1508) Connected to Tado cloud, initialyzing...
      2024-06-20 14:52:05.940  - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 2313
      2024-06-20 14:52:07.712  - info: vis-inventwo.0 (1769) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.20.3, js-controller: 6.0.5
      2024-06-20 14:52:08.078  - info: opendtu.0 (1794) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.20.3, js-controller: 6.0.5
      2024-06-20 14:52:08.596  - info: eusec.0 (1791) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.3, js-controller: 6.0.5
      2024-06-20 14:52:09.044  - info: info.0 (1031) Reading network data every 3 seconds.
      2024-06-20 14:52:09.147  - info: opendtu.0 (1794) Connect to OpenDTU over websocket connection.
      2024-06-20 14:52:18.398  - info: eusec.0 (1791) Connected to station T8010P2322101A9A on host 192.168.0.24 and port 16267
      2024-06-20 14:52:19.340  - info: enocean.0 (2313) starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.enocean, node: v18.20.3, js-controller: 6.0.5
      2024-06-20 14:52:19.429  - info: pvforecast.0 (2067) starting. Version 2.9.1 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v18.20.3, js-controller: 6.0.5
      2024-06-20 14:52:19.417  - error: eusec.0 (1791) Station: T8010P2322101A9A command CMD_SDINFO_EX failed with error: undefined (-148)
      2024-06-20 14:52:20.116  - warn: enocean.0 (2313) An error occured at serial port: Error: Error Resource temporarily unavailable Cannot lock port
      2024-06-20 14:52:20.358  - info: eusec.0 (1791) go2rtc started: 14:52:19.735 INF go2rtc version 1.8.5 linux/arm
      14:52:19.738 INF [rtsp] listen addr=:8554
      14:52:19.739 INF [api] listen addr=:1984
      14:52:19.741 INF [webrtc] listen addr=:8555
      2024-06-20 14:52:25.111  - info: tado.0 (1508) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
      2024-06-20 14:52:28.793  - info: pvforecast.0 (2067) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
      2024-06-20 14:52:32.628  - info: eusec.0 (1791) Push notification connection successfully established
      iob diag has finished.
      Press any key for a summary
      • Thomas BraunT Online
        /usr/bin/npm 10.7.0
        /usr/bin/npx 10.7.0
        Ist doch drin...
          @mooly
          mooly
          schrieb am zuletzt editiert von mooly
          Das stellt mich vor ein großes Problem. Das habe ich so noch nie gemacht. Hätte ich das vorher gewusst...
          Ich versuche es weiter.
          • M mooly
            @mooly
            Ich weiß gar nicht wo dein Problem liegt...
            ioBroker Status
            Objects type: jsonl
            States type: jsonl
              @mooly
              ioBroker Status
              Objects type: jsonl
              States type: jsonl
              mooly
              Ich kann aktuell nicht auf meine VIS bzw. Admin zugreifen. Ich vermute gerade ein anderes Problem...
              Ich werde mich auf jeden Fall mal mit dem OS Update beschäftigen. Sorry für die Noob-Fragen. Ich danke euch sehr für eure Unterstützung.
              • M mooly
                In dem iob diag sehe ich auch noch andere Probleme.
                • M mooly
                  Wirst du machen müssen. Der Buster wird nicht lebendiger. Steig von dem toten Pferd runter.
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    mooly
                    Klasse... vielen Dank!
                    • crunchipC Offline
                      crunchipC Offline
                      @mooly sagte in ioBroker komplett neu installieren (Argon ONE mit SSD):
                      dennoch ihr System aktuell halten wollen
                      das ist allerdings ein Zitat aus Juni/2024
                        mooly
                        @crunchip
                        Was genau ist denn jetzt das Problem? Was willst du mir mitteilen?
                        Wenn du nichts konstruktives zum Thema beitragen kannst, sind auch diese Posts unnötig.
                        HomoranH crunchipC 2 Antworten Letzte Antwort
                        -1
                        • M mooly
                          @crunchip
                          @mooly was soll denn das jetzt?
                          Dieser Post von @crunchip wird aufgrund deines crosspostings mit https://forum.iobroker.net/topic/79539/iobroker-komplett-neu-installieren-argon-one-mit-ssd/1 entstanden sein und eine Frage nach der Aktualität der hier genannten Informationen.
                          Oder willst du keine Hilfe mehr?
                          • M mooly
                            @crunchip
                            crunchipC Offline
                            crunchipC Offline
                            Wollte eigentlich im anderen Thread zitieren um die Informationen zu verbinden.
                            Hattest du bereits bekommen und nicht nachgegangen, somit nicht mein, sondern dein Problem
                            Gut zu wissen und für solche Aussagen ist mir die Zeit zu schade.
                            Schöne Abend noch
                              Schöne Abend noch
                              mooly
                              @crunchip
                              Sah für mich eher danach aus, dass man sich daran belustigt, dass seit Juni nix passiert ist und ich erneut nach Unterstützung frage. Bin aber erleichtert, dass das anscheinend nicht der Fall ist.
